17-High Availability
HomeSupportReference GuidesMIB CompanionH3C S6800 & S6860 MIB Companion-Release 6715-6W10017-High Availability
05-HH3C-ERPS-MIB
05-HH3C-ERPS-MIB 105.30 KB
HH3C-ERPS-MIB
About this MIB
HH3C-ERPS-MIB is a private MIB used to implement network management for ERPS. Use this MIB to bind a ring port to an ERPS ring or obtain port state information.
MIB file name
hh3c-erps.mib
Root object
iso(1).org(3).dod(6).internet(1).private(4).enterprises(1).hh3c(25506).h3cCommon(2).hh3cErps(225)
Scalar objects
hh3cErpsRingID
Object (OID)
Access
Value range
Implementation
hh3cErpsRingID
(1.3.6.1.4.1.25506.2.225.1.1.1)
accessible-for-notify
Integer32
Integer32 (1..255)
ERPS ring ID.
As per the MIB.
hh3cErpsInstanceID
Object (OID)
Access
Value range
Implementation
hh3cErpsInstanceID
(1.3.6.1.4.1.25506.2.225.1.1.2)
Integer32
Integer32 (1..64)
ERPS instance ID.
As per the MIB.
hh3cErpsState
Object (OID)
Access
Value range
Implementation
hh3cErpsState
(1.3.6.1.4.1.25506.2.225.1.1.3)
INTEGER
undefined(1),
init(2),
idle(3),
protection(4),
ms(5),
fs(6),
pending(7)
ERPS ring state.
As per the MIB.
Notifications
hh3cErpsPortStateForwarding
Basic information
OID
Event
Severity
Recovery notification
Default status
1.3.6.1.4.1.25506.2.225.1.0.1
The ERPS ring port transitions to forwarding state.
Informational
Warning
N/A
ON
Notification triggers
This notification is generated when the ERPS ring port state becomes forwarding.
System impact
The network topology has changed and service traffic might be lost.
Status control
The notification cannot be disabled.
Objects
OID (object name)
Index nodes
Value range
1.3.6.1.4.1.25506.2.225.1.1.1 (hh3cErpsRingID)
ID of the ERPS ring.
N/A
Integer32
Integer32 (1..255)
1.3.6.1.2.1.2.2.1.1 (ifIndex)
Index of the interface
ifIndex
Integer32
Integer32 (1..2147483647)
1.3.6.1.2.1.2.2.1.2 (ifDescr)
Name of the interface.
ifIndex
OCTET STRING
OCTET STRING (0..255)
Recommended action
To resolve this issue:
1.     Examine whether a new physical link is added to the ERPS network topology.
¡     If a new physical link is added, examine whether the link is necessary.
-     If yes, no action is required.
-     If no, collect information and contact H3C Support for help.
¡     If no new physical link is added, examine whether a port in the ERPS network changes to up or down state.
2.     If the issue persists, collect alarm information and configuration data, and then contact H3C Support for help.
hh3cErpsPortStateDiscarding
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.2.225.1.0.2
The ERPS ring port transitions to blocked state.
Informational
Warning
N/A
ON
This notification is generated when the ERPS ring port state becomes blocked.
System impact
Status control
Objects
OID (object name)
Index nodes
Value range
N/A
Integer32
Integer32 (1..255)
ifIndex
Integer32
ifIndex
OCTET STRING
Recommended action
hh3cErpsRingStateChange
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.2.225.1.0.3
ERPS ring state changes.
Informational
Warning
N/A
ON
This notification is generated when the ERPS ring state changes.
System impact
Status control
Objects
OID (object name)
Index nodes
Value range
ERPS ring ID.
N/A
Integer32
Integer32 (1..255)
1.3.6.1.4.1.25506.2.225.1.1.2 (hh3cErpsInstanceID)
ERPS instance ID.
N/A
Integer32
Integer32 (1.. 64)
1.3.6.1.4.1.25506.2.225.1.1.3 (hh3cErpsState)
ERPS ring state.
N/A
INTEGER
undefined(1),
init(2),
idle(3),
protection(4),
ms(5),
fs(6),
pending(7)
Recommended action
