- 03-Security Command Reference
- 01-Security zone commands
- 02-Security policy commands
- 03-ASPF commands
- 04-Session management commands
- 05-Object group commands
- 06-IP source guard commands
- 07-AAA commands
- 08-User identification commands
- 09-Password control commands
- 10-Portal commands
- 11-MAC authentication commands
- 12-SMS commands
- 13-802.1X commands
- 14-Public key management commands
- 15-PKI commands
- 16-SSH commands
- 17-SSL commands
- 18-Connection limit commands
- 19-Attack detection and prevention commands
- 20-Server connection detection commands
- 21-ARP attack protection commands
- 22-ND attack defense commands
- 23-uRPF commands
- 24-IP-MAC binding commands
- 25-Keychain commands
- 26-MAC learning through a Layer 3 device commands
- 27-APR commands
- 28-IPoE commands
- 29-Crypto engine commands
- 30-Location identification commands
- 31-Terminal identification commands
| 07-AAA commands | 1.49 MB |
authorization-attribute (ISP domain view)
domain-delimiter search-direction
local-server log change-password-prompt
service-type (ISP domain view)
session-time include-idle-time
access-user email authentication
authorization-attribute (local user view/user group view)
description (network access user view)
display local-guest waiting-approval
display local-user access-count
local-guest auto-delete enable
local-user-export class network
local-user-export class network guest
local-user-import class network
local-user-import class network guest
reset local-guest waiting-approval
service-type (local user view)
attribute 182 vendor-id 25506 vlan
attribute convert (RADIUS DAS view)
attribute convert (RADIUS scheme view)
attribute reject (RADIUS DAS view)
attribute reject (RADIUS scheme view)
attribute vendor-id 2011 version
data-flow-format (RADIUS scheme view)
display radius server-load statistics
include-attribute h3c-dhcp-option
primary accounting (RADIUS scheme view)
primary authentication (RADIUS scheme view)
radius authentication-request first
reset radius server-load statistics
secondary accounting (RADIUS scheme view)
secondary authentication (RADIUS scheme view)
timer quiet (RADIUS scheme view)
timer realtime-accounting (RADIUS scheme view)
timer response-timeout (RADIUS scheme view)
user-name-format (RADIUS scheme view)
vpn-instance (RADIUS scheme view)
data-flow-format (HWTACACS scheme view)
primary accounting (HWTACACS scheme view)
primary authentication (HWTACACS scheme view)
secondary accounting (HWTACACS scheme view)
secondary authentication (HWTACACS scheme view)
timer quiet (HWTACACS scheme view)
timer realtime-accounting (HWTACACS scheme view)
timer response-timeout (HWTACACS scheme view)
user-name-format (HWTACACS scheme view)
vpn-instance (HWTACACS scheme view)
ignore search-result-reference
authentication-server (AAA private-protocol scheme view)
display aaa-private-protocol scheme
AAA commands
Non-default vSystems do not support some of the AAA commands. For information about vSystem support for a command, see the usage guidelines on that command. For information about vSystem, see Virtual Technologies Configuration Guide.
General AAA commands
aaa nas-id profile
Use aaa nas-id profile to create a NAS-ID profile and enter its view, or enter the view of an existing NAS-ID profile.
Use undo aaa nas-id profile to delete a NAS-ID profile.
undo aaa nas-id profile profile-name
No NAS-ID profiles exist.
context-admin
profile-name: Specifies the NAS-ID profile name, a case-insensitive string of 1 to 31 characters.
Non-default vSystems do not support this command.
Configure a NAS-ID profile to maintain NAS-ID and VLAN bindings on the device.
During RADIUS authentication, the device uses a NAS-ID to set the NAS-Identifier attribute of RADIUS packets so that the RADIUS server can identify the access location of users.
The device selects the NAS-ID for the NAS-Identifier attribute in the following order:
1. NAS-ID bound with VLANs in a NAS-ID profile.
2. NAS-ID in an ISP domain.
By default, the device uses the device name as the NAS-ID.
# Create a NAS-ID profile named aaa and enter its view.
[Sysname] aaa nas-id profile aaa
[Sysname-nas-id-prof-aaa]
nas-id
nas-id bind vlan
portal nas-id-profile
aaa session-id mode
Use aaa session-id mode to specify the format for attribute Acct-Session-Id.
Use undo aaa session-id mode to restore the default.
aaa session-id mode { common | simplified }
undo session-id mode
The device uses the common mode for attribute Acct-Session-Id.
context-admin
vsys-admin
common: Specifies the common format for attribute Acct-Session-Id. In this format, the Acct-Session-Id attribute is a string with a length of 38 characters. This string contains the prefix (indicating the access type), date and time, sequence number, LIP address of the access node, device ID, and job ID of the access process.
simplified: Specifies the simple format for attribute Acct-Session-Id. In this format, the Acct-Session-Id attribute is a string of 16 characters. This string contains the prefix (indicating the access type), month, sequence number, device ID, and LIP address of the access node.
Configure the format for attribute Acct-Session-Id to meet the requirements of the RADIUS servers.
# Specify the simple format for attribute Acct-Session-Id.
[Sysname] aaa session-id mode simplified
aaa session-limit
Use aaa session-limit to set the maximum number of concurrent users that can log on to the device through the specified method.
Use undo aaa session-limit to restore the default maximum number of concurrent users for the specified login method.
aaa session-limit { ftp | http | https | ssh | telnet } max-sessions
undo aaa session-limit { ftp | http | https | ssh | telnet }
The maximum number of concurrent users is 32 for each user type.
context-admin
ftp: FTP users.
http: HTTP users.
https: HTTPS users.
ssh: SSH users.
telnet: Telnet users.
max-sessions: Specifies the maximum number of concurrent login users. The value range is 1 to 64 for HTTP and HTTPS services, 1 to 32 for SSH service,is 1 to 32 for the Telnet service, and is 1 to 64 for FTP, HTTP, and HTTPS services.
After the maximum number of concurrent login users for a user type exceeds the upper limit, the system denies the subsequent users of this type.
For HTTP and HTTPS services, the number of concurrent users of an application is separately limited. For example, if the maximum number of concurrent HTTP users is 20, a maximum of 20 concurrent users are allowed for each HTTP-based application, such as RESTful, Web, and NETCONF.
# Set the maximum number of concurrent FTP users to 4.
[Sysname] aaa session-limit ftp 4
accounting advpn
Use accounting advpn to specify accounting methods for ADVPN users.
Use undo accounting advpn to restore the default.
accounting advpn { local [ radius-scheme radius-scheme-name ] [ none ] | none | radius-scheme radius-scheme-name [ local ] [ none ] }
The default accounting methods of the ISP domain are used for ADVPN users.
ISP domain view
context-admin
vsys-admin
local: Performs local accounting.
none: Does not perform accounting.
radius-scheme radius-scheme-name: Specifies a RADIUS scheme by its name, a case-insensitive string of 1 to 32 characters.
You can specify one primary accounting method and multiple backup accounting methods.
When the primary method is invalid, the device attempts to use the backup methods in sequence. For example, the accounting advpn radius-scheme radius-scheme-name local none command specifies a primary RADIUS accounting method and two backup methods (local accounting and no accounting). The device performs RADIUS accounting by default and performs local accounting when the RADIUS server is invalid. The device does not perform accounting when both of the previous methods are invalid.
The remote accounting method is invalid in the following situations:
· The specified accounting scheme does not exist.
· Accounting packet sending fails.
· The device does not receive any accounting response packets from an accounting server.
The local accounting method is invalid if the device fails to find the matching local user configuration.
When the primary accounting method is local, the following rules apply to the accounting of a user:
· The device uses the backup accounting methods in sequence only if local accounting is invalid for one of the following reasons:
¡ An exception occurs in the local accounting process.
¡ The user account is not configured on the device or the user is not allowed to use the ADVPN service.
· The device does not turn to the backup accounting methods if local accounting is invalid because of any other reason. Accounting fails for the user.
# In ISP domain test, perform local accounting for ADVPN users.
[Sysname] domain test
[Sysname-isp-test] accounting advpn local
# In ISP domain test, perform RADIUS accounting for ADVPN users based on scheme rd and use local accounting as the backup.
[Sysname-isp-test] accounting advpn radius-scheme rd local
accounting default
local-user
radius scheme
accounting command
Use accounting command to specify the command line accounting method.
Use undo accounting command to restore the default.
accounting command hwtacacs-scheme hwtacacs-scheme-name
The default accounting methods of the ISP domain are used for command line accounting.
ISP domain view
context-admin
vsys-admin
hwtacacs-scheme hwtacacs-scheme-name: Specifies an HWTACACS scheme by its name, a case-insensitive string of 1 to 32 characters.
The command line accounting feature works with the accounting server to record valid commands that have been successfully executed on the device.
· When the command line authorization feature is disabled, the accounting server records all valid commands that have been successfully executed.
· When the command line authorization feature is enabled, the accounting server records only authorized commands that have been successfully executed.
Command line accounting can use only a remote HWTACACS server.
# In ISP domain test, perform command line accounting based on HWTACACS scheme hwtac.
[Sysname-isp-test] accounting command hwtacacs-scheme hwtac
accounting default
command accounting (Fundamentals Command Reference)
hwtacacs scheme
accounting default
Use accounting default to specify default accounting methods for an ISP domain.
Use undo accounting default to restore the default.
accounting default { hwtacacs-scheme hwtacacs-scheme-name [ radius-scheme radius-scheme-name ] [ local ] [ none ] | local [ radius-scheme radius-scheme-name | hwtacacs-scheme hwtacacs-scheme-name ] * [ none ] | none | radius-scheme radius-scheme-name [ hwtacacs-scheme hwtacacs-scheme-name ] [ local ] [ none ] }
The default accounting method of an ISP domain is local.
ISP domain view
context-admin
vsys-admin
The default accounting method is used for all users that support this method and do not have an accounting method configured.
Local accounting is only used for monitoring and controlling the number of local user connections. It does not provide the statistics function that the accounting feature generally provides.
You can specify one primary default accounting method and multiple backup default accounting methods.
When the primary method is invalid, the device attempts to use the backup methods in sequence. For example, the accounting default radius-scheme radius-scheme-name local none command specifies the primary default RADIUS accounting method and two backup methods (local accounting and no accounting). The device performs RADIUS accounting by default and performs local accounting when the RADIUS server is invalid. The device does not perform accounting when both of the previous methods are invalid.
¡ The user account is not configured on the device or the user is not allowed to use the access service.
# In ISP domain test, use RADIUS scheme rd as the primary default accounting method and use local accounting as the backup.
[Sysname-isp-test] accounting default radius-scheme rd local
· hwtacacs scheme
local-user
radius scheme
accounting ipoe
Use accounting ipoe to specify accounting methods for IPoE users.
Use undo accounting ipoe to restore the default.
accounting ipoe { broadcast radius-scheme radius-scheme-name1 radius-scheme radius-scheme-name2 [ local ] [ none ] | local [ radius-scheme radius-scheme-name ] [ none ] | none | radius-scheme radius-scheme-name [ local ] [ none ] }
The default accounting methods of the ISP domain are used for IPoE users.
ISP domain view
context-admin
vsys-admin
broadcast: Broadcasts accounting requests to servers in RADIUS schemes.
radius-scheme radius-scheme-name1: Specifies the primary broadcast RADIUS scheme by its name, a case-insensitive string of 1 to 32 characters.
radius-scheme radius-scheme-name2: Specifies the backup broadcast RADIUS scheme by its name, a case-insensitive string of 1 to 32 characters.
When the primary method is invalid, the device attempts to use the backup methods in sequence. For example, the accounting ipoe radius-scheme radius-scheme-name local none command specifies a primary RADIUS accounting method and two backup methods (local accounting and no accounting). The device performs RADIUS accounting by default and performs local accounting when the RADIUS server is invalid. The device does not perform accounting when both of the previous methods are invalid.
The following guidelines apply to broadcast accounting:
· The device sends accounting requests to the primary accounting servers in the specified broadcast RADIUS schemes at the real-time accounting interval set in the primary broadcast RADIUS scheme. If the primary server is unavailable in a scheme, the device sends accounting requests to the secondary servers of the scheme in the order the servers are configured.
· The accounting result is determined by the primary broadcast RADIUS scheme. The accounting result from the backup scheme is used as reference only. If the primary scheme does not return any result, the device considers the accounting as a failure.
¡ The user account is not configured on the device or the user is not allowed to use the IPoE service.
# In ISP domain test, perform local accounting for IPoE users.
[Sysname-isp-test] accounting ipoe local
# In ISP domain test, perform RADIUS accounting for IPoE users based on scheme rd and use local accounting as the backup.
[Sysname-isp-test] accounting ipoe radius-scheme rd local
# In ISP domain test, broadcast accounting requests of IPoE users to RADIUS servers in schemes rd1 and rd2, and use local accounting as the backup.
[Sysname-isp-test] accounting ipoe broadcast radius-scheme rd1 radius-scheme rd2 local
accounting default
local-user
radius scheme
accounting lan-access
Use accounting lan-access to specify accounting methods for LAN users.
Use undo accounting lan-access to restore the default.
accounting lan-access { broadcast radius-scheme radius-scheme-name1 radius-scheme radius-scheme-name2 [ local ] [ none ] | local [ radius-scheme radius-scheme-name ] [ none ] | none | radius-scheme radius-scheme-name [ local ] [ none ] }
The default accounting methods of the ISP domain are used for LAN users.
ISP domain view
context-admin
vsys-admin
When the primary method is invalid, the device attempts to use the backup methods in sequence. For example, the accounting lan-access radius-scheme radius-scheme-name local none command specifies a primary RADIUS accounting method and two backup methods (local accounting and no accounting). The device performs RADIUS accounting by default and performs local accounting when the RADIUS server is invalid. The device does not perform accounting when both of the previous methods are invalid.
¡ The user account is not configured on the device or the user is not allowed to use the LAN access service.
# In ISP domain test, perform local accounting for LAN users.
[Sysname-isp-test] accounting lan-access local
# In ISP domain test, perform RADIUS accounting for LAN users based on scheme rd and use local accounting as the backup.
[Sysname-isp-test] accounting lan-access radius-scheme rd local
# In ISP domain test, broadcast accounting requests of LAN users to RADIUS servers in schemes rd1 and rd2, and use local accounting as the backup.
[Sysname-isp-test] accounting lan-access broadcast radius-scheme rd1 radius-scheme rd2 local
accounting default
local-user
radius scheme
accounting login
Use accounting login to specify accounting methods for login users.
Use undo accounting login to restore the default.
accounting login { hwtacacs-scheme hwtacacs-scheme-name [ radius-scheme radius-scheme-name ] [ local ] [ none ] | local [ radius-scheme radius-scheme-name | hwtacacs-scheme hwtacacs-scheme-name ] * [ none ] | none | radius-scheme radius-scheme-name [ hwtacacs-scheme hwtacacs-scheme-name ] [ local ] [ none ] }
The default accounting methods of the ISP domain are used for login users.
ISP domain view
context-admin
vsys-admin
Accounting is not supported for FTP, SFTP, and SCP users.
When the primary method is invalid, the device attempts to use the backup methods in sequence. For example, the accounting login radius-scheme radius-scheme-name local none command specifies a primary default RADIUS accounting method and two backup methods (local accounting and no accounting). The device performs RADIUS accounting by default and performs local accounting when the RADIUS server is invalid. The device does not perform accounting when both of the previous methods are invalid.
¡ The user account is not configured on the device.
# In ISP domain test, perform local accounting for login users.
[Sysname-isp-test] accounting login local
# In ISP domain test, perform RADIUS accounting for login users based on scheme rd and use local accounting as the backup.
[Sysname-isp-test] accounting login radius-scheme rd local
accounting default
· hwtacacs scheme
local-user
radius scheme
accounting portal
Use accounting portal to specify accounting methods for portal users.
Use undo accounting portal to restore the default.
accounting portal { broadcast radius-scheme radius-scheme-name1 radius-scheme radius-scheme-name2 [ local ] [ none ] | local [ radius-scheme radius-scheme-name ] [ none ] | none | radius-scheme radius-scheme-name [ local ] [ none ] }
The default accounting methods of the ISP domain are used for portal users.
ISP domain view
context-admin
vsys-admin
When the primary method is invalid, the device attempts to use the backup methods in sequence. For example, the accounting portal radius-scheme radius-scheme-name local none command specifies a primary default RADIUS accounting method and two backup methods (local accounting and no accounting). The device performs RADIUS accounting by default and performs local accounting when the RADIUS server is invalid. The device does not perform accounting when both of the previous methods are invalid.
¡ The user account is not configured on the device or the user is not allowed to use the portal service.
# In ISP domain test, perform local accounting for portal users.
[Sysname-isp-test] accounting portal local
# In ISP domain test, perform RADIUS accounting for portal users based on scheme rd and use local accounting as the backup.
[Sysname-isp-test] accounting portal radius-scheme rd local
# In ISP domain test, broadcast accounting requests of portal users to RADIUS servers in schemes rd1 and rd2, and use local accounting as the backup.
[Sysname-isp-test] accounting portal broadcast radius-scheme rd1 radius-scheme rd2 local
accounting default
local-user
radius scheme
accounting ppp
Use accounting ppp to specify accounting methods for PPP users.
Use undo accounting ppp to restore the default.
accounting ppp { broadcast radius-scheme radius-scheme-name1 radius-scheme radius-scheme-name2 [ hwtacacs-scheme hwtacacs-scheme-name ] [ local ] [ none ] | hwtacacs-scheme hwtacacs-scheme-name [ radius-scheme radius-scheme-name ] [ local ] [ none ] | local [ radius-scheme radius-scheme-name | hwtacacs-scheme hwtacacs-scheme-name ] * [ none ] | none | radius-scheme radius-scheme-name [ hwtacacs-scheme hwtacacs-scheme-name ] [ local ] [ none ] }
undo accounting ppp
The default accounting methods of the ISP domain are used for PPP users.
ISP domain view
context-admin
vsys-admin
When the primary method is invalid, the device attempts to use the backup methods in sequence. For example, the accounting ppp radius-scheme radius-scheme-name local none command specifies a primary RADIUS accounting method and two backup methods (local accounting and no accounting). The device performs RADIUS accounting by default and performs local accounting when the RADIUS server is invalid. The device does not perform accounting when both of the previous methods are invalid.
· The device sends accounting requests to the primary accounting servers in the specified broadcast RADIUS schemes at the real-time accounting interval set in the primary broadcast RADIUS scheme. If the primary server is unavailable for a scheme, the device sends accounting requests to the secondary servers of the scheme in the order the servers are configured.
¡ The user account is not configured on the device or the user is not allowed to use the PPP service.
# In ISP domain test, perform local accounting for PPP users.
[Sysname-isp-test] accounting ppp local
# In ISP domain test, perform RADIUS accounting for PPP users based on scheme rd and use local accounting as the backup.
[Sysname-isp-test] accounting ppp radius-scheme rd local
# In ISP domain test, broadcast accounting requests of PPP users to RADIUS servers in schemes rd1 and rd2, and use local accounting as the backup.
[Sysname-isp-test] accounting ppp broadcast radius-scheme rd1 radius-scheme rd2 local
accounting default
· hwtacacs scheme
local-user
radius scheme
accounting quota-out
Use accounting quota-out to configure access control for users that have used up their data or time accounting quotas.
Use undo accounting quota-out to restore the default.
accounting quota-out { offline | online }
The device logs off users that have used up their accounting quotas.
ISP domain view
context-admin
vsys-admin
offline: Logs off users that have used up their accounting quotas.
online: Allows users that have used up their accounting quotas to stay online.
# In ISP domain test, configure the device to allow users that have used up their accounting quotas to stay online.
[Sysname-isp-test] accounting quota-out online
accounting sslvpn
Use accounting sslvpn to specify accounting methods for SSL VPN users.
Use undo accounting sslvpn to restore the default.
accounting sslvpn { local [ radius-scheme radius-scheme-name ] [ none ] | none | radius-scheme radius-scheme-name [ local ] [ none ] }
The default accounting methods of the ISP domain are used for SSL VPN users.
ISP domain view
context-admin
vsys-admin
When the primary method is invalid, the device attempts to use the backup methods in sequence. For example, the accounting sslvpn radius-scheme radius-scheme-name local none command specifies a primary RADIUS accounting method and two backup methods (local accounting and no accounting). The device performs RADIUS accounting by default and performs local accounting when the RADIUS server is invalid. The device does not perform accounting when both of the previous methods are invalid.
¡ The user account is not configured on the device or the user is not allowed to use the SSL VPN service.
# In ISP domain test, perform local accounting for SSL VPN users.
[Sysname-isp-test] accounting sslvpn local
# In ISP domain test, perform RADIUS accounting for SSL VPN users based on scheme rd and use local accounting as the backup.
[Sysname-isp-test] accounting sslvpn radius-scheme rd local
accounting default
local-user
radius scheme
accounting start-fail
Use accounting start-fail to configure access control for users that encounter accounting-start failures.
Use undo accounting start-fail to restore the default.
accounting start-fail { offline | online }
The device allows users that encounter accounting-start failures to stay online.
ISP domain view
context-admin
vsys-admin
offline: Logs off users that encounter accounting-start failures.
online: Allows users that encounter accounting-start failures to stay online.
The offline keyword takes effect only on portal, IPoE, and PPP users in the current software version.
# In ISP domain test, configure the device to allow users that encounter accounting-start failures to stay online.
[Sysname-isp-test] accounting start-fail online
accounting update-fail
Use accounting update-fail to configure access control for users that have failed all their accounting-update attempts.
Use undo accounting update-fail to restore the default.
accounting update-fail { [ max-times max-times ] offline | online }
The device allows users that have failed all their accounting-update attempts to stay online.
ISP domain view
context-admin
vsys-admin
max-times max-times: Specifies the maximum number of consecutive accounting-update failures allowed by the device for each user. The value range for the times argument is 1 to 255, and the default value is 1.
offline: Logs off users that have failed all their accounting-update attempts.
online: Allows users that have failed all their accounting-update attempts to stay online.
The [ max-times max-times ] offline parameter takes effect only on portal, IPoE, and PPP users in the current software version.
# In ISP domain test, configure the device to allow users that have failed all their accounting-update attempts to stay online.
[Sysname-isp-test] accounting update-fail online
authentication advpn
Use authentication advpn to specify authentication methods for ADVPN users.
Use undo authentication advpn to restore the default.
authentication advpn { local [ radius-scheme radius-scheme-name ] [ none ] | none | radius-scheme radius-scheme-name [ local ] [ none ] }
The default authentication methods of the ISP domain are used for ADVPN users.
ISP domain view
context-admin
vsys-admin
local: Performs local authentication.
none: Does not perform authentication.
You can specify one primary authentication method and multiple backup authentication methods.
When the primary method is invalid, the device attempts to use the backup methods in sequence. For example, the authentication advpn radius-scheme radius-scheme-name local none command specifies a primary RADIUS authentication method and two backup methods (local authentication and no authentication). The device performs RADIUS authentication by default and performs local authentication when the RADIUS server is invalid. The device does not perform authentication when both of the previous methods are invalid.
The remote authentication method is invalid in the following situations:
· The specified authentication scheme does not exist.
· Authentication packet sending fails.
· The device does not receive any authentication response packets from an authentication server.
The local authentication method is invalid if the device fails to find the matching local user configuration.
When the primary authentication method is local, the following rules apply to the authentication of a user:
· The device uses the backup authentication methods in sequence only if local authentication is invalid for one of the following reasons:
¡ An exception occurs in the local authentication process.
· The device does not turn to the backup authentication methods if local authentication is invalid because of any other reason. Authentication fails for the user.
# In ISP domain test, perform local authentication for ADVPN users.
[Sysname-isp-test] authentication advpn local
# In ISP domain test, perform RADIUS authentication for ADVPN users based on scheme rd and use local authentication as the backup.
[Sysname-isp-test] authentication advpn radius-scheme rd local
authentication default
local-user
radius scheme
Use authentication default to specify default authentication methods for an ISP domain.
Use undo authentication default to restore the default.
authentication default { hwtacacs-scheme hwtacacs-scheme-name [ radius-scheme radius-scheme-name ] [ local ] [ none ] | ldap-scheme ldap-scheme-name [ local ] [ none ] | local [ radius-scheme radius-scheme-name | hwtacacs-scheme hwtacacs-scheme-name ] * [ none ] | local [ ldap-scheme ldap-scheme-name ] [ none ] | none | radius-scheme radius-scheme-name [ hwtacacs-scheme hwtacacs-scheme-name ] [ local ] [ none ] }
The default authentication method of an ISP domain is local.
ISP domain view
context-admin
vsys-admin
ldap-scheme ldap-scheme-name: Specifies an LDAP scheme by its name, a case-insensitive string of 1 to 32 characters.
The default authentication method is used for all users that support this method and do not have an authentication method configured.
You can specify one primary default authentication method and multiple backup default authentication methods.
When the primary method is invalid, the device attempts to use the backup methods in sequence. For example, the authentication default radius-scheme radius-scheme-name local none command specifies a primary default RADIUS authentication method and two backup methods (local authentication and no authentication). The device performs RADIUS authentication by default and performs local authentication when the RADIUS server is invalid. The device does not perform authentication when both of the previous methods are invalid.
# In ISP domain test, use RADIUS scheme rd as the primary default authentication method and use local authentication as the backup.
[Sysname-isp-test] authentication default radius-scheme rd local
hwtacacs scheme
ldap scheme
local-user
radius scheme
authentication ike
Use authentication ike to specify extended authentication methods for IKE users.
Use undo authentication ike to restore the default.
authentication ike { aaa-private-protocol-scheme aaa-private-protocol-scheme-name | local [ radius-scheme radius-scheme-name ] [ none ] | none | radius-scheme radius-scheme-name [ local ] [ none ] }
The default authentication methods of the ISP domain are used for IKE extended authentication.
ISP domain view
context-admin
vsys-admin
aaa-private-protocol-scheme aaa-private-protocol-scheme-name: Specifies an AAA private protocol scheme by its name, a case-insensitive string of 1 to 32 characters.
When the primary method is invalid, the device attempts to use the backup methods in sequence. For example, the authentication ike radius-scheme radius-scheme-name local none command specifies a primary RADIUS authentication method and two backup methods (local authentication and no authentication). The device performs RADIUS authentication by default and performs local authentication when the RADIUS server is invalid. The device does not perform authentication when both of the previous methods are invalid.
¡ The user account is not configured on the device or the user is not allowed to use the IKE service.
If you specify an AAA private protocol scheme and a JIT authentication server is specified in the scheme, do not configure authorization methods for IKE extended authentication. In this situation, the authorization methods configured for IKE extended authentication cannot take effect.
# In ISP domain test, configure the device to perform local authentication through IKE extended authentication.
[Sysname-isp-test] authentication ike local
# In ISP domain test, perform IKE extended authentication based on RADIUS scheme rd and use local authentication as the backup.
[Sysname-isp-test] authentication ike radius-scheme rd local
aaa private-protocol scheme
local-user
radius scheme
authentication ipoe
Use authentication ipoe to specify authentication methods for IPoE users.
Use undo authentication ipoe to restore the default.
authentication ipoe { local [ radius-scheme radius-scheme-name ] [ none ] | none | radius-scheme radius-scheme-name [ local ] [ none ] }
The default authentication methods of the ISP domain are used for IPoE users.
ISP domain view
context-admin
vsys-admin
When the primary method is invalid, the device attempts to use the backup methods in sequence. For example, the authentication ipoe radius-scheme radius-scheme-name local none command specifies a primary RADIUS authentication method and two backup methods (local authentication and no authentication). The device performs RADIUS authentication by default and performs local authentication when the RADIUS server is invalid. The device does not perform authentication when both of the previous methods are invalid.
# In ISP domain test, perform local authentication for IPoE users.
[Sysname-isp-test] authentication ipoe local
# In ISP domain test, perform RADIUS authentication for IPoE users based on scheme rd and use local authentication as the backup.
[Sysname-isp-test] authentication ipoe radius-scheme rd local
local-user
radius scheme
authentication lan-access
Use authentication lan-access to specify authentication methods for LAN users.
Use undo authentication lan-access to restore the default.
authentication lan-access { ldap-scheme ldap-scheme-name [ local ] [ none ] | local [ ldap-scheme ldap-scheme-name | radius-scheme radius-scheme-name ] [ none ] | none | radius-scheme radius-scheme-name [ local ] [ none ] }
The default authentication methods of the ISP domain are used for LAN users.
ISP domain view
context-admin
vsys-admin
When the primary method is invalid, the device attempts to use the backup methods in sequence. For example, the authentication lan-access radius-scheme radius-scheme-name local none command specifies a primary RADIUS authentication method and two backup methods (local authentication and no authentication). The device performs RADIUS authentication by default and performs local authentication when the RADIUS server is invalid. The device does not perform authentication when both of the previous methods are invalid.
# In ISP domain test, perform local authentication for LAN users.
[Sysname-isp-test] authentication lan-access local
# In ISP domain test, perform RADIUS authentication for LAN users based on scheme rd and use local authentication as the backup.
[Sysname-isp-test] authentication lan-access radius-scheme rd local
ldap scheme
local-user
radius scheme
authentication login
Use authentication login to specify authentication methods for login users.
Use undo authentication login to restore the default.
authentication login { hwtacacs-scheme hwtacacs-scheme-name [ radius-scheme radius-scheme-name ] [ local ] [ none ] | ldap-scheme ldap-scheme-name [ local ] [ none ] | local [ radius-scheme radius-scheme-name | hwtacacs-scheme hwtacacs-scheme-name ] * [ none ] | local [ ldap-scheme ldap-scheme-name ] [ none ] | none | radius-scheme radius-scheme-name [ hwtacacs-scheme hwtacacs-scheme-name ] [ local ] [ none ] }
The default authentication methods of the ISP domain are used for login users.
ISP domain view
context-admin
vsys-admin
When the primary method is invalid, the device attempts to use the backup methods in sequence. For example, the authentication login radius-scheme radius-scheme-name local none command specifies the default primary RADIUS authentication method and two backup methods (local authentication and no authentication). The device performs RADIUS authentication by default and performs local authentication when the RADIUS server is invalid. The device does not perform authentication when both of the previous methods are invalid.
¡ The user account is not configured on the device or the user is not allowed to use the service for accessing the device.
# In ISP domain test, perform local authentication for login users.
[Sysname-isp-test] authentication login local
# In ISP domain test, perform RADIUS authentication for login users based on scheme rd and use local authentication as the backup.
[Sysname-isp-test] authentication login radius-scheme rd local
hwtacacs scheme
ldap scheme
local-user
radius scheme
authentication portal
Use authentication portal to specify authentication methods for portal users.
Use undo authentication portal to restore the default.
authentication portal { ldap-scheme ldap-scheme-name [ local ] [ none ] | local [ ldap-scheme ldap-scheme-name | radius-scheme radius-scheme-name ] [ none ] | none | radius-scheme radius-scheme-name [ local ] [ none ] }
The default authentication methods of the ISP domain are used for portal users.
ISP domain view
context-admin
vsys-admin
When the primary method is invalid, the device attempts to use the backup methods in sequence. For example, the authentication portal radius-scheme radius-scheme-name local none command specifies the default primary RADIUS authentication method and two backup methods (local authentication and no authentication). The device performs RADIUS authentication by default and performs local authentication when the RADIUS server is invalid. The device does not perform authentication when both of the previous methods are invalid.
# In ISP domain test, perform local authentication for portal users.
[Sysname-isp-test] authentication portal local
# In ISP domain test, perform RADIUS authentication for portal users based on scheme rd and use local authentication as the backup.
[Sysname-isp-test] authentication portal radius-scheme rd local
ldap scheme
local-user
radius scheme
authentication ppp
Use authentication ppp to specify authentication methods for PPP users.
Use undo authentication ppp to restore the default.
authentication ppp { hwtacacs-scheme hwtacacs-scheme-name [ radius-scheme radius-scheme-name ] [ local ] [ none ] | ldap-scheme ldap-scheme-name [ local ] [ none ] | local [ radius-scheme radius-scheme-name | hwtacacs-scheme hwtacacs-scheme-name ] * [ none ] | local [ ldap-scheme ldap-scheme-name ] [ none ] | none | radius-scheme radius-scheme-name [ hwtacacs-scheme hwtacacs-scheme-name ] [ local ] [ none ] }
The default authentication methods of the ISP domain are used for PPP users.
ISP domain view
context-admin
vsys-admin
When the primary method is invalid, the device attempts to use the backup methods in sequence. For example, the authentication ppp radius-scheme radius-scheme-name local none command specifies a primary RADIUS authentication method and two backup methods (local authentication and no authentication). The device performs RADIUS authentication by default and performs local authentication when the RADIUS server is invalid. The device does not perform authentication when both of the previous methods are invalid.
# In ISP domain test, perform local authentication for PPP users.
[Sysname-isp-test] authentication ppp local
# In ISP domain test, perform RADIUS authentication for PPP users based on scheme rd and use local authentication as the backup.
[Sysname-isp-test] authentication ppp radius-scheme rd local
hwtacacs scheme
ldap scheme
local-user
radius scheme
authentication sslvpn
Use authentication sslvpn to specify authentication methods for SSL VPN users.
Use undo authentication sslvpn to restore the default.
authentication sslvpn { ldap-scheme ldap-scheme-name [ local ] [ none ] | local [ ldap-scheme ldap-scheme-name | radius-scheme radius-scheme-name ] [ none ] | none | radius-scheme radius-scheme-name [ local ] [ none ] }
The default authentication methods of the ISP domain are used for SSL VPN users.
ISP domain view
context-admin
vsys-admin
When the primary method is invalid, the device attempts to use the backup methods in sequence. For example, the authentication sslvpn radius-scheme radius-scheme-name local none command specifies a primary RADIUS authentication method and two backup methods (local authentication and no authentication). The device performs RADIUS authentication by default and performs local authentication when the RADIUS server is invalid. The device does not perform authentication when both of the previous methods are invalid.
If you specify multiple authentication methods for SSL VPN users in an ISP domain, the device does not support the online user password change feature for the SSL VPN users.
# In ISP domain test, perform local authentication for SSL VPN users.
[Sysname-isp-test] authentication sslvpn local
# In ISP domain test, perform LDAP authentication for SSL VPN users based on scheme ldp and use local authentication as the backup.
[Sysname-isp-test] authentication sslvpn ldap-scheme ldp local
ldap scheme
local-user
radius scheme
authentication super
Use authentication super to specify a method for user role authentication.
Use undo authentication super to restore the default.
authentication super { hwtacacs-scheme hwtacacs-scheme-name | radius-scheme radius-scheme-name } *
The default authentication methods of the ISP domain are used for user role authentication.
ISP domain view
context-admin
vsys-admin
To enable a user to obtain another user role without reconnecting to the device, you must configure user role authentication. The device supports local and remote methods for user role authentication. For more information about user role authentication, see RBAC configuration in Fundamentals Configuration Guide.
You can specify one authentication method and one backup authentication method to use in case that the previous authentication method is invalid.
# In ISP domain test, perform user role authentication based on HWTACACS scheme tac.
[Sysname] super authentication-mode scheme
[Sysname-isp-test] authentication super hwtacacs-scheme tac
hwtacacs scheme
radius scheme
authorization advpn
Use authorization advpn to specify authorization methods for ADVPN users.
Use undo authorization advpn to restore the default.
authorization advpn { local [ radius-scheme radius-scheme-name ] [ none ] | none | radius-scheme radius-scheme-name [ local ] [ none ] }
The default authorization methods of the ISP domain are used for ADVPN users.
ISP domain view
context-admin
vsys-admin
local: Performs local authorization.
none: Does not perform authorization.
The RADIUS authorization configuration takes effect only when authentication and authorization methods of the ISP domain use the same RADIUS scheme.
You can specify one primary authorization method and multiple backup authorization methods.
