17-High Availability
HomeSupportReference GuidesMIB CompanionH3C S6800 & S6860 MIB Companion-Release 6715-6W10017-High Availability
03-HH3C-CFD-MIB
03-HH3C-CFD-MIB 255.38 KB
HH3C-CFD-MIB
About this MIB
This MIB describes extended CFD table entries.
MIB file name
hh3c-cfd.mib
Root object
iso(1).org(3).dod(6).internet(1).private(4).enterprises(1).hh3c(25506).hh3cCommon(2).hh3cCfd(207)
Scalar objects
hh3cCfdMepId
Object (OID)
Access
Value range
Implementation
hh3cCfdMepId
(1.3.6.1.4.1.25506.2.207.1.1.1)
accessible-for-notify
Integer32
Integer(1..8191)
MEP ID.
Supported
hh3cCfdSrvId
Object (OID)
Access
Value range
Implementation
hh3cCfdSrvId
(1.3.6.1.4.1.25506.2.207.1.1.2 )
Integer32
Integer(0..32767)
Service instance ID.
Supported
hh3cCfdTimeThreshold
Object (OID)
Access
Value range
Implementation
hh3cCfdTimeThreshold (1.3.6.1.4.1.25506.2.207.1.1.3)
Integer32
Standard MIB values.
Configured threshold.
Supported
hh3cCfdFrameEnd
Object (OID)
Access
Value range
Implementation
hh3cCfdFrameEnd (1.3.6.1.4.1.25506.2.207.1.1.4)
Integer32
 nearEnd(1)
 farEnd(2)
Detection frame direction.
Supported
hh3cCfdStatisticThreshold
Object (OID)
Access
Value range
Implementation
hh3cCfdStatisticThreshold (1.3.6.1.4.1.25506.2.207.1.1.5)
OCTET STRING
STRING(SIZE(0..8))
Configured frame loss threshold.
Supported
hh3cCfdMdIndex
Object (OID)
Access
Value range
Implementation
hh3cCfdMdIndex (1.3.6.1.4.1.25506.2.207.1.1.6)
Unsigned32
Unsigned32  (1..4294967295)
MD index.
Supported
hh3cCfdMdName
Object (OID)
Access
Value range
Implementation
hh3cCfdMdName (1.3.6.1.4.1.25506.2.207.1.1.7)
OCTET STRING
OCTET STRING(1..43)
MD name.
Supported
hh3cCfdMaIndex
Object (OID)
Access
Value range
Implementation
hh3cCfdMaIndex (1.3.6.1.4.1.25506.2.207.1.1.8)
Unsigned32
MA index.
Supported
hh3cCfdMaName
Object (OID)
Access
Value range
Implementation
hh3cCfdMaName (1.3.6.1.4.1.25506.2.207.1.1.9)
OCTET STRING
OCTET STRING(1..45)
MA name.
Supported
hh3cCfdRMepId
Object (OID)
Access
Value range
Implementation
hh3cCfdRMepId (1.3.6.1.4.1.25506.2.207.1.1.10)
Unsigned32
Unsigned32  (1..8191)
MEP ID.
Supported
Notifications
hh3cCfdTwowayDelay
Basic information
OID
Event
Severity
Recovery notification
Default status
1.3.6.1.4.1.25506.2.207.1.0.1
The two-way delay exceeds the upper limit.
Error
Warning
1.3.6.1.4.1.25506.2.207.1.0.2 (hh3cCfdTwowayDelayRecovery)
ON
Notification triggers
This notification is generated when the two-way delay reaches or exceeds the configured upper limit for three consecutive times.
System impact
The link delay is high.
Status control
This notification cannot be disabled.
Objects
OID (object name)
Index nodes
Value range
(hh3cCfdMepId)
MEP ID.
N/A
Integer32
Integer(1..8191)
(hh3cCfdSrvId)
N/A
Integer32
Integer(0..32767)
(hh3cCfdTimeThreshold)
N/A
Integer32
Recommended action
Check whether excessive service traffic exists in the network.
Basic information
OID
Event
Severity
Default status
The two-way delay threshold alarm is recovered.
