07-IP Multicast
HomeSupportReference GuidesMIB CompanionH3C S6826 & S9826 MIB Companion-Release 6715-6W10007-IP Multicast
11-PIM-STD-MIB
11-PIM-STD-MIB 456.17 KB
PIM-STD-MIB· 1
About this MIB· 1
MIB file name· 1
Root object 1
Scalar objects· 1
pimKeepalivePeriod· 1
pimRegisterSuppressionTime· 1
pimStarGEntries· 1
pimStarGIEntries· 2
pimSGEntries· 2
pimSGIEntries· 2
pimSGRptEntries· 2
pimSGRptIEntries· 2
pimOutAsserts· 2
pimInAsserts· 3
pimLastAssertInterface· 3
pimLastAssertGroupAddressType· 3
pimLastAssertGroupAddress· 3
pimLastAssertSourceAddressType· 4
pimLastAssertSourceAddress· 4
pimNeighborLossNotificationPeriod· 4
pimNeighborLossCount 4
pimInvalidRegisterNotificationPeriod· 5
pimInvalidRegisterMsgsRcvd· 5
pimInvalidRegisterAddressType· 5
pimInvalidRegisterOrigin· 5
pimInvalidRegisterGroup· 6
pimInvalidRegisterRp· 6
pimInvalidJoinPruneNotificationPeriod· 6
pimInvalidJoinPruneMsgsRcvd· 6
pimInvalidJoinPruneAddressType· 6
pimInvalidJoinPruneOrigin· 7
pimInvalidJoinPruneGroup· 7
pimInvalidJoinPruneRp· 7
pimRPMappingNotificationPeriod· 7
pimRPMappingChangeCount 8
pimInterfaceElectionNotificationPeriod· 8
pimInterfaceElectionWinCount 8
pimRefreshInterval 8
pimDeviceConfigStorageType· 8
Tabular objects· 9
pimInterfaceTable· 9
pimNeighborTable· 12
pimNbrSecAddressTable· 14
pimStarGTable· 14
pimStarGITable· 17
pimSGTable· 18
pimSGITable· 21
pimSGRptTable· 23
pimSGRptITable· 24
pimBidirDFElectionTable· 24
pimStaticRPTable· 26
pimGroupMappingTable· 27
pimAnycastRPSetTable· 28
Notifications· 29
pimNeighborLoss· 29
pimInvalidRegister 31
pimInvalidJoinPrune· 32
pimRPMappingChange· 34
pimInterfaceElection· 35
PIM-STD-MIB
About this MIB
Use this MIB to manage PIM routers.
MIB file name
rfc5060-pim-std.mib
Root object
iso(1).org(3).dod(6).internet(1).mgmt(2).mib-2(1).pimStdMIB(157)
Scalar objects
pimKeepalivePeriod
Object (OID)
Access
Value range
Implementation
pimKeepalivePeriod
(1.3.6.1.2.1.157.1.14)
read-write
Unsigned32
Unsigned32(0..65535)
Duration of the Keepalive timer.
Supports only IPv4.
Value range: 1:0..65535.
When write, this object might first create a PIM view.
Object (OID)
Access
Value range
Implementation
(1.3.6.1.2.1.157.1.15)
read-write
Unsigned32
Duration of the register suppression timer.
Supports only IPv4.
Value range: 1:1..65535.
pimStarGEntries
Object (OID)
Access
Value range
Implementation
pimStarGEntries
(1.3.6.1.2.1.157.1.16)
read-only
Gauge32
INTEGER(0..4294967295)
Number of entries in the pimStarGTable.
As per the MIB.
pimStarGIEntries
Object (OID)
Access
Value range
Implementation
pimStarGIEntries
(1.3.6.1.2.1.157.1.17)
read-only
Gauge32
Number of entries in the pimStarGITable.
As per the MIB.
pimSGEntries
Object (OID)
Access
Value range
Implementation
pimSGEntries
(1.3.6.1.2.1.157.1.18)
read-only
Gauge32
Number of entries in the pimSGTable.
As per the MIB.
pimSGIEntries
Object (OID)
Access
Value range
Implementation
pimSGIEntries
(1.3.6.1.2.1.157.1.19)
read-only
Gauge32
Number of entries in the pimSGITable.
As per the MIB.
pimSGRptEntries
Object (OID)
Access
Value range
Implementation
pimSGRptEntries
(1.3.6.1.2.1.157.1.20)
read-only
Gauge32
Number of entries in the pimSGRptTable.
As per the MIB.
pimSGRptIEntries
Object (OID)
Access
Value range
Implementation
pimSGRptIEntries
(1.3.6.1.2.1.157.1.21)
read-only
Gauge32
Number of entries in the pimSGRptITable.
As per the MIB.
pimOutAsserts
Object (OID)
Access
Value range
Implementation
pimOutAsserts
(1.3.6.1.2.1.157.1.22)
read-only
Counter64
INTEGER(0..18446744073709551615)
Number of Asserts sent by this router.
As per the MIB.
pimInAsserts
Object (OID)
Access
Value range
Implementation
pimInAsserts
(1.3.6.1.2.1.157.1.23)
read-only
Counter64
Number of Asserts received by this router.
As per the MIB.
Object (OID)
Access
Value range
Implementation
(1.3.6.1.2.1.157.1.24)
read-only
InterfaceIndexOrZero
Integer32(0..2147483647)
Interface on which this router most recently sent or received an assert.
If this router has not sent or received an assert, then this object is set to zero.
As per the MIB.
Object (OID)
Access
Value range
Implementation
(1.3.6.1.2.1.157.1.25)
read-only
InetAddressType
INTEGER{
unknown(0),
ipv4(1),
ipv6(2)
Address type of the multicast group address in the most recently sent or received assert.
If this router has not sent or received an assert, then this object is set to unknown(0).
Supports only the following values: unknown(0), ipv4(1), and ipv6(2).
Object (OID)
Access
Value range
Implementation
(1.3.6.1.2.1.157.1.26)
read-only
InetAddress
OCTET STRING (0..255)
Multicast group address in the most recently sent or received assert. The InetAddressType is given by the pimLastAssertGroupAddressType object.
As per the MIB.
Object (OID)
Access
Value range
Implementation
(1.3.6.1.2.1.157.1.27)
read-only
InetAddressType
INTEGER{
unknown(0),
ipv4(1),
ipv6(2)
Address type of the source address in the most recently sent or received assert.
If the most recent assert was  (*,G), or if this router has not sent or received an assert, then this object is set to unknown(0).
Object (OID)
Access
Value range
Implementation
(1.3.6.1.2.1.157.1.28)
read-only
InetAddress
OCTET STRING (0|4|8|16|20)
Source address in the most recently sent or received assert.
The InetAddressType is given by the pimLastAssertSourceAddressType object.
As per the MIB.
Object (OID)
Access
Value range
Implementation
(1.3.6.1.2.1.157.1.29)
read-write
Unsigned32
Minimum time that must elapse between pimNeighborLoss notifications originated by this router.
Read-only.
Supports only value 0.
Object (OID)
Access
Value range
Implementation
(1.3.6.1.2.1.157.1.30)
read-only
Counter32
Number of neighbor loss events that have occurred.
As per the MIB.
Object (OID)
Access
Value range
Implementation
(1.3.6.1.2.1.157.1.31)
read-write
Unsigned32
Unsigned32(10..65535)
Minimum time that must elapse between pimInvalidRegister notifications originated by this router.
Read-only.
Supports only value 65535.
Object (OID)
Access
Value range
Implementation
(1.3.6.1.2.1.157.1.32)
read-only
Counter32
Number of invalid PIM register messages that have been received by this router.
