07-IP Multicast
HomeSupportReference GuidesMIB CompanionH3C S6826 & S9826 MIB Companion-Release 6715-6W10007-IP Multicast
06-IGMP-STD-MIB
06-IGMP-STD-MIB 76.28 KB
IGMP-STD-MIB
About this MIB
Use this MIB to manage IGMP.
This MIB contains the following tables:
·     IGMP interface table—Each row contains an interface enabled with IGMP.
·     IGMP cache table—Each row contains a multicast group for which an IGMP interface maintain membership.
These tables are intended to be implemented by hosts and routers. However, some objects in the table are applicable only to routers.
MIB file name
rfc2933-igmp-std.mib
Root object
iso(1).org(3).dod(6).internet(1).mgmt(2).mib-2(1).igmpStdMIB(85)
Tabular objects
igmpInterfaceTable
About this table
This table contains settings of an interface enabled with IGMP.
Support for operations
Create
Edit/Modify
Delete
Read
Supported
Supported
Supported
Supported
Columns
The table index is igmpInterfaceIfIndex.
Object (OID)
Access
Value range
Implementation
(1.3.6.1.2.1.85.1.1.1.1)
not-accessible
InterfaceIndex
Integer32(1..2147483647)
Index of an interface enabled with IGMP.
As per the MIB.
igmpInterfaceQueryInterval
(1.3.6.1.2.1.85.1.1.1.2)
read-create
Unsigned32
Unsigned32(1..31744)
General query interval of the interface, in seconds.
Value range: 1 to 31744.
igmpInterfaceStatus
(1.3.6.1.2.1.85.1.1.1.3)
read-create
RowStatus
active(1)
createAndGo(4)
destroy(6)
Row status.
Supports only the following values: active(1), createAndGo(4), and destroy(6).
·     createAndGo(4)—Enable IGMP on the interface.
·     destroy(6)—Disable IGMP on the interface.
igmpInterfaceVersion
(1.3.6.1.2.1.85.1.1.1.4)
read-create
Unsigned32
Unsigned32(1..2)
IGMP version.
Value range: 1 to 3.
igmpInterfaceQuerier
(1.3.6.1.2.1.85.1.1.1.5)
read-only
IpAddress
OCTET STRING (4)
IP address of the IGMP querier of the subnet to which the interface is attached.
As per the MIB.
igmpInterfaceQueryMaxResponseTime
(1.3.6.1.2.1.85.1.1.1.6)
read-create
Unsigned32
Unsigned32(10..250)
Maximum response time, in tenth seconds.
Value range: 10 to 250.
igmpInterfaceQuerierUpTime
(1.3.6.1.2.1.85.1.1.1.7)
read-only
Timeticks
Standard MIB values.
Time elapsed since the IGMP querier was elected.
As per the MIB.
igmpInterfaceQuerierExpiryTime
(1.3.6.1.2.1.85.1.1.1.8)
read-only
Timeticks
Time remaining before the IGMP querier ages out.
As per the MIB.
igmpInterfaceVersion1QuerierTimer
(1.3.6.1.2.1.85.1.1.1.9)
read-only
Timeticks
Time remaining until the host assumes that there are no IGMPv1 routers present on the interface.
Not supported
igmpInterfaceWrongVersionQueries
(1.3.6.1.2.1.85.1.1.1.10)
read-only
Counter32
INTEGER(0..4294967295)
Number of queries received whose IGMP version does not match the IGMP version on the interface.
Not supported
igmpInterfaceJoins
(1.3.6.1.2.1.85.1.1.1.11)
read-only
Counter32
Number of times a group membership has been added on this interface.
As per the MIB.
igmpInterfaceProxyIfIndex
(1.3.6.1.2.1.85.1.1.1.12)
read-create
InterfaceIndexOrZero
Integer32(0..2147483647)
Index of the interface acting as the IGMP proxy on the interface.
Supports only the read operation.
igmpInterfaceGroups
(1.3.6.1.2.1.85.1.1.1.13)
read-only
Gauge32
Number of groups for which the interface maintains membership.
As per the MIB.
igmpInterfaceRobustness
(1.3.6.1.2.1.85.1.1.1.14)
read-create
Unsigned32
Unsigned32(1..255)
Robustness variable of the interface.
As per the MIB.
igmpInterfaceLastMembQueryIntvl
(1.3.6.1.2.1.85.1.1.1.15)
read-create
Unsigned32
Unsigned32(10..250)
Last member interface of the interface, in tenth seconds.
igmpCacheTable
About this table
This table contains multicast groups for which there are members on an interface.
Create
Edit/Modify
Delete
Read
Not supported
Not supported
Not supported
Supported
Columns
The table indexes are igmpCacheAddress and igmpCacheIfIndex.
Object (OID)
Access
Value range
Implementation
igmpCacheAddress
(1.3.6.1.2.1.85.1.2.1.1)
not-accessible
IpAddress
OCTET STRING (4)
IP multicast group address.
As per the MIB.
igmpCacheIfIndex
(1.3.6.1.2.1.85.1.2.1.2)
not-accessible
InterfaceIndex
Interface for which this entry contains information for an IP multicast group address.
As per the MIB.
igmpCacheSelf
(1.3.6.1.2.1.85.1.2.1.3)
read-create
TruthValue
false(2)
Whether the local system is a member of this group address on this interface.
Supports only false(2).
igmpCacheLastReporter
(1.3.6.1.2.1.85.1.2.1.4)
read-only
IpAddress
OCTET STRING (4)
IP address of the source of the last membership report received for this IP Multicast group address on this interface.
As per the MIB.
igmpCacheUpTime
(1.3.6.1.2.1.85.1.2.1.5)
read-only
Timeticks
Time elapsed since this entry was created.
As per the MIB.
igmpCacheExpiryTime
(1.3.6.1.2.1.85.1.2.1.6)
read-only
Timeticks
Minimum amount of time remaining before this entry ages out.
As per the MIB.
igmpCacheStatus
(1.3.6.1.2.1.85.1.2.1.7)
read-create
RowStatus
active(1),
notInService(2),
notReady(3),
createAndGo(4),
createAndWait(5),
destroy(6)
Row status.
igmpCacheVersion1HostTimer
(1.3.6.1.2.1.85.1.2.1.8)
read-only
TimeTicks
Time remaining until the local router will assume that there are no longer any IGMP version 1 members on the IP subnet attached to this interface.
As per the MIB.
