- 14-Layer 3—IP Services Configuration Guide
- 01-IP addressing configuration
- 02-IP forwarding basics configuration
- 03-Fast forwarding configuration
- 04-ARP configuration
- 05-IPv6 basics configuration
- 06-IPv6 fast forwarding configuration
- 07-DHCP configuration
- 08-DHCPv6 configuration
- 09-DNS configuration
- 10-IP performance optimization configuration
- 11-Multi-CPU packet distribution configuration
- 12-Adjacency table configuration
- 13-Web caching configuration
| 13-Web caching configuration | 175.37 KB |
Restrictions: Hardware compatibility with Web caching
License requirement for Web caching
Restrictions and guidelines: Web caching configuration
Configuring webpage file filtering
Configuring Web client and server filtering
Specifying listening port numbers
Configuring Web cache file storage parameters
Configuring extended Web caching features
Configuring traffic direction channels for Web cache dual gateways
Enabling Web caching for files in QueryString of a URL
Configuring Web caching to ignore the specified HTTP/HTTPS response headers
Configuring Web caching backup
Display and maintenance commands for Web caching
About Web caching
The Web caching feature saves specific webpage content requested by HTTP or HTTPS users from specific Web servers to files in the Web cache directory. If users access the same content before the content is aged out, the device retrieves the content from the files and sends the content to the users. Web caching can reduce the traffic between the device and the Web servers, lower Web content transmission costs, relieve pressure on Web servers, and improve user Web access speed.
Basic concepts
· Web cache files and Web cache directory—The Web caching feature saves its operation data and the Web content to be cached to files in the Web cache directory. After the effective maximum total size for Web cache files is reached, the device deletes the oldest Web cache file to save the new Web cache file.
· TCP listening port:
¡ Listening port for Web caching—Provides the Web cache service on the device. Only packets sent to this port will be processed by Web caching.
¡ Listening port for the Web server—Provides the Web service on the Web server. Only packets sent to this port will be processed by Web.
· Web cache file aging time—The Web cache file aging time is fixed at 30 days. When the device reboots or receives a request for the cached content in a file, it restarts the aging timer. If no users request the cached content before the aging timer expires, the device deletes the file.
Web caching mechanism
Figure 1 shows the Web caching mechanism.
Figure 1 Web caching mechanism
1. The host sends an HTTP or HTTPS GET request to the device.
2. The device identifies whether the destination port number in the request is the same as the listening port number used by the Web server. If yes, the device replaces the destination port number with the listening port number specified for Web caching to trigger the Web caching process.
3. The Web caching process obtains the URL of the request and looks up its cache for the requested content.
¡ If the requested content is found in the cache, the device retrieves the content and sends the content to the host. The HTTP or HTTPS GET operation is completed.
¡ If the requested content is not found, the device re-constructs the request and sends the request to the Web server.
4. The Web server sends the requested content to the device.
5. The device identifies whether the Web caching feature is configured to cache the content.
¡ If yes, the device uses the Web caching feature to cache the content, re-constructs a response, and sends the response to the host.
¡ If not, the device re-constructs a response and sends the response to the host.
Before sending the response, the device will check whether the source port number is the same as the listening port number used by Web caching. If not, the device will replace the source port number in the response with the listening port number of the Web server.
Web caching backup
The Web cache backup feature enhances the high availability of the Web caching service. You can specify a primary slot and a backup slot for Web caching. When the primary slot fails, the backup slot will take over to provide the Web caching service to ensure service continuity. When the primary slot recovers, the Web caching service switches back to the primary slot.
You can also specify a primary Web caching directory and a backup Web caching directory, which are used by the primary and backup slots to provide the Web caching service, respectively.
Series |
Models |
Web caching compatibility |
F5000 series |
F5000-CN160 |
No |
F5000-AI160, F5000-CN-G85, F5000-CN-G65, F5000-CN-G55, F5000-AI-40, F5000-AI-20, F5000-AI-15 |
Yes |
F1000 series |
F1000-AI-25 |
Yes |
The Web caching feature requires a license. If you configure the feature without a license, the settings will be lost after a device reboot. For information about feature licensing, see Fundamentals Configuration Guide.
Before configuring or modifying Web caching parameters, you must disable Web caching. After configuring or modifying Web caching parameters, enable Web caching again.
Web caching tasks at a glance
To configure Web caching, perform the following tasks:
1. Configuring webpage file filtering
2. (Optional.) Configuring Web client and server filtering
3. Specifying listening port numbers
4. Configuring Web cache file storage parameters
5. (Optional.) Configuring extended Web caching features
¡ Configuring traffic direction channels for Web cache dual gateways
¡ Enabling Web caching for files in QueryString of a URL
¡ Configuring Web caching to ignore the specified HTTP/HTTPS response headers
7. (Optional.) Configuring Web caching backup
Perform this task to filter webpage files to be cached. Web caching supports filtering webpage files by file name, file type, and file extension.
You must specify a type of files to be cached so that Web cache will cache Web resources.