As per the MIB.
Object (OID)
Access
Value range
Implementation
(1.3.6.1.2.1.157.1.33)
read-only
InetAddressType
INTEGER{
unknown(0),
ipv4(1),
ipv6(2)
Address type stored in pimInvalidRegisterOrigin, pimInvalidRegisterGroup, and pimInvalidRegisterRp.
Object (OID)
Access
Value range
Implementation
(1.3.6.1.2.1.157.1.34)
read-only
InetAddress
Source address of the last invalid register message received by this device .
As per the MIB.
Object (OID)
Access
Value range
Implementation
(1.3.6.1.2.1.157.1.35)
read-only
InetAddress
IP multicast group address to which the last invalid register message received by this device was addressed.
As per the MIB.
Object (OID)
Access
Value range
Implementation
(1.3.6.1.2.1.157.1.36)
read-only
InetAddress
RP address to which the last invalid Register message received by this device was delivered.
As per the MIB.
Object (OID)
Access
Value range
Implementation
(1.3.6.1.2.1.157.1.37)
read-write
Unsigned32
Minimum time that must elapse between pimInvalidJoinPrune notifications originated by this router.
Read-only.
Object (OID)
Access
Value range
Implementation
(1.3.6.1.2.1.157.1.38)
read-only
Counter32
Number of invalid PIM Join/Prune messages that have been received by this device.
As per the MIB.
Object (OID)
Access
Value range
Implementation
(1.3.6.1.2.1.157.1.39)
read-only
InetAddressType
INTEGER{
unknown(0),
ipv4(1),
ipv6(2)
Address type stored in pimInvalidJoinPruneOrigin, pimInvalidJoinPruneGroup, and pimInvalidJoinPruneRp.
Object (OID)
Access
Value range
Implementation
(1.3.6.1.2.1.157.1.40)
read-only
InetAddress
Source address of the last invalid join/prune message received by this device.
As per the MIB.
Object (OID)
Access
Value range
Implementation
(1.3.6.1.2.1.157.1.41)
read-only
InetAddress
IP multicast group address carried in the last invalid join/prune message received by this device.
As per the MIB.
Object (OID)
Access
Value range
Implementation
(1.3.6.1.2.1.157.1.42)
read-only
InetAddress
RP address carried in the last invalid join/prune message received by this device.
As per the MIB.
Object (OID)
Access
Value range
Implementation
(1.3.6.1.2.1.157.1.43)
read-write
Unsigned32
Minimum time that must elapse between pimRPMappingChange notifications originated by this router.
Read-only.
Object (OID)
Access
Value range
Implementation
(1.3.6.1.2.1.157.1.44)
read-only
Counter32
Number of changes to active RP mappings on this device.
Not supported
Object (OID)
Access
Value range
Implementation
(1.3.6.1.2.1.157.1.45)
read-write
Unsigned32
Minimum time that must elapse between pimInterfaceElection notifications originated by this router.
Not supported.
Object (OID)
Access
Value range
Implementation
(1.3.6.1.2.1.157.1.46)
read-only
Counter32
Number of times this device has been elected as DR or DF on any interface.
Not supported.
pimRefreshInterval
Object (OID)
Access
Value range
Implementation
pimRefreshInterval
(1.3.6.1.2.1.157.1.47)
read-write
Unsigned32
Interval between successive state refresh messages sent by an originator.
Supports only IPv4.
Value range: 1:1..255.
Object (OID)
Access
Value range
Implementation
(1.3.6.1.2.1.157.1.48)
read-write
StorageType
INTEGER {
other(1),
volatile(2),
nonVolatile(3),
permanent(4),
readOnly(5)
Storage type used for the global PIM configuration of this device.
Read-only.
Tabular objects
pimInterfaceTable
About this table
This table contains PIM interface settings. This table supports only the public network and is available only when the interface runs in the PIM-SM mode.
Support for operations
Create
Edit/Modify
Delete
Read
Supported
Supported
Supported
Supported
Columns
The table indexes are pimInterfaceIfIndex and pimInterfaceIPVersion.
Object (OID)
Access
Value range
Implementation
pimInterfaceIfIndex
(1.3.6.1.2.1.157.1.1.1.1)
not-accessible
InterfaceIndex
Integer32(1..2147483647)
Index of an interface.
As per the MIB.
(1.3.6.1.2.1.157.1.1.1.2)
not-accessible
InetVersion
INTEGER{
unknown(0),         ipv4(1),       ipv6(2)
IP version of this PIM interface.
As per the MIB.
pimInterfaceAddressType
(1.3.6.1.2.1.157.1.1.1.3)
read-only
InetAddressType
INTEGER{
unknown(0),
ipv4(1),
ipv6(2)
Address type of this PIM interface.
pimInterfaceAddress
(1.3.6.1.2.1.157.1.1.1.4)
read-only
InetAddress
Primary IP address of this router on this PIM interface.
As per the MIB.
pimInterfaceGenerationIDValue
(1.3.6.1.2.1.157.1.1.1.5)
read-only
Unsigned32
Standard MIB values.
Value of the Generation ID this router inserted in the last PIM hello message it sent on this interface.
0 means an invalid value.
pimInterfaceDR
(1.3.6.1.2.1.157.1.1.1.6)
read-only
InetAddress
Primary IP address of the DR on this PIM interface.
As per the MIB.
pimInterfaceDRPriority
(1.3.6.1.2.1.157.1.1.1.7)
read-create
Unsigned32
DR priority value inserted into the DR Priority option in PIM Hello messages transmitted on this interface.
As per the MIB.
pimInterfaceDRPriorityEnabled
(1.3.6.1.2.1.157.1.1.1.8)
read-only
TruthValue
true(1),
false(2)
Whether all routers on this interface are using the DR Priority option.
As per the MIB.
pimInterfaceHelloInterval
(1.3.6.1.2.1.157.1.1.1.9)
read-create
Unsigned32
Unsigned32(0..18000)
Interval at which PIM Hello messages are transmitted on this interface
Value range: 1:0..18000.
pimInterfaceTrigHelloInterval
(1.3.6.1.2.1.157.1.1.1.10)
read-create
Unsigned32
Unsigned32(0..60)
Maximum time before this router sends a triggered PIM hello message on this interface.
Value range: 1:1..60.
pimInterfaceHelloHoldtime
(1.3.6.1.2.1.157.1.1.1.11)
read-create
Unsigned32
Value set in the Holdtime field of PIM Hello messages transmitted on this interface.
pimInterfaceJoinPruneInterval
(1.3.6.1.2.1.157.1.1.1.12)
read-create
Unsigned32
Interval at which this router sends PIM Join/Prune messages on this PIM interface.
pimInterfaceJoinPruneHoldtime
(1.3.6.1.2.1.157.1.1.1.13)
read-create
Unsigned32
Value inserted into the Holdtime field of a PIM Join/Prune message sent on this interface.
pimInterfaceDFElectionRobustness
(1.3.6.1.2.1.157.1.1.1.14)
read-create
Unsigned32
Minimum number of PIM DF-Election messages that must be lost in order for DF election on this interface to fail.
Read-only.
Supports only value 3.
pimInterfaceLanDelayEnabled
(1.3.6.1.2.1.157.1.1.1.15)
read-only
TruthValue
true(1),
false(2)
Whether all routers on this interface are using the LAN Prune Delay option.
As per the MIB.
pimInterfacePropagationDelay
(1.3.6.1.2.1.157.1.1.1.16)
read-create
Unsigned32
Unsigned32(0..32767)
Expected propagation delay between PIM routers on this network or link.
