06-Interface
HomeSupportReference GuidesMIB CompanionH3C MSR Router Series MIB Reference-R6749-6W10006-Interface
06-HH3C-T1-MIB
06-HH3C-T1-MIB 68.41 KB
HH3C-T1-MIB
About this MIB
Use this MIB to manage T1,interfaces excluded from RFC 1213 and RFC 2233.
MIB file name
hh3c-t1.mib
Root object
iso(1).org(3).dod(6).internet(1).private(4).enterprises(1).hh3c(25506).hh3cCommon(2).hh3cT1(29)
Tabular objects
hh3ct1InterfaceStatusTable
About this table
This table contains packet statistics for a T1 interface.
Support for operations
Create
Edit/Modify
Delete
Read
Not supported
Not supported
Not supported
Supported
Columns
The table index is hh3ct1InterfaceInErrs.
Object (OID)
Access
Value range
Implementation
hh3ct1InterfaceInErrs (1.3.6.1.4.1.25506.2.29.1.1.1)
read-only
Counter32
Standard MIB values.
Number of errors received on a T1 interface.
As per the MIB.
hh3ct1InterfaceInRuntsErrs (1.3.6.1.4.1.25506.2.29.1.1.2)
read-only
Counter32
Number of runt errors received on the interface.
As per the MIB.
hh3ct1InterfaceInGiantsErrs
(1.3.6.1.4.1.25506.2.29.1.1.3)
read-only
Counter32
Number of giant errors received on the interface.
As per the MIB.
hh3ct1InterfaceInCrcErrs
(1.3.6.1.4.1.25506.2.29.1.1.4)
read-only
Counter32
Number of CRC errors received on the interface.
As per the MIB.
hh3ct1InterfaceInAlignErrs
(1.3.6.1.4.1.25506.2.29.1.1.5)
read-only
Counter32
Number of alignment errors received on the interface.
As per the MIB.
hh3ct1InterfaceInOverRunsErrs
(1.3.6.1.4.1.25506.2.29.1.1.6)
read-only
Counter32
Number of overrun errors received on the interface.
As per the MIB.
hh3ct1InterfaceInDribblesErrs(1.3.6.1.4.1.25506.2.29.1.1.7)
read-only
Counter32
Number of dribble packets received on the interface.
As per the MIB.
hh3ct1InterfaceInAbortedSeqErrs
(1.3.6.1.4.1.25506.2.29.1.1.8)
read-only
Counter32
Number of AbortedSeq errors received on the interface.
As per the MIB.
hh3ct1InterfaceInNoBufferErrs
(1.3.6.1.4.1.25506.2.29.1.1.9)
read-only
Counter32
Number of insufficient buffer errors received on the interface.
As per the MIB.
hh3ct1InterfaceInFramingErrs
(1.3.6.1.4.1.25506.2.29.1.1.10)
read-only
Counter32
Number of framing errors on the interface.
As per the MIB.
hh3ct1InterfaceOutputErrs
(1.3.6.1.4.1.25506.2.29.1.1.11)
read-only
Counter32
Number of errors transmitted by the interface.
As per the MIB.
hh3ct1InterfaceOutUnderRunErrs
(1.3.6.1.4.1.25506.2.29.1.1.12)
read-only
Counter32
Number of underrun errors transmitted by the interface.
As per the MIB.
hh3ct1InterfaceOutCollisonsErrs
(1.3.6.1.4.1.25506.2.29.1.1.13)
read-only
Counter32
Number of collision errors transmitted by the interface.
As per the MIB.
hh3ct1InterfaceOutDeferedErrs  (1.3.6.1.4.1.25506.2.29.1.1.14)
read-only
Counter32
Number of deferred errors transmitted by the interface.
As per the MIB.
hh3ct1Table
About this table
This table contains EI interface management information.
Create
Edit/Modify
Delete
Read
Not supported
Not supported
Not supported
Supported
Columns
The table index is hh3ct1Type.
Object (OID)
Access
Value range
Implementation
hh3ct1Type
(1.3.6.1.4.1.25506.2.29.2.1.1)
read-only
BITS
voice(0)
Type of a T1 interface.
As per the MIB.
hh3ct1Clock
(1.3.6.1.4.1.25506.2.29.2.1.2)
read-write
INTEGER
slave(1),
master(2),
internal(3),
line(4),
linePri(5)
Clock type used on the T1 interface.
As per the MIB.
hh3ct1FrameFormat
(1.3.6.1.4.1.25506.2.29.2.1.3)
read-write
INTEGER
sf(1),
esf(2)
Frame format used on the T1 interface.
As per the MIB.
hh3ct1LineCode
(1.3.6.1.4.1.25506.2.29.2.1.4)
read-write
INTEGER
ami(1),
b8zs(2)
Line code type used on the T1 interface.
As per the MIB.
hh3ct1PriSetTimeSlot
(1.3.6.1.4.1.25506.2.29.2.1.5)
read-write
Hh3cT1TimeSlot
Bit map of PRI time slots used on the T1 interface.
As per the MIB.
hh3ct1DChannelIndex
(1.3.6.1.4.1.25506.2.29.2.1.6)
read-only
Integer32
Interface index of the D channel of the T1 interface.
As per the MIB.
hh3ct1SubScribLineChannelIndex
(1.3.6.1.4.1.25506.2.29.2.1.7)
read-only
Integer32
Interface index of the subscriber-line channel of the T1 interface.
As per the MIB.
hh3ct1InterfaceTable
About this table
This table contains information about D channel and subscriber-line channels of a T1 interface.
Create
Edit/Modify
Delete
Read
Not supported
Not supported
Not supported
Supported
Columns
The table index is hh3ct1ControllerIndex.
Object (OID)
Access
Value range
Implementation
hh3ct1ControllerIndex (1.3.6.1.4.1.25506.2.29.3.1.1 )
read-only
Integer32
T1 interface to which a channel belongs.
As per the MIB.