Recovery
Warning
N/A
ON
This notification is generated when the two-way delay drops below the specified upper limit.
System impact
No negative impact on services.
Status control
Objects
OID (object name)
Index nodes
Value range
(hh3cCfdMepId)
MEP ID.
N/A
Integer32
Integer(1..8191)
(hh3cCfdSrvId)
N/A
Integer32
Integer(0..32767)
N/A
Integer32
Recommended action
No action is required.
hh3cCfdSlmStatistic
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.2.207.1.0.3
The one-way packet loss ratio exceeds the upper limit.
Error
Warning
1.3.6.1.4.1.25506.2.207.1.0.20 (hh3cCfdSlmStatisticClear)
ON
This notification is generated when the two-way frame loss ratio on the source or target MEP reaches or exceeds the configured upper limit for three consecutive times.
System impact
Link congestion or packet loss occurs.
Status control
Objects
OID (object name)
Index nodes
Value range
(hh3cCfdFrameEnd)
N/A
Integer32
 nearEnd(1)
 farEnd(2)
(hh3cCfdMepId)
MEP ID.
N/A
Integer32
Integer(1..8191)
(hh3cCfdSrvId)
N/A
Integer32
Integer(0..32767)
(hh3cCfdStatisticThreshold)
N/A
OCTET STRING
STRING(SIZE(0..8))
Recommended action
Check whether overloaded traffic exists in the network and whether a line issue exists.
hh3cCfdUnexpectedMDLevel
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.2.207.1.0.4
The MD levels are incorrect on the two ends.
Error
Warning
1.3.6.1.4.1.25506.2.207.1.0.13 (hh3cCfdUnexpectedMDLevelClear)
ON
This notification is generated when the MD level in the received CCMs on the MEP is inconsistent with the configured level.
System impact
Continuity check cannot be performed.
Status control
Objects
OID (object name)
Index nodes
Value range
(hh3cCfdMdIndex)
MD index.
N/A
Unsigned32
(hh3cCfdMdName)
MD name.
N/A
OCTET STRING
OCTET STRING (SIZE(1..43))
(hh3cCfdMaIndex)
MA index.
N/A
Unsigned32
(hh3cCfdMaName)
MA name.
N/A
OCTET STRING
OCTET STRING (SIZE(1..45))
(hh3cCfdMepId)
MEP ID.
N/A
Integer32
Integer(1..8191)
Recommended action
Check CFD configuration on both ends to make sure the MD levels are consistent.
hh3cCfdMismerge
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.2.207.1.0.5
The MD or MA names are inconsistent on the two ends.
Error
Warning
1.3.6.1.4.1.25506.2.207.1.0.14 (hh3cCfdMismergeClear)
ON
This notification is generated when the MD or MA names are inconsistent on the two ends that have consistent MD levels configured.
System impact
Status control
Objects
OID (object name)
Index nodes
Value range
(hh3cCfdMdIndex)
MD index.
N/A
Unsigned32
(hh3cCfdMdName)
MD name.
N/A
OCTET STRING
(hh3cCfdMaIndex)
MA index.
N/A
Unsigned32
(hh3cCfdMaName)
MA name.
N/A
OCTET STRING
(hh3cCfdMepId)
MEP ID.
N/A
Integer32
Integer(1..8191)
Recommended action
Check CFD configuration on both ends to make sure the MD or MA names are consistent.
hh3cCfdLoc
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.2.207.1.0.6
The CCM connection times out.
Error
Warning
1.3.6.1.4.1.25506.2.207.1.0.17 (hh3cCfdLOCClear)
ON
This notification is generated when the MEP fails to receive any CCM messages from the peer MEP upon expiration of the CCM timeout timer.
System impact
Status control
Objects
OID (object name)
Index nodes
Value range
(hh3cCfdMdIndex)
MD index.
N/A
Unsigned32
(hh3cCfdMdName)
MD name.
N/A
OCTET STRING
(hh3cCfdMaIndex)
MA index.
N/A
Unsigned32
(hh3cCfdMaName)
MA name.
N/A
OCTET STRING
(hh3cCfdMepId)
MEP ID.
