13-MPLS
HomeSupportReference GuidesMIB CompanionH3C MSR Router Series MIB Reference-R6749-6W10013-MPLS
02-HH3C-MPLSEXT-MIB
02-HH3C-MPLSEXT-MIB 125.48 KB
HH3C-MPLSEXT-MIB
About this MIB
Use this MIB to manage MPLS and LDP capabilities and MPLS BFD sessions.
MIB file name
rfc3812-mplsext.mib
Root object
iso(1).org(3).dod(6).internet(1).mgmt(2).mib-2(1).transmission(10).mplsStdMIB(166).mplsTeStdMIB(3)
Scalar objects
hh3cMplsExtLsrID
Object (OID)
Access
Value range
Implementation
hh3cMplsExtLsrID (1.3.6.1.4.1.25506.2.142.1.1.1)
read-write
OCTET STRING
OCTET STRING
(0..255)
Global LSR ID.
As per the MIB.
hh3cMplsExtLdpStatus
Object (OID)
Access
Value range
Implementation
hh3cMplsExtLdpStatus (1.3.6.1.4.1.25506.2.142.1.1.2)
read-write
TruthValue
true(1),
false(2)
Enabling status of global LDP.
As per the MIB.
Tabular objects
hh3cMplsExtTable
About this table
Use this table to configure the MPLS capability for interfaces.
Support for operations
Create
Edit/Modify
Delete
Read
You cannot set an MTU for a tunnel interface.
By default, the MPLS MTU depends on the interface MTU. Different types of interfaces have different MTU values.
The MTU of a tunnel interface cannot be modified.
Supported
Supported
Columns
The table index is hh3cMplsExtIndex.
Object (OID)
Access
Value range
Implementation
hh3cMplsExtIndex (1.3.6.1.4.1.25506.2.142.1.2.1.1)
not-accessible
Unsigned32
Unsigned32
(1..4294967295)
Index of an interface.
As per the MIB.
hh3cMplsExtCapability
(1.3.6.1.4.1.25506.2.142.1.2.1.2)
read-create
TruthValue
true(1),
false(2)
MPLS capability of the interface.
As per the MIB.
hh3cMplsExtMtu
(1.3.6.1.4.1.25506.2.142.1.2.1.3)
read-create
Unsigned32
Unsigned32
(46..65535)
MPLS MTU of the interface.
As per the MIB.
hh3cMplsExtRowStatus
(1.3.6.1.4.1.25506.2.142.1.2.1.4)
read-create
RowStatus
active(1),
notInService(2),
notReady(3),
createAndGo(4),
createAndWait(5),
destroy(6)
Row status.
Supports only active(1), createAndGo(4), and destroy(6).
hh3cMplsExtLdpTable
About this table
Use this table to configure the LDP capability for interfaces.
Create
Edit/Modify
Delete
Read
When create, the value of hh3cMplsExtLdpCapability must be true(1).
Supported
Supported
Supported
Columns
The table index is hh3cMplsExtLdpIndex.
Object (OID)
Access
Value range
Implementation
hh3cMplsExtLdpIndex
(1.3.6.1.4.1.25506.2.142.1.3.1.1)
not-accessible
Unsigned32
Unsigned32
(1..4294967295)
As per the MIB.
(1.3.6.1.4.1.25506.2.142.1.3.1.2)
read-create
TruthValue
true(0)
false(1)
LDP capability of the interface.
As per the MIB.
hh3cMplsExtLdpRowStatus
(1.3.6.1.4.1.25506.2.142.1.3.1.3)
read-create
RowStatus
active(1),
notInService(2),
notReady(3),
createAndGo(4),
createAndWait(5),
destroy(6)
Row status.
hh3cMplsExtBfdTable
About this table
This table contains information about MPLS BFD sessions.
Create
Edit/Modify
Delete
Read
Not supported
Not supported
Not supported
Supported
Columns
The table index is hh3cMplsExtBfdLocalDiscr.
Object (OID)
Access
Value range
Implementation
hh3cMplsExtBfdLocalDiscr (1.3.6.1.4.1.25506.2.142.1.4.1.1)
not-accessible
Unsigned32
Unsigned32
(1..4294967295)
Local discriminator of a BFD session.
As per the MIB.
hh3cMplsExtBfdType (1.3.6.1.4.1.25506.2.142.1.4.1.2)
read-only
INTEGER
1: unknown
2: BFD for LSP
3: BFD for VPWS PW
4: BFD for VPLS PW
5: BFD for TE
Type of the BFD session.
