- 13-MPLS
- 01-HH3C-L2VPN-MIB
- 02-HH3C-MPLSEXT-MIB
- 03-HH3C-MPLSTE-MIB
- 04-HH3C-VSI-MIB
- 05-MPLS-FRR-FACILITY-STD-MIB
- 06-MPLS-FRR-GENERAL-STD-MIB
- 07-MPLS-FTN-STD-MIB
- 08-MPLS-L3VPN-STD-MIB
- 09-MPLS-LDP-STD-MIB
- 10-MPLS-LSR-STD-MIB
- 11-MPLS-TE-STD-MIB
- 12-PW-ENET-STD-MIB
- 13-PW-MPLS-STD-MIB
- 14-PW-STD-MIB
- 15-TE-MIB
03-HH3C-MPLSTE-MIB | 101.95 KB |
hh3cMplsTeStatus (1.3.6.1.4.1.25506.2.143.1.1.1)
HH3C-MPLSTE-MIB
About this MIB
Use this MIB to manage MPLS TE and RSVP TE settings.
MIB file name
hh3c-mplste.mib
Root object
iso(1).org(3).dod(6).internet(1).private(4).enterprises(1).hh3c(25506).hh3cCommon(2).hh3cMplsTe(143
Scalar objects
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cMplsTeStatus (1.3.6.1.4.1.25506.2.143.1.1.1) |
read-write |
TruthValue |
true(1), false(2) |
Globally enable MPLS TE (mpls te) or TE attribute (te attribute enable) for the device. |
As per the MIB. |
hh3cMplsTeRsvpStatus (1.3.6.1.4.1.25506.2.143.1.1.2)
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cMplsTeRsvpStatus (1.3.6.1.4.1.25506.2.143.1.1.2) |
read-write |
TruthValue |
true(1), false(2) |
Enabling status of global RSVP TE. |
As per the MIB. |
Tabular objects
hh3cMplsTeTable
About this table
This table specifies per-interface MPLS TE settings.
Support for operations
Create |
Edit/Modify |
Delete |
Read |
Supported only when the value for hh3cMplsTeCapability is true(1) |
Not supported |
Supported |
Supported |
Columns
The table index is hh3cMplsTeIndex.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cMplsTeIndex (1.3.6.1.4.1.25506.2.143.1.2.1.1) |
not-accessible |
Unsigned32 |
Unsigned32 (1..4294967295) |
Index of an MPLS TE interface. |
As per the MIB. |
hh3cMplsTeCapability (1.3.6.1.4.1.25506.2.143.1.2.1.2) |
read-create |
TruthValue |
true(1), false(2) |
MPLS TE capability of the interface. No MPLS TE capability information can be obtained when MPLS TE is not enabled on the interface. |
As per the MIB. |
hh3cMplsTeRowStatus (1.3.6.1.4.1.25506.2.143.1.2.1.3) |
read-create |
RowStatus |
active(1) createAndGo(4) destroy(6). |
Row status. |
Supports only the following values: active(1), createAndGo(4), and destroy(6). |
hh3cMplsTeRsvpTable
About this table
This table specifies per-interface RSVP TE settings.
Create |
Edit/Modify |
Delete |
Read |
Supported only when the value for hh3cMplsTeRsvpCapability is true(1) |
Not supported |
Supported |
Supported |
Columns
The table index is hh3cMplsTeRsvpIndex.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cMplsTeRsvpIndex (1.3.6.1.4.1.25506.2.143.1.3.1.1) |
not-accessible |
Unsigned32 |
Index of an RSVP TE interface. |
As per the MIB. |
hh3cMplsTeRsvpCapability (1.3.6.1.4.1.25506.2.143.1.3.1.2) |
read-create |
TruthValue |
true(1), false(2) |
RSVP TE capability of the interface. No RSVP TE capability information can be obtained when RSVP is not enabled on the interface. |
As per the MIB. |
hh3cMplsTeRsvpRowStatus (1.3.6.1.4.1.25506.2.143.1.3.1.3) |
read-create |
RowStatus |
Row status. |