N/A
Integer32
Integer(1..8191)
(hh3cCfdRMepId)
Remote MEP ID.
N/A
Unsigned32
Recommended action
Check whether a link issue exists in the network.
hh3cCfdLOCClear
Basic information
OID
Event
Severity
Default status
The MEPs on the two ends are reconnected.
Recovery
Warning
N/A
ON
This notification is generated when the MEP receives CCM messages from the peer MEP upon expiration of the CCM timeout timer.
System impact
Status control
Objects
OID (object name)
Index nodes
Value range
(hh3cCfdMdIndex)
MD index.
N/A
Unsigned32
(hh3cCfdMdName)
MD name.
N/A
OCTET STRING
(hh3cCfdMaIndex)
MA index.
N/A
Unsigned32
(hh3cCfdMaName)
MA name.
N/A
OCTET STRING
(hh3cCfdMepId)
MEP ID.
N/A
Integer32
Integer(1..8191)
(hh3cCfdRMepId)
Remote MEP ID.
N/A
Unsigned32
Recommended action
hh3cCfdUnexpectedMEP
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.2.207.1.0.7
The MEP IDs do not match on the two ends.
Error
Warning
1.3.6.1.4.1.25506.2.207.1.0.15 (hh3cCfdUnexpectedMEPClear)
ON
This notification is generated when the MEP ID carried in CCMs is not in the MEP list on the local end if both MD level and MA name settings are correctly configured on the two ends.
System impact
Status control
Objects
OID (object name)
Index nodes
Value range
(hh3cCfdMdIndex)
MD index.
N/A
Unsigned32
(hh3cCfdMdName)
MD name.
N/A
OCTET STRING
(hh3cCfdMaIndex)
MA index.
N/A
Unsigned32
(hh3cCfdMaName)
MA name.
N/A
OCTET STRING
(hh3cCfdMepId)
MEP ID.
N/A
Integer32
Integer(1..8191)
Recommended action
Check whether the two ends have the same MEP ID and MEP list settings.
Basic information
OID
Event
Severity
Default status
The local MEP receives a CCM with the same MEP ID from the remote MEP.
Recovery
Warning
N/A
ON
This notification is generated when the local MEP receives a CCM upon expiration of the CCM timeout timer, and the MEP ID in the received CCM matches the MEP list.
System impact
Status control
Objects
OID (object name)
Index nodes
Value range
(hh3cCfdMdIndex)
MD index.
N/A
Unsigned32
(hh3cCfdMdName)
MD name.
N/A
OCTET STRING
(hh3cCfdMaIndex)
MA index.
N/A
Unsigned32
(hh3cCfdMaName)
MA name.
N/A
OCTET STRING
(hh3cCfdMepId)
MEP ID.
N/A
Integer32
Integer(1..8191)
Recommended action
hh3cCfdUnexpectedPeriod
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.2.207.1.0.8
The CCM intervals do not match.
Error
Warning
1.3.6.1.4.1.25506.2.207.1.0.16 (hh3cCfdUnexpectedPeriodClear)
ON
This notification is generated when the CCM intervals do not match on the two ends that have correctly configured MD level, MA name, MEP ID, and MEP list settings.
System impact
Status control
Objects
OID (object name)
Index nodes
Value range
(hh3cCfdMdIndex)
MD index.
N/A
Unsigned32
(hh3cCfdMdName)
MD name.
N/A
OCTET STRING
(hh3cCfdMaIndex)
MA index.
N/A
Unsigned32
(hh3cCfdMaName)
MA name.
N/A
OCTET STRING
(hh3cCfdMepId)
MEP ID.
N/A
Integer32
Integer(1..8191)
(hh3cCfdRMepId)
Remote MEP ID.
N/A
Unsigned32
Recommended action
Check whether the two ends have the same CCM interval settings.
Basic information
OID
Event
Severity
Default status
The local MEP receives a CCM with the same CCM interval from the remote MEP.
Recovery
Warning
N/A
ON
This notification is generated when the local MEP receives a CCM with the same CCM interval from the remote MEP upon expiration of the CCM timeout timer.