Value range: 1:1..32767.
pimInterfaceOverrideInterval
(1.3.6.1.2.1.157.1.1.1.17)
read-create
Unsigned32
Value this router inserts into the Override_Interval field of the LAN Prune Delay option in the PIM Hello messages it sends on this interface.
pimInterfaceEffectPropagDelay
(1.3.6.1.2.1.157.1.1.1.18)
read-only
Unsigned32
Effective Propagation Delay on this interface.
As per the MIB.
pimInterfaceEffectOverrideIvl
(1.3.6.1.2.1.157.1.1.1.19)
read-only
Unsigned32
Effective Override Interval on this interface.
As per the MIB.
pimInterfaceSuppressionEnabled
(1.3.6.1.2.1.157.1.1.1.20)
read-only
TruthValue
true(1),
false(2)
Whether join suppression is enabled on this interface.
As per the MIB.
pimInterfaceBidirCapable
(1.3.6.1.2.1.157.1.1.1.21)
read-only
TruthValue
true(1),
false(2)
Whether all routers on this interface are using the Bidirectional-PIM Capable option.
As per the MIB.
pimInterfaceDomainBorder
(1.3.6.1.2.1.157.1.1.1.22)
read-create
TruthValue
true(1),
false(2)
Whether this interface is a PIM domain border.
As per the MIB.
pimInterfaceStubInterface
(1.3.6.1.2.1.157.1.1.1.23)
read-create
TruthValue
true(1),
false(2)
Whether this interface is a stub interface.
Read-only.
The value of this object value is always false(2).
pimInterfacePruneLimitInterval
(1.3.6.1.2.1.157.1.1.1.24)
read-create
Unsigned32
Minimum interval that must transpire between two successive Prunes sent by a router.
Read-only.
Default: 1:210(int).
pimInterfaceGraftRetryInterval
(1.3.6.1.2.1.157.1.1.1.25)
read-create
Unsigned32
Minimum interval that must elapse between two successive Grafts sent by a Pim-DM router.
pimInterfaceSRPriorityEnabled
(1.3.6.1.2.1.157.1.1.1.26)
read-only
TruthValue
true(1),
false(2)
Whether all routers on this interface are using the State Refresh option.
As per the MIB.
pimInterfaceStatus
(1.3.6.1.2.1.157.1.1.1.27)
read-create
RowStatus
active(1),
createAndGo(4),
destroy(6)
Row status.
·     active(1).
·     createAndGo(4)—Enable PIM-SM on this interface.
·     destroy(6)—Disable PIM-SM on this interface.
pimInterfaceStorageType
(1.3.6.1.2.1.157.1.1.1.28)
read-create
StorageType
other(1)
Row storage type.
Read-only.
Supports only value other(1).
pimNeighborTable
About this table
This table contains PIM neighbor settings. This table supports only the public network.
Create
Edit/Modify
Delete
Read
Not supported
Not supported
Not supported
Supported
Columns
The table indexes are pimNeighborIfIndex, pimNeighborAddressType, and pimNeighborAddress.
Object (OID)
Access
Value range
Implementation
pimNeighborIfIndex
(1.3.6.1.2.1.157.1.2.1.1)
not-accessible
InterfaceIndex
Index of the interface used to reach this PIM neighbor.
As per the MIB.
(1.3.6.1.2.1.157.1.2.1.2)
not-accessible
InetAddressType
INTEGER{
ipv4(1),
ipv6(2)
Address type of this PIM neighbor.
Supports only the following values: ipv4(1) and ipv6(2).
pimNeighborAddress
(1.3.6.1.2.1.157.1.2.1.3)
not-accessible
InetAddress
OCTET STRING (4|8|16|20)
Primary IP address of this PIM neighbor.
As per the MIB.
pimNeighborGenerationIDPresent
(1.3.6.1.2.1.157.1.2.1.4)
read-only
TruthValue
true(1),
false(2)
Whether this neighbor is using the Generation ID option.
As per the MIB.
pimNeighborGenerationIDValue
(1.3.6.1.2.1.157.1.2.1.5)
read-only
Unsigned32
Value of the Generation ID from the last PIM Hello message received from this neighbor.
As per the MIB.
pimNeighborUpTime
(1.3.6.1.2.1.157.1.2.1.6)
read-only
TimeTicks
Time since this PIM neighbor (last) became a neighbor of the local router.
As per the MIB.
pimNeighborExpiryTime
(1.3.6.1.2.1.157.1.2.1.7)
read-only
TimeTicks
Minimum time remaining before this PIM neighbor will time out.
As per the MIB.
pimNeighborDRPriorityPresent
(1.3.6.1.2.1.157.1.2.1.8)
read-only
TruthValue
true(1),
false(2)
Whether this neighbor is using the DR Priority option.
As per the MIB.
(1.3.6.1.2.1.157.1.2.1.9)
read-only
Unsigned32
Value of the Designated Router Priority from the last PIM Hello message received from this neighbor.
As per the MIB.
pimNeighborLanPruneDelayPresent
(1.3.6.1.2.1.157.1.2.1.10)
read-only
TruthValue
true(1),
false(2)
Whether this neighbor is using the LAN Prune Delay option.
As per the MIB.
pimNeighborTBit
(1.3.6.1.2.1.157.1.2.1.11)
read-only
TruthValue
true(1),
false(2)
Whether the T bit was set in the LAN Prune Delay option received from this neighbor.
As per the MIB.
pimNeighborPropagationDelay
(1.3.6.1.2.1.157.1.2.1.12)
read-only
Unsigned32
Value of the Propagation_Delay field of the LAN Prune Delay option received from this neighbor.
As per the MIB.
pimNeighborOverrideInterval (1.3.6.1.2.1.157.1.2.1.13)
read-only
Unsigned32
Value of the Override_Interval field of the LAN Prune Delay option received from this neighbor.
As per the MIB.
pimNeighborBidirCapable
(1.3.6.1.2.1.157.1.2.1.14)
read-only
TruthValue
true(1),
false(2)
Whether this neighbor is using the Bidirectional-PIM Capable option.
As per the MIB.
pimNeighborSRCapable
(1.3.6.1.2.1.157.1.2.1.15)
read-only
TruthValue
true(1),
false(2)
Whether this neighbor is using the State Refresh Capable option.
As per the MIB.
About this table
This table contains secondary addresses advertised by a PIM neighbor.
Create
Edit/Modify
Delete
Read
Not supported
Not supported
Not supported
Supported
Columns
The table indexes are pimNbrSecAddressIfIndex, pimNbrSecAddressType, pimNbrSecAddressPrimary, and pimNbrSecAddress.
Object (OID)
Access
Value range
Implementation
(1.3.6.1.2.1.157.1.3.1.1)
not-accessible
InterfaceIndex
As per the MIB.
(1.3.6.1.2.1.157.1.3.1.2)
not-accessible
InetAddressType
INTEGER{
unknown(0),
ipv4(1),
ipv6(2),
As per the MIB.
(1.3.6.1.2.1.157.1.3.1.3)
not-accessible
InetAddress
As per the MIB.
pimNbrSecAddress
(1.3.6.1.2.1.157.1.3.1.4)
read-only
InetAddress
Secondary IP address of this PIM neighbor.
Supports only value ipv6(2).
pimStarGTable
About this table
This table contains the non-interface specific (*,G) state that PIM has. This table supports only the public network and is available only to PIM-SM.
Create
Edit/Modify
Delete
Read
Not supported
Not supported
Not supported
Supported
Columns
The table indexes are pimStarGAddressType and pimStarGGrpAddress.
