06-Interface
HomeSupportReference GuidesMIB CompanionH3C MSR Router Series MIB Reference-R6749-6W10006-Interface
04-HH3C-IF-EXT-MIB
04-HH3C-IF-EXT-MIB 279.00 KB
HH3C-IF-EXT-MIB
About this MIB
Use this MIB to manage and describe interfaces.
MIB file name
hh3c-if-ext.mib
Root object
iso(1).org(3).dod(6).internet(1).private(4).enterprises(1).hh3c(25506).hh3cCommon(2).hh3cIfExt(40)
Scalar objects
hh3cIfShutDownInterval (1.3.6.1.4.1.25506.2.40.1.2)
Object (OID)
Access
Value range
Implementation
read-write
Integer32
Integer32(1..2147483647)
Port status detection timer.
0..300
hh3cIfThroughputInKbps (1.3.6.1.4.1.25506.2.40.1.3)
Object (OID)
Access
Value range
Implementation
read-only
CounterBasedGauge64
Counter64(0..18446744073709551615)
Actual inbound throughput of the device.
As per the MIB.
hh3cIfThroughputOutKbps (1.3.6.1.4.1.25506.2.40.1.4)
Object (OID)
Access
Value range
Implementation
read-only
CounterBasedGauge64
Actual outbound throughput of the device.
As per the MIB.
hh3cIfPhysicalNumber (1.3.6.1.4.1.25506.2.40.2.3.1)
Object (OID)
Access
Value range
Implementation
read-only
Integer32
Number of physical interfaces on the device.
As per the MIB.
Tabular objects
hh3cIfFlowStatTable
About this table
Use this table to obtain the interface traffic information.
Support for operations
Create
Edit/Modify
Delete
Read
Not supported
Not supported
Not supported
Supported
Columns
The table index is hh3cIfStatFlowInterval.
Object (OID)
Access
Value range
Implementation
hh3cIfStatFlowInterval (1.3.6.1.4.1.25506.2.40.2.1.2.1.1.1)
read-write
Integer32
Integer32(1..300)
Traffic statistics polling interval.
Supported. Implementation varies by product.
hh3cIfStatFlowInBits (1.3.6.1.4.1.25506.2.40.2.1.2.1.1.2)
read-only
Unsigned32
Unsigned32 (0..4294967295)
Incoming traffic in bits.
As per the MIB.
hh3cIfStatFlowOutBits (1.3.6.1.4.1.25506.2.40.2.1.2.1.1.3)
read-only
Unsigned32
Outgoing traffic in bits.
As per the MIB.
hh3cIfStatFlowInPkts (1.3.6.1.4.1.25506.2.40.2.1.2.1.1.4)
read-only
Unsigned32
Incoming traffic in packets.
As per the MIB.
hh3cIfStatFlowOutPkts (1.3.6.1.4.1.25506.2.40.2.1.2.1.1.5)
read-only
Unsigned32
Outgoing traffic in packets.
As per the MIB.
hh3cIfStatFlowInBytes (1.3.6.1.4.1.25506.2.40.2.1.2.1.1.6)
read-only
Unsigned32
Incoming traffic in bytes.
As per the MIB.
hh3cIfStatFlowOutBytes (1.3.6.1.4.1.25506.2.40.2.1.2.1.1.7)
read-only
Unsigned32
Outgoing traffic in bytes.
As per the MIB.
hh3cIfSpeedStatTable
About this table
Use this table to obtain the interface traffic speed statistics.
Create
Edit/Modify
Delete
Read
Not supported
Not supported
Not supported
Supported
Columns
The table index is hh3cIfSpeedStatInterval.
Object (OID)
Access
Value range
Implementation
hh3cIfSpeedStatInterval (1.3.6.1.4.1.25506.2.40.2.1.2.2.1.1)
read-write
Integer32
Integer32(1..300)
Interface traffic speed statistics polling interval. 0 indicates the interface traffic speed statistics collection feature is disabled.
hh3cIfSpeedStatInPkts (1.3.6.1.4.1.25506.2.40.2.1.2.2.1.2)
read-only
Unsigned32
Average incoming traffic speed (in pps) of the interface within the specified interval before the latest sampling point. The interval is specified by h3cIfSpeedStatInterval.
