| 01-DOT3-OAM-MIB | 145.07 KB |
DOT3-OAM-MIB
About this MIB
Ethernet Operation, Administration, and Maintenance (OAM) is a tool that monitors Layer 2 link status. It checks the connectivity of a link by sending OAM protocol data units (OAMPDUs) and reports to the network administrators when a link error occurs.
This MIB focuses on Ethernet OAM functions.
MIB file name
rfc4878-dot3-oam.mib
Root object
iso(1).org(3).dod(6).internet(1).mgmt(2).mib-2(1).dot3OamMIB(25506)
Tabular objects
dot3OamTable
About this table
This table contains information about basic Ethernet OAM functions of a port.
Support for operations
Create |
Edit/Modify |
Delete |
Read |
Supported |
Supported |
Supported |
Supported |
Columns
The table index is ifIndex.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
dot3OamAdminState (1.3.6.1.2.1.158.1.1.1.1) |
read-write |
INTEGER |
1..2 |
Whether Ethernet OAM is enabled on the port. |
As per the MIB. |
dot3OamOperStatus (1.3.6.1.2.1.158.1.1.1.2) |
read-only |
INTEGER |
disabled(1),linkFault(2),passiveWait(3),activeSendLocal(4),sendLocalAndRemote(5),sendLocalAndRemoteOk(6),oamPeeringLocallyRejected(7),oamPeeringRemotelyRejected(8),operational(9),nonOperHalfDuplex(10) |
OAM capability of the link when the interface enters discovery state upon initialization or link error of the OAM entities. |
As per the MIB. |
dot3OamMode (1.3.6.1.2.1.158.1.1.1.3) |
read-write |
IINTEGER |
1...2 |
OAM mode. Ethernet interfaces have two OAM modes: passive(1) and active(2). |
As per the MIB. |
dot3OamMaxOamPduSize (1.3.6.1.2.1.158.1.1.1.4) |
read-only |
Unsigned32 |
64…1518 |
Largest OAMPDU that the OAM entity supports. |
As per the MIB. |
dot3OamConfigRevision (1.3.6.1.2.1.158.1.1.1.5) |
read-only |
Unsigned32 |
0…65535 |
Configuration revision of the local OAM entity. |
As per the MIB. |
dot3OamFunctionsSupported (1.3.6.1.2.1.158.1.1.1.6) |
read-only |
BITS |
unidirectionalSupport(0),loopbackSupport(1),eventSupport(2),variableSupport(3) |
Functions supported by the OAM port. |
As per the MIB. |
dot3OamPeerTable
About this table
This table contains OAM peer configuration information.
Create |
Edit/Modify |
Delete |
Read |
Supported |
Supported |
Supported |
Supported |
Columns
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
dot3OamPeerMacAddress (1.3.6.1.2.1.158.1.2.1.1) |
read-only |
MacAddress |
OCTET STRING (6) Originaltype + valid length. |
MAC address of the OAM peer. |
As per the MIB. |
dot3OamPeerVendorOui (1.3.6.1.2.1.158.1.2.1.2) |
read-only |
EightOTwoOui |
OCTET STRING(3) |
Peer OUI. |
Not supported |
dot3OamPeerVendorInfo (1.3.6.1.2.1.158.1.2.1.3) |
read-only |
Gauge32 |
Standard MIB values. |
Vendor information of the OAM peer. |
Not supported |
dot3OamPeerMode (1.3.6.1.2.1.158.1.2.1.4) |
read-only |
INTEGER |
passive(1), active(2),unknown(3) |
Mode of the OAM peer. |
As per the MIB. |
dot3OamPeerMaxOamPduSize (1.3.6.1.2.1.158.1.2.1.5) |
read-only |
Unsigned32 |
1:0,2:64…1518 |
Maximum OAMPDU length of the OAM peer. |
As per the MIB. |
dot3OamPeerConfigRevision (1.3.6.1.2.1.158.1.2.1.6) |
read-only |
Unsigned32 |
0..65535 |
Configuration revision of the OAM peer. |
As per the MIB. |
dot3OamPeerFunctionsSupported (1.3.6.1.2.1.158.1.2.1.7) |
read-only |
BITS |
unidirectionalSupport(0), loopbackSupport(1), eventSupport(2), variableSupport(3) |
Functions supported by the OAM peer. |
As per the MIB. |
dot3OamStatsTable
About this table
This table contains OAM statistics information.