When the primary method is invalid, the device attempts to use the backup methods in sequence. For example, the authorization advpn radius-scheme radius-scheme-name local none command specifies a primary RADIUS authorization method and two backup methods (local authorization and no authorization). The device performs RADIUS authorization by default and performs local authorization when the RADIUS server is invalid. The device does not perform authorization when both of the previous methods are invalid.
The remote authorization method is invalid in the following situations:
· The specified authorization scheme does not exist.
· Authorization packet sending fails.
· The device does not receive any authorization response packets from an authorization server.
The local authorization method is invalid if the device fails to find the matching local user configuration.
When the primary authorization method is local, the following rules apply to the authorization of a user:
· The device uses the backup authorization methods in sequence only if local authorization is invalid for one of the following reasons:
¡ An exception occurs in the local authorization process.
· The device does not turn to the backup authorization methods if local authorization is invalid because of any other reason. Authorization fails for the user.
# In ISP domain test, perform local authorization for ADVPN users.
[Sysname-isp-test] authorization advpn local
# In ISP domain test, perform RADIUS authorization for ADVPN users based on scheme rd and use local authorization as the backup.
[Sysname-isp-test] authorization advpn radius-scheme rd local
authorization default
local-user
radius scheme
authorization command
Use authorization command to specify command authorization methods.
Use undo authorization command to restore the default.
authorization command { hwtacacs-scheme hwtacacs-scheme-name [ local ] [ none ] | local [ none ] | none }
The default authorization methods of the ISP domain are used for command authorization.
ISP domain view
context-admin
vsys-admin
none: Does not perform authorization. The authorization server does not verify whether the entered commands are permitted by the user role. The commands are executed successfully if the user role has permission to the commands.
Command authorization restricts login users to execute only authorized commands by employing an authorization server to verify whether each entered command is permitted.
When local command authorization is configured, the device compares each entered command with the user's configuration on the device. The command is executed only when it is permitted by the user's authorized user roles.
The commands that can be executed are controlled by both the access permission of user roles and command authorization of the authorization server. Access permission only controls whether the authorized user roles have access to the entered commands, but it does not control whether the user roles have obtained authorization to these commands. If a command is permitted by the access permission but denied by command authorization, this command cannot be executed.
You can specify one primary command authorization method and multiple backup command authorization methods.
When the default authorization method is invalid, the device attempts to use the backup authorization methods in sequence. For example, the authorization command hwtacacs-scheme hwtacacs-scheme-name local none command specifies the default HWTACACS authorization method and two backup methods (local authorization and no authorization). The device performs HWTACACS authorization by default and performs local authorization when the HWTACACS server is invalid. The device does not perform command authorization when both of the previous methods are invalid.
# In ISP domain test, configure the device to perform local command authorization.
[Sysname-isp-test] authorization command local
# In ISP domain test, perform command authorization based on HWTACACS scheme hwtac and use local authorization as the backup.
[Sysname-isp-test] authorization command hwtacacs-scheme hwtac local
command authorization (Fundamentals Command Reference)
hwtacacs scheme
local-user
Use authorization default to specify default authorization methods for an ISP domain.
Use undo authorization default to restore the default.
authorization default { hwtacacs-scheme hwtacacs-scheme-name [ radius-scheme radius-scheme-name ] [ local ] [ none ] | local [ radius-scheme radius-scheme-name | hwtacacs-scheme hwtacacs-scheme-name ] * [ none ] | none | radius-scheme radius-scheme-name [ hwtacacs-scheme hwtacacs-scheme-name ] [ local ] [ none ] }
The default authorization method of an ISP domain is local.
ISP domain view
context-admin
vsys-admin
none: Does not perform authorization. The following default authorization information applies after users pass authentication:
· Login users obtain the level-0 user role. Login users include the Telnet, FTP, SFTP, SCP, and terminal users. Terminal users can access the device through the console port. For more information about the level-0 user role, see RBAC configuration in Fundamentals Configuration Guide.
· The working directory for FTP, SFTP, and SCP login users is the root directory of the NAS. However, the users do not have permission to access the root directory.
· Non-login users can access the network.
The default authorization method is used for all users that support this method and do not have an authorization method configured.
The RADIUS authorization configuration takes effect only when the authentication method and authorization method of the ISP domain use the same RADIUS scheme.
When the default authorization method is invalid, the device attempts to use the backup authorization methods in sequence. For example, the authorization default radius-scheme radius-scheme-name local none command specifies the default RADIUS authorization method and two backup methods (local authorization and no authorization). The device performs RADIUS authorization by default and performs local authorization when the RADIUS server is invalid. The device does not perform authorization when both of the previous methods are invalid.
# In ISP domain test, use RADIUS scheme rd as the primary default authorization method and use local authorization as the backup.
[Sysname-isp-test] authorization default radius-scheme rd local
hwtacacs scheme
local-user
radius scheme
authorization ike
Use authorization ike to specify authorization methods for IKE extended authentication.
Use undo authorization ike to restore the default.
authorization ike { local [ radius-scheme radius-scheme-name ] [ none ] | none | radius-scheme radius-scheme-name [ local ] [ none ] }
The default authorization methods of the ISP domain are used for IKE extended authentication.
ISP domain view
context-admin
vsys-admin
When the default authorization method is invalid, the device attempts to use the backup authorization methods in sequence. For example, the authorization ike radius-scheme radius-scheme-name local none command specifies the default RADIUS authorization method and two backup methods (local authorization and no authorization). The device performs RADIUS authorization by default and performs local authorization when the RADIUS server is invalid. The device does not perform authorization when both of the previous methods are invalid.
# In ISP domain test, perform local authorization for IKE extended authentication.
[Sysname-isp-test] authorization ike local
local-user
authorization ipoe
Use authorization ipoe to specify authorization methods for IPoE users.
Use undo authorization ipoe to restore the default.
authorization ipoe { local [ radius-scheme radius-scheme-name ] [ none ] | none | radius-scheme radius-scheme-name [ local ] [ none ] }
The default authorization methods of the ISP domain are used for IPoE users.
ISP domain view
context-admin
vsys-admin
When the primary method is invalid, the device attempts to use the backup methods in sequence. For example, the authorization ipoe radius-scheme radius-scheme-name local none command specifies a primary RADIUS authorization method and two backup methods (local authorization and no authorization). The device performs RADIUS authorization by default and performs local authorization when the RADIUS server is invalid. The device does not perform authorization when both of the previous methods are invalid.
# In ISP domain test, perform local authorization for IPoE users.
[Sysname-isp-test] authorization ipoe local
# In ISP domain test, perform RADIUS authorization for IPoE users based on scheme rd and use local authorization as the backup.
[Sysname-isp-test] authorization ipoe radius-scheme rd local
local-user
radius scheme
authorization lan-access
Use authorization lan-access to specify authorization methods for LAN users.
Use undo authorization lan-access to restore the default.
authorization lan-access { local [ radius-scheme radius-scheme-name ] [ none ] | none | radius-scheme radius-scheme-name [ local ] [ none ] }
The default authorization methods of the ISP domain are used for LAN users.
ISP domain view
context-admin
vsys-admin
none: Does not perform authorization. An authenticated LAN user directly accesses the network.
When the primary method is invalid, the device attempts to use the backup methods in sequence. For example, the authorization lan-access radius-scheme radius-scheme-name local none command specifies a primary RADIUS authorization method and two backup methods (local authorization and no authorization). The device performs RADIUS authorization by default and performs local authorization when the RADIUS server is invalid. The device does not perform authorization when both of the previous methods are invalid.
# In ISP domain test, perform local authorization for LAN users.
[Sysname-isp-test] authorization lan-access local
# In ISP domain test, perform RADIUS authorization for LAN users based on scheme rd and use local authorization as the backup.
[Sysname-isp-test] authorization lan-access radius-scheme rd local
local-user
radius scheme
authorization login
Use authorization login to specify authorization methods for login users.
Use undo authorization login to restore the default.
authorization login { hwtacacs-scheme hwtacacs-scheme-name [ radius-scheme radius-scheme-name ] [ local ] [ none ] | local [ radius-scheme radius-scheme-name | hwtacacs-scheme hwtacacs-scheme-name ] * [ none ] | none | radius-scheme radius-scheme-name [ hwtacacs-scheme hwtacacs-scheme-name ] [ local ] [ none ] }
The default authorization methods of the ISP domain are used for login users.
ISP domain view
context-admin
vsys-admin
When the default authorization method is invalid, the device attempts to use the backup authorization methods in sequence. For example, the authorization login radius-scheme radius-scheme-name local none command specifies the default RADIUS authorization method and two backup methods (local authorization and no authorization). The device performs RADIUS authorization by default and performs local authorization when the RADIUS server is invalid. The device does not perform authorization when both of the previous methods are invalid.
# In ISP domain test, perform local authorization for login users.
[Sysname-isp-test] authorization login local
# In ISP domain test, perform RADIUS authorization for login users based on scheme rd and use local authorization as the backup.
[Sysname-isp-test] authorization login radius-scheme rd local
hwtacacs scheme
local-user
radius scheme
authorization portal
Use authorization portal to specify authorization methods for portal users.
Use undo authorization portal to restore the default.
authorization portal { local [ radius-scheme radius-scheme-name ] [ none ] | none | radius-scheme radius-scheme-name [ local ] [ none ] }
The default authorization methods of the ISP domain are used for portal users.
ISP domain view
context-admin
vsys-admin
none: Does not perform authorization. An authenticated portal user directly accesses the network.
When the default authorization method is invalid, the device attempts to use the backup authorization methods in sequence. For example, the authorization portal radius-scheme radius-scheme-name local none command specifies the default RADIUS authorization method and two backup methods (local authorization and no authorization). The device performs RADIUS authorization by default and performs local authorization when the RADIUS server is invalid. The device does not perform authorization when both of the previous methods are invalid.
# In ISP domain test, perform local authorization for portal users.
[Sysname-isp-test] authorization portal local
# In ISP domain test, perform RADIUS authorization for portal users based on scheme rd and use local authorization as the backup.
[Sysname-isp-test] authorization portal radius-scheme rd local
local-user
radius scheme
authorization ppp
Use authorization ppp to specify authorization methods for PPP users.
Use undo authorization ppp to restore the default.
authorization ppp { hwtacacs-scheme hwtacacs-scheme-name [ radius-scheme radius-scheme-name ] [ local ] [ none ] | ldap-scheme ldap-scheme-name [ local ] [ none ] | local [ radius-scheme radius-scheme-name | hwtacacs-scheme hwtacacs-scheme-name ] * [ none ] | local [ ldap-scheme ldap-scheme-name ] [ none ] | none | radius-scheme radius-scheme-name [ hwtacacs-scheme hwtacacs-scheme-name ] [ local ] [ none ] }
The default authorization methods of the ISP domain are used for PPP users.
ISP domain view
context-admin
vsys-admin
When the primary method is invalid, the device attempts to use the backup methods in sequence. For example, the authorization ppp radius-scheme radius-scheme-name local none command specifies a primary RADIUS authorization method and two backup methods (local authorization and no authorization). The device performs RADIUS authorization by default and performs local authorization when the RADIUS server is invalid. The device does not perform authorization when both of the previous methods are invalid.
# In ISP domain test, perform local authorization for PPP users.
[Sysname-isp-test] authorization ppp local
# In ISP domain test, perform RADIUS authorization for PPP users based on scheme rd and use local authorization as the backup.
[Sysname-isp-test] authorization ppp radius-scheme rd local
hwtacacs scheme
ldap scheme
local-user
radius scheme
authorization sslvpn
Use authorization sslvpn to specify authorization methods for SSL VPN users.
Use undo authorization sslvpn to restore the default.
authorization sslvpn { ldap-scheme ldap-scheme-name [ local ] [ none ] | local [ ldap-scheme ldap-scheme-name | radius-scheme radius-scheme-name ] [ none ] | none | radius-scheme radius-scheme-name [ local ] [ none ] }
The default authorization methods of the ISP domain are used for SSL VPN users.
ISP domain view
context-admin
vsys-admin
none: Does not perform authorization. Authenticated SSL VPN users can access the network directly.
When the primary method is invalid, the device attempts to use the backup methods in sequence. For example, the authorization sslvpn radius-scheme radius-scheme-name local none command specifies a primary RADIUS authorization method and two backup methods (local authorization and no authorization). The device performs RADIUS authorization by default and performs local authorization when the RADIUS server is invalid. The device does not perform authorization when both of the previous methods are invalid.
# In ISP domain test, perform local authorization for SSL VPN users.
[Sysname-isp-test] authorization sslvpn local
# In ISP domain test, perform LDAP authorization for SSL VPN users based on scheme ldp and use local authorization as the backup.
[Sysname-isp-test] authorization sslvpn ldap-scheme ldp local
ldap scheme
local-user
radius scheme
authorization-attribute (ISP domain view)
Use authorization-attribute to configure authorization attributes for users in an ISP domain.
Use undo authorization-attribute to restore the default of an authorization attribute.
authorization-attribute { acl acl-number | car inbound cir committed-information-rate [ pir peak-information-rate ] outbound cir committed-information-rate [ pir peak-information-rate ] | idle-cut minutes [ flow ] | igmp max-access-number max-access-number | ip-pool ipv4-pool-name | ipv6-pool ipv6-pool-name | ipv6-prefix ipv6-prefix prefix-length | { primary-dns | secondary-dns } { ip ipv4-address | ipv6 ipv6-address } | session-timeout minutes | url url-string | user-group user-group-name | vpn-instance vpn-instance-name }
undo authorization-attribute { acl | car | idle-cut | igmp | ip-pool | ipv6-pool | ipv6-prefix | primary-dns | secondary-dns | session-timeout | url | user-group | vpn-instance }
The idle cut feature is disabled.
An IPv4 user can concurrently join a maximum of four IGMP multicast groups.
An IPv6 user can concurrently join a maximum of four MLD multicast groups.
No other authorization attributes exist.
ISP domain view
context-admin
vsys-admin
acl acl-number: Specifies an ACL to filter traffic for users. The value range for the acl-number argument is is 2000 to 4999. This option is applicable only to portal and LAN users. The device processes the traffic that matches the rules in the authorization ACL based on the permit or deny statement in the rules.
car: Specifies a CAR action for users. Typically, the attribute applies to authenticated users. If you configure the attribute in a portal preauthentication domain, the CAR action applies before authentication. This keyword is applicable only to IPoE, portal, and PPP users.
inbound: Specifies the upload rate of users.
outbound: Specifies the download rate of users.
cir committed-information-rate: Specifies the committed information rate in kbps. The value range for the committed-information-rate argument is 8 to 10000000.
pir peak-information-rate: Specifies the peak information rate in kbps. The peak information rate cannot be smaller than the committed information rate. If you do not specify this option, the CAR action does not restrict users by peak information rate. The value range for the peak-information-rate argument is 8 to 10000000.
idle-cut minutes: Specifies an idle timeout period in minutes. The value range for the minutes argument is 1 to 129600. This option is applicable only to IPoE, portal, and PPP users.
flow: Specifies the minimum traffic that must be generated in the idle timeout period in bytes. The value range is 1 to 10240000, and the default value is 10240.
igmp max-access-number max-access-number: Specifies the maximum number of IGMP groups that an IPv4 user can join concurrently. The value range for the max-access-number argument is 1 to 64. This option is applicable only to IPoE, portal, and PPP users.
ip-pool ipv4-pool-name: Specifies an IPv4 address pool for users. The ipv4-pool-name argument is a case-insensitive string of 1 to 63 characters. This option is applicable only to PPP, IKE, IPoE, and portal users.
ipv6-pool ipv6-pool-name: Specifies an IPv6 address pool for users. The ipv6-pool-name argument is a case-insensitive string of 1 to 63 characters. This option is applicable only to IPoE, portal, and PPP users.
ipv6-prefix ipv6-prefix prefix-length: Specifies an IPv6 prefix for users. The value range for the prefix-length argument is 1 to 128. The IPv6 prefix cannot be ::/128, ::1/128, or an IPv6 multicast prefix. This option is applicable only to IPoE and PPP users.
primary-dns ip ipv4-address: Specifies the IPv4 address of the primary DNS server for users. This option is applicable only to IPoE and PPP users.
primary-dns ipv6 ipv6-address: Specifies the IPv6 address of the primary DNS server for users. This option is applicable only to IPoE and PPP users.
secondary-dns ip ipv4-address: Specifies the IPv4 address of the secondary DNS server for users. This option is applicable only to IPoE and PPP users.
secondary-dns ipv6 ipv6-address: Specifies the IPv6 address of the secondary DNS server for users. This option is applicable only to IPoE and PPP users.
session-timeout minutes: Specifies the session timeout timer for users, in minutes. The value range for the minutes argument is 1 to 4294967295. The device logs off a user when the user's session timeout timer expires. This option is applicable only to PPP, portal, IPoE, and LAN users.
url url-string: Specifies a redirect URL for users. The url-string argument is a case-sensitive string of 1 to 255 characters. The URL must start with http:// or https://. You can configure the redirect URL attribute to push advertisements or notifications to users after the users pass authentication or push bill overdue notifications to users. This option is applicable only to PPP users. For IPoE users, you must specify a URL with port number 80 or 443.
user-group user-group-name: Specifies a user group for users. The user-group-name argument is a case-insensitive string of 1 to 32 characters. Authenticated users obtain all attributes of the user group.
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN instance to which the users belong. The vpn-instance-name argument is a case-sensitive string of 1 to 31 characters. When a user passes authentication, it has permission to access the network resources in the specified VPN. This option is applicable only to PPP and IPoE users.
When the idle cut feature is configured, the device periodically detects the traffic of each online user. The device logs out users that do not meet the minimum traffic requirement in the idle timeout period. When the idle cut feature is disabled on the device, the idle cut feature of the server takes effect. The server considers a user idle if the user's traffic is less than 10240 bytes in a configurable idle timeout period.
If the server or NAS does not authorize a type of attribute to an authenticated user, the device authorizes the attribute in the ISP domain to the user.
You can configure multiple authorization attributes for users in an ISP domain. If you execute the command multiple times with the same attribute specified, the most recent configuration takes effect.
# Specify user group abc as the authorization user group for users in ISP domain test.
[Sysname-isp-test] authorization-attribute user-group abc
display domain
basic-service-ip-type
Use basic-service-ip-type to specify the types of IP addresses that L2TP users must rely on to use the basic services.
Use undo basic-service-ip-type to restore the default.
basic-service-ip-type { ipv4 | ipv6 | ipv6-pd } *
L2TP users do not rely on any types of IP addresses to use the basic services.
ISP domain view
context-admin
vsys-admin
ipv4: Specifies the IPv4 address type.
ipv6: Specifies the IPv6 address type.
ipv6-pd: Specifies the IPv6-PD address type. This type of IPv6 addresses are generated based on the DHCPv6 server-assigned prefix.
This command takes effect only when the device acts as an L2TP LNS and only on L2TP users.
A user might request multiple services of different IP address types. By default, the device logs off the user if the user does not obtain an IP address. This command enables the device to allow the user to come online if the user has obtained IP addresses of all the specified types for the basic services.
The device does not allow a user to come online if the user does not obtain IP addresses of all the specified types for the basic services. For example, if you execute the basic-service-ip-type ipv6 command, the device does not allow a user to come online if the user does not obtain an IPv6 address.
If you specify both the ipv6 and ipv6-pd keywords, the device does not allow a user that fails IPv6 address negotiation or PD negotiation to come online.
# In ISP domain test, specify L2TP users to rely on IPv4 addresses to use the basic services.
[Sysname] domain test
[Sysname-isp-test] basic-service-ip-type ipv4
dhcpv6-follow-ipv6cp
Use dhcpv6-follow-ipv6cp to set the IPv6 address wait timer for L2TP users.
Use undo dhcpv6-follow-ipv6cp to restore the default.
dhcpv6-follow-ipv6cp timeout delay-time
The IPv6 address wait timer for L2TP users is 60 seconds.
ISP domain view
context-admin
vsys-admin
timeout delay-time: Sets the IPv6 address wait timer, in the range of 30 to 120 seconds.
The IPv6 address wait timer defines the maximum amount of time that a user can wait before the device determines that the user fails to obtain an IPv6 address or PD prefix.
The device starts an IPv6 address wait timer for a user after it finishes IPv6CP negotiation with the user. If the user's basic service relies on an IPv6 address or PD prefix but it fails to obtain any IPv6 address or PD prefix when the timer expires, the user cannot come online.
As a best practice, increase the IPv6 address wait timer in the following situations:
· The network communication is unstable.
· The device uses DHCPv6 to assign IPv6 addresses to users.
· The ISP domain serves a large number of users.
# In ISP domain test, set the IPv6 address wait timer to 90 seconds for L2TP users.
[Sysname-isp-test] dhcpv6-follow-ipv6cp timeout 90
display domain
Use display domain to display ISP domain configuration.
display domain [ isp-name ]
context-admin
context-operator
vsys-admin
vsys-operator
isp-name: Specifies an ISP domain by its name, a case-insensitive string of 1 to 255 characters. If you do not specify an ISP domain, this command displays the configuration of all ISP domains.
# Display the configuration of all ISP domains.
<Sysname> display domain
Total 2 domains
Domain: system
State: Active
Default authentication scheme: Local
Default authorization scheme: Local
Default accounting scheme: Local
Accounting start failure action: Online
Accounting update failure action: Online
Accounting quota out action: Offline
Service type: HSI
Session time: Exclude idle time
NAS-ID: N/A
DHCPv6-follow-IPv6CP timeout: 60 seconds
Authorization attributes:
Idle cut: Disabled
Session timeout: Disabled
IGMP access limit: 4
MLD access limit: 4
Domain: dm
State: Active
Login authentication scheme: RADIUS=rad
Login authorization scheme: HWTACACS=hw
Super authentication scheme: RADIUS=rad
Command authorization scheme: HWTACACS=hw
LAN access authentication scheme: RADIUS=r4
Default authentication scheme: RADIUS=rad, Local, None
Default accounting scheme: None
Service type: HSI
Session time: Include idle time
User address type: ipv4
NAS-ID: test
Idle cut : Enabled
Idle timeout: 2 minutes
Flow: 10240 bytes
Session timeout: 34 minutes
IP pool: appy
Inbound CAR: CIR 64000 bps PIR 640000 bps
Outbound CAR: CIR 64000 bps PIR 640000 bps
ACL number: 3000
User group: ugg
IPv6 prefix: 1::1/34
IPv6 pool: ipv6pool
Primary DNS server: 6.6.6.6
Secondary DNS server: 3.6.2.3
URL: http://test
VPN instance: vpn1
MLD access limit: 4
Default domain name: system
Domain |
ISP domain name. |
State |
Status of the ISP domain. |
Default authentication scheme |
Default authentication methods. |
Default authorization scheme |
Default authorization methods. |
Default accounting scheme |
Default accounting methods. |
ADVPN authentication scheme |
Authentication methods for ADVPN users. |
ADVPN authorization scheme |
Authorization methods for ADVPN users. |
ADVPN accounting scheme |
Accounting methods for ADVPN users. |
Login authentication scheme |
Authentication methods for login users. |
Login authorization scheme |
Authorization methods for login users. |
Login accounting scheme |
Accounting methods for login users. |
Super authentication scheme |
Authentication methods for obtaining another user role without reconnecting to the device. |
PPP authentication scheme |
Authentication methods for PPP users. |
PPP authorization scheme |
Authorization methods for PPP users. |
PPP accounting scheme |
Accounting methods for PPP users. |
Command authorization scheme |
Command line authorization methods. |
Command accounting scheme |
Command line accounting method. |
LAN access authentication scheme |
Authentication methods for LAN users. |
LAN access authorization scheme |
Authorization methods for LAN users. |
LAN access accounting scheme |
Accounting methods for LAN users. |
Portal authentication scheme |
Authentication methods for portal users. |
Portal authorization scheme |
Authorization methods for portal users. |
Portal accounting scheme |
Accounting methods for portal users. |
IKE authentication scheme |
IKE extended authentication methods. |
IKE authorization scheme |
Authorization methods for IKE extended authentication. |
IPoE authentication scheme |
Authentication methods for IPoE users. |
IPoE authorization scheme |
Authorization methods for IPoE users. |
IPoE accounting scheme |
Accounting methods for IPoE users. |
SSL VPN authentication scheme |
Authentication methods for SSL VPN users. |
SSL VPN authorization scheme |
Authorization methods for SSL VPN users. |
SSL VPN accounting scheme |
Accounting methods for SSL VPN users. |
RADIUS |
RADIUS scheme. |
HWTACACS |
HWTACACS scheme. |
LDAP |
LDAP scheme. |
Local |
Local scheme. |
None |
No authentication, no authorization, or no accounting. |
Accounting start failure action |
Access control for users that encounter accounting-start failures: · Online—Allows the users to stay online. · Offline—Logs off the users. |
Accounting update failure max-times |
Maximum number of consecutive accounting-update failures allowed by the device for each user in the domain. |
Accounting update failure action |
Access control for users that have failed all their accounting-update attempts: · Online—Allows the users to stay online. · Offline—Logs off the users. |
Accounting quota out action |
Access control for users that have used up their accounting quotas: · Online—Allows the users to stay online. · Offline—Logs off the users. |
Service type |
Service type of the ISP domain, including HSI, STB, and VoIP. |
Session time |
Online duration sent to the server for users that went offline due to connection failure or malfunction: · Include idle time—The online duration includes the idle timeout period. · Exclude idle time—The online duration does not include the idle timeout period. |
User address type |
Type of IP addresses for users in the ISP domain. This field is not available if no user address type is specified in the ISP domain. |
NAS-ID |
NAS-ID of the device. This field displays N/A if no NAS-ID is set in the ISP domain. |
User basic service IP type |
Types of IP addresses that PPPoE and L2TP users rely on to use the basic services: · IPv4. · IPv6. · IPv6-PD. |
DHCPv6-follow-IPv6CP timeout |
IPv6 address wait timer (in seconds) that starts after IPv6CP negotiation for PPPoE and L2TP users. |
Authorization attributes |
Authorization attributes for users in the ISP domain. |
Idle cut |
Idle cut feature status: · Enabled—The feature is enabled. The device logs off users that do not meet the minimum traffic requirements in an idle timeout period. · Disabled—The feature is disabled. It is the default idle cut state. |
Idle timeout |
Idle timeout period, in minutes. |
Flow |
Minimum traffic that a login user must generate in an idle timeout period, in bytes. |
Session timeout |
Session timeout time for users in the ISP domain, in minutes. |
IP pool |
Name of the authorization IPv4 address pool. |
Inbound CAR |
Authorization inbound CAR: · CIR—Committed information rate in bps. · PIR—Peak information rate in bps. |
Outbound CAR |
Authorization outbound CAR: · CIR—Committed information rate in bps. · PIR—Peak information rate in bps. |
ACL number |
Authorization ACL for users. |
User group |
Authorization user group for users. |
IPv6 prefix |
Authorization IPv6 prefix for users. |
IPv6 pool |
Name of the authorization IPv6 address pool for users. |
Primary DNS server |
IPv4 address of the authorization primary DNS server for users. |
Secondary DNS server |
IPv4 address of the authorization secondary DNS server for users. |
Primary DNSV6 server |
IPv6 address of the authorization primary DNS server for users. |
Secondary DNSV6 server |
IPv6 address of the authorization secondary DNS server for users. |
URL |
Authorization redirect URL for users. |
VPN instance |
Name of the authorization VPN instance for users. |
IGMP access limit |
Maximum number of IGMP groups that an IPv4 user is authorized to join concurrently. |
MLD access limit |
This field is not supported in the current software version. Maximum number of MLD groups that an IPv6 user is authorized to join concurrently. |
domain
Use domain to create an ISP domain and enter its view, or enter the view of an existing ISP domain.
Use undo domain to delete an ISP domain.
domain isp-name
undo domain isp-name
A system-defined ISP domain exists. The domain name is system.
context-admin
vsys-admin
isp-name: Specifies the ISP domain name, a case-insensitive string of 1 to 255 characters. The name must meet the following requirements:
· The name cannot contain a forward slash (/), backslash (\), vertical bar (|), quotation marks ("), colon (:), asterisk (*), question mark (?), left angle bracket (<), right angle bracket (>), or at sign (@).
· The name cannot be d, de, def, defa, defau, defaul, default, i, if, if-, if-u, if-un, if-unk, if-unkn, if-unkno, if-unknow, or if-unknown.
All ISP domains are in active state when they are created.
You can modify settings for the system-defined ISP domain system, but you cannot delete this domain.
An ISP domain cannot be deleted when it is the default ISP domain. Before you use the undo domain command, change the domain to a non-default ISP domain by using the undo domain default enable command.
Use short domain names to ensure that user names containing a domain name do not exceed the maximum name length required by different types of users.
# Create an ISP domain named test and enter ISP domain view.
display domain
domain if-unknown
state (ISP domain view)
Use domain default enable to specify the default ISP domain. Users without any domain name included in the usernames are considered in the default domain.
Use undo domain default enable to restore the default.
domain default enable isp-name
The default ISP domain is the system-defined ISP domain system.
context-admin
vsys-admin
isp-name: Specifies the ISP domain name, a case-insensitive string of 1 to 255 characters. The ISP domain must already exist.
The system has only one default ISP domain.
# Create an ISP domain named test, and configure the domain as the default ISP domain.
[Sysname-isp-test] quit
[Sysname] domain default enable test
display domain
domain
domain if-unknown
Use domain if-unknown to specify an ISP domain to accommodate users that are assigned to nonexistent domains.
Use undo domain if-unknown to restore the default.
domain if-unknown isp-name
No ISP domain is specified to accommodate users that are assigned to nonexistent domains.
context-admin
vsys-admin
The device chooses an authentication domain for each user in the following order:
1. The authentication domain specified for the access module.
2. The ISP domain in the username.
3. The default ISP domain of the device.
If the chosen domain does not exist on the device, the device searches for the ISP domain that accommodates users assigned to nonexistent domains. If no such ISP domain is configured, user authentication fails.
NOTE: Support for the authentication domain configuration depends on the access module. |
# Specify ISP domain test to accommodate users that are assigned to nonexistent domains.
[Sysname] domain if-unknown test
display domain
domain-delimiter
Use domain-delimiter to configure global domain name delimiters.
Use undo domain-delimiter to restore the default.
domain-delimiter [ advpn | ike | ipoe | lanaccess | login | portal | ppp | sslvpn | super] string
undo domain-delimiter [ advpn | ike | ipoe | lanaccess | login | portal | ppp | sslvpn | super]
Global domain name delimiters include at sign (@), slash (/), and backslash (\).
context-admin
vsys-admin
advpn: Specifies ADVPN tunnel users.
ike: Specifies IKE users that access the network through IKE extended authentication.
ipoe: Specifies IPoE users.
lanaccess: Specifies LAN access users.
login: Specifies users that log in to the device.
portal: Specifies portal users.
ppp: Specifies PPP users.
ssh: Specifies SSH users.
sslvpn: Specifies SSL VPN users.
super: Specifies users that obtain temporary user role authorization.
string: Specifies a string of 1 to 16 global domain name delimiters. Valid delimiters include at sign (@), dot (.), slash (/), and backslash (\). To specify a backslash (\), you must precede the backslash with an escape character (\).
A domain name delimiter separates the username part from the domain name part in a username. For the device to correctly extract the username and domain name parts in usernames, you can configure domain name delimiters. Table 2 shows the way that the device interprets a username based on different domain name delimiters.
Table 2 Domain name delimiters and username formats
Domain name delimiter |
Username format |
At sign (@) |
username@domain-name |
Backslash (\) |
domain-name\username |
Slash (/) |
username/domain-name |
Dot (.) |
username.domain-name |
If a username includes multiple domain name delimiters, the device selects the first delimiter in the search direction specified by using the domain-delimiter search-from command.
If you do not specify a user type, the configured domain name delimiters take effect on all types of users.
The access module-specific domain name delimiters have higher priority than global domain name delimiters.
Modification of global domain name delimiters takes effect only on users that come online after the modification.
# Configure global domain name delimiters as at sign (@) and slash (/).
[Sysname] domain-delimiter login @/
domain-delimiter search-direction
Use domain-delimiter search-direction to specify the search direction for the domain name delimiter.
Use undo domain-delimiter search-direction to restore the default.
domain-delimiter search-direction { backward | forward }
The device searches for a domain name delimiter in usernames from right to left.
context-admin
vsys-admin
backward: Specifies the right-to-left search direction.
forward: Specifies the left-to-right search direction.
In authentication, it is very import for the device to correctly extract the username and domain name parts in a username. If a username includes multiple domain name delimiters, the search direction for the domain name delimiter determines how the device interprets a username. For example, if a username is 1234@456@789 and the domain name delimiter is at sign (@), the device can interpret the username in the following ways:
· If the search direction is left-to-right, the device uses the first at sign (@) as the delimiter. The username part is 1234 and the domain name part is 456@789.
· If the search direction is right-to-left, the device uses the second at sign (@) as the delimiter. The username part is 1234@789 and the domain name part is 789.
Use this command to specify the direction in which the device search for a domain name delimiter in usernames.
Modification of the search direction takes effect only on users that come online after the modification.
# Specify the left-to-right direction for the device to search for a domain name delimiter in usernames.
[Sysname] domain-delimiter search-direction forward
domain-delimiter
local-server log change-password-prompt
Use local-server log change-password-prompt to enable password change prompt logging.
Use undo local-server log change-password-prompt to disable password change prompt logging.
Password change prompt logging is enabled.
context-admin
Non-default vSystems do not support this command.
Use this feature to enhance the protection of passwords for Telnet, SSH, HTTP, HTTPS, NETCONF over SSH, and NETCONF over SOAP users and improve the system security.
This feature enables the device to generate logs to prompt users to change their weak passwords at an interval of 24 hours and at the users' login.
A password is a weak password if it does not meet the following requirements:
· Password composition restriction configured by using the password-control composition command.
· Minimum password length restriction set by using the password-control length command.
· Password complexity checking policy configured by using the password-control complexity command.
For a NETCONF over SSH or NETCONF over SOAP user, the device also generates a password change prompt log if any of the following conditions exists:
· The current password of the user is the default password or has expired.
· The user logs in to the device for the first time or uses a new password to log in after global password control is enabled.
The device will no longer generate password change prompt logs for a user when one of the following conditions exists:
· The password change prompt logging feature is disabled.
· The user has changed the password and the new password meets the password control requirements.
· The enabling status of a related password control feature has changed so the current password of the user meets the password control requirements.
· The password composition policy or the minimum password length has changed.
You can use the display password-control command to display password control configuration. For more information about password control commands, see "Password control commands."
# Enable password change prompt logging.
[Sysname] local-server log change-password-prompt
nas-id
Use nas-id to set the NAS-ID in an ISP domain.
Use undo nas-id to restore the default.
nas-id nas-identifier
undo nas-id
No NAS-ID is set in an ISP domain.
ISP domain view
context-admin
vsys-admin
nas-identifier: Specifies a NAS-ID, a case-sensitive string of 1 to 31 characters.
During RADIUS authentication, the device uses a NAS-ID to set the NAS-Identifier attribute of RADIUS packets so that the RADIUS server can identify the access location of users.
You can configure a NAS-ID in VSRP instance view, in NAS-ID profile view, or in ISP domain view. The device selects the NAS-ID for the NAS-Identifier attribute in the following order:
1. NAS-ID bound with VLANs in a NAS-ID profile.
2. NAS-ID in an ISP domain.
If no NAS-ID is selected, the device uses the device name as the NAS-ID.
# Set the NAS-ID to test for ISP domain test.
[Sysname-isp-test] nas-id test
aaa nas-id profile
nas-id bind vlan
Use nas-id bind vlan to bind a NAS-ID with a VLAN.