Object (OID)
Access
Value range
Implementation
pimStarGAddressType
(1.3.6.1.2.1.157.1.4.1.1)
not-accessible
InetAddressType
INTEGER{
ipv4(1),
ipv6(2)
Address type of a multicast group.
pimStarGGrpAddress
(1.3.6.1.2.1.157.1.4.1.2)
not-accessible
InetAddress
Multicast group address.
As per the MIB.
pimStarGUpTime
(1.3.6.1.2.1.157.1.4.1.3)
read-only
TimeTicks
Time since this entry was created by the local router.
As per the MIB.
pimStarGPimMode
(1.3.6.1.2.1.157.1.4.1.4)
read-only
PimMode
asm(3), bidir(4)
PIM mode of this entry: ASM or BIDIR-PIM.
Supports only the following values: asm(3) and bidir(4).
pimStarGRPAddressType
(1.3.6.1.2.1.157.1.4.1.5)
read-only
InetAddressType
INTEGER{
unknown(0),
ipv4(1),
ipv6(2)
Address type of the RP.
This object is associated with the current designated RP, which might be different from the actual RP.
pimStarGRPAddress
(1.3.6.1.2.1.157.1.4.1.6)
read-only
InetAddress
IP address of the RP for the group.
pimStarGPimModeOrigin
(1.3.6.1.2.1.157.1.4.1.7)
read-only
PimGroupMappingOriginType
INTEGER {
fixed(1),    configRp(2),   configSsm(3),    bsr(4),    autoRP(5),    embedded(6),    other(7)
Mechanism by which the PIM mode and RP for the group were learned.
Supported only the following values:
configRp (2), bsr(4), and other(7).
pimStarGRPIsLocal
(1.3.6.1.2.1.157.1.4.1.8)
read-only
TruthValue
true(1),
false(2)
Whether the local router is the RP for the group.
As per the MIB.
pimStarGUpstreamJoinState
(1.3.6.1.2.1.157.1.4.1.9)
read-only
INTEGER
notJoined (1),          joined (2)
Whether the local router should join the RP tree for the group.
As per the MIB.
pimStarGUpstreamJoinTimer
(1.3.6.1.2.1.157.1.4.1.10)
read-only
TimeTicks
Time remaining before the local router sends a next periodic (*,G) Join message.
As per the MIB.
pimStarGUpstreamNeighborType
(1.3.6.1.2.1.157.1.4.1.11)
read-only
InetAddressType
INTEGER{
unknown(0),
ipv4(1),
ipv6(2)
Primary address type of the upstream neighbor.
(1.3.6.1.2.1.157.1.4.1.12)
read-only
InetAddress
As per the MIB.
pimStarGRPFIfIndex (1.3.6.1.2.1.157.1.4.1.13)
read-only
Index of the RPF towards the RP.
As per the MIB.
pimStarGRPFNextHopType
(1.3.6.1.2.1.157.1.4.1.14)
read-only
InetAddressType
INTEGER{
unknown(0),
ipv4(1),
ipv6(2)
Address type of the RPF next hop towards the RP.
pimStarGRPFNextHop
(1.3.6.1.2.1.157.1.4.1.15)
read-only
InetAddress
Address of the RPF next hop towards the RP.
As per the MIB.
pimStarGRPFRouteProtocol
(1.3.6.1.2.1.157.1.4.1.16)
read-only
IANAipRouteProtocol
other(1)
local(2)
netmgmt(3)
rip(8)
isis(9)
ospf(13)
bgp(14)
Routing mechanism via which the route used to find the RPF interface towards the RP was learned.
·     other(1).
·     local(2).
·     netmgmt(3).
·     rip(8).
·     isis(9).
·     ospf(13).
·     bgp(14).
pimStarGRPFRouteAddress
(1.3.6.1.2.1.157.1.4.1.17)
read-only
InetAddress
IP address that identifies the route used to find the RPF interface towards the RP.
As per the MIB.
pimStarGRPFRoutePrefixLength
(1.3.6.1.2.1.157.1.4.1.18)
read-only
InetAddressPrefixLength
Unsigned32(0..2040)
Prefix length that identifies the route used to find the RPF interface towards the RP.
If pimStarGRPFIfIndex is 0, this object value is always 0.
pimStarGRPFRouteMetricPref
(1.3.6.1.2.1.157.1.4.1.19)
read-only
Unsigned32
Unsigned32(0..2147483647)
Metric preference of the route used to find the RPF interface towards the RP.
If pimStarGRPFIfIndex is 0, this object value is always 2147483647.
(1.3.6.1.2.1.157.1.4.1.20)
read-only
Unsigned32
Routing metric of the route used to find the RPF interface towards the RP.
If pimStarGRPFIfIndex is 0, this object value is always 4294967295.
pimStarGITable
About this table
This table contains interface-specific (*,G)  state that PIM has. This table supports only the public network and is available only to PIM-SM.
Create
Edit/Modify
Delete
Read
Not supported
Not supported
Not supported
Supported
Columns
The table indexes are pimStarGAddressType, pimStarGGrpAddress, and pimStarGIIfIndex.
Object (OID)
Access
Value range
Implementation
pimStarGIIfIndex
(1.3.6.1.2.1.157.1.5.1.1)
not-accessible
InterfaceIndex
Index of the interface that an entry corresponds to.
As per the MIB.
pimStarGIUpTime
(1.3.6.1.2.1.157.1.5.1.2)
read-only
TimeTicks
Not supported
pimStarGILocalMembership
(1.3.6.1.2.1.157.1.5.1.3)
read-only
TruthValue
true(1),
false(2)
Whether the local router has (*,G) local membership on this interface.
As per the MIB.
pimStarGIJoinPruneState
(1.3.6.1.2.1.157.1.5.1.4)
read-only
INTEGER
noInfo (1),         join (2),        prunePending (3)
State resulting from (*,G) Join/Prune messages received on this interface.
As per the MIB.
pimStarGIPrunePendingTimer
(1.3.6.1.2.1.157.1.5.1.5)
read-only
TimeTicks
Time remaining before the local router acts on a (*,G) Prune message received on this interface, during which the router is waiting to see whether another downstream router will override the Prune message.
As per the MIB.
pimStarGIJoinExpiryTimer
(1.3.6.1.2.1.157.1.5.1.6)
read-only
TimeTicks
Time remaining before (*,G) Join state for this interface expires.
As per the MIB.
pimStarGIAssertState
(1.3.6.1.2.1.157.1.5.1.7)
read-only
INTEGER
noInfo (1),
iAmAssertWinner (2),
iAmAssertLoser (3)
(*,G) Assert state for this interface.
Not supported
pimStarGIAssertTimer
(1.3.6.1.2.1.157.1.5.1.8)
read-only
TimeTicks
Time remaining before the local router next sends a (*,G) Assert message on this interface.
Not supported
pimStarGIAssertWinnerAddressType
(1.3.6.1.2.1.157.1.5.1.9)
read-only
InetAddressType
INTEGER{
unknown(0),
ipv4(1),
ipv6(2),
dns(16)
Address type of the assert winner.
Not supported
(1.3.6.1.2.1.157.1.5.1.10)
read-only
InetAddress
IP address of the assert winner.
Not supported
pimStarGIAssertWinnerMetricPref
(1.3.6.1.2.1.157.1.5.1.11)
read-only
Unsigned32
Metric preference of the route to the RP advertised by the assert winner.
Not supported
(1.3.6.1.2.1.157.1.5.1.12)
read-only
Unsigned32
Routing metric of the route to the RP advertised by the assert winner.
Not supported
pimSGTable
About this table
This table contains the non-interface specific (S,G) state that PIM has. This table supports only the public network.
