- 05-Layer 2 - LAN Switching
- 01-BRIDGE-MIB
- 02-EtherLike-MIB
- 03-HH3C-LAG-MIB
- 04-HH3C-LPBKDT-MIB
- 05-HH3C-LswMAM-MIB
- 06-HH3C-LswMSTP-MIB
- 07-HH3C-PVST-MIB
- 08-HH3C-VLANGROUP-MIB
- 09-HH3C-LswVLAN-MIB
- 10-IEEE8023-LAG-MIB
- 11-LLDP-EXT-MED-MIB
- 12-LLDP-EXT-DOT1-MIB
- 13-LLDP-EXT-DOT1-V2-MIB
- 14-LLDP-EXT-DOT3-MIB
- 15-LLDP-EXT-DOT3-V2-MIB
- 16-LLDP-MIB
- 17-LLDP-V2-MIB
- 18-MAU-MIB
- 19-P-BRIDGE-MIB
- 20-Q-BRIDGE-MIB
- 21-RBRIDGE-MIB
17-LLDP-V2-MIB | 140.75 KB |
lldpV2MessageTxInterval (1.3.111.2.802.1.1.13.1.1.1)
lldpV2MessageTxHoldMultiplier (1.3.111.2.802.1.1.13.1.1.2)
lldpV2ReinitDelay (1.3.111.2.802.1.1.13.1.1.3)
lldpV2NotificationInterval (1.3.111.2.802.1.1.13.1.1.4)
lldpV2TxCreditMax (1.3.111.2.802.1.1.13.1.1.5)
lldpV2MessageFastTx (1.3.111.2.802.1.1.13.1.1.6)
lldpV2TxFastInit (1.3.111.2.802.1.1.13.1.1.7)
lldpV2StatsRemTablesLastChangeTime (1.3.111.2.802.1.1.13.1.2.1)
lldpV2StatsRemTablesInserts (1.3.111.2.802.1.1.13.1.2.2)
lldpV2StatsRemTablesDeletes (1.3.111.2.802.1.1.13.1.2.3)
lldpV2StatsRemTablesDrops (1.3.111.2.802.1.1.13.1.2.4)
lldpV2StatsRemTablesAgeouts (1.3.111.2.802.1.1.13.1.2.5)
lldpV2LocChassisIdSubtype (1.3.111.2.802.1.1.13.1.3.1)
lldpV2LocChassisId (1.3.111.2.802.1.1.13.1.3.2)
lldpV2LocSysName (1.3.111.2.802.1.1.13.1.3.3)
lldpV2LocSysDesc (1.3.111.2.802.1.1.13.1.3.4)
lldpV2LocSysCapSupported (1.3.111.2.802.1.1.13.1.3.5)
lldpV2LocSysCapEnabled (1.3.111.2.802.1.1.13.1.3.6)
LLDP-V2-MIB
About this MIB
This MIB is compliant with IEEE 802.1AB-2009. It defines MIB objects for the following LLDP information:
· LLDP configuration.
· LLDP statistics.
· LLDP local system information.
· LLDP neighbor system information.
· 802.1 extension.
· DCBX extension.
· 802.3 extension.
MIB file name
lldp-v2.mib
Root object
iso(1).org(3).ieee(111).standards-association-numbers-series-standards(2).lan-man-stds(802).ieee802dot1(1).ieee802dot1mibs(1).lldpV2MIB(13)
Scalar objects
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
lldpV2MessageTxInterval (1.3.111.2.802.1.1.13.1.1.1) |
read-write |
Unsigned32 |
Unsigned32 (5..32768) |
LLDP frame transmission interval. |
As per the MIB. |
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
lldpV2MessageTxHoldMultiplier (1.3.111.2.802.1.1.13.1.1.2) |
read-write |
Unsigned32 |
Unsigned32 (2..10) |
TTL multiplier. |
As per the MIB. |
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
lldpV2ReinitDelay (1.3.111.2.802.1.1.13.1.1.3) |
read-write |
Unsigned32 |
Unsigned32 (1..10) |
LLDP reinitialization delay. |
As per the MIB. |
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
lldpV2NotificationInterval (1.3.111.2.802.1.1.13.1.1.4) |
read-write |
Unsigned32 |
Unsigned32 (5..3600) |
Trap transmission interval. |
As per the MIB. |
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
lldpV2TxCreditMax (1.3.111.2.802.1.1.13.1.1.5) |
read-write |
Unsigned32 |
Unsigned32 (1..100) |
Token bucket size for sending LLDP frames. |
As per the MIB. |
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
lldpV2MessageFastTx (1.3.111.2.802.1.1.13.1.1.6) |
read-write |
Unsigned32 |
Unsigned32 (1..3600) |
Fast LLDP frame transmission interval. |
As per the MIB. |
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
lldpV2TxFastInit (1.3.111.2.802.1.1.13.1.1.7) |
read-write |
Unsigned32 |
Unsigned32 (1..8) |
Number of LLDP frames sent each time fast LLDP frame transmission is triggered. |
As per the MIB. |
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
lldpV2StatsRemTablesLastChangeTime (1.3.111.2.802.1.1.13.1.2.1) |
read-only |
TimeStamp |
Standard MIB values. |
Time when LLDP information about a neighboring device was last updated. |
As per the MIB. |
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
lldpV2StatsRemTablesInserts (1.3.111.2.802.1.1.13.1.2.2) |
read-only |
ZeroBasedCounter32 |
Number of neighbors added by LLDP. |
As per the MIB. |
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
lldpV2StatsRemTablesDeletes (1.3.111.2.802.1.1.13.1.2.3) |
read-only |
Number of neighbors deleted by LLDP. |
As per the MIB. |
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
lldpV2StatsRemTablesDrops (1.3.111.2.802.1.1.13.1.2.4) |
read-only |
Number of neighbors discarded by LLDP. |
As per the MIB. |
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