Use undo nas-id bind vlan to remove a NAS-ID and VLAN binding.
nas-id nas-identifier bind vlan vlan-id
undo nas-id nas-identifier bind vlan vlan-id
No NAS-ID and VLAN bindings exist.
NAS-ID profile view
context-admin
vlan-id: Specifies a VLAN ID in the range of 1 to 4094.
You can configure multiple NAS-ID and VLAN bindings in a NAS-ID profile.
A NAS-ID can be bound with more than one VLAN, but a VLAN can be bound with only one NAS-ID. If you configure multiple bindings for the same VLAN, the most recent configuration takes effect.
# Bind NAS-ID 222 with VLAN 2 in NAS-ID profile aaa.
[Sysname] aaa nas-id profile aaa
[Sysname-nas-id-prof-aaa] nas-id 222 bind vlan 2
aaa nas-id profile
service-type (ISP domain view)
Use service-type to specify the service type for users in an ISP domain.
Use undo service-type to restore the default.
service-type { hsi | stb | voip }
undo service-type
The service type is hsi for users in an ISP domain.
ISP domain view
context-admin
vsys-admin
hsi: Specifies the High Speed Internet (HSI) service. This service is applicable to users that access the network through PPP or leased IPoE.
stb: Specifies the Set Top Box (STB) service. This service is applicable to users that access the network through STB.
voip: Specifies the Voice over IP (VoIP) service. This service is applicable to users that access the network through IP phones.
When the HSI service is specified, the multicast feature of the access module is disabled to save system resources.
When the STB service is specified, the multicast feature of the access module is enabled to improve the performance of the multicast module.
When the VoIP service is specified, the QoS module increases the priority of voice traffic to reduce the transmission delay for IP phone users.
For PPP (excluding PPPoE) users, the system uses the HSI service forcibly even if the STB or VoIP service is specified.
You can configure only one service type for an ISP domain.
# Specify the STB service for users in ISP domain test.
[Sysname-isp-test] service-type stb
session-time include-idle-time
Use session-time include-idle-time to configure the device to include the idle timeout period in the user online duration sent to the server.
Use undo session-time include-idle-time to restore the default.
The device does not include the idle timeout period in the user online duration sent to the server.
ISP domain view
context-admin
vsys-admin
Whether to configure the device to include the idle timeout period in the user online duration sent to the server, depending on the accounting policy in your network. The idle timeout period is assigned to users by the authorization server after the users pass authentication. For portal users, the device includes the idle timeout period set for the online portal user detection feature in the user online duration. For more information about online detection for portal users, see portal authentication configuration in Security Configuration Guide.
If the user goes offline due to connection failure or malfunction, the user online duration sent to the server is not the same as the actual online duration.
· If the session-time include-idle-time command is used, the user's online duration sent to the server includes the idle timeout period. The online duration that is generated on the server is longer than the actual online duration of the user.
· If the undo session-time include-idle-time command is used, the user's online duration sent to the server excludes the idle timeout period. The online duration that is generated on the server is shorter than the actual online duration of the user.
# Configure the device to include the idle timeout period in the online duration sent to the server for users in ISP domain test.
[Sysname-isp-test] session-time include-idle-time
display domain
Use state to set the status of an ISP domain.
Use undo state to restore the default.
state { active | block }
undo state
An ISP domain is in active state.
ISP domain view
context-admin
vsys-admin
active: Places the ISP domain in active state to allow the users in the ISP domain to request network services.
block: Places the ISP domain in blocked state to prevent users in the ISP domain from requesting network services.
By blocking an ISP domain, you disable offline users of the domain from requesting network services. However, the online users are not affected.
# Place ISP domain test in blocked state.
[Sysname-isp-test] state block
display domain
user-address-type
Use user-address-type to specify the user address type in the ISP domain.
Use undo user-address-type to restore the default.
user-address-type { ds-lite | ipv6 | nat64 | private-ds | private-ipv4 | public-ds | public-ipv4 }
No user address type is specified for the ISP domain.
ISP domain view
context-admin
vsys-admin
ds-lite: Specifies the DS-Lite address type.
nat64: Specifies the NAT64 address type.
private-ds: Specifies the private-DS address type.
private-ipv4: Specifies the private IPv4 address type.
public-ds: Specifies the public-DS address type.
public-ipv4: Specifies the public IPv4 address type.
Any change to the user address type does not affect online users.
# Specify the private IPv4 address type for users in ISP domain test.
[Sysname-isp-test] user-address-type private-ipv4
display domain
Local user commands
access-limit
Use access-limit to set the maximum number of concurrent logins using the local user name.
Use undo access-limit to restore the default.
access-limit max-user-number
undo access-limit
The number of concurrent logins using the local user name is not limited.
Local user view
context-admin
vsys-admin
max-user-number: Specifies the maximum number of concurrent logins, in the range of 1 to 1024.
This command takes effect only when local accounting is configured for the local user.
The command does not apply to FTP, SFTP, or SCP users. These users do not support accounting.
As a best practice to ensure accuracy for this command on network access users, execute the accounting start-fail offline command in the view of the users' ISP domain.
# Set the maximum number of concurrent logins to 5 for users using the local user name abc.
[Sysname] local-user abc
[Sysname-luser-manage-abc] access-limit 5
display local-user
access-user email authentication
Use access-user email authentication to specify the username and password used to log in to the SMTP server that sends email notifications to network access users.
Use undo access-user email authentication to restore the default.
access-user email authentication username user-name password { cipher | simple } string
No SMTP server username or password is specified.
context-admin
username user-name: Specifies the username, a case-sensitive string of 1 to 63 characters.
password: Specifies the password.
cipher: Specifies the password in encrypted form.
simple: Specifies the password in plaintext form. For security purposes, the password specified in plaintext form will be stored in encrypted form.
string: Specifies the password string. Its plaintext form is a case-sensitive string of 1 to 63 characters. Its encrypted form is a case-sensitive string of 1 to 117 characters.
If the SMTP server requires a username and password for login, you must use this command to specify the username and password on the device.
# Set the username to abc and the password to 123 for logging in to the SMTP server that sends email notifications to network access users.
[Sysname] access-user email authentication username abc password simple 123
access-user email format
access-user email sender
access-user email smtp-server
Use access-user email format to configure the subject and body for the email notifications to send to network access users.
Use undo access-user email format to restore the default.
access-user email format { body body-string | subject sub-string }
undo access-user email format { body | subject }
The email subject is Password reset notification.
The email body is as follows:
A random password has been generated for your account.
Username: xxx
Password: yyy
Validity: YYYY/MM/DD hh:mm:ss to YYYY/MM/DD hh:mm:ss
The xxx string represents the username, the yyy string represents the password, and the YYYY/MM/DD hh:mm:ss to YYYY/MM/DD hh:mm:ss string represents the validity period.
context-admin
body body-string: Configures the body content. The body-string argument is a case-sensitive string of 1 to 255 characters.
subject sub-string: Configures the email subject. The sub-string argument is a case-sensitive string of 1 to 127 characters.
You can configure the device to generate a random password for a network access user on the Web interface. The random password is sent to the user by email. Use this command to configure the email subject and body content.
The email body includes the string configured by using the body-string argument and the following information:
Username: xxx
Password: yyy
# Configure the subject and body for the email notifications to send to network access users.
[Sysname] access-user email format subject new password setting
[Sysname] access-user email format body The username, password, and validity period of the account are given below.
Use access-user email sender to configure the email sender address in email notifications sent by the device to network access users.
Use undo access-user email sender to restore the default.
access-user email sender email-address
No email sender address is configured for the email notifications sent by the device to network access users.
context-admin
email-address: Specifies the email sender address, a case-sensitive string of 1 to 255 characters. The string must contain an at sign (@), and it can contain only one at sign (@). In addition, the string cannot contain only the at sign (@).
If you do not specify the email sender address, the device cannot send email notifications to any network access users.
The device supports only one email sender address for network access users. If you execute this command multiple times, the most recent configuration takes effect.
# Specify the email sender address as [email protected] for email notifications of network access users.
[Sysname] access-user email sender [email protected]
Use access-user email smtp-server to specify an SMTP server to send email notifications of network access users.
Use undo access-user email smtp-server to restore the default.
access-user email smtp-server url-string
No SMTP server is specified to send email notifications of network access users.
context-admin
url-string: Specifies the path of the SMTP server, a case-sensitive string of 1 to 255 characters. The path must comply with the standard SMTP protocol and start with smtp://.
You can specify only one SMTP server to send email notifications of network access users.
# Specify the SMTP server at smtp://www.test.com/smtp to send email notifications of network access users.
[Sysname] access-user email smtp-server smtp://www.test.com/smtp
authorization-attribute (local user view/user group view)
Use authorization-attribute to configure authorization attributes for a local user or user group. After the local user or a local user in the user group passes authentication, the device assigns these attributes to the user.
authorization-attribute { acl acl-number | callback-number callback-number | idle-cut minutes | ip ipv4-address | ip-pool ipv4-pool-name | ipv6 ipv6-address | ipv6-pool ipv6-pool-name | ipv6-prefix ipv6-prefix prefix-length | { primary-dns | secondary-dns } { ip ipv4-address | ipv6 ipv6-address } | session-timeout minutes | sslvpn-policy-group group-name | url url-string | user-role role-name | vlan vlan-id | vpn-instance vpn-instance-name | work-directory directory-name } *
undo authorization-attribute { acl | callback-number | idle-cut | ip | ip-pool | ipv6 | ipv6-pool | ipv6-prefix | primary-dns | secondary-dns| session-timeout | sslvpn-policy-group | url | user-role role-name | vlan | vpn-instance | work-directory } *
The working directory for FTP, SFTP, and SCP users is the root directory of the NAS. However, the users do not have permission to access the root directory.
The local users created by a network-admin or level-15 user on the default context are assigned the network-operator user role. The local users created by a context-admin or level-15 user on a non-default context are assigned the context-operator user role.
The local users created by a network-admin or level-15 user on the default vSystem are assigned the network-operator user role. The local users created by a vsys-admin or level-15 user on a non-default vSystem are assigned the vsys-operator user role.
Local user view
User group view
context-admin
vsys-admin
acl acl-number: Specifies an authorization ACL. The value range for the acl-number argument is is 2000 to 4999. The device processes the traffic that matches the rules in the authorization ACL based on the permit or deny statement in the rules.
callback-number callback-number: Specifies an authorized PPP callback number. The callback-number argument is a case-sensitive string of 1 to 64 characters. After a local user passes authentication, the device uses this number to call the user.
idle-cut minutes: Specifies an idle timeout period in minutes. The value range for the minutes argument is 1 to 120. An online user is logged out if its idle period exceeds the specified idle timeout period.
ip ipv4-address: Assigns a static IPv4 address to the user after it passes authentication. This attribute is configurable only in local user view. You cannot configure it in user group view.
ip-pool ipv4-pool-name: Specifies an IPv4 address pool for the user. The ipv4-pool-name argument is a case-insensitive string of 1 to 63 characters.
ipv6 ipv6-address: Assigns a static IPv6 address to the user after it passes authentication. This attribute is configurable only in local user view. You cannot configure it in user group view.
ipv6-pool ipv6-pool-name: Specifies an IPv6 address pool for the user. The ipv6-pool-name argument is a case-insensitive string of 1 to 63 characters.
ipv6-prefix ipv6-prefix prefix-length: Specifies an IPv6 prefix for the user. The value range for the prefix-length argument is 1 to 128. The IPv6 prefix cannot be ::/128, ::1/128, or an IPv6 multicast prefix. After passing authentication, a local user can use the IPv6 prefix.
primary-dns ip ipv4-address: Specifies the IPv4 address of the primary DNS server for the user.
primary-dns ipv6 ipv6-address: Specifies the IPv6 address of the primary DNS server for the user.
secondary-dns ip ipv4-address: Specifies the IPv4 address of the secondary DNS server for the user.
secondary-dns ipv6 ipv6-address: Specifies the IPv6 address of the secondary DNS server for the user.
session-timeout minutes: Specifies the session timeout timer for the user, in minutes. The value range for the minutes argument is 1 to 1440. The device logs off the user after the timer expires.
sslvpn-policy-group group-name: Specifies an SSL VPN policy group for the user. The group-name argument is a case-insensitive string of 1 to 31 characters. For information about SSL VPN policy groups, see Security Configuration Guide.
url url-string: Specifies a redirect URL. The url-string argument is a case-sensitive string of 1 to 255 characters. The URL must start with http:// or https://. You can configure the redirect URL attribute to push advertisements or notifications to users after the users pass authentication or push bill overdue notifications to users. This option is applicable only to IPoE and LAN users. For IPoE users, you must specify a URL with port number 80 or 443.
user-role role-name: Specifies an authorized user role. The role-name argument is a case-sensitive string of 1 to 63 characters. A maximum of 64 user roles can be specified for a user. For user role-related commands, see Fundamentals Command Reference for RBAC commands. This option is available only in local user view, and is not available in user group view.
vlan vlan-id: Specifies an authorized VLAN. The value range for the vlan-id argument is 1 to 4094. After passing authentication and being authorized a VLAN, a local user can access only the resources in this VLAN.
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN instance to which the user belongs. The vpn-instance-name argument is a case-sensitive string of 1 to 31 characters. After passing authentication, the user has permission to access the network resources in the specified VPN.
work-directory directory-name: Specifies the working directory for FTP, SFTP, or SCP users. The directory-name argument is a case-insensitive string of 1 to 255 characters. The directory must already exist.
Configure authorization attributes according to the application environments and purposes. Support for authorization attributes depends on the service types of users.
For PPP users, only the following authorization attributes take effect: callback-number, idle-cut, ip, ip-pool, ipv6-pool, ipv6-prefix, primary-dns, secondary-dns, vpn-instance, and session-timeout.
For IPoE users, only the following authorization attributes take effect: idle-cut, ip-pool, ipv6-pool, ipv6-prefix, user-profile, vpn-instance, primary-dns, secondary-dns, url, and session-timeout.
For portal users, only the following authorization attributes take effect: idle-cut, acl, ip-pool, ipv6-pool, vpn-instance, and session-timeout.
For LAN users, only the following authorization attributes take effect: acl, idle-cut, session-timeout, ulr, and vlan. The idle-cut authorization attribute takes effect only on wireless users.
For SSH, Telnet, and terminal users, only the user-role authorization attribute takes effect.
For HTTP and HTTPS users, only the authorization attribute user-role takes effect.
For FTP users, only the authorization attributes user-role and work-directory take effect.
For SSL VPN users, only the authorization attribute sslvpn-policy-group takes effect.
For IKE users, only the authorization attributes ip-pool, ip, and ipv6 take effect.
For other types of local users, no authorization attribute takes effect.
Authorization attributes configured for a user group are intended for all local users in the group. You can group local users to improve configuration and management efficiency. An authorization attribute configured in local user view takes precedence over the same attribute configured in user group view.
When you specify an authorization ACL, the following restrictions apply:
· The authorization ACL is invalid if it does not exist or does not contain rules. If strict checking on authorization ACLs is enabled for portal users in this situation, portal users will be forced offline.
· For portal users to come online after passing authentication, make sure ACLs assigned to them do not have rules specified with a source IP or MAC address.
To make sure FTP, SFTP, and SCP users can access the directory after an IRF master/subordinate switchover, do not specify slot information for the working directory.
To make sure the user have only the user roles authorized by using this command, use the undo authorization-attribute user-role command to remove the default user role.
The security-audit user role has access to the commands for managing security log files and security log file system. To display all the accessible commands of the security-audit user role, use the display role name security-audit command. For more information about security log management, see information center configuration in Network Management and Monitoring Configuration Guide. For more information about file system management, see Fundamentals Configuration Guide.
You cannot delete a local user if the local user is the only user that has the security-audit user role.
The security-audit user role is mutually exclusive with other user roles.
The users assigned with the system-admin, security-admin, or audit-admin user role have access to specific Web pages and the ping and tracert commands. For more information about the access permissions of these user roles, see RBAC in Fundamentals Configuration Guide.
The system-admin, security-admin, and audit-admin user roles are mutually exclusive in a user account. In addition, these user roles are mutually exclusive with other user roles in a user account.
When you assign user roles to a user, the system prompts you to confirm the deletion of the user roles that are mutually exclusive with the new user roles.
# Configure the authorized VLAN of network access user abc as VLAN 2.
[Sysname] local-user abc class network
[Sysname-luser-network-abc] authorization-attribute vlan 2
# Configure the authorized VLAN of user group abc as VLAN 3.
[Sysname] user-group abc
[Sysname-ugroup-abc] authorization-attribute vlan 3
# Assign the security-audit user role to device management user xyz as the authorized user role.
[Sysname] local-user xyz class manage
[Sysname-luser-manage-xyz] authorization-attribute user-role security-audit
This operation will delete all other roles of the user. Are you sure? [Y/N]:y
display local-user
display user-group
bind-attribute
Use bind-attribute to configure binding attributes for a local user.
Use undo bind-attribute to remove binding attributes of a local user.
bind-attribute { call-number call-number [ : subcall-number ] | location interface interface-type interface-number | mac mac-address | vlan vlan-id } *
undo bind-attribute { call-number | location | mac | vlan } *
No binding attributes are configured for a local user.
Local user view
context-admin
vsys-admin
call-number call-number: Specifies a calling number for PPP user authentication. The call-number argument is a string of 1 to 64 characters. This option applies only to PPP users.
subcall-number: Specifies the subcalling number. The total length of the calling number and the subcalling number cannot be more than 62 characters.
location interface interface-type interface-number: Specifies the interface to which the user is bound. The interface-type argument represents the interface type, and the interface-number argument represents the interface number. To pass authentication, the user must access the network through the bound interface. This option applies only to LAN, PPP, IPoE, and portal users.
mac mac-address: Specifies the MAC address of the user in the format H-H-H. This option applies only to SSL VPN users that log in through iNode clients, LAN users, PPP users, IPoE users, and portal users.
vlan vlan-id: Specifies the VLAN to which the user belongs. The vlan-id argument is in the range of 1 to 4094. This option applies only to LAN, PPP, IPoE, and portal users.
To perform local authentication of a user, the device matches the actual user attributes with the configured binding attributes. If the user has a non-matching attribute or lacks a required attribute, the user will fail authentication.
Binding attribute check takes effect on all access services. Configure the binding attributes for a user based on the access services and make sure the device can obtain all attributes to be checked from the user's packet.
The binding interface type must meet the requirements of the local user. Configure the binding interface based on the service type of the user. If the user is a portal user, specify the portal-enabled interface. Specify the Layer 2 Ethernet interface if portal is enabled on a VLAN interface and the portal roaming enable command is not configured.
# Bind MAC address 11-11-11 with network access user abc.
[Sysname-luser-network-abc] bind-attribute mac 11-11-11
display local-user
company
Use company to specify the company of a local guest.
Use undo company to restore the default.
company company-name
undo company
No company is specified for a local guest.
Local guest view
context-admin
company-name: Specifies the company name, a case-sensitive string of 1 to 255 characters.
# Specify company yyy for local guest abc.
[Sysname] local-user abc class network guest
[Sysname-luser-network(guest)-abc] company yyy
display local-user
description (network access user view)
Use description to configure a description for a network access user.
No description is configured for a network access user.
Network access user view
context-admin
vsys-admin
text: Configures a description, case-sensitive string of 1 to 127 characters.
To mark a network access user for special displaying or management purposes in the Web interface, configure description #user_from_server# for the user. The purposes depend on the implementation of the Web interface.
# Configure a description for network access user 123.
[Sysname] local-user 123 class network
[Sysname-luser-network-123] description Manager of MSC company
display local-user
description (user group view)
Use description to configure a description for a user group.
No description is configured for a user group.
User group view
context-admin
vsys-admin
text: Configures a description, a case-sensitive string of 1 to 127 characters.
To distinguish a user group from other user groups, configure a description for the user group.
# Configure a description for user group abc.
[Sysname-ugroup-abc] description student
display user-group
display local-guest waiting-approval
Use display local-guest waiting-approval to display pending registration requests for local guests.
display local-guest waiting-approval [ user-name user-name ]
context-admin
context-operator
user-name user-name: Specifies a local guest by the user name, a string of 1 to 55 characters. If you do not specify a guest, this command displays pending registration requests for all local guests. The username can be a pure username or a username containing a domain name.
· A pure username is case sensitive. It cannot contain a forward slash (/), backslash (\), vertical bar (|), colon (:), asterisk (*), question mark (?), left angle bracket (<), or right angle bracket (>). It also cannot be a, al, or all.
· A username containing a domain name is in the pure-username@domain-name format.
¡ The pure username part is case sensitive. It cannot contain a forward slash (/), backslash (\), vertical bar (|), colon (:), asterisk (*), question mark (?), left angle bracket (<), right angle bracket (>), or at sign (@). It also cannot be a, al, or all.
¡ The domain name part is case insensitive and cannot contain an at sign (@).
On the Web registration page, users submit local guest registration requests for approval. The guest manager can add supplementary information to the guest accounts and approves the requests. The device then creates local guest accounts based on the approved requests.
# Display all pending registration requests for local guests.
<Sysname> display local-guest waiting-approval
Total 1 guest informations matched.
Guest user Smith:
Full name : Smith Li
Company : YYY
Email : [email protected]
Phone : 139189301033
Description: The employee of YYY company
Total 1 guest informations matched. |
Number of local guests that have pending registration requests. |
Full name |
Full name of the local guest. |
Company |
Company name of the local guest. |
Email address of the local guest. |
Phone |
Phone number of the local guest. |
Description of the local guest. |
reset local-guest waiting-approval
display local-user
Use display local-user to display the local user configuration and online user statistics.
display local-user [ class { manage | network [ guest ] } | idle-cut { disable | enable } | service-type { advpn | ftp | http | https | ike | ipoe | lan-access | portal | ppp | ssh | sslvpn | telnet | terminal } | state { active | block } | user-name user-name class { manage | network [ guest ] } | vlan vlan-id ]
context-admin
context-operator
vsys-admin
vsys-operator
class: Specifies the local user type.
manage: Device management user.
network: Network access user.
guest: Guest user account.
idle-cut { disable | enable }: Specifies local users by the status of the idle cut feature.
service-type: Specifies the local users that use a specific type of service.
advpn: ADVPN tunnel users.
ftp: FTP users.
http: HTTP users.
https: HTTPS users.
ike: IKE users that access the network through IKE extended authentication.
ipoe: IPoE users that access the network through Layer 2 or Layer 3 leased lines or STBs.
lan-access: LAN users that typically access the LAN network.
portal: Portal users.
ppp: PPP users.
ssh: SSH users.
sslvpn: SSL VPN users.
telnet: Telnet users.
terminal: Terminal users that log in through console ports.
state { active | block }: Specifies local users in active or blocked state. A local user in active state can access network services, but a local user in blocked state cannot.
user-name user-name: Specifies all local users using the specified username. The username is a string of 1 to 55 characters, which can be a pure username or a username containing a domain name.
vlan vlan-id: Specifies all local users in a VLAN. The vlan-id argument is in the range of 1 to 4094.
If you do not specify any parameters, this command displays information about all local users.
# Display information about all local users.
<Sysname> display local-user
Device management user root:
State: Active
Service type: SSH/Telnet/Terminal
Access limit: Enabled Max access number: 3
Current access number: 1
User group: system
Bind attributes:
Work directory: flash:
User role list: network-admin
Password aging: Enabled
Password complexity: Enabled (username checking)
Disabled (repeated characters checking)
Password history was last reset: 0 days ago
Network access user jj:
State: Active
Service type: SSL VPN
User group: system
Bind attributes:
Location bound: GigabitEthernet1/0/1
MAC address: 0001-0001-0001
VLAN ID: 2
Idle timeout: 33 minutes
ACL number: 2000
User role list: network-operator, level-0, level-3
SSL VPN policy group: spg
Description: A network access user
Validity period:
Start date and time: 2016/01/01-00:01:01
Expiration date and time:2019/12/01-01:01:01
Password aging: Enabled (34 days)
Password length: 4 characters
Create date and time: 2022/11/01-00:01:01
LastSuccessfulLoginTime: 2022/11/02-00:02:02
Network access guest user user1:
State: Active
Service type: Portal
User group: guest1
Full name: Jack
Company: cc
Email: [email protected]
Phone: 131129237
Description: A guest from company cc
Sponsor full name: Sam
Sponsor department: security
Sponsor email: [email protected]
Validity period:
Start date and time: 2016/04/01-08:00:00
Expiration date and time:2019/12/03-18:00:00
Total 3 local users matched.
State |
Status of the local user: active or blocked. |
Service type |
Service types that the local user can use. |
Access limit |
Whether the concurrent login limit is enabled. |
Max access number |
Maximum number of concurrent logins using the local user name. |
Current access number |
Current number of concurrent logins using the local user name. |
User group |
Group to which the local user belongs. |
Bind attributes |
Binding attributes of the local user. |
Location bound |
Binding port of the local user. |
MAC address |
MAC address of the local user. |
VLAN ID |
Binding VLAN of the local user. |
Calling number |
Calling number of the ISDN user. |
Authorization attributes of the local user. |
Idle timeout |
Idle timeout period of the user, in minutes. |
Session-timeout |
Session timeout timer for the user, in minutes. |
Callback number |
Authorized PPP callback number of the local user. |
Work directory |
Directory that the FTP, SFTP, or SCP user can access. |
ACL number |
Authorization ACL of the local user. |
VLAN ID |
Authorized VLAN of the local user. |
User role list |
Authorized roles of the local user. |
IP pool |
IPv4 address pool authorized to the local user. |
SSL VPN policy group |
SSL VPN policy group authorized to the local user. |
IP address |
IPv4 address authorized to the local user. |
IPv6 address |
IPv6 address authorized to the local user. |
IPv6 prefix |
IPv6 address prefix authorized to the local user. |
IPv6 pool |
IPv6 address pool authorized to the local user. |
IPv4 address of the primary DNS server for the local user. |
IPv4 address of the secondary DNS server for the local user. |
IPv6 address of the primary DNS server for the local user. |
IPv6 address of the secondary DNS server for the local user. |
URL |
Authorization PADM URL for the local user. |
VPN instance |
Authorization VPN instance for the local user. |
Password control configurations |
Password control attributes that are configured for the local user. |
Password aging |
Password expiration time. |
Password length |
Minimum number of characters that a password must contain. |
Password composition |
Password composition policy: · Minimum number of character types that a password must contain. · Minimum number of characters from each type in a password. |
Password complexity |
Password complexity checking policy: · Reject a password that contains the username or the reverse of the username. · Reject a password that contains any character repeated consecutively three or more times. |
Maximum login attempts |
Maximum number of consecutive failed login attempts. |
Action for exceeding login attempts |
Action to take on the user that failed to log in after using up all login attempts. |
Password history was last reset |
The most recent time that the history password records were cleared. |
Full name |
Name of the local guest. |
Company |
Phone |
Sponsor full name |
Name of the guest sponsor. |
Sponsor department |
Department of the guest sponsor. |
Sponsor email |
Email address of the guest sponsor. |
Description of the network access user. |
Period of validity |
Validity period of the network access user. |
Start date and time |
Date and time from which the network access user begins to take effect. |
Expiration date and time |
Date and time at which the network access user expires. |
display local-user access-count
Use display local-user access-count to display access statistics for a local user.
display local-user user-name user-name class { manage | network } access-count
context-admin
context-operator
vsys-admin
vsys-operator
user-name user-name: Specifies all local users using the specified username. The username is a string of 1 to 55 characters. The username cannot contain a forward slash (/), backslash (\), vertical bar (|), colon (:), asterisk (*), question mark (?), left angle bracket (<), or right angle bracket (>). It also cannot be a, al, or all.
manage: Specifies the device management user.
network: Specifies the network access user.
# Display access statistics for device management user admin.
<Sysname> display local-user user-name admin class manage access-count
Device management user admin:
Configured access limit: 30
Current access count: 15
Access method Slot Access count
Telnet 1 10
SSH 1 5
Table 5 Command output
Configured access limit |
Current access count |
Access method |
Access type of the user: · ADVPN. · Telnet. · SSH. · HTTP. · HTTPS. · Terminal. · IPoE. · LAN access. · Portal. · PPP. · SSL VPN. |
Access count |
Current number of concurrent logins of the specified access type that use the specified local username. |
access-limit
display user-group
Use display user-group to display user group configuration.
display user-group { all | name group-name } [ identity-member { all | group | user } ]
context-admin
context-operator
all: Specifies all user groups.
name group-name: Specifies a user group by its name, a case-insensitive string of 1 to 32 characters.
identity-member { all | group | user }: Specifies identity members in the specified user group or all user groups. If you do not specify this option, the command does not display identity member information.
· all: Specifies all identity members, including identity users and identity groups.
· group: Specifies identity groups.
· user: Specifies identity users.
# Display the configuration of all user groups.
<Sysname> display user-group all
Total 2 user groups matched.
User group: system
User group: jj
Description: school
Callback number: 2:2
Work directory: flash:/
ACL number: 2000
VLAN ID: 2
SSL VPN policy group: policygroup1
Password aging: 2 days
# Display information about all identity members for all user groups.
<Sysname> display user-group all identity-member all
User group: system
Identity groups: 0
Identity users: 0
User group: jj
Description: school
Identity groups: 2
Group name Group description
1 group1
2 group2
Identity users: 2
User ID Username
0x234 user1
0xffffffff user2
Table 6 Command output
User group |
User group name. |
Authorization attributes of the user group. |
Idle timeout |
Session-timeout |
Session timeout timer, in minutes. |
Callback number |
Authorized PPP callback number. |
Work directory |
Directory that FTP, SFTP, or SCP users in the group can access. |
ACL number |
Authorization ACL. |
VLAN ID |
Authorized VLAN. |
IP pool |
IPv4 address pool authorized to the user group. |
SSL VPN policy group authorized to the user group. |
IPv6 prefix |
IPv6 address prefix authorized to the user group. |
IPv6 pool |
IPv6 address pool authorized to the user group. |
IPv4 address of the primary DNS server authorized to the user group. |
IPv4 address of the secondary DNS server authorized to the user group. |
IPv6 address of the primary DNS server authorized to the user group. |
IPv6 address of the secondary DNS server authorized to the user group. |
URL |
Authorization PADM URL for the user group. |
VPN instance |
Authorization VPN instance for the user group. |
Password control attributes that are configured for the user group. |
Password aging |
Password length |
Identity users |
Number of identity users. |
Identity groups |
Number of identity groups. |
User ID |
Identity user ID. |
Group ID |
Identity group ID. |
Username |
Identity user name. |
Group name |
Identity group name. |
Use email to configure an email address for a local guest.
Use undo email to restore the default.
email email-string
undo email
No email address is configured for a local guest.
Local guest view
context-admin
email-string: Specifies the email address for the local guest, a case-sensitive string of 1 to 255 characters. The string must contain an at sign (@), and it can contain only one at sign (@). In addition, the string cannot contain only the at sign (@).
The local guest uses the email address to receive notifications from the device.
# Configure the email address as [email protected] for local guest abc.
[Sysname-luser-network(guest)-abc] email [email protected]
display local-user
full-name
Use full-name to configure the name of a local guest.
Use undo full-name to restore the default.
full-name name-string
undo full-name
No name is configured for a local guest.
Local guest view
context-admin
name-string: Specifies the local guest name, a case-sensitive string of 1 to 255 characters.
# Configure the name as abc Snow for local guest abc.
[Sysname-luser-network(guest)-abc] full-name abc Snow
display local-user
group
Use group to assign a local user to a user group.
Use undo group to restore the default.
group group-name
undo group
A local user belongs to user group system.
Local user view
context-admin
vsys-admin
group-name: Specifies the user group name, a case-insensitive string of 1 to 32 characters.
# Assign device management user 111 to user group abc.
[Sysname] local-user 111 class manage
[Sysname-luser-manage-111] group abc
display local-user
identity-group
Use identity-group to add a network access user to an identity group.
Use undo identity-group to remove a network access user from identity groups.
identity-group group-name
undo identity-group [ group-name ]
A network access user does not belong to any identity groups.
context-admin
vsys-admin
group-name: Specifies an identity group by its name, a case-insensitive string of 1 to 32 characters.
Add users to an identity group as identity members for centralized management.
A user can belong to multiple identity groups.
After you add a user to an identity group in network access user view, the system automatically synchronizes the configuration to the identity group. Then, the user is available in user group view of the identity group.
If you do not specify a group name, the undo identity-group command removes the user from all identity groups.
# Add network access user user1 to identity group group1.
[Sysname] local-user user1 class network
[Sysname-luser-network-user1] identity-group group1
identity-member
user-group
identity-member
Use identity-member to add an identity member to a user group.
Use undo identity-member to remove identity members from a user group.
identity-member { group group-name | user user-name }
undo identity-member { group [ group-name ] | user [ user-name ] }
No identity members exist in a user group.
User group view
context-admin
vsys-admin
group group-name: Specifies an identity group by its name, a case-insensitive string of 1 to 32 characters.
user user-name: Specifies an identity user by its name, a string of 1 to 55 characters. The username can be a pure username or a username containing a domain name.
Assign users or users groups that have the same user identification requirements to the same group.
When you add identity members, follow these restrictions and guidelines:
· You can add network access users as identity members.
· After you add an identity user to an identity group in user group view, the system automatically synchronizes the configuration to the identity user if the user exists. Then, the identity group is available in network access user view of the identity user.
· You cannot add an identity group to a lower-level group that is an identity member of the group.
If you do not specify a user name or group name, the undo identity-member command removes all identity users or groups from the user group.
If an identity group has been specified for a security policy, do not remove member identity groups from the identity group. A violation will cause the truncation of the tree where the identity group resides and further affect user traffic matching of the security policy.
# Add identity user user1 and identity group group2 to user group group1.
[Sysname] user-group group1
[Sysname-ugroup-group1] identity-member user user1
[Sysname-ugroup-group1] identity-member group group2
display user-group
identity-group
local-guest auto-delete enable
Use local-guest auto-delete enable to enable the guest auto-delete feature.
Use undo local-guest auto-delete enable to restore the default.
The guest auto-delete feature is disabled.
context-admin
This feature enables the device to automatically delete the local guest accounts when they expire.
# Enable the guest auto-delete feature.
[Sysname] local-guest auto-delete enable
validity-datetime
local-guest email format
Use local-guest email format to configure the subject and body for the email notifications of local guest information.
Use undo local-guest email format to delete the configured subject or body for the email notifications of local guest information.
local-guest email format to { guest | manager | sponsor } { body body-string | subject sub-string }
undo local-guest email format to { guest | manager | sponsor } { body | subject }
No subject or body is configured for the email notifications of local guest information.
context-admin
to: Specifies the email recipient.
guest: Specifies the local guest.
manager: Specifies the guest manager.
sponsor: Specifies the guest sponsor.
Email notifications need to be sent to notify the local guests, guest sponsors, or guest managers of the guest account information or guest registration requests. Use this command to configure the subject and body for the email notifications to be sent by the device.
You can configure one subject and one body for each email recipient. If you configure the subject or body content multiple times for the same recipient, the most recent configuration takes effect.
You must configure both the subject and body for each recipient.
# Configure the subject and body for the email notifications to send to the local guest.
[Sysname] local-guest email format to guest subject Guest account information
[Sysname] local-guest email format to guest body A guest account has been created for you. The username, password, and validity period of the account are given below.
local-guest email sender
local-guest email smtp-server
local-guest manager-email
local-guest send-email
Use local-guest email sender to configure the email sender address in email notifications of local guests sent by the device.
Use undo local-guest email sender to restore the default.
local-guest email sender email-address
No email sender address is configured for the email notifications of local guests sent by the device.
context-admin
If you do not specify the email sender address, the device cannot send email notifications of local guests.
The device supports only one email sender address for local guests. If you execute this command multiple times, the most recent configuration takes effect.
# Specify the email sender address as [email protected] for email notifications of local guests.
[Sysname] local-guest email sender [email protected]
Use local-guest email smtp-server to specify an SMTP server to send email notifications of local guests.
