03-HH3C-MPM-MIB | 79.05 KB |
HH3C-MPM-MIB
About this MIB
The h3cHostStaticJoinTable table was added to this MIB to configure a host as a static member of a multicast group.
MIB file name
hh3c-mpm.mib
Root object
iso(1).org(3).dod(6).internet(1).private(4).enterprises(1).hh3c(25506).hh3cCommon(2).hh3cMpm(51)
Scalar objects
hh3cMPortGroupLimitMinNumber
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cMPortGroupLimitMinNumber (1.3.6.1.4.1.25506.2.51.1.1) |
read-only |
Unsigned32 |
Standard MIB values. |
Minimum number of groups that a port can join. |
The value of this object is always 0. |
hh3cMPortGroupLimitMaxNumber
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cMPortGroupLimitMaxNumber (1.3.6.1.4.1.25506.2.51.1.2) |
read-only |
Unsigned32 |
Maximum number of groups that a port can join. |
The value of this object is always 4294967295. |
Tabular objects
hh3cMPortGroupJoinTable
About this table
Use this table to configure a port in a VLAN to join a multicast group.
Support for operations
Create |
Edit/Modify |
Delete |
Read |
Supported |
Supported |
Supported |
Supported |
Columns
The table indexes are ifIndex, hh3cMPortGroupJoinVlanID, hh3cMPortGroupJoinAddressType, and hh3cMPortGroupJoinAddress.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cMPortGroupJoinVlanID (1.3.6.1.4.1.25506.2.51.2.1.1.1) |
not-accessible |
Integer32 |
An index uniquely identifying a port in a VLAN which joined the multicast group. |
As per the MIB. |
hh3cMPortGroupJoinAddressType (1.3.6.1.4.1.25506.2.51.2.1.1.2) |
not-accessible |
InetAddressType |
INTEGER{ unknown(0), ipv4(1), ipv6(2), dns(16) } |
Type of the multicast group address. |
As per the MIB. |
hh3cMPortGroupJoinAddress (1.3.6.1.4.1.25506.2.51.2.1.1.3) |
not-accessible |
InetAddress |
OCTET STRING (0..255) |
Address of the multicast group. It must be a valid multicast IP address. |
As per the MIB. |
hh3cMPortGroupJoinStatus (1.3.6.1.4.1.25506.2.51.2.1.1.4) |
read-create |
RowStatus |
active(1), createAndGo(4), destroy(6) |
Row status. |
Supports only the following values: active(1), createAndGo(4), and destroy(6). |
hh3cMPortGroupTable
About this table
This table contains information about the status of a port which joined a multicast group in a VLAN.
Create |
Edit/Modify |
Delete |
Read |
Not supported |
Not supported |
Not supported |
Supported |
Columns
The table indexes are ifIndex, hh3cMPortGroupVlanID, hh3cMPortGroupAddressType, and hh3cMPortGroupAddress.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cMPortGroupVlanID (1.3.6.1.4.1.25506.2.51.2.2.1.1) |
not-accessible |
Integer32 |
An index uniquely identifies that a port belongs to a specified VLAN. |
As per the MIB. |
hh3cMPortGroupAddressType (1.3.6.1.4.1.25506.2.51.2.2.1.2) |
read-only |
InetAddressType |
As per the MIB. |
hh3cMPortGroupAddress (1.3.6.1.4.1.25506.2.51.2.2.1.3) |
read-only |
InetAddress |
Address of the multicast group. |
As per the MIB. |
hh3cMPortConfigTable
About this table
This table contians information about the fast-leaving status, group limit number, and group policy parameters of a port in a VLAN.
Create |
Edit/Modify |
Delete |
Read |
Supported |
Supported |
Supported |
Supported |
Columns
The table indexes are ifIndex and hh3cMPortConfigVlanID.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cMPortConfigVlanID (1.3.6.1.4.1.25506.2.51.2.3.1.1) |
not-accessible |
Integer32 |
As per the MIB. |
hh3cMPortGroupLimitNumber (1.3.6.1.4.1.25506.2.51.2.3.1.2) |
read-create |
Unsigned32 |
As per the MIB. |
hh3cMPortFastLeaveStatus (1.3.6.1.4.1.25506.2.51.2.3.1.3) |
read-create |
EnabledStatus |
INTEGER{ enabled(1), disabled(2) } |
Fast-leaving status of the port. |
As per the MIB. |
hh3cMPortGroupPolicyParameter (1.3.6.1.4.1.25506.2.51.2.3.1.4) |
read-create |
Integer32 |
Integer32(0|2000..2999) |
ACL number which is used as the group policy of the port. |
As per the MIB. |
hh3cMPortConfigRowStatus (1.3.6.1.4.1.25506.2.51.2.3.1.5) |
read-create |
RowStatus |
active(1), notReady(3), createAndGo(4), destroy(6) |
Row status. |
Supports only the following values: destroy(6), notReady(3),, createAndGo(4), and destroy(6). |
hh3cMPortGroupLimitReplace (1.3.6.1.4.1.25506.2.51.2.3.1.6) |
read-create |
EnabledStatus |
This object is related to the object hh3cMPortGroupLimitNumber. If the current IGMP group number is less than the value of hh3cMPortGroupLimitNumber, any new IGMP group is permitted. |
As per the MIB. |
hh3cHostStaticJoinTable
About this table
Use this table to configure a host on a port in a VLAN statically to join a multicast group.
Create |
Edit/Modify |
Delete |
Read |
Supported |
Not supported |
Supported |
Supported |
Columns
The table indexes are ifIndex, h3cHostStaticJoinVlanID, h3cHostStaticJoinAddressType, and h3cHostStaticJoinAddress.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cHostStaticJoinVlanID (1.3.6.1.4.1.25506.2.51.2.4.1.1) |
not-accessible |
Integer32 |
An index uniquely identifies the VLAN in which a host on a port statically joined a multicast group. |
As per the MIB. |
hh3cHostStaticJoinAddressType (1.3.6.1.4.1.25506.2.51.2.4.1.2) |
not-accessible |
InetAddressType |
As per the MIB. |
hh3cHostStaticJoinAddress (1.3.6.1.4.1.25506.2.51.2.4.1.3) |
not-accessible |
InetAddress |
As per the MIB. |
hh3cHostStaticJoinStatus (1.3.6.1.4.1.25506.2.51.2.4.1.4) |
read-create |
RowStatus |
Row status. |
Supports only the following values: createAndGo(4), active(1), and destroy(6). |