As per the MIB.
hh3cIfSpeedStatOutPkts (1.3.6.1.4.1.25506.2.40.2.1.2.2.1.3)
read-only
Unsigned32
Average outgoing traffic speed (in pps) of the interface within the specified interval before the latest sampling point. The interval is specified by h3cIfSpeedStatInterval.
As per the MIB.
hh3cIfSpeedStatInBytes (1.3.6.1.4.1.25506.2.40.2.1.2.2.1.4)
read-only
Unsigned32
Average incoming traffic speed (in Bps) of the interface within the specified interval before the latest sampling point. The interval is specified by h3cIfSpeedStatInterval.
As per the MIB.
hh3cIfSpeedStatOutBytes (1.3.6.1.4.1.25506.2.40.2.1.2.2.1.5)
read-only
Unsigned32
Average outgoing traffic speed (in Bps) of the interface within the specified interval before the latest sampling point. The interval is specified by h3cIfSpeedStatInterval.
As per the MIB.
hh3cIfHCFlowStatTable
About this table
Use this table to obtain the 64-bit traffic information of interfaces.
Create
Edit/Modify
Delete
Read
Not supported
Not supported
Not supported
Supported
Columns
The table index is hh3cIfStatFlowHCInBits.
Object (OID)
Access
Value range
Implementation
hh3cIfStatFlowHCInBits (1.3.6.1.4.1.25506.2.40.2.1.2.3.1.1)
read-only
CounterBasedGauge64
Counter64 (0..18446744073709551615)
Incoming traffic in bits (64-bit version).
As per the MIB.
hh3cIfStatFlowHCOutBits (1.3.6.1.4.1.25506.2.40.2.1.2.3.1.2)
read-only
CounterBasedGauge64
Outgoing traffic in bits (64-bit version).
As per the MIB.
hh3cIfStatFlowHCInPkts (1.3.6.1.4.1.25506.2.40.2.1.2.3.1.3)
read-only
CounterBasedGauge64
Incoming traffic in packets (64-bit version).
As per the MIB.
hh3cIfStatFlowHCOutPkts (1.3.6.1.4.1.25506.2.40.2.1.2.3.1.4)
read-only
CounterBasedGauge64
Outgoing traffic in packets (64-bit version).
As per the MIB.
hh3cIfStatFlowHCInBytes (1.3.6.1.4.1.25506.2.40.2.1.2.3.1.5)
read-only
CounterBasedGauge64
Incoming traffic in bytes (64-bit version).
As per the MIB.
hh3cIfStatFlowHCOutBytes (1.3.6.1.4.1.25506.2.40.2.1.2.3.1.6)
read-only
CounterBasedGauge64
Outgoing traffic in bytes (64-bit version).
As per the MIB.
hh3cRTParentIfTable
About this table
Use this table to obtain main interface information of subinterfaces.
Create
Edit/Modify
Delete
Read
Not supported
Not supported
Not supported
Supported
Columns
The table index is hh3cRTParentIfIndex.
Object (OID)
Access
Value range
Implementation
hh3cRTParentIfIndex (1.3.6.1.4.1.25506.2.40.2.2.1.1.1)
not-accessible
Integer32
Main interface index. Index of the interface for which you can create subinterfaces.
As per the MIB.
hh3cRTMinSubIfOrdinal (1.3.6.1.4.1.25506.2.40.2.2.1.1.2)
read-only
Integer32
Minimum number of the subinterface that can be created.
As per the MIB.
hh3cRTMaxSubIfOrdinal (1.3.6.1.4.1.25506.2.40.2.2.1.1.3)
read-only
Integer32
Maximum number of the subinterface that can be created.
As per the MIB.
hh3cRTSubIfTable
About this table
Use this table to obtain information about subinterface information of main interfaces.
Create
Edit/Modify
Delete
Read
Not supported
Not supported
Not supported
Supported
Columns
The table index is hh3cRTSubIfParentIfIndex.