System impact
Status control
Objects
OID (object name)
Index nodes
Value range
(hh3cCfdMdIndex)
MD index.
N/A
Unsigned32
(hh3cCfdMdName)
MD name.
N/A
OCTET STRING
(hh3cCfdMaIndex)
MA index.
N/A
Unsigned32
(hh3cCfdMaName)
MA name.
N/A
OCTET STRING
(hh3cCfdMepId)
MEP ID.
N/A
Integer32
Integer(1..8191)
(hh3cCfdRMepId)
Remote MEP ID.
N/A
Unsigned32
Recommended action
hh3cCfdExceptionMACStatus
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.2.207.1.0.9
The MEP receives a CCM with an abnormal port status TLV.
Error
Warning
1.3.6.1.4.1.25506.2.207.1.0.19 (hh3cCfdExceptionMACStatusClear)
ON
This notification is generated when the local MEP receives a CCM from the remote MEP upon expiration of the CCM timeout timer, but the TLV information in the CCM indicates that the port status of the remote MEP is abnormal.
System impact
Status control
Objects
OID (object name)
Index nodes
Value range
(hh3cCfdMdIndex)
MD index.
N/A
Unsigned32
(hh3cCfdMdName)
MD name.
N/A
OCTET STRING
(hh3cCfdMaIndex)
MA index.
N/A
Unsigned32
(hh3cCfdMaName)
MA name.
N/A
OCTET STRING
(hh3cCfdMepId)
MEP ID.
N/A
Integer32
Integer(1..8191)
(hh3cCfdRMepId)
Remote MEP ID.
N/A
Unsigned32
Recommended action
Check the port status of the remote MEP.
Basic information
OID
Event
Severity
Default status
The local MEP receives a CCM with normal TLV information.
Recovery
Warning
N/A
ON
This notification is generated when the local MEP receives a CCM with normal TLV information from the remote MEP upon expiration of the CCM timeout timer.
System impact
Status control
Objects
OID (object name)
Index nodes
Value range
(hh3cCfdMdIndex)
MD index.
N/A
Unsigned32
(hh3cCfdMdName)
MD name.
N/A
OCTET STRING
(hh3cCfdMaIndex)
MA index.
N/A
Unsigned32
(hh3cCfdMaName)
MA name.
N/A
OCTET STRING
(hh3cCfdMepId)
MEP ID.
N/A
Integer32
Integer(1..8191)
(hh3cCfdRMepId)
Remote MEP ID.
N/A
Unsigned32
Recommended action
hh3cCfdRDI
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.2.207.1.0.10
The remote MEP receives a CCM carrying the RDI flag bits.
Error
Warning
1.3.6.1.4.1.25506.2.207.1.0.18 (hh3cCfdRDIClear)
ON
This notification is sent to the local MEP after the remote MEP receives a CCM carrying the RDI flag bits.
System impact
Status control
Objects
OID (object name)
Index nodes
Value range
(hh3cCfdMdIndex)
MD index.
N/A
Unsigned32
(hh3cCfdMdName)
MD name.
N/A
OCTET STRING
(hh3cCfdMaIndex)
MA index.
N/A
Unsigned32
(hh3cCfdMaName)
MA name.
N/A
OCTET STRING
(hh3cCfdMepId)
MEP ID.
N/A
Integer32
Integer(1..8191)
(hh3cCfdRMepId)
Remote MEP ID.
N/A
Unsigned32
Recommended action
hh3cCfdRDIClear
Basic information
OID
Event
Severity
Default status
The MEPs in the MA do not carry the RDI flag bits in CCMs.
Recovery
Warning
N/A
ON
This notification is sent to the local MEP after the remote MEP receives a CCM carrying no RDI flag bits.
System impact
Status control
Objects
OID (object name)
Index nodes
Value range
(hh3cCfdMdIndex)
MD index.
N/A
Unsigned32
(hh3cCfdMdName)
MD name.
N/A
OCTET STRING
(hh3cCfdMaIndex)
MA index.
N/A
Unsigned32
(hh3cCfdMaName)
MA name.
N/A
OCTET STRING
(hh3cCfdMepId)
MEP ID.