Create
Edit/Modify
Delete
Read
Not supported
Not supported
Not supported
Supported
Columns
The table indexes are pimSGAddressType, pimSGGrpAddress, and pimSGSrcAddress.
Object (OID)
Access
Value range
Implementation
pimSGAddressType
(1.3.6.1.2.1.157.1.6.1.1)
not-accessible
InetAddressType
INTEGER{
ipv4(1),
ipv6(2),
Address type of the source and multicast group for an entry.
pimSGGrpAddress
(1.3.6.1.2.1.157.1.6.1.2)
not-accessible
InetAddress
Multicast group address for this entry.
As per the MIB.
pimSGSrcAddress
(1.3.6.1.2.1.157.1.6.1.3)
not-accessible
InetAddress
Source address for this entry.
As per the MIB.
pimSGUpTime
(1.3.6.1.2.1.157.1.6.1.4)
read-only
TimeTicks
As per the MIB.
pimSGPimMode
(1.3.6.1.2.1.157.1.6.1.5)
read-only
PimMode
ssm(2), asm(3)
PIM mode of the group for this entry, SSM or ASM.
Supports only the following values: ssm(2), asm(3), and dm(5).
pimSGUpstreamJoinState
(1.3.6.1.2.1.157.1.6.1.6)
read-only
INTEGER
Whether the local router should join the SPT for the source and group represented by this entry.
If the PIM mode is not PIM-SM, this object value is always joined (2).
pimSGUpstreamJoinTimer
(1.3.6.1.2.1.157.1.6.1.7)
read-only
TimeTicks
Time remaining before the local router sends a next periodic (S,G) Join message.
As per the MIB.
pimSGUpstreamNeighbor
(1.3.6.1.2.1.157.1.6.1.8)
read-only
InetAddress
Primary IP address of the upstream neighbor.
As per the MIB.
pimSGRPFIfIndex
(1.3.6.1.2.1.157.1.6.1.9)
read-only
Index of the RPF interface towards the source.
As per the MIB.
pimSGRPFNextHopType
(1.3.6.1.2.1.157.1.6.1.10)
read-only
InetAddressType
INTEGER{
unknown(0),
ipv4(1),
ipv6(2),
Address type of the RPF next hop towards the source.
pimSGRPFNextHop
(1.3.6.1.2.1.157.1.6.1.11)
read-only
InetAddress
IP address of the RPF next hop towards the source.
As per the MIB.
pimSGRPFRouteProtocol
(1.3.6.1.2.1.157.1.6.1.12)
read-only
IANAipRouteProtocol
INTEGER {
other (1),
local (2),
netmgmt (3),
icmp(4),
egp (5),
ggp (6),
hello (7),
rip (8),
isIs (9),
esIs (10),
ciscoIgrp (11),
bbnSpfIgp (12),
ospf (13),
bgp (14),
idpr (15),
ciscoEigrp (16),
dvmrp (17)
Routing mechanism via which the route used to find the RPF interface towards the source was learned.
·     other(1).
·     local(2).
·     netmgmt(3).
·     rip(8).
·     isis(9).
·     ospf(13).
·     bgp(14).
pimSGRPFRouteAddress
(1.3.6.1.2.1.157.1.6.1.13)
read-only
InetAddress
IP address that identifies the route used to find the RPF interface towards the source.
As per the MIB.
pimSGRPFRoutePrefixLength
(1.3.6.1.2.1.157.1.6.1.14)
read-only
Unsigned32(0..2040)
Prefix length that identifies the route used to find the RPF interface towards the source.
If pimSGRPFIfIndex is 0, this object value is always 0.
pimSGRPFRouteMetricPref
(1.3.6.1.2.1.157.1.6.1.15)
read-only
Unsigned32
Metric preference of the route used to find the RPF interface towards the source.
If pimSGRPFIfIndex is 0, this object value is always 2147483647.
pimSGRPFRouteMetric
(1.3.6.1.2.1.157.1.6.1.16)
read-only
Unsigned32
Routing metric of the route used to find the RPF interface towards the source.
If pimSGRPFIfIndex is 0, this object is 4294967295.
pimSGSPTBit
(1.3.6.1.2.1.157.1.6.1.17)
read-only
TruthValue
true(1),
false(2)
Whether the SPT bit is set.
As per the MIB.
pimSGKeepaliveTimer
(1.3.6.1.2.1.157.1.6.1.18)
read-only
TimeTicks
Time remaining before this (S,G) state expires.
If the PIM mode is not PIM-SM, this object value is always 0.
pimSGDRRegisterState
(1.3.6.1.2.1.157.1.6.1.19)
read-only
INTEGER
noInfo (1),
join (2),     joinPending (3),
prune (4)
Whether the local router should encapsulate (S,G) data packets in Register messages and send them to the RP.
As per the MIB.
pimSGDRRegisterStopTimer
(1.3.6.1.2.1.157.1.6.1.20)
read-only
TimeTicks
Time remaining before the local router sends a Null-Register message to the RP.
As per the MIB.
pimSGRPRegisterPMBRAddressType
(1.3.6.1.2.1.157.1.6.1.21)
read-only
InetAddressType
INTEGER{
unknown(0),
ipv4(1),
ipv6(2),
dns(16)
Address type of the first PIM Multicast Border Router to send a Register message with the Border bit set.
Not supported
(1.3.6.1.2.1.157.1.6.1.22)
read-only
InetAddress
IP address of the first PIM Multicast Border Router to send a Register message with the Border bit set.
Not supported
pimSGUpstreamPruneState
(1.3.6.1.2.1.157.1.6.1.23)
read-only
INTEGER
forwarding (1),    ackpending (2),
pruned (3)
Whether the local router has pruned itself from the tree.
If the PIM mode is not PIM-SM, this object value is always forwarding
pimSGUpstreamPruneLimitTimer
(1.3.6.1.2.1.157.1.6.1.24)
read-only
TimeTicks
Time remaining before the local router may send a (S,G) Prune message.
As per the MIB.
pimSGOriginatorState
(1.3.6.1.2.1.157.1.6.1.25)
read-only
INTEGER
notOriginator (1),   originator (2)
Whether the router is an originator for an (S,G) message flow.
As per the MIB.
pimSGSourceActiveTimer
(1.3.6.1.2.1.157.1.6.1.26)
read-only
TimeTicks
Time remaining before the local router reverts to a notOriginator state.
As per the MIB.
pimSGStateRefreshTimer
(1.3.6.1.2.1.157.1.6.1.27)
read-only
TimeTicks
Time remaining before the local router sends a State Refresh message.
As per the MIB.
pimSGITable
About this table
This table contains interface-specific (S,G) state that PIM has. This table supports only the public network.
Create
Edit/Modify
Delete
Read
Not supported
Not supported
Not supported
Supported
Columns
The table indexes are pimSGAddressType, pimSGGrpAddress, pimSGSrcAddress, and pimSGIIfIndex.
Object (OID)
Access
Value range
Implementation
pimSGIIfIndex (1.3.6.1.2.1.157.1.7.1.1)
not-accessible
InterfaceIndex
As per the MIB.
pimSGIUpTime
(1.3.6.1.2.1.157.1.7.1.2)
read-only
TimeTicks
0 (by default)
Not supported
pimSGILocalMembership
(1.3.6.1.2.1.157.1.7.1.3)
read-only
TruthValue
true(1),
false(2)
Whether the local router has (S,G) local membership on this interface.
As per the MIB.
pimSGIJoinPruneState (1.3.6.1.2.1.157.1.7.1.4)
read-only
INTEGER
noInfo (1),
State resulting from (S,G) Join/Prune messages received on this interface.