Object (OID)
Access
Value range
Implementation
hh3cRTSubIfParentIfIndex (1.3.6.1.4.1.25506.2.40.2.2.2.1.1)
not-accessible
Integer32
As per the MIB.
hh3cRTSubIfOrdinal (1.3.6.1.4.1.25506.2.40.2.2.2.1.2)
not-accessible
Integer32
Subinterface number.
As per the MIB.
hh3cRTSubIfSubIfIndex (1.3.6.1.4.1.25506.2.40.2.2.2.1.3)
read-only
Integer32
Subinterface index.
As per the MIB.
hh3cRTSubIfSubIfDesc (1.3.6.1.4.1.25506.2.40.2.2.2.1.4)
read-only
DisplayString
OCTET STRING(0..255)
Subinterface description.
As per the MIB.
hh3cRTSubIfRowStatus (1.3.6.1.4.1.25506.2.40.2.2.2.1.5)
read-create
RowStatus
active(1),
notInService(2),
notReady(3),
createAndGo(4),
createAndWait(5),
destroy(6)
Subinterface state.
Available values are active(1), createAndGo(4), and destroy(6).
hh3cIfLinkModeTable
About this table
Use this table to obtain the interface link mode.
Create
Edit/Modify
Delete
Read
Not supported
Not supported
Not supported
Supported
Columns
The table index is hh3cIfLinkModeIndex.
Object (OID)
Access
Value range
Implementation
hh3cIfLinkModeIndex (1.3.6.1.4.1.25506.2.40.2.2.3.1.1)
not-accessible
Integer32
1..2147483647
Link mode index.
As per the MIB.
hh3cIfLinkMode (1.3.6.1.4.1.25506.2.40.2.2.3.1.2)
read-write
INTEGER
bridgeMode(1),
routeMode(2)
Current link mode of the interface.
As per the MIB.
hh3cIfLinkModeSwitchSupport (1.3.6.1.4.1.25506.2.40.2.2.3.1.3)
read-only
TruthValue
true(1),
false(2)
Whether the link mode of the interface can be switched.
As per the MIB.
hh3cIfPortTypeTable
About this table
Use this table to obtain the port type of an interface.
Create
Edit/Modify
Delete
Read
Not supported
Not supported
Not supported
Supported
Columns
The table index is hh3cIfPortTypeIndex.
Object (OID)
Access
Value range
Implementation
hh3cIfPortTypeIndex (1.3.6.1.4.1.25506.2.40.2.2.4.1.1)
not-accessible
Integer32
Interface index, which is the same as ifIndex in ifTable.
As per the MIB.
hh3cIfPortType (1.3.6.1.4.1.25506.2.40.2.2.4.1.2)
read-write
INTEGER
other(1),ethernet(2),fc(3)
Ethernet/ FC mode of an interface.
As per the MIB.
hh3cIfTable
About this table
Use this table to obtain interface-related information.
Create
Edit/Modify
Delete
Read
Not supported
Not supported
Not supported
Supported
Columns
The table index is hh3cIfUpDownTimes.
Object (OID)
Access
Value range
Implementation
hh3cIfUpDownTimes (1.3.6.1.4.1.25506.2.40.2.3.2.1.1)
read-only
Integer32
Number of interface up/down events.
As per the MIB.
hh3cIfMtu (1.3.6.1.4.1.25506.2.40.2.3.2.1.2)
read-write
Integer32
Interface MTU.
As per the MIB.
hh3cIfStatusKeepTime (1.3.6.1.4.1.25506.2.40.2.3.2.1.5)
read-only
TimeTicks
TimeTicks (0..4294967295)
Duration of the current interface state.
As per the MIB.
hh3cIfPfcStatus (1.3.6.1.4.1.25506.2.40.2.3.2.1.11)
read-write
INTEGER
enable(1),
disable(2),
auto(3)
PFC mode of an interface.
hh3cIfPfcDot1pNoDrop (1.3.6.1.4.1.25506.2.40.2.3.2.1.12)
read-write
BITS
pri0(0), pri1(1), pri2(2), pri3(3), pri4(4), pri5(5), pri6(6), pri7(7)
802.1p priority list for PFC on an interface.
hh3cIfDescription (1.3.6.1.4.1.25506.2.40.2.3.2.1.13)
read-write
DisplayString
Description of an interface.
