- 13-MPLS
- 01-HH3C-L2VPN-MIB
- 02-HH3C-MPLSEXT-MIB
- 03-HH3C-MPLSTE-MIB
- 04-HH3C-VSI-MIB
- 05-MPLS-FRR-FACILITY-STD-MIB
- 06-MPLS-FRR-GENERAL-STD-MIB
- 07-MPLS-FTN-STD-MIB
- 08-MPLS-L3VPN-STD-MIB
- 09-MPLS-LDP-STD-MIB
- 10-MPLS-LSR-STD-MIB
- 11-MPLS-TE-STD-MIB
- 12-PW-ENET-STD-MIB
- 13-PW-MPLS-STD-MIB
- 14-PW-STD-MIB
- 15-TE-MIB
08-MPLS-L3VPN-STD-MIB | 154.94 KB |
mplsL3VpnConfiguredVrfs (1.3.6.1.2.1.10.166.11.1.1.1)
mplsL3VpnActiveVrfs (1.3.6.1.2.1.10.166.11.1.1.2)
mplsL3VpnConnectedInterfaces (1.3.6.1.2.1.10.166.11.1.1.3)
mplsL3VpnNotificationEnable (1.3.6.1.2.1.10.166.11.1.1.4)
mplsL3VpnVrfConfMaxPossRts (1.3.6.1.2.1.10.166.11.1.1.5)
mplsL3VpnVrfConfRteMxThrshTime (1.3.6.1.2.1.10.166.11.1.1.6)
mplsL3VpnIllLblRcvThrsh (1.3.6.1.2.1.10.166.11.1.1.7)
MPLS-L3VPN-STD-MIB
About this MIB
Use this MIB to obtain MPLS VPN information.
MIB file name
rfc4382-mpls-l3vpn-std.mib
Root object
iso(1).org(3).dod(6).internet(1).mgmt(2).mib-2(1).transmission(10).mplsStdMIB(166).mplsL3VpnMIB(11)
Scalar objects
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
mplsL3VpnConfiguredVrfs (1.3.6.1.2.1.10.166.11.1.1.1) |
read-only |
Unsigned32 |
Standard MIB values. |
Number of configured VRFs. |
As per the MIB. |
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
mplsL3VpnActiveVrfs (1.3.6.1.2.1.10.166.11.1.1.2) |
read-only |
Gauge32 |
INTEGER(0..4294967295) |
Number of VRFs in up state. |
As per the MIB. |
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
mplsL3VpnConnectedInterfaces (1.3.6.1.2.1.10.166.11.1.1.3) |
read-only |
Gauge32 |
Number of interfaces bound to the VRF. |
As per the MIB. |
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
mplsL3VpnNotificationEnable (1.3.6.1.2.1.10.166.11.1.1.4) |
read-write |
TruthValue |
true(1), false(2) |
Whether MPLS L3VPN notification is enabled. |
As per the MIB. |
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
mplsL3VpnVrfConfMaxPossRts (1.3.6.1.2.1.10.166.11.1.1.5) |
read-only |
Unsigned32 |
Maximum number of routes that all VRFs on the device can have. |
As per the MIB. This object is not supported. The return value is always 0. |
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
mplsL3VpnVrfConfRteMxThrshTime (1.3.6.1.2.1.10.166.11.1.1.6) |
read-only |
Unsigned32 |
Interval at which the route max threshold notification is regenerated after the maximum route number is exceeded (or reached if mplsL3VpnVrfConfMaxRoutes and mplsL3VpnVrfConfHighRteThresh are equivalent) and the initial notification is sent. If this value is set to 0, the agent generates only one notification when maximum route number is reached. |
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
mplsL3VpnIllLblRcvThrsh (1.3.6.1.2.1.10.166.11.1.1.7) |
read-write |
Unsigned32 |
Number of received incorrect labels. |
Supports only the read operation. This object is not supported. The return value is always 32. |
Tabular objects
mplsL3VpnIfConfTable
About this table
This table specifies MPLS capability and associated VPNs for an interface.