In PIM-DM, v noInfo(1) indicates pruned, and join(2) indicates no information.
pimSGIPrunePendingTimer
(1.3.6.1.2.1.157.1.7.1.5)
read-only
TimeTicks
Time remaining before the local router acts on an (S,G) Prune message received on this interface, during which the router is waiting to see whether another downstream router will override the Prune message.
This timer is available to PIM-SM, PIM-DM, and PIM-SSM.
pimSGIJoinExpiryTimer
(1.3.6.1.2.1.157.1.7.1.6)
read-only
TimeTicks
Time remaining before (S,G) Join state for this interface expires.
pimSGIAssertState
(1.3.6.1.2.1.157.1.7.1.7)
read-only
INTEGER(
noInfo (1),                iAmAssertWinner (2),                 iAmAssertLoser (3)
(S,G) Assert state for this interface.
pimSGIAssertTimer
(1.3.6.1.2.1.157.1.7.1.8)
read-only
TimeTicks
Time remaining before the local router next sends a (S,G) Assert message on this interface
pimSGIAssertWinnerAddressType (1.3.6.1.2.1.157.1.7.1.9)
read-only
InetAddressType
INTEGER{
unknown(0),
ipv4(1),
ipv6(2),
As per the MIB.
(1.3.6.1.2.1.157.1.7.1.10)
read-only
InetAddress
Address of the assert winner.
As per the MIB.
pimSGIAssertWinnerMetricPref
(1.3.6.1.2.1.157.1.7.1.11)
read-only
Unsigned32
Metric preference of the route to the source advertised by the assert winner.
As per the MIB.
(1.3.6.1.2.1.157.1.7.1.12)
read-only
Unsigned32
Routing metric of the route to the source advertised by the assert winner.
As per the MIB.
pimSGRptTable
About this table
This table contains the non-interface specific (S,G,rpt) state that PIM has. It supports only the public network.
Create
Edit/Modify
Delete
Read
Not supported
Not supported
Not supported
Supported
Columns
The table indexes are pimStarGAddressType, pimStarGGrpAddress, and pimSGRptSrcAddress.
Object (OID)
Access
Value range
Implementation
pimSGRptSrcAddress
(1.3.6.1.2.1.157.1.8.1.1)
not-accessible
InetAddress
Source address for an entry.
As per the MIB.
pimSGRptUpTime
(1.3.6.1.2.1.157.1.8.1.2)
read-only
TimeTicks
As per the MIB.
pimSGRptUpstreamPruneState
(1.3.6.1.2.1.157.1.8.1.3)
read-only
INTEGER
rptNotJoined (1),                 pruned (2),                notPruned (3)
Whether the local router should prune the source off the RP tree.
As per the MIB.
pimSGRptUpstreamOverrideTimer
(1.3.6.1.2.1.157.1.8.1.4)
read-only
TimeTicks
Time remaining before the local router sends a triggered (S,G,rpt) Join message
As per the MIB.
pimSGRptITable
About this table
This table contains the interface-specific (S,G,rpt) state that PIM has. It supports only the public network.
Create
Edit/Modify
Delete
Read
Not supported
Not supported
Not supported
Supported
Columns
The table indexes are pimSGRptITable, pimStarGGrpAddress, pimSGRptSrcAddress, and pimSGRptIIfIndex.
Object (OID)
Access
Value range
Implementation
pimSGRptIIfIndex
(1.3.6.1.2.1.157.1.9.1.1)
not-accessible
InterfaceIndex
As per the MIB.
pimSGRptIUpTime
(1.3.6.1.2.1.157.1.9.1.2)
read-only
TimeTicks
0 (by default)
Not supported
pimSGRptILocalMembership
(1.3.6.1.2.1.157.1.9.1.3)
read-only
TruthValue
true(1),
false(2)
Whether the local router has both (*,G) include local membership and (S,G) exclude local membership on this interface..
As per the MIB.
pimSGRptIJoinPruneState
(1.3.6.1.2.1.157.1.9.1.4)
read-only
INTEGER
noInfo(1),                 prune(2),                 prunePending (3)
State resulting from (S,G,rpt) Join/Prune messages received on this interface.
As per the MIB.
pimSGRptIPrunePendingTimer
(1.3.6.1.2.1.157.1.9.1.5)
read-only
TimeTicks
Time remaining before the local router starts pruning this source off the RP tree.
As per the MIB.
pimSGRptIPruneExpiryTimer
(1.3.6.1.2.1.157.1.9.1.6)
read-only
TimeTicks
Time remaining before (S,G,rpt) Prune state for this interface expires.
As per the MIB.
About this table
This table contains BIDIR-PIM DF settings. It supports only the public network.
Create
Edit/Modify
Delete
Read
Not supported
Not supported
Not supported
Supported
Columns
The table indexes are pimBidirDFElectionAddressType, pimBidirDFElectionRPAddress, and pimBidirDFElectionIfIndex.
Object (OID)
Access
Value range
Implementation
(1.3.6.1.2.1.157.1.10.1.1)
not-accessible
InetAddressType
INTEGER{
unknown(0),
ipv4(1),
ipv6(2),
Address type of the RP associated with a DF.
As per the MIB.
(1.3.6.1.2.1.157.1.10.1.2)
not-accessible
InetAddress
IP address of the RP associated with the DF.
As per the MIB.
(1.3.6.1.2.1.157.1.10.1.3)
not-accessible
InterfaceIndex
Index of the interface used in DF selection .
As per the MIB.
pimBidirDFElectionWinnerAddressType
(1.3.6.1.2.1.157.1.10.1.4)
read-only
InetAddressType
INTEGER{
unknown(0),
ipv4(1),
ipv6(2),
Address type of the DF winner.
(1.3.6.1.2.1.157.1.10.1.5)
read-only
InetAddress
IP address of the DF winner.
As per the MIB.
pimBidirDFElectionWinnerUpTime
(1.3.6.1.2.1.157.1.10.1.6)
read-only
TimeTicks
Time since the DF winner has come up.
As per the MIB.
pimBidirDFElectionWinnerMetricPref
(1.3.6.1.2.1.157.1.10.1.7)
read-only
Unsigned32
Metric preference of the DF winner.
As per the MIB.
(1.3.6.1.2.1.157.1.10.1.8)
read-only
Unsigned32
Metric of the DF winner.
As per the MIB.
pimBidirDFElectionState
(1.3.6.1.2.1.157.1.10.1.9)
read-only
INTEGER
dfOffer(1), dfLose(2), dfWinner(3), dfBackoff(4)
DF status of the interface.
As per the MIB.
pimBidirDFElectionStateTimer
(1.3.6.1.2.1.157.1.10.1.10)
read-only
Timeticks
DF election timeout time of the interface.
As per the MIB.
pimStaticRPTable
About this table
This table contains static RP settings. It supports only the public network. ACL-based multicast group filtering for static RPs configured by using the static-rp command is not supported.
Create
Edit/Modify
Delete
Read
Supported
Supported
Supported
Read of the static-rp command with an ACL specified is not supported.
Columns
The table indexes are pimStaticRPAddressType, pimStaticRPGrpAddress, and pimStaticRPGrpPrefixLength.
Object (OID)
Access
Value range
Implementation
(1.3.6.1.2.1.157.1.11.1.1)
not-accessible
InetAddressType
INTEGER{
unknown(0),
ipv4(1),
ipv6(2),
Type of a static RP.
As per the MIB.
(1.3.6.1.2.1.157.1.11.1.2)
not-accessible
InetAddress
Address of the multicast group to which the static RP is designated..