As per the MIB.
hh3cIfFwdErrDiscards
(1.3.6.1.4.1.25506.2.40.2.3.2.1.14)
read-only
Unsigned32
Number of packets dropped because of forwarding entry errors on an interface.
As per the MIB.
hh3cIfUsingTable
About this table
Use this table to obtain information about breakout interfaces.
Create
Edit/Modify
Delete
Read
Not supported
Not supported
Not supported
Supported
Columns
The table index is hh3cIfUsingIndex.
Object (OID)
Access
Value range
Implementation
hh3cIfUsingIndex (1.3.6.1.4.1.25506.2.40.2.3.3.1.1)
not-accessible
Integer32
Index of an interface that can be split or combined.
As per the MIB.
hh3cIfUsingSupportType (1.3.6.1.4.1.25506.2.40.2.3.3.1.2)
read-only
Integer32
Interface type that an interface can be split or combined into.
As per the MIB.
hh3cIfUsingType (1.3.6.1.4.1.25506.2.40.2.3.3.1.3)
read-write
INTEGER
noUsing(0),
using10GE(1),
using20GE(2),
using40GE(3),
using100GE(4),
using25GE(5),
using50GE(6)
using200GE(7)
using400GE(8)
Interface type that an interface will be split or combined into.
As per the MIB.
hh3cIfUsingStatus (1.3.6.1.4.1.25506.2.40.2.3.3.1.4)
read-only
INTEGER
noUsing(0),
needReboot(1)
State of the splitting or combining operation.
As per the MIB.
hh3cIfHCSpeedStatTable
About this table
Use this table to obtain the 64-bit packet statistics of an interface.
Create
Edit/Modify
Delete
Read
Not supported
Not supported
Not supported
Supported
Columns
The table index is hh3cIfSpeedStatHCInPkts.
Object (OID)
Access
Value range
Implementation
hh3cIfSpeedStatHCInPkts (1.3.6.1.4.1.25506.2.40.2.1.2.4.1.1)
read-only
CounterBasedGauge64
Average incoming traffic speed (in packets) of the interface within the specified interval before the latest sampling point.
As per the MIB.
hh3cIfSpeedStatHCOutPkts (1.3.6.1.4.1.25506.2.40.2.1.2.4.1.2)
read-only
CounterBasedGauge64
Average outgoing traffic speed (in packets) of the interface within the specified interval before the latest sampling point.
As per the MIB.
hh3cIfSpeedStatHCInBytes (1.3.6.1.4.1.25506.2.40.2.1.2.4.1.3)
read-only
CounterBasedGauge64
Average incoming traffic speed (in bytes) of the interface within the specified interval before the latest sampling point.
As per the MIB.
hh3cIfSpeedStatHCOutBytes (1.3.6.1.4.1.25506.2.40.2.1.2.4.1.4)
read-only
CounterBasedGauge64
Average outgoing traffic speed (in bytes) of the interface within the specified interval before the latest sampling point.
As per the MIB.
hh3cIfMonStatTable
About this table
Use this table to obtain the interface bandwidth usage statistics.
Create
Edit/Modify
Delete
Read
Not supported
Not supported
Not supported
Supported
Columns
The table index is hh3cIfMonInputRateStatistics.
Object (OID)
Access
Value range
Implementation
hh3cIfMonInputUsageStatistics (1.3.6.1.4.1.25506.2.40.5.1.1.1.1)
read-only
Unsigned32
Unsigned32 (0..100)
Inbound bandwidth usage statistics.
