- 13-MPLS
- 01-HH3C-L2VPN-MIB
- 02-HH3C-MPLSEXT-MIB
- 03-HH3C-MPLSTE-MIB
- 04-HH3C-VSI-MIB
- 05-MPLS-FRR-FACILITY-STD-MIB
- 06-MPLS-FRR-GENERAL-STD-MIB
- 07-MPLS-FTN-STD-MIB
- 08-MPLS-L3VPN-STD-MIB
- 09-MPLS-LDP-STD-MIB
- 10-MPLS-LSR-STD-MIB
- 11-MPLS-TE-STD-MIB
- 12-PW-ENET-STD-MIB
- 13-PW-MPLS-STD-MIB
- 14-PW-STD-MIB
- 15-TE-MIB
01-HH3C-L2VPN-MIB | 140.11 KB |
HH3C-L2VPN-MIB
About this MIB
Use this MIB to obtain L2VPN configuration information. This MIB also contains notifications about PW state changes.
MIB file name
hh3c-l2vpn.mib
Root object
iso(1).org(3).dod(6).internet(1).private(4).enterprises(1).hh3c(25506).hh3cCommon(2).hh3L2vpn(162)
Tabular objects
hh3cL2vpnPwcTable
About this table
This table contains PW class information.
Support for operations
Create |
Edit/Modify |
Delete |
Read |
Not supported |
Not supported |
Not supported |
Supported |
Columns
The table index is hh3cL2vpnPwcName.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cL2vpnPwcName (1.3.6.1.4.1.25506.2.162.2.1.1.1) |
not-accessible |
OCTET STRING |
OCTET STRING (0..19) |
PW class name. |
As per the MIB. |
hh3cL2vpnPwcCvType (1.3.6.1.4.1.25506.2.162.2.1.1.2) |
read-create |
INTEGER |
unknown(1), bfd(2), rawBFD(3) |
Encapsulation mode used by BFD packets for PW fault detection. |
Supports only the read operation. |
hh3cL2vpnPwcCcType (1.3.6.1.4.1.25506.2.162.2.1.1.3) |
read-create |
INTEGER |
unknown(1), controlWord(2), routerAlert(3), ttl(4) |
VCCV control channel type. |
hh3cL2vpnPwcControlWord (1.3.6.1.4.1.25506.2.162.2.1.1.4) |
read-create |
TruthValue |
true(1) false(2) |
Whether the control word feature is enabled. |
hh3cL2vpnPwcPwType (1.3.6.1.4.1.25506.2.162.2.1.1.5) |
read-create |
INTEGER |
vlan(4), ethernet(5) |
PW data encapsulation type. |
hh3cL2vpnPwcRowStatus (1.3.6.1.4.1.25506.2.162.2.1.1.6) |
read-create |
RowStatus |
active(1), notInService(2), notReady(3), createAndGo(4), createAndWait(5), destroy(6) |
Row status. |
hh3cL2vpnXcgTable
About this table
This table contains L2VPN cross-connect group information.
Create |
Edit/Modify |
Delete |
Read |
Not supported |
Not supported |
Not supported |
Supported |
Columns
The table index is hh3cL2vpnXcgName.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cL2vpnXcgName (1.3.6.1.4.1.25506.2.162.3.1.1.1) |
not-accessible |
OCTET STRING |
OCTET STRING (1..31)) |
Name of the cross-connect group. |
As per the MIB. |
hh3cL2vpnXcgAdminState (1.3.6.1.4.1.25506.2.162.3.1.1.2) |
read-create |
INTEGER |
adminUp(1), adminDown(2) |
Administrative state of the cross-connect group. |
hh3cL2vpnXcgRowStatus (1.3.6.1.4.1.25506.2.162.3.1.1.3) |
read-create |
RowStatus |
Row status. |
hh3cL2vpnXcgConnTable
About this table
This table contains L2VPN cross-connect information.
