18-Network Management and Monitoring
HomeSupportReference GuidesMIB CompanionH3C S6800 & S6860 MIB Companion-Release 6715-6W10018-Network Management and Monitoring
08-HH3C-NETCONF-MIB
08-HH3C-NETCONF-MIB 147.11 KB
HH3C-NETCONF-MIB
About this MIB
Use this MIB to notify SNMP NMSs of NETCONF session establishment and disconnection events.
MIB file name
hh3c-netconf.mib
Root object
iso(1).org(3).dod(6).internet(1).private(4).enterprises(1).hh3c(25506).hh3cCommon(2).hh3cNetconf(206)
Scalar objects
hh3cNetconfSessionId
Object (OID)
Access
Value range
Implementation
hh3cNetconfSessionId (1.3.6.1.4.1.25506.2.206.1.1.1)
accessible-for-notify
Integer32
Integer32 (1..2147483647)
NETCONF session ID.
Implementation varies by product.
hh3cNetconfSessionUserName
Object (OID)
Access
Value range
Implementation
hh3cNetconfSessionUserName (1.3.6.1.4.1.25506.2.206.1.1.2)
DisplayString
OCTET STRING (1..80)
NETCONF session username.
As per the MIB.
hh3cNetconfSessionPeerIPAddressType
Object (OID)
Access
Value range
Implementation
hh3cNetconfSessionPeerIPAddressType (1.3.6.1.4.1.25506.2.206.1.1.3)
InetAddress
Standard MIB values.
Type of the remote IP address that established the NETCONF session with the device.
As per the MIB.
Object (OID)
Access
Value range
Implementation
hh3cNetconfSessionPeerIPAddress (1.3.6.1.4.1.25506.2.206.1.1.4)
InetAddressType
Remote IP address that established the NETCONF session with the device.
As per the MIB.
hh3cNetconfSessionTerminationReason
Object (OID)
Access
Value range
Implementation
hh3cNetconfSessionTerminationReason (1.3.6.1.4.1.25506.2.206.1.1.5)
INTEGER
other(1),
closed(2),
linkDown(3),
idleTimeout(4)
Reason. for the session to be disconnected by the NETCONF client.
Options:
other(1)—Any other reason than those listed below.
closed(2)—Session was closed.
linkDown(3)—Link went down.
idleTimeout(4)—Session timed out.
hh3cNetconfSessionLoginTime
Object (OID)
Access
Value range
Implementation
hh3cNetconfSessionLoginTime (1.3.6.1.4.1.25506.2.206.1.1.6)
DateAndTime
Session start time.
As per the MIB.
hh3cNetconfSessionLogoutTime
Object (OID)
Access
Value range
Implementation
hh3cNetconfSessionLogoutTime (1.3.6.1.4.1.25506.2.206.1.1.7)
DateAndTime
Session end time.
As per the MIB.
hh3cNetconfSessionAccessType
Object (OID)
Access
Value range
Implementation
hh3cNetconfSessionAccessType (1.3.6.1.4.1.25506.2.206.1.1.8)
INTEGER
other(1),
web(2),
soap(3),
terminal (4)
User session type.
Options:
other(1),
web(2),
soap(3),
terminal (4)
hh3cNetconfSessionUserRole
Object (OID)
Access
Value range
Implementation
hh3cNetconfSessionUserRole (1.3.6.1.4.1.25506.2.206.1.1.9)
DisplayString
As per the MIB.
hh3cNetconfAbnormalReason
Object (OID)
Access
Value range
Implementation
hh3cNetconfAbnormalReason (1.3.6.1.4.1.25506.2.206.1.1.10)
DisplayString
Cause for the NETCONF request failure.
As per the MIB.
hh3cNetconfOperationResult
Object (OID)
Access
Value range
Implementation
hh3cNetconfOperationResult (1.3.6.1.4.1.25506.2.206.1.1.11)
DisplayString
NETCONF operation result.
As per the MIB.
Notifications
hh3cNetconfServerSessionStart
Basic information
OID
Event
Severity
Recovery notification
Default status
1.3.6.1.4.1.25506.2.206.2.0.1
NETCONF server established a session.
Informational
Warning
N/A
ON
Notification triggers
This notification is generated when the NETCONF server establishes a session with a NETCONF client.
System impact
No negative impact on the system.
Status control
No action is required.
Objects
OID (object name)
Index nodes
Value range
(hh3cNetconfSessionId)
NETCONF session ID.
