07-IP Multicast
HomeSupportReference GuidesMIB CompanionH3C S6826 & S9826 MIB Companion-Release 6715-6W10007-IP Multicast
02-HH3C-MGMD-STD-MIB
02-HH3C-MGMD-STD-MIB 92.53 KB
HH3C-MGMD-STD-MIB
About this MIB
Use this MIB to manage IGMP and MLD.
MIB file name
hh3c-mgmd-std.mib
Root object
iso(1).org(3).dod(6).internet(1).private(4).enterprises(1).hh3c(25506).hh3cCommon(2).hh3cMgmdStd(223)
Scalar objects
hh3cMgmdStdInterfaceName
Object (OID)
Access
Data type
Value range
Implementation
(1.3.6.1.4.1.25506.2.223.1.1)
accessible-for-notify
DisplayString (SIZE(1..64))
OCTET STRING (1..64)
Interface name
As per the MIB.
hh3cMgmdStdInterfaceIfIndex
Object (OID)
Access
Data type
Value range
Implementation
(1.3.6.1.4.1.25506.2.223.1.2)
InterfaceIndex
Integer32(1..2147483647)
Interface index
As per the MIB.
hh3cMgmdStdGmpJoinVersion
Object (OID)
Access
Data type
Value range
Implementation
hh3cMgmdStdGmpJoinVersion (1.3.6.1.4.1.25506.2.223.1.3)
Unsigned32
Unsigned32 (1..3)
Version of IGMP/MLD join messages.
As per the MIB.
hh3cMgmdStdAddressType
Object (OID)
Access
Data type
Value range
Implementation
hh3cMgmdStdAddressType (1.3.6.1.4.1.25506.2.223.1.4)
InetAddressType
unknown(0),
ipv4(1),
ipv6(2).
Address type of IGMP/MLD join messages.
As per the MIB.
hh3cMgmdStdGmpJoinSrcAddr
Object (OID)
Access
Data type
Value range
Implementation
hh3cMgmdStdGmpJoinSrcAddr (1.3.6.1.4.1.25506.2.223.1.5)
InetAddress
OCTET STRING (0..255)
Source address of IGMP/MLD join messages.
As per the MIB.
hh3cMgmdStdGmpJoinGrpAddr
Object (OID)
Access
Data type
Value range
Implementation
hh3cMgmdStdGmpJoinGrpAddr (1.3.6.1.4.1.25506.2.223.1.6)
InetAddress
Group address of IGMP/MLD join messages.
As per the MIB.
hh3cMgmdStdGmpJoinSenderIp
Object (OID)
Access
Data type
Value range
Implementation
hh3cMgmdStdGmpJoinSenderIp (1.3.6.1.4.1.25506.2.223.1.7)
InetAddress
Sender IP address of IGMP/MLD join messages.
As per the MIB.
hh3cMgmdStdInstanceName
Object (OID)
Access
Data type
Value range
Implementation
hh3cMgmdStdInstanceName (1.3.6.1.4.1.25506.2.223.1.8)
DisplayString
VPN instance name.
As per the MIB.
hh3cMgmdStdGmpJoinNotifPeriod
Object (OID)
Access
Value range
Implementation
hh3cMgmdStdGmpJoinNotifPeriod (1.3.6.1.4.1.25506.2.223.2.1)
read-write
Unsigned32
Unsigned32(0..65535)
Interval between hh3cMgmdStdGmpJoin notifications generated.
As per the MIB.
hh3cMgmdStdGmpLeaveNotifPeriod
Object (OID)
Access
Value range
Implementation
hh3cMgmdStdGmpLeaveNotifPeriod (1.3.6.1.4.1.25506.2.223.2.2)
read-write
Unsigned32
Interval between hh3cMgmdStdGmpLeave notifications generated.
As per the MIB.
Notifications
This section describes the HH3C-MGMD-STD-MIB notifications.
hh3cMgmdStdGmpJoin
Basic information
OID
Event
Severity
Recovery notification
Default status
1.3.6.1.4.1.25506.2.223.0.1
An IGMPv1, IGMPv2, or MLDv1 join message was received.
Informational
Warning
N/A
ON
Notification triggers
This notification is generated when an interface receives an IGMPv1, IGMPv2, or MLDv1 join message.
System impact
No negative impact on services
Status control
ON
CLI: Use the snmp-agent trap enable igmp join command.
CLI: Use the snmp-agent trap enable mld join command.
OFF
CLI: Use the undo snmp-agent trap enable igmp join command.
CLI: Use the undo snmp-agent trap enable mld join command.
Objects
OID (object name)
Index nodes
Value range
(hh3cMgmdStdInterfaceName)
Interface name.
N/A
(hh3cMgmdStdInterfaceIfIndex)
Interface index.
N/A
InterfaceIndex
(hh3cMgmdStdGmpJoinVersion)
Version of IGMP/ MLD join messages.
N/A
Unsigned32
Unsigned32 (1..3)
(hh3cMgmdStdAddressType)
Address type of IGMP/ MLD join messages.
N/A
InetAddressType
unknown(0),
ipv4(1),
ipv6(2).
(hh3cMgmdStdGmpJoinSrcAddr)
Multicast source address of IGMP/ MLD join messages.
N/A
InetAddress
(hh3cMgmdStdGmpJoinGrpAddr)
Group address of IGMP/ MLD join messages.
N/A
InetAddress
(hh3cMgmdStdGmpJoinSenderIp)
Sender IP address of IGMP/ MLD join messages.
N/A
InetAddress
(hh3cMgmdStdInstanceName)
VPN instance name.
N/A
DisplayString
Recommended action
No action is required.
hh3cMgmdStdGmpLeave
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.2.223.0.2
An IGMPv1, IGMPv2, or MLDv1 leave message was received.
Informational
Warning
N/A
ON
This notification is generated when an interface receives an IGMPv1, IGMPv2, or MLDv1 leave message or the corresponding multicast group timer times out.
System impact
No negative impact on services.
Status control
ON
CLI: Use the snmp-agent trap enable igmp leave command.
CLI: Use the snmp-agent trap enable mld leave command.
OFF
CLI: Use the undo snmp-agent trap enable igmp leave command.
CLI: Use the undo snmp-agent trap enable mld leave command.
Objects
OID (object name)
Index nodes
Value range
Interface name.
N/A
Interface index.
N/A
InterfaceIndex
Address type of IGMP/ MLD leave messages.
N/A
InetAddressType
unknown(0),
ipv4(1),
ipv6(2).
Source address of IGMP/ MLD leave messages.
N/A
InetAddress
Group address of IGMP/ MLD leave messages.
N/A
InetAddress
Sender IP address of IGMP/ MLD leave messages.
N/A
InetAddress
VPN instance name.
N/A
DisplayString
Recommended action