Use undo local-guest email smtp-server to restore the default.
local-guest email smtp-server url-string
No SMTP server is specified to send email notifications of local guests.
context-admin
# Specify the SMTP server at smtp://www.test.com/smtp to send local guest email notifications.
[Sysname] local-guest email smtp-server smtp://www.test.com/smtp
local-guest generate
Use local-guest generate to create local guests in batch.
local-guest generate username-prefix name-prefix [ password-prefix password-prefix ] suffix suffix-number [ group group-name ] count user-count validity-datetime start-date start-time to expiration-date expiration-time
context-admin
username-prefix name-prefix: Specifies the name prefix. The name-prefix argument is a case-sensitive string of 1 to 45 characters. The prefix cannot contain any of the following characters: forward slash (/), backslash (\), vertical bar (|), colon (:), asterisk (*), question mark (?), left angle bracket (<), right angle bracket (>), and at sign (@).
password-prefix password-prefix: Specifies a prefix for the plaintext password. The password-prefix argument is a case-sensitive string of 1 to 53 characters. If you do not specify a password prefix, the device randomly generates passwords for the local guests.
suffix suffix-number: Specifies the start suffix number of the username and password. The suffix-number argument is a numeric string of 1 to 10 digits.
group group-name: Specifies a user group by the name. The group-name argument is a case-sensitive string of 1 to 32 characters. If you do not specify a user group, the guests are assigned to the system-defined user group system.
count user-count: Specifies the number of local guests to be created. The value range for the user-count argument is 1 to 256.
validity-datetime: Specifies the validity period of the local guests. The expiration date and time must be later than the start date and time.
start-date: Specifies the start date of the validity period, in the format of MM/DD/YYYY or YYYY/MM/DD. The value range for the MM argument is 1 to 12. The value range for the DD argument varies with the specified month. The value range for the YYYY argument is 2000 to 2035.
start-time: Specifies the start time of the validity period, in the format of hh:mm:ss. The value range for the hh argument is 0 to 23. The value range for the mm and ss arguments is 0 to 59. The mm and ss arguments are optional. For example, enter 1 to indicate 1:00:00. A value of 0 indicates 00:00:00.
to: Specifies the end date and time of the validity period.
expiration-date: Specifies the expiration date in the format of MM/DD/YYYY or YYYY/MM/DD. The value range for the MM argument is 1 to 12. The value range for the DD argument varies with the specified month. The value range for the YYYY argument is 2000 to 2035.
expiration-time: Specifies the expiration time in the format of hh:mm:ss. The value range for the hh argument is 0 to 23. The value range for the mm and ss arguments is 0 to 59. The mm and ss arguments are optional. For example, enter 1 to indicate 1:00:00. A value of 0 indicates 00:00:00.
Account names of batch created local guests start with the same string specified by the name prefix, and end with a different number as the suffix. The system increases the start suffix number by 1 for each new local guest created in the batch.
The device generates plaintext passwords by using the password prefix and suffix number in the same way it batch creates the local guest names.
Consider the system resources when you specify the number of local guests to create. The device might fail to create all accounts for a large batch of local guests because of insufficient resources.
If a local guest to be created has the same name as an existing local guest on the device, the new guest overrides the existing guest.
# Create 20 local guests in batch with user names abc01 through abc20 for user group visit. The user accounts are effective from 2018/10/01 00:00:00 to 2019/10/02 12:00:00.
[Sysname] local-guest generate username-prefix abc suffix 01 group visit count 20 validity-datetime 2018/10/01 00:00:00 to 2019/10/02 12:00:00
local-user
display local-user
Use local-guest manager-email to configure the email address of the guest manager.
Use undo local-guest manager-email to restore the default.
local-guest manager-email email-address
No email address is configured for the guest manager.
context-admin
email-address: Specifies the email address, a case-sensitive string of 1 to 255 characters. For example, [email protected]. The address must comply with RFC 822.
Use this command to specify the email address to which the device sends the local guest registration requests for approval.
# Configure the email address of the guest manager as [email protected].
[Sysname] local-guest manager-email [email protected]
Use local-guest send-email to send emails to a local guest or guest sponsor.
local-guest send-email user-name user-name to { guest | sponsor }
context-admin
user-name user-name: Specifies a local guest by user name, a string of 1 to 55 characters. The username can be a pure username or a username containing a domain name.
Guest managers can use this command to inform local guests or guest sponsors of the guest password and validity period information.
# Send an email to notify local guest abc of the guest password and validity period information.
<Sysname> local-guest send-email user-name abc to guest
sponsor-email
local-guest timer
Use local-guest timer to set the waiting-approval timeout timer for local guests.
local-guest timer waiting-approval time-value
undo local-guest timer waiting-approval
The setting is 24 hours.
context-admin
time-value: Specifies the waiting-approval timeout timer in the range of 1 to 720, in hours.
The waiting-approval timeout timer starts when the registration request of a local guest is sent for approval. If the request is not approved within the timer, the device deletes the registration request.
# Set the waiting-approval timeout timer to 12 hours.
[Sysname] local-guest timer waiting-approval 12
local-user
Use local-user to add a local user and enter its view, or enter the view of an existing local user.
Use undo local-user to delete local users.
local-user user-name [ class { manage | network [ guest ] } ]
undo local-user { user-name class { manage | network [ guest ] } | all [ service-type { advpn | ftp | http | https | ike | ipoe | lan-access | portal | ppp | ssh | sslvpn | telnet | terminal } | class { manage | network [ guest ] } ] }
No local users exist.
context-admin
vsys-admin
user-name: Specifies the local user name, a string of 1 to 55 characters. The username can be a pure username or a username containing a domain name.
class: Specifies the local user type. If you do not specify this keyword, the command adds a device management user.
manage: Device management user that can configure and monitor the device after login. Device management users can use FTP, HTTP, HTTPS, Telnet, SSH, and terminal services.
network: Network access user that accesses network resources through the device. Network access users can use ADVPN, IKE, IPoE, LAN access, portal, PPP, and SSL VPN services.
guest: Guest that can access network resources through the device during a specific validity period. Guests can use LAN access and portal services.
all: Specifies all users.
ftp: FTP users.
http: HTTP users.
https: HTTPS users.
ppp: PPP users.
ssh: SSH users.
In local authentication, a username and user type uniquely identifies a local user. The username is used to match the pure username parsed from the username entered by the user. The user type restricts the service types that can be used by the user.
In the current software version, only the pure username of an SSL VPN user can contain an at sign (@).
The device supports a maximum of 16 device management users and a maximum of 1024 network access users.
The device encodes Chinese characters in GB18030 when it saves local usernames that contain Chinese characters. If a local username includes Chinese characters, users that log in to the device with this user account must make sure their terminal software also uses GB18030 for Chinese character encoding. This ensures that the device can correctly parse the username for a successful local authentication.
# Add a device management user named user1 and enter local user view.
[Sysname-luser-manage-user1]
# Add a network access user named user2 and enter local user view.
[Sysname] local-user user2 class network
[Sysname-luser-network-user2]
# Add a local guest named user3 and enter local guest view.
[Sysname] local-user user3 class network guest
[Sysname-luser-network(guest)-user3]
display local-user
service-type (local user view)
local-user-export class network
Use local-user-export class network to export network access user account information from the device to a .csv file in the specified path.
local-user-export class network url url-string [ from { group group-name | user user-name } ]
context-admin
url url-string: Specifies the URL of the destination file, a case-insensitive string of 1 to 255 characters.
from: Specifies the range of users to be exported. If you do not specify this keyword, the command exports all network access users on the device.
group group-name: Specifies a user group by its name, a case-insensitive string of 1 to 32 characters.
user user-name: Specifies a user by its name, a string of 1 to 55 characters. The username can be a pure username or a username containing a domain name.
Non-default vSystems do not support this command.
You can import the user account information back to the device or to other devices that support the local-user-import class network command. Before the import, you can edit the .csv file as needed. However, you must follow the restrictions in "local-user-import class network."
The device supports TFTP and FTP file transfer modes. Table 7 describes the valid URL formats of the .csv file.
Protocol |
URL format |
TFTP |
tftp://server/path/filename |
Specify a TFTP server. The server argument represents the IP address or host name of the server and the path argument represents the relative path of the TFTP work directory. For example, tftp://1.1.1.1/user/user.csv. |
FTP |
· With FTP user name and password: · Without FTP user name and password: |
Specify an FTP server. The server argument represents the IP address or host name of the server and the path argument represents the relative path of the FTP work directory. The device ignores the domain name in the FTP user name. For example, specify the file path as ftp://1:[email protected]/user/user.csv or ftp://1.1.1.1/user/user.csv. |
# Export network access user account information to the identityuser.csv file in the ftp://1.1.1.1/user/ path.
[Sysname] local-user-export class network url ftp://1.1.1.1/user/identityuser.csv
display local-user
local-user-export class network guest
Use local-user-export class network guest to export local guest account information to a .csv file in the specified path.
local-user-export class network guest url url-string
context-admin
You can import the user account information back to the device or to other devices that support the local-user-import class network guest command. Before the import, you can edit the .csv file as needed. However, you must follow the restrictions in "local-user-import class network guest."
The device supports TFTP and FTP file transfer modes. Table 8 describes the valid URL formats of the .csv file.
Protocol |
URL format |
TFTP |
Specify a TFTP server. The server argument represents the IP address or host name of the server and the path argument represents the relative path of the TFTP work directory. For example, specify the file path as tftp://1.1.1.1/user/user.csv. |
FTP |
# Export local guest account information to the guest.csv file in the ftp://1.1.1.1/user/ path.
[Sysname] local-user-export class network guest url ftp://1.1.1.1/user/guest.csv
display local-user
Use local-user-import class network to import user information from a .csv file in the specified path and create network access users based on the imported information.
local-user-import class network url url-string [ auto-create-group | override | start-line line-number ] *
context-admin
url url-string: Specifies the URL of the source file, a case-insensitive string of 1 to 255 characters.
auto-create-group: Enables the device to automatically create user groups for the imported network access users if the groups do not exist on the device. If you do not specify this keyword, the device ignores the nonexistent user groups of the network access users and assigns them to the predefined user group system.
override: Specifies the device to override the existing account with the same name as a user account to be imported. If you do not specify this keyword, the device retains the existing account information.
start-line line-number: Specifies the number of the line at which the account import begins. If you do not specify this option, the command imports information about all user accounts in the file.
The .csv file contains multiple parameters for each account and the parameters must be strictly arranged in the following order:
· Username—User name of an account. This parameter is required for each user account. The user name is a case-sensitive string of 1 to 55 characters. The name cannot be a, al, or all. It cannot contain a forward slash (/), backslash (\), vertical bar (|), colon (:), asterisk (*), question mark (?), left angle bracket (<), or right angle bracket (>). If the user name of an account contains an invalid character, the import process interrupts.
· Password form—Plaintext or encrypted form. By default, a password is in encrypted form.
· Password—Password of an account. A password in encrypted form is a case-sensitive string of 1 to 117 characters. A password in plaintext form is a case-sensitive string of 1 to 63 characters. If the device fails to parse the password or the password is empty, the device imports the account without a password.
· Authorization user group—User group to which a user belongs after the user passes local authentication. The group name is a case-insensitive string of 1 to 32 characters. If the parameter is empty, the device assigns the user to the system-defined user group system.
· Identity groups—Groups for identity-based access control. A user can belong to multiple identity groups. An identity group name is a case-insensitive string of 1 to 32 characters. Separate identity group names by the string of 0x0A. If the parameter is empty for a user, the user does not belong to any identity group.
· Service types—Services to assign to the user. Available services include portal, PPP, IPoE, LAN access, ADVPN, SSL VPN, and IKE. A service name is case insensitive. Separate service types by the string of 0x0A. If the parameter is empty for a user, the user cannot use any service.
· Max concurrent logins—The maximum number of online users with the same user name. The value range is 1 to 1024. If the parameter is empty, the device does not restrict the number of online users with the same user name.
Separate different accounts by a carriage return and separate each parameter value of the same account by a comma (,). To ensure a successful user information import, make sure no spaces are included in the contents. For example,
Jack,$c$3$uM6DH5empTfbsx341Qk/ORGozkbxNE0=,author-group1,parent-group1(0x0A)parent-group2,portal,1024
Mary,$c$3$YpVonswJTN1dVMEev+zu2pgrCIIJ,author-group2,parent-group1(0x0A)parent-group2,portal,800
When you edit the .csv file, follow these restrictions and guidelines:
· Start lines with pound signs (#) to contain explanation information for usage guidelines. The device does not import the lines as user account information.
· Separate parameter values by a comma (,). To avoid ambiguity, you must enclose the value of a parameter into single quotation marks (') if the value contains a comma (,). For example, if the authorization user group of a user is named as author,group, you must specify the authorization user group name as 'author,group' in the .csv file.
The device supports TFTP and FTP file transfer modes. Table 9 describes the valid URL formats of the .csv file.
Protocol |
URL format |
TFTP |
FTP |
# Import user account information from the localuser.csv file in the ftp://1.1.1.1/user/ path, and create network access users based on the imported information. Specify the device to ignore the accounts that have the same name as the existing accounts on the device. Enable the device to automatically create the user group of an imported network access user if the user group does not exist on the device.
[Sysname] local-user-import class network url ftp://1.1.1.1/user/localuser.csv auto-create-group
display local-user
Use local-user-import class network guest to import local guest account information from a .csv file in the specified path to the device to create local guests based on the imported information.
local-user-import class network guest url url-string validity-datetime start-date start-time to expiration-date expiration-time [ auto-create-group | override | start-line line-number ] *
context-admin
url url-string: Specifies the source file path. The url-string argument is a case-insensitive string of 1 to 255 characters.
validity-datetime: Specifies the guest validity period of the local guests. The expiration date and time must be later than the start date and time.
auto-create-group: Enables the device to automatically create user groups for the imported local guests if the groups in the imported information do not exist on the device. If you do not specify this keyword, the device adds all imported local guests to the system-defined user group named system.
override: Enables the device to override the existing account with the same name as an imported guest account. If you do not specify this keyword, the device retains the existing account and does not import the local guest with the same name.
start-line line-number: Specifies the number of the line at which the account import begins. If you do not specify a line number, this command imports all accounts in the .csv file.
· Username—User name of the guest account. The user name cannot be empty. The user name cannot be empty and cannot contain any of the following characters: forward slash (/), backslash (\), vertical bar (|), colon (:), asterisk (*), question mark (?), left angle bracket (<), or right angle bracket (>). The name cannot be a, al, or all. Any invalid character results in account import failure and interruption.
· Password—Password of the guest account in plaintext form. If the password is empty, the device generates a random password in encrypted form for the guest.
· User group—User group to which the guest belongs. If the user group is empty, the device assigns the guest to the system-defined user group named system.
· Guest full name—Name of the guest.
· Guest company—Company of the guest.
· Guest email—Email address of the guest.
· Guest phone—Phone number of the guest.
· Guest description—Description of the guest.
· Sponsor full name—Name of the guest sponsor.
· Sponsor department—Department of the guest sponsor.
· Sponsor email—Email address of the guest sponsor.
The value of each parameter in the file must meet the requirements of the local user attributes on the device. Any violation results in account import failure and interruption. The system displays the number of the line where the account import is interrupted.
Separate different account entries by a carriage return and separate each parameter value in an account entry by a comma (,). If the value of a parameter contains a comma (,), you must enclose the value within a pair of quotation marks ("") to avoid ambiguity. For example,
Jack,abc,visit,Jack Chen,ETP,[email protected],1399899,"The manager of ETP, come from TP.",Sam Wang,Ministry of personnel,[email protected]
The device supports TFTP and FTP file transfer modes. Table 10 describes the valid URL formats of the .csv file.
Protocol |
URL format |
TFTP |
FTP |
# Import guest account information from the ftp://1.1.1.1/user/guest.csv file and specify a validity period for the imported guests.
[Sysname] local-user-import class network guest url ftp://1.1.1.1/user/guest.csv validity-datetime 2018/10/01 00:00:00 to 2019/10/02 12:00:00
display local-user
password
Use password to configure a password for a device management user.
Use undo password to restore the default.
password [ { hash | simple } string ]
undo password
A device management user does not have a password and cannot pass authentication.
Local user view
context-admin
vsys-admin
hash: Specifies a password encrypted by the hash algorithm.
simple: Specifies a password in plaintext form. For security purposes, the password specified in plaintext form will be stored in hashed form.
string: Specifies the password string. This argument is case sensitive. The hashed form of the password is a string of 1 to 110 characters. The plaintext form of the password is a string of 1 to 63 characters.
If you do not specify any parameters, you enter the interactive mode to set a plaintext password.
A device management user for which no password is specified can pass authentication after entering the correct username and passing attribute checks. To enhance security, configure a password for each device management user.
When global password control is enabled, the device handles passwords of device management users as follows:
· All passwords in the history records are saved in hashed form.
· If a user changes its own password in plaintext form, the system requests the user to enter the current plaintext password. The new password must be different from all passwords in the history records and the current password. In addition, the new password must have a minimum of four characters different from the current password.
· If a user changes the password for another user in plaintext form, the new password must be different from the latter user's all passwords in the history records and current password.
· If a user deletes its own password, the system requests the user to enter the current plaintext password.
· Except the above listed situations, the system does not request a user to enter the current plaintext password or compare the new password with passwords in the history records and the current password.
# Set the password to 123456TESTplat&! in plaintext form for device management user user1.
# Configure the password in interactive mode for device management user test.
[Sysname-luser-manage-test] password
Password:
confirm :
display local-user
password (user view)
Use password to configure a password for a device management user in interactive mode.
password
context-admin
vsys-admin
Use this command to configure a password in interactive mode for an existing device management user without entering the user's local user view.
The password is a plaintext string of 1 to 63 characters.
· When you change a user's password in user view, the system requests you to enter the current plaintext password of the user. The new password must be different from all passwords in the history records and the current password. In addition, the new password must have a minimum of four characters different from the current password.
# Configure a password for user test.
<Sysname> password
Change password for user: test
Old password:
Enter new password:
Confirm:
password (local user view)
phone
Use phone to specify the phone number of a local guest.
Use undo phone to restore the default.
phone phone-number
undo phone
No phone number is specified for a local guest.
Local guest view
context-admin
phone-number: Specifies the phone number, a string of 1 to 32 characters.
# Specify the phone number as 13813723920 for local guest abc.
[Sysname-luser-network(guest)-abc] phone 13813723920
display local-user
Use reset local-guest waiting-approval to clear pending registration requests for local guests.
reset local-guest waiting-approval [ user-name user-name ]
context-admin
user-name user-name: Specifies a local guest by the username, a string of 1 to 55 characters. If you do not specify a guest, this command clears information about all registration requests for local guests. The username can be a pure username or a username containing a domain name.
# Clear information about all registration requests for local guests.
<Sysname> reset local-guest waiting-approval
Use service-type to specify the service types that a local user can use.
Use undo service-type to remove service types configured for a local user.
service-type { advpn | ftp | ike | ipoe | lan-access | { http | https | ssh | telnet | terminal } * | portal | ppp | sslvpn }
undo service-type { advpn | ftp | ike | ipoe | lan-access | { http | https | ssh | telnet | terminal } * | portal | ppp | sslvpn }
A local user is not authorized to use any service.
Local user view
context-admin
vsys-admin
advpn: Authorizes the user to use the ADVPN service.
ftp: Authorizes the user to use the FTP service. The authorized directory can be modified by using the authorization-attribute work-directory command.
http: Authorizes the user to use the HTTP service.
https: Authorizes the user to use the HTTPS service.
ike: Authorizes the user to use the IKE extended authentication service.
ipoe: Authorizes the user to use the IPoE service.
lan-access: Authorizes the user to use the LAN access service.
ssh: Authorizes the user to use the SSH service.
telnet: Authorizes the user to use the Telnet service.
terminal: Authorizes the user to use the terminal service and log in from a console port.
portal: Authorizes the user to use the portal service.
ppp: Authorizes the user to use the PPP service.
sslvpn: Authorizes the user to use the SSL VPN service.
You can assign multiple service types to a user.
# Authorize device management user user1 to use the Telnet and FTP services.
[Sysname-luser-manage-user1] service-type telnet
[Sysname-luser-manage-user1] service-type ftp
display local-user
sponsor-department
Use sponsor-department to specify the department of the guest sponsor for a local guest.
Use undo sponsor-department to restore the default.
sponsor-department department-string
No department is specified for the guest sponsor of a local guest.
Local guest view
context-admin
department-string: Specifies the department name, a case-sensitive string of 1 to 127 characters.
# Specify the department as test for the guest sponsor of local guest abc.
[Sysname-luser-network(guest)-abc] sponsor-department test
display local-user
sponsor-email
Use sponsor-email to specify the email address of the guest sponsor for a local guest.
Use undo sponsor-email to restore the default.
sponsor-email email-string
undo sponsor-email
No email address is specified for the guest sponsor.
Local guest view
context-admin
email-string: Specifies the email address, a case-sensitive string of 1 to 255 characters. The string must contain an at sign (@), and it can contain only one at sign (@). In addition, the string cannot contain only the at sign (@).
# Specify the email address as [email protected] for the guest sponsor of local guest abc.
[Sysname-luser-network(guest)-abc] sponsor-email [email protected]
display local-user
sponsor-full-name
Use sponsor-full-name to specify the guest sponsor name for a local guest.
Use undo sponsor-full-name to restore the default.
sponsor-full-name name-string
No guest sponsor name is specified for a local guest.
Local guest view
context-admin
name-string: Specifies the guest sponsor name, a case-sensitive string of 1 to 255 characters.
# Specify the guest sponsor name as Sam Li for local guest abc.
[Sysname-luser-network(guest)-abc] sponsor-full-name Sam Li
display local-user
state (local user view)
Use state to set the status of a local user.
Use undo state to restore the default.
undo state
A local user is in active state.
Local user view
context-admin
vsys-admin
active: Places the local user in active state to allow the local user to request network services.
block: Places the local user in blocked state to prevent the local user from requesting network services.
# Place device management user user1 in blocked state.
[Sysname-luser-manage-user1] state block
display local-user
user-group
Use user-group to create a user group and enter its view, or enter the view of an existing user group.
Use undo user-group to delete a user group.
user-group group-name
undo user-group group-name
A system-defined user group exists. The group name is system.
context-admin
vsys-admin
A user group consists of a group of local users and has a set of local user attributes. You can configure local user attributes for a user group to implement centralized management of user attributes for the local users in the group.
You cannot use the undo user-group command to delete a user group that has local users.
You can modify settings for the system-defined user group named system, but you cannot delete the user group.
# Create a user group named abc and enter user group view.
display user-group
validity-datetime
Use validity-datetime to specify the validity period for a network access user.
Use undo validity-datetime to restore the default.
Network access user view:
validity-datetime { from start-date start-time to expiration-date expiration-time | from start-date start-time | to expiration-date expiration-time }
Local guest view:
validity-datetime from start-date start-time to expiration-date expiration-time
The validity period for a network access user does not expire.
Local guest view
context-admin
vsys-admin
from: Specifies the validity start date and time for the user. If you do not specify this option, the command defines only the expiration date and time of the user.
start-date: Specifies the date on which the user becomes effective. The date is in the format of MM/DD/YYYY or YYYY/MM/DD. The value range for the MM argument is 1 to 12. The value range for the DD argument varies with the specified month. The value range for the YYYY argument is 2000 to 2035.
start-time: Specifies the time on the day when the user becomes effective. The time is in the format of hh:mm:ss. The value range for the hh argument is 0 to 23. The value range for the mm and ss arguments is 0 to 59. The mm and ss arguments are optional. For example, enter 1 to indicate 1:00:00. A value of 0 indicates 00:00:00.
to: Specifies the expiration date and time for the user. If you do not specify this option, the command defines only the validity start date and time of the user.
Expired network access user accounts cannot be used for authentication.
When both from and to options are specified, the expiration date and time must be later than the validity start date and time.
When only the from option is specified, the network access user is valid since the specified date and time.
When only the to option is specified, the network access user is valid until the specified date and time.
# Specify the validity period for network access user 123.
[Sysname-luser-network-123] validity-datetime from 2018/10/01 00:00:00 to 2019/10/02 12:00:00
display local-user
RADIUS commands
aaa device-id
Use aaa device-id to configure the device ID.
Use undo aaa device-id to restore the default.
aaa device-id device-id
undo aaa device-id
The device ID is 0.
context-admin
vsys-admin
device-id: Specifies a device ID in the range of 1 to 255.
RADIUS uses the value of the Acct-Session-ID attribute as the accounting ID for a user. The device generates an Acct-Session-ID value that includes the device ID for each online user.
If you modify the device ID, the new device ID does not take effect on users that have been online during the change.
# Configure the device ID as 1.
[Sysname] aaa device-id 1
accounting-on enable
Use accounting-on enable to configure the accounting-on feature.
Use undo accounting-on enable to disable the accounting-on feature.
accounting-on enable [ interval interval | send send-times ] *
The accounting-on feature is disabled.
RADIUS scheme view
context-admin
vsys-admin
interval interval: Specifies the time interval for retransmitting an accounting-on packet in seconds. The value range for the interval argument is 1 to 15, and the default setting is 3.
send send-times: Specifies the maximum number of accounting-on packet transmission attempts. The value range for the send-times argument is 1 to 255, and the default setting is 50.
This feature enables the device to automatically monitor the status of all accounting servers in the RADIUS scheme and then send accounting-on packets to the reachable servers after a reboot. The accounting-on packets are used to request the RADIUS servers to stop accounting on all online users on the device and to log out the users.
Execute the save command to ensure that the accounting-on enable command takes effect at the next device reboot. For information about the save command, see Fundamentals Command Reference.
Parameters set by using the accounting-on enable command take effect immediately.
# Enable the accounting-on feature for RADIUS scheme radius1, and set the retransmission interval to 5 seconds and the transmission attempts to 15.
[Sysname] radius scheme radius1
[Sysname-radius-radius1] accounting-on enable interval 5 send 15
display radius scheme
attribute 15 check-mode
Use attribute 15 check-mode to configure the Login-Service attribute check method for SSH, FTP, and terminal users.
Use undo attribute 15 check-mode to restore the default.
attribute 15 check-mode { loose | strict }
The strict check method applies for SSH, FTP, and terminal users.
RADIUS scheme view
context-admin
vsys-admin
loose: Matches the standard Login-Service attribute value 0 for SSH, FTP, and terminal services.
strict: Matches Login-Service attribute values 50, 51, and 52 for SSH, FTP, and terminal services, respectively.
Use the loose check method only when the server does not issue Login-Service attribute values 50, 51, and 52 for SSH, FTP, and terminal users.
# Configure the Login-Service attribute check method as loose for SSH, FTP, and terminal users in RADIUS scheme radius1.
[Sysname-radius-radius1] attribute 15 check-mode loose
attribute 17 old-password
Use attribute 17 old-password to enable online user password change by using RADIUS attribute 17.
Use undo attribute 17 old-password to restore the default.
Online user password change is disabled.
RADIUS scheme view
context-admin
When this feature is enabled, the process of online password change is as follows for a user when the user passes authentication:
1. If the RADIUS authentication server sends an Access-Challenge packet that includes the Reply-Message attribute when a user passes authentication, the device prompts the user to change its password.
2. After receiving the password change request from the user, the device sends a RADIUS authentication request to the RADIUS authentication server.
In the authentication request, the device uses attribute 2 to carry the new user password.
3. When the device receives a response from the RADIUS authentication server, the online user's password is changed successfully.
When this feature is enabled, the process of online password change is as follows for an online user:
1. After receiving the password change request from the user, the device sends a RADIUS authentication request to a reachable RADIUS server. In the authentication request, the device uses attribute 2 and attribute 17 to carry the new user password and old user password, respectively.
The RADIUS server selection process for online password change is the same as the process used to select a RADIUS authentication server. Online password change might fail because the device selects a RADIUS server different from the RADIUS server that authenticated the user.
2. When the device receives a response from the selected RADIUS server, the online user's password is changed successfully.
This feature is applicable only to SSL VPN users.
Do not enable this feature if the RADIUS server does not support online user password change.
In a RADIUS scheme with this feature enabled, do not configure parsing rules for the Reply-Message attribute by using the attribute 18 match command. A violation will cause this feature fail to take effect.
# In RADIUS scheme radius1, enable online user password change by using RADIUS attribute 17.
[Sysname-radius-radius1] attribute 17 old-password
attribute 18 match
attribute 18 match
Use attribute 18 match to configure a parsing rule for the RADIUS Reply-Message attribute.
Use undo attribute 18 match to remove a parsing rule for the RADIUS Reply-Message attribute.
attribute 18 match string action { new-password | next-token }
undo attribute 18 match string action
No parsing rules for the RADIUS Reply-Message attribute are configured. The device parses the Reply-Message attribute as to prompt users to enter the next authentication factor for double-factor authentication.
RADIUS scheme view
context-admin
string: Specifies a match criterion, a case-sensitive string of 1 to 255 characters. To include spaces in the string, enclose the entire string in double quotation marks ("").
action: Specifies the action that the device prompts users to take if the attribute value matches the match criterion.
new-password: Enters the new password.
next-token: Enters the next authentication factor for double-factor authentication.
The RADIUS Reply-Message attribute (attribute 18) is intended for the RADIUS server to return a message to users. In the Access-Challenge packets, this attribute indicates the action that the RADIUS server expects users to take. For the access device to correctly parse this attribute, you can configure parsing rules for this attribute. For example, the device needs to parse the Reply-Message attribute containing the new pin string as to prompt users to change the passwords online.
Each parsing rule contains a match criterion and an action. The device uses the fuzzy match method to match the Reply-Message attribute value against the match criterion. If the attribute value partially matches the match criterion, the device prompts the users to take the action specified in the parsing rule.
Before you configure parsing rules, make sure you fully understand the implications of the Reply-Message attribute defined by the RADIUS server.
For a RADIUS scheme, you can configure a maximum of 18 parsing rules for the Reply-Message attribute. Make sure the match criterion in each parsing rule is not contained by the match criterion of another parsing rule.
When parsing rules for the Reply-Message attribute are configured, the online user password change feature configured by using the attribute 17 old-password command does not take effect. As a best practice, do not configure both parsing rules and online user password change in the same RADIUS scheme.
# In RADIUS scheme radius1, configure a parsing rule for the Reply-Message attribute. According to this rule, the device will prompt users to enter the new password if the Reply-Message attribute contain string new pin.
[sysname] radius scheme radius1
[sysname-radius-radius1] attribute 18 match “new pin” action new-password
attribute 25 car
Use attribute 25 car to configure the device to interpret the RADIUS class attribute (attribute 25) as CAR parameters.
Use undo attribute 25 car to restore the default.
attribute 25 car
The RADIUS class attribute is not interpreted as CAR parameters.
RADIUS scheme view
context-admin
Configure the device to interpret the RADIUS class attribute if the RADIUS server uses the attribute to deliver CAR parameters for user-based traffic monitoring and control.
# In RADIUS scheme radius1, configure the device to interpret the RADIUS class attribute as CAR parameters.
[Sysname-radius-radius1] attribute 25 car
attribute 30 mac-format
Use attribute 30 mac-format to configure the format of the MAC address in the RADIUS Called-Station-Id attribute.
Use undo attribute 30 mac-format to restore the default.
attribute 30 mac-format section { one | { six | three } separator separator-character } { lowercase | uppercase }
The MAC address in the RADIUS Called-Station-Id attribute is in the format of HH-HH-HH-HH-HH-HH. The MAC address is separated by hyphens (-) into six sections with letters in upper case.
RADIUS scheme view
context-admin
section: Specifies the number of sections that a MAC address contains.
one: Specifies the one-section format HHHHHHHHHHHH.
six: Specifies the six-section format HH-HH-HH-HH-HH-HH.
three: Specifies the three-section format HHHH-HHHH-HHHH.
separator separator-character: Specifies a case-sensitive character that separates the sections.
lowercase: Specifies the letters in a MAC address to be in lower case.
uppercase: Specifies the letters in a MAC address to be in upper case.
Configure the format of the MAC address in the RADIUS Called-Station-Id attribute to meet the requirements of the RADIUS servers.
# In RADIUS scheme radius1, specify hhhhhhhhhhhh as the format of the MAC address in the RADIUS Called-Station-Id attribute.
[Sysname-radius-radius1] attribute 30 mac-format section one lowercase
attribute 31 mac-format
Use attribute 31 mac-format to configure the format of the MAC address in the RADIUS Calling-Station-Id attribute.
Use undo attribute 31 mac-format to restore the default.
attribute 31 mac-format section { one | { six | three } separator separator-character } { lowercase | uppercase }
The MAC address in the RADIUS Calling-Station-Id attribute (attribute 31) is in the format of HH-HH-HH-HH-HH-HH. The MAC address is separated by hyphens (-) into six sections with letters in upper case.
RADIUS scheme view
context-admin
Configure the the format of the MAC address in the RADIUS Calling-Station-Id attribute to meet the requirements of the RADIUS servers.
# In RADIUS scheme radius1, specify hh:hh:hh:hh:hh:hh as the format of the MAC address in the RADIUS Calling-Station-Id attribute.
[Sysname-radius-radius1] attribute 31 mac-format section six separator : lowercase
attribute 182 vendor-id 25506 vlan
Use attribute 182 vendor-id 25506 vlan to enable the device to interpret the Microsegment-Id attribute to an authorization VLAN.
Use undo attribute 182 vendor-id 25506 vlan to disable the device from interpreting the Microsegment-Id attribute to an authorization VLAN.
The device is disabled from interpreting the Microsegment-Id attribute to an authorization VLAN.
RADIUS scheme view
context-admin
Use this command only when the RADIUS server uses authorization microsegment IDs for granular user access control and the access device uses authorization VLANs to implement microsegment-based access control.
This feature enables the device to interpret the RADIUS Microsegment-Id attribute (attribute 182 with vendor ID 25506) assigned by the RADIUS server to an authorization VLAN.
· If the attribute value is an integer, the device interprets this attribute to a VLAN ID.
· If the attribute value is not an integer, the device interprets this attribute to a VLAN name.
If the RADIUS server uses a RADIUS attribute other than the Microsegment-Id attribute to assign microsegment IDs, you must first convert the attribute to the Microsegment-Id attribute. To enable RADIUS attribute translation feature, use the attribute translate command.
# In RADIUS scheme radius1, enable the device to interpret the Microsegment-Id attribute to an authorization VLAN.
[Sysname-radius-radius1] attribute 182 vendor-id 25506 vlan
attribute translate
attribute convert (RADIUS DAS view)
Use attribute convert to configure a RADIUS attribute conversion rule.
Use undo attribute convert to delete RADIUS attribute conversion rules.
attribute convert src-attr-name to dest-attr-name { { coa-ack | coa-request } * | { received | sent } * }
undo attribute convert [ src-attr-name ]
No RADIUS attribute conversion rules exist. The system processes RADIUS attributes according to the principles of the standard RADIUS protocol.
RADIUS DAS view
context-admin
src-attr-name: Specifies the source RADIUS attribute by its name, a case-insensitive string of 1 to 63 characters. The attribute must be supported by the system.
dest-attr-name: Specifies the destination RADIUS attribute by its name, a case-insensitive string of 1 to 63 characters. The attribute must be supported by the system.
coa-ack: Specifies the CoA acknowledgment packets.
coa-request: Specifies the CoA request packets.
received: Specifies the received DAE packets.
sent: Specifies the sent DAE packets.
The device replaces the attribute in packets that match a RADIUS attribute conversion rule with the destination RADIUS attribute in the rule.
The conversion rules take effect only when the RADIUS attribute translation feature is enabled.
When you configure RADIUS attribute conversion rules, follow these restrictions and guidelines:
· The source and destination RADIUS attributes in a rule must use the same data type.
