- 03-Security Command Reference
- 01-Security zone commands
- 02-Security policy commands
- 03-ASPF commands
- 04-Session management commands
- 05-Object group commands
- 06-IP source guard commands
- 07-AAA commands
- 08-User identification commands
- 09-Password control commands
- 10-Portal commands
- 11-MAC authentication commands
- 12-SMS commands
- 13-802.1X commands
- 14-Public key management commands
- 15-PKI commands
- 16-SSH commands
- 17-SSL commands
- 18-Connection limit commands
- 19-Attack detection and prevention commands
- 20-Server connection detection commands
- 21-ARP attack protection commands
- 22-ND attack defense commands
- 23-uRPF commands
- 24-IP-MAC binding commands
- 25-Keychain commands
- 26-MAC learning through a Layer 3 device commands
- 27-APR commands
- 28-IPoE commands
- 29-Crypto engine commands
- 30-Location identification commands
- 31-Terminal identification commands
| 31-Terminal identification commands | 94.58 KB |
display terminal-identification terminal predefined
allowlist action
Use allowlist action to specify an allowlist action.
Use undo allowlist action to restore the default.
allowlist action { drop | permit }
The traffic matching the allowlist is permitted.
Terminal identification view
context-admin
drop: Specifies a description, a case-sensitive string of 1 to 127 characters. If the description contains spaces, use quotation marks to enclose the character string.
This command takes effect only in allowlist mode.
In allowlist mode with the drop action, the system drops traffic of a terminal in the allowlist when the terminal comes online for the first time. To permits the traffic of the terminal, execute the approved command to approve it as a legal terminal.
If the allowlist action is permit, the system permit the traffic of terminals in the allowlist no matter whether the terminal information changes.
# Set the allowlist action to drop.
[Sysname] terminal-identification
[Sysname-terminal-identification] allowlist action drop
allowlist object-group
Use allowlist object-group to specify an address object group for generating the allowlist.
Use undo allowlist object-group to restore the default.
allowlist object-group ipv4 object-group-name
undo allowlist object-group ipv4
No address object group is specified.
context-admin
ipv4 object-group-name: Specifies an IPv4 address object group by its name, a case-insensitive string of 1 to 63 characters.
The specified IPv4 address object group must already exist. For more information about address object groups, see object group configuration in Security Configuration Guide.
# Specify address object group aa for generating the allowlist.
[Sysname-terminal-identification] allowlist object-group ipv4 aa
approved
Use approved to approve terminals as legal terminals.
approved { all | ipv4 ipv4-address }
Terminals are not approved as legal terminals.
context-admin
all: Specifies all terminals.
ipv4 ipv4-address: Specifies a terminal by its IPv4 address.
If you are sure identified terminals are accurate and trusted, you can execute this command to approve them as legal terminals.
In allowlist mode with the drop action, the system drops traffic of a terminal in the allowlist when the terminal comes online for the first time. To permits the traffic of the terminal, you can approve it as a legal terminal.
# Approve the terminal with IPv4 address 1.1.1.1 as a legal terminal.
[Sysname-terminal-identification] approved ipv4 1.1.1.1
description
Use description to configure a description for a terminal group.
A terminal group is described as "User-defined terminal group".
Terminal group view
context-admin
text: Specifies a description, a case-sensitive string of 1 to 127 characters. If the description contains spaces, use quotation marks to enclose the character string.
Use this command to configure descriptions for terminal groups for easy maintenance.
# Configure the description as user defined test terminal group for terminal group test.
[Sysname-terminal-identification] terminal-group test
[Sysname-terminal-identification-terminal-group-test] description "User defined test terminal group"
terminal-group
Use display terminal-identification terminal predefined to display information about predefined terminals.
context-admin
context-operator
Use this command to view the information about terminals predefined in the signature library.
# Display information about predefined terminals.
[Sysname] display terminal-identification terminal predefined
Pre-defined count: 2
Terminal name Type Terminal ID
DahuaIPC Pre-defined 0x0000681e
DahuaNVR Pre-defined 0x00006829
display terminal-identification terminal-group
Use display terminal-identification terminal-group to display information about terminal groups.
context-admin
context-operator
# Display information about all terminal groups.
[Sysname] display terminal-identification terminal-group
terminal-group
include terminal
Use include terminal to add a terminal to a terminal group.
Use undo include terminal to remove a terminal from a terminal group.
include terminal terminal-name
undo include terminal terminal-name
No terminals exist in a terminal group.
