17-High Availability
HomeSupportReference GuidesMIB CompanionH3C S6800 & S6860 MIB Companion-Release 6715-6W10017-High Availability
04-HH3C-DLDP2-MIB
04-HH3C-DLDP2-MIB 121.89 KB
HH3C-DLDP2-MIB
About this MIB
HH3C-DLDP2-MIB is a private MIB used to implement network management on the DLDP feature. Use this MIB to enable DLDP globally or on a port, and obtain port running state information, link state information, and DLDP neighbor information.
MIB file name
hh3c-dldp2.mib
Root object
iso(1).org(3).dod(6).internet(1).private(4).enterprises(1).hh3c(25506).h3cCommon(2).hh3cDldp2(117)
Scalar objects
hh3cDldp2GlobalEnable
Object (OID)
Access
Value range
Implementation
(1.3.6.1.4.1.25506.2.117.1.1)
read-write
TruthValue
true(1),
false(2)
Whether DLDP is enabled globally.
As per the MIB.
hh3cDldp2Interval
Object (OID)
Access
Value range
Implementation
hh3cDldp2Interval
(1.3.6.1.4.1.25506.2.117.1.2)
read-write
Integer32
Integer32(1..100)
Advertisement packet sending interval.
As per the MIB.
hh3cDldp2AuthMode
Object (OID)
Access
Value range
Implementation
hh3cDldp2AuthMode
(1.3.6.1.4.1.25506.2.117.1.3)
read-write
INTEGER
unknown(1),
none(2),
simple(3),
md5(4)
Authentication mode.
As per the MIB.
hh3cDldp2AuthPassword
Object (OID)
Access
Value range
Implementation
(1.3.6.1.4.1.25506.2.117.1.4)
read-write
OCTET STRING
OCTET STRING (0..16)
Authentication password.
As per the MIB.
hh3cDldp2UniShutdown
Object (OID)
Access
Value range
Implementation
(1.3.6.1.4.1.25506.2.117.1.5)
read-write
INTEGER
unknown(1),             auto(2),                    manual(3)
Port shutdown mode on detecting a unidirectional link.
As per the MIB.
Tabular objects
hh3cDldp2PortConfigTable
About this table
Use this table to enable DLDP on a port and obtain DLDP port configuration information.
Support for operations
Create
Edit/Modify
Delete
Read
Not supported
Supported
Not supported
Supported
Columns
The table index is ifIndex.
Object (OID)
Access
Value range
Implementation
hh3cDldp2PortEnable
(1.3.6.1.4.1.25506.2.117.2.1.1.1)
read-write
TruthValue
true(1),
false(2)
Whether DLDP is enabled on the port.
As per the MIB.
hh3cDldp2PortStatusTable
About this table
Use this table to obtain DLDP port state and link state information.
Create
Edit/Modify
Delete
Read
Not supported
Not supported
Not supported
Supported
Columns
Object (OID)
Access
Value range
Implementation
hh3cDldp2PortOperStatus
(1.3.6.1.4.1.25506.2.117.2.2.1.1)
read-only
INTEGER
unknown(1),                   initial(2),             inactive(3),               unidirectional(4),                  bidirectional(5)
Port state.
As per the MIB.
hh3cDldp2PortLinkStatus
(1.3.6.1.4.1.25506.2.117.2.2.1.2)
read-only
INTEGER
unknown(1),
down(2),
up(3)
Link state.
As per the MIB.
hh3cDldp2NeighborTable
About this table
Use this table to obtain neighbor information about a port.
Create
Edit/Modify
Delete
Read
Not supported
Not supported
Not supported
Supported
Columns
The table indexes are ifIndex, hh3cDldp2NeighborBridgeMac, and hh3cDldp2NeighborPortIndex.
Object (OID)
Access
Value range
Implementation
hh3cDldp2NeighborBridgeMac (1.3.6.1.4.1.25506.2.117.2.3.1.1)
not-accessible
MacAddress
OCTET STRING (6)
Bridge MAC address of the neighbor.
As per the MIB.
hh3cDldp2NeighborPortIndex(1.3.6.1.4.1.25506.2.117.2.3.1.2)
not-accessible
Integer32
Integer32(1..2147483647)
Port index of the neighbor.
As per the MIB.
hh3cDldp2NeighborStatus (1.3.6.1.4.1.25506.2.117.2.3.1.3)
read-only
INTEGER
unknown(1),            unconfirmed(2),                  confirmed(3)
State of the neighbor.
As per the MIB.
hh3cDldp2NeighborAgingTime (1.3.6.1.4.1.25506.2.117.2.3.1.4)
read-only
Integer32
Standard MIB values.
Aging time of the neighbor.
As per the MIB.
Notifications
This section contains trap notifications.
hh3cDldp2TrapUniLink
Basic information
OID
Event
Severity
Recovery notification
Default status
1.3.6.1.4.1.25506.2.117.4.0.1
This notification is generated when DLDP detects unidirectional links.
Failure
Warning
1.3.6.1.4.1.25506.2.117.4.0.2 (hh3cDldp2TrapBidLink)
ON
Notification triggers
The notification is generated when DLDP detects a unidirectional link.
System impact
Service traffic cannot be forwarded in one direction.
Status control
The notification cannot be disabled.
Objects
OID (object name)
Index nodes
Value range
1.3.6.1.2.1.2.2.1.1 (ifIndex)
Unidirectional interface index.
ifIndex
InterfaceIndex
1..2147483647
1.3.6.1.2.1.2.2.1.2 (ifDescr)
Unidirectional interface description.
ifIndex
DisplayString
OCTET STRING (SIZE (0..255))
Recommended action
To resolve the issue:
1.     Shut down the port, and recover the unidirectional link.
2.     If the issue persists, collect alarm information and configuration data, and then contact H3C Support.
Basic information
OID
Event
Severity
Default status
This notification is generated when DLDP detects bidirectional links.
Recovery
Warning
ON
The notification is generated when DLDP detects a bidirectional link.
System impact
Service traffic can be forwarded in two directions, and the system is not impacted.
Status control
Objects
OID (object name)
Index
Value range
Bidirectional interface index.
ifIndex
InterfaceIndex
1..2147483647
Bidirectional interface description.
ifIndex
DisplayString
Recommended action
No action is required.
