03-HH3C-E1T1VI-MIB | 55.13 KB |
HH3C-E1T1VI-MIB
About this MIB
Use this MIB to obtain E1 or T1 voice interface information.
MIB file name
hh3c-e1t1vi.mib
Root object
iso(1).org(3).dod(6).internet(1).private(4).enterprises(1).hh3c(25506).hh3cCommon(2).hh3cE1T1VI(76)
Tabular objects
hh3cE1T1VITable
About this table
This table contains E1 or T1 voice interface information.
Support for operations
Create |
Edit/Modify |
Delete |
Read |
Not supported |
Not supported |
Not supported |
Supported |
Columns
The table index is hh3cE1T1VIUsingTimeslots.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cE1T1VIUsingTimeslots (1.3.6.1.4.1.25506.2.76.1.1.1) |
read-only |
Integer32 |
Standard MIB values. |
Number of time slots used on an E1 or T1 interface. |
As per the MIB. |
hh3cE1T1VIUsingTimeslotsRatio (1.3.6.1.4.1.25506.2.76.1.1.2) |
read-only |
Integer32 |
Ratio of used time slots to all time slots on the interface. |
As per the MIB. |
hh3cE1T1VIGeneral
About this table
Use this table to configure attributes of an E1 or T1 interface globally.
Create |
Edit/Modify |
Delete |
Read |
Not supported |
Not supported |
Not supported |
Supported |
Columns
The table index is hh3cE1T1VITrapTimeSlotEnable.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cE1T1VITrapTimeSlotEnable (1.3.6.1.4.1.25506.2.76.3.1) |
read-write |
INTEGER |
enable(1), disable(2) |
Enabling status of notifications for all time slots on an E1 or T1 interface being used. |
As per the MIB. |
Notifications
Basic information
OID |
Event |
Type |
Severity |
Recovery notification |
Default status |
1.3.6.1.4.1.25506.2.76.2.0.1 |
All time slots of an E1 or T1 interface were being used. |
Informational |
Warning |
N/A |
ON |
Notification triggers
This notification is generated when all time slots of an E1 or T1 interface are being used.
System impact
No time slots can be used by new voice services.
Status control
The notification cannot be disabled.
Objects
OID (object name) |
Index nodes |
Type |
Value range |
1.3.6.1.2.1.2.2.1.1 (ifIndex) |
Index of an E1 or T1 interface. |
ifIndex |
InterfaceIndex |
Integer32 (1..2147483647) |
1.3.6.1.2.1.2.2.1.2 (ifDescr) |
Description of the interface. |
ifIndex |
DisplayString |
OCTET STRING (SIZE (0..255)) |
Recommended action
No action is required.