Support for operations
Create |
Edit/Modify |
Delete |
Read |
Supported |
Supported |
Supported |
Supported |
Columns
The table indexes are mplsL3VpnVrfName and mplsL3VpnIfConfIndex.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
mplsL3VpnIfConfIndex(1.3.6.1.2.1.10.166.11.1.2.1.1.1) |
not-accessible |
InterfaceIndex |
Integer32(1..2147483647) |
Interface index. |
As per the MIB. |
mplsL3VpnIfVpnClassification(1.3.6.1.2.1.10.166.11.1.2.1.1.2) |
read-create |
INTEGER |
carrierOfCarrier (1), enterprise (2), interProvider (3) |
Interface category. |
Supports only the read operation. |
mplsL3VpnIfVpnRouteDistProtocol (1.3.6.1.2.1.10.166.11.1.2.1.1.3) |
read-create |
BITS |
none (0), bgp (1), ospf (2), rip(3), isis(4), static(5), other (6) |
Route distribution protocol. |
mplsL3VpnIfConfStorageType (1.3.6.1.2.1.10.166.11.1.2.1.1.4) |
read-create |
StorageType |
INTEGER { other(1), volatile(2), nonVolatile(3), permanent(4), readOnly(5) } |
Storage type of the interface. |
mplsL3VpnIfConfRowStatus (1.3.6.1.2.1.10.166.11.1.2.1.1.5) |
read-create |
RowStatus |
active(1), notInService(2), notReady(3), createAndGo(4), createAndWait(5), destroy(6) |
Row status. |
As per the MIB. |
mplsL3VpnVrfTable
About this table
This table contains VRF configuration information.
Create |
Edit/Modify |
Delete |
Read |
Supported |
Supported |
Supported |
Supported |
Columns
The table index is mplsL3VpnVrfName.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
mplsL3VpnVrfName (1.3.6.1.2.1.10.166.11.1.2.2.1.1) |
not-accessible |
MplsL3VpnName |
OCTET STRING (0..31) |
VRF name. |
As per the MIB. |
mplsL3VpnVrfVpnId (1.3.6.1.2.1.10.166.11.1.2.2.1.2) |
read-create |
VPNIdOrZero |
OCTET STRING (0 | 7) |
VPN ID. |
As per the MIB. |
mplsL3VpnVrfDescription (1.3.6.1.2.1.10.166.11.1.2.2.1.3) |
read-create |
SnmpAdminString |
OCTET STRING (0..255) |
VRF description. |
As per the MIB. |
mplsL3VpnVrfRD (1.3.6.1.2.1.10.166.11.1.2.2.1.4) |
read-create |
MplsL3VpnRouteDistinguisher |
OCTET STRING(0..256) |
Configured RD. By default, a get operation obtains the global RD. If no global RD is configured, it obtains the RD for the IPv4 unicast address family. If the IPv4 unicast address family RD is not configured either, "0:0" is displayed. |
As per the MIB. |
mplsL3VpnVrfCreationTime (1.3.6.1.2.1.10.166.11.1.2.2.1.5) |
read-only |
TimeStamp |
TimeTicks |
Time when the VRF entry was created. |
As per the MIB. |
mplsL3VpnVrfOperStatus (1.3.6.1.2.1.10.166.11.1.2.2.1.6) |
read-only |
INTEGER |
up (1), down (2) |
Up/down state. |
As per the MIB. |
mplsL3VpnVrfActiveInterfaces (1.3.6.1.2.1.10.166.11.1.2.2.1.7) |
read-only |
Gauge32 |
Number of associated interfaces in up state. |
As per the MIB. |
mplsL3VpnVrfAssociatedInterfaces (1.3.6.1.2.1.10.166.11.1.2.2.1.8) |
read-only |
Unsigned32 |
Number of associated interfaces. |
As per the MIB. |
mplsL3VpnVrfConfMidRteThresh (1.3.6.1.2.1.10.166.11.1.2.2.1.9) |
read-create |
Unsigned32 |
The value for mplsL3VpnVrfConfMidRteThresh depends on the route limit set by using the routing-table limit command. If the route limit is not configured, the value for mplsL3VpnVrfConfMidRteThresh is the system-defined route limit value. If the route limit is configured as X and the action is configured as simply-alert, the value for mplsL3VpnVrfConfMidRteThresh is the configured route limit value X. If the route limit is configured as X and a warning threshold is set to Y%, the value for mplsL3VpnVrfConfMidRteThresh is X*Y%. The value for mplsL3VpnVrfConfMidRteThresh is the sum of the route limits for both IPv4 and IPv6 routes, calculated using the previous rules. |
mplsL3VpnVrfConfHighRteThresh (1.3.6.1.2.1.10.166.11.1.2.2.1.10) |
read-create |
Unsigned32 |
The value for mplsL3VpnVrfConfHighRteThresh depends on the route limit set by using the routing-table limit command. If the route limit is not configured or is configured with the simply-alert action, the value for mplsL3VpnVrfConfHighRteThresh is the system-defined route limit value. If the route limit is configured as X and a warning threshold is set to Y%, the value for mplsL3VpnVrfConfHighRteThresh is X. |
mplsL3VpnVrfConfMaxRoutes (1.3.6.1.2.1.10.166.11.1.2.2.1.11) |
read-create |
Unsigned32 |
Maximum number of routes that this VRF can hold. |
mplsL3VpnVrfConfLastChanged (1.3.6.1.2.1.10.166.11.1.2.2.1.12) |
read-only |
TimeStamp |
TimeTicks |
Time when the entry changed most recently. |
As per the MIB. |
mplsL3VpnVrfConfRowStatus (1.3.6.1.2.1.10.166.11.1.2.2.1.13) |
read-create |
RowStatus |
Row status. |
As per the MIB. |
mplsL3VpnVrfConfAdminStatus (1.3.6.1.2.1.10.166.11.1.2.2.1.14) |
read-create |
INTEGER |
up(1), down(2), testing(3) |
Administrative state of the VRF. |
mplsL3VpnVrfConfStorageType (1.3.6.1.2.1.10.166.11.1.2.2.1.15) |
read-create |
StorageType |
Storage type of the VRF. |
mplsL3VpnVrfRTTable
About this table
This table contains VPN RT information.