As per the MIB.
hh3cMplsExtBfdBindIfIndex (1.3.6.1.4.1.25506.2.142.1.4.1.3)
read-only
InterfaceIndexOrZero
This object displays a tunnel interface index when the value of hh3cMplsExtBfdType is 5 (BFD for TE) and displays the index of an AC interface bound to a PW when the value of hh3cMplsExtBfdType is 3 (BFD for VPWS PW).
This object is invalid and displays 0 when the value of hh3cMplsExtBfdType is not 5 (BFD for TE) or 3 (BFD for VPWS PW).
Index of the bound local interface.
As per the MIB.
hh3cMplsExtBfdBindIfName (1.3.6.1.4.1.25506.2.142.1.4.1.4)
read-only
DisplayString
DisplayString
(0..255)
Name of the bound local interface.
As per the MIB.
hh3cMplsExtBfdXcIndex (1.3.6.1.4.1.25506.2.142.1.4.1.5)
read-only
OCTET STRING
OCTET STRING
(0..24)
MplsOutSegmentEntry index for an LSP entry.
As per the MIB.
hh3cMplsExtBfdPwBackupFlag (1.3.6.1.4.1.25506.2.142.1.4.1.6)
read-only
INTEGER
1: Non-PW
2: Primary PW
3: Backup PW
Primary or backup flag of a PW.
As per the MIB.
hh3cMplsExtBfdPwId (1.3.6.1.4.1.25506.2.142.1.4.1.7)
read-only
Unsigned32
Unsigned32
(0..4294967295)
PW identifier.
As per the MIB.
hh3cMplsExtBfdVsiIndex (1.3.6.1.4.1.25506.2.142.1.4.1.8)
read-only
Unsigned32
Unsigned32
(1..4294967295)
VSI index + 1.
As per the MIB.
hh3cMplsExtBfdPwPeerIpType (1.3.6.1.4.1.25506.2.142.1.4.1.9)
read-only
InetAddressType
IPv4 or IPv6.
The value of this object is 0 if the BFD session is not for a PW.
Type of the PW peer address.
As per the MIB.
hh3cMplsExtBfdPwPeerIp (1.3.6.1.4.1.25506.2.142.1.4.1.10)
read-only
InetAddress
OCTET STRING (0..255)
Peer address of the PW.
As per the MIB.
hh3cMplsExtBfdPwSPE (1.3.6.1.4.1.25506.2.142.1.4.1.11)
read-only
INTEGER
1: Non-VPWS PW
2: UPE (User facing-Provider Edge)
3: SPE (Switching Provider Edge, a transit node of a multi-segment PW)
Node information of the VPWS PW.
As per the MIB.
hh3cMplsExtBfdPwEncapType (1.3.6.1.4.1.25506.2.142.1.4.1.12)
read-only
INTEGER
1: unknown
2: fr-dlci-martini
3: atm-aal5-sdu
4: atm-trans-cell
5: vlan
6: ethernet
7: hdlc
8: ppp
9: cesom
10: atm-nto1-vcc
11: atm-nto1-vpc
12: ip-interworking
13: atm-1to1-vcc
14: atm-1to1-vpc
15: atm-aal5-pdu
16: fr-port
17: cep
18: satop-e1
19: satop-t1
20: satop-e3
21: satop-t3
22: esopsn-basic
23: tdmoip-aal1-mode
24: tdm-cesopsn-with-cas
25: tdmoip-aal2-mode
26: fr-dlci
Encapsulation type of the PW.
As per the MIB.
hh3cMplsExtVpnStatsTable
About this table
This table contains statistical information about packets received and sent by VPNs.
Create
Edit/Modify
Delete
Read
Not supported
Not supported
Not supported
Supported
Columns
The table index is hh3cMplsExtVpnStatsVrfIndex .
Object (OID)
Access
Value range
Implementation
hh3cMplsExtVpnStatsVrfIndex (1.3.6.1.4.1.25506.2.142.1.5.1.1)
not-accessible
Unsigned32
Unsigned32
(1..4294967295)
Index of a VPN instance.
As per the MIB.
hh3cMplsExtVpnStatsVpnName (1.3.6.1.4.1.25506.2.142.1.5.1.2)
read-only
OCTET STRING
OCTET STRING
(1..31 )
Name of the VPN instance.
As per the MIB.
This object is invalid if VPN statistics is not enabled. When read, this object returns a zero-length string.
hh3cMplsExtVpnStatsInOctets (1.3.6.1.4.1.25506.2.142.1.5.1.3)
read-only
Counter64
Counter64
(0..18446744073709551615)
Number of octets received by the VPN instance.
