17-High Availability
HomeSupportReference GuidesMIB CompanionH3C S6800 & S6860 MIB Companion-Release 6715-6W10017-High Availability
06-HH3C-ETHOAM-MIB
06-HH3C-ETHOAM-MIB 68.68 KB
HH3C-ETHOAM-MIB
About this MIB
This MIB is a private MIB to implement Ethernet OAM functions.
MIB file name
hh3c-ethoam.mib
Root object
iso(1).org(3).dod(6).internet(1).private(4).enterprises(1).hh3c(25506).h3cCommon(2).hh3cEthoam(226)
Notifications
hh3cEthoamNonThresholdRecovery
Basic information
OID
Event
Severity
Recovery notification
Default status
1.3.6.1.4.1.25506.2.227.1.0.1
The alarm for a non-threshold-crossing event is cleared.
Recovery
Warning
N/A
ON
Notification triggers
This notification is generated when a non-threshold-crossing event is cleared on the local or remote end.
System impact
No negative impact on the system.
Status control
The notification cannot be disabled.
Objects
OID (object name)
Index nodes
Value range
1.3.6.1.2.1.2.2.1.1
(ifIndex)
Interface index
ifIndex
Integer32
Integer32 (1..2147483647)
1.3.6.1.2.1.2.2.1.2
(ifDescr)
Interface name
ifIndex
OCTET STRING
OCTET STRING (0..255)
1.3.6.1.2.1.158.1.6.1.2 (dot3OamEventLogTimestamp)
Timestamp of the event.
ifIndex
dot3OamEventLogIndex
TimeStamp
TimeTicks
1.3.6.1.2.1.158.1.6.1.3 (dot3OamEventLogOui)
OUI of the event packet.
ifIndex
EightOTwoOui
OCTET STRING (SIZE (1..255))
1.3.6.1.2.1.158.1.6.1.4 (dot3OamEventLogType)
Event type.
ifIndex
Unsigned32
linkFault(256)
dyingGaspEvent(257)
criticalLinkEvent(258)
1.3.6.1.2.1.158.1.6.1.5 (dot3OamEventLogLocation)
Whether the event is a local event or a peer event.
ifIndex
INTEGER
local(1)
remote(2)
1.3.6.1.2.1.158.1.6.1.12 (dot3OamEventLogTimestamp)
Total number of times the event has occurred.
ifIndex
Unsigned32
Standard MIB values.
Recommended action
No action is required.
hh3cEthoamLoopbackFailed
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.2.227.1.0.2
Loopback detection failed to be enabled on an interface.
Informational
Warning
N/A
ON
This notification is generated when loopback detection fails to be enabled on an interface.
System impact
Remote loopback cannot be enabled, affecting link diagnosis.
Status control
Objects
OID (object name)
Index nodes
Value range
1.3.6.1.2.1.2.2.1.1
(ifIndex)
Interface index
ifIndex
Integer32
1.3.6.1.2.1.2.2.1.2
(ifDescr)
Interface name
ifIndex
OCTET STRING
This table does not contain indexes. For information about the index or indexes of a MIB object instance in an SNMP variable binding, see the section for that MIB object.
Recommended action
To resolve the issue:
1.     Check whether the remote port rejects the Ethernet OAM remote loopback request from the local port.
Execute the display current-configuration command on the remote device to check whether the oam remote-loopback reject-request command has been configured.
¡     If that command has been configured, execute the undo oam remote-loopback reject-request command to accept the Ethernet OAM remote loopback request from the local port. Then go to step 2.
¡     If that command has not been configured, go to step 3.
2.     Check whether the issue has been resolved. If the issue persists, go to step 3.
3.     Execute the display oam remote command to display Ethernet OAM connection information for the remote port.
¡     If the value of the OAM mode field is Active, go to step 5.
¡     If the value of the OAM mode field is Active, go to step 4.
4.     Ensure that the physical link is normal. For more information, see physical connection troubleshooting methods.
5.     Collect log messages and configuration data, and then contact H3C Support for help.