N/A
Integer32
Integer(1..8191)
(hh3cCfdRMepId)
Remote MEP ID.
N/A
Unsigned32
Recommended action
hh3cCfdAisDefectAlarm
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.2.207.1.0.11
The MEP receives AIS frames.
Error
Warning
1.3.6.1.4.1.25506.2.207.1.0.12 (hh3cCfdAisDefectAlarmRecovery)
ON
This notification is generated when a MEP receives AIS frames and enters the AIS error state.
System impact
The link where the MEP resides is faulty.
Status control
Objects
OID (object name)
Index nodes
Value range
(hh3cCfdMdIndex)
MD index.
N/A
Unsigned32
(hh3cCfdMdName)
MD name.
N/A
OCTET STRING
(hh3cCfdMaIndex)
MA index.
N/A
Unsigned32
(hh3cCfdMaName)
MA name.
N/A
OCTET STRING
(hh3cCfdMepId)
MEP ID.
N/A
Integer32
Integer(1..8191)
Recommended action
Check the link errors on the two ends.
Basic information
OID
Event
Severity
Default status
The MEP no longer receives any AIS frames.
Recovery
Warning
N/A
ON
This notification is generated when a MEP receives no AIS frames within 3.5 times the AIS frame transmission interval.
System impact
Status control
Objects
OID (object name)
Index nodes
Value range
(hh3cCfdMdIndex)
MD index.
N/A
Unsigned32
(hh3cCfdMdName)
MD name.
N/A
OCTET STRING
(hh3cCfdMaIndex)
MA index.
N/A
Unsigned32
(hh3cCfdMaName)
MA name.
N/A
OCTET STRING
(hh3cCfdMepId)
MEP ID.
N/A
Integer32
Integer(1..8191)
Recommended action
Basic information
OID
Event
Severity
Default status
The MEP does not receive any CCMs with an incorrect MD level upon expiration of the CCM timeout timer.
Recovery
Warning
N/A
ON
This notification is generated when the MEP does not receive any CCMs with an incorrect MD level upon expiration of the CCM timeout timer.
System impact
Status control
Objects
OID (object name)
Index nodes
Value range
(hh3cCfdMdIndex)
MD index.
N/A
Unsigned32
(hh3cCfdMdName)
MD name.
N/A
OCTET STRING
(hh3cCfdMaIndex)
MA index.
N/A
Unsigned32
(hh3cCfdMaName)
MA name.
N/A
OCTET STRING
(hh3cCfdMepId)
MEP ID.
N/A
Integer32
Integer(1..8191)
Recommended action
Basic information
OID
Event
Severity
Default status
The MEP does not receive any CCMs with inconsistent MD or MA names of the two ends upon expiration of the CCM timeout timer.
Recovery
Warning
N/A
ON
This notification is generated when the MEP does not receive any CCMs with inconsistent MD or MA names of the two ends upon expiration of the CCM timeout timer.
System impact
Status control
Objects
OID (object name)
Index nodes
Value range
(hh3cCfdMdIndex)
MD index.
N/A
Unsigned32
(hh3cCfdMdName)
MD name.
N/A
OCTET STRING
(hh3cCfdMaIndex)
MA index.
N/A
Unsigned32
(hh3cCfdMaName)
MA name.
N/A
OCTET STRING
(hh3cCfdMepId)
MEP ID.
N/A
Integer32
Integer(1..8191)
Recommended action
Basic information
OID
Event
Severity
Default status
The one-way packet loss ratio drops below the upper limit.
Recovery
Warning
N/A
ON
This notification is generated when the two-way frame loss ratio on the source or target MEP drops below the configured upper limit.
System impact
Status control
Objects
OID (object name)
Index nodes
Value range
(hh3cCfdFrameEnd)
N/A
Integer32
 nearEnd(1)
 farEnd(2)
(hh3cCfdMepId)
MEP ID.
N/A
Integer32
Integer(1..8191)
(hh3cCfdSrvId)
N/A
Integer32
Integer(0..32767)
N/A
OCTET STRING
STRING(SIZE(0..8))
Recommended action