· The source and destination RADIUS attributes in a rule cannot use the same name.
· A source RADIUS attribute can be converted only by one criterion, packet type or direction.
· One source RADIUS attribute cannot be converted to multiple destination attributes.
If you do not specify a source RADIUS attribute, the undo attribute convert command deletes all RADIUS attribute conversion rules.
# In RADIUS DAS view, configure a RADIUS attribute conversion rule to replace the Hw-Server-String attribute in the received DAE packets with the Connect-Info attribute.
[Sysname] radius dynamic-author server
[Sysname-radius-da-server] attribute convert Hw-Server-String to Connect-Info received
attribute translate
attribute convert (RADIUS scheme view)
attribute convert src-attr-name to dest-attr-name { { access-accept | access-request | accounting } * | { received | sent } * }
RADIUS scheme view
context-admin
access-accept: Specifies the RADIUS Access-Accept packets.
access-request: Specifies the RADIUS Access-Request packets.
accounting: Specifies the RADIUS accounting packets.
received: Specifies the received RADIUS packets.
sent: Specifies the sent RADIUS packets.
# In RADIUS scheme radius1, configure a RADIUS attribute conversion rule to replace the Hw-Server-String attribute of received RADIUS packets with the Connect-Info attribute.
[Sysname-radius-radius1] attribute convert Hw-Server-String to Connect-Info received
attribute translate
attribute reject (RADIUS DAS view)
Use attribute reject to configure a RADIUS attribute rejection rule.
Use undo attribute reject to delete RADIUS attribute rejection rules.
attribute reject attr-name { { coa-ack | coa-request } * | { received | sent } * }
undo attribute reject [ attr-name ]
No RADIUS attribute rejection rules exist.
RADIUS DAS view
context-admin
attr-name: Specifies a RADIUS attribute by its name, a case-insensitive string of 1 to 63 characters. The attribute must be supported by the system.
Configure RADIUS attribute rejection rules for the following purposes:
· Delete attributes from the RADIUS packets to be sent if the destination RADIUS server does not identify the attributes.
· Ignore unwanted attributes in the RADIUS packets received from a RADIUS server.
The RADIUS attribute rejection rules take effect only when the RADIUS attribute translation feature is enabled.
A RADIUS attribute can be rejected only by one criterion, packet type or direction.
If you do not specify a RADIUS attribute, the undo attribute reject command deletes all RADIUS attribute rejection rules.
# In RADIUS DAS view, configure a RADIUS attribute rejection rule to delete the Connect-Info attribute from the DAE packets to be sent.
[Sysname-radius-da-server] attribute reject Connect-Info sent
attribute translate
attribute reject (RADIUS scheme view)
attribute reject attr-name { { access-accept | access-request | accounting } * | { received | sent } * }
RADIUS scheme view
context-admin
# In RADIUS scheme radius1, configure a RADIUS attribute rejection rule to delete the Connect-Info attribute from the RADIUS packets to be sent.
[Sysname-radius-radius1] attribute reject Connect-Info sent
attribute translate
attribute remanent-volume
Use attribute remanent-volume to set the data measurement unit for the Remanent_Volume attribute.
Use undo attribute remanent-volume to restore the default.
attribute remanent-volume unit { byte | giga-byte | kilo-byte | mega-byte }
undo attribute remanent-volume unit
The data measurement unit is kilobyte for the Remanent_Volume attribute.
RADIUS scheme view
context-admin
byte: Specifies the unit as byte.
giga-byte: Specifies the unit as gigabyte.
kilo-byte: Specifies the unit as kilobyte.
mega-byte: Specifies the unit as megabyte.
Make sure the measurement unit is the same as the user data measurement unit on the RADIUS server.
# In RADIUS scheme radius1, set the data measurement unit to kilobyte for the Remanent_Volume attribute.
[Sysname-radius-radius1] attribute remanent-volume unit kilo-byte
attribute translate
Use attribute translate to enable the RADIUS attribute translation feature.
Use undo attribute translate to disable the RADIUS attribute translation feature.
attribute translate
The RADIUS attribute translation feature is disabled.
RADIUS DAS view
RADIUS scheme view
context-admin
To cooperate with RADIUS servers of different vendors, enable the RADIUS attribute translation feature. Configure RADIUS attribute conversion rules and rejection rules to ensure that RADIUS attributes in the packets exchanged between the device and the server are supported by both sides.
# Enable the RADIUS attribute translation feature for RADIUS scheme radius1.
[Sysname-radius-radius1] attribute translate
attribute vendor-id 2011 version
Use attribute vendor-id 2011 version to specify the version of the RADIUS servers with a vendor ID of 2011.
Use undo attribute vendor-id 2011 version to restore the default.
attribute vendor-id 2011 version { 1.0 | 1.1 }
The version is 1.0.
RADIUS scheme view
context-admin
1.0: Specifies version 1.0.
1.1: Specifies version 1.1.
For the device to correctly interpret RADIUS attributes from the servers with a vendor ID of 2011, specify a server version the same as the actual version of the RADIUS servers.
The following table shows the differences in the way that the device interprets the vendor-specific RADIUS attributes assigned by different versions of RADIUS servers with vendor ID 2011.
RADIUS attribute |
RADIUS server with version 1.0 |
RADIUS server with version 1.1 |
HW_ARRT_26_1 |
Upstream peak rate |
Upstream burst size |
HW_ARRT_26_2 |
Upstream average rate |
HW_ARRT_26_3 |
N/A |
HW_ARRT_26_4 |
Downstream peak rate |
Downstream burst size |
HW_ARRT_26_5 |
Downstream average rate |
HW_ARRT_26_6 |
N/A |
# In RADIUS scheme radius1, specify the version of the RADIUS servers with a vendor ID of 2011 as version 1.1.
[Sysname-radius-radius1] attribute vendor-id 2011 version 1.1
client
Use client to specify a RADIUS DAC.
Use undo client to remove a RADIUS DAC.
client { ip ipv4-address | ipv6 ipv6-address } [ key { cipher | simple } string | vendor-id 2011 version { 1.0 | 1.1 } | vpn-instance vpn-instance-name ] *
undo client { ip ipv4-address | ipv6 ipv6-address } [ vpn-instance vpn-instance-name ]
No RADIUS DACs are specified.
RADIUS DAS view
context-admin
ip ipv4-address: Specifies a DAC by its IPv4 address.
ipv6 ipv6-address: Specifies a DAC by its IPv6 address.
key: Specifies the shared key for secure communication between the RADIUS DAC and server. Make sure the shared key is the same as the key configured on the RADIUS DAC. If the RADIUS DAC does not have any shared key, do not specify this option.
cipher: Specifies the key in encrypted form.
simple: Specifies the key in plaintext form. For security purposes, the key specified in plaintext form will be stored in encrypted form.
string: Specifies the key. This argument is case sensitive. The encrypted form of the key is a string of 1 to 117 characters. The plaintext form of the key is a string of 1 to 64 characters.
vendor-id 2011: Specifies the vendor-ID of the DAC as 2011.
version: Specifies the version of the DAC.
1.0: Specifies the DAC version as version 1.0.
1.1: Specifies the DAC version as version 1.1.
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN instance to which the RADIUS DAC belongs. The vpn-instance-name argument is a case-sensitive string of 1 to 31 characters. If the server is on the public network, do not specify this option.
With the RADIUS DAS feature, the device listens to the default or specified UDP port to receive DAE requests from the specified DACs. The device processes the requests and sends DAE responses to the DACs.
The device discards any DAE packets sent from DACs that are not specified for the DAS.
You can execute the client command multiple times to specify multiple DACs for the DAS.
To work with a DAC with vendor-ID 2011 and version 1.0, you do not need to specify the vendor-ID or version attribute. To work with a DAC with vendor-ID 2011 and version 1.1, you must specify the vendor-id 2011 version 1.1 keywords.
# Specify the DAC as 10.110.1.2. Set the shared key to 123456 in plaintext form for secure communication between the DAS and DAC.
[Sysname-radius-da-server] client ip 10.110.1.2 key simple 123456
port
data-flow-format (RADIUS scheme view)
Use data-flow-format to set the data flow and packet measurement units for traffic statistics.
Use undo data-flow-format to restore the default.
data-flow-format { data { byte | giga-byte | kilo-byte | mega-byte } | packet { giga-packet | kilo-packet | mega-packet | one-packet } } *
undo data-flow-format { data | packet }
Traffic is counted in bytes and packets.
RADIUS scheme view
context-admin
data: Specifies the unit for data flows.
packet: Specifies the unit for data packets.
giga-packet: Specifies the unit as giga-packet.
kilo-packet: Specifies the unit as kilo-packet.
mega-packet: Specifies the unit as mega-packet.
one-packet: Specifies the unit as one-packet.
The data flow and packet measurement units for traffic statistics must be the same as configured on the RADIUS accounting servers. Otherwise, accounting results might be incorrect.
# In RADIUS scheme radius1, set the data flow and packet measurement units for traffic statistics to kilobyte and kilo-packet, respectively.
[Sysname-radius-radius1] data-flow-format data kilo-byte packet kilo-packet
Use display radius scheme to display RADIUS scheme configuration.
display radius scheme [ radius-scheme-name ]
context-admin
context-operator
vsys-admin
vsys-operator
radius-scheme-name: Specifies a RADIUS scheme by its name, a case-insensitive string of 1 to 32 characters. If you do not specify a RADIUS scheme, this command displays the configuration of all RADIUS schemes.
When displaying configuration only for one scheme, this command also displays the active state duration for each active server and the most recent five state changes for all servers in the scheme.
When displaying configuration for all schemes, this command also displays the active state duration for each active server and the most recent blocked period for all servers in all schemes.
# Display the configuration of all RADIUS schemes.
<Sysname> display radius scheme
Total 1 RADIUS schemes
RADIUS scheme name: radius1
Index : 0
Primary authentication server:
IP : 2.2.2.2 Port: 1812
VPN : vpn1
State: Active (duration: 1 weeks, 2 days, 1 hours, 32 minutes, 34 seconds)
Most recent blocked period: 2019/08/08 20:33:45 – 2019/08/08 20:38:45
Test profile: 132
Probe username: test
Probe interval: 60 minutes
Probe count : 5
Weight: 40
Primary accounting server:
IP : 1.1.1.1 Port: 1813
VPN : Not configured
Most recent blocked period: 2019/08/08 20:33:45 - 2019/08/08 20:38:45
Weight: 40
Second authentication server:
IP : 3.3.3.3 Port: 1812
State: Blocked
Most recent blocked period: 2019/08/08 20:33:45 - now
Test profile: Not configured
Weight: 40
Second accounting server:
Host name: Not configured
IP : 3.3.3.3 Port: 1813
State: Blocked (mandatory)
Weight: 40
Accounting-On function : Enabled
extended function : Disabled
retransmission times : 5
retransmission interval(seconds) : 2
Timeout Interval(seconds) : 3
Retransmission Times : 3
Retransmission Times for Accounting Update : 5
Server Quiet Period(minutes) : 5
Realtime Accounting Interval(seconds) : 22
NAS IP Address : 1.1.1.1
User Name Format : with-domain
Data flow unit : Megabyte
Packet unit : One
Attribute 15 check-mode : Strict
Attribute 25 : CAR
Attribute Remanent-Volume unit : Mega
RADIUS server version (vendor ID 2011) : 1.0
Server-load-sharing : Enabled
Attribute 30 MAC format : hh:hh:hh:hh:hh:hh
Attribute 31 MAC format : hh:hh:hh:hh:hh:hh
Attribute 17 carry old password : Disabled
Attribute 182 vendor-ID 25506 VLAN : Enabled
Stop-accounting-packet send-force : Disabled
H3c-DHCP-Option attribute format : Format 2 (2-byte Type field)
Username authorization : Applied
# Display the configuration of RADIUS scheme radius1.
<Sysname> display radius scheme radius1
Index: 0
Most recent state changes:
2019/08/08 20:38:45 Changed to active state
2019/08/08 20:33:45 Changed to blocked state
2019/08/08 20:31:19 Changed to active state
2019/08/08 20:26:19 Changed to blocked state
2019/08/08 20:26:00 Changed to active state
Test profile: 132
Probe count : 5
Weight: 40
Weight: 40
State: Blocked
2019/08/08 20:56:22 Changed to blocked state
2019/08/08 20:48:45 Changed to active state
2019/08/08 20:43:45 Changed to blocked state
2019/08/08 20:41:19 Changed to active state
2019/08/08 20:46:19 Changed to blocked state
Weight: 40
Weight: 40
Accounting-On function : Disabled
Packet unit : One
Attribute 25 : CAR
Attribute 30 MAC format : HH-HH-HH-HH-HH-HH
Parsing rules for attribute 18:
If match: "new pin"
Action: New password
If match: "challenge"
Action: Next token
Table 11 Command output
Index |
Index number of the RADIUS scheme. |
Primary authentication server |
Information about the primary authentication server. |
Primary accounting server |
Information about the primary accounting server. |
Second authentication server |
Information about the secondary authentication server. |
Second accounting server |
Information about the secondary accounting server. |
IP |
IP address of the server. This field displays Not configured if the server is not configured. |
Port |
Service port number of the server. If no port number is specified, this field displays the default port number. |
State |
Status of the server: · Active—The server is in active state. · Blocked—The server is changed to blocked state automatically. · Blocked (mandatory)—The server is set to blocked state manually. |
duration |
The duration of the current active state for the server. This field is displayed only when the server is in active state. |
Most recent blocked period |
Most recent blocking start time and end time when the server stayed in blocked state. If the server still remains in blocked state, now is displayed for the end time. |
Most recent state changes |
Most recent five state changes of the server. |
VPN |
MPLS L3VPN instance to which the server or the RADIUS scheme belongs. If no VPN instance is specified for the server, this field displays Not configured. |
Test profile |
Test profile used for RADIUS server status detection. |
Probe username |
Username used for RADIUS server status detection. |
Probe interval |
Server status detection interval, in minutes. |
Probe count |
Number of consecutive probe intervals that the device takes to determine the reachability of a RADIUS server. |
Weight |
Weight of the RADIUS server. |
Accounting-On function |
Whether the accounting-on feature is enabled. |
extended function |
Whether the extended accounting-on feature is enabled. |
retransmission times |
Number of accounting-on packet transmission attempts. |
retransmission interval(seconds) |
Interval at which the device retransmits accounting-on packets, in seconds. |
Timeout Interval(seconds) |
RADIUS server response timeout period, in seconds. |
Retransmission times |
Maximum number of attempts for transmitting a RADIUS packet to a single RADIUS server. |
Retransmission Times for Accounting Update |
Maximum number of accounting attempts. |
Server Quiet Period(minutes) |
Quiet period for the servers, in minutes. |
Realtime Accounting Interval(seconds) |
Interval for sending real-time accounting updates, in seconds. |
NAS IP Address |
Source IP addresses for outgoing RADIUS packets. This field displays Not configured if no source IP addresses are specified for outgoing RADIUS packets. |
User Name Format |
Format for the usernames sent to the RADIUS server: · with-domain—Includes the domain name. · without-domain—Excludes the domain name. · keep-original—Forwards the username as the username is entered. |
Data flow unit |
Measurement unit for data flow. |
Packet unit |
Measurement unit for packets. |
Attribute 15 check-mode |
RADIUS Login-Service attribute check method for SSH, FTP, and terminal users: · Strict—Matches Login-Service attribute values 50, 51, and 52 for SSH, FTP, and terminal services, respectively. · Loose—Matches the standard Login-Service attribute value 0 for SSH, FTP, and terminal services. |
Attribute 25 |
RADIUS attribute 25 interpretation status: · Standard—The attribute is not interpreted as CAR parameters. · CAR—The attribute is interpreted as CAR parameters. |
Attribute Remanent-Volume unit |
Data measurement unit for the RADIUS Remanent_Volume attribute. |
RADIUS server version (vendor ID 2011) |
Version of the RADIUS servers with a vendor ID of 2011: · 1.0. · 1.1. |
Server-load-sharing |
Status of the RADIUS server load sharing feature: · Disabled—The feature is disabled. The device forwards traffic to the server selected based on the server role (primary or secondary) and server availability. · Enabled—The feature is enabled. The device distributes traffic across the available servers for load sharing. |
Attribute 30 MAC format |
Format of the MAC address in the RADIUS Called-Station-Id attribute. |
Attribute 31 MAC format |
Format of the MAC address in the RADIUS Calling-Station-Id attribute. |
Attribute 17 carry old password |
Status of online user password change by using RADIUS attribute 17: · Enabled—Online user password change by using RADIUS attribute 17 is enabled. The device uses RADIUS attribute 17 to carry a user's old password. · Disabled—Online user password change by using RADIUS attribute 17 is disabled. |
Attribute 182 vendor-ID 25506 VLAN |
Whether the device is enabled to interpret the Microsegment-Id attribute (attribute 182 with vendor ID 25506) to an authorization VLAN. |
H3c-DHCP-Option attribute format |
Encapsulation format for the H3c-DHCP-Option attribute in outgoing RADIUS packets: · Format 1 (1-byte Type field)—In this format, the length of the Type field is 1 byte. Use this format for the device to cooperate with RADIUS servers of most vendors. · Format 2 (2-byte Type field)—In this format, the length of the Type field is 2 bytes. Use this format for the device to cooperate with RADIUS servers of special vendors (HUAWEI, for example). This field is not displayed if the device does not include the H3c-DHCP-Option attribute in outgoing RADIUS packets. |
Username authorization |
Whether to allow the device to use the server-assigned usernames for AAA processes subsequent to authentication: · Applied—The device uses the server-assigned usernames for AAA processes subsequent to authentication. · Not applied—The device uses the usernames used in authentication for AAA processes subsequent to authentication. |
Parsing rules for attribute 18 |
Rules for the device to parse the RADIUS Reply-Message attribute. |
If match |
Match criterion, a string enclosed by double quotation marks (""). |
Action |
Action for users to take when the Reply-Message attribute value matches the criterion: · New password—Enters the new password. · Next token—Enters the next authentication factor for double-factor authentication. |
display radius server-load statistics
Use display radius server-load statistics to display authentication and accounting load statistics for all RADIUS servers.
context-admin
context-operator
vsys-admin
vsys-operator
This command displays the following statistics:
· Last-5-second statistics—Total number of authentication or accounting requests sent to each RADIUS server over the most recent 5 seconds.
· History statistics—Total number of authentication or accounting requests sent to each RADIUS server since startup of the device.
The device uses the following mechanisms to collect statistics:
· Last-5-second statistics—The device polls the number of requests sent to an authentication or accounting server every 5 seconds, starting from the first request. When you execute this command, you can view the statistics collected for the most recent 5 seconds.
· History statistics—The device maintains a request counter for each RADIUS authentication or accounting server. The request counter for a server increases by 1 every time it sends an authentication or accounting-start request to that server. The request counter does not decrease when users go offline or the device fails to receive a response from the server upon expiration of the response timeout timer.
Based on these statistics, you can tune the server weights or change the sequence in which the servers were configured to balance load across available RADIUS servers. The last-5-second statistics would be empty if no users triggered authentication or accounting in the most recent 5 seconds. In this situation, use the history statistics to make a server configuration tuning decision.
This command displays statistics for all RADIUS servers specified in the RADIUS schemes.
The device deletes the statistic entry for a RADIUS server in the following situations:
· The server is removed from the RADIUS scheme that contains it.
· The server has the primary role and its VPN instance, IP address, or service port number changes. This is because a RADIUS scheme can have only one primary server.
If you change the VPN instance, IP address, or service port number of a secondary server, the device does not remove the original statistic entry for the server. Instead, the device creates a new statistic entry for the server.
When an active/standby switchover occurs, the device deletes the last-5-second statistics, but it retains the history statistics. Be aware that the history statistics might be inaccurate in this situation.
# Display load statistics for all RADIUS authentication and accounting servers.
<Sysname> display radius server-load statistics
Authentication servers: 2
IP VPN Port Last 5 sec History
1.1.1.1 N/A 1812 20 100
2.2.2.2 ABC 1812 0 20
Accounting servers: 2
1.1.1.1 N/A 1813 20 100
2.2.2.2 ABC 1813 0 20
Table 12 Command output
Authentication servers |
Total number of RADIUS authentication servers. |
Accounting servers |
Total number of RADIUS accounting servers. |
IP |
IP address of a RADIUS server. |
VPN |
MPLS L3VPN instance to which the RADIUS server belongs. This field displays N/A if no VPN instance is specified for the server. |
Port |
Service port number of the RADIUS server. |
Last 5 sec |
Total number of RADIUS authentication or accounting requests sent to the RADIUS server over the most recent 5 seconds. |
History |
Total number of RADIUS authentication or accounting requests sent to the RADIUS server since the device started up. |
reset radius server-load statistics
display radius statistics
Use display radius statistics to display RADIUS packet statistics.
context-admin
context-operator
vsys-admin
vsys-operator
# Display RADIUS packet statistics.
<Sysname> display radius statistics
Auth. Acct. SessCtrl.
Request Packet: 0 0 0
Retry Packet: 0 0 -
Timeout Packet: 0 0 -
Access Challenge: 0 - -
Account Start: - 0 -
Account Update: - 0 -
Account Stop: - 0 -
Terminate Request: - - 0
Set Policy: - - 0
Packet With Response: 0 0 0
Packet Without Response: 0 0 -
Access Rejects: 0 - -
Dropped Packet: 0 0 0
Check Failures: 0 0 0
Table 13 Command output
Auth. |
Authentication packets. |
Acct. |
Accounting packets. |
SessCtrl. |
Session-control packets. |
Request Packet |
Number of request packets. |
Retry Packet |
Number of retransmitted request packets. |
Timeout Packet |
Number of request packets timed out. |
Access Challenge |
Number of access challenge packets. |
Account Start |
Number of start-accounting packets. |
Account Update |
Number of accounting update packets. |
Account Stop |
Number of stop-accounting packets. |
Terminate Request |
Number of packets for logging off users forcibly. |
Set Policy |
Number of packets for updating user authorization information. |
Packet With Response |
Number of packets for which responses were received. |
Packet Without Response |
Number of packets for which no responses were received. |
Access Rejects |
Number of Access-Reject packets. |
Dropped Packet |
Number of discarded packets. |
Check Failures |
Number of packets with checksum errors. |
reset radius statistics
exclude
Use exclude to exclude an attribute from RADIUS requests.
Use undo exclude to cancel the configuration of excluding an attribute from RADIUS requests.
exclude { accounting | authentication } name attribute-name
undo exclude { accounting | authentication } name attribute-name
No attributes are configured to be excluded from RADIUS requests.
RADIUS attribute test group view
context-admin
accounting: Specifies RADIUS accounting requests.
authentication: Specifies RADIUS authentication requests.
name attribute-name: Specifies a RADIUS attribute by its name, a case-insensitive string of 1 to 63 characters. The specified attribute must be an attribute that RADIUS requests carry by default. Available attributes that you can specify for RADIUS authentication requests include Service-Type, Framed-Protocol, NAS-Identifier, Acct-Session-Id, and NAS-Port-Type. Available attributes that you can specify for RADIUS accounting requests include NAS-Identifier, Acct-Delay-Time, Acct-Session-Id, and Acct-Terminate-Cause.
Non-default vSystems do not support this command.
Use this command to exclude an attribute from RADIUS requests sent during an AAA test to help troubleshoot authentication or accounting failures.
Before you exclude an attribute that is already configured to be included in RADIUS requests, you must cancel the inclusion configuration by using the undo include command.
# In RADIUS attribute test group t1, exclude Service-Type attribute from RADIUS authentication requests.
[Sysname] radius attribute-test-group t1
[Sysname-radius-attr-test-grp-t1] exclude authentication name Service-Type
include
test-aaa
include
Use include to include an attribute in RADIUS requests.
Use undo include to cancel the configuration of including an attribute in RADIUS requests.
include { accounting | authentication } { name attribute-name | [ vendor vendor-id ] code attribute-code } type { binary | date | integer | interface-id | ip | ipv6 | ipv6-prefix | octets | string } value attribute-value
undo include { accounting | authentication} { name attribute-name | [ vendor vendor-id ] code attribute-code }
No attributes are configured to be included in RADIUS authentication or accounting requests.
context-admin
name attribute-name: Specifies a standard RADIUS attribute by its name, a case-insensitive string of 1 to 63 characters.
vendor vendor-id: Specifies a vendor by its ID in the range of 1 to 65535. If you do not specify a vendor, this command includes a standard attribute in RADIUS requests. Table 14 shows the vendor IDs of supported vendors.
Table 14 Supported vendors and vendor IDs
Vendor |
Vendor ID |
Vendor |
Vendor ID |
Vendor |
Vendor ID |
HUAWEI |
2011 |
H3C |
25506 |
Microsoft |
311 |
3COM |
43 |
DSL Forum |
3561 |
China Telecom |
20942 |
Wi-Fi Alliance |
40808 |
Juniper |
2636 |
CMCC |
28357 |
Cisco |
9 |
code attribute-code: Specifies a RADIUS attribute by its code in the range of 1 to 255.
type: Specifies a data type for the attribute content.
binary: Binary type.
date: Date type.
integer: Integer type.
interface-id: Interface ID type.
ip: IPv4 address type.
ipv6: IPv6 address type.
ipv6-prefix: IPv6 address prefix type.
octets: Octet type.
string: String type.
value attribute-value: Specifies the value for the attribute of the data type. The value range of the attribute-value argument varies by data type.
· For the binary type, the value is a string of 1 to 256 hexadecimal characters, which represents a binary number with a maximum of 128 bytes.
· For the date type, the value range is 0 to 4294967295.
· For the integer type, the value range is 0 to 4294967295.
· For the interface ID type, the value range is 1 to ffffffffffffffff.
· For the IPv6 address prefix type, the value is in the format of prefix/prefix-length.
· For the octet type, the value is a string of 1 to 256 hexadecimal characters, which represents an octet number with a maximum of 128 bytes.
· For the string type, the value of this argument is a string of 1 to 253 characters.
RADIUS requests carry some attributes by default. For these attributes, you can use the include command to change its value or use the undo include command to restore its value to the default. Table 15 shows the attributes that RADIUS requests carry by default.
Table 15 Attributes that RADIUS requests carry by default
Packet type |
Attributes that the type of packets carry by default |
RADIUS authentication request |
User-Name CHAP-Password (or User-Password) CHAP-Challenge NAS-IP-Address (or NAS-IPv6-Address) Service-Type Framed-Protocol NAS-Identifier NAS-Port-Type Acct-Session-Id |
RADIUS accounting request |
User-Name Acct-Status-Type NAS-IP-Address (or NAS-IPv6-Address) NAS-Identifier Acct-Session-Id Acct-Delay-Time Acct-Terminate-Cause |
For the accuracy of AAA tests, the value of an attribute must be of the data type specified for that attribute.
The attribute names of standard attributes saved in the configuration file will be converted to attribute codes.
Before you include an attribute that is already configured to be excluded from RADIUS requests, you must cancel the exclusion configuration by using the undo exclude command.
You can include multiple attributes in RADIUS requests. The device adds the included attributes to RADIUS packets in the order they are configured. If the length of a RADIUS request reaches 4096 bytes, the device will not add the remaining attributes to the request. As a best practice, include a reasonable number of attributes in RADIUS requests.
# In RADIUS attribute test group t1, include Calling-Station-Id attribute with value 08-00-27-00-34-D8 in RADIUS authentication requests.
[Sysname-radius-attr-test-grp-t1] include authentication name Calling-Station-Id type string value 08-00-27-00-34-d8
exclude
test-aaa
include-attribute h3c-dhcp-option
Use include-attribute h3c-dhcp-option to include the proprietary H3c-DHCP-Option attribute in outgoing RADIUS packets.
Use undo include-attribute h3c-dhcp-option to restore the default.
include-attribute h3c-dhcp-option format { format1 | format2 }
Outgoing RADIUS packets do not include the proprietary H3c-DHCP-Option attribute.
RADIUS scheme view
context-admin
format: Specifies the encapsulation format for the proprietary H3c-DHCP-Option attribute.
format1: Specifies format 1. In this format, the length of the Type field in the H3c-DHCP-Option attribute is 1 byte. Use this format when the device cooperates with RADIUS servers of most vendors.
format2: Specifies format 2. In this format, the length of the Type field in the H3c-DHCP-Option attribute is 2 bytes. Use this format when the device cooperates with RADIUS servers of special vendors (HUAWEI, for example).
The RADIUS Vendor-Specific attribute (attribute 26) allows vendors to define extended attributes to implement functions that the standard RADIUS protocol does not provide. H3C defines the proprietary H3c-DHCP-Option attribute to carry user DHCP option information.
To send user DHCP option information to RADIUS servers, use this command to include the proprietary H3c-DHCP-Option attribute in outgoing RADIUS authentication requests, start-accounting requests, and update-accounting requests.
Determine whether to include the proprietary attribute in outgoing RADIUS packets and which attribute encapsulation format to use based on the requirements of RADIUS servers.
# In RADIUS scheme rad, include the proprietary H3c-DHCP-Option attribute in outgoing RADIUS packets and use attribute encapsulation format 2.
[Sysname-radius-rad] include-attribute h3c-dhcp-option format format2
key (RADIUS scheme view)
Use key to set the shared key for secure RADIUS authentication or accounting communication.
Use undo key to delete the shared key for secure RADIUS authentication or accounting communication.
key { accounting | authentication } { cipher | simple } string
undo key { accounting | authentication }
No shared key is configured for secure RADIUS authentication or accounting communication.
RADIUS scheme view
context-admin
vsys-admin
accounting: Specifies the shared key for secure RADIUS accounting communication.
authentication: Specifies the shared key for secure RADIUS authentication communication.
The shared keys configured by using this command apply to all servers in the scheme. Make sure the settings match the shared keys configured on the RADIUS servers.
The shared keys specified for specific RADIUS servers take precedence over the shared key specified with this command.
# In RADIUS scheme radius1, set the shared key to ok in plaintext form for secure accounting communication.
[Sysname-radius-radius1] key accounting simple ok
nas-ip (RADIUS scheme view)
Use nas-ip to specify a source IP address for outgoing RADIUS packets.
Use undo nas-ip to delete the specified source IP address for outgoing RADIUS packets.
nas-ip { ipv4-address | ipv6 ipv6-address }
undo nas-ip [ ipv6 ]
The source IP address of an outgoing RADIUS packet is that specified by using the radius nas-ip command in system view.
If the radius nas-ip command is not used, the source IP address is the primary IP address of the outbound interface.
RADIUS scheme view
context-admin
vsys-admin
ipv4-address: Specifies an IPv4 address, which must be an address of the device. The IP address cannot be 0.0.0.0, 255.255.255.255, a class D address, a class E address, or a loopback address.
ipv6 ipv6-address: Specifies an IPv6 address, which must be a unicast address of the device and cannot be a loopback address or a link-local address.
The source IP address of RADIUS packets that a NAS sends must match the IP address of the NAS that is configured on the RADIUS server. A RADIUS server identifies a NAS by its IP address. Upon receiving a RADIUS packet, the RADIUS server checks the source IP address of the packet.
· If the source IP address of the packet is the IP address of a managed NAS, the server processes the packet.
· If the source IP address of the packet is not the IP address of a managed NAS, the server drops the packet.
As a best practice, specify a loopback interface address as the source IP address for outgoing RADIUS packets to avoid RADIUS packet loss caused by physical port errors.
If you use both the nas-ip command and radius nas-ip command, the following guidelines apply:
· The setting configured by using the nas-ip command in RADIUS scheme view applies only to the RADIUS scheme.
· The setting configured by using the radius nas-ip command in system view applies to all RADIUS schemes.
· The setting in RADIUS scheme view takes precedence over the setting in system view.
For a RADIUS scheme, you can specify only one source IPv4 address and one source IPv6 address for outgoing RADIUS packets.
If you do not specify any parameter for the undo nas-ip command, the command deletes the specified source IPv4 address for outgoing RADIUS packets.
# In RADIUS scheme radius1, specify IP address 10.1.1.1 as the source IP address for outgoing RADIUS packets.
[Sysname-radius-radius1] nas-ip 10.1.1.1
radius nas-ip
port
Use port to specify the RADIUS DAS port.
Use undo port to restore the default.
port port-number
undo port
The RADIUS DAS port number is 3799.
RADIUS DAS view
context-admin
port-number: Specifies a UDP port number in the range of 1 to 65535.
The destination port in DAE packets on the DAC must be the same as the RADIUS DAS port on the DAS.
# Enable the RADIUS DAS to listen to UDP port 3790 for DAE requests.
[Sysname-radius-da-server] port 3790
client
primary accounting (RADIUS scheme view)
Use primary accounting to specify the primary RADIUS accounting server.
Use undo primary accounting to restore the default.
primary accounting { ipv4-address | ipv6 ipv6-address } [ port-number | key { cipher | simple } string | vpn-instance vpn-instance-name | weight weight-value ] *
The primary RADIUS accounting server is not specified.
RADIUS scheme view
context-admin
vsys-admin
ipv4-address: Specifies the IPv4 address of the primary RADIUS accounting server.
ipv6 ipv6-address: Specifies the IPv6 address of the primary RADIUS accounting server.
port-number: Specifies the service port number of the primary RADIUS accounting server. The value range for the UDP port number is 1 to 65535. The default setting is 1813.
key: Specifies the shared key for secure communication with the primary RADIUS accounting server.
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN instance to which the primary RADIUS accounting server belongs. The vpn-instance-name argument is a case-sensitive string of 1 to 31 characters. If the server is on the public network, do not specify this option.
weight weight-value: Specifies the weight of the RADIUS server for weighted load balancing. The value range for the weight-value argument is 0 to 100, and the default value is 0. The server weight takes effect when RADIUS server load balancing is enabled for the RADIUS scheme. To not use a server for request processing, set its weight to 0. To distribute more requests to a server, assign a higher weight to that server.
Make sure the port number and shared key settings of the primary RADIUS accounting server are the same as those configured on the server.
Two accounting servers specified for a scheme, primary or secondary, cannot have identical VPN instance, IP address, and port number settings.
The shared key configured by using this command takes precedence over the shared key configured with the key accounting command.
If the specified server resides on an MPLS L3VPN, specify the VPN instance by using the vpn-instance vpn-instance-name option. The VPN instance specified by this command takes precedence over the VPN instance specified for the RADIUS scheme.
If you modify or delete an accounting server while the device is sending a start-accounting request to it, communication with that server will time out. The action to take by the device upon a timeout depends on the enabling status of RADIUS server load sharing for the RADIUS scheme.
· If RADIUS server load sharing is disabled, the device tries to communicate with the active server that has the highest priority for accounting.
· If RADIUS server load sharing is enabled, the device returns an accounting failure message rather than searching for another active accounting server.
If you remove an actively used accounting server, the device no longer sends users' real-time accounting requests and stop-accounting requests. It does not buffer the stop-accounting requests. The device can generate incorrect accounting results.
# In RADIUS scheme radius1, specify the primary accounting server with IP address 10.110.1.2, UDP port number 1813, and plaintext shared key 123456TESTacct&!.
[Sysname-radius-radius1] primary accounting 10.110.1.2 1813 key simple 123456TESTacct&!
secondary accounting (RADIUS scheme view)
vpn-instance (RADIUS scheme view)
primary authentication (RADIUS scheme view)
Use primary authentication to specify the primary RADIUS authentication server.
Use undo primary authentication to restore the default.
primary authentication { ipv4-address | ipv6 ipv6-address } [ port-number | key { cipher | simple } string | test-profile profile-name | vpn-instance vpn-instance-name | weight weight-value ] *
The primary RADIUS authentication server is not specified.