This object can only be reported.
hh3cIfMonOutputUsageStatistics (1.3.6.1.4.1.25506.2.40.5.1.1.1.2)
read-only
Unsigned32
Unsigned32 (0..100)
Outbound bandwidth usage statistics.
hh3cIfMonInputErrorAlarmStatistics
(1.3.6.1.4.1.25506.2.40.5.1.1.1.3)
read-only
Counter64
Inbound error alarm statistics.
hh3cIfMonOutputErrorAlarmStatistics
(1.3.6.1.4.1.25506.2.40.5.1.1.1.4)
read-only
Counter64
Outbound error alarm statistics.
hh3cIfMonSdhErrorStatistics
(1.3.6.1.4.1.25506.2.40.5.1.1.1.5)
read-only
Counter64
SDH error statistics.
hh3cIfMonSdhB1ErrorStatistics
(1.3.6.1.4.1.25506.2.40.5.1.1.1.6)
read-only
Counter64
SDH-B1 error statistics.
hh3cIfMonSdhB2ErrorStatistics
(1.3.6.1.4.1.25506.2.40.5.1.1.1.7)
read-only
Counter64
SDH-B2 error statistics.
hh3cIfMonCRCErrorStatistics
(1.3.6.1.4.1.25506.2.40.5.1.1.1.8)
read-only
Counter64
CRC error statistics.
hh3cIfMonRxPauseFrameStatistics
(1.3.6.1.4.1.25506.2.40.5.1.1.1.9)
read-only
Counter64
Received pause frame statistics.
hh3cIfMonTxPauseFrameStatistics
(1.3.6.1.4.1.25506.2.40.5.1.1.1.10)
read-only
Counter64
Transmitted pause frame statistics.
hh3cIfMonThresholdTable
About this table
Use this table to set the thresholds for statistics of an interface.
Create
Edit/Modify
Delete
Read
Not supported
Supported
Not supported
Supported
Columns
The table index is hh3cIfMonInputUsageLowThres.
Object (OID)
Access
Value range
Implementation
(1.3.6.1.4.1.25506.2.40.5.2.1.1.1)
read-write
Unsigned32
Lower threshold for the inbound bandwidth usage.
This object can only be reported and modified.
hh3cIfMonInputUsageHighThres
(1.3.6.1.4.1.25506.2.40.5.2.1.1.2)
read-write
Unsigned32
Upper threshold for the inbound bandwidth usage.
hh3cIfMonOutputUsageLowThres
(1.3.6.1.4.1.25506.2.40.5.2.1.1.3)
read-write
Unsigned32
Lower threshold for the outbound bandwidth usage.
hh3cIfMonOutputUsageHighThres
 (1.3.6.1.4.1.25506.2.40.5.2.1.1.4)
read-write
Unsigned32
Upper threshold for the outbound bandwidth usage.
hh3cIfMonInputErrorAlarmLowThres
(1.3.6.1.4.1.25506.2.40.5.2.1.1.5)
read-write
Unsigned32
Lower threshold for the number of inbound error packets.
hh3cIfMonInputErrorAlarmHighThres
(1.3.6.1.4.1.25506.2.40.5.2.1.1.6)
read-write
Unsigned32
Upper threshold for the number of inbound error packets.
hh3cIfMonInputErrorAlarmInterval (1.3.6.1.4.1.25506.2.40.5.2.1.1.7)
read-write
Unsigned32
Unsigned32 (0..65535)
Inspection interval for the number of inbound error packets.
hh3cIfMonOutputErrorAlarmLowThres
(1.3.6.1.4.1.25506.2.40.5.2.1.1.8)
read-write
Unsigned32
Inspection interval for the number of outbound error packets.
hh3cIfMonOutputErrorAlarmHighThres
(1.3.6.1.4.1.25506.2.40.5.2.1.1.9)
read-write
Unsigned32
Upper threshold for the number of outbound error packets.
hh3cIfMonOutputErrorAlarmInterval
(1.3.6.1.4.1.25506.2.40.5.2.1.1.10)
read-write
Unsigned32
hh3cIfMonSdhErrorLowThres
(1.3.6.1.4.1.25506.2.40.5.2.1.1.11)
read-write
Unsigned32
Lower threshold for the number of SDH error packets.