As per the MIB.
hh3cMplsExtVpnStatsInPackets (1.3.6.1.4.1.25506.2.142.1.5.1.4)
read-only
Counter64
Counter64
Number of packets received by the VPN instance.
As per the MIB.
hh3cMplsExtVpnStatsInErrors (1.3.6.1.4.1.25506.2.142.1.5.1.5)
read-only
Counter64
Counter64
Number of error packets received by the VPN instance.
As per the MIB.
hh3cMplsExtVpnStatsInDiscards (1.3.6.1.4.1.25506.2.142.1.5.1.6)
read-only
Counter64
Counter64
Number of incoming packets discarded by the VPN instance.
As per the MIB.
hh3cMplsExtVpnStatsOutOctets (1.3.6.1.4.1.25506.2.142.1.5.1.7)
read-only
Counter64
Counter64
Number of octets sent by the VPN instance.
As per the MIB.
hh3cMplsExtVpnStatsOutPackets (1.3.6.1.4.1.25506.2.142.1.5.1.8)
read-only
Counter64
Counter64
Number of packets sent by the VPN instance.
As per the MIB.
hh3cMplsExtVpnStatsOutErrors (1.3.6.1.4.1.25506.2.142.1.5.1.9)
read-only
Counter64
Counter64
Number of error packets sent by the VPN instance.
As per the MIB.
hh3cMplsExtVpnStatsOutDiscards (1.3.6.1.4.1.25506.2.142.1.5.1.10)
read-only
Counter64
Counter64
Number of outgoing packets discarded by the VPN instance.
As per the MIB.
hh3cMplsExtVpnTable
About this table
This table contains MPLS L3VPN information.
Create
Edit/Modify
Delete
Read
Not supported
Not supported
Not supported
Supported
Columns
The table index is hh3cMplsExtVpnName.
Object (OID)
Access
Value range
Implementation
hh3cMplsExtVpnName (1.3.6.1.4.1.25506.2.142.1.6.1.1)
not-accessible
OCTET STRING
OCTET STRING
(1..31)
Name of a VPN instance.
As per the MIB.
hh3cMplsExtVrfIndex (1.3.6.1.4.1.25506.2.142.1.6.1.2)
read-only
Unsigned32
Unsigned32 (1..4294967295)
Index of the VPN instance.
As per the MIB.
hh3cMplsExtStaticLspTable
About this table
This table contains information about MPLS static LSPs.
Create
Edit/Modify
Delete
Read
Not supported
Not supported
Not supported
Supported
Columns
The table index is hh3cMplsExtStaticLspName.
Object (OID)
Access
Value range
Implementation
hh3cMplsExtStaticLspName (1.3.6.1.4.1.25506.2.142.1.7.1.1)
not-accessible
OCTET STRING
OCTET STRING
(1..15)
Name of a static LSP.
As per the MIB.
hh3cMplsExtStaticLspType (1.3.6.1.4.1.25506.2.142.1.7.1.2)
read-only
Enumeration
1—Ingress
2—Transit
3—Egress
Type of the static LSP.
As per the MIB.
hh3cMplsExtStaticLspInLabel (1.3.6.1.4.1.25506.2.142.1.7.1.3)
read-only
Unsigned integer.
Unsigned integer.
(16..4294967295)
Incoming label for the static LSP.
As per the MIB.
hh3cMplsExtStaticLspOutLabel (1.3.6.1.4.1.25506.2.142.1.7.1.4)
read-only
Unsigned integer
Unsigned integer.
(0,3,16..4294967295)
Outgoing label for the static LSP.
As per the MIB.
hh3cMplsExtStaticLspDestAddr (1.3.6.1.4.1.25506.2.142.1.7.1.5)
read-only
String, dotted decimal notation.
Destination address of the static LSP.
As per the MIB.
hh3cMplsExtStaticLspDestAddrMaskLen (1.3.6.1.4.1.25506.2.142.1.7.1.6)
read-only
Unsigned integer.
Unsigned integer.
(0..32)
Mask length of the destination address.
As per the MIB.
hh3cMplsExtStaticLspNextHopAddr (1.3.6.1.4.1.25506.2.142.1.7.1.7)
read-only
OCTET STRING
(0..255)
Nexthop address of the static LSP.
As per the MIB.
hh3cMplsExtStaticLspOutIfIndex (1.3.6.1.4.1.25506.2.142.1.7.1.8)
read-only
Unsigned integer.
Unsigned integer.
(0..4294967295)
Index of the outgoing interface for this static LSP.
As per the MIB.