N/A
Integer32
Integer32
(1..2147483647)
(hh3cNetconfSessionUserName)
N/A
DisplayString
(hh3cNetconfSessionPeerIPAddressType)
N/A
InetAddressType
(hh3cNetconfSessionPeerIPAddress)
N/A
InetAddress
Recommended action
hh3cNetconfServerSessionEnd
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.2.206.2.0.2
NETCONF server ended a session
Informational
Warning
N/A
ON
This notification might be generated when the following events occur:
·     The NETCONF server receives a session termination request.
·     A persistent session is disconnected because of a network error.
·     A temporary session is disconnected because the session timeout time expires.
System impact
NETCONF server terminates a session.
Status control
This notification cannot be disabled.
Objects
OID (object name)
Index nodes
Value range
NETCONF session ID.
N/A
Integer32
Integer32
(1..2147483647)
N/A
DisplayString
N/A
InetAddressType
N/A
InetAddress
(hh3cNetconfSessionTerminationReason)
Reasons for the session to be disconnected by the NETCONF client:
N/A
INTEGER
Options:
linkDown(3)—Session exception occurred.
Recommended action
·     If the session was closed normally, no action is required.
·     If the session was closed abnormally, check the physical link.
hh3cNetconfServerAuthFailure
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.2.206.2.0.3
Creating a NETCONF session failed.
Error
Warning
N/A
ON
This notification is generated when the username or password is incorrect.
System impact
NETCONF session creation fails.
Status control
Objects
OID (object name)
Index nodes
Value range
N/A
DisplayString
N/A
InetAddressType
N/A
InetAddress
(hh3cNetconfSessionLoginTime)
Session start time.
N/A
DateAndTime
(hh3cNetconfSessionAccessType)
User session type.
N/A
INTEGER
Options:
other(1),
web(2),
soap(3),
terminal (4)
Recommended action
Check the username and password.
hh3cNetconfCli
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.2.206.2.0.4
A CLI command was executed by using NETCONF.
Informational
Warning
N/A
ON
This notification is generated after a CLI command is executed by using NETCONF, which contains the operation result.
System impact
The NETCONF server deploys CLI configuration.
Status control
Objects
OID (object name)
Index nodes
Value range
NETCONF session ID.
N/A
Integer32
Integer32
(1..2147483647)
N/A
DisplayString
(hh3cNetconfOperationResult)
N/A
DisplayString
Recommended action
hh3cNetconfEditConfig
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.2.206.2.0.5
A row operation was deployed.
Informational
Warning
N/A
ON
This notification is generated for each row operation. The notification is available only for <action> and <set> operations. The content is same as the EDIT-CONFIG log.
System impact
The NETCONF server deploys a row operation.
Status control
Objects
OID (object name)
Index nodes
Value range
NETCONF session ID.
N/A
Integer32
Integer32
(1..2147483647)
N/A
DisplayString
N/A
DisplayString
Recommended action
hh3cNetconfEditConfigCli
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.2.206.2.0.6
A NETCONF operation was converted from the XML form to the CLI command form.
Informational
Warning
N/A
ON
This notification is generated when the device converts a NETCONF operation from the XML form to the CLI command form. This notification is available only for <action> and <edit-config> operations.
System impact
The operation deployed by the NETCONF server is converted from the XML form to the CLI form.
Status control
Objects
OID (object name)
Index nodes
Value range
NETCONF session ID.
N/A
Integer32
Integer32
(1..2147483647)
N/A
DisplayString
N/A
DisplayString
Recommended action
hh3cNetconfMsgDel
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.2.206.2.0.7
A NETCONF request message was dropped.
Informational
Warning
N/A
ON
This notification is generated when the system drops a NETCONF request message that was received from a NETCONF over SSH client or at the XML view. The reason is that the message size exceeds the upper limit.
System impact
The NETCONF request message is dropped.
Status control
Objects
OID (object name)
Index nodes
Value range
(hh3cNetconfAbnormalReason)
N/A
DisplayString
Recommended action
To resolve the issue:
1.     Reduce the size of the request message. For example, delete blank spaces, carriage returns, and tab characters.
2.     Contact H3C Support to segment the request message and then re-encapsulate the segments before sending them to the device.
hh3cNetconfThread
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.2.206.2.0.8
The number of NETCONF threads reached the upper limit.
Informational
Warning
N/A
ON
This notification is generated when the number of NETCONF threads reaches the upper limit.
System impact
The number of NETCONF threads has reached the upper limit. Please try again later.
Status control
Objects
OID (object name)
Index nodes
Value range
N/A
DisplayString
Recommended action
