- 05-Layer 2 - LAN Switching
- 01-BRIDGE-MIB
- 02-EtherLike-MIB
- 03-HH3C-LAG-MIB
- 04-HH3C-LPBKDT-MIB
- 05-HH3C-LswMAM-MIB
- 06-HH3C-LswMSTP-MIB
- 07-HH3C-PVST-MIB
- 08-HH3C-VLANGROUP-MIB
- 09-HH3C-LswVLAN-MIB
- 10-IEEE8023-LAG-MIB
- 11-LLDP-EXT-MED-MIB
- 12-LLDP-EXT-DOT1-MIB
- 13-LLDP-EXT-DOT1-V2-MIB
- 14-LLDP-EXT-DOT3-MIB
- 15-LLDP-EXT-DOT3-V2-MIB
- 16-LLDP-MIB
- 17-LLDP-V2-MIB
- 18-MAU-MIB
- 19-P-BRIDGE-MIB
- 20-Q-BRIDGE-MIB
- 21-RBRIDGE-MIB
10-IEEE8023-LAG-MIB | 70.56 KB |
IEEE8023-LAG-MIB
About this MIB
This MIB defines MIB objects for the following information:
· Aggregate interface configuration.
· Aggregation member port list.
· Aggregation member port configuration.
· Traffic statistics.
· State machine information about aggregation member ports.
MIB file name
ieee8023-lag.mib
Root object
iso(1).member-body(2).us(840).802dot3(10006).snmpmibs(300).lagMIB(43)
Tabular objects
dot3adAggPortDebugTable
About this table
Use this table to obtain state machine information about aggregation member ports.
Support for operations
Create:Not supported
Edit/Modify:Not supported
Delete:Not supported
Read:Supported
Columns
The table index is dot3adAggPortDebugRxState.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
dot3adAggPortDebugActorChangeCount (1.2.840.10006.300.43.1.2.3.1.11) |
read-only |
Counter32 |
Standard MIB values. |
Number of times the Actor Churn state machine has changed status. |
As per the MIB. |
dot3adAggPortDebugPartnerChangeCount (1.2.840.10006.300.43.1.2.3.1.12) |
read-only |
Counter32 |
Number of times the Partner Churn state machine has changed status. |
As per the MIB. |
