05-HH3C-LswINF-MIB | 133.84 KB |
hh3cSlotPortMax (1.3.6.1.4.1.25506.8.35.5.1.1)
hh3cSwitchPortMax (1.3.6.1.4.1.25506.8.35.5.1.2)
hh3cIsolateGroupMax (1.3.6.1.4.1.25506.8.35.5.1.5)
hh3cMaxMacLearnRange (1.3.6.1.4.1.25506.8.35.5.1.12)
HH3C-LswINF-MIB
About this MIB
Use this MIB to manage interfaces.
An isolation group either can have only one uplink port or does not have any uplink port. You can create an isolation group, specify an uplink port for the group, add member ports to the group, and then remove the uplink port.
Speed autonegotiation allows an interface to operate at the possible fastest speed. You can set the speed modes that an interface can automatically negotiated with the peer interface to meet various speed requirements.
MIB file name
hh3c-splat-inf.mib
Root object
iso(1).org(3).dod(6).internet(1).private(4).enterprises(1).hh3c(25506).hh3cRhw(8).hh3clswCommon(35) .hh3cLswL2InfMib(5)
Scalar objects
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cSlotPortMax (1.3.6.1.4.1.25506.8.35.5.1.1) |
read-only |
INTEGER |
1..65535 |
Maximum number of ports on a slot. |
As per the MIB. |
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cSwitchPortMax (1.3.6.1.4.1.25506.8.35.5.1.2) |
read-only |
INTEGER |
1..65535 |
Maximum number of ports on the switch. |
As per the MIB. |
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cIsolateGroupMax (1.3.6.1.4.1.25506.8.35.5.1.5) |
read-only |
Integer32 |
Integer32(1..2147483647) |
Maximum number of isolation groups supported by the switch. |
As per the MIB. |
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cMaxMacLearnRange (1.3.6.1.4.1.25506.8.35.5.1.12) |
read-only |
Integer32 |
Maximum number of MAC addresses supported by an interface. |
2048 on MSR 2630. 8192 on MSR3600si. 16384 on other devices. |
Tabular objects
hh3cifXXTable
About this table
This table contains extended information for an interface.
Support for operations
Create |
Edit/Modify |
Delete |
Read |
Not supported |
Not supported |
Not supported |
Supported |
Columns
The table index is hh3cifUnBoundPort.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cifVLANType (1.3.6.1.4.1.25506.8.35.1.1.1.5) |
read-write |
INTEGER |
vLANTrunk(1), access(2), hybrid(3), fabric(4) |
VLAN type. |
fabric(4) is not supported. |
hh3cifMcastControl (1.3.6.1.4.1.25506.8.35.1.1.1.6) |
read-write |
INTEGER |
INTEGER (0..100) |
Multicast control |
Implementation varies by product. |
hh3cifFlowControl (1.3.6.1.4.1.25506.8.35.1.1.1.7) |
read-write |
TruthValue |
true(1), false(2) |
Flow Control |
As per the MIB. |
hh3cifClearStat (1.3.6.1.4.1.25506.8.35.1.1.1.9) |
read-write |
INTEGER |
clear(1) |
Clear packet statistics on the interface. |
Supports only the read operation. |
hh3cifXXBasePortIndex (1.3.6.1.4.1.25506.8.35.1.1.1.10) |
read-only |
INTEGER |
INTEGER |
Index of the interface. |
As per the MIB. |
hh3cifXXDevPortIndex (1.3.6.1.4.1.25506.8.35.1.1.1.11) |
read-only |
INTEGER |
INTEGER |
As per the MIB. |
hh3cifPpsMcastControl (1.3.6.1.4.1.25506.8.35.1.1.1.12) |
read-write |
Integer32 |
Integer32 (-2147483648..2147483647) |
Multicast suppression threshold in pps. |
As per the MIB. |
hh3cifUniSuppression (1.3.6.1.4.1.25506.8.35.1.1.1.18) |
read-write |
Integer32 |
Unicast suppression threshold in percentage. |
hh3cifPpsUniSuppression (1.3.6.1.4.1.25506.8.35.1.1.1.19) |
read-write |
Integer32 |
Unicast suppression threshold in pps. |
As per the MIB. |
hh3cifMulSuppression (1.3.6.1.4.1.25506.8.35.1.1.1.20) |
read-write |
Integer32 |
Multicast suppression threshold in percentage. |
hh3cifPpsMulSuppression (1.3.6.1.4.1.25506.8.35.1.1.1.21) |
read-write |
Integer32 |
As per the MIB. |
hh3cifHybridPortTable
About this table
This table contains hybrid interface information.
