05-Layer 2 - LAN Switching
HomeSupportReference GuidesMIB CompanionH3C Wireless Products MIB Reference(E58xx R56xx)-6W10005-Layer 2 - LAN Switching
20-Q-BRIDGE-MIB
20-Q-BRIDGE-MIB 86.94 KB
Q-BRIDGE-MIB
About this MIB
Use this MIB to manage Virtual Bridged Local Area Networks, as defined by IEEE 802.1Q-2003.
MIB file name
rfc4363-qbridge.mib
Root object
iso(1).org(3).dod(6).internet(1).mgmt(2).mib-2(1).dot1dBridge(17).qBridgeMIB(7)
Scalar objects
dot1qConstraintTypeDefault (1.3.6.1.2.1.17.7.1.4.10)
Object (OID)
Access
Value range
Implementation
read-write
INTEGER
independent(1)
shared(2)
The type of constraint set to which a VLAN belongs.
Supports only the read operation.
dot1qVlanVersionNumber (1.3.6.1.2.1.17.7.1.1.1)
Object (OID)
Access
Value range
Implementation
read-only
INTEGER
version1(1)
The version number of IEEE 802.1Q that this device supports.
As per the MIB.
dot1qMaxVlanId (1.3.6.1.2.1.17.7.1.1.2)
Object (OID)
Access
Value range
Implementation
read-only
VlanId
Standard MIB values.
The maximum IEEE 802.1Q VLAN ID that this device supports.
As per the MIB.
dot1qMaxSupportedVlans (1.3.6.1.2.1.17.7.1.1.3)
Object (OID)
Access
Value range
Implementation
read-only
Unsigned32
The maximum number of IEEE 802.1Q VLANs that this device supports.
As per the MIB.
dot1qNumVlans (1.3.6.1.2.1.17.7.1.1.4)
Object (OID)
Access
Value range
Implementation
read-only
Unsigned32
The current number of IEEE 802.1Q VLANs that are configured in this device.
As per the MIB.
Tabular objects
dot1qVlanStaticTable
About this table
Use this table to obtain static configuration information for each VLAN configured into the device.
Support for operations
CreateSupported
Edit/ModifyNot supported
DeleteNot supported
ReadSupported
Columns
The table index is dot1qVlanIndex.
Object (OID)
Access
Value range
Implementation
dot1qVlanStaticUntaggedPorts (1.3.6.1.2.1.17.7.1.4.3.1.4)
read-create
PortList
The set of ports that should transmit egress packets for this VLAN as untagged.
As per the MIB.
dot1qVlanStaticRowStatus (1.3.6.1.2.1.17.7.1.4.3.1.5)
read-create
RowStatus
Status of this VLAN.
Supports only active(1), createAndgo(4) and destroy(6). You cannot delete the default VLAN.
dot1qPortVlanTable
About this table
Use this table to obtain per-port control and status information for VLAN configuration in the device.
CreateNot supported
Edit/ModifySupported
DeleteNot supported
ReadSupported
Columns
The table index is ifIndex.
Object (OID)
Access
Value range
Implementation
dot1qPvid (1.3.6.1.2.1.17.7.1.4.5.1.1)
read-write
VlanIndex
The PVID, the VLAN ID assigned to untagged frames received on this port.
Does not support the write operation on an access port.
dot1qPortAcceptableFrameTypes (1.3.6.1.2.1.17.7.1.4.5.1.2)
read-write
INTEGER
admitAll(1)
admitOnlyVlanTagged(2)
Packet types that this port can receive:
admitOnlyVlanTagged(2)—Drop untagged packets.
admitAll(1)—Accept untagged packets and assign them the PVID.
dot1qPortIngressFiltering (1.3.6.1.2.1.17.7.1.4.5.1.3)
read-write
TruthValue
true(1),
false(2)
When this is true(1), the device will discard incoming frames for VLANs that do not include this port in its member set. When false(2), the port will accept all incoming frames.