Supports only the following values: 224.0.0.0/4(ipv4) and FF :: / 8(ipv6).
(1.3.6.1.2.1.157.1.11.1.3)
not-accessible
Unsigned32(4..128)
Mask length of the multicast group address to which the static RP is designated.
Supports only the following values: 4(ipv4) and 8(ipv6).
pimStaticRPRPAddress
(1.3.6.1.2.1.157.1.11.1.4)
read-create
InetAddress
IP address of the static RP.
As per the MIB.
pimStaticRPPimMode
(1.3.6.1.2.1.157.1.11.1.5)
read-create
PimMode
ssm(2), asm(3), bidir(4)
Mode of the static RP.
pimStaticRPOverrideDynamic
(1.3.6.1.2.1.157.1.11.1.6)
read-create
TruthValue
true(1),
false(2)
Whether priority has been given to the static RP.
As per the MIB.
pimStaticRPPrecedence
(1.3.6.1.2.1.157.1.11.1.7)
read-create
Unsigned32
Priority of the static RP.
Read-only.
The value is always 1342177280.
pimStaticRPRowStatus
(1.3.6.1.2.1.157.1.11.1.8)
read-create
RowStatus
active(1),
createAndGo(4),
destroy(6)
Row status.
Supports only the following values: active(1), createAndGo(4), and destroy(6).
pimStaticRPStorageType
(1.3.6.1.2.1.157.1.11.1.9)
read-create
StorageType
other(1)
Row storage type.
Read-only.
About this table
This table contains mappings between multicast group addresses to RPs. It supports only the public network.
Create
Edit/Modify
Delete
Read
Not supported
Not supported
Not supported
Supported
Columns
The table indexes are pimGroupMappingOrigin, pimGroupMappingAddressType, pimGroupMappingGrpAddress, pimGroupMappingGrpPrefixLength, pimGroupMappingRPAddressType, and pimGroupMappingRPAddress.
Object (OID)
Access
Value range
Implementation
(1.3.6.1.2.1.157.1.13.1.1)
not-accessible
fixed(1); configRp(2); configSsm(3); bsr(4); autoRP(5); embedded(6); other(7)
Mechanism by which this group mapping was learned.
Supports only BSR, SRP, and SSM.
(1.3.6.1.2.1.157.1.13.1.2)
not-accessible
InetAddressType
INTEGER{
ipv4(1),
ipv6(2),
Address type of the IP multicast group prefix.
Supports only values ipv4(1) and ipv6(2).
(1.3.6.1.2.1.157.1.13.1.3)
not-accessible
InetAddress
Multicast group address that gives the group prefix for this mapping.
As per the MIB.
(1.3.6.1.2.1.157.1.13.1.4)
not-accessible
Unsigned32(4..128)
Prefix length of the multicast group address that gives the group prefix for this mapping.
As per the MIB.
(1.3.6.1.2.1.157.1.13.1.5)
not-accessible
InetAddressType
INTEGER{
unknown(0),
ipv4(1),
ipv6(2),
Address type of the RP to be used for groups within this group prefix
(1.3.6.1.2.1.157.1.13.1.6)
not-accessible
InetAddress
IP address of the RP to be used for groups within this group prefix.
As per the MIB.
pimGroupMappingPimMode
(1.3.6.1.2.1.157.1.13.1.7)
read-only
PimMode
none(1); ssm(2); asm(3); bidir(4); dm(5); other(6)
PIM mode to be used for groups in this group prefix.
Supports only the following values: asm, ssm, and bidir.
pimGroupMappingPrecedence
(1.3.6.1.2.1.157.1.13.1.8)
read-only
Unsigned32
Precedence of the SSM mapping.
If pimGroupMappingOrigin is bsr(4), this object is (0x30000000 + rp priority).
If pimGroupMappingOrigin is configRp(2), this object is (0x50000000).
If pimGroupMappingOrigin is configSsm(3), this object is (0x00000000).
Basic information
This table contain information about the anycast RP configuration.
Create
Edit/Modify
Delete
Read
Not supported
Not supported
Not supported
Not supported
Columns
The table indexes are pimAnycastRPSetAddressType, pimAnycastRPSetAnycastAddress, and pimAnycastRPSetRouterAddress.
Object (OID)
Access
Value range
Implementation
pimAnycastRPSetAddressType (1.3.6.1.2.1.157.1.12.1.1)
not-accessible
InetAddressType
INTEGER{
unknown(0),
ipv4(1),
ipv6(2),
Anycast RP address type.
Not supported
pimAnycastRPSetAnycastAddress (1.3.6.1.2.1.157.1.12.1.2)
not-accessible
InetAddress
Anycast RP address.
Not supported
pimAnycastRPSetRouterAddress (1.3.6.1.2.1.157.1.12.1.3)
not-accessible
InetAddress
Anycast RP member address.
Not supported
pimAnycastRPSetLocalRouter (1.3.6.1.2.1.157.1.12.1.4)
read-only
TruthValue
N/A
Local member address or not.
Not supported
pimAnycastRPSetRowStatus (1.3.6.1.2.1.157.1.12.1.5)
read-create
RowStatus
active(1),
notInService(2),
notReady(3),
createAndGo(4),
createAndWait(5),
destroy(6)
Row status.
Not supported
pimAnycastRPSetStorageType (1.3.6.1.2.1.157.1.12.1.6)
read-create
StorageType
N/A
Row storage type.
Not supported
Notifications
pimNeighborLoss
Basic information
OID
Event
Severity
Recovery notification
Default status
1.3.6.1.2.1.157.0.1
PIM neighbor loss.
Informational
Warning
N/A
ON
Notification triggers
This notification is generated when the timer of a neighbor expires and no neighbor of the same IP version and with a lower IP address exists.
This notification might be generated for the following reasons:
·     The hold timer of the PIM neighbor expires.
·     The interface where the PIM neighbor resides goes down.
·     The PIM neighbor is deleted.
·     The device receives a neighbor message with the hold time as 0.
·     The BFD session of the neighbor goes down.
System impact
A connection will fail to be established, and data forwarding will be interrupted.
Status control
ON
CLI: Use the snmp-agent trap enable pim neighbor-loss command.
CLI: Use the snmp-agent trap enable pim6 neighbor-loss command.
OFF
CLI: Use the undo snmp-agent trap enable pim neighbor-loss command.
CLI: Use the undo snmp-agent trap enable pim6 neighbor-loss command.
Objects
OID (object name)
Index nodes
Value range
1.3.6.1.2.1.157.1.2.1.6 (pimNeighborUpTime)
Time since the neighbor has come up.
pimNeighborIfIndex
pimNeighborAddress
TimeTicks
Recommended action
To resolve this issue:
1.     Use the display this command to identify whether the pim neighbor-policy or ipv6 pim neighbor-policy command is executed on the interface.
¡     If yes, go to step 2.
¡     If no, go to step 3.
2.     Use the display acl or display acl ipv6 command to identify whether the neighbor is permitted by the ACL.
¡     If yes, go to step 3.
¡     If no, reconfigure the ACL to permit the neighbor.
3.     Use the display interface command on the local device and the neighbor device to identify the physical state of the interface.
¡     If the physical state is Administratively DOWN, execute the undo shutdown command.
¡     If the physical state is Down, check the physical connection (including whether the network cable and transceiver module are loose or disconnected), and reconnect the physical connection.
¡     If the physical state is Up, go to step 4.
4.     Use the display ip interface or display ipv6 interface command on the local device and the neighbor device to identify the protocol state of the interface.
¡     If the protocol state is Up, go to step 5.
¡     If the protocol state is Down, use the ip address or ipv6 address command to assign an IP address to the interface.