Create |
Edit/Modify |
Delete |
Read |
Supported |
Supported |
Supported |
Supported |
Columns
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
dot3OamInformationTx (1.3.6.1.2.1.158.1.4.1.1) |
read-only |
Counter32 |
Number of sent Information OAMPDUs. |
As per the MIB. |
dot3OamInformationRx (1.3.6.1.2.1.158.1.4.1.2) |
read-only |
Counter32 |
Number of received Information OAMPDUs. |
As per the MIB. |
dot3OamUniqueEventNotificationTx (1.3.6.1.2.1.158.1.4.1.3) |
read-only |
Counter32 |
Number of sent unique Event Notification OAMPDUs. |
As per the MIB. |
dot3OamUniqueEventNotificationRx (1.3.6.1.2.1.158.1.4.1.4) |
read-only |
Counter32 |
Number of received unique Event Notification OAMPDUs. |
As per the MIB. |
dot3OamDuplicateEventNotificationTx (1.3.6.1.2.1.158.1.4.1.5) |
read-only |
Counter32 |
Number of sent duplicate Event Notification OAMPDUs. |
As per the MIB. |
dot3OamDuplicateEventNotificationRx (1.3.6.1.2.1.158.1.4.1.6) |
read-only |
Counter32 |
Number of received duplicate Event Notification OAMPDUs. |
As per the MIB. |
dot3OamLoopbackControlTx (1.3.6.1.2.1.158.1.4.1.7) |
read-only |
Counter32 |
Number of sent Loopback Control OAMPDUs. |
As per the MIB. |
dot3OamLoopbackControlRx (1.3.6.1.2.1.158.1.4.1.8) |
read-only |
Counter32 |
Number of received Loopback Control OAMPDUs. |
As per the MIB. |
dot3OamVariableRequestTx (1.3.6.1.2.1.158.1.4.1.9) |
read-only |
Counter32 |
Number of sent Variable Request OAMPDUs. |
Not supported |
dot3OamVariableRequestRx (1.3.6.1.2.1.158.1.4.1.10) |
read-only |
Counter32 |
Number of received Variable Request OAMPDUs. |
Not supported |
dot3OamVariableResponseTx (1.3.6.1.2.1.158.1.4.1.11) |
read-only |
Counter32 |
Number of sent Variable Response OAMPDUs. |
Not supported |
dot3OamVariableResponseRx (1.3.6.1.2.1.158.1.4.1.12) |
read-only |
Counter32 |
Number of received Variable Response OAMPDUs. |
Not supported |
dot3OamOrgSpecificTx (1.3.6.1.2.1.158.1.4.1.13) |
read-only |
Counter32 |
Number of sent Organization Specific OAMPDUs. |
Not supported |
dot3OamOrgSpecificRx (1.3.6.1.2.1.158.1.4.1.14) |
read-only |
Counter32 |
Number of received Organization Specific OAMPDUs. |
Not supported |
dot3OamUnsupportedCodesTx (1.3.6.1.2.1.158.1.4.1.15) |
read-only |
Counter32 |
Number of sent OAMPDUs that do not support operation codes. |
Not supported |
dot3OamUnsupportedCodesRx (1.3.6.1.2.1.158.1.4.1.16) |
read-only |
Counter32 |
Number of received OAMPDUs that do not support operation codes. |
Not supported |
dot3OamFramesLostDueToOam (1.3.6.1.2.1.158.1.4.1.17) |
read-only |
Counter32 |
Number of dropped frames due to OAM. |
Not supported |
dot3OamEventConfigTable
About this table
This table contains OAM link event detection information.
Create |
Edit/Modify |
Delete |
Read |
Supported |
Supported |
Supported |
Supported |
Columns
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
dot3OamErrSymPeriodWindowHi (1.3.6.1.2.1.158.1.5.1.1) |
read-write |
Unsigned32 |
High 32 bits of the errored symbol event detection window. |
Not supported |
dot3OamErrSymPeriodWindowLo (1.3.6.1.2.1.158.1.5.1.2) |
read-write |
Unsigned32 |
Low 32 bits of the errored symbol event detection window. |
Not supported |
dot3OamErrSymPeriodThresholdHi (1.3.6.1.2.1.158.1.5.1.3) |
read-write |
Unsigned32 |
High 32 bits of the errored symbol event triggering threshold within the detection window. |
Not supported |
dot3OamErrSymPeriodThresholdLo (1.3.6.1.2.1.158.1.5.1.4) |
read-write |
Unsigned32 |
Low 32 bits of the errored symbol event triggering threshold within the detection window. |
Not supported |
dot3OamErrSymPeriodEvNotifEnable (1.3.6.1.2.1.158.1.5.1.5) |
read-write |
TruthValue |
true(1), false(2) |
Whether errored symbol event notification is enabled. |
As per the MIB. |
dot3OamErrFramePeriodWindow (1.3.6.1.2.1.158.1.5.1.6) |
read-write |
Unsigned32 |
100..60000(V5) 1-65535(V7) |
Errored frame period event detection window. |
Value range: 1 to 65535. Default: 1000. |
dot3OamErrFramePeriodThreshold (1.3.6.1.2.1.158.1.5.1.7) |
read-write |
Unsigned32 |
0.. 4294967295 |
Errored frame period event triggering threshold. |
