H3C WSG1808X-PWR Wireless Integrated Services Gateway Installation Guide-5W101
HomeSupportWirelessWSG1800X Wireless Integrated Services GatewayInstall & UpgradeInstallation GuidesH3C WSG1808X-PWR Wireless Integrated Services Gateway Installation Guide-5W101
04-Hardware management and maintenance
04-Hardware management and maintenance 90.49 KB
The command lines and outputs depend on the software version that runs on the device.
The following procedure uses the EWP-WSG1808X-PWR access controller as an example.
Displaying hardware information about the device
Displaying software and hardware version information about the device
Use the display version command to display software and hardware version information about the device. The output includes the following information:
·     Current software version.
·     Current hardware version.
·     Device operating time.
The output depends on the software and hardware version of the device.
<H3C> display version
H3C Comware Software, Version 7.1.064, ESS 5626
Copyright (c) 2004-2023 New H3C Technologies Co., Ltd. All rights reserved.
H3C WSG1808X-PWR uptime is 0 weeks, 0 days, 0 hours, 1 minute
Last reboot reason : Power on
Boot image: flash:/boot.bin
Boot image version: 7.1.064, ESS 5626
  Compiled Sep 18 2023 15:00:00
System image: flash:/system.bin
System image version: 7.1.064, ESS 5626
with 1 ARM 2000MHz Processor
2048M bytes DDR4
3728M bytes EMMC Memory
Hardware Version is Ver.B
Basic Bootrom Version is 1.11
Extend Bootrom Version is 1.11
[Subslot 0]WSG1808X-PWR Hardware Version is Ver.B
Displaying the operational statistics about the device
When you perform routine maintenance or the system fails, you might need to display the operational information of each feature module to locate failures. Typically, you need to run the display commands individually. However, you can use the display diagnostic-information command in any view to display or save the operational statistics of multiple feature modules of the device. This command displays the output of the display clock, display version, display device, and display current-configuration commands.
·     Save the operational statistics for each feature module of the device:
Save or display diagnostic information (Y=save, N=display)? [Y/N]:y
Please input the file name(*.tar.gz)[flash:/diag_H3C_20110101-001758.tar.gz]:
Diagnostic information is outputting to flash:/diag_H3C_20110101-001758.tar.gz.
Please wait...
Save successfully.
To view the contents of the default.diag file, execute the more default.diag command in user view, and then press the Page Up and Page Down keys.
·     Display the operational statistics for each feature module of the device. (Details not shown.)
<H3C> display diagnostic-information
00:18:53 UTC Sat 01/01/2011
H3C WSG1808X-PWR uptime is 0 weeks, 0 days, 0 hours, 19 minutes
2048M bytes DDR4
  ===============display system internal version===============
H3C WSG1808X-PWR V500R001B64D073SP26
Comware V700R001B64D073SP26
  ===============display device verbose===============
Slot No.  Subslot No. Board Type        Status    Max Ports
1         0           WSG1808X-PWR      Normal      10
Slot 1
Status: Normal
Type: WSG1808X-PWR
Hardware: B
Driver: 1.11
Displaying information about the device
Use the display device command to display information about the device.
<H3C> display device
Table4-1 Command output
Board Type
Device type.
Status
Device status:
·     Fault—The device is faulty and cannot start up correctly.
·     Normal—The device is operating correctly.
Max Ports
Maximum number of ports supported.
Displaying electrical label information for the device
An electrical label is a profile of a device. It contains the permanent configuration, including the serial number, manufacturing date, MAC address, and vendor name.
Use the display device manuinfo command to display the electrical label information for the device.
<H3C> display device manuinfo
DEVICE_NAME:WSG1808X-PWR
DEVICE_SERIAL_NUMBER:219801A5NNAAAAA0928
MAC_ADDRESS:54C6-FFC4-DBA0
MANUFACTURING_DATE:2023-01-31
VENDOR_NAME:H3C
Table4-2 Command output
DEVICE_NAME
Device model.
Serial number of the device.
MAC_ADDRESS
MAC address of the device.
MANUFACTURING_DATE
Manufacturing data of the device.
VENDOR_NAME
Vendor name.
Displaying the CPU usage of the device
Use the display cpu-usage command to display the CPU usage statistics for the device.
<H3C> display cpu-usage
Unit CPU usage:
       1% in last 5 seconds
       1% in last 1 minute
       2% in last 5 minutes
Table4-3 Command output
Average CPU usage in the last 5 seconds (after the device boots, the device calculates and records the average CPU usage at the interval of 5 seconds).
1% in last 1 minute
Average CPU usage in the last minute (after the device boots, the device calculates and records the average CPU usage at the interval of 1 minute).
Average CPU usage in the last 5 minutes (after the device boots, the device calculates and records the average CPU usage at the interval of 5 minutes).
Displaying the memory usage of the device
Use the display memory command to display the memory usage statistics for the device.
<H3C>display memory
Memory statistics are measured in KB:
Slot 1:
             Total      Used      Free    Shared   Buffers    Cached   FreeRatio
Mem:       1995208   1057476    937732         0      6176    320952       48.5%
-/+ Buffers/Cache:    730348   1264860
Swap:           0         0         0
Table4-4 Command output
Mem
Memory usage information.
Total
Total size of the physical memory space that can be allocated.
Used
Used physical memory.
Free
Free physical memory.
Shared
Physical memory shared by processes.
Buffers
Physical memory used for buffers.
Cached
Used physical memory for cache.
FreeRatio
Free memory ratio.
–/+ Buffers/Cache
·     -/+ Buffers/Cache:used = Mem:Used – Mem:Buffers – Mem:Cached, which indicates the physical memory used by applications.
·     -/+ Buffers/Cache:free = Mem:Free + Mem:Buffers + Mem:Cached, which indicates the physical memory available for applications.
Swap
Swap memory.
Rebooting the device
To reboot the device, use one of the following methods:
·     Reboot the device at the CLI. You can remotely reboot the device in either of the following ways:
¡     Reboot the device immediately by using the reboot command.
¡     Schedule a reboot to occur at a specific time or date or after a delay by using the schedule reboot command.
·     Power off and power on the device. This method cuts off the power of the device forcibly, which might cause data loss. It is the least-preferred method.
·     Before you reboot the device, perform the following tasks:
¡     Use the save command to save the running configuration. For more information about the save command, see configuration file management commands in the command references.
¡     Use the display startup and display boot-loader commands to verify that you have specified the correct next-startup configuration files and startup software images. If the main startup software image is corrupt or does not exist, a reboot failure will occur. To avoid a reboot failure, use the boot-loader file command to specify a new startup software image. For more information about the display startup and display boot-loader commands, see software upgrade commands in the command references.
·     The device will not reboot if a file is being accessed.
Configuration procedure
Rebooting the device immediately
Remarks
Reboot the device immediately.
reboot [ force ]
Available in user view.
Scheduling a reboot for the device
Remarks
Schedule a reboot.
·     Schedule a reboot to occur at a specific time or date:
schedule reboot at time [ date ]
·     Schedule a reboot to occur after a delay:
schedule reboot delay time
Use either command.
By default, no reboot date or time or reboot delay time is specified.
The most recent configuration takes effect if you execute the scheduler reboot at or scheduler reboot delay command multiple times.