Create |
Edit/Modify |
Delete |
Read |
Not supported |
Not supported |
Not supported |
Supported |
Columns
The table indexes are mplsL3VpnVrfName, mplsL3VpnVrfRTIndex, and mplsL3VpnVrfRTType.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
mplsL3VpnVrfRTIndex (1.3.6.1.2.1.10.166.11.1.2.3.1.2) |
not-accessible |
Unsigned32 |
Unsigned32(1..4294967295) |
RT index. |
As per the MIB. |
mplsL3VpnVrfRTType (1.3.6.1.2.1.10.166.11.1.2.3.1.3) |
not-accessible |
MplsL3VpnRtType |
import (1), export (2), or both (3). |
Incoming and outgoing policies. |
As per the MIB. |
mplsL3VpnVrfRT (1.3.6.1.2.1.10.166.11.1.2.3.1.4) |
read-create |
RT character string. |
mplsL3VpnVrfRTDescr (1.3.6.1.2.1.10.166.11.1.2.3.1.5) |
read-create |
SnmpAdminString |
RT description. |
mplsL3VpnVrfRTRowStatus (1.3.6.1.2.1.10.166.11.1.2.3.1.6) |
read-create |
RowStatus |
Row status. |
mplsL3VpnVrfRTStorageType (1.3.6.1.2.1.10.166.11.1.2.3.1.7) |
read-create |
StorageType |
RT storage type. |
mplsL3VpnVrfSecTable
About this table
This table contains MPLS VRF security statistics information about interfaces.
Create |
Edit/Modify |
Delete |
Read |
Not supported |
Not supported |
Not supported |
Supported |
Columns
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
mplsL3VpnVrfSecIllegalLblVltns (1.3.6.1.2.1.10.166.11.1.2.6.1.1) |
read-only |
Counter32 |
Number of invalid labels that are received. |
As per the MIB. |
mplsL3VpnVrfSecDiscontinuityTime (1.3.6.1.2.1.10.166.11.1.2.6.1.2) |
read-only |
TimeStamp |
TimeTicks |
Interruption time. |
As per the MIB. |
mplsL3VpnVrfPerfTable
About this table
This table contains MPLS L3VPN VRF table performance information.
Create |
Edit/Modify |
Delete |
Read |
Not supported |
Not supported |
Not supported |
Supported |
Columns
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
mplsL3VpnVrfPerfRoutesAdded (1.3.6.1.2.1.10.166.11.1.3.1.1.1) |
read-only |
Counter32 |
Total number of added IPv4 and IPv6 routes. |
As per the MIB. |
mplsL3VpnVrfPerfRoutesDeleted (1.3.6.1.2.1.10.166.11.1.3.1.1.2) |
read-only |
Counter32 |
Total number of deleted IPv4 and IPv6 routes. |
As per the MIB. |
mplsL3VpnVrfPerfCurrNumRoutes (1.3.6.1.2.1.10.166.11.1.3.1.1.3) |
read-only |
Gauge32 |
Total number of active IPv4 and IPv6 routes. |
As per the MIB. |
mplsL3VpnVrfPerfRoutesDropped (1.3.6.1.2.1.10.166.11.1.3.1.1.4) |
read-only |
Counter32 |
Number of discarded routes. |
As per the MIB. |
mplsL3VpnVrfPerfDiscTime (1.3.6.1.2.1.10.166.11.1.3.1.1.5) |
read-only |
TimeStamp |
TimeTicks |
Interruption time. The value of this object is always 0. |
As per the MIB. |
mplsL3VpnVrfRteTable
About this table
This table contains information about routes configured for a VRF.
