05-Layer 2 - LAN Switching
HomeSupportReference GuidesMIB CompanionH3C Wireless Products MIB Reference(E58xx R56xx)-6W10005-Layer 2 - LAN Switching
04-HH3C-LPBKDT-MIB
04-HH3C-LPBKDT-MIB 199.14 KB
HH3C-LPBKDT-MIB
About this MIB
The loop detection mechanism performs periodic checking for Layer 2 loops and processes the interfaces with loops as configured.
Use this MIB to perform the following tasks:
·     Generate traps when the loop state of an interface changes.
·     Configure and view the loop detection state, loop protection action, and loop detection interval for VLANs globally.
·     Configure and view the loop detection state, loop protection action, and loop detection interval for VLANs on an interface.
MIB file name
hh3c-lpbkdt.mib
Root object
iso(1).org(3).dod(6).internet(1).private(4).enterprises(1).hh3c(25506).h3cCommon(2).hh3cDldp2Lpbkdt(95)
Scalar objects
hh3cLpbkdtVlanID (1.3.6.1.4.1.25506.2.95.2.1)
Object (OID)
Access
Value range
Implementation
accessible-for-notify
INTEGER
1..4094
VLAN ID in reported trap messages when a loop is detected or eliminated on an interface.
As per the MIB.
hh3cLpbkdtVlanEnable (1.3.6.1.4.1.25506.2.95.2.2)
Object (OID)
Access
Value range
Implementation
read-write
OCTET STRING
OCTET STRING (1..512)
Enable or disable loop detection for VLANs globally.
As per the MIB.
hh3cLpbkdtAction (1.3.6.1.4.1.25506.2.95.2.3)
Object (OID)
Access
Value range
Implementation
read-write
INTEGER
none (1),
block(2),
nolearning(3),
shutdown(4)
Configure the global loop protection action, which is to take on all ports where loops are detected.
In the current software version, only the log and shutdown operations are supported, and the block and nolearning actions are not supported.
hh3cLpbkdtIntervalTime (1.3.6.1.4.1.25506.2.95.2.4)
Object (OID)
Access
Value range
Implementation
read-write
Integer32
1..300
Loop detection interval.
As per the MIB.
hh3cLpbkdtVsiName (1.3.6.1.4.1.25506.2.95.1.1.1)
Object (OID)
Access
Value range
Implementation
OCTET STRING
OCTET STRING0..255
VSI name.
As per the MIB.
hh3cLpbkdtSVlanID (1.3.6.1.4.1.25506.2.95.1.1.2)
Object (OID)
Access
Value range
Implementation
Integer32
Integer32 (1..4094)
SVLAN ID.
As per the MIB.
hh3cLpbkdtCVlanID (1.3.6.1.4.1.25506.2.95.1.1.3)
Object (OID)
Access
Value range
Implementation
Integer32
Integer32 (1..4094)
CVLAN ID.
As per the MIB.
hh3cLpbkdtACName (1.3.6.1.4.1.25506.2.95.1.1.4)
Object (OID)
Access
Value range
Implementation
OCTET STRING
OCTET STRING0..255
AC name.
As per the MIB.
Tabular objects
hh3cLpbkdtPortTable
About this table
Use this table to configure loop detection on a port.
Support for operations
CreateSupported
Edit/ModifySupported
DeleteSupported
ReadSupported
Columns
The table index is hh3cLpbkdtPortIndex.
Object (OID)
Access
Value range
Implementation
hh3cLpbkdtPortIfIndex (1.3.6.1.4.1.25506.2.95.2.5.1.1)
not-accessible
INTEGER
1..2147483647
Interface index.
As per the MIB.
hh3cLpbkdtPortVlanEnable (1.3.6.1.4.1.25506.2.95.2.5.1.2)
read-write
OCTET STRING
Enable or disable loop detection for VLANs on a port.
As per the MIB.
hh3cLpbkdtPortAction (1.3.6.1.4.1.25506.2.95.2.5.1.3)
read-write
INTEGER
none (1),
block(2),
nolearning(3),
shutdown(4)
Configure the loop protection action for a port, which is to take on the port when a loop is detected.
An aggregate interface supports only the log and shutdown actions. The other interfaces support all actions.
hh3cLpbkdtPortLoopbacked (1.3.6.1.4.1.25506.2.95.2.5.1.4)
read-only
TruthValue
true(1),
false(2)
Check for a loop on a port.
As per the MIB.
