18-Network Management and Monitoring
HomeSupportReference GuidesMIB CompanionH3C S6800 & S6860 MIB Companion-Release 6715-6W10018-Network Management and Monitoring
05-HH3C-ESMC-MIB
05-HH3C-ESMC-MIB 100.62 KB
HH3C-ESMC-MIB
About this MIB
Use this MIB to synchronize the interface alarm functions.
MIB file name
hh3c-esmc.mib
Root object
iso(1).org(3).dod(6).internet(1).private(4).enterprises(1).hh3c(25506).hh3cCommon(2).hh3cEsmc(260)
Scalar objects
hh3cEsmcPortName
Object (OID)
Access
Value range
Implementation
hh3cEsmcPortName (1.3.6.1.4.1.25506.2.260.1.1.1)
accessible-for-notify
OCTET STRING
Standard MIB values.
Interface name.
As per the MIB.
Notifications
This section contains the HH3C-ESMC-MIB notifications.
h3cEsmcPacketLoss
Basic information
OID
Event
Severity
Recovery notification
Default status
1.3.6.1.4.1.25506.2.260.1.0.1
ESMC packets loss alarm.
Error
Minor
1.3.6.1.4.1.25506.2.260.1.0.2 (h3cEsmcPacketLossResume)
ON
Notification triggers
This notification is generated when ESMC is enabled on an interface and no ESMC packets have been received for more than 5 seconds.
System impact
The system cannot perform SyncE clock frequency synchronization.
Status control
This notification cannot be turned off.
Objects
OID (object name)
Index nodes
Value range
1.3.6.1.4.1.25506.2.260.1.1.1 (hh3cEsmcPortName)
Interface name.
N/A
OCTET STRING
OCTET STRING
Recommended action
To resolve the issue:
1.     Execute the display esmc interface command to verify that the values for the following fields are as follows.
¡     Port status—Up.
¡     Duplex mode—Full.
¡     Mode—Synchronous.
¡     ESMC status—Enable.
a.     If the value of any of the fields is not as expected, verify that the configuration and physical link are normal.
¡     To modify the duplex mode, execute the duplex command in interface view.
¡     To configure the operating mode for an interface, execute the synchronous mode command in interface view.
¡     To enable ESMC, execute the esmc enable command.
b.     If the values for the fields are as expected, go to step 2.
2.     Execute the display esmc interface command to verify that the number of received ESMC packets (the value of the ESMC information packets received field) has increased. If the number of packets has increased, the ESMC is functioning correctly and no further processing is required.
3.     If the issue persists, contact H3C Support.
Basic information
OID
Event
Severity
Default status
Alarm for ESMC packets recovery.
Recovery
Minor
N/A
ON
This notification is generated when the number of ESMC packets is restored.
System impact
No negative impact on services.
Status control
Objects
OID (object name)
Index nodes
Value range
Interface name.
N/A
OCTET STRING
OCTET STRING
Recommended action
No action is required.
