- 18-Network Management and Monitoring
- 01-DISMAN-EVENT-MIB
- 02-DISMAN-PING-MIB
- 03-DISMAN-TRACEROUTE-MIB
- 04-HH3C-EMDI-MIB
- 05-HH3C-ESMC-MIB
- 06-HH3C-HTTP-MIB
- 07-HH3C-MIRRORGROUP-MIB
- 08-HH3C-NETCONF-MIB
- 09-HH3C-NQA-MIB
- 10-HH3C-NTP-MIB
- 11-HH3C-PTP-MIB
- 12-HH3C-RMON-EXT2-MIB
- 13-HH3C-SNMP-EXT-MIB
- 14-HH3C-TWAMP-MIB
- 15-RMON-MIB
- 16-RMON2-MIB
- 17-SFLOW-MIB
- 18-SNMP-FRAMEWORK-MIB
- 19-SNMP-MPD-MIB
- 20-SNMP-NOTIFICATION-MIB
- 21-SNMP-TARGET-MIB
- 22-SNMP-USER-BASED-SM-MIB
- 23-SNMP-VIEW-BASED-ACM-MIB
- 24-SNMPv2-MIB
14-HH3C-TWAMP-MIB | 159.36 KB |
HH3C-TWAMP-MIB
About this MIB
Use HH3C-TWAMP-MIB to implement NQA TWAMP Light as follows:
· Enable the TWAMP Light client and the TWAMP Light sender.
· Configure and obtain information about test sessions on the TWAMP Light client.
· Configure and obtain packet sending intervals, timeout time of the reflected packet, and statistics collection interval for TWAMP Light tests on the TWAMP Light sender.
· Obtain the TWAMP Light sender status.
· Obtain two-way delay and two-way jitter statistics for TWAMP Light tests on the TWAMP Light sender.
· Obtain two-way packet loss statistics for TWAMP Light tests on the TWAMP Light sender.
· Obtain the largest index value in TWAMP loss results and TWAMP delay results.
· Clear statistics about TWAMP Light tests.
· Enable the TWAMP Light responder.
· Configure and obtain information about test sessions on the TWAMP Light responder.
MIB file name
hh3c-twamp.mib
Root object
iso(1).org(3).dod(6).internet(1).private(4).enterprises(1).hh3c(25506).hh3cCommon(2).hh3cTwamp(184)
Scalar objects
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cTwamplightSenderEnable (1.3.6.1.4.1.25506.2.184.2.1.2) |
read-write |
TruthValue |
Standard MIB values. |
Enabling status of the TWAMP Light sender. |
As per the MIB. |
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cTwamplightRespondeEnable(1.3.6.1.4.1.25506.2.184.2.2.1) |
read- write |
TruthValue |
Enabling status of the TWAMP Light responder. |
As per the MIB. |
Tabular objects
Notifications
hh3cTwampTwoWayLossExceed
Basic information
OID |
Event |
Type |
Severity |
Recovery notification |
Default status |
1.3.6.1.4.1.25506.2.184.1.0.1 |
The two-way packet loss ratio exceeds the upper threshold. |
Error |
Warning |
1.3.6.1.4.1.25506.2.184.1.0.2( hh3cTwampTwoWayLossRecover) |
OFF |
Notification triggers
This notification is generated when the two-way packet loss ratio exceeds the upper threshold in the TWAMP test. Possible causes might include the following:
1. Cause 1: Network congestion due to abnormal traffic.
2. Cause 2: Unstable link state.
System impact
The packet loss rate is too high and might not meet the service requirements. Services are affected.
Status control
ON
CLI: Use the reaction item-number checked-element two-way-loss threshold-value upper-threshold lower-threshold action-type trap-only command.
OFF
CLI: Use the undo reaction item-number command.