5.     Use the display this command on the local device and the neighbor device to identify whether the interface is enabled with PIM SM or IPv6 PIM SM.
¡     If yes, go to step 6.
¡     If no, execute the pim sm or ipv6 pim sm command on the interface.
6.     Use the display current-configuration command on the local device and the neighbor device to identify whether the VPN instance is enabled multicast routing or IPv6 multicast routing.
¡     If yes, go to step 7.
¡     If no, execute the multicast routing or ipv6 multicast routing command on the interface.
7.     Use the display memory command on the local device and the neighbor device to identify the memory usage.
¡     If the memory is insufficient, address the memory issue.
¡     If the memory is sufficient, go to step 8.
8.     Use the ping or ping ipv6 command on the local device to test the connectivity with the neighbor device.
¡     If the ping succeeds, go to step 10.
¡     If the ping fails, go to step 9.
9.     Use the display ip routing-table or display ipv6 routing-table command on the local device and the neighbor device to identify the unicast routes to each other are normal.
¡     If the unicast routes are normal, go to step 10.
¡     If the unicast routes are abnormal, address the route issues.
10.     If the issue persists, collect alarm information and configuration data, and then contact H3C Support for help.
pimInvalidRegister
Basic information
OID
Event
Severity
Default status
1.3.6.1.2.1.157.0.2
An invalid PIM register message was received.
Informational
Warning
N/A
ON
This notification is generated when an invalid PIM register message is received. A PIM register message is invalid if the device is not the RP corresponding to the group address in the message or the group address is in the SSM range of the device.
System impact
Multicast sources might fail to be registered with the RP.
Status control
ON
CLI: Use the snmp-agent trap enable pim invalid-register command.
CLI: Use the snmp-agent trap enable pim6 invalid-register command.
OFF
CLI: Use the undo snmp-agent trap enable pim invalid-register command.
CLI: Use the undo snmp-agent trap enable pim6 invalid-register command.
Objects
OID (object name)
Index nodes
Value range
1.3.6.1.2.1.157.1.13.1.7 (pimGroupMappingPimMode)
PIM mode.
PimMode
1.3.6.1.2.1.157.1.33 (pimInvalidRegisterAddressType)
Address type of the register message.
N/A
InetAddressType
1.3.6.1.2.1.157.1.34 (pimInvalidRegisterOrigin)
Source address of the register message.
N/A
InetAddress
1.3.6.1.2.1.157.1.35 (pimInvalidRegisterGroup)
Group address of the register message.
N/A
InetAddress
1.3.6.1.2.1.157.1.36 (pimInvalidRegisterRp)
Destination address of the register message.
N/A
InetAddress
Recommended action
To resolve this issue if the device is not the RP corresponding to the group address in the packet:
1.     Modify the source DR or RP configuration.
You can use the display pim rp-info or display ipv6 pim rp-info command to identify whether the device is the RP corresponding to the group address in the packet.
2.     If the issue persists, collect alarm information and configuration data, and then contact H3C Support for help.
To resolve this issue if the group address in the packet is not in the SSM range of the device:
1.     Modify an SSM range to make sure the SSM ranges on the local device and on the peer device are the same.
You can use the display current-configuration command to identify whether the group address in the packet is in the SSM range of the device.
pimInvalidJoinPrune
Basic information
OID
Event
Severity
Default status
1.3.6.1.2.1.157.0.3
An invalid PIM join/prune message was received.
Informational
Warning
N/A
ON
This notification is generated when an invalid PIM join/prune message is received. A PIM join/prune message is invalid if the RP address in a PIM join/prune message is different from the RP address on the device or the group address in a (*,G) or (S,G,RPT) join/prune message is in the SSM range of the device.
System impact
Multicast member information might fail to reach the RP, and multicast traffic forwarding might be affected.
Status control
ON
CLI: Use the snmp-agent trap enable pim invalid-join-prune command.
CLI: Use the snmp-agent trap enable pim6 invalid-join-prune command.
OFF
CLI: Use the undo snmp-agent trap enable pim invalid-join-prune command.
CLI: Use the undo snmp-agent trap enable pim6 invalid-join-prune command.
Objects
OID (object name)
Index nodes
Value range
PIM mode.
PimMode
1.3.6.1.2.1.157.1.39 (pimInvalidJoinPruneAddressType)
Address type of the join/prune message.
N/A
InetAddressType
1.3.6.1.2.1.157.1.40 (pimInvalidJoinPruneOrigin)
Source address of the join/prune message.
N/A
InetAddress
1.3.6.1.2.1.157.1.41 (pimInvalidJoinPruneGroup)
Group address of the join/prune message.
N/A
InetAddress
1.3.6.1.2.1.157.1.42 (pimInvalidJoinPruneRp)
Destination address of the join/prune message
N/A
InetAddress
Neighbor uptime.
pimNeighborIfIndex
pimNeighborAddress
TimeTicks
Recommended action
To resolve this issue if the RP address in a PIM join/prune message is different from the RP address for the multicast group:
1.     Modify the RP address to make sure the two RP addresses are the same.
You can use the display pim rp-info or display ipv6 pim rp-info command to view RP address information.
To resolve the issue if the RP address in the group address in a (*,G) or (S,G,RPT) join/prune message is in the SSM range of the device:
You can use the display current-configuration command to view SSM range information.
pimRPMappingChange
Basic information
OID
Event
Severity
Default status
1.3.6.1.2.1.157.0.4
RP change.
Informational
Warning
N/A
ON
This notification is generated for the following possible reasons:
·     The configuration of the RP changes.
·     The RP fails.
·     An RP is added.
System impact
The source and multicast group members might fail to communicate, affecting multicast services.
Status control
ON
CLI: Use the snmp-agent trap enable pim rp-mapping-change command.
CLI: Use the snmp-agent trap enable pim6 rp-mapping-change command.
OFF
CLI: Use the undo snmp-agent trap enable pim rp-mapping-change command.
CLI: Use the undo snmp-agent trap enable pim6 rp-mapping-change command.
Objects
OID (object name)
Index nodes
Value range
PIM mode.
PimMode
1.3.6.1.2.1.157.1.13.1.8 (pimGroupMappingPrecedence)
Priority.
Unsigned32
Recommended action
If the RP change is not desired, configure the device as a static RP or increase the priority of the original RP.
If the RP change is desired, no action is required.
Basic information
OID
Event
Severity
Default status
1.3.6.1.2.1.157.0.5
DR change.
Informational
Warning
N/A
ON
·     A PIM interface receives a hello packet, and the DR priority or IP address of the interface is higher than that of all other interface on the shared network segment.
·     A PIM interface does not receive hello packets from other interfaces during the first hello interval after the interface comes up.
System impact
The RP might receive incorrect Register messages if the multicast source-side DR changes. The RP might receive incorrect Join messages if the multicast receiver-side DR changes.
Status control
ON
CLI: Use the snmp-agent trap enable pim interface-election command.
CLI: Use the snmp-agent trap enable pim6 interface-election command.
OFF
CLI: Use the undo snmp-agent trap enable pim interface-election command.
CLI: Use the undo snmp-agent trap enable pim6 interface-election command.
Objects
OID (object name)
Index nodes
Value range
1.3.6.1.2.1.157.1.1.1.3 (pimInterfaceAddressType)
Interface address type.
pimInterfaceIfIndex
InetAddressType
1.3.6.1.2.1.157.1.1.1.4 (pimInterfaceAddress)
Interface address
pimInterfaceIfIndex
InetAddress
Recommended action
If the DR change is not desired, configure a lower DR priority or a lower IP address.
If the DR change is desired, no action is required.