Create |
Edit/Modify |
Delete |
Read |
Not supported |
Not supported |
Not supported |
Supported |
Columns
The table indexes are hh3cL2vpnXcgName and hh3cL2vpnXcgConnName.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cL2vpnXcgConnName (1.3.6.1.4.1.25506.2.162.3.2.1.1) |
not-accessible |
OCTET STRING |
OCTET STRING (1..20) |
Name of the cross-connect. |
As per the MIB. |
hh3cL2vpnXcgConnRowStatus (1.3.6.1.4.1.25506.2.162.3.2.1.2) |
read-create |
RowStatus |
Row status. |
hh3cL2vpnXcgAcTable
About this table
This table contains cross-connect group AC information.
Create |
Edit/Modify |
Delete |
Read |
Not supported |
Not supported |
Not supported |
Supported |
Columns
The table indexes are hh3cL2vpnXcgName, hh3cL2vpnXcgConnName, hh3cL2vpnXcgAcIfIndex, and hh3cL2vpnXcgAcEvcSrvInstId.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cL2vpnXcgAcIfIndex (1.3.6.1.4.1.25506.2.162.3.3.1.1) |
not-accessible |
InterfaceIndex |
InterfaceIndex (1..2147483647) |
Interface index of the AC. |
As per the MIB. |
hh3cL2vpnXcgAcEvcSrvInstId (1.3.6.1.4.1.25506.2.162.3.3.1.2) |
not-accessible |
Unsigned32 |
ID of the Ethernet service instance bound to the cross-connect group. |
As per the MIB. The value of this object is fixed at 0 for a Layer 3 interface. |
hh3cL2vpnXcgAcAccessMode (1.3.6.1.4.1.25506.2.162.3.3.1.3) |
read-create |
INTEGER |
vlan(1), ethernet(2) |
Access mode of the AC. |
Supports only the read operation. This object is meaningless when the AC is not a Layer 2 Ethernet interface. |
hh3cL2vpnXcgAcRowStatus (1.3.6.1.4.1.25506.2.162.3.3.1.4) |
read-create |
RowStatus |
Row status. |
hh3cL2vpnXcgPwTable
About this table
This table contains cross-connect group PW information.
Create |
Edit/Modify |
Delete |
Read |
Not supported |
Not supported |
Not supported |
Supported |
Columns
The table indexes are hh3cL2vpnXcgName, hh3cL2vpnXcgConnName, and hh3cL2vpnXcgPwIndex.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cL2vpnXcgPwIndex (1.3.6.1.4.1.25506.2.162.3.4.1.1) |
accessible-for-notify |
Unsigned32 |
Unsigned32 (0..4294967295) |
PW index. |
As per the MIB. |
hh3cL2vpnXcgPwCfgType (1.3.6.1.4.1.25506.2.162.3.4.1.2) |
read-create |
INTEGER |
primary(1), backup(2) |
PW type, primary PW or backup PW. |
hh3cL2vpnXcgPwClassName (1.3.6.1.4.1.25506.2.162.3.4.1.3) |
read-create |
OCTET STRING |
Name of the used PW class. |
hh3cL2vpnXcgPwTunnelPolicy (1.3.6.1.4.1.25506.2.162.3.4.1.4) |
read-create |
OCTET STRING |
Name of the used tunnel policy. |
hh3cL2vpnXcgPwPeerIp (1.3.6.1.4.1.25506.2.162.3.4.1.5) |
IpAddress |
OCTET STRING (SIZE (4)) |
Peer's IP address. |
As per the MIB. |
hh3cL2vpnXcgPwPwID (1.3.6.1.4.1.25506.2.162.3.4.1.6) |
Unsigned32 |
PW ID. |
As per the MIB. |
hh3cL2vpnXcgPwRowStatus (1.3.6.1.4.1.25506.2.162.3.4.1.7) |
read-create |
RowStatus |
Row status. |
hh3cL2vpnLinkTable
About this table
This table contains L2VPN link information.