As per the MIB. |
dot3OamErrFramePeriodEvNotifEnable (1.3.6.1.2.1.158.1.5.1.8) |
read-write |
TruthValue |
true(1), false(2) |
Whether errored frame period event notification is enabled. |
As per the MIB. |
dot3OamErrFrameWindow (1.3.6.1.2.1.158.1.5.1.9) |
read-write |
Unsigned32 |
10..600 |
Errored frame event detection window. |
Value range: 10 -600. Default: 10. |
dot3OamErrFrameThreshold (1.3.6.1.2.1.158.1.5.1.10) |
read-write |
Unsigned32 |
0.. 4294967295 |
Errored frame event triggering threshold. |
As per the MIB. |
dot3OamErrFrameEvNotifEnable (1.3.6.1.2.1.158.1.5.1.11) |
read-write |
TruthValue |
true(1), false(2) |
Whether errored frame event notification is enabled. |
As per the MIB. |
dot3OamErrFrameSecsSummaryWindow (1.3.6.1.2.1.158.1.5.1.12) |
read-write |
Integer32 |
100..9000 |
Errored frame seconds event detection window. |
Value range: 100 to 9000 Default: 600. |
dot3OamErrFrameSecsSummaryThreshold (1.3.6.1.2.1.158.1.5.1.13) |
read-write |
Integer32 |
1..900 |
Errored frame seconds event triggering threshold. |
As per the MIB. |
dot3OamErrFrameSecsEvNotifEnable (1.3.6.1.2.1.158.1.5.1.14) |
read-write |
TruthValue |
true(1), false(2) |
Whether errored frame seconds event notification is enabled. |
As per the MIB. |
dot3OamDyingGaspEnable (1.3.6.1.2.1.158.1.5.1.15) |
read-write |
TruthValue |
true(1), false(2) |
Whether Dying Gasp notification is enabled. |
Not supported |
dot3OamCriticalEventEnable (1.3.6.1.2.1.158.1.5.1.16) |
read-write |
TruthValue |
true(1), false(2) |
Whether critical event notification is enabled. |
Not supported |
dot3OamEventLogTable
About this table
This table contains OAM event log information.
Create |
Edit/Modify |
Delete |
Read |
Supported |
Supported |
Supported |
Supported |
Columns
The table indexes are ifIndex and dot3OamEventLogIndex.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
dot3OamEventLogIndex (1.3.6.1.2.1.158.1.6.1.1) |
not-accessible |
Unsigned32 |
1..100 |
Event index. |
As per the MIB. |
dot3OamEventLogTimestamp (1.3.6.1.2.1.158.1.6.1.2) |
read-only |
TimeStamp |
Timestamp of the event. |
As per the MIB. |
dot3OamEventLogOui (1.3.6.1.2.1.158.1.6.1.3) |
read-only |
EightOTwoOui |
OCTET STRING(3) |
OUI of the event packet. |
As per the MIB. |
dot3OamEventLogType (1.3.6.1.2.1.158.1.6.1.4) |
read-only |
Unsigned32 |
erroredSymbolEvent(1),erroredFramePeriodEvent(2),erroredFrameEvent(3),erroredFrameSecondsEvent(4),linkFault(256),dyingGaspEvent(257),criticalLinkEvent(258) |
Event type. |
As per the MIB. |
dot3OamEventLogLocation (1.3.6.1.2.1.158.1.6.1.5) |
read-only |
INTEGER |
local(1), remote(2) |
Whether the event is a local event or a peer event. |
As per the MIB. |
dot3OamEventLogWindowHi (1.3.6.1.2.1.158.1.6.1.6) |
read-only |
Unsigned32 |
High bits of the event statistics window. |
As per the MIB. |
dot3OamEventLogWindowLo (1.3.6.1.2.1.158.1.6.1.7) |
read-only |
Unsigned32 |
Low bits of the event statistics window. |
As per the MIB. |
dot3OamEventLogThresholdHi (1.3.6.1.2.1.158.1.6.1.8) |
read-only |
Unsigned32 |
High bits of the event statistics threshold. |
As per the MIB. |
dot3OamEventLogThresholdLo (1.3.6.1.2.1.158.1.6.1.9) |
read-only |
Unsigned32 |
Low bits of the event statistics threshold. |
As per the MIB. |
dot3OamEventLogValue (1.3.6.1.2.1.158.1.6.1.10) |
read-only |
CounterBasedGauge64 |
Number of occurrences for the event exceeding the threshold within the window. |
As per the MIB. |
dot3OamEventLogRunningTotal (1.3.6.1.2.1.158.1.6.1.11) |
read-only |
Total number of occurrences for the running event. |
As per the MIB. |
dot3OamEventLogEventTotal (1.3.6.1.2.1.158.1.6.1.12) |
read-only |
Unsigned32 |
Total number of times the event has occurred. |
As per the MIB. |
Notifications
dot3OamThresholdEvent
Basic information
OID |
Event |
Type |
Severity |
Recovery notification |
Default status |
1.3.6.1.2.1.158.0.1 |
A threshold-crossing event is detected. |
Informational |
Warning |
N/A |
OFF |
Notification triggers
This notification is generated when one of the following threshold-exceeded events occurs on the local or remote end:
· Errored symbol event.