Notifications
hh3cLpbkdtTrapLoopbacked
Basic information
OID
Event
Severity
Recovery notification
Default status
1.3.6.1.4.1.25506.2.95.1.0.1
Loops occur on an interface.
Error
Warning
1.3.6.1.4.1.25506.2.95.1.0.2 (hh3cLpbkdtTrapRecovered)
ON
Notification triggers
This notification is generated when the device receives loop detection frames sent by the device itself.
System impact
If you do not remove loops, the broadcast storm caused by loops might cause network congestion or even cause the network to break down.
After loops are removed, the system impact varies by the following loop detection actions:
Block—Disables the interface from learning MAC addresses and blocks the interface.
No-learning—Disables the interface from learning MAC addresses.
Shutdown—Shuts down the interface to disable it from receiving and sending any frames.
VLAN-block—Blocks traffic of the protected VLAN where the loop is detected on the interface.
Status control
This notification cannot be disabled.
Object
OID (object name)
Index
Value range
6.1.4.1.2.1.2.2.1.1
 (ifIndex)
Interface index
ifIndex
Integer32
Integer32 (1..2147483647)
1.3.6.1.2.1.2.2.1.2 (ifDescr)
Interface name
ifIndex
OCTET STRING
OCTET STRING(0..255)
Recommended action
To resolve this issue:
1.Check whether a Layer 2 loop occurs on the interface.
2.Change the network physical topology to remove the Layer 2 loop.
3.If the issue persists, collect alarm information and configuration data, and then contact H3C Support for help.
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.2.95.1.0. 2
Loops are removed from an interface.
Recovery
Warning
N/A (N/A)
ON
This notification is generated when the device does not receive a loop detection frame within the loop detection interval.
System impact
The interface is restored to the normal forwarding state and the interface services are recovered.
Status control
Object
OID (object name)
Index
Value range
1.3.6.1.2.1.2.2.1.1
 (ifIndex)
Interface index
ifIndex
Integer32
Interface name
ifIndex
OCTET STRING
Recommended action
No action is required.
hh3cLpbkdtTrapPerVlanLoopbacked
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.2.95.1.0.3
Loops occur on an interface in a specific VLAN.
Error
Warning
1.3.6.1.4.1.25506.2.95.1.0.4 (hh3cLpbkdtTrapPerVlanRecovered)
ON
This notification is generated when the device receives loop detection frames sent by the device itself in a specific VLAN.
System impact
Status control
Object
OID (object name)
Index
Value range
1.3.6.1.2.1.2.2.1.1
 (ifIndex)
Interface index
ifIndex
Integer32
1.3.6.1.2.1.2.2.1.2
 (ifDescr)
Interface name
ifIndex
OCTET STRING
1.3.6.1.4.1.25506.2. 2/1/1995 (hh3cLpbkdtVlanID)
VLAN ID
N/A
Integer32
Integer32 (1..4094)
Recommended action
Basic information
OID
Event
Severity
Default status
Loops are removed from an interface in a specific VLAN.
Recovery
Warning
N/A (N/A)
ON
This notification is generated when the device does not receive a loop detection frame in a specific VLAN within the loop detection interval.
System impact
The interface is restored to the normal forwarding state in the VLAN and the VLAN services are recovered.
Status control
Object
OID (object name)
Index
Value range
1.3.6.1.2.1.2.2.1.1
 (ifIndex)
Interface index
ifIndex
Integer32
1.3.6.1.2.1.2.2.1.2
 (ifDescr)
Interface name
ifIndex
OCTET STRING
VLAN ID
N/A
Integer32
Integer32 (1..4094)
Recommended action
hh3cLpbkdtTrapVsiLoopbacked
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.2.95.1.0.5
Loops occur on an AC.
Error
Warning
1.3.6.1.4.1.25506.2.95.1.0.6 (hh3cLpbkdtTrapVsiRecovered)
ON
This notification is generated when an AC receives a loop detection frame that carries the AC's VXLAN ID.
System impact
Block—Disables the AC from learning MAC addresses and blocks the AC.
Shutdown—Shuts down the interface where the AC resides to disable it from receiving and sending any frames.
Status control
Object
OID (object name)
Index
Value range
1.3.6.1.2.1.2.2.1.1
 (ifIndex)
Interface index
ifIndex
Integer32
 (hh3cLpbkdtVsiName)
VSI name
N/A
OCTET STRING
 (hh3cLpbkdtSVlanID)
SVLAN ID
N/A
Integer32
Integer32 (1..4094)
 (hh3cLpbkdtCVlanID)
CVLAN ID
N/A
Integer32
Integer32 (1..4094)
1.3.6.1.4.1.25506.2.95.1.1.4 (hh3cLpbkdtACName)
AC name
N/A
OCTET STRING
Recommended action
1.Check whether a Layer 2 loop occurs on the interface where the AC resides.