hh3cIfMonSdhErrorHighThres
(1.3.6.1.4.1.25506.2.40.5.2.1.1.12)
read-write
Unsigned32
Upper threshold for the number of SDH error packets.
hh3cIfMonSdhErrorInterval
(1.3.6.1.4.1.25506.2.40.5.2.1.1.13)
read-write
Unsigned32
Inspection interval for the number of SDH error packets.
hh3cIfMonSdhB1ErrorLowThres
(1.3.6.1.4.1.25506.2.40.5.2.1.1.14)
read-write
Unsigned32
Lower threshold for the number of SDH B1 error packets.
hh3cIfMonSdhB1ErrorHighThres
(1.3.6.1.4.1.25506.2.40.5.2.1.1.15)
read-write
Unsigned32
Upper threshold for the number of SDH B1 error packets.
hh3cIfMonSdhB1ErrorInterval
(1.3.6.1.4.1.25506.2.40.5.2.1.1.16)
read-write
Unsigned32
Inspection interval for the number of SDH B1 error packets.
hh3cIfMonSdhB2ErrorLowThres
(1.3.6.1.4.1.25506.2.40.5.2.1.1.17)
read-write
Unsigned32
Lower threshold for the number of SDH B2 error packets.
hh3cIfMonSdhB2ErrorHighThres
(1.3.6.1.4.1.25506.2.40.5.2.1.1.18)
read-write
Unsigned32
Upper threshold for the number of SDH B2 error packets.
hh3cIfMonSdhB2ErrorInterval
(1.3.6.1.4.1.25506.2.40.5.2.1.1.19)
read-write
Unsigned32
Inspection interval for the number of SDH B2 error packets.
hh3cIfMonCRCErrorLowThres
(1.3.6.1.4.1.25506.2.40.5.2.1.1.20)
read-write
Unsigned32
Lower threshold for the number of CRC error packets.
hh3cIfMonCRCErrorHighThres
(1.3.6.1.4.1.25506.2.40.5.2.1.1.21)
read-write
Unsigned32
Upper threshold for the number of CRC error packets.
hh3cIfMonCRCErrorInterval
(1.3.6.1.4.1.25506.2.40.5.2.1.1.22)
read-write
Unsigned32
Inspection interval for the number of CRC error packets.
hh3cIfMonCRCErrType
(1.3.6.1.4.1.25506.2.40.5.2.1.1.23)
read-write
INTEGER
Absolute(1)
Ratio(2)
Invalid(65535)
Inspection type for the CRC error packets.
hh3cIfMonRxPauseFrameLowThres
(1.3.6.1.4.1.25506.2.40.5.2.1.1.24)
read-write
Unsigned32
Lower threshold for the number of received pause frames.
hh3cIfMonRxPauseFrameHighThres
(1.3.6.1.4.1.25506.2.40.5.2.1.1.25)
read-write
Unsigned32
Upper threshold for the number of received pause frames.
hh3cIfMonRxPauseFrameInterval
(1.3.6.1.4.1.25506.2.40.5.2.1.1.26)
read-write
Unsigned32
Inspection interval for the number of received pause frames.
hh3cIfMonTxPauseFrameLowThres
(1.3.6.1.4.1.25506.2.40.5.2.1.1.27)
read-write
Unsigned32
Lower threshold for the number of transmitted pause frames.
hh3cIfMonTxPauseFrameHighThres
(1.3.6.1.4.1.25506.2.40.5.2.1.1.28)
read-write
Unsigned32
Upper threshold for the number of transmitted pause frames.
hh3cIfMonTxPauseFrameInterval
(1.3.6.1.4.1.25506.2.40.5.2.1.1.29)
read-write
Unsigned32
Inspection interval for the number of transmitted pause frames.
hh3cifMonAlarmDownEnableTable
About this table
Use this table to set or get whether to enable the interface down function.
Create
Edit/Modify
Delete
Read
Not supported
Not supported
Not supported
Supported
Columns
The table index is hh3cIfMonInputErrorAlarmEnableDown.