RADIUS scheme view
context-admin
vsys-admin
ipv4-address: Specifies the IPv4 address of the primary RADIUS authentication server.
ipv6 ipv6-address: Specifies the IPv6 address of the primary RADIUS authentication server.
port-number: Specifies the service port number of the primary RADIUS authentication server. The value range for the UDP port number is 1 to 65535. The default setting is 1812.
key: Specifies the shared key for secure communication with the primary RADIUS authentication server.
test-profile profile-name: Specifies a test profile for detecting the RADIUS server status. The profile-name argument is a case-sensitive string of 1 to 31 characters.
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN instance to which the primary RADIUS authentication server belongs. The vpn-instance-name argument is a case-sensitive string of 1 to 31 characters. If the server is on the public network, do not specify this option.
Make sure the service port and shared key settings of the primary RADIUS authentication server are the same as those configured on the server.
Two authentication servers specified for a scheme, primary or secondary, cannot have identical VPN instance, IP address, and port number settings.
The shared key configured by this command takes precedence over the shared key configured with the key authentication command.
The server status detection is triggered for the server if the specified test profile exists on the device.
If you modify or delete an authentication server during the authentication process for a request, communication with the server will time out. The action to take by the device upon a timeout depends on the enabling status of RADIUS server load sharing for the RADIUS scheme.
· If RADIUS server load sharing is disabled, the device tries to communicate with an active server that has the highest priority for authentication.
· If RADIUS server load sharing is enabled, the device reselects a server from all active authentication servers based on their weights and loads, and then sends the request to that server.
If you modify or delete the primary authentication server during an authentication process, communication with the primary server times out. The device tries to communicate with an active server that has the highest priority for authentication.
# In RADIUS scheme radius1, specify the primary authentication server with IP address 10.110.1.1, UDP port number 1812, and plaintext shared key 123456TESTauth&!.
[Sysname-radius-radius1] primary authentication 10.110.1.1 1812 key simple 123456TESTauth&!
radius-server test-profile
secondary authentication (RADIUS scheme view)
radius attribute extended
Use radius attribute extended to define an extended RADIUS attribute.
Use undo radius attribute extended to delete user-defined extended RADIUS attributes.
radius attribute extended attribute-name [ vendor vendor-id ] code attribute-code type { binary | date | integer | interface-id | ip | ipv6 | ipv6-prefix | octets | string }
undo radius attribute extended [ attribute-name ]
No user-defined extended RADIUS attributes exist.
context-admin
attribute-name: Specifies the RADIUS attribute name, a case-insensitive string of 1 to 63 characters. The name must be unique among all RADIUS attributes, including the standard and extended RADIUS attributes.
vendor vendor-id: Specifies a vendor ID in the range of 1 to 65535. If you do not specify a vendor ID, the device processes the RADIUS attribute as a standard RADIUS attribute.
code attribute-code: Specifies the ID of the RADIUS attribute in the attribute set. The value range for the attribute-code argument is 1 to 255.
date: Date type.
ipv6-prefix: IPv6 prefix type.
octets: Octet type.
To support the proprietary RADIUS attributes of other vendors, perform the following tasks:
1. Use this command to define the attributes as extended RADIUS attributes.
2. Use the attribute convert command to map the extended RADIUS attributes to attributes supported by the system.
3. Use the attribute translate command to enable the RADIUS attribute translation feature for the mappings to take effect.
To cooperate with RADIUS servers of a third-party vendor, map attributes that cannot be identified by the server to server-supported attributes.
Two RADIUS attributes cannot have the same combination of attribute name, vendor ID, and attribute ID.
If you do not specify a RADIUS attribute name, the undo radius attribute extended command deletes all user-defined extended RADIUS attributes.
# Define a string-type extended RADIUS attribute with attribute name Owner-Password, vendor ID 122, and attribute ID 80.
[Sysname] radius attribute extended Owner-Password vendor 122 code 80 type string
Use radius attribute-test-group to create a RADIUS attribute test group and enter its view, or enter the view of an existing RADIUS attribute test group.
Use undo radius attribute-test-group to remove a RADIUS attribute test group.
radius attribute-test-group attr-test-group-name
undo radius attribute-test-group attr-test-group-name
No RADIUS attribute test groups exist.
context-admin
attr-test-group-name: Specifies the name of a RADIUS attribute test group, a case-insensitive string of 1 to 31 characters.
A RADIUS attribute test group is a collection of RADIUS attributes that will be included in or excluded from RADIUS requests.
The system can have multiple RADIUS attribute test groups.
# Create a RADIUS attribute test group named t1 and enter its view.
exclude
include
test-aaa
radius authentication-request first
Use radius authentication-request first to preferentially process RADIUS authentication requests
Use undo radius authentication-request first to restore the default.
The device processes RADIUS requests in the sequence that the requests are initiated.
context-admin
RADIUS requests include RADIUS authentication requests, RADIUS accounting-start requests, RADIUS accounting-update requests, and RADIUS accounting-stop requests.
When a large number of users go offline and then try to come online immediately, authentication might fail for these users because of authentication request timeout. To resolve this issue, configure the device to preferentially process authentication requests.
Do not perform this task if the RADIUS server identifies users by the username and does not allow repeated authentication for the same username. A violation might cause authentication failure for users that try to come online immediately after going offline.
As a best practice, do not perform this task when the device has online users.
# Configure the device to preferentially process RADIUS authentication requests.
[Sysname] radius authentication-request first
radius dscp
Use radius dscp to change the DSCP priority of RADIUS packets.
Use undo radius dscp to restore the default.
radius [ ipv6 ] dscp dscp-value
undo radius [ ipv6 ] dscp
The DSCP priority of RADIUS packets is 0.
context-admin
vsys-admin
ipv6: Specifies the IPv6 RADIUS packets. If you do not specify this keyword, the command sets the DSCP priority for the IPv4 RADIUS packets.
dscp-value: Specifies the DSCP priority of RADIUS packets, in the range of 0 to 63. A larger value represents a higher priority.
Use this command to set the DSCP priority in the ToS field of RADIUS packets for changing their transmission priority.
# Set the DSCP priority of IPv4 RADIUS packets to 10.
[Sysname] radius dscp 10
Use radius dynamic-author server to enable the RADIUS DAS feature and enter RADIUS DAS view.
Use undo radius dynamic-author server to disable the RADIUS DAS feature.
The RADIUS DAS feature is disabled.
context-admin
After you enable the RADIUS DAS feature, the device listens to the RADIUS DAS port to receive DAE packets from specified DACs. Based on the DAE packet type and contents, the device performs one of the following operations:
· Log off online users.
· Change online user authorization information.
# Enable the RADIUS DAS feature and enter RADIUS DAS view.
client
port
radius nas-ip
Use radius nas-ip to specify a source IP address for outgoing RADIUS packets.
Use undo radius nas-ip to delete the specified source IP address for outgoing RADIUS packets.
radius nas-ip { ipv4-address | ipv6 ipv6-address } [ vpn-instance vpn-instance-name ]
undo radius nas-ip { ipv4-address | ipv6 ipv6-address } [ vpn-instance vpn-instance-name ]
The source IP address of an outgoing RADIUS packet is the primary IPv4 address or the IPv6 address of the outbound interface.
context-admin
vsys-admin
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN instance to which the source IP address belongs. The vpn-instance-name argument is a case-sensitive string of 1 to 31 characters. To configure a public-network source IP address, do not specify this option.
You can specify a maximum of 16 source IP addresses in system view, including:
· Zero or one public-network source IPv4 address.
· Zero or one public-network source IPv6 address.
· Private-network source IP addresses.
Each VPN instance can have only one private-network source IPv4 address and one private-network source IPv6 address in system view.
# Specify IP address 129.10.10.1 as the source IP address for outgoing RADIUS packets.
[Sysname] radius nas-ip 129.10.10.1
radius scheme
Use radius scheme to create a RADIUS scheme and enter its view, or enter the view of an existing RADIUS scheme.
Use undo radius scheme to delete a RADIUS scheme.
radius scheme radius-scheme-name
undo radius scheme radius-scheme-name
No RADIUS schemes exist.
context-admin
vsys-admin
radius-scheme-name: Specifies the RADIUS scheme name, a case-insensitive string of 1 to 32 characters.
A RADIUS scheme can be used by more than one ISP domain at the same time.
The device supports a maximum of 16 RADIUS schemes.
# Create a RADIUS scheme named radius1 and enter RADIUS scheme view.
[Sysname] radius scheme radius1
radius session-control client
Use radius session-control client to specify a RADIUS session-control client.
Use undo radius session-control client to remove the specified RADIUS session-control clients.
radius session-control client { ip ipv4-address | ipv6 ipv6-address } [ key { cipher | simple } string | vpn-instance vpn-instance-name ] *
undo radius session-control client { all | { ip ipv4-address | ipv6 ipv6-address } [ vpn-instance vpn-instance-name ] }
No RADIUS session-control clients are specified.
context-admin
ip ipv4-address: Specifies a session-control client by its IPv4 address.
ipv6 ipv6-address: Specifies a session-control client by its IPv6 address.
key: Specifies the shared key for secure communication with the session-control client.
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN instance to which the RADIUS session-control client belongs. The vpn-instance-name argument is a case-sensitive string of 1 to 31 characters. If the client is on the public network, do not specify this option.
all: Specifies all session-control clients.
To verify the session-control packets sent from a RADIUS server running on IMC, specify the RADIUS server as a session-control client to the device. The device matches a session-control packet to a session-control client based on the IP address and VPN instance, and then uses the shared key of the matched client to validate the packet.
The device searches the session-control client settings prior to searching all RADIUS scheme settings for a server with matching settings. This process narrows the search scope for finding the matched RADIUS server.
The session-control client settings take effect only when the RADIUS session-control feature is enabled.
The session-control client settings must be the same as the corresponding settings of the RADIUS server.
You can specify multiple session-control clients on the device.
# Specify a session-control client with IP address 10.110.1.2 and shared key 12345 in plaintext form.
[Sysname] radius session-control client ip 10.110.1.2 key simple 12345
radius session-control enable
Use radius session-control enable to enable the RADIUS session-control feature.
Use undo radius session-control enable to disable the RADIUS session-control feature.
The RADIUS session-control feature is disabled.
context-admin
An H3C IMC RADIUS server uses session-control packets to deliver dynamic authorization change requests or disconnection requests to the device. The session-control feature enables the device to receive the RADIUS session-control packets on UDP port 1812.
This feature must work with H3C IMC servers.
# Enable the RADIUS session-control feature.
[Sysname] radius session-control enable
radius trap-version
Use radius trap-version to set the version of RADIUS server status change MIB nodes.
Use undo radius trap-version to restore the default.
radius trap-version { v1 | v2 } [ accounting-server-down | accounting-server-up | authentication-server-down | authentication-server-up ] *
undo radius trap-version { v1 | v2 } [ accounting-server-down | accounting-server-up | authentication-server-down | authentication-server-up ] *
The device sends notifications about RADIUS server status change MIB nodes over SNMPv1.
context-admin
v1: Specifies SNMPv1.
v2: Specifies SNMPv2.
accounting-server-down: Specifies the MIB node of RADIUS accounting server down notifications.
accounting-server-up: Specifies the MIB node of RADIUS accounting server up notifications.
authentication-server-down: Specifies the MIB node of RADIUS authentication server down notifications.
authentication-server-up: Specifies the MIB node of RADIUS authentication server up notifications.
Make sure the RADIUS server status change notifications sent by the device can be recognized by the NMS. Choose a MIB node version depending on the NMS requirements.
Table 16 RADIUS server status change MIB nodes (SNMPv1)
MIB node |
OID |
hh3cRadiusAuthServerUpTrap |
1.3.6.1.4.1.25506.2.13.3.0.1 |
hh3cRadiusAccServerUpTrap |
1.3.6.1.4.1.25506.2.13.3.0.2 |
hh3cRadiusAuthServerDownTrap |
1.3.6.1.4.1.25506.2.13.3.1 |
hh3cRadiusAccServerDownTrap |
1.3.6.1.4.1.25506.2.13.3.2 |
Table 17 RADIUS server status change MIB nodes (SNMPv2)
MIB node |
OID |
hh3cRadiusAuthenticationServerUpTrap |
1.3.6.1.4.1.25506.2.13.3.0.4 |
hh3cRadiusAccountingServerUpTrap |
1.3.6.1.4.1.25506.2.13.3.0.5 |
hh3cRadiusAuthenticationServerDownTrap |
1.3.6.1.4.1.25506.2.13.3.0.6 |
hh3cRadiusAccountingServerDownTrap |
1.3.6.1.4.1.25506.2.13.3.0.7 |
If you do not specify any RADIUS server status change MIB nodes, this command sets a version for all types of RADIUS server status change MIB nodes.
# Set the MIB node version to SNMPv2 for the MIB node of RADIUS accounting server down notifications.
[Sysname] radius trap-version v2 accounting-server-down
snmp-agent trap enable radius
Use radius-server test-profile to configure a test profile for detecting the RADIUS server status.
Use undo radius-server test-profile to delete a RADIUS test profile.
radius-server test-profile profile-name username name [ interval interval ] [ probe-count count ]
undo radius-server test-profile profile-name
No RADIUS test profiles exist.
context-admin
profile-name: Specifies the name of the test profile, which is a case-sensitive string of 1 to 31 characters.
username name: Specifies the username in the probe packets. The name argument is a case-sensitive string of 1 to 253 characters.
interval interval: Specifies the interval for sending a probe packet, in minutes. The value range for the interval argument is 1 to 3600, and the default value is 60.
probe-count count: Specifies the number of consecutive probe intervals that the device takes to determine the reachability of a RADIUS server. The value range for the count argument is 1 to 10, and the default value is 1.
The device starts detecting the status of a RADIUS server only if the test profile specified for the server exists. If you specify a nonexistent test profile for a RADIUS server, the device does not detect the status of the server until you create the test profile on the device.
When the network is unstable, increase the value for the probe-count count option. This operation reduces the times that the device obtains a false RADIUS server state.
When the network is stable, reduce the value for the probe-count count option. This operation ensures that the device can obtain the real status of a RADIUS server in time.
When you delete a test profile, the device stops detecting the status of RADIUS servers that use the test profile.
You can execute this command multiple times to configure multiple test profiles.
# Configure a test profile named abc for RADIUS server status detection. A probe packet that uses username admin is sent every 10 minutes. The device takes two consecutive probe intervals to to determine the reachability of a RADIUS server.
[Sysname] radius-server test-profile abc username admin interval 10 probe-count 2
Use reset radius statistics to clear RADIUS statistics.
context-admin
vsys-admin
# Clear RADIUS statistics.
<Sysname> reset radius statistics
Use reset radius server-load statistics to clear history load statistics for all RADIUS authentication and accounting servers.
context-admin
vsys-admin
This command does not clear the last-5-second load statistics for the RADIUS authentication and accounting servers.
# Clear the history load statistics for all RADIUS authentication and accounting servers.
<Sysname> reset radius server-load statistics
retry
Use retry to set the maximum number of attempts for transmitting a RADIUS packet to a single RADIUS server.
Use undo retry to restore the default.
retry retries
undo retry
The maximum number of RADIUS packet transmission attempts is 3.
RADIUS scheme view
context-admin
vsys-admin
retries: Specifies the maximum number of RADIUS packet transmission attempts, in the range of 1 to 20.
Because RADIUS uses UDP packets to transmit data, the communication is not reliable.
If the device does not receive a response to its request from the RADIUS server within the response timeout period, the device retransmits the RADIUS request. To set the response timeout period, use the timer response-timeout command.
If the device does not receive a response from the RADIUS server after the maximum number of transmission attempts is reached, the device considers the request a failure.
If the client times out during the authentication process, the user is immediately logged off. To avoid user logoffs, the value multiplied by the following items cannot be larger than the client timeout period defined by the access module:
· The maximum number of RADIUS packet transmission attempts.
· The RADIUS server response timeout period.
· The number of RADIUS authentication servers in the RADIUS scheme.
When the device sends a RADIUS request to a new RADIUS server, it checks the total amount of time it has taken to transmit the RADIUS packet. If the amount of time has reached 300 seconds, the device stops sending the RADIUS request to the next RADIUS server. As a best practice, consider the number of RADIUS servers when you configure the maximum number of packet transmission attempts and the RADIUS server response timeout period.
# In RADIUS scheme radius1, set the maximum number of RADIUS packet transmission attempts to 5.
[Sysname-radius-radius1] retry 5
radius scheme
timer response-timeout (RADIUS scheme view)
retry realtime-accounting
Use retry realtime-accounting to set the maximum number of accounting attempts.
Use undo retry realtime-accounting to restore the default.
retry realtime-accounting retries
The maximum number of accounting attempts is 5.
RADIUS scheme view
context-admin
vsys-admin
retries: Specifies the maximum number of accounting attempts, in the range of 1 to 255.
Typically, a RADIUS accounting server checks whether a user is online by using a timeout timer. If the server does not receive a real-time accounting request for a user in the timeout period, it considers that a line or device failure has occurred. The server considers that the accounting attempt fails.
To work with the RADIUS server, the NAS needs to send real-time accounting requests to the server before the timer on the server expires and to keep pace with the server in disconnecting the user when a failure occurs. The NAS disconnects from a user according to the maximum number of accounting attempts and specific parameters.
For example, for a LAN user, the following conditions exist for a LAN user:
· The RADIUS server response timeout period is 3 seconds (set by using the timer response-timeout command).
· The maximum number of RADIUS packet transmission attempts is 3 (set by using the retry command).
· The real-time accounting interval is 12 minutes (set by using the timer realtime-accounting command).
· The maximum number of accounting attempts is 5 (set by using the retry realtime-accounting command).
In the above case, the device generates an accounting request every 12 minutes, and retransmits the request if it sends the request but receives no response within 3 seconds. If the device receives no response after transmitting the request three times, it considers the accounting attempt a failure, and makes another accounting attempt. If five consecutive accounting attempts fail, the device considers that the user accounting fails.
# In RADIUS scheme radius1, set the maximum number of accounting attempts to 10.
[Sysname-radius-radius1] retry realtime-accounting 10
retry
timer realtime-accounting (RADIUS scheme view)
Use secondary accounting to specify a secondary RADIUS accounting server.
Use undo secondary accounting to remove a secondary RADIUS accounting server.
secondary accounting { ipv4-address | ipv6 ipv6-address } [ port-number | key { cipher | simple } string | vpn-instance vpn-instance-name | weight weight-value ] *
undo secondary accounting [ { ipv4-address | ipv6 ipv6-address } [ port-number | vpn-instance vpn-instance-name ] * ]
No secondary RADIUS accounting servers are specified.
RADIUS scheme view
context-admin
vsys-admin
ipv4-address: Specifies the IPv4 address of a secondary RADIUS accounting server.
ipv6 ipv6-address: Specifies the IPv6 address of a secondary RADIUS accounting server.
port-number: Specifies the service port number of the secondary RADIUS accounting server. The value range for the UDP port number is 1 to 65535. The default setting is 1813.
key: Specifies the shared key for secure communication with the secondary RADIUS accounting server.
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN instance to which the secondary RADIUS accounting server belongs. The vpn-instance-name argument is a case-sensitive string of 1 to 31 characters. If the server is on the public network, do not specify this option.
Make sure the port number and shared key settings of each secondary RADIUS accounting server are the same as those configured on the corresponding server.
A RADIUS scheme supports a maximum of 16 secondary RADIUS accounting servers. If the primary server fails, the device tries to communicate with a secondary server in active state. The device connects to the secondary servers in the order they are configured.
The shared key configured by this command takes precedence over the shared key configured with the key accounting command.
If you remove an actively used accounting server, the device no longer sends users' real-time accounting requests and stop-accounting requests. The device does not buffer the stop-accounting requests, either.
# In RADIUS scheme radius1, specify a secondary accounting server with IP address 10.110.1.1 and UDP port 1813.
[Sysname-radius-radius1] secondary accounting 10.110.1.1 1813
# In RADIUS scheme radius2, specify two secondary accounting servers with IP addresses 10.110.1.1 and 10.110.1.2 and UDP port 1813.
[Sysname] radius scheme radius2
[Sysname-radius-radius2] secondary accounting 10.110.1.1 1813
[Sysname-radius-radius2] secondary accounting 10.110.1.2 1813
Use secondary authentication to specify a secondary RADIUS authentication server.
Use undo secondary authentication to remove a secondary RADIUS authentication server.
secondary authentication { ipv4-address | ipv6 ipv6-address } [ port-number | key { cipher | simple } string | test-profile profile-name | vpn-instance vpn-instance-name | weight weight-value ] *
undo secondary authentication [ { ipv4-address | ipv6 ipv6-address } [ port-number | vpn-instance vpn-instance-name ] * ]
No secondary RADIUS authentication servers are specified.
RADIUS scheme view
context-admin
vsys-admin
ipv4-address: Specifies the IPv4 address of a secondary RADIUS authentication server.
ipv6 ipv6-address: Specifies the IPv6 address of a secondary RADIUS authentication server.
port-number: Specifies the service port number of the secondary RADIUS authentication server. The value range for the UDP port number is 1 to 65535. The default setting is 1812.
key: Specifies the shared key for secure communication with the secondary RADIUS authentication server.
cipher: Specifies the key in encrypted form.
simple: Specifies the key in plaintext form. For security purposes, the key specified in plaintext form will be stored in encrypted form.
string: Specifies the key. This argument is case sensitive. The encrypted form of the key is a string of 1 to 117 characters. The plaintext form of the key is a string of 1 to 64 characters.
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN instance to which the secondary RADIUS authentication server belongs. The vpn-instance-name argument is a case-sensitive string of 1 to 31 characters. If the server is on the public network, do not specify this option.
Make sure the port number and shared key settings of each secondary RADIUS authentication server are the same as those configured on the corresponding server.
A RADIUS scheme supports a maximum of 16 secondary RADIUS authentication servers. If the primary server fails, the device tries to communicate with a secondary server in active state. The device connects to the secondary servers in the order they are configured.
The server status detection is triggered for a server if the specified test profile exists on the device.
# In RADIUS scheme radius1, specify a secondary authentication server with IP address 10.110.1.2 and UDP port 1812.
[Sysname-radius-radius1] secondary authentication 10.110.1.2 1812
# In RADIUS scheme radius2, specify two secondary authentication servers with IP addresses 10.110.1.1 and 10.110.1.2 and UDP port 1812.
[Sysname-radius-radius2] secondary authentication 10.110.1.1 1812
[Sysname-radius-radius2] secondary authentication 10.110.1.2 1812
server-load-sharing enable
Use server-load-sharing enable to enable RADIUS server load sharing.
Use undo server-load-sharing enable to disable RADIUS server load sharing.
RADIUS server load sharing is disabled.
RADIUS scheme view
context-admin
vsys-admin
By default, RADIUS server load sharing is disabled. The device sends all requests to the primary server as long as it is available. If the primary server is unavailable, the device selects a server from among all active secondary servers in the order in which they were configured, and then sends all requests to that server. This mechanism causes request processing performance to decrease as the number of requests increases.
To improve server resource usage and request processing performance, enable RADIUS server load sharing. This feature dynamically distributes requests across the active servers specified in a RADIUS scheme by user on a weighted basis, regardless of their server roles. You can specify a weight for each server depending on their performance, with a higher weight for higher possibility of being selected. The device distributes AAA requests proportionally across the active authentication or accounting servers in the scheme based on their weights and loads (number of served users).
If a RADIUS accounting server has started accounting service for a user, the device sends all subsequent accounting requests for the user to that RADIUS accounting server. If the server becomes unavailable, the device returns an accounting failure message.
# Enable RADIUS server load sharing for RADIUS scheme radius1.
[Sysname-radius-radius1] server-load-sharing enable
Use snmp-agent trap enable radius to enable SNMP notifications for RADIUS.
Use undo snmp-agent trap enable radius to disable SNMP notifications for RADIUS.
snmp-agent trap enable radius [ accounting-server-down | accounting-server-up | authentication-error-threshold | authentication-server-down | authentication-server-up ] *
undo snmp-agent trap enable radius [ accounting-server-down | accounting-server-up | authentication-error-threshold | authentication-server-down | authentication-server-up ] *
All RADIUS SNMP notifications are disabled.
context-admin
accounting-server-down: Specifies notifications to be sent when the RADIUS accounting server becomes unreachable.
accounting-server-up: Specifies notifications to be sent when the RADIUS accounting server becomes reachable.
authentication-error-threshold: Specifies notifications to be sent when the number of authentication failures exceeds the specified threshold. The threshold is represented by the ratio of the authentication failures to the total number of authentication attempts. The value range is 1 to 100, and the default value is 30. This threshold can only be configured through the MIB.
authentication-server-down: Specifies notifications to be sent when the RADIUS authentication server becomes unreachable.
authentication-server-up: Specifies notifications to be sent when the RADIUS authentication server becomes reachable.
If you do not specify any keywords, this command enables or disables all types of notifications for RADIUS.
When SNMP notifications for RADIUS are enabled, the device supports the following notifications generated by RADIUS:
· RADIUS server unreachable notification—The RADIUS server cannot be reached. RADIUS generates this notification if it cannot receive any response to an accounting or authentication request within the specified RADIUS request transmission attempts.
· RADIUS server reachable notification—The RADIUS server can be reached. RADIUS generates this notification for a previously blocked RADIUS server after the quiet timer expires.
· Excessive authentication failures notification—RADIUS generates this notification when the number of authentication failures to the total number of authentication attempts exceeds the specified threshold.
# Enable the device to send RADIUS accounting server unreachable notifications.
[Sysname] snmp-agent trap enable radius accounting-server-down
state primary
Use state primary to set the status of a primary RADIUS server.
state primary { accounting | authentication } { active | block }
A primary RADIUS server is in active state.
RADIUS scheme view
context-admin
vsys-admin
accounting: Specifies the primary RADIUS accounting server.
authentication: Specifies the primary RADIUS authentication server.
active: Specifies the active state, the normal operation state.
block: Specifies the blocked state, the out-of-service state.
During an authentication or accounting process, the device first tries to communicate with the primary server if the primary server is in active state. If the primary server is unavailable, the device performs the following operations:
· Changes the status of the primary server to blocked.
· Starts a quiet timer for the server.
· Tries to communicate with a secondary server in active state.
When the quiet timer of the primary server times out, the status of the server automatically changes to active. If you set the server status to blocked before the quiet timer times out, the server status cannot change back to active unless you manually set the status to active.
When all servers are in blocked state, the device tries to communicate with a server as follows:
· If the primary server is placed in blocked state automatically, the device only tries to communicate with the primary server.
· If the primary server is placed in blocked state manually, the device tries to communicate with secondary servers automatically placed in blocked state in the sequence they are configured.
This command can affect the RADIUS server status detection feature when a valid test profile is specified for a primary RADIUS authentication server.
· If you set the status of the server to blocked, the device stops detecting the status of the server.
· If you set the status of the server to active, the device starts to detect the status of the server.
# In RADIUS scheme radius1, set the status of the primary authentication server to blocked.
[Sysname-radius-radius1] state primary authentication block
display radius scheme
state secondary
state secondary
Use state secondary to set the status of a secondary RADIUS server.
state secondary { accounting | authentication } [ { ipv4-address | ipv6 ipv6-address } [ port-number | vpn-instance vpn-instance-name ] * ] { active | block }
A secondary RADIUS server is in active state.
RADIUS scheme view
context-admin
vsys-admin
accounting: Specifies a secondary RADIUS accounting server.
authentication: Specifies a secondary RADIUS authentication server.
ipv4-address: Specifies the IPv4 address of a secondary RADIUS server.
ipv6 ipv6-address: Specifies the IPv6 address of a secondary RADIUS server.
port-number: Specifies the service port number of a secondary RADIUS server. The value range for the UDP port number is 1 to 65535. The default port numbers for authentication and accounting are 1812 and 1813, respectively.
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN instance to which the secondary RADIUS server belongs. The vpn-instance-name argument is a case-sensitive string of 1 to 31 characters.
If you do not specify an IP address, this command changes the status of all configured secondary RADIUS servers.
If the device finds that a secondary server in active state is unreachable, the device performs the following operations:
· Changes the status of the secondary server to blocked.
· Tries to communicate with another secondary server in active state.
When the quiet timer of a server times out, the status of the server automatically changes to active. If you set the server status to blocked before the quiet timer times out, the server status cannot change back to active unless you manually set the status to active. If all configured secondary servers are unreachable, the device considers the authentication or accounting attempt a failure.
This command can affect the RADIUS server status detection feature when a valid test profile is specified for a secondary RADIUS authentication server.
# In RADIUS scheme radius1, set the status of all the secondary authentication servers to blocked.
[Sysname-radius-radius1] state secondary authentication block
state primary
test-aaa
Use test-aaa to perform an AAA test.
test-aaa user user-name password password radius-scheme radius-scheme-name [ radius-server { ipv4-address | ipv6 ipv6-address } port-number [ vpn-instance vpn-instance-name ] ] [ chap | pap ] [ attribute-test-group attr-test-group-name ] [ trace ]
context-admin
user user-name: Specifies the test username, a string of 1 to 80 characters. The username can be a pure username or contain a domain name. The format for a username containing a domain name is pure-username@domain-name. The pure username is case sensitive and the domain name is case insensitive.
password password: Specifies the password of the test user, a case-sensitive string of 1 to 63 characters.
radius-scheme radius-scheme-name: Specifies a RADIUS scheme by its name, a case-insensitive string of 1 to 32 characters.
radius-server: Specifies a RADIUS server.
ipv4-address: Specifies the IPv4 address of the RADIUS server.
ipv6 ipv6-address: Specifies the IPv6 address of the RADIUS server.
port-number: Specifies the UDP port number of the RADIUS server, in the range of 1 to 65535.
vpn-instance vpn-instance-name: Specifies the MPLS L3VPN instance to which the RADIUS server belongs. The vpn-instance-name argument is a case-sensitive string of 1 to 31 characters. If the server is on the public network, do not specify this option.
chap: Specifies the CHAP authentication method (the default).
pap: Specifies the PAP authentication method.
attribute-test-group attr-test-group-name: Specifies a RADIUS attribute test group by its name, a case-insensitive string of 1 to 31 characters. If you do not specify a RADIUS attribute test group or the specified RADIUS attribute test group does not exist, the device does not change the attributes carried in authentication or accounting requests.
trace: Displays detailed information about RADIUS packets exchanged during the AAA test. If you do not specify this keyword, the command displays brief information about the AAA test, including the sent and received packets and the test result.
Use this command to identify the reasons for the failure of interaction between the device and the AAA servers.
The device might communicate with the AAA servers incorrectly during an AAA test. Make sure no users come online or go offline during an AAA text.
If the configuration of the specified RADIUS scheme changes, the new configuration does not affect the current AAA test. The modification will take effect in the next test.
The system can have only one AAA test at a time. Another AAA test can be performed only after the current test finishes.
# Perform an AAA test and display detailed information about the test. The test uses username user1, password 123456, the CHAP authentication method, and RADIUS scheme test.
<Sysname> test-aaa user user1 password 123456 radius-scheme test chap trace
Sent a RADIUS authentication request.
Server IP : 192.168.1.110
Source IP : 192.168.1.166
VPN instance : N/A
Server port : 1812
Packet type : Authentication request
Packet length: 118 bytes
Packet ID : 0
Attribute list:
[User-Name(1)] [6] [user1]
[CHAP-Password(3)] [19] [******]
[NAS-IP-Address(4)] [6] [192.168.1.166]
[Service-Type(6)] [6] [2] [Framed]
[Framed-Protocol(7)] [6] [1] [PPP]
[NAS-Identifier(32)] [5] [Sysname]
[Acct-Session-Id(44)] [40] [00000008201707241008280000000c16100171]
[CHAP-Challenge(60)] [18] [******]
[NAS-Port-Type(61)] [6] [15] [Ethernet]
Received a RADIUS authentication response.
VPN instance : N/A
Server port : 1812
Packet type : Access-Reject
Packet length: 20 bytes
Packet ID : 0
Reply-Message: "E63032: Incorrect password. You can retry 9 times."
Sent a RADIUS start-accounting request.
VPN instance : N/A
Server port : 1813
Packet type : Start-accounting request
Packet length: 63 bytes
Packet ID : 1
Attribute list:
[Acct-Status-Type(40)] [6] [1] [Start]
Received a RADIUS start-accounting response.
VPN instance : N/A
Server port : 1813
Packet type : Start-accounting response
Packet ID : 1
Sent a RADIUS stop-accounting request.
VPN instance : N/A
Server port : 1813
Packet type : Stop-accounting request
Packet length: 91 bytes
Packet ID : 1
Attribute list:
[Acct-Status-Type(40)] [6] [2] [Stop]
[Acct-Delay-Time(41)] [6] [0]
[Acct-Terminate-Cause(49)] [6] [1] [User Request]
Received a RADIUS stop-accounting response.
VPN instance : N/A
Server port : 1813
Packet type : Stop-accounting response
Packet ID : 1
Test result: Failed
# Perform an AAA test and display brief information about the test. The test uses username user1, password 123456 and the CHAP authentication method to test RADIUS server at 192.168.1.110 in RADIUS scheme test.
<Sysname> test-aaa user user1 password 123456 radius-scheme test radius-server 192.168.1.110 1812
Test result: Successful
Table 18 Command output
Server IP |
IP address of the server. |
Source IP |
Source IP address of the RADIUS packet. |
VPN instance |
MPLS L3VPN instance to which the server belongs. This field displays N/A if the server belongs to the public network. |
Server port |
UDP port number of the server. |
Packet type |
Type of the RADIUS packet: · Authentication request. · Access-Accept. · Access-Reject. · Start-accounting request. · Start-accounting response. · Stop-accounting request. · Stop-accounting response. |
Packet length |
Total length of the RADIUS packet, in bytes. |
Packet ID |
ID of the RADIUS packet. This field is used to identity a pair of request and response packets. |
[attribute-name (code)] [length] [value] [description] |
Information about a RADIUS attribute: · attribute-name—Name of the attribute. · code—Code of the attribute. · length—Length of the attribute, in bytes. · value—Value of the attribute. · description—Description of the attribute. |
Reply-Message: |
The RADIUS server rejected the authentication request and replied a message. |
Test result |
Result of the AAA test: · Successful—The test has succeeded. · Failed—The test has failed. If any request is rejected, the test fails. |
radius scheme
timer quiet (RADIUS scheme view)
Use timer quiet to set the quiet timer for the servers specified in a RADIUS scheme.
Use undo timer quiet to restore the default.
timer quiet minutes
undo timer quiet
The server quiet timer period is 5 minutes in a RADIUS scheme.
RADIUS scheme view
context-admin
vsys-admin
minutes: Specifies the server quiet period in minutes, in the range of 1 to 255.
Make sure the server quiet timer is set correctly.
A timer that is too short might result in frequent authentication or accounting failures. This is because the device will continue to attempt to communicate with an unreachable server that is in active state.
A timer that is too long might temporarily block a reachable server that has recovered from a failure. This is because the server will remain in blocked state until the timer expires.
# In RADIUS scheme radius1, set the quiet timer to 10 minutes for the servers.
[Sysname-radius-radius1] timer quiet 10
Use timer realtime-accounting to set the real-time accounting interval.
Use undo timer realtime-accounting to restore the default.
timer realtime-accounting interval [ second ]
The real-time accounting interval is 12 minutes.
RADIUS scheme view
context-admin
vsys-admin
interval: Specifies the real-time accounting interval in the range of 0 to 71582.
second: Specifies the measurement unit as second. If you do not specify this keyword, the real-time accounting interval is measured in minutes.
When the real-time accounting interval on the device is not zero, the device sends online user accounting information to the RADIUS accounting server at the configured interval.
When the real-time accounting interval on the device is zero, the device sends online user accounting information to the RADIUS accounting server at the real-time accounting interval configured on the server. If the real-time accounting interval is not configured on the server, the device does not send online user accounting information.
If a user uses RADIUS accounting but not RADIUS authentication and authorization, the device performs real-time accounting for that user only based on the real-time accounting interval set in the user's RADIUS accounting scheme. The real-time accounting interval assigned by the RADIUS accounting server does not take effect.