lldpV2StatsRemTablesAgeouts (1.3.111.2.802.1.1.13.1.2.5) |
read-only |
Neighbor ageout count. |
As per the MIB. |
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
lldpV2LocChassisIdSubtype (1.3.111.2.802.1.1.13.1.3.1) |
read-only |
LldpV2ChassisIdSubtype |
Local chassis ID subtype. |
As per the MIB. |
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
lldpV2LocChassisId (1.3.111.2.802.1.1.13.1.3.2) |
read-only |
LldpV2ChassisId |
Local chassis ID. |
As per the MIB. |
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
lldpV2LocSysName (1.3.111.2.802.1.1.13.1.3.3) |
read-only |
SnmpAdminString |
OCTET STRING (0..255) |
Local system name. |
As per the MIB. |
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
lldpV2LocSysDesc (1.3.111.2.802.1.1.13.1.3.4) |
read-only |
SnmpAdminString |
Local system description. |
As per the MIB. |
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
lldpV2LocSysCapSupported (1.3.111.2.802.1.1.13.1.3.5) |
read-only |
LldpV2SystemCapabilitiesMap |
Capabilities supported by the local system. |
As per the MIB. |
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
lldpV2LocSysCapEnabled (1.3.111.2.802.1.1.13.1.3.6) |
read-only |
Capabilities enabled on the local system. |
As per the MIB. |
Tabular objects
lldpV2RemUnknownTLVTable
About this table
Use this table to display the unrecognized TLVs received from neighbors.
Support for operations
Create:Not supported
Edit/Modify:Not supported
Delete:Not supported
Read:Supported
Columns
The table indexes are lldpV2RemTimeMark, lldpV2RemLocalIfIndex, lldpV2RemLocalDestMACAddress, lldpV2RemIndex, and lldpV2RemUnknownTLVType.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
lldpV2RemUnknownTLVType (1.3.111.2.802.1.1.13.1.4.3.1.1) |
not-accessible |
Unsigned32 |
Unsigned32 (9..126) |
TLV type. |
As per the MIB. |
lldpV2RemUnknownTLVInfo (1.3.111.2.802.1.1.13.1.4.3.1.2) |
read-only |
OCTET STRING |
OCTET STRING (0..511) |
TLV string. |
As per the MIB. |
lldpV2RemOrgDefInfoTable
About this table
Use this table to display the neighbor organizationally defined information not recognized by the local system.
Read:Supported
Columns
The table indexes are lldpV2RemTimeMark, lldpV2RemLocalIfIndex, lldpV2RemLocalDestMACAddress, lldpV2RemIndex, lldpV2RemOrgDefInfoOUI, lldpV2RemOrgDefInfoSubtype, and lldpV2RemOrgDefInfoIndex.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
lldpV2RemOrgDefInfoOUI (1.3.111.2.802.1.1.13.1.4.4.1.1) |
not-accessible |
OCTET STRING |
OCTET STRING (3) |
Organizationally Unique Identifier (OUI). |
As per the MIB. |
lldpV2RemOrgDefInfoSubtype (1.3.111.2.802.1.1.13.1.4.4.1.2) |
not-accessible |
Unsigned32 |
Unsigned32 (1..255) |
Subtype of the organizationally defined information. |
As per the MIB. |
lldpV2RemOrgDefInfoIndex (1.3.111.2.802.1.1.13.1.4.4.1.3) |
not-accessible |
Unsigned32 |
Unsigned32 (1..2147483647) |
Index of the organizationally defined information. |
As per the MIB. |
lldpV2RemOrgDefInfo (1.3.111.2.802.1.1.13.1.4.4.1.4) |
read-only |
OCTET STRING |
OCTET STRING (0..507) |
Organizationally defined information. |
As per the MIB. |
Notifications
lldpV2RemTablesChange
Basic information
OID |
Event |
Type |
Severity |
Recovery notification |
Default status |
1.3.111.2.802.1.1.13.0.0.1 |
LLDP polling is triggered. |
Informational |
Warning |
OFF |
Notification triggers
This notification is generated when the value of the lldpV2StatsRemTableLastChangeTime object changes. The network management system can use this notification to trigger LLDP polling to facilitate maintaining remote system entries.
You can set the notification transmission interval by configuring the lldpV2NotificationInterval object.
System impact
No impact on the system.
Status control
ON
CLI: Use the lldp notification remote-change enable command.
MIB: Set the lldpV2PortConfigNotificationEnable object to true(1).
OFF
CLI: Use the undo lldp notification remote-change enable command.
MIB: Set the lldpV2PortConfigNotificationEnable object to false(2).
Object
OID (object name) |
Index |
Type |
Value range |
Neighbor creation. |
N/A |
Neighbor deletion. |
N/A |
Neighbor discard. |
N/A |
Neighbor ageout. |
N/A |
Recommended action
Verify that the topology changes are as expected.
If the issue persists, collect alarm information and configuration data, and then contact H3C Support for help.