Object (OID)
Access
Value range
Implementation
(1.3.6.1.4.1.25506.2.40.5.2.2.1.1)
read-write
TruthValue
true(1),
false(2)
Whether to shut down the physical interface when the number of inbound error packets exceeds the upper threshold.
hh3cIfMonOutputErrorAlarmEnableDown
(1.3.6.1.4.1.25506.2.40.5.2.2.1.2)
read-write
TruthValue
true(1),
false(2)
Whether to shut down the physical interface when the number of outbound error packets exceeds the upper threshold.
hh3cIfMonSdhErrorEnableDown
(1.3.6.1.4.1.25506.2.40.5.2.2.1.3)
read-write
TruthValue
true(1),
false(2)
Whether to shut down the physical interface when the number of SDH error packets exceeds the upper threshold.
hh3cIfMonSdhB1ErrorEnableDown
(1.3.6.1.4.1.25506.2.40.5.2.2.1.4)
read-write
TruthValue
true(1),
false(2)
Whether to shut down the physical interface when the number of SDH B1 error packets exceeds the upper threshold.
hh3cIfMonSdhB2ErrorEnableDown
(1.3.6.1.4.1.25506.2.40.5.2.2.1.5)
read-write
TruthValue
true(1),
false(2)
Whether to shut down the physical interface when the number of SDH B2 error packets exceeds the upper threshold.
hh3cIfMonCRCErrorEnableDown
(1.3.6.1.4.1.25506.2.40.5.2.2.1.6)
read-write
TruthValue
true(1),
false(2)
Whether to shut down the physical interface when the number of CRC error packets exceeds the upper threshold.
hh3cIfMonGiantEnableDown (1.3.6.1.4.1.25506.2.40.5.2.2.1.7)
read-write
TruthValue
true(1),
false(2)
Whether to the shut down a physical interface when the number of giant error packets exceeds the upper threshold.
hh3cIfMonRuntEnableDown (1.3.6.1.4.1.25506.2.40.5.2.2.1.8)
read-write
TruthValue
true(1),
false(2)
Whether to the shut down a physical interface when the number of runt error packets exceeds the upper threshold.
hh3cIfMonTxPauseFrameEnableDown (1.3.6.1.4.1.25506.2.40.5.2.2.1.9)
read-write
TruthValue
true(1),
false(2)
Whether to the shut down a physical interface when the number of sent pause frames exceeds the upper threshold.
hh3cIfMonInputBufferDropEnableDown
(1.3.6.1.4.1.25506.2.40.5.2.2.1.10)
read-write
TruthValue
true(1)
false(2)
Whether to the shut down a physical interface when the number of incoming packets dropped in the buffer exceeds the upper threshold.
Notifications
hh3cIfPortUp
Basic information
OID
Event
Severity
Recovery notification
Default status
1.3.6.1.4.1.25506.2.40.3.0.5
Link-up alarm
Recovery
Warning
N/A
ON
Notification triggers
The notification is generated when physical state of the interface changes to up.
Possible reasons are:
·     The undo shutdown command is executed on the interface.
·     The interface or link failure is resolved.
·     The physical state of the interface comes up.
System impact
The interface can normally forward packets.
Status control
ON
CLI: snmp-agent trap enable standard linkup
OFF
CLI: undo snmp-agent trap enable standard linkup
Objects
OID (object name)
Index nodes
Value range
1.3.6.1.2.1.2.2.1.1 (ifIndex)
Interface index.
ifIndex
Integer32
Standard MIB values.
1.3.6.1.2.1.2.2.1.2 (ifDescr)
Interface description.
ifIndex
OCTET STRING
Recommended action
No action is required.
hh3cIfPortDown
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.2.40.3.0.6
Link-down alarm.
Error
Major
1.3.6.1.4.1.25506.2.40.3.0.5 (hh3cIfPortUp)
ON
The notification is generated when physical state of the interface changes to down.
·     The physical link of the interface is down, and the link is disconnected.
·     The interface is shut down.
System impact
The interface cannot normally forward packets.
Status control
ON
OFF
Objects
OID (object name)
Index nodes
Value range
Interface index.
ifIndex
Integer32
ifIndex
OCTET STRING
Recommended action
To resolve this issue:
1.     Execute the display this command in interface view to identify whether the interfaces on both end are shut down. If the interfaces are shut down, execute the undo shutdown command in interface view to bring them up.