Terminal group view
context-admin
terminal-name: Specifies a terminal by its name, a case-insensitive string of 1 to 63 characters. The names invalid and other are not allowed.
You can repeat this command to add multiple terminals to a terminal group. The number of terminals in a terminal group is not limited.
# Add dahua and haikang to terminal group test.
[Sysname-terminal-identification-terminal-group-test] include terminal dahua
[Sysname-terminal-identification-terminal-group-test] include terminal haikang
logging enable
Use logging enable to enable terminal identification logging.
Use undo logging enable to disable terminal identification logging.
logging enable
undo logging enable
Terminal identification logging is disabled.
context-admin
This feature allows the device to fast output logs to log hosts upon detecting the changes of terminal information, such as the vendor and model changes. For more information about fast log output, see configuring fast log output in Network Management and Monitoring Configuration Guide.
# Enable terminal identification logging.
[Sysname] cc-defense policy news
[Sysname-cc-defense-policy-news] rule name test
[Sysname-cc-defense-policy-news-rule-test] logging enable
manage object-group
Use manage object-group to configure the manager address object group.
Use undo manage object-group to delete the manager address object group.
manage object-group { ipv4 | ipv6 } object-group-name
undo manage object-group { ipv4 | ipv6 } object-group-name
No manager address object group is configured.
context-admin
{ ipv4 | ipv6 } object-group-name: Specifies an IPv4 or IPv6 address object group by its name, a case-insensitive string of 1 to 63 characters. The object group must already exist, and its name must be globally unique.
The manager address object group is a set of terminal manager IP addresses. For packets transmitted between managers and terminals, this object group helps you identify whether the source or destination IP is the terminal IP addresses.
· If the source IP address matches the manager address object group, the destination IP address is the terminal IP address.
· If the destination IP address matches the manager address object group, the source IP address is the terminal IP address.
For accurate terminal identification, configure the manager address object group, or the terminal address object group, or both. If you configure both, the manager address object group takes precedence.
# Specify IPv4 address object group obgroup1 as the manager address object group.
[Sysname-terminal-identification] manage object-group ipv4 obgroup1
reidentify
Use reidentify to reidentify terminals.
reidentify { all | ipv4 ipv4-address }
context-admin
If you consider that terminal information is inaccurate, you can execute this command to clear all identified terminal information and reidentifies terminals.
# Reidentify the terminal with IPv4 address 1.1.1.1.
[Sysname-terminal-identification] reidentify ipv4 1.1.1.1
terminal object-group
Use terminal object-group to configure the terminal address object group.
Use undo terminal object-group to delete the terminal address object group.
terminal object-group { ipv4 | ipv6 } object-group-name
undo terminal object-group { ipv4 | ipv6 } object-group-name
No terminal address object group is configured.
context-admin
The terminal address object group is a set of terminal IP addresses. If the packet source or destination IP address matches the object group, the source or destination IP address is the terminal address.
# Specify IPv4 address object group obgroup1 as the terminal address object group.
[Sysname-terminal-identification] terminal object-group ipv4 obgroup1
terminal-group
Use terminal-group to create a terminal group and enter its view, or enter the view of an existing terminal group.
Use undo terminal-group to delete a terminal group.
terminal-group group-name
undo terminal-group group-name
No terminal groups exist.
context-admin
group-name: Specifies a terminal by its name, a case-insensitive string of 1 to 63 characters. The names invalid and other are not allowed.
# Create a terminal group named test and enter its view.
include terminal
Use terminal-identification to enter terminal identification view.
Use undo terminal-identification to delete the configuration in terminal identification view.
context-admin
In terminal identification view, you can create a terminal group, add terminals to the terminal group, and enable terminal identification logging.
# Enter terminal identification view.
work-mode
Use work-mode to specify an operating mode.
Use undo work-mode to restore the default.
work-mode { allowlist | warning }
undo work-mode
Terminal identification works in alarm mode.
context-admin
allowlist: Specifies the allowlist mode.
warning: Specifies the alarm mode.
Terminal identification supports the following operating modes:
· Alarm—In this mode, the system permits traffic of all terminals. When the system identifies a terminal for the first time or detects a terminal information change, it sends a log message to the log host by using the fast log output feature. This mode is applicable to scenarios that do not have strict security requirements.
· Allowlist—In this mode, the system permits traffic of only terminals in the allowlist. When the system detects a terminal information change, it sends a log message to the log host by using the fast log output feature. This mode is applicable to scenarios that have strict security requirements.
# Specify the operating mode as alarm.
[Sysname-terminal-identification] work-mode allowlist