Create |
Edit/Modify |
Delete |
Read |
Not supported |
Not supported |
Not supported |
Supported |
Columns
The table indexes are hh3cL2vpnLinkVsiIndex and hh3cL2vpnLinkLinkID.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cL2vpnLinkVsiIndex |
not-accessible |
Unsigned32 |
VSI index. |
As per the MIB. |
hh3cL2vpnLinkLinkID (1.3.6.1.4.1.25506.2.162.2.2.1.2) |
not-accessible |
Unsigned32 |
Link ID |
As per the MIB. |
hh3cL2vpnLinkType (1.3.6.1.4.1.25506.2.162.2.2.1.3) |
read-only |
INTEGER |
unknown(1), ac(2), tunnel(3) |
VSI link type. |
As per the MIB. |
hh3cL2vpnLinkIfIndex (1.3.6.1.4.1.25506.2.162.2.2.1.4) |
read-only |
InterfaceIndex |
Interface index of the VSI link. |
As per the MIB. |
hh3cL2vpnLinkSrvID (1.3.6.1.4.1.25506.2.162.2.2.1.5) |
read-only |
Unsigned32 |
Unsigned32(0..4294967295) |
Ethernet service instance ID of the VSI link. |
As per the MIB. |
hh3cL2vpnLinkTunnelID (1.3.6.1.4.1.25506.2.162.2.2.1.6) |
read-only |
Unsigned32 |
Tunnel interface number of the VSI link. |
As per the MIB. |
hh3cL2vpnAcCfgTable
About this table
This table contains L2VPN AC information.
Create |
Edit/Modify |
Delete |
Read |
Not supported |
Not supported |
Not supported |
Supported |
Columns
The table indexes are hh3cL2vpnAcIfIndex and hh3cL2vpnAcSrvId.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cL2vpnAcIfIndex (1.3.6.1.4.1.25506.2.162.4.1.1.1) |
not-accessible |
InterfaceIndex |
As per the MIB. |
hh3cL2vpnAcSrvId (1.3.6.1.4.1.25506.2.162.4.1.1.2) |
not-accessible |
Unsigned32 |
Ethernet service instance ID of the AC. |
As per the MIB. |
hh3cL2vpnAcIfName (1.3.6.1.4.1.25506.2.162.4.1.1.3) |
read-only |
DisplayString |
OCTET STRING (0..255) |
Interface name. |
As per the MIB. |
hh3cL2vpnAcVsiName (1.3.6.1.4.1.25506.2.162.4.1.1.4) |
read-only |
DisplayString |
OCTETSTRING (0..255) |
Name of the VSI bound to the AC. |
As per the MIB. |
hh3cL2vpnAcXcgName (1.3.6.1.4.1.25506.2.162.4.1.1.5) |
read-only |
DisplayString |
Name of the cross-connect group bound to the AC. |
As per the MIB. |
hh3cL2vpnAcXcgConnName (1.3.6.1.4.1.25506.2.162.4.1.1.6) |
read-only |
DisplayString |
Name of the cross-connect bound to the AC. |
As per the MIB. |
hh3cL2vpnAcDot1qType (1.3.6.1.4.1.25506.2.162.4.1.1.7) |
read-only |
INTEGER |
other(1), default(2), singletag(3) |
802.1Q type of the interface. |
As per the MIB. |
hh3cL2vpnAcVLANID (1.3.6.1.4.1.25506.2.162.4.1.1.8) |
read-only |
Unsigned32 |
VLAN information about the interface. |
As per the MIB. |
hh3cL2vpnPwCfgTable
About this table
This table contains L2VPN PW information.