2.     Identify whether the physical connection is normal (for example, whether the network cables or transceiver modules are firmly connected). If the physical connection is abnormal, correctly connect the interfaces.
3.     If the issue persists, contact H3C Support.
hh3cIfMonInputUsageRising
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.2.40.6.0.1
Inbound bandwidth usage rising alarm.
Error
Warning
1.3.6.1.4.1.25506.2.40.6.0.2 (hh3cIfMonInputUsageResume)
ON
The notification is generated when the inbound bandwidth usage exceeds the upper threshold.
System impact
When the inbound bandwidth usage reaches about 100%, the service traffic might be delayed or dropped.
Status control
ON
CLI: snmp-agent trap enable ifmonitor input-usage
OFF
CLI: undo snmp-agent trap enable ifmonitor input-usage
Objects
OID (object name)
Index nodes
Value range
Interface index.
ifIndex
Integer32
ifIndex
OCTET STRING
1.3.6.1.4.1.25506.2.40.5.2.1.1.1 (hh3cIfMonInputUsageLowThres)
Unsigned32
0-100
1.3.6.1.4.1.25506.2.40.5.2.1.1.2 (hh3cIfMonInputUsageHighThres)
Unsigned32
0-100
1.3.6.1.4.1.25506.2.40.5.1.1.1.1 (hh3cIfMonInputUsageStatistics)
Counter64
Recommended action
1.     Identify whether the upper threshold set on the interface is too low.
¡     If the threshold is too low, execute the port ifmonitor input-usage command to modify the threshold.
¡     If the threshold is set reasonably, collect alarm information and configuration data, and then contact H3C Support.
Basic information
OID
Event
Severity
Default status
Inbound bandwidth usage recovery alarm
Recovery
Informational
N/A
ON
The notification is generated when the inbound bandwidth usage drops from above the upper threshold to below the lower threshold.
System impact
The service restores.
Status control
ON
OFF
Objects
OID (object name)
Index nodes
Value range
Interface index.
ifIndex
Integer32
ifIndex
OCTET STRING
Unsigned32
0-100
Unsigned32
0-100
Counter64
Recommended action
hh3cIfMonOutputUsageRising
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.2.40.6.0.3
Outbound bandwidth usage rising alarm.
Error
Warning
1.3.6.1.4.1.25506.2.40.6.0.4 (hh3cIfMonOutputUsageResume)
ON
The notification is generated when the outbound bandwidth usage exceeds the upper threshold.
System impact
When the outbound bandwidth usage reaches about 100%, the service traffic might be delayed or dropped.
Status control
ON
CLI: snmp-agent trap enable ifmonitor output-usage
OFF
CLI: undo snmp-agent trap enable ifmonitor output-usage
Objects
OID (object name)
Index nodes
Value range
Interface index.
ifIndex
Integer32
ifIndex
OCTET STRING
1.3.6.1.4.1.25506.2.40.5.2.1.1.3 (hh3cIfMonOutputUsageLowThres)
Unsigned32
0-100
1.3.6.1.4.1.25506.2.40.5.2.1.1.4 (hh3cIfMonOutputUsageHighThres)
Unsigned32
0-100
1.3.6.1.4.1.25506.2.40.5.1.1.1.2 (hh3cIfMonOutputUsageStatistics)
Counter64
Recommended action
¡     If the threshold is too low, execute the port ifmonitor output-usage command to modify the threshold.
Basic information
OID
Event
Severity
Default status
Outbound bandwidth usage recovery alarm
Recovery
Informational
N/A
ON
The notification is generated when the outbound bandwidth usage drops from above the upper threshold to below the lower threshold.
System impact
Status control
ON
OFF
Objects
OID (object name)
Index nodes
Value range
Interface index.
ifIndex
Integer32
ifIndex
OCTET STRING
Unsigned32
1-4294967295
Unsigned32
1-4294967295
Counter64
Recommended action
