18-Network Management and Monitoring
HomeSupportReference GuidesMIB CompanionH3C S6800 & S6860 MIB Companion-Release 6715-6W10018-Network Management and Monitoring
04-HH3C-EMDI-MIB
04-HH3C-EMDI-MIB 159.19 KB
HH3C-EMDI-MIB
About this MIB
Use this MIB to implement the eMDI function.
MIB file name
hh3c-emdi.mib
Root object
iso(1).org(3).dod(6).internet(1).private(4).enterprises(1).hh3c(25506).hh3cCommon(2).hh3cEmdi(251)
Scalar objects
hh3cEmdiInstanceID
Object (OID)
Access
Value range
Implementation
hh3cEmdiInstanceID (1.3.6.1.4.1.25506.2.251.1.1.1)
accessible-for-notify
Unsigned32
Unsigned32 (1.. 65535)
Instance ID
Not supported
hh3cEmdiIndicatorType
Object (OID)
Access
Value range
Implementation
hh3cEmdiIndicatorType (1.3.6.1.4.1.25506.2.251.1.1.2)
INTEGER
rtplr(1), rtpser (2)
uplr(3),
dplr(4),
Monitored item type
Not supported
hh3cEmdiIndicatorValue
Object (OID)
Access
Value range
Implementation
hh3cEmdiIndicatorValue (1.3.6.1.4.1.25506.2.251.1.1.3)
Unsigned32
Standard MIB values.
Monitored item value
Not supported
hh3cEmdiIndicatorThreshold
Object (OID)
Access
Value range
Implementation
hh3cEmdiIndicatorThreshold (1.3.6.1.4.1.25506.2.251.1.1.4)
Unsigned32
Threshold set for the monitored item
Not supported
hh3cEmdiSuppressTimes
Object (OID)
Access
Value range
Implementation
hh3cEmdiSuppressTimes (1.3.6.1.4.1.25506.2.251.1.1.5)
Unsigned32
Number of consecutive alarms to be suppressed before logging the event for a monitored item
Not supported
hh3cEmdiFlowSrcIPType
Object (OID)
Access
Value range
Implementation
hh3cEmdiFlowSrcIPType (1.3.6.1.4.1.25506.2.251.1.1.6)
InetAddressType
Source IP address type of the target flow
Not supported
hh3cEmdiFlowSrcIP
Object (OID)
Access
Value range
Implementation
hh3cEmdiFlowSrcIP (1.3.6.1.4.1.25506.2.251.1.1.7)
InetAddress
Source IP address of the target flow
Not supported
hh3cEmdiFlowDstIPType
Object (OID)
Access
Value range
Implementation
hh3cEmdiFlowDstIPType (1.3.6.1.4.1.25506.2.251.1.1.8)
InetAddressType
Destination IP address type of the target flow
Not supported
hh3cEmdiFlowDstIP
Object (OID)
Access
Value range
Implementation
hh3cEmdiFlowDstIP (1.3.6.1.4.1.25506.2.251.1.1.9)
InetAddress
Destination IP address of the target flow
Not supported
hh3cEmdiFlowSrcPort
Object (OID)
Access
Value range
Implementation
hh3cEmdiFlowSrcPort (1.3.6.1.4.1.25506.2.251.1.1.10)
Integer32
Integer32 (1..65535)
Source port number of the target flow
Not supported
hh3cEmdiFlowDstPort
Object (OID)
Access
Value range
Implementation
hh3cEmdiFlowDstPort (1.3.6.1.4.1.25506.2.251.1.1.11)
Integer32
Destination port number of the target flow
Not supported
hh3cEmdiFlowProtocol
Object (OID)
Access
Value range
Implementation
hh3cEmdiFlowProtocol (1.3.6.1.4.1.25506.2.251.1.1.12)
INTEGER
tcp(1), udp(2)
Protocol type of the target flow
Not supported
hh3cEmdiFlowVlanID
Object (OID)
Access
Value range
Implementation
hh3cEmdiFlowVlanID (1.3.6.1.4.1.25506.2.251.1.1.13)
Integer32
Integer32 (1..4094)
VLAN ID of the target flow
Not supported
hh3cEmdiFlowVxlanID
Object (OID)
Access
Value range
Implementation
hh3cEmdiFlowVxlanID (1.3.6.1.4.1.25506.2.251.1.1.14)
Integer32
Integer32 (0..16777215)
VXLAN ID of the target flow
Not supported
hh3cEmdiChassisID
Object (OID)
Access
Value range
Implementation
hh3cEmdiChassisID (1.3.6.1.4.1.25506.2.251.1.1.15)
Integer32
Integer32 (0..65535)
Chassis number
The value of 65565 indicates a non-IRF scenario.
hh3cEmdiSlotID
Object (OID)
Access
Value range
Implementation
hh3cEmdiSlotID (1.3.6.1.4.1.25506.2.251.1.1.16)
Integer32
Slot number
Not supported
Notifications
hh3cEmdiIndicatorOverThres
Basic information
OID
Event
Severity
Recovery notification
Default status
1.3.6.1.4.1.25506.2.251.1.0.1
The value of the monitored item reaches the alarm threshold continuously for the specified times
Error
Warning
1.3.6.1.4.1.25506.2.251.1.0.2 (hh3cEmdiIndicatorOverThresResume)
OFF
Notification triggers
The notification is generated when the value of the monitored item reaches the alarm threshold continuously for the specified times.
Monitored item types include:
·     RTP-LR—RTP packet loss rate.
·     RTP-SER—RTP packet sequence error rate.