Create |
Edit/Modify |
Delete |
Read |
Not supported |
Not supported |
Not supported |
Supported |
Columns
The table index is hh3cifHybridPortIndex.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cifHybridPortIndex (1.3.6.1.4.1.25506.8.35.1.3.1.1) |
read-only |
INTEGER |
INTEGER |
Index of a hybrid interface. |
As per the MIB. |
hh3cifHybridTaggedVlanListLow (1.3.6.1.4.1.25506.8.35.1.3.1.2) |
read-write |
OCTET STRING |
OCTET STRING (0..256) |
Per-bit representation of tagged VLANs (in the range of VLAN 1 to VLAN 2048). Each bit in an octet represents a VLAN. If a bit is set to 1, the VLAN represented by this bit is a tagged VLAN. |
As per the MIB. |
hh3cifHybridTaggedVlanListHigh (1.3.6.1.4.1.25506.8.35.1.3.1.3) |
read-write |
OCTET STRING |
Per-bit representation of tagged VLANs (in the range of VLAN 2049 to VLAN 4094). Each bit in an octet represents a VLAN. If a bit is set to 1, the VLAN represented by this bit is a tagged VLAN. |
As per the MIB. |
hh3cifHybridUnTaggedVlanListLow (1.3.6.1.4.1.25506.8.35.1.3.1.4) |
read-write |
OCTET STRING |
Per-bit representation of untagged VLANs (in the range of VLAN 1 to VLAN 2048). Each bit in an octet represents a VLAN. If a bit is set to 1, the VLAN represented by this bit is an untagged VLAN. |
As per the MIB. |
hh3cifHybridUnTaggedVlanListHigh (1.3.6.1.4.1.25506.8.35.1.3.1.5) |
read-write |
OCTET STRING |
Per-bit representation of untagged VLANs (in the range of VLAN 2049 to VLAN 4094). Each bit in an octet represents a VLAN. If a bit is set to 1, the VLAN represented by this bit is an untagged VLAN. |
As per the MIB. |
hh3cifComboPortTable
About this table
This table contains combo interface information.
Create |
Edit/Modify |
Delete |
Read |
Not supported |
Not supported |
Not supported |
Supported |
Columns
The table index is hh3cifComboPortIndex.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cifComboPortIndex (1.3.6.1.4.1.25506.8.35.1.4.1.1) |
read-only |
Integer32 |
Index of a combo interface. |
As per the MIB. |
hh3cifComboPortCurActive (1.3.6.1.4.1.25506.8.35.1.4.1.2) |
read-write |
INTEGER |
fiber(1) copper(2) na(3) auto(4) |
Type of the activated combo port. |
As per the MIB. |
hh3cifVLANTrunkStatusTable
About this table
This table contains GVRP attributes for a trunk port.
Create |
Edit/Modify |
Delete |
Read |
Not supported |
Not supported |
Not supported |
Supported |
Columns
The table index is hh3cifVLANTrunkIndex.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cifVLANTrunkIndex (1.3.6.1.4.1.25506.8.35.5.1.3.1.1) |
read-only |
INTEGER |
INTEGER |
Index of a trunk port. |
As per the MIB. |
hh3cifVLANTrunkPassListLow (1.3.6.1.4.1.25506.8.35.5.1.3.1.4) |
read-only |
OCTET STRING |
Per-bit representation of permitted VLANs (in the range of VLAN 1 to VLAN 2048) on the port. Each bit in an octet represents a VLAN. If a bit is set to 1, the VLAN represented by this bit is a trunked VLAN. |
As per the MIB. |
hh3cifVLANTrunkPassListHigh (1.3.6.1.4.1.25506.8.35.5.1.3.1.5) |
read-only |
OCTET STRING |
Per-bit representation of permitted VLANs (in the range of VLAN 2049 to VLAN 4094) on the port. Each bit in an octet represents a VLAN. If a bit is set to 1, the VLAN represented by this bit is a trunked VLAN. |
As per the MIB. |
hh3cifVLANTrunkAllowListLow (1.3.6.1.4.1.25506.8.35.5.1.3.1.6) |
read-write |
OCTET STRING |
You must specify this object and hh3cifVLANTrunkAllowListHigh in pairs in an SNMP request. |
hh3cifVLANTrunkAllowListHigh (1.3.6.1.4.1.25506.8.35.5.1.3.1.7) |
read-write |
OCTET STRING |
You must specify this object and hh3cifVLANTrunkAllowListLow in pairs in an SNMP request. |
hh3cethernetTable of hh3cLswL2InfMibObject
About this table
This table contains Layer 2 interface settings.