Objects
OID (object) |
Index nodes |
Type |
Value range |
1.3.6.1.4.1.25506.2.184.2.1.3.1.1 (hh3cTwamplightControllerID) |
Session ID. |
hh3cTwamplightControllerID hh3cTwamplightReactItemIndex |
Integer32 |
Integer32(1..512) |
1.3.6.1.4.1.25506.2.184.2.1.11.1.1 (hh3cTwamplightReactItemIndex) |
Threshold alarm group ID. |
Unsigned32 |
Unsigned32(1..10) |
1.3.6.1.4.1.25506.2.184.2.1.11.1.7 (hh3cTwamplightReactValue) |
Threshold. |
Unsigned32 |
Unsigned32(1..1000000) |
1.3.6.1.4.1.25506.2.184.2.1.11.1.3 (hh3cTwamplightReactUpperLimit) |
Upper threshold. |
Unsigned32 |
Unsigned32(2..1000000) |
1.3.6.1.4.1.25506.2.184.2.1.11.1.4 (hh3cTwamplightReactLowerLimit) |
Lower threshold. |
Unsigned32 |
Unsigned32(1..999999) |
Recommended action
To resolve this issue:
3. Identify whether abnormal traffic exists in the network during the alarm time.
4. Identify whether the link state is stable in the network during the alarm time, and troubleshoot link instability issues.
5. If the issue persists, collect alarm information and configuration data, and then contact H3C Support for help.
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.2.184.1.0.2 |
The two-way packet loss ratio drops below the lower threshold. |
Recovery |
Warning |
N/A |
OFF |
This notification is generated when the two-way packet loss ratio drops below the lower threshold in the TWAMP test.
System impact
No negative impact on services.
Status control
ON
OFF
CLI: Use the reaction item-number checked-element two-way-loss threshold-value upper-threshold lower-threshold action-type trap-only none command.
Objects
OID (object) |
Index nodes |
Type |
Value range |
Session ID. |
Integer32 |
Integer32(1..512) |
Unsigned32 |
Unsigned32(1..10) |
Threshold. |
Unsigned32 |
Upper threshold. |
Unsigned32 |
Lower threshold. |
Unsigned32 |
Recommended action
No action is required.
hh3cTwampTwoWayDelayExceed
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.2.184.1.0.3 |
The two-way delay exceeds the upper threshold. |
Error |
Warning |
1.3.6.1.4.1.25506.2.184.1.0.4(hh3cTwampTwoWayDelayRecover) |
OFF |
This notification is generated when the two-way delay exceeds the upper threshold in the TWAMP test.
System impact
The delay is too high and might not meet the service requirements. Services are affected.
Status control
ON
CLI: Use the reaction item-number checked-element two-way-delay threshold-value upper-threshold lower-threshold action-type trap-only command.
OFF
Objects
OID (object) |
Index nodes |
Type |
Value range |
Session ID. |
Integer32 |
Integer32(1..512) |
Unsigned32 |
Unsigned32(1..10) |
Threshold. |
Unsigned32 |
Upper threshold. |
Unsigned32 |
Lower threshold. |
Unsigned32 |
Recommended action
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.2.184.1.0.4 |
The two-way delay drops below the lower threshold. |
Recovery |
Warning |
N/A |
OFF |
This notification is generated when the two-way delay drops below the lower threshold in the TWAMP test.
System impact
Status control
ON
OFF
Objects
OID (object) |
Index nodes |
Type |
Value range |
Session ID. |
Integer32 |
Integer32(1..512) |
Unsigned32 |
Unsigned32(1..10) |
Threshold. |
Unsigned32 |
Upper threshold. |
Unsigned32 |
Lower threshold. |
Unsigned32 |
Recommended action
hh3cTwampTwoWayJitterExceed
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.2.184.1.0.5 |
The two-way jitter exceeds the upper threshold. |
Error |
Warning |
1.3.6.1.4.1.25506.2.184.1.0.6(hh3cTwampTwoWayJitterRecover) |
OFF |
This notification is generated when the two-way jitter exceeds the upper threshold in the TWAMP test.
System impact
The jitter is too high and might not meet the service requirements. Services are affected.
Status control
ON
CLI: Use the reaction item-number checked-element two-way-jitter threshold-value upper-threshold lower-threshold action-type trap-only command.
