06-Interface
HomeSupportReference GuidesMIB CompanionH3C MSR Router Series MIB Reference-R6749-6W10006-Interface
01-ADSL-LINE-MIB
01-ADSL-LINE-MIB 66.65 KB
ADSL-LINE-MIB
About this MIB
Use this MIB to obtain ADSL line information.
MIB file name
rfc2662-adsl-line.mib
Root object
iso(1).org(3).dod(6).internet(1).mgmt(2).mib-2(1).transmission(10).adslMIB(94).adslLineMib(1)
Tabular objects
adslLineTable
About this table
This table contains common attributes of ADSL physical interface at the ends of an ADSL line.
Support for operations
Create
Edit/Modify
Delete
Read
Not supported
Not supported
Not supported
Supported
Columns
The table index is adslLineCoding.
Object (OID)
Access
Value range
Implementation
adslLineType (1.3.6.1.2.1.10.94.1.1.1.1.2)
read-only
INTEGER
noChannel (1), fastOnly (2), interleavedOnly (3), fastOrInterleaved (4), fastAndInterleaved (5)
Type of the ADSL physical line.
As per the MIB.
adslAtucPhysTable
About this table
This table contains physical layer parameters for an ATUC.
Create
Edit/Modify
Delete
Read
Not supported
Not supported
Not supported
Supported
Columns
The table index is adslAtucInvSerialNumber.
Object (OID)
Access
Value range
Implementation
adslAtucCurrSnrMgn (1.3.6.1.2.1.10.94.1.1.2.1.4)
read-only
INTEGER
INTEGER (-640..640)
Noise margin of the ATU, in tenth dB.
As per the MIB.
adslAtucCurrAtn (1.3.6.1.2.1.10.94.1.1.2.1.5)
read-only
Gauge32
Gauge32(0..630)
Attenuation of the ATUC line, in tenth dB.
As per the MIB.
adslAtucCurrOutputPwr (1.3.6.1.2.1.10.94.1.1.2.1.7)
read-only
INTEGER
INTEGER (-310..310)
Output power of the ATUC line, in tenth dBm.
As per the MIB.
adslAtucCurrAttainableRate (1.3.6.1.2.1.10.94.1.1.2.1.8)
read-only
Gauge32
Standard MIB values.
Maximum currently attainable data rate by the ATU, in bps.
As per the MIB.
adslAturPhysTable
About this table
This table contains physical layer parameters for an ATUR.
Create
Edit/Modify
Delete
Read
Not supported
Not supported
Not supported
Supported
Columns
The table index is adslAturInvSerialNumber.
Object (OID)
Access
Value range
Implementation
adslAturCurrSnrMgn (1.3.6.1.2.1.10.94.1.1.3.1.4)
read-only
INTEGER
INTEGER (-640..640)
Noise margin of the ATUR line, in tenth dB.
As per the MIB.
adslAturCurrAtn (1.3.6.1.2.1.10.94.1.1.3.1.5)
read-only
Gauge32
Gauge32(0..630)
Attenuation of the ATUR line, in tenth dB.
As per the MIB.
adslAturCurrOutputPwr (1.3.6.1.2.1.10.94.1.1.3.1.7)
read-only
INTEGER
INTEGER (-310..310)
Output power transmitted by the ATU, in tenth dBm.
As per the MIB.
adslAturCurrAttainableRate (1.3.6.1.2.1.10.94.1.1.3.1.8)
read-only
Gauge32
As per the MIB.
adslAtucChanTable
About this table
This table contains parameters of an ATUC channel.
Create
Edit/Modify
Delete
Read
Not supported
Not supported
Not supported
Supported
Columns
The table index is adslAtucChanInterleaveDelay.
Object (OID)
Access
Value range
Implementation
adslAtucChanCurrTxRate (1.3.6.1.2.1.10.94.1.1.4.1.2)
read-only
Gauge32
Actual transmit rate on the  channel.
As per the MIB.
adslAturChanTable
About this table
This table contains parameters of an ATUR channel.
Create
Edit/Modify
Delete
Read
Not supported
Not supported
Not supported
Supported
Columns
The table index is adslAturChanInterleaveDelay.
Object (OID)
Access
Value range
Implementation
adslAturChanCurrTxRate (1.3.6.1.2.1.10.94.1.1.5.1.2)
read-only
Gauge32
As per the MIB.