Create |
Edit/Modify |
Delete |
Read |
Not supported |
Not supported |
Not supported |
Supported |
Columns
The table indexes are mplsL3VpnVrfName, mplsL3VpnVrfRteInetCidrDestType, mplsL3VpnVrfRteInetCidrDest, mplsL3VpnVrfRteInetCidrPfxLen, mplsL3VpnVrfRteInetCidrPolicy, mplsL3VpnVrfRteInetCidrNHopType, and mplsL3VpnVrfRteInetCidrNextHop.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
mplsL3VpnVrfRteInetCidrDestType (1.3.6.1.2.1.10.166.11.1.4.1.1.1) |
not-accessible |
InetAddressType |
INTEGER{ unknown(0), ipv4(1), ipv6(2), dns(16) } |
Destination address type. |
As per the MIB. |
mplsL3VpnVrfRteInetCidrDest (1.3.6.1.2.1.10.166.11.1.4.1.1.2) |
not-accessible |
InetAddress |
Destination IP address. |
As per the MIB. |
mplsL3VpnVrfRteInetCidrPfxLen (1.3.6.1.2.1.10.166.11.1.4.1.1.3) |
not-accessible |
InetAddressPrefixLength |
Unsigned32(0..128) |
Prefix length of the destination address. |
As per the MIB. |
mplsL3VpnVrfRteInetCidrPolicy (1.3.6.1.2.1.10.166.11.1.4.1.1.4) |
not-accessible |
OBJECT IDENTIFIER |
Additional index that delineates between multiple entries to the same destination. |
As per the MIB. |
mplsL3VpnVrfRteInetCidrNHopType (1.3.6.1.2.1.10.166.11.1.4.1.1.5) |
not-accessible |
InetAddressType |
Next hop type. |
As per the MIB. |
mplsL3VpnVrfRteInetCidrNextHop (1.3.6.1.2.1.10.166.11.1.4.1.1.6) |
not-accessible |
InetAddress |
Next hop. |
As per the MIB. |
mplsL3VpnVrfRteInetCidrIfIndex (1.3.6.1.2.1.10.166.11.1.4.1.1.7) |
read-create |
InterfaceIndexOrZero |
Integer32(0..2147483647) |
Egress interface index. |
mplsL3VpnVrfRteInetCidrType (1.3.6.1.2.1.10.166.11.1.4.1.1.8) |
read-create |
INTEGER |
other(1), reject(2), local(3), remote (4), blackhole(5) |
Route type. |
mplsL3VpnVrfRteInetCidrProto (1.3.6.1.2.1.10.166.11.1.4.1.1.9) |
read-only |
IANAipRouteProtocol |
Routing protocol. |
As per the MIB. |
mplsL3VpnVrfRteInetCidrAge(1.3.6.1.2.1.10.166.11.1.4.1.1.10) |
read-only |
Gauge32 |
Route update time. |
As per the MIB. |
mplsL3VpnVrfRteInetCidrNextHopAS (1.3.6.1.2.1.10.166.11.1.4.1.1.11) |
read-create |
InetAutonomousSystemNumber |
AS number of the next hop. |
mplsL3VpnVrfRteInetCidrMetric1 (1.3.6.1.2.1.10.166.11.1.4.1.1.12) |
read-create |
Integer32 |
Integer32(-1 | 0..2147483647) |
Primary route metric. |
mplsL3VpnVrfRteInetCidrMetric2 (1.3.6.1.2.1.10.166.11.1.4.1.1.13) |
read-create |
Integer32 |
Optional route metric. |
Supports only the read operation. Set the value of this object to -1 if this object is not used. |
mplsL3VpnVrfRteInetCidrMetric3 (1.3.6.1.2.1.10.166.11.1.4.1.1.14) |
read-create |
Integer32 |
mplsL3VpnVrfRteInetCidrMetric4 (1.3.6.1.2.1.10.166.11.1.4.1.1.15) |
read-create |
Integer32 |
mplsL3VpnVrfRteInetCidrMetric5 (1.3.6.1.2.1.10.166.11.1.4.1.1.16) |
read-create |
Integer32 |
mplsL3VpnVrfRteXCPointer (1.3.6.1.2.1.10.166.11.1.4.1.1.17) |
read-create |
MplsIndexType |
mplsXCTable index. |
Supports only the read operation. This object is not supported. The return value is always 00.00.00.00. |
mplsL3VpnVrfRteInetCidrStatus (1.3.6.1.2.1.10.166.11.1.4.1.1.18) |
read-create |
RowStatus |
Row status. |