OFF
Objects
OID (object) |
Index nodes |
Type |
Value range |
Session ID. |
Integer32 |
Integer32(1..512) |
Unsigned32 |
Unsigned32(1..10) |
Threshold. |
Unsigned32 |
Upper threshold. |
Unsigned32 |
Lower threshold. |
Unsigned32 |
Recommended action
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.2.184.1.0.6 |
The two-way jitter drops below the lower threshold. |
Recovery |
Warning |
N/A |
OFF |
This notification is generated when the two-way jitter drops below the lower threshold in the TWAMP test.
System impact
Status control
ON
OFF
Objects
OID (object) |
Index nodes |
Type |
Value range |
Session ID. |
Integer32 |
Integer32(1..512) |
Unsigned32 |
Unsigned32(1..10) |
Threshold. |
Unsigned32 |
Upper threshold. |
Unsigned32 |
Lower threshold. |
Unsigned32 |
Recommended action
hh3cTwampSenderSessionNumLimit
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.2.184.1.0.7 |
The number of TWAMP test sessions reaches the upper limit. |
Informational |
Major |
N/A |
OFF |
This notification is generated when the number of TWAMP test sessions reaches the upper limit.
System impact
The TWAMP test sessions that exceed the system capacity cannot operate correctly.
Status control
This notification cannot be disabled.
Objects
None.
Recommended action
1. Execute the display nqa twamp-light client verbose command to check for inactive sessions.
¡ If inactive sessions exist, delete the sessions.
¡ If no inactive sessions exist, as a best practice, arrange services appropriately.
2. If the issue persists, collect alarm information and configuration data, and then contact H3C Support for help.
hh3cTwampSenderStartFailure
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.2.184.1.0.9 |
The TWAMP test session failed to start. |
Informational |
Major |
N/A |
OFF |
This notification is generated when the TWAMP test session fails to start.
Possible reasons for generating this notification include:
· The timestamp format is set to NTP for probe packets in the TWAMP test, and the packet sending interval is set to 10 milliseconds or 100 milliseconds. Configuration conflict occurs.
· Hardware resource insufficiency.
System impact
The test session cannot operate correctly on the TWAMP sender.
Status control
Objects
OID (object name) |
Index nodes |
Type |
Value range |
Session ID. |
hh3cTwamplightControllerID |
Integer32 |
Integer32 (1..512) |
Recommended action
1. Use the display nqa twamp-light client verbose command to view detailed information about all test sessions. Use the start command to edit the packet sending interval. Alternatively, use the timestamp-format command to change the timestamp format. Then restart the test session.
¡ If the test session starts successfully, the issue is resolved.
¡ If the test session fails to start, proceed to step 2.
2. Collect alarm information and configuration data, and then contact H3C Support for help.
hh3cTwampRespStartFailure
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.2.184.1.0.10 |
The test session failed to start on the TWAMP responder. |
Informational |
Major |
N/A |
OFF |
This notification is generated when the TWAMP test session fails to start on the TWAMP responder.
System impact
Status control
Objects
OID (object name) |
Index nodes |
Type |
Value range |
1.3.6.1.4.1.25506.2.184.2.2.2.1.1 (hh3cTwamplightRespID) |
Session ID. |
hh3cTwamplightRespID |
Integer32 |
Recommended action
1. Use the display nqa twamp-light responder command to check the reflected packet settings.
2. Use the test-session command to configure the parameters required for the current network, and then restart the test session.
¡ If the test session fails to start, proceed to step 3.
3. Collect alarm information and configuration data, and then contact H3C Support for help.
hh3cTwampStatisticsAbnormal
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.2.184.1.0.11 |
A TWAMP test session statistics error occurred. |
Informational |
Warning |
N/A |
OFF |
This notification is generated when the TWAMP test session collects an exceptional number of probe frames.
· The statistics collection interval for the TWAMP test session is shorter than the packet sending interval.
System impact
The results of this probing will not be included in the statistics.
Status control
Objects
OID (object name) |
Index nodes |
Type |
Value range |
Session ID. |
Integer32 |
1.3.6.1.4.1.25506.2.184.2.1.7.1.1 (hh3cTwamplightTWLossSeq) |
Serial number. |
hh3cTwamplightControllerID hh3cTwamplightTWLossSeq |
Gauge32 |
Recommended action