·     DPLR—Downstream TCP packet loss rate.
·     UPLR—Upstream TCP packet loss rate.
System impact
If this alarm appears, the value of the monitored item reaches the alarm threshold continuously for the specified times. The network transmission quality is poor.
Status control
ON
CLI: snmp-agent trap enable emdi
OFF
CLI: undo snmp-agent trap enable emdi
Objects
OID (object name)
Index nodes
Value range
1.3.6.1.4.1.25506.2.251.1.1.1 (hh3cEmdiInstanceID)
Instance ID
None
Unsigned32
1.3.6.1.4.1.25506.2.251.1.1.2 (hh3cEmdiIndicatorType)
Monitoring
None
INTEGER
rtp-lr(1),
rtp-ser (2)
uplr(3),
dplr(4),
1.3.6.1.4.1.25506.2.251.1.1.3 (hh3cEmdiIndicatorValue)
None
Unsigned32
1.3.6.1.4.1.25506.2.251.1.1.4 (hh3cEmdiIndicatorThreshold)
None
Unsigned32
1.3.6.1.4.1.25506.2.251.1.1.5 (hh3cEmdiSuppressTimes)
None
Unsigned32
Recommended action
1.     Locate the faulty device according to the eMDI statistics on the network.
2.     Replace the transceiver module or optical fiber of the corresponding physical interface of the faulty device. Identify whether the alarm is cleared.
3.     If the alarm is not cleared, collect alarm information and configuration data, and then contact H3C Support.
Basic information
OID
Event
Severity
Default status
The value of the monitored item drops below the alarm threshold continuously for the specified times, and the monitored item is recovered
Recovery
Warning
OFF
The notification is generated when the value of the monitored item drops below the alarm threshold continuously for the specified times, and the monitored item is recovered.
System impact
The service is not impacted.
Status control
ON
OFF
Objects
OID (object name)
Index nodes
Value range
Instance ID
None
Unsigned32
Monitored item type
None
INTEGER
rtp-lr(1),
rtp-ser (2)
uplr(3),
dplr(4),
None
Unsigned32
None
Unsigned32
None
Unsigned32
Recommended action
No action is required.
hh3cEmdiFlowConflict
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.2.251.1.0.3
Destination flow conflict alarm between eMDI instances
Informational
Warning
OFF
This notification is generated when the target flow bound to a dynamic eMDI instance conflicts with the target flow of an existing instance.
Possible reasons are:
1.     The target flow bound to a dynamic instance is the same as the target flow of an existing instance.
2.     The target flow bound to a dynamic instance is a subset of the target flow of an existing instance.
System impact
The target flow cannot be bound to a dynamic instance.
Status control
ON
OFF
Objects
OID (object name)
Index nodes
Value range
Instance ID of the conflicting target flow.
N/A
Unsigned32
1.3.6.1.4.1.25506.2.251.1.1.6 (hh3cEmdiFlowSrcIPType)
Source IP address type of the target flow.
N/A
InetAddressType
1.3.6.1.4.1.25506.2.251.1.1.7 (hh3cEmdiFlowSrcIP)
Source IP address of the target flow.
N/A
InetAddress
1.3.6.1.4.1.25506.2.251.1.1.8 (hh3cEmdiFlowDstIPType)
Destination IP address type of the target flow.
N/A
InetAddressType
1.3.6.1.4.1.25506.2.251.1.1.9 (hh3cEmdiFlowDstIP)
Destination IP address of the target flow.
N/A
InetAddress
1.3.6.1.4.1.25506.2.251.1.1.10 (hh3cEmdiFlowSrcPort)
Source port number of the target flow.
N/A
Integer32
1.3.6.1.4.1.25506.2.251.1.1.11 (hh3cEmdiFlowDstPort)
Destination port number of the target flow.
N/A
Integer32
1.3.6.1.4.1.25506.2.251.1.1.12 (hh3cEmdiFlowProtocol)
Protocol type of the target flow.
N/A
INTEGER
tcp(1), udp(2)
1.3.6.1.4.1.25506.2.251.1.1.13 (hh3cEmdiFlowVlanID)
VLAN ID of the target flow.
N/A
Integer32
Integer32 (1..4094)
1.3.6.1.4.1.25506.2.251.1.1.14 (hh3cEmdiFlowVxlanID)
VXLAN ID of the target flow.
N/A
Integer32
Recommended action
1.     Execute the display emdi instance verbose command to view eMDI instance information to identify whether conflicts exist between target flows.
¡     If conflicts exist, configure the target flows properly.
¡     If no conflicts exist, go to step 2.
2.     If the issue persists, collect alarm information and configuration data, and then contact H3C Support.
hh3cEmdiInstanceExceed
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.2.251.1.0.4
The number of eMDI instances exceeds the upper limit
Informational
Warning
OFF
This notification is generated when the number of eMDI instances exceeds the upper limit
System impact
You cannot create new instances after the number of instances exceeds the upper limit.
Status control
ON
OFF
Objects
OID (object name)
Index nodes
Value range
1.3.6.1.4.1.25506.2.251.1.1.15 (hh3cEmdiChassisID)
Chassis number.
N/A
Integer32
1.3.6.1.4.1.25506.2.251.1.1.16 (hh3cEmdiSlotID)
Slot number.
N/A
Integer32
Recommended action
1.     Execute the display emdi resource command to view eMDI instance resource information to identify whether the number of instances exceeds the upper limit.
¡     If the upper limit is exceeded, plan and configure the instances properly.
¡     If the upper limit is not exceeded, go to step 2.