If you configure filtering criteria file name, file type, and file extension, a webpage file that matches any of the filtering criteria will be cached. During filtering, the criterion file name is firstly used.
Before configuring or modifying webpage file filtering settings, you must disable Web caching. After configuring or modifying webpage file filtering settings, enable Web caching again.
1. Enter system view.
2. Create and enter Web cache view.
web-cache slot slot-number
3. Specify the types of webpage files to be cached.
cached-data { apk | bmp | doc | docx | gif | gzip | ipa | jar | jpg | jpeg | mp4 | pdf | png | ppt | pptx | rar | swf | tar | txt | xls | xlsx | zip } *
By default, no webpage file types are specified. The Web caching feature does not cache any types of files on webpages.
4. (Optional.) Specify webpage files to be cached.
cached-file file-name
By default, no webpage files to be cached are specified.
5. (Optional.) Specify a file extension of webpage files to be cached.
cached-extension-name extension-name
By default, no file extensions are specified.
You can execute this command multiple times to specify multiple file extensions. A maximum of 64 file extensions are supported.
About this feature
By default, Web caching caches webpage content from all Web servers. You can perform this task to configure Web caching to cache only Web content requested by Web clients or sent from Web servers specified by an object group.
Make sure the object group used is an existing object group. Otherwise, Web caching will not cache any Web content.
Before you configure Web client and server filtering, you must complete the following tasks:
· Configure an IP address object group. For more information about the IP address object group feature, see object group configuration in Security Configuration Guide.
· Disable HTTP-based Web caching. After you complete the configuration, enable Web caching again.
3. Specify an IP address object group used to filter Web content to be cached.
object-group [ source ] { ip | ipv6 } object-group-name
By default, no IP address object group is specified for the Web caching feature to filter Web content. The Web caching feature caches Web content from all Web servers.
By default:
· For HTTP, Web caching listens for HTTP packets on port number 4180 and caches Web resources from Web servers that use 80 as the HTTP listening port number.
· For HTTPS, Web caching listens for HTTPS packets on port number 2043 and caches Web resources from Web servers that use 443 as the HTTPS listening port number.
Perform this task in either of the following situations:
· A port number used by Web caching to listen for HTTP or HTTPS packets is used by another service on the device, which causes Web caching fails to be enabled.
· A Web server does not listen for HTTP packets on port number 80 or HTTPS packets on port number 443.
If Web caching caches webpage files from multiple Web servers that use different listening port numbers, you must configure multiple listening port number pairs for the Web servers. A listening port number for Web caching and a listening port number for a Web server is a listening port number pair.
For each protocol (HTTP or HTTPS), you can specify a maximum of eight listening port number pairs.
If you execute the https listen-port or listen-port command multiple times with the same Web caching listening port number or Web server caching listening port number, the most recent configuration takes effect.
Make sure the specified TCP port numbers are not being used or will be used by any other services on the device. To display TCP port numbers in use, execute the display tcp verbose command.
Before you specify listening port numbers, you must complete the following tasks:
· Disable Web caching. After you complete the configuration, enable Web caching again.
2. Enter Web cache view.
3. Specify listening port numbers.
¡ Specify HTTP listening port numbers.
listen-port port-number [ server-port server-port-number ]
¡ Specify HTTPS listening port numbers.
https listen-port port-number [ server-port server-port-number ]
Perform this task to specify the primary Web cache directory or limit the total size of Web cache files.
The Web cache directory for a Web cache view must reside on the same slot as the Web view.
Before specifying a Web cache directory, make sure all files in the upper-level directory are using a different name than the Web cache directory or have a file extension.
Make sure the storage medium where the Web cache directory resides has sufficient storage space. The directory typically needs a storage space of over 1 GB.
Before you configuring Web cache file storage parameters, disable Web caching. After you complete the configuration, enable Web caching again.
3. Set the primary Web cache directory.
file-directory directory
By default, the primary Web cache directory is not set.
4. (Optional.) Set the maximum total size of Web cache files.
cache-limit size
By default, the maximum total size of Web cache files is 4 GB.
The maximum total size for Web cache files must be smaller than the maximum storage space size in the working directory.
Perform this task in the Web Cache dual gateways scenario. As shown in Figure 2, gateways Device A and Device B provide the Web Cache service for the user through the switch, and equal cost paths exist on both the uplink and downlink for Web cache. If the uplink and downlink traffic forwarding paths are not the same, the uplink traffic and downlink traffic will be forwarded to different gateways for processing, for example, the user uplink traffic passes Device A and the downlink traffic for the user passes Device B. Device B does not have a record for the user and therefore cannot forward the downlink traffic to the user and the user cannot access the requested Web resources as a result.
NOTE: In the Web cache dual gateway scenario, the uplink traffic refers to the HTTP/HTTPS requests sent from user hosts to Web servers, and the downlink traffic refers to the HTTP/HTTP responses sent from Web servers to user hosts. The traffic direction channel between the gateway devices is a direct physical link or a GRE tunnel, which ensures the IP connectivity between the gateways. |
Figure 2 User failure to access Web resources
As shown in Figure 3, on Device B, you can configure a traffic direction channel with the peer gateway (Device A). If Device B receives Web cache downlink traffic for a user that it cannot find, it forwards the downlink traffic to the peer gateway through the specified channel interface, so the peer gateway can provide Web resources for the user correctly.
