18-Network Management and Monitoring
HomeSupportReference GuidesMIB CompanionH3C S6800 & S6860 MIB Companion-Release 6715-6W10018-Network Management and Monitoring
17-SFLOW-MIB
17-SFLOW-MIB 70.24 KB
SFLOW-MIB
About this MIB
Use this MIB to configure sFlow, a traffic monitoring technology.
MIB file name
sflow.mib
Root object
iso(1).org(3).dod(6).internet(1).private(4).enterprises(1).sflow(14706).sFlowMIB(1).sFlowAgent(1)
Scalar objects
sFlowVersion
Object (OID)
Access
Value range
Implementation
sFlowVersion (1.3.6.1.4.1.14706.1.1.1)
read-only
SnmpAdminString
Standard MIB values.
Version information.
As per the MIB.
sFlowAgentAddressType
Object (OID)
Access
Value range
Implementation
sFlowAgentAddressType (1.3.6.1.4.1.14706.1.1.2)
read-only
InetAddressType
Agent address type.
As per the MIB.
sFlowAgentAddress
Object (OID)
Access
Value range
Implementation
sFlowAgentAddress (1.3.6.1.4.1.14706.1.1.3)
read-only
InetAddress
Agent address.
As per the MIB.
Tabular objects
sFlowRcvrTable
About this table
This table configures the sFlow collector information.
Support for operations
Create
Edit/Modify
Delete
Read
Not supported
Supported
Not supported
Supported
Columns
The table index is sFlowRcvrIndex.
Object (OID)
Access
Value range
Implementation
sFlowRcvrIndex (1.3.6.1.4.1.14706.1.1.4.1.1)
not-accessible
INTEGER
Integer32(1..65535)
Collector index.
As per the MIB.
sFlowRcvrOwner (1.3.6.1.4.1.14706.1.1.4.1.2)
read-write
OwnerString
Collector description.
As per the MIB.
sFlowRcvrTimeout (1.3.6.1.4.1.14706.1.1.4.1.3)
read-write
INTEGER
Aging time.
As per the MIB.
sFlowRcvrMaximumDatagramSize (1.3.6.1.4.1.14706.1.1.4.1.4)
read-write
INTEGER
Integer32(200..3000)
Maximum number of data bytes that can be sent in a single sample datagram.
As per the MIB.
sFlowRcvrAddressType (1.3.6.1.4.1.14706.1.1.4.1.5)
read-write
InetAddressType
Collector address type.
As per the MIB.
sFlowRcvrAddress (1.3.6.1.4.1.14706.1.1.4.1.6)
read-write
InetAddress
OCTET STRING (0..255)
Collector IP address.
As per the MIB.
sFlowRcvrPort (1.3.6.1.4.1.14706.1.1.4.1.7)
read-write
INTEGER
UDP port number.
As per the MIB.
sFlowRcvrDatagramVersion (1.3.6.1.4.1.14706.1.1.4.1.8)
read-write
Integer32
Datagram version.
Supports only V5.
sFlowFsTable
About this table
This table configures sFlow flow sampling.
Create
Edit/Modify
Delete
Read
Not supported
Supported
Not supported
Supported
Columns
The table indexes are sFlowFsDataSource and sFlowFsInstance.
Object (OID)
Access
Value range
Implementation
sFlowFsDataSource (1.3.6.1.4.1.14706.1.1.5.1.1)
not-accessible
SFlowDataSource
Data source.
As per the MIB.
sFlowFsInstance (1.3.6.1.4.1.14706.1.1.5.1.2)
not-accessible
SFlowInstance
Instance ID.
As per the MIB.
sFlowFsReceiver (1.3.6.1.4.1.14706.1.1.5.1.3)
read- write
SFlowReceiver
Receiver.
As per the MIB.
sFlowFsPacketSamplingRate (1.3.6.1.4.1.14706.1.1.5.1.4)
read- write
INTEGER
Sampling rate.
As per the MIB.
sFlowFsMaximumHeaderSize (1.3.6.1.4.1.14706.1.1.5.1.5)
read- write
INTEGER
Integer32(18..512)
Maximum number of bytes that should be copied from a sampled packet.
As per the MIB.
sFlowCpTable
About this table
This table configures sFlow counter sampling.
Create
Edit/Modify
Delete
Read
Not supported
Supported
Not supported
Supported
Columns
The table indexes are sFlowCpDataSource and sFlowCpInstance.
Object (OID)
Access
Value range
Implementation
sFlowCpDataSource (1.3.6.1.4.1.14706.1.1.6.1.1)
not-accessible
SFlowDataSource
Data source.
As per the MIB.
sFlowCpInstance (1.3.6.1.4.1.14706.1.1.6.1.2)
not-accessible
SFlowInstance
Instance ID.
As per the MIB.
sFlowCpReceiver (1.3.6.1.4.1.14706.1.1.6.1.3)
read- write
INTEGER
Sampling collector.
As per the MIB.
sFlowCpInterval (1.3.6.1.4.1.14706.1.1.6.1.4)
read- write
INTEGER
Integer32(2..86400)
Sampling interval.
As per the MIB.