Create |
Edit/Modify |
Delete |
Read |
Not supported |
Not supported |
Not supported |
Supported |
Columns
The table index is hh3cifEthernetDuplex.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cifEthernetDuplex (1.3.6.1.4.1.25506.8.35.5.1.4.1.3) |
read-write |
INTEGER |
full(1), half(2), auto(3) |
Duplex mode of an interface. |
Values half and auto are supported only when the interface operates at a speed higher than 1000 Mbps or is connected to a fiber connector. Layer 3 interfaces do not support write operation. |
hh3cifEthernetMTU (1.3.6.1.4.1.25506.8.35.5.1.4.1.4) |
read-write |
INTEGER |
1..65535 |
MTU of the interface. |
Supported. The value range is 1518 to 9018. To perform write operations, the interface must operate in bridging mode and support setting jumbo frames at the CLI. For setting operations, value 1 enables the function (equal to the maximum set value), and value 2 disables the function (equal to the minimum set value). |
hh3cifEthernetSpeed (1.3.6.1.4.1.25506.8.35.5.1.4.1.5) |
read-write |
INTEGER |
auto(0), s10M(10), s100M(100), s1000M(1000), s2500M(2500), s5000M(5000), s10000M(10000), s24000M(24000), s40000M(40000), s20000M(20000), s25000M(25000), s50000M(50000), s100000M(100000) |
Speed of the interface. |
Ethernet interfaces do not support values s1000 and higher. GE interfaces do not support values s10000 and higher. |
hh3cifEthernetMdi (1.3.6.1.4.1.25506.8.35.5.1.4.1.7) |
read-write |
INTEGER |
mdi-ii(1), mdi-x(2), mdi-auto(3) |
MDI type of the interface. |
GE, XGE, 20GE, 25GE, 40GE, 50GE, and 100GE interfaces that connect to fiber connectors do not support write operation. |
hh3cMaxMacLearn (1.3.6.1.4.1.25506.8.35.5.1.4.1.8) |
read-write |
INTEGER |
-1..2147483647 |
Maximum number of MAC addresses that the interface can learn. |
The value of this object must be smaller than the maximum number of MAC addresses supported on the interface. |
hh3cifMacAddressLearn (1.3.6.1.4.1.25506.8.35.5.1.4.1.9) |
read-only |
INTEGER |
enabled(1), disabled(2) |
Enabling status of MAC address learning on the interface. |
As per the MIB. |
hh3cifEthernetFlowInterval (1.3.6.1.4.1.25506.8.35.5.1.4.1.12) |
read-write |
INTEGER |
5..300 |
Flow interval of the interface. |
Supported. The object can only be read. |
read-write |
INTEGER |
5..300 |
read-write |
INTEGER |
5..300 |
read-write |
INTEGER |
5..300 |
hh3cifIsolateGroupID (1.3.6.1.4.1.25506.8.35.5.1.4.1.17) |
read-write |
Integer32 |
ID of the isolation group to which the interface belongs. |
Value 0 indicates that the interface does not belong to any isolation group. |
hh3cifEthernetAutoSpeedMask (1.3.6.1.4.1.25506.8.35.5.1.4.1.19) |
read-only |
SpeedModeFlagBITS |
BITS{ s10M(0), s100M(1), s1000M(2), s10000M(3), s24000M(4), s40000M(5), s100000M(6), s2500M(7), s5000M(8), s20000M(9), s25000M(10), s50000M(11) } |
Speed modes that can be negotiated |
As per the MIB. |
hh3cifEthernetAutoSpeed (1.3.6.1.4.1.25506.8.35.5.1.4.1.20) |
read-write |
SpeedModeFlagBITS |
Speed modes that are negotiable on this port |
As per the MIB. |
hh3cPortIsolateGroupTable
About this table
This table contains isolation group settings.
Create |
Edit/Modify |
Delete |
Read |
Not supported |
Supported |
Supported |
Supported |
Columns
The table index is hh3cPortIsolateGroupIndex.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cPortIsolateGroupIndex (1.3.6.1.4.1.25506.8.35.5.1.11.1.1) |
not-accessible |
Integer32 |
Index of an isolation group. |
As per the MIB. |
hh3cPortIsolateGroupRowStatus (1.3.6.1.4.1.25506.8.35.5.1.11.1.3) |
read-create |
INTEGER |
INTEGER |
Row status. |
Supports only the following values: createAndGo, destroy, and active. Isolation group is available only when the row is in active status. You can set this object only when the device supports multiple isolation groups. |