· Error frame event.
· Error frame period event.
· Error frame seconds event.
System impact
The link is faulty and service traffic is interrupted.
Status control
ON
MIB: Set dot3OamErrSymEvNotifEnable to true(1).
MIB: Set dot3OamErrFramePeriodEvNotifEnable to true(1).
MIB: Set dot3OamErrFrameEvNotifEnable to true(1).
MIB: Set dot3OamErrFrameSecsEvNotifEnable to true(1).
OFF
MIB: Set dot3OamErrSymEvNotifEnable to false(0)
MIB: Set dot3OamErrFramePeriodEvNotifEnable to false(0).
MIB: Set dot3OamErrFrameEvNotifEnable to false(0).
MIB: Set dot3OamErrFrameSecsEvNotifEnable to false(0).
Objects
OID (object name) |
Index nodes |
Type |
Value range |
1.3.6.1.2.1.158.1.6.1.2 (dot3OamEventLogTimestamp) |
ifIndex dot3OamEventLogIndex |
TimeStamp |
TimeTicks |
1.3.6.1.2.1.158.1.6.1.3 (dot3OamEventLogOui) |
EightOTwoOui |
OCTET STRING (SIZE (1..255)) |
1.3.6.1.2.1.158.1.6.1.4 (dot3OamEventLogType) |
Event type. |
Unsigned32 |
1.3.6.1.2.1.158.1.6.1.5 (dot3OamEventLogLocation) |
INTEGER |
local(1) remote(2) |
1.3.6.1.2.1.158.1.6.1.6 (dot3OamEventLogWindowHi) |
Unsigned32 |
0..65535 |
1.3.6.1.2.1.158.1.6.1.7 (dot3OamEventLogWindowLo) |
Unsigned32 |
0..65535 |
1.3.6.1.2.1.158.1.6.1.8 (dot3OamEventLogThresholdHi) |
Unsigned32 |
1.3.6.1.2.1.158.1.6.1.9 (dot3OamEventLogThresholdLo) |
Unsigned32 |
1.3.6.1.2.1.158.1.6.1.10 (dot3OamEventLogValue) |
Counter64 |
1.3.6.1.2.1.158.1.6.1.11 (dot3OamEventLogRunningTotal) |
Counter64 |
1.3.6.1.2.1.158.1.6.1.12 (dot3OamEventLogEventTotal) |
Unsigned32 |
Recommended action
Check the link.
dot3OamNonThresholdEvent
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.2.1.158.0.2 |
A non-threshold-crossing event is detected. |
Failure |
Warning |
1.3.6.1.4.1.25506.2.226.1.0.1 (hh3cEthoamNonThresholdRecovery) |
ON |
This notification is generated when one of the following non-threshold-crossing events is detected on the local or remote end.
· Link Fault event.
· Dying Gasp event.
· Critical Event.
System impact
Status control
The notification cannot be disabled.
Objects
OID (object name) |
Index nodes |
Type |
Value range |
TimeStamp |
TimeTicks |
EightOTwoOui |
Event type. |
Unsigned32 |
linkFault(256) dyingGaspEvent(257) criticalLinkEvent(258) |
INTEGER |
Unsigned32 |
This table does not contain indexes. For information about the index or indexes of a MIB object instance in an SNMP variable binding, see the section for that MIB object.
Recommended action
To resolve the issue, check the value of the EventLogType field in the notification.
· If the value is 256, a Link Fault event has occurred on the local or remoted end. Check whether the interface is shut down.
¡ If the interface is shut down, execute the undo shutdown command to resolve the issue.
¡ If the interface is not shut down, check the physical link.
· If the value is 257, a Dying Gasp event has occurred on the local or remoted end. Check whether the device is rebooting.
¡ If the device is rebooting, wait for the device to start and then check whether the issue has been resolved.
¡ If the device is not rebooting, collect related information and then contact H3C Support.
· If the value is 258, a Critical Event has occurred on the remote end. Check the peer device.