Figure 3 Traffic direction channel between gateways
When you execute the dual-gateway-channel command, make sure the specified IPv4 address of the peer gateway is reachable, and in the routing table, the outgoing interface for this IPv4 address is the channel interface specified in this command.
You can use the dual-gateway-channel command to configure multiple traffic direction channels in multiple VPN instances. If you execute this command for the same VPN instance or for the public network multiple times, the most recent configuration takes effect.
Before you configure a channel for traffic direction with the peer gateway, complete the following tasks:
· Establish the channel between the gateways to ensure that the downlink traffic can be sent to the peer gateway through the channel.
· Disable the Web cache feature.
After you configure the channel, enable the Web cache feature again.
2. Create a Web cache and enter its view.
3. Configure a channel for traffic direction with the peer gateway.
dual-gateway-channel [ vpn-instance vpn-instance-name ] interface interface-type interface-number peer ipv4-address
By default, no channels are configured for traffic direction with the peer gateway.
By default, Web caching does not cache files in QueryString of a URL. After you configure this feature, Web caching can cache the files and it determines whether to cache the files according to other file filtering rules.
3. Enable Web caching to cache files in QueryString of a URL.
querystring-file-cache enable
The HTTP/HTTPS response header type affects Web caching as follows:
· If the HTTP/HTTPS response has a Cache-Control header, whether Web caching caches the requested Web resources depends on the instructions in the header.
· If the HTTP/HTTPS response has a Set-Cookie header, Web caching does not cache the requested Web resources.
· If the HTTP/HTTPS response has a Vary header, whether Web caching caches the requested Web resources depends on the value for the Vary field.
To make sure Web caching caches the requested Web resources, configure Web caching to ignore the specified HTTP/HTTPS response headers.
3. Configure Web caching to ignore the specified HTTP/HTTPS response headers.
cache-ignore { cache-control | set-cookie | vary } *
By default, whether Web caching caches Web resources is affected by the HTTP/HTTPS response header type.
Before enabling Web caching, you must configure the types of the webpage files to be cached and the primary Web cache directory.
Web caching will restart in one of the following situations:
· When HTTP-based Web caching is configured, enable HTTPS-based Web caching.
· When HTTPS-based Web caching is configured, enable HTTP-based Web caching.
· When both HTTP-based and HTTPS-based Web caching are configured, disable HTTP-based or HTTPS-based Web caching.
When the device enabled with HTTPS-based Web caching attempts to cache Web resources accessed by a user through HTTPS, the user will be prompted with a certificate warning. Because the certificate of the device is a private CA-issued digital certificate, it cannot pass the verification of the user host. To resolve this issue, the user can export the device's CA root certificate file (webcache_cacert.crt) from the Web caching working directory and import it to the trusted certificate authorities store. Then, the device' certificate can pass the verification of the user host so the user will not be prompted with the certificate warning.
3. Enable Web caching. Choose the options to configure as needed:
¡ Enable HTTP-based Web caching.
http enable
By default, HTTP-based Web caching is disabled.
¡ Enable HTTPS-based Web caching.
https enable
By default, HTTPS-based Web caching is disabled.
Make sure the storage medium where the Web cache directory resides has sufficient storage space. The Web caching feature saves its operation data and the Web content to be cached to files in the directory. The directory typically needs a storage space of over 1 GB.
The backup Web cache directory for a Web cache view must reside on the backup slot.
3. Specify a backup Web caching slot.
backup slot slot-number
By default, the backup Web caching slot is not set.
4. Set the backup Web cache directory.
By default, the backup Web cache directory is not set.
After the backup Web cache directory is created, the device will not synchronize cache files under the primary directory to the backup directory.
Execute the display command in any view.
Task |
Command |
Display Web caching information. |
display web-cache [ history [ last { day | 30-days | 365-days | hour | minute | week } | verbose ] ] |
Troubleshooting Web caching
Web caching enabling failure
Symptom
Web caching failed to be enabled.
Analysis
The TCP port number specified for Web caching must belong to Web caching exclusively. If any other services on the device are using the same TCP port number, Web caching cannot be enabled.
Solution
To resolve the problem:
1. Execute the display tcp verbose command to display TCP port numbers being used.
2. Specify an unused TCP port number as the Web caching listening port number.
Web caching backup failure
Symptom
The device does not use the backup Web caching slot for Web caching after the primary Web caching slot reboots.
Analysis
If the storage medium of the backup Web caching slot is inaccessible or is not correctly configured, the Web caching service cannot be enabled on the backup Web caching slot.
Solution
1. Execute the dir command to display information about the backup Web caching slot and then make sure the storage medium of the directory is accessible.
For more information about the dir command, see file system management commands in Fundamentals Command Reference.
2. If the issue persists, contact H3C Support.
