- 04-Layer 2—LAN Switching Configuration Guide
- 01-MAC address table configuration
- 02-Ethernet link aggregation configuration
- 03-M-LAG configuration
- 04-Port isolation configuration
- 05-VLAN configuration
- 06-MVRP configuration
- 07-QinQ configuration
- 08-VLAN mapping configuration
- 09-Loop detection configuration
- 10-Spanning tree configuration
- 11-LLDP configuration
- 12-L2PT configuration
- 13-Service loopback group configuration
- 14-PFC configuration
| 13-Service loopback group configuration | 49.11 KB |
Configuring service loopback groups
Restrictions: Hardware compatibility with service loopback group
Restrictions and guidelines: Service loopback group configuration
Configuring a service loopback group
Display and maintenance commands for service loopback groups
About service loopback groups
Only SD interface modules, SF interface modules, and ports on the SC MPUs prefixed with LSCM2 support the service loopback group feature.
When you apply service loopback groups to features, follow these restrictions and guidelines:
· You can apply a service loopback group to other features once the group is created. The service loopback group will process services for the features.
· Do not delete a service loopback group that is being used by a feature.
1. Enter system view.
2. Create a service loopback group and specify its service type.
service-loopback group group-id type vsi-gateway
You can configure only one service loopback group for a service type.
Task |
Command |
Display information about service loopback groups. |
display service-loopback group [ group-id ] |