Create |
Edit/Modify |
Delete |
Read |
Not supported |
Not supported |
Not supported |
Supported |
Columns
The table indexes are hh3cL2vpnPwPeerIp and hh3cL2vpnPwId.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cL2vpnPwPeerIp |
not-accessible |
IpAddress |
OCTET STRING (4) |
As per the MIB. |
hh3cL2vpnPwId (1.3.6.1.4.1.25506.2.162.5.1.1.2) |
not-accessible |
Unsigned32 |
PW ID. |
As per the MIB. |
hh3cL2vpnPwAcIfIndex (1.3.6.1.4.1.25506.2.162.5.1.1.3) |
read-only |
InterfaceIndexOrZero |
Integer32 (0..2147483647) |
Interface index of the AC corresponding to the PW. |
As per the MIB. VPLS PW is not supported. |
hh3cL2vpnPwAcIfName (1.3.6.1.4.1.25506.2.162.5.1.1.4) |
read-only |
DisplayString |
Interface name of the AC corresponding to the PW. |
hh3cL2vpnPwAcSrvId (1.3.6.1.4.1.25506.2.162.5.1.1.5) |
read-only |
Unsigned32 |
As per the MIB. |
hh3cL2vpnPwVsiName (1.3.6.1.4.1.25506.2.162.5.1.1.6) |
read-only |
DisplayString |
Name of the VSI bound to the PW. |
As per the MIB. |
hh3cL2vpnPwXcgName (1.3.6.1.4.1.25506.2.162.5.1.1.7) |
read-only |
DisplayString |
Name of the cross-connect group bound to the PW. |
As per the MIB. |
hh3cL2vpnPwXcgConnName (1.3.6.1.4.1.25506.2.162.5.1.1.8) |
read-only |
DisplayString |
Name of the cross-connect bound to the PW. |
As per the MIB. |
hh3cL2vpnPwQosDirection (1.3.6.1.4.1.25506.2.162.5.1.1.9) |
read-only |
INTEGER |
none(1), inbound(2), outbound(3), both(4) |
QoS direction. |
As per the MIB. |
hh3cL2vpnPwInboundQosCir (1.3.6.1.4.1.25506.2.162.5.1.1.10) |
read-only |
Unsigned32 |
Inbound QoS CIR. |
As per the MIB. |
hh3cL2vpnPwInboundQosCbs (1.3.6.1.4.1.25506.2.162.5.1.1.11) |
read-only |
Unsigned32 |
Inbound QoS CBS. |
As per the MIB. |
hh3cL2vpnPwInboundQosEbs (1.3.6.1.4.1.25506.2.162.5.1.1.12) |
read-only |
Unsigned32 |
Inbound QoS EBS. |
As per the MIB. |
hh3cL2vpnPwOutboundQosCir (1.3.6.1.4.1.25506.2.162.5.1.1.13) |
read-only |
Unsigned32 |
Outbound QoS CIR. |
As per the MIB. |
hh3cL2vpnPwOutboundQosCbs (1.3.6.1.4.1.25506.2.162.5.1.1.14) |
read-only |
Unsigned32 |
Outbound QoS CBS. |
As per the MIB. |
hh3cL2vpnPwOutboundQosEbs (1.3.6.1.4.1.25506.2.162.5.1.1.15) |
read-only |
Unsigned32 |
Outbound QoS EBS. |
As per the MIB. |
Notifications
hh3cL2vpnPwSwitchPtoB
Basic information
OID |
Event |
Type |
Severity |
Recovery notification |
Default status |
1.3.6.1.4.1.25506.2.162.0.1 |
Traffic is switched from the primary PW to the backup PW. |
Error |
Warning |
1.3.6.1.4.1.25506.2.162.0.2(hh3cL2vpnPwSwitchBtoP) |
OFF |
Notification triggers
This notification is generated when the traffic is switched from the primary PW to the backup PW.
System impact
Milliseconds of packet loss might occur during the PW switchover process.
Status control
ON
CLI: Use the snmp-agent trap enable l2vpn pw-switch command.
OFF
CLI: Use the undo snmp-agent trap enable l2vpn pw-switch command.
Objects
OID (object name) |
Index nodes |
Type |
Value range |
1.3.6.1.4.1.25506.2.162.3.4.1.1 (hh3cL2vpnXcgPwIndex) |
PW index associated with the cross-connect. |
hh3cL2vpnXcgPwIndex hh3cL2vpnXcgName hh3cL2vpnXcgConnName |
Unsigned32 |
As per the MIB. |
1.3.6.1.4.1.25506.2.162.3.4.1.5 (hh3cL2vpnXcgPwPeerIp) |
IP address of the PW associated with the cross-connect. |
IpAddress |
As per the MIB. |
1.3.6.1.4.1.25506.2.162.3.4.1.6 (hh3cL2vpnXcgPwPwID) |
ID of the PW associated with the cross-connect. |
Unsigned32 |
As per the MIB. |
Recommended action
No action is required.
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.2.162.0.2 |
Traffic is switched from the backup PW to the primary PW. |
Recovery |
Warning |
OFF |
This notification is generated when the traffic is switched from the backup PW to the primary PW.
System impact
Status control
ON
OFF
Objects
OID (object name) |
Index nodes |
Type |
Value range |
Unsigned32 |
As per the MIB. |
IpAddress |
As per the MIB. |
Unsigned32 |
As per the MIB. |
Recommended action