Basic information
OID
Event
Severity
Default status
Loops are removed from an AC.
Recovery
Warning
N/A (N/A)
ON
This notification is generated when an AC does not receive a loop detection frame that carries the AC's VXLAN ID within the loop detection interval.
System impact
The AC is restored to the normal forwarding state and the AC services are recovered.
Status control
Object
OID (object name)
Index
Value range
1.3.6.1.2.1.2.2.1.1
 (ifIndex)
Interface index
ifIndex
Integer32
 (hh3cLpbkdtVsiName)
VSI name
N/A
OCTET STRING
AC name
N/A
OCTET STRING
Recommended action
hh3cLpbkdtTrapActionLOG
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.2.95.1.0.7
A loop occurs on an interface and a log message is generated.
Error
Warning
1.3.6.1.4.1.25506.2.95.1.0.8 (hh3cLpbkdtTrapActionLOGClear)
ON
This notification is generated when the interface is in loopback state and the processing action uses the default.
System impact
Status control
Object
OID (object name)
Index
Value range
1.3.6.1.2.1.2.2.1.1
 (ifIndex)
Interface index
ifIndex
Integer32
Interface name
ifIndex
OCTET STRING
OCTET STRING (0..255)
Recommended action
Basic information
OID
Event
Severity
Default status
A loop is removed or the processing action is changed and a log message is generated.
Recovery
Warning
N/A (N/A)
ON
This notification is generated when the loop is removed or the processing action is changed.
System impact
When loops are removed, services are recovered on the interface where loops occur.
Status control
Object
OID (object name)
Index
Value range
1.3.6.1.2.1.2.2.1.1
 (ifIndex)
Interface index
ifIndex
Integer32
Interface name
ifIndex
OCTET STRING
Recommended action
hh3cLpbkdtTrapActionBlock
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.2.95.1.0.9
A loop occurs on an interface and the processing action is block
Error
Warning
1.3.6.1.4.1.25506.2.95.1.0.10 (hh3cLpbkdtTrapActionBlockClear)
ON
This notification is generated when the device receives loop detection frames sent by the device itself and the processing action is block.
System impact
A loop occurs on an interface in a VLAN, and the interface is blocked.
Status control
Object
OID (object name)
Index
Value range
1.3.6.1.2.1.2.2.1.1
 (ifIndex)
Interface index
ifIndex
Integer32
Interface name
ifIndex
OCTET STRING
Recommended action
Basic information
OID
Event
Severity
Default status
The blocked interface is restored to the normal forwarding state.
Recovery
Warning
N/A (N/A)
ON
The loop is considered removed if no loop detection packets are received on the blocked interface within three loop detection intervals.
System impact
Status control
Object
OID (object name)
Index
Value range
1.3.6.1.2.1.2.2.1.1
 (ifIndex)
Interface index
ifIndex
Integer32
Interface name
ifIndex
OCTET STRING
Recommended action
hh3cLpbkdtTrapActionDown
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.2.95.1.0.11
A loop occurs on an interface and the processing action is shutdown
Error
Warning
1.3.6.1.4.1.25506.2.95.1.0.12 (hh3cLpbkdtTrapActionDownClear)
ON
This notification is generated when the device receives loop detection frames sent by the device itself and the interface goes down.
System impact
The device shuts down the interface where a loop occurs to disable it from receiving and sending any frames.
Status control
Object
OID (object name)
Index
Value range
1.3.6.1.2.1.2.2.1.1
 (ifIndex)
Interface index
ifIndex
Integer32
Interface name
ifIndex
OCTET STRING
Recommended action
Basic information
OID
Event
Severity
Default status
The shutdown interface is restored
Recovery
Warning
N/A (N/A)
ON
After the interface where a loop occurs is shut down, the interface is restored after the interval configured by using the shutdown-interval command.
System impact
The interface is restored to the normal forwarding state. If the loop still exists on the interface, the interface will be shut down and then restored repeatedly until the loop is removed.
Status control
Object
OID (object name)
Index
Value range
1.3.6.1.2.1.2.2.1.1
 (ifIndex)
Interface index
ifIndex
Integer32
Interface name
ifIndex
OCTET STRING
Recommended action
If the interface is shut down after it is restored, perform the following tasks:
If the interface is not shut down after it is restored, no action is required.