A short interval helps improve accounting precision but requires many system resources.
Table 19 Recommended real-time accounting intervals
Number of users |
Real-time accounting interval |
1 to 99 |
3 minutes |
100 to 499 |
6 minutes |
500 to 999 |
12 minutes |
1000 or more |
15 minutes or longer |
When you modify the real-time accounting interval, the following rules apply to users that have been online before the modification:
· If you modify the real-time accounting interval from a non-zero value to zero or from zero to a non-zero value, the modification does not take effect on these users. These users still use the old real-time accounting interval.
· If you modify the real-time accounting interval from a non-zero value to another non-zero value, the modification takes effect immediately on these users.
The device sends a start-accounting packet for a dual-stack user after the user obtains an IP address of one stack. No matter how long the real-time accounting interval is, the device sends an update-accounting packet for the user immediately after the user obtains an IP address of another stack.
# In RADIUS scheme radius1, set the real-time accounting interval to 51 minutes.
[Sysname-radius-radius1] timer realtime-accounting 51
Use timer response-timeout to set the RADIUS server response timeout timer.
Use undo timer response-timeout to restore the default.
timer response-timeout seconds
The RADIUS server response timeout period is 3 seconds.
RADIUS scheme view
context-admin
vsys-admin
seconds: Specifies the RADIUS server response timeout period, in the range of 1 to 10 seconds.
If a NAS receives no response from the RADIUS server in a period of time after sending a RADIUS request, it resends the request so that the user has more opportunity to obtain the RADIUS service. The NAS uses the RADIUS server response timeout timer to control the transmission interval.
· The number of RADIUS servers in the RADIUS scheme.
# In RADIUS scheme radius1, set the RADIUS server response timeout timer to 5 seconds.
[Sysname-radius-radius1] timer response-timeout 5
retry
user-name-format (RADIUS scheme view)
Use user-name-format to specify the format of the username to be sent to a RADIUS server.
Use undo user-name-format to restore the default.
user-name-format { keep-original | with-domain | without-domain }
The ISP domain name is included in the usernames sent to a RADIUS server.
RADIUS scheme view
context-admin
vsys-admin
keep-original: Sends the username to the RADIUS server as the username is entered.
with-domain: Includes the ISP domain name in the username sent to the RADIUS server.
without-domain: Excludes the ISP domain name from the username sent to the RADIUS server.
A username is generally in the userid@isp-name format, of which the isp-name argument is used by the device to determine the ISP domain to which a user belongs. Some earlier RADIUS servers, however, cannot recognize a username containing an ISP domain name. Before sending a username including a domain name to such a RADIUS server, the device must remove the domain name. This command allows you to specify whether to include a domain name in a username sent to a RADIUS server.
If a RADIUS scheme defines that the username is sent without the ISP domain name, do not apply the scheme to more than one ISP domain. Otherwise, the RADIUS server will consider two users in different ISP domains but with the same userid as one user.
# In RADIUS scheme radius1, configure the device to remove the domain name from the usernames sent to the RADIUS servers.
[Sysname-radius-radius1] user-name-format without-domain
Use vpn-instance to specify an MPLS L3VPN instance for a RADIUS scheme.
Use undo vpn-instance to restore the default.
undo vpn-instance
The RADIUS scheme belongs to the public network.
RADIUS scheme view
context-admin
vpn-instance-name: Specifies an MPLS L3VPN instance by its name, a case-sensitive string of 1 to 31 characters.
Non-default vSystems do not support this command.
The VPN instance specified for a RADIUS scheme applies to all authentication and accounting servers in that scheme. If a VPN instance is also configured for an individual RADIUS server, the VPN instance specified for the RADIUS scheme does not take effect on that server.
# Specify VPN instance test for RADIUS scheme radius1.
[Sysname-radius-radius1] vpn-instance test
HWTACACS commands
data-flow-format (HWTACACS scheme view)
Use data-flow-format to set the data flow and packet measurement units for traffic statistics.
Use undo data-flow-format to restore the default.
data-flow-format { data { byte | giga-byte | kilo-byte | mega-byte } | packet { giga-packet | kilo-packet | mega-packet | one-packet } } *
undo data-flow-format { data | packet }
Traffic is counted in bytes and packets.
context-admin
vsys-admin
data: Specifies the unit for data flows.
byte: Specifies the unit as byte.
giga-byte: Specifies the unit as gigabyte.
kilo-byte: Specifies the unit as kilobyte.
mega-byte: Specifies the unit as megabyte.
packet: Specifies the unit for data packets.
giga-packet: Specifies the unit as giga-packet.
kilo-packet: Specifies the unit as kilo-packet.
mega-packet: Specifies the unit as mega-packet.
one-packet: Specifies the unit as one-packet.
The data flow and packet measurement units for traffic statistics must be the same as configured on the HWTACACS accounting servers. Otherwise, accounting results might be incorrect.
# In HWTACACS scheme hwt1, set the data flow and packet measurement units for traffic statistics to kilobyte and kilo-packet, respectively.
[Sysname] hwtacacs scheme hwt1
[Sysname-hwtacacs-hwt1] data-flow-format data kilo-byte packet kilo-packet
display hwtacacs scheme
Use display hwtacacs scheme to display the configuration or statistics of HWTACACS schemes.
display hwtacacs scheme [ hwtacacs-scheme-name [ statistics ] ]
context-admin
context-operator
vsys-admin
vsys-operator
hwtacacs-scheme-name: Specifies an HWTACACS scheme by its name, a case-insensitive string of 1 to 32 characters. If you do not specify an HWTACACS scheme, this command displays the configuration of all HWTACACS schemes.
statistics: Displays the HWTACACS service statistics. If you do not specify this keyword, the command displays the configuration of the specified HWTACACS scheme.
When displaying configuration only for one scheme, this command also displays the active state duration for each active server and the most recent five state changes for all servers in the scheme.
When displaying configuration for all schemes, this command also displays the active state duration for each active server and the most recent blocked period for all servers in all schemes.
# Displays the configuration of all HWTACACS schemes.
<Sysname> display hwtacacs scheme
Total 1 HWTACACS schemes
HWTACACS Scheme Name : hwtac
Index : 0
Primary Auth Server:
IP : 2.2.2.2 Port: 49 State: Active
VPN Instance: 2
State: Active (duration: 1 weeks, 2 days, 1 hours, 32 minutes, 34 seconds)
Most recent blocked period: 2019/08/08 20:33:45 - 2019/08/08 20:38:45
Single-connection: Enabled
Track ID: 1
Primary Author Server:
VPN Instance: 2
Single-connection: Disabled
Track ID: 1
Primary Acct Server:
IP : Not Configured Port: 49 State: Block
VPN Instance: Not configured
State: Blocked
Most recent blocked period: 2019/08/08 20:33:45 - now
VPN Instance : 2
NAS IP Address : 2.2.2.3
Server Quiet Period(minutes) : 5
Realtime Accounting Interval(minutes) : 12
Response Timeout Interval(seconds) : 5
Username Format : with-domain
Data flow unit : Byte
Packet unit : one
All-server-block action : Attempt the top-priority server
# Display the configuration of HWTACACS scheme hwtac.
<Sysname> display hwtacacs scheme hwtac
Index : 0
VPN Instance: 2
Most recent state changes:
2019/08/08 21:01:23 Changed to active state
2019/08/08 20:56:22 Changed to blocked state
Track ID: 1
VPN Instance: 2
Track ID: 1
State: Blocked
2019/08/08 22:16:52 Changed to blocked state
2019/08/08 22:01:25 Changed to active state
2019/08/08 21:56:22 Changed to blocked state
VPN Instance : 2
Packet unit : one
Table 20 Command output
Index |
Index number of the HWTACACS scheme. |
Primary Auth Server |
Primary HWTACACS authentication server. |
Primary Author Server |
Primary HWTACACS authorization server. |
Primary Acct Server |
Primary HWTACACS accounting server. |
Secondary Auth Server |
Secondary HWTACACS authentication server. |
Secondary Author Server |
Secondary HWTACACS authorization server. |
Secondary Acct Server |
Secondary HWTACACS accounting server. |
IP |
IP address of the server. This field displays Not configured if the server is not configured. |
Port |
Service port of the HWTACACS server. If no port configuration is performed, this field displays the default port number. |
VPN Instance |
MPLS L3VPN instance to which the HWTACACS server or scheme belongs. If no VPN instance is specified for the server or scheme, this field displays Not configured. |
State |
Status of the server: · Active—The server is in active state. · Blocked—The server is in blocked state. |
duration |
The duration of the current active state for the server. This field is displayed only when the server is in active state. |
Most recent blocked period |
Most recent blocking start time and end time when the server stayed in blocked state. If the server still remains in blocked state, now is displayed for the end time. |
Most recent state changes |
Most recent five state changes of the server. |
Single-connection |
Single connection status: · Enabled—Establish only one TCP connection for all users to communicate with the server. · Disabled—Establish a TCP connection for each user to communicate with the server. |
Track ID |
ID of the track entry associated with the server. This field is not available if the server is not associated with a track entry. |
NAS IP Address |
Source IP addresses for outgoing HWTACACS packets. This field displays Not configured if no source IP addresses are specified for outgoing HWTACACS packets. |
Server Quiet Period(minutes) |
Quiet period for the primary servers, in minutes. |
Realtime Accounting Interval(minutes) |
Real-time accounting interval, in minutes. |
Response Timeout Interval(seconds) |
HWTACACS server response timeout period, in seconds. |
Username Format |
Format for the usernames sent to the HWTACACS server: · with-domain—Includes the domain name. · without-domain—Excludes the domain name. · keep-original—Forwards the username as the username is entered. |
Data flow unit |
Measurement unit for data flows. |
Packet unit |
Measurement unit for packets. |
All-server-block action |
Action to take for AAA requests when all servers in the scheme are blocked: · Attempt the top-priority server. · Skip all servers in the scheme. |
# Display the HWTACACS service statistics.
<Sysname> display hwtacacs scheme tac statistics
HWTACACS scheme name: tac
Primary authentication server: 3.3.3.3
Round trip time: 0 seconds
Request packets: 1
Login request packets: 1
Change-password request packets: 0
Request packets including plaintext password: 0
Request packets including ciphertext password: 0
Response packets: 2
Pass response packets: 1
Failure response packets: 0
Get-data response packets: 0
Get-username response packets: 0
Get-password response packets: 1
Restart response packets: 0
Error response packets: 0
Follow response packets: 0
Malformed response packets: 0
Continue packets: 1
Continue-abort packets: 0
Pending request packets: 0
Timeout packets: 0
Unknown type response packets: 0
Dropped response packets: 0
Primary authorization server: 3.3.3.3
Round trip time: 1 seconds
Request packets: 1
Response packets: 1
PassAdd response packets: 1
PassReply response packets: 0
Timeout packets: 0
Primary accounting server: 3.3.3.3
Request packets: 2
Accounting start request packets: 1
Accounting stop request packets: 1
Accounting update request packets: 0
Response packets: 2
Success response packets: 2
Timeout response packets: 0
Table 21 Command output
Primary authentication server |
Primary authorization server |
Primary accounting server |
Secondary authentication server |
Secondary authorization server |
Secondary accounting server |
Round trip time |
Time between the device processes the latest pair of request and response, in seconds. |
Request packets |
Number of sent requests. |
Response packets |
Number of received responses. |
Failure response packets |
Number of responses for authentication or authorization failure. |
Error response packets |
Number of error authentication responses. |
Follow response packets |
Number of follow authentication responses. |
Malformed response packets |
Number of invalid responses. |
Pending request packets |
Number of requests for which the device waits for responses. |
Timeout packets |
Number of requests that timed out. |
Unknown type response packets |
Number of unknown responses. |
Dropped response packets |
Number of dropped responses. |
Login request packets |
Number of sent packets that request to log in to the device. |
Change-password request packets |
Number of sent packets that request to change user passwords. |
Request packets including plaintext passwords |
Number of sent requests that include user passwords in plaintext form. |
Request packets including ciphertext passwords |
Number of requests that include user passwords in encrypted form. |
Pass response packets |
Number of responses that indicate users pass authentication. |
Get-data response packets |
Number of responses that get data. |
Get-username response packets |
Number of responses that get usernames. |
Get-password response packets |
Number of responses that get user passwords. |
Restart response packets |
Number of responses that indicate reauthentication. |
Continue packets |
Number of sent continue packets. |
Continue-abort packets |
Number of sent continue-abort packets. |
PassAdd response packets |
Number of received PassAdd responses. This type of responses indicate that the server agrees to assign all requested authorization attributes and adds other authorization attributes. |
PassReply response packets |
Number of received PassReply responses. This type of responses indicate that the server uses the authorization attributes in the responses to replace the requested authorization attributes. |
Accounting start request packets |
Number of sent start-accounting requests. |
Accounting stop request packets |
Number of sent stop-accounting requests. |
Accounting update request packets |
Number of sent accounting-update requests. |
Success response packets |
Number of received responses that indicate accounting success. |
reset hwtacacs statistics
hwtacacs nas-ip
Use hwtacacs nas-ip to specify a source IP address for outgoing HWTACACS packets.
Use undo hwtacacs nas-ip to delete the specified source IP address for outgoing HWTACACS packets.
hwtacacs nas-ip { ipv4-address | ipv6 ipv6-address } [ vpn-instance vpn-instance-name ]
undo hwtacacs nas-ip { ipv4-address | ipv6 ipv6-address } [ vpn-instance vpn-instance-name ]
The source IP address of an HWTACACS packet sent to the server is the primary IPv4 address or the IPv6 address of the outbound interface.
context-admin
vsys-admin
ipv4-address: Specifies an IPv4 address, which must be an address of the device. The IP address cannot be 0.0.0.0, 255.255.255.255, a class D address, a class E address, or a loopback address.
ipv6 ipv6-address: Specifies an IPv6 address, which must be a unicast address of the device and cannot be a loopback address or a link-local address.
The source IP address of HWTACACS packets that a NAS sends must match the IP address of the NAS that is configured on the HWTACACS server. An HWTACACS server identifies a NAS by IP address. Upon receiving an HWTACACS packet, the HWTACACS server checks the source IP address of the packet.
· If the source IP address of the packet is the IP address of a managed NAS, the server processes the packet.
· If the source IP address of the packet is not the IP address of a managed NAS, the server drops the packet.
As a best practice, specify a loopback interface address as the source IP address for outgoing HWTACACS packets to avoid HWTACACS packet loss caused by physical port errors.
If you use both the nas-ip command and hwtacacs nas-ip command, the following guidelines apply:
· The setting configured by using the nas-ip command in HWTACACS scheme view applies only to the HWTACACS scheme.
· The setting configured by using the hwtacacs nas-ip command in system view applies to all HWTACACS schemes.
· The setting in HWTACACS scheme view takes precedence over the setting in system view.
# Specify IP address 129.10.10.1 as the source IP address for HWTACACS packets.
[Sysname] hwtacacs nas-ip 129.10.10.1
nas-ip (HWTACACS scheme view)
hwtacacs scheme
Use hwtacacs scheme to create an HWTACACS scheme and enter its view, or enter the view of an existing HWTACACS scheme.
Use undo hwtacacs scheme to delete an HWTACACS scheme.
hwtacacs scheme hwtacacs-scheme-name
undo hwtacacs scheme hwtacacs-scheme-name
No HWTACACS schemes exist.
context-admin
vsys-admin
hwtacacs-scheme-name: Specifies the HWTACACS scheme name, a case-insensitive string of 1 to 32 characters.
An HWTACACS scheme can be used by more than one ISP domain at the same time.
You can configure a maximum of 16 HWTACACS schemes.
# Create an HWTACACS scheme named hwt1 and enter HWTACACS scheme view.
hwtacacs server-probe track
Use hwtacacs server-probe track to associate an HWTACACS server with a track entry.
Use undo hwtacacs server-probe track to remove the association between an HWTACACS server and a track entry.
hwtacacs server-probe { ip ipv4-address | ipv6 ipv6-address } [ vpn-instance vpn-instance-name ] [ port port-number ] track track-entry-number
undo hwtacacs server-probe { ip ipv4-address | ipv6 ipv6-address } [ vpn-instance vpn-instance-name ] [ port port-number ] track
An HWTACACS server is not associated with any track entry.
context-admin
ip ipv4-address: Specifies an HWTACACS server by its IPv4 address.
ipv6 ipv6-address: Specifies an HWTACACS server by its IPv6 address.
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN instance to which the HWTACACS server belongs. The vpn-instance-name argument is a case-sensitive string of 1 to 31 characters. If the server is on the public network, do not specify this option.
port port-number: Specifies the service port number of the HWTACACS server. The value range for the TCP port number is 1 to 65535. The default setting is 49.
track-entry-number: Specifies a track entry by its ID, in the range of 1 to 1024.
Use this command on a network that has high real-time requirements for HWTACACS authentication, authorization, and accounting.
By default, the device does not actively detect the status of an HWTACACS server. It changes the state of an HWTACACS server to active or blocked based on the server response timeout timer and the server quiet timer. This timer-based state transition mechanism needs time to determine the server state, and it cannot ensure that the device obtains the actual server state in time. To resolve this issue, associate the server with a track entry and associate the track entry with a TCP-type NQA operation. This HWTACACS server-Track-NQA collaboration can actively detect the reachability of the server in real time.
By using HWTACACS server-Track-NQA collaboration, the device determines the status of an HWTACACS server only based on the detection result.
1. The NQA operation starts to detect the reachability of the server and obtains the result. NQA sends the detection result to the Track module for the Track module to set the state of the track entry.
¡ If the server is reachable, the Track module sets the state of the track entry to Positive.
¡ If the server is unreachable, the Track module sets the state of the track entry to Negative.
¡ If the Track-NQA collaboration does not take effect, the Track module keeps the track entry in NotReady state or changes its state to NotReady.
2. AAA sets the status of the server based on the track entry state.
¡ If the track entry is in Positive state, AAA sets the state of the server to active.
¡ If the track entry is in Negative state, AAA sets the state of the server to blocked and disables the quiet timer for the server.
¡ If the track entry stays in NotReady state or its state changes to NotReady, AAA sets the state of the server to active.
To start the NQA operation to detect the reachability of the server, use the nqa schedule command with appropriate settings for the scheduling parameters. For more information about associating Track with NQA, see Track configuration in Network Management and Monitoring Configuration Guide. For more information about configuring a TCP-type NQA operation and scheduling the NQA operation, see NQA configuration in Network Management and Monitoring Configuration Guide.
# Associate HWTACACS server that uses IP address 10.163.155.13 and TCP port number 49 with track entry 1.
[Sysname] hwtacacs server-probe ip 10.163.155.13 port 49 track 1
nqa schedule (Network Monitoring and Management Command Reference)
track nqa (Network Management and Monitoring Command Reference)
key (HWTACACS scheme view)
Use key to set the shared key for secure HWTACACS authentication, authorization, or accounting communication.
Use undo key to delete the shared key for secure HWTACACS authentication, authorization, or accounting communication.
key { accounting | authentication | authorization } { cipher | simple } string
undo key { accounting | authentication | authorization }
No shared key is configured for secure HWTACACS authentication, authorization, or accounting communication.
context-admin
vsys-admin
accounting: Specifies the shared key for secure HWTACACS accounting communication.
authentication: Specifies the shared key for secure HWTACACS authentication communication.
authorization: Specifies the shared key for secure HWTACACS authorization communication.
string: Specifies the key. This argument is case sensitive. The encrypted form of the key is a string of 1 to 373 characters. The plaintext form of the key is a string of 1 to 255 characters.
The shared keys configured on the device must match those configured on the HWTACACS servers.
# In HWTACACS scheme hwt1, set the shared key to 123456TESTauth&! in plaintext form for secure HWTACACS authentication communication.
[Sysname-hwtacacs-hwt1] key authentication simple 123456TESTauth&!
# Set the shared key to 123456TESTautr&! in plaintext form for secure HWTACACS authorization communication.
[Sysname-hwtacacs-hwt1] key authorization simple 123456TESTautr&!
# Set the shared key to 123456TESTacct&! in plaintext form for secure HWTACACS accounting communication.
[Sysname-hwtacacs-hwt1] key accounting simple 123456TESTacct&!
Use nas-ip to specify a source IP address for outgoing HWTACACS packets.
Use undo nas-ip to delete the specified source IP address for outgoing HWTACACS packets.
undo nas-ip [ ipv6 ]
The source IP address of an outgoing HWTACACS packet is that configured by using the hwtacacs nas-ip command in system view.
If the hwtacacs nas-ip command is not used, the source IP address is the primary IP address of the outbound interface.
context-admin
vsys-admin
For an HWTACACS scheme, you can specify only one source IPv4 address and one source IPv6 address for outgoing HWTACACS packets.
If you do not specify any parameter for the undo nas-ip command, the command deletes the configured source IPv4 address for outgoing HWTACACS packets.
# In HWTACACS scheme hwt1, specify IP address 10.1.1.1 as the source address for outgoing HWTACACS packets.
[Sysname-hwtacacs-hwt1] nas-ip 10.1.1.1
hwtacacs nas-ip
primary accounting (HWTACACS scheme view)
Use primary accounting to specify the primary HWTACACS accounting server.
Use undo primary accounting to restore the default.
primary accounting { ipv4-address | ipv6 ipv6-address } [ port-number | key { cipher | simple } string | single-connection | vpn-instance vpn-instance-name ] *
The primary HWTACACS accounting server is not specified.
context-admin
vsys-admin
ipv4-address: Specifies an IPv4 address of the primary HWTACACS accounting server.
ipv6 ipv6-address: Specifies an IPv6 address of the primary HWTACACS accounting server.
port-number: Specifies the service port number of the primary HWTACACS accounting server. The value range for the TCP port number is 1 to 65535. The default setting is 49.
key: Specifies the shared key for secure communication with the primary HWTACACS accounting server.
single-connection: The device and the primary HWTACACS accounting server use the same TCP connection to exchange accounting packets for all users. If you do not specify this keyword, the device establishes a new TCP connection each time it exchanges accounting packets with the primary accounting server for a user.
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN instance to which the primary HWTACACS accounting server belongs. The vpn-instance-name argument is a case-sensitive string of 1 to 31 characters. If the server is on the public network, do not specify this option.
Make sure the port number and shared key settings of the primary HWTACACS accounting server are the same as those configured on the server.
Two accounting servers specified for a scheme, primary or secondary, cannot have identical VPN instance, IP address, and port number settings.
As a best practice, specify the single-connection keyword to reduce TCP connections for improving system performance if the HWTACACS server supports the single-connection method.
If the specified server resides on an MPLS L3VPN, specify the VPN instance by using the vpn-instance vpn-instance-name option. The VPN instance specified by this command takes precedence over the VPN instance specified for the HWTACACS scheme.
You can remove an accounting server only when it is not used for user accounting. Removing an accounting server affects only accounting processes that occur after the remove operation.
# In HWTACACS scheme hwt1, specify the primary accounting server with IP address 10.163.155.12, TCP port number 49, and plaintext shared key 123456TESTacct&!.
[Sysname-hwtacacs-hwt1] primary accounting 10.163.155.12 49 key simple 123456TESTacct&!
secondary accounting (HWTACACS scheme view)
vpn-instance (HWTACACS scheme view)
primary authentication (HWTACACS scheme view)
Use primary authentication to specify the primary HWTACACS authentication server.
Use undo primary authentication to restore the default.
primary authentication { ipv4-address | ipv6 ipv6-address } [ port-number | key { cipher | simple } string | single-connection | vpn-instance vpn-instance-name ] *
The primary HWTACACS authentication server is not specified.
context-admin
vsys-admin
ipv4-address: Specifies the IPv4 address of the primary HWTACACS authentication server.
ipv6 ipv6-address: Specifies the IPv6 address of the primary HWTACACS authentication server.
port-number: Specifies the service port number of the primary HWTACACS authentication server. The value range for the TCP port number is 1 to 65535. The default setting is 49.
key: Specifies the shared key for secure communication with the primary HWTACACS authentication server.
single-connection: The device and the primary HWTACACS authentication server use the same TCP connection to exchange all authentication packets for all users. If you do not specify this keyword, the device establishes a new TCP connection at each authentication.
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN instance to which the primary HWTACACS authentication server belongs. The vpn-instance-name argument is a case-sensitive string of 1 to 31 characters. If the server is on the public network, do not specify this option.
Make sure the port number and shared key settings of the primary HWTACACS authentication server are the same as those configured on the server.
Two authentication servers specified for a scheme, primary or secondary, cannot have identical VPN instance, IP address, and port number settings.
You can remove an authentication server only when it is not used for user authentication. Removing an authentication server affects only authentication processes that occur after the remove operation.
# In HWTACACS scheme hwt1, specify the primary authentication server with IP address 10.163.155.13, TCP port number 49, and plaintext shared key 123456TESTauth&!.
[Sysname-hwtacacs-hwt1] primary authentication 10.163.155.13 49 key simple 123456TESTauth&!
secondary authentication (HWTACACS scheme view)
primary authorization
Use primary authorization to specify the primary HWTACACS authorization server.
Use undo primary authorization to restore the default.
primary authorization { ipv4-address | ipv6 ipv6-address } [ port-number | key { cipher | simple } string | single-connection | vpn-instance vpn-instance-name ] *
The primary HWTACACS authorization server is not specified.
context-admin
vsys-admin
ipv4-address: Specifies the IPv4 address of the primary HWTACACS authorization server.
ipv6 ipv6-address: Specifies the IPv6 address of the primary HWTACACS authorization server.
port-number: Specifies the service port number of the primary HWTACACS authorization server. The value range for the TCP port number is 1 to 65535. The default setting is 49.
key: Specifies the shared key for secure communication with the primary HWTACACS authorization server.
single-connection: The device and the primary HWTACACS authorization server use the same TCP connection to exchange all authorization packets for all users. If you do not specify this keyword, the device establishes a new TCP connection each time it exchanges authorization packets with the primary authorization server for a user.
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN instance to which the primary HWTACACS authorization server belongs. The vpn-instance-name argument is a case-sensitive string of 1 to 31 characters. If the server is on the public network, do not specify this option.
Make sure the port number and shared key settings of the primary HWTACACS authorization server are the same as those configured on the server.
Two authorization servers specified for a scheme, primary or secondary, cannot have identical VPN instance, IP address, and port number settings.
You can remove an authorization server only when it is not used for user authorization. Removing an authorization server affects only authorization processes that occur after the remove operation.
# In HWTACACS scheme hwt1, specify the primary authorization server with IP address 10.163.155.13, TCP port number 49, and plaintext shared key 123456TESTautr&!.
[Sysname-hwtacacs-hwt1] primary authorization 10.163.155.13 49 key simple 123456TESTautr&!
secondary authorization (HWTACACS scheme view)
Use reset hwtacacs statistics to clear HWTACACS statistics.
reset hwtacacs statistics { accounting | all | authentication | authorization }
context-admin
vsys-admin
accounting: Clears the HWTACACS accounting statistics.
all: Clears all HWTACACS statistics.
authentication: Clears the HWTACACS authentication statistics.
authorization: Clears the HWTACACS authorization statistics.
# Clear all HWTACACS statistics.
<Sysname> reset hwtacacs statistics all
Use secondary accounting to specify a secondary HWTACACS accounting server.
Use undo secondary accounting to remove a secondary HWTACACS accounting server.
secondary accounting { ipv4-address | ipv6 ipv6-address } [ port-number | key { cipher | simple } string | single-connection | vpn-instance vpn-instance-name ] *
No secondary HWTACACS accounting servers are specified.
context-admin
vsys-admin
ipv4-address: Specifies the IPv4 address of a secondary HWTACACS accounting server.
ipv6 ipv6-address: Specifies the IPv6 address of a secondary HWTACACS accounting server.
port-number: Specifies the service port number of the secondary HWTACACS accounting server. The value range for the TCP port number is 1 to 65535. The default setting is 49.
key: Specifies the shared key for secure communication with the secondary HWTACACS accounting server.
single-connection: The device and the secondary HWTACACS accounting server use the same TCP connection to exchange all accounting packets for all users. If you do not specify this keyword, the device establishes a new TCP connection each time it exchanges accounting packets with the secondary accounting server for a user.
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN instance to which the secondary HWTACACS accounting server belongs. The vpn-instance-name argument is a case-sensitive string of 1 to 31 characters. If the server is on the public network, do not specify this option.
Make sure the port number and shared key settings of the secondary HWTACACS accounting server are the same as those configured on the server.
An HWTACACS scheme supports a maximum of 16 secondary HWTACACS accounting servers. If the primary server fails, the device tries to communicate with a secondary server in active state. The device connects to the secondary servers in the order they are configured.
If you do not specify any parameters for the undo secondary accounting command, the command removes all secondary accounting servers.
# In HWTACACS scheme hwt1, specify a secondary accounting server with IP address 10.163.155.12, TCP port number 49, and plaintext shared key 123456TESTacct&!.
[Sysname-hwtacacs-hwt1] secondary accounting 10.163.155.12 49 key simple 123456TESTacct&!
Use secondary authentication to specify a secondary HWTACACS authentication server.
Use undo secondary authentication to remove a secondary HWTACACS authentication server.
secondary authentication { ipv4-address | ipv6 ipv6-address } [ port-number | key { cipher | simple } string | single-connection | vpn-instance vpn-instance-name ] *
No secondary HWTACACS authentication servers are specified.
context-admin
vsys-admin
ipv4-address: Specifies the IPv4 address of a secondary HWTACACS authentication server.
ipv6 ipv6-address: Specifies the IPv6 address of a secondary HWTACACS authentication server.
port-number: Specifies the service port number of the secondary HWTACACS authentication server. The value range for the TCP port number is 1 to 65535. The default setting is 49.
key: Specifies the shared key for secure communication with the secondary HWTACACS authentication server.
single-connection: The device and the secondary HWTACACS authentication server use the same TCP connection to exchange all authentication packets for all users. If you do not specify this keyword, the device establishes a new TCP connection each time it exchanges authentication packets with the secondary authentication server for a user.
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN instance to which the secondary HWTACACS authentication server belongs. The vpn-instance-name argument is a case-sensitive string of 1 to 31 characters. If the server is on the public network, do not specify this option.
Make sure the port number and shared key settings of each secondary HWTACACS authentication server are the same as those configured on the corresponding server.
An HWTACACS scheme supports a maximum of 16 secondary HWTACACS authentication servers. If the primary server fails, the device tries to communicate with a secondary server in active state. The device connects to the secondary servers in the order they are configured.
If you do not specify any parameters for the undo secondary authentication command, the command removes all secondary authentication servers.
# In HWTACACS scheme hwt1, specify a secondary authentication server with IP address 10.163.155.13, TCP port number 49, and plaintext shared key 123456TESTauth&!.
[Sysname-hwtacacs-hwt1] secondary authentication 10.163.155.13 49 key simple 123456TESTauth&!
Use secondary authorization to specify a secondary HWTACACS authorization server.
Use undo secondary authorization to remove a secondary HWTACACS authorization server.
secondary authorization { ipv4-address | ipv6 ipv6-address } [ port-number | key { cipher | simple } string | single-connection | vpn-instance vpn-instance-name ] *
undo secondary authorization [ { ipv4-address | ipv6 ipv6-address } [ port-number | vpn-instance vpn-instance-name ] * ]
No secondary HWTACACS authorization servers are specified.
context-admin
vsys-admin
ipv4-address: Specifies the IPv4 address of a secondary HWTACACS authorization server.
ipv6 ipv6-address: Specifies the IPv6 address of a secondary HWTACACS authorization server.
port-number: Specifies the service port number of the secondary HWTACACS authorization server. The value range for the TCP port number is 1 to 65535. The default setting is 49.
key: Specifies the shared key for secure communication with the secondary HWTACACS authorization server.
single-connection: The device and the secondary HWTACACS authorization server use the same TCP connection to exchange all authorization packets for all users. If you do not specify this keyword, the device establishes a new TCP connection each time it exchanges authorization packets with the secondary authorization server for a user.
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN instance to which the secondary HWTACACS authorization server belongs. The vpn-instance-name argument is a case-sensitive string of 1 to 31 characters. If the server is on the public network, do not specify this option.
Make sure the port number and shared key settings of the secondary HWTACACS authorization server are the same as those configured on the server.
An HWTACACS scheme supports a maximum of 16 secondary HWTACACS authorization servers. If the primary server fails, the device tries to communicate with a secondary server in active state. The device connects to the secondary servers in the order they are configured.
If you do not specify any parameters for the undo secondary authorization command, the command removes all secondary authorization servers.
# In HWTACACS scheme hwt1, specify a secondary authorization server with IP address 10.163.155.13, TCP port number 49, and plaintext shared key 123456TESTautr&!.
[Sysname-hwtacacs-hwt1] secondary authorization 10.163.155.13 49 key simple 123456TESTautr&!
primary authorization (HWTACACS scheme view)
server-block-action
Use server-block-action to specify the action to take for AAA requests if all servers in an HWTACACS scheme are blocked.
Use undo server-block-action to restore the default.
server-block-action { attempt | skip }
The device attempts to connect to the server with the highest priority in an HWTACACS scheme upon receiving AAA requests if all servers in the scheme are blocked.
context-admin
vsys-admin
attempt: Attempts to connect to the server that has the highest priority in the scheme. (Typically, the highest-priority server is the primary server. If no primary server is specified, it is the firstly configured secondary server. Primary and secondary servers manually set in block state are not used.) If the device fails to connect to the server, it turns to the backup method.
skip: Skips all servers in the scheme and turns to the backup method.
The attempt action gives the device a chance to use the scheme in case the server with the highest priority in the scheme might be available. However, the attempt to communicate with an unavailable server increases the response time for AAA requests. As a best practice, specify the skip action in scenarios that require quick responses to AAA requests.
When processing an AAA request, the device does not turn back to a skipped scheme even though the state of the servers in the scheme changes from blocked to active.
# In HWTACACS scheme hwt1, configure the device to skip all servers in the scheme upon receiving AAA requests if all servers in the scheme are blocked.
[Sysname-hwtacacs-hwt1] server-block-action skip
timer quiet (HWTACACS scheme view)
Use timer quiet to set the quiet timer for the servers specified in an HWTACACS scheme.
timer quiet minutes
undo timer quiet
The server quiet period is 5 minutes.
context-admin
vsys-admin
# In HWTACACS scheme hwt1, set the server quiet timer to 10 minutes.
[Sysname-hwtacacs-hwt1] timer quiet 10
timer realtime-accounting (HWTACACS scheme view)
timer realtime-accounting minutes
context-admin
vsys-admin
minutes: Specifies the real-time accounting interval in minutes, in the range of 0 to 60. Setting this interval to 0 disables the device from sending online user accounting information to the HWTACACS accounting server.
For real-time accounting, a NAS must transmit the accounting information of online users to the HWTACACS accounting server periodically. This command is used to set the interval.
Table 22 Recommended real-time accounting intervals
Number of users |
1 to 99 |
3 minutes |
100 to 499 |
6 minutes |
500 to 999 |
12 minutes |
1000 or more |
# In HWTACACS scheme hwt1, set the real-time accounting interval to 51 minutes.
[Sysname-hwtacacs-hwt1] timer realtime-accounting 51
timer response-timeout (HWTACACS scheme view)
Use timer response-timeout to set the HWTACACS server response timeout timer.
The HWTACACS server response timeout time is 5 seconds.
context-admin
vsys-admin
seconds: Specifies the HWTACACS server response timeout time, in the range of 1 to 300 seconds.
HWTACACS is based on TCP. When the server response timeout timer or the TCP timeout timer times out, the device is disconnected from the HWTACACS server.
The client timeout period of the associated access module cannot be shorter than the total response timeout timer of all HWTACACS servers in the scheme. Any violation will result in user logoffs before the authentication, authorization, or accounting process is complete.
# In HWTACACS scheme hwt1, set the HWTACACS server response timeout timer to 30 seconds.
[Sysname-hwtacacs-hwt1] timer response-timeout 30
user-name-format (HWTACACS scheme view)
Use user-name-format to specify the format of the username to be sent to an HWTACACS server.
The ISP domain name is included in the usernames sent to an HWTACACS server.
context-admin
vsys-admin
keep-original: Sends the username to the HWTACACS server as the username is entered.
with-domain: Includes the ISP domain name in the username sent to the HWTACACS server.
without-domain: Excludes the ISP domain name from the username sent to the HWTACACS server.
A username is generally in the userid@isp-name format, of which the isp-name argument is used by the device to determine the ISP domain to which a user belongs. However, some HWTACACS servers cannot recognize a username containing an ISP domain name. Before sending a username including a domain name to such an HWTACACS server, the device must remove the domain name. This command allows you to specify whether to include a domain name in a username to be sent to an HWTACACS server.
If an HWTACACS scheme defines that the username is sent without the ISP domain name, do not apply the scheme to more than one ISP domain. Otherwise, the HWTACACS server will consider two users in different ISP domains but with the same userid as one user.
# In HWTACACS scheme hwt1, configure the device to remove the ISP domain name from the usernames sent to the HWTACACS servers.
[Sysname-hwtacacs-hwt1] user-name-format without-domain
Use vpn-instance to specify an MPLS L3VPN instance for an HWTACACS scheme.
undo vpn-instance
The HWTACACS scheme belongs to the public network.
context-admin
The VPN instance specified for an HWTACACS scheme applies to all servers in that scheme. If a VPN instance is also configured for an individual HWTACACS server, the VPN instance specified for the HWTACACS scheme does not take effect on that server.
# Specify VPN instance test for HWTACACS scheme hwt1.
[Sysname-hwtacacs-hwt1] vpn-instance test
LDAP commands
attribute-map
Use attribute-map to specify the LDAP attribute map in an LDAP scheme.
Use undo attribute-map to restore the default.
attribute-map map-name
undo attribute-map
An LDAP scheme does not use an LDAP attribute map.
LDAP scheme view
context-admin
vsys-admin
map-name: Specifies an LDAP attribute map by its name, a case-sensitive string of 1 to 31 characters.
When the LDAP scheme used for authorization contains an LDAP attribute map, the device converts server-assigned LDAP attributes to device-recognizable AAA attributes based on the mapping entries.
You can specify only one LDAP attribute map in an LDAP scheme. If you execute this command multiple times, the most recent configuration takes effect.
If you specify another attribute map or change the mapping entries, the new settings take effect only on the LDAP authorization that occurs after your operation.
# Specify LDAP attribute map map1 in LDAP scheme ldap1.
[Sysname] ldap scheme ldap1
[Sysname-ldap-ldap1] attribute-map map1
display ldap scheme
ldap attribute-map
authentication-server
Use authentication-server to specify the LDAP authentication server for an LDAP scheme.
Use undo authentication-server to restore the default.
authentication-server server-name
No LDAP authentication server is specified for an LDAP scheme.
LDAP scheme view
context-admin
vsys-admin
server-name: Specifies the name of an LDAP server, a case-sensitive string of 1 to 64 characters.
You can specify only one LDAP authentication server in an LDAP scheme. If you execute this command multiple times, the most recent configuration takes effect.
# In LDAP scheme ldap1, specify the LDAP authentication server as ccc.
[Sysname-ldap-ldap1] authentication-server ccc
display ldap scheme
ldap server
authorization-server
Use authorization-server to specify the LDAP authorization server for an LDAP scheme.
Use undo authorization-server to restore the default.
authorization-server server-name
No LDAP authorization server is specified for an LDAP scheme.
LDAP scheme view
context-admin
vsys-admin
You can specify only one LDAP authorization server in an LDAP scheme. If you execute this command multiple times, the most recent configuration takes effect.
# In LDAP scheme ldap1, specify the LDAP authorization server as ccc.
[Sysname-ldap-ldap1] authorization-server ccc
display ldap scheme
ldap server
character-encoding
Use character-encoding to specify the character encoding format for an LDAP server.
Use undo character-encoding to restore the default.
character-encoding { gb18030 | utf-8 }
No character encoding format is specified for an LDAP server. The device does not change the character encoding format for information exchanged with the LDAP server.
LDAP server view
context-admin
vsys-admin
gb18030: Specifies the GB18030 character encoding format.
utf-8: Specifies the UTF-8 character encoding format.
By default, the device encodes the configuration made through the Web interface in GB18030 and that made through terminal software in the character encoding format used by the software. If the device and the LDAP server use different character encoding formats, some characters in the exchanged information might fail to be interpreted, causing further issues. For example, if user DNs on the LDAP server are Chinese and the user DNs on the device are English, user DN search will fail and the users will fail to come online. To resolve this issue, use this command to ensure that the device and the LDAP server use the same character encoding format.
After you specify the character encoding format for an LDAP server, the device processes LDAP packets exchanged with the LDAP server as follows:
· For an LDAP packet sent to the LDAP server, the device first decodes the information in the packet by using GB18030. Then, the device uses the specified character encoding format to encode the information.
· For an LDAP packet received form the LDAP server, the device first uses the specified character encoding format to decode the information in the packet. Then, the device uses GB18030 to encode the information and saves the information.
As a best practice to avoid LDAP authentication failure caused by inconsistent character encoding format, change the character encoding format before using the LDAP server to perform authentication on users.
# Specify UTF-8 as the character encoding format for LDAP server ccc.
[Sysname] ldap server ccc
[Sysname-ldap-server-ccc] character-encoding utf-8
display ldap scheme
display ldap scheme
Use display ldap scheme to display LDAP scheme configuration.
display ldap scheme [ ldap-scheme-name ]
context-admin
context-operator
vsys-admin
vsys-operator
ldap-scheme-name: Specifies an LDAP scheme by its name, a case-insensitive string of 1 to 32 characters. If you do not specify an LDAP scheme, this command displays the configuration of all LDAP schemes.
# Display the configuration of all LDAP schemes.
<Sysname> display ldap scheme
Total 1 LDAP schemes
LDAP scheme name : aaa
Authentication server : aaa
IP : 1.1.1.1
Port : 111
VPN instance : Not configured
Source IP : Provided by interface
GigabitEthernet1/0/1
LDAP protocol version : LDAPv3
Server timeout interval : 10 seconds
Login account DN : Not configured
Base DN : Not configured
Search scope : all-level
User searching parameters:
User object class : Not configured
Username attribute : cn
Username format : with-domain
Group filter : (objectclass=group)
Character encoding : UTF-8
Authorization server : aaa
IP : 1.1.1.1
Port : 111
Source IP : 2.2.2.2
Character encoding : GB18030
Attribute map : map1
Search-result-reference : Ignored
Table 23 Command output
Authentication server |
Name of the LDAP authentication server. If no server is configured, this field displays Not configured. |
Authorization server |
Name of the LDAP authorization server. If no server is configured, this field displays Not configured. |
IP |
IP address of the LDAP server. If no server is specified, this field displays Not configured. |
Port |
Port number of the server. If no port number is specified, this field displays the default port number. |
VPN instance |
MPLS L3VPN instance to which the LDAP server belongs. If no VPN instance is specified, this field displays Not configured. |
Source IP |
Source IP address for LDAP packets sent to the LDAP server. If no source IP address is specified, this field displays Not configured. |
LDAP protocol version |
LDAP version, LDAPv2 or LDAPv3. |
Server timeout interval |
LDAP server timeout period, in seconds. |
Login account DN |
DN of the administrator. |
Base DN |
Base DN for user search. |
Search scope |
User DN search scope, including: · all-level—All subdirectories. · single-level—Next lower level of subdirectories under the base DN. |
User searching parameters |
User search parameters. |
User object class |
User object class for user DN search. If no user object class is configured, this field displays Not configured. |
Username attribute |
User account attribute for login. |
Username format |
Format for the username sent to the server. |
Group filter |
User group filter. |
Character encoding |
Character encoding format for the LDAP server: · GB18030. · UTF-8. This field is not available if no character encoding format has been specified for the LDAP server. |
Attribute map |
LDAP attribute map used by the scheme. If no LDAP attribute map is used, this field displays Not configured. |
Search-result-reference |
Whether the device ignores the SearchResultReference fields in LDAP responses. · Ingored—Ignores the SearchResultReference fields. · Not ignored—Processes the SearchResultReference fields. |
group-filter
Use group-filter to configure the user group filter.
Use undo group-filter to restore the default.
group-filter group-filter
undo group-filter
The user group filter is (objectclass=group).
LDAP server view
context-admin
vsys-admin
group-filter: Specifies the user group filter, a case-sensitive string of 1 to 127 characters. The syntax of the filter must meet the filter syntax requirements defined by LDAP servers.
When the device requests to import user group information from an LDAP server, the LDAP server sends only user groups that match the user group filter to the device.
# Configure the user group filter as (&(objectclass=group)(name=group1)) for LDAP server ccc.
[Sysname-ldap-server-ccc] group-filter (&(objectclass=group)(name=group1))
display ldap scheme
ignore search-result-reference
Use ignore search-result-reference to have the device ignore the SearchResultReference fields in LDAP search results.
Use undo ignore search-result-reference to restore the default.
The device processes the SearchResultReference fields in LDAP search results.
LDAP scheme view
context-admin
vsys-admin
In distributed LDAP database deployment, an LDAP server sends one or more SearchResultReference fields in a user DN query response if it fails to find all the requested user DNs. Each SearchResultReference field carries the URL of one LDAP server that the device can continue querying.
By default, when the device receives a query response that contains SearchResultReference fields, it performs the following operations if it is enabled with the DNS client:
1. Performs domain name resolution for the URL in each SearchResultReference field.
2. Sends a user DN query request to the successfully resolved LDAP server addresses as an anonymous user, without doing administrator binding.
During this process, a single domain name resolution or LDAP anonymous query failure will result in the failure of the LDAP query process as a whole. The device will discard all obtained query results.
As a best practice, enable the device to ignore SearchResultReference fields if the following conditions are met:
· The DNS client feature is enabled on it.
· The LDAP server administrator confirms that the desired user data is all stored in one of the LDAP databases.
After you enable this feature in LDAP scheme view, the device will ignore the SearchResultReference fields carried in the LDAP query responses and save the obtained user data. This feature helps avoid the overall query failure in the following situations:
· The LDAP server includes SearchResultReference fields in query responses because of incorrect deployment. The device fails to complete domain name resolution for all URLs in the SearchResultReference field in time.
·The LDAP server rejects anonymous query requests, because it does not support anonymous query.
# In LDAP scheme ldap1, configure the device to ignore the SearchResultReference fields in LDAP search results.
[Sysname-ldap-ldap1] ignore search-result-reference
display ldap scheme
ip
Use ip to configure the IP address of the LDAP server.
Use undo ip to restore the default.
ip ip-address [ port port-number ] [ vpn-instance vpn-instance-name ]
undo ip
An LDAP server does not have an IP address.
LDAP server view
context-admin
vsys-admin
ip-address: Specifies the IP address of the LDAP server.
port port-number: Specifies the TCP port number of the LDAP server. The value range for the port-number argument is 1 to 65535, and the default value is 389.
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN instance to which the LDAP server belongs. The vpn-instance-name argument is a case-sensitive string of 1 to 31 characters. If the server is on the public network, do not specify this option.
The LDAP service port configured on the device must be consistent with the service port of the LDAP server.
If you change the IP address and port number of the LDAP server, the change takes effect only on the LDAP authentication that occurs after the change.
# Specify the IP address and port number as 192.168.0.10 and 4300 for LDAP server ccc.
[Sysname-ldap-server-ccc] ip 192.168.0.10 port 4300
ldap server
ipv6
Use ipv6 to configure the IPv6 address of the LDAP server.
Use undo ipv6 to restore the default.
ipv6 ipv6-address [ port port-number ] [ vpn-instance vpn-instance-name ]
undo ipv6
An LDAP server does not have an IPv6 address.
LDAP server view
context-admin
vsys-admin
ipv6-address: Specifies the IPv6 address of the LDAP server.
# Specify the IPv6 address and port number as 1:2::3:4 and 4300 for LDAP server ccc.
[Sysname-ldap-server-ccc] ipv6 1:2::3:4 port 4300
ldap server
ldap attribute-map
Use ldap attribute-map to create an LDAP attribute map and enter its view, or enter the view of an existing LDAP attribute map.
Use undo ldap attribute-map to delete an LDAP attribute map.
ldap attribute-map map-name
undo ldap attribute-map map-name
No LDAP attribute maps exist.
context-admin
vsys-admin
map-name: Specifies the name of the LDAP attribute map, a case-sensitive string of 1 to 31 characters.
Execute this command multiple times to create multiple LDAP attribute maps. You can add multiple mapping entries to an LDAP attribute map. Each entry defines the mapping between an LDAP attribute and an AAA attribute.
# Create an LDAP attribute map named map1 and enter LDAP attribute map view.
[Sysname] ldap attribute-map map1
[Sysname-ldap-map-map1]
attribute-map
ldap scheme
map
ldap scheme
Use ldap scheme to create an LDAP scheme and enter its view, or enter the view of an existing LDAP scheme.
Use undo ldap scheme to delete an LDAP scheme.
ldap scheme ldap-scheme-name
undo ldap scheme ldap-scheme-name
No LDAP schemes exist.
context-admin
vsys-admin
ldap-scheme-name: Specifies the LDAP scheme name, a case-insensitive string of 1 to 32 characters.
An LDAP scheme can be used by more than one ISP domain at the same time.
You can configure a maximum of 16 LDAP schemes.
# Create an LDAP scheme named ldap1 and enter LDAP scheme view.
display ldap scheme
ldap server
Use ldap server to create an LDAP server and enter its view, or enter the view of an existing LDAP server.
Use undo ldap server to delete an LDAP server.
ldap server server-name
undo ldap server server-name
No LDAP servers exist.
context-admin
vsys-admin
server-name: Specifies the LDAP server name, a case-insensitive string of 1 to 64 characters.
# Create an LDAP server named ccc and enter LDAP server view.
display ldap scheme
login-dn
Use login-dn to specify the administrator DN.
Use undo login-dn to restore the default.
login-dn dn-string
undo login-dn
No administrator DN is specified.
LDAP server view
context-admin
vsys-admin
dn-string: Specifies the administrator DN for binding with the server, a case-insensitive string of 1 to 255 characters.
The administrator DN specified on the device must be consistent with the administrator DN configured on the LDAP server.
If you change the administrator DN, the change takes effect only on the LDAP authentication that occurs after the change.
# Specify the administrator DN as uid=test, ou=people, o=example, c=city for LDAP server ccc.
[Sysname-ldap-server-ccc] login-dn uid=test,ou=people,o=example,c=city
display ldap scheme
login-password
Use login-password to configure the administrator password for binding with the LDAP server during LDAP authentication.
Use undo login-password to restore the default.
login-password { cipher | simple } string
undo login-password
No administrator password is configured.
LDAP server view
context-admin
vsys-admin
string: Specifies the password. Its plaintext form is a case-sensitive string of 1 to 128 characters. Its encrypted form is a case-sensitive string of 1 to 201 characters.
This command takes effect only after the login-dn command is used.
# Specify the administrator password as abcdefg in plaintext form for LDAP server ccc.
[Sysname-ldap-server-ccc] login-password simple abcdefg
display ldap scheme
login-dn
map
Use map to configure a mapping entry in an LDAP attribute map.
Use undo map to delete the specified mapping entries from the LDAP attribute map.
map ldap-attribute ldap-attribute-name [ prefix prefix-value ] [ delimiter delimiter-value ] aaa-attribute user-group
undo map [ ldap-attribute ldap-attribute-name ]
An LDAP attribute map does not contain mapping entries.
context-admin
vsys-admin
ldap-attribute ldap-attribute-name: Specifies an LDAP attribute by its name. The ldap-attribute-name argument is a case-sensitive string of 1 to 63 characters.
prefix prefix-value: Specifies a partial value string of the LDAP attribute for attribute mapping. The prefix-value argument represents the prefix of the attribute value to match. The prefix is a case-sensitive string of 1 to 7 characters, such as cn=. You do not need to specify a prefix if the attribute string to match does not contain one. a prefix, you do not need to specify t The delimiter-value argument represents the position where the partial string ends, such as a comma (,). If you do not specify a prefix or delimiter, the mapping entry uses the entire value string for the LDAP attribute.
delimiter delimiter-value: Specifies the delimiter, for example, a comma (,), that separates the value string to match from the next value string in the attribute. You do not need to specify a delimiter if the attribute string to match is not separated by one. If you do not specify a prefix or delimiter, the mapping entry uses the entire value string for the LDAP attribute.
aaa-attribute: Specifies an AAA attribute.
mobile-number: AAA attributes of the mobile number type.
user-group: Specifies the user group attribute.
Because the device ignores unrecognized LDAP attributes, configure the mapping entries to include important LDAP attributes that should not be ignored.
An LDAP attribute can be mapped only to one AAA attribute. Different LDAP attributes can be mapped to the same AAA attribute.
If you do not specify an LDAP attribute for the undo map command, the command deletes all mapping entries from the LDAP attribute map.
# In LDAP attribute map map1, map a partial value string of the LDAP attribute named memberof to AAA attribute named user-group.
[Sysname-ldap-map-map1] map ldap-attribute memberof prefix cn= delimiter , aaa-attribute user-group
ldap attribute-map
user-group
protocol-version
Use protocol-version to specify the LDAP version.
Use undo protocol-version to restore the default.
protocol-version { v2 | v3 }
The LDAP version is LDAPv3.
LDAP server view
context-admin
vsys-admin
v2: Specifies the LDAP version LDAPv2.
v3: Specifies the LDAP version LDAPv3.
For successful LDAP authentication, the LDAP version used by the device must be consistent with the version used by the LDAP server.
If you change the LDAP version, the change takes effect only on the LDAP authentication that occurs after the change.
A Microsoft LDAP server supports only LDAPv3.
# Specify the LDAP version as LDAPv2 for LDAP server ccc.
[Sysname-ldap-server-ccc] protocol-version v2
display ldap scheme
search-base-dn
Use search-base-dn to specify the base DN for user search.
Use undo search-base-dn to restore the default.
search-base-dn base-dn
undo search-base-dn
No base DN is specified for user search.
LDAP server view
context-admin
vsys-admin
base-dn: Specifies the base DN for user search, a case-insensitive string of 1 to 255 characters.
# Specify the base DN for user search as dc=ldap,dc=com for LDAP server ccc.
[Sysname-ldap-server-ccc] search-base-dn dc=ldap,dc=com
display ldap scheme
ldap server
search-scope
Use search-scope to specify the user search scope.
Use undo search-scope to restore the default.
search-scope { all-level | single-level }
undo search-scope
The user search scope is all-level.
LDAP server view
context-admin
vsys-admin
all-level: Specifies that the search goes through all subdirectories of the base DN.
single-level: Specifies that the search goes through only the next lower level of subdirectories under the base DN.
# Specify the search scope for the LDAP authentication as all subdirectories of the base DN for LDAP server ccc.
[Sysname-ldap-server-ccc] search-scope all-level
display ldap scheme
ldap server
server-timeout
Use server-timeout to set the LDAP server timeout period, the maximum time that the device waits for an LDAP response.
Use undo server-timeout to restore the default.
server-timeout time-interval
undo server-timeout
The LDAP server timeout period is 10 seconds.
LDAP server view
context-admin
vsys-admin
time-interval: Specifies the LDAP server timeout period in the range of 5 to 20 seconds.
If you change the LDAP server timeout period, the change takes effect only on the LDAP authentication that occurs after the change.
# Set the LDAP server timeout period to 15 seconds for LDAP server ccc.
[Sysname-ldap-server-ccc] server-timeout 15
display ldap scheme
source-ip
Use source-ip to specify a source interface or source IP address for outgoing LDAP packets.
Use undo source-ip to remove the source interface or the source IP address of the specified type for outgoing LDAP packets.
source-ip { ipv4-address | interface interface-type interface-number | ipv6 ipv6-address }
undo source-ip [ interface | ipv6 ]
No IP address is specified as the source IP address of LDAP packets sent to an LDAP server. The device uses the primary IPv4 address or the IPv6 address of the outbound interface that can reach the server as the source IP address of LDAP packets sent to the server.
LDAP server view
context-admin
vsys-admin
interface interface-type interface-number: Specifies a source interface by its type and number. The device uses the primary IPv4 address or the IPv6 address of the interface as the source IP address of an outgoing LDAP packet.
When you use this command for an LDAP server, follow these restrictions and guidelines:
· You can specify only one source IPv4 address and one source IPv6 address for LDAP packets sent to the server.
· You can specify only one source interface. Make sure the source interface can reach the server.
· To ensure that the source interface configuration can take effect, the VPN instance of the source interface must be the same as the VPN instance of the server.
· To ensure that the source address configuration can take effect, the IP version of the specified source address must be the same as that of the server IP address.
· The source interface configuration and the source address configuration overwrite each other.
# In the view of LDAP server ccc, configure 3.3.3.3 as the source IP address for outgoing LDAP packets.
[Sysname-ldap-server-ccc] source-ip 3.3.3.3
# In the view of LDAP server ddd, specify GigabitEthernet 1/0/1 as the source interface for outgoing LDAP packets.
[Sysname] ldap server ddd
[Sysname-ldap-server-ddd] source-ip interface gigabitethernet 1/0/1
user-parameters
Use user-parameters to configure LDAP user attributes, including the username attribute, username format, and user-defined user object class.
Use undo user-parameters to restore the default of an LDAP user attribute.
user-parameters { user-name-attribute { name-attribute | cn | uid } | user-name-format { with-domain | without-domain } | user-object-class object-class-name }
undo user-parameters { user-name-attribute | user-name-format | user-object-class }
The LDAP username attribute is cn and the username format is without-domain. No user object class is specified and the default user object class of the LDAP server is used.
LDAP server view
context-admin
vsys-admin
user-name-attribute { name-attribute | cn | uid }: Specifies the username attribute. The name-attribute argument represents an attribute value, a case-insensitive string of 1 to 64 characters. The cn keyword represents the user account attribute of common name, and the uid keyword represents the user account attribute of user ID.
user-name-format { with-domain | without-domain }: Specifies the format of the username to be sent to the server. The with-domain keyword means that the username contains the domain name, and the without-domain keyword means that the username does not contain the domain name.
user-object-class object-class-name: Specifies the user object class for user search. The object-class-name argument represents a class value, a case-insensitive string of 1 to 64 characters.
If the username on the LDAP server does not contain the domain name, specify the without-domain keyword. If the username contains the domain name, specify the with-domain keyword.
# Set the user object class to person for LDAP server ccc.
[Sysname-ldap-server-ccc] user-parameters user-object-class person
display ldap scheme
login-dn
AAA private protocol commands
The following compatibility matrix shows the support of hardware platforms for AAA private protocols:
Hardware series |
Model |
AAA private protocol compatibility |
F5000 series |
F5000-AI-40, F5000-AI-20, F5000-AI-15 |
Yes |
F5000-AI160, F5000-CN160, F5000-CN-G85, F5000-CN-G65, F5000-CN-G55 |
No |
F1000 series |
F1000-AI-25 |
Yes |
aaa bjca-auth-server
Use aaa bjca-auth-server to create a BJCA authentication server and enter its view, or enter the view of an existing BJCA authentication server.
Use undo aaa bjca-auth-server to delete a BJCA authentication server.
aaa bjca-auth-server bjca-auth-server-name
undo aaa bjca-auth-server bjca-auth-server-name
No BJCA authentication servers exist.
context-admin
vsys-admin
bjca-auth-server-name: Specifies a name for the BJCA authentication server, a case-insensitive string of 1 to 64 characters.
The device exchanges HTTP-based AAA private protocol packets with the BJCA authentication server to perform identity authentication for endpoints.
You can specify the same BJCA authentication server in multiple AAA private protocol schemes.
The system supports a maximum of 16 BJCA authentication servers.
# Create a BJCA authentication server named ccc and enter its view.
[Sysname] aaa bjca-auth-server bbb
[Sysname-bjca-auth-server-bbb]
display aaa-private-protocol scheme
aaa jit-auth-server
Use aaa jit-auth-server to create a Jilin University Information Technologies (JIT) authentication server and enter its view, or enter the view of an existing JIT authentication server.
Use undo aaa jit-auth-server to delete a JIT authentication server.
aaa jit-auth-server jit-auth-server-name
undo aaa jit-auth-server jit-auth-server-name
No JIT authentication servers exist.
context-admin
vsys-admin
jit-auth-server-name: Specifies a name for the JIT authentication server, a case-insensitive string of 1 to 64 characters.
The device exchanges HTTP-based AAA private protocol packets with the JIT authentication server to perform identity authentication for access endpoints.
You can specify the same JIT authentication server in multiple AAA private protocol schemes.
The system supports a maximum of 16 JIT authentication servers.
# Create a JIT authentication server named ccc and enter its view.
[Sysname] aaa jit-auth-server ccc
[Sysname-jit-auth-server-ccc]
aaa private-protocol scheme
Use aaa private-protocol scheme to create an AAA private protocol scheme and enter its view, or enter the view of an existing AAA private protocol scheme.
Use undo aaa private-protocol scheme to delete an AAA private protocol scheme.
aaa private-protocol scheme scheme-name
undo aaa private-protocol scheme scheme-name
No AAA private protocol schemes exist.
context-admin
vsys-admin
scheme-name: Specifies a name for the AAA private protocol scheme, a case-insensitive string of 1 to 32 characters.
An AAA private protocol scheme is used to define the parameters used by the device to communicate with an AAA server that uses a private protocol.
You can apply an AAA private protocol scheme to multiple ISP domains.
The system supports a maximum of 16 AAA private protocol schemes.
# Create an AAA private protocol scheme named pp1 and enter its view.
[Sysname] aaa private-protocol scheme pp1
[Sysname-aaa-priv-prot-pp1]
appid
Use appid to specify an app ID for an AAA private protocol authentication server.
Use undo appid to restore the default.
appid appid-string
undo appid
No app ID is specified for an AAA private protocol authentication server.
BJCA authentication server view
JIT authentication server view
context-admin
vsys-admin
appid-string: Specifies an AAA private protocol app ID by its name, a case-sensitive string of 1 to 32 characters.
An app ID uniquely identifies an application system (for example, a medical insurance service system) on the AAA private protocol authentication server. When a client for the AAA private protocol application system comes online through the device, the device sends an authentication request that contains the app ID of the application system to the server.
To communicate with a BJCA authentication server, configure the app ID only on the IPsec tunnel responder.
To communicate with a JIT authentication server, configure the app ID on both the IPsec tunnel initiator and responder.
# Specify app ID user1 for the JIT authentication server named ccc.
[Sysname-jit-auth-server-ccc] appid user1
# Specify app ID user1 for the BJCA authentication server named bbb.
[Sysname-bjca-auth-server-bbb] appid user1
authentication-server (AAA private-protocol scheme view)
Use authentication-server jit-auth-server to specify an authentication server for an AAA private protocol scheme.
Use undo authentication-server jit-auth-server to delete the specified server.
authentication-server { bjca-auth-server | jit-auth-server } auth-server-name
undo authentication-server { bjca-auth-server | jit-auth-server }
No authentication server is specified for an AAA private protocol scheme.
AAA private protocol scheme view
context-admin
vsys-admin
bjca-auth-server: Specifies a BJCA server.
jit-auth-server: Specifies a JIT server.
auth-server-name: Specifies an authentication server by its name, a case-insensitive string of 1 to 64 characters.
You can specify only one authentication server (BJCA or JIT) in an AAA private protocol scheme. If you execute this command multiple times for the same server type, the most recent configuration takes effect. To specify a different type of authentication server than the existing server in the scheme, you must first delete the existing authentication server from the scheme.
# In AAA private protocol scheme pp1, specify JIT authentication server ccc.
[Sysname-aaa-priv-prot-pp1] authentication-server jit-auth-server ccc
# In AAA private protocol scheme pp2, specify BJCA authentication server bbb.
[Sysname] aaa private-protocol scheme pp2
[Sysname-aaa-priv-prot-pp2] authentication-server bjca-auth-server bbb
aaa jit-auth-server
Use display aaa-private-protocol scheme to display configuration information for AAA private protocol schemes.
display aaa-private-protocol scheme [ scheme-name ]
context-admin
context-operator
vsys-admin
vsys-operator
scheme-name: Specifies an AAA private protocol scheme by its name, a case-insensitive string of 1 to 32 characters. If you do not specify an AAA private protocol scheme, this command displays configuration information for all AAA private protocol schemes.
# Display configuration information for all AAA private protocol schemes.
<Sysname> display aaa-private-protocol scheme
Total 2 AAA private protocol schemes
AAA private protocol scheme name: pp2
Authentication server : bjca-server-1
Random number service URL : https://xyz
Token service URL : https://xyz
Token-auth service URL : https://xyz
App ID : 123
VPN instance : aaa
PKI domain : pk1
Response timeout : 300 seconds
AAA private protocol scheme name: pp1
Authentication server : jit-server-1
URL : https://xxx
App ID : 123
PKI domain : Not configured
Response timeout : 5 seconds
Table 24 Command output
Name of the authentication server in an AAA private protocol scheme. If no authentication server is specified, this field displays Not configured. |
URL |
URL of the JIT authentication server. If no authentication server URL is specified, this field displays Not configured. |
Random number service URL |
URL for obtaining a random number from the BJCA server. If no random number service URL is specified, this field displays Not configured. |
Token service URL |
URL for obtaining a Token from the BJCA server. If no Token service URL is specified, this field displays Not configured. |
Token-auth service URL |
URL for initiating Token authentication to the BJCA server. If no Token-auth service URL is specified, this field displays Not configured. |
App ID |
App ID of the authentication server. If no app ID is specified, this field displays Not configured. |
VPN instance |
VPN instance name. If no VPN instance name is specified, this field displays Not configured. |
PKI domain |
PKI domain name. If no PKI domain name is specified, this field displays Not configured. |
Response timeout |
Response timeout time of the authentication server, in seconds. If no response timeout time is configured for the authentication server, this field displays the default response timeout time. |
aaa jit-auth-server
key
Use key to specify the shared key used for communication with the BJCA server.
Use undo key to delete the configured shared key used for communication with the BJCA server.
undo key
No shared key is configured for the device to communicate with the BJCA server.
context-admin
vsys-admin
cipher: Specifies a ciphertext key.
simple: Specifies a plaintext key. The key will be saved in ciphertext format.
String: Specifies the key string, a case-sensitive string. The length of a plaintext string is in the range of 1 to 64 characters, and the length of a ciphertext string is in the range of 1 to 117 characters.
When the device acts as an IPsec tunnel responder to exchange private authentication protocol packets with the BJCA authentication server, it uses the preshared key to generate the digital signature in the authentication request. The BJCA server uses the same preshared key to validate the signature in the received authentication request.
The preshared key is assigned by the BJCA authentication server. Make sure the preshared key configured on the device is the same as the preshared key on the BJCA server.
# Configure the device to use plaintext key 1234test to communicate with BJCA server bbb.
[Sysname-bjca-auth-server-bbb] key simple 1234test
pki-domain
Use pki-domain to specify a PKI domain for communication with a JIT authentication server.
Use undo pki-domain to restore the default.
pki-domain domain-name
undo pki-domain
No PKI domain is specified for communication with a JIT authentication server.
context-admin
vsys-admin
domain-name: Specifies a PKI domain by its name, a case-insensitive string of 1 to 31 characters.
When the device acts as the IPsec tunnel initiator to send a token request to the JIT authentication server, it obtains a local digital certificate based on the specified PKI domain. The local digital certificate is used to add a digital signature to some critical data in the request packet. Then, the device sends the packet that includes the digital signature to the server. When the server receives the token request packet, it validates the signature information in the packet.
# Specify PKI domain jit-domain for communication with the JIT authentication server named ccc.
[Sysname-jit-auth-server-ccc] pki-domain jit-domain
# Specify PKI domain bjca-domain for communication with the BJCA authentication server named bbb.
[Sysname-bjca-auth-server-bbb] pki-domain bjca-domain
Use timer response-timeout to set the response timeout time for an AAA private protocol authentication server.
Use undo timer response-timeout to restore the default.
timer response-timeout seconds
The response timeout time is 5 seconds for an AAA private protocol authentication server.
context-admin
vsys-admin
seconds: Sets the response timeout time, in the range of 1 to 300 seconds.
The response timeout time is the interval that the device waits for a response from the JIT or BJCA authentication server before the device determines that the server is unreachable. The device starts the response timeout timer after it sends an AAA private protocol request to the authentication server. If no response is received at timer timeout, the device notifies the access module that the server is unreachable.
Typically, use the default value for this command. If a large number of users come online concurrently and the server has low performance, use this command to increase the response timeout time to avoid user online failures caused by untimely server responding.
# Set the response timeout time to 6 seconds for the JIT authentication server named ccc.
[Sysname-jit-auth-server-ccc] timer response-timeout 6
# Set the response timeout time to 6 seconds for the BJCA authentication server named bbb.
[Sysname-bjca-auth-server-bbb] timer response-timeout 6
url
Use url to specify a URL for a JIT authentication server.
Use undo url to restore the default.
url url-string
undo url
No URL is specified for a JIT authentication server.
context-admin
vsys-admin
url-string: Specifies a URL, a case-sensitive string of 1 to 256 characters. The URL can contain question marks (?). You cannot obtain the help for this argument by entering a question mark (?) at the place of this argument on the CLI.
Use this command to specify the URL that a JIT authentication server uses to provide authentication services for users.
Changing the URL of the JIT authentication server does not affect online users.
# Specify URL https://www.jit.com.cn/cinas for the JIT authentication server named ccc.
[Sysname-jit-auth-server-ccc] url http://www.jit.com.cn/cinas
url { get-random | get-token | token-auth }
Use url { get-random | get-token | token-auth } to configure authentication service URLs for the BJCA authentication server.
Use undo url { get-random | get-token | token-auth } to restore the default.
url { get-random | get-token | token-auth } url-string
No authentication service URL is configured for the BJCA authentication server.
context-admin
vsys-admin
get-random: Specifies the get-random URL.
get-token: Specifies the get-Token URL.
token-auth: Specifies the Token-authentication URL.
url-string: Specifies the URL string, a case-sensitive string of 1 to 255 characters. Question marks (?) are allowed, but you cannot obtain online help for this argument by entering a question mark (?) in the CLI.
To ensure authentication exchange success, make sure the specified URLs are the same URLs on the BJCA authentication server.
When you configure the authentication service URLs, follow these restrictions and guidelines:
· Different service URLs are required on different device roles:
¡ Configure the get-random URL and get-Token URL on the IPsec tunnel initiator.
¡ Configure the Token-authentication URL on the IPsec tunnel responder.
· If you execute this command multiple times to specify URLs of the same service type, the most recent configuration takes effect.
· Changing a service URL for the BJCA authentication server does not affect online users.
# Configure the get-random URL for BJCA server bbb as https://www.bjca.com.cn/cinas.
[Sysname-jit-auth-server-bbb] url get-random http://www.jit.com.cn/cinas
vpn-instance
Use vpn-instance to specify the VPN instance to which a JIT authentication server belongs.
Use undo vpn-instance to restore the default.
undo vpn-instance
No VPN instance is specified for a JIT authentication server.
context-admin
vpn-instance-name: Specifies an MPLS L3VPN instance by its name, a case-sensitive string of 1 to 31 characters.
# Specify VPN instance test for the JIT authentication server named ccc.
[Sysname-jit-auth-server-ccc] vpn-instance test
# Specify VPN instance test for the BJCA authentication server named bbb.
[Sysname-bjca-auth-server-bbb] vpn-instance test
