- 14-Layer 3—IP Services Configuration Guide
- 01-IP addressing configuration
- 02-IP forwarding basics configuration
- 03-Fast forwarding configuration
- 04-ARP configuration
- 05-IPv6 basics configuration
- 06-IPv6 fast forwarding configuration
- 07-DHCP configuration
- 08-DHCPv6 configuration
- 09-DNS configuration
- 10-IP performance optimization configuration
- 11-Multi-CPU packet distribution configuration
- 12-Adjacency table configuration
- 13-Web caching configuration
| 03-Fast forwarding configuration | 99.44 KB |
Restrictions and guidelines: Fast forwarding configuration
Configuring the aging time for fast forwarding entries
Configuring fast forwarding load sharing
Configuring hardware fast forwarding
Enabling DSCP-based fast forwarding for GRE and VXLAN packets
Enabling the fast forwarding chip to encapsulate the incremental checksum in outgoing packets
Enabling the fast forwarding chip to do packet integrity check
Specifying the action on altered packets
Enabling single-chip hardware forwarding for upstream packets
Display and maintenance commands for fast forwarding
About fast forwarding
Fast forwarding reduces route lookup time and improves packet forwarding efficiency by using a high-speed cache and data-flow-based technology. It identifies a data flow by using the following fields: source IP address, source port number, destination IP address, destination port number, and protocol number. After a flow's first packet is forwarded through the routing table, fast forwarding creates an entry and uses the entry to forward subsequent packets of the flow.
vSystem support for features
Non-default vSystems do not support the following features:
· Hardware fast forwarding.
· Enabling/disabling fast forwarding.
For information about the support of non-default vSystems for the commands, see fast forwarding command reference. For information about vSystem, see Virtual Technologies Configuration Guide.
Fast forwarding can process fragmented IP packets, but it does not fragment IP packets.
Fast forwarding can be implemented by software or hardware. Unless otherwise noted, fast forwarding in this chapter refers to software fast forwarding.
The fast forwarding table uses an aging timer for each forwarding entry. If an entry is not updated before the timer expires, the device deletes the entry. If an entry has a hit within the aging time, the aging timer restarts.
1. Enter system view.
2. Configure the aging time for fast forwarding entries.
ip fast-forwarding aging-time aging-time
By default, the aging time is 30 seconds.
Fast forwarding load sharing enables the device to identify a data flow by using the packet information.
If fast forwarding load sharing is disabled, the device identifies a data flow by the packet information and the input interface.
2. Configure fast forwarding load sharing. Choose one option as needed:
¡ Enable fast forwarding load sharing.
ip fast-forwarding load-sharing
¡ Disable fast forwarding load sharing.
undo ip fast-forwarding load-sharing
By default, fast forwarding load sharing is enabled.
Hardware fast forwarding stores session information during fast forwarding to speed up subsequent traffic forwarding by comparing the traffic with session information.
Disable hardware fast forward when you troubleshoot problems on forwarding chips.
The following compatibility matrix shows the support of hardware platforms for this command:
Series |
Models |
Command compatibility |
F5000 series |
F5000-AI160, F5000-CN160 |
Yes |
F5000-CN-G85, F5000-CN-G65, F5000-CN-G55, F5000-AI-40, F5000-AI-20, F5000-AI-15 |
No |
F1000 series |
F1000-AI-25 |
No |
2. Configure hardware fast forwarding.
¡ Enable hardware fast forwarding.
hardware fast-forwarding enable [ slot slot-number ]
hardware fast-forwarding enable [ chassis chassis-number slot slot-number ]
¡ Disable hardware fast forwarding.
undo hardware fast-forwarding enable [ slot slot-number ]
undo hardware fast-forwarding enable [ chassis chassis-number slot slot-number ]
By default, hardware fast forwarding is enabled.
This feature uses the DSCP value in the outer header instead of the source port number among the identification criteria to identify GRE and VXLAN traffic flows.
2. Enable DSCP-based fast forwarding for GRE and VXLAN packets.
ip fast-forwarding dscp
By default, DSCP-based fast forwarding for GRE and VXLAN packet is disabled.
3. (Optional.) Specify the destination UDP port number for identifying VXLAN packets
ip fast-forwarding vxlan-port port-number
By default, the destination UDP port number is 4789.
2. Enable the fast forwarding chip to encapsulate the incremental checksum in outgoing packets.
hardware fast-forwarding checksum encap incremental [ slot slot-number cpu cpu-number ]
By default, the fast forwarding chip encapsulates the incremental checksum in outgoing packets.
Series |
Models |
F5000 series |
Yes |
No |
F1000 series |
F1000-AI-25 |
No |
2. Enable the fast forwarding chip to check the integrity of outgoing packets.
hardware fast-forwarding checksum inspect [ l3 | l4 [ tcp | udp ] ] enable [ slot slot-number cpu cpu-number ]
By default, the fast forwarding chip checks the integrity of outgoing packets to prevent packet alteration.
Series |
Models |
F5000 series |
Yes |
No |
F1000 series |
F1000-AI-25 |
No |
2. Specify the action to take on altered packets.
hardware fast-forwarding checksum inspect action { drop-err | log } [ slot slot-number cpu cpu-number ]
By default, the device forwards the altered packet and generates a log message.
Series |
Models |
F5000 series |
Yes |
No |
F1000 series |
F1000-AI-25 |
No |
This feature enables a dual-chip module to forward upstream packets by using only one of the chips. It does not apply to downstream packets. The module uses both chips to forward downstream packets.
This feature applies only to modules that have more than one hardware forwarding chip.
After you change the hardware forwarding mode for upstream packets, you must restart the module for the change to take effect.
To change the hardware forwarding mode for upstream packets in a security engine group with multiple security engines (multiple modules), perform the following tasks:
1. Execute the hardware fast-forwarding standalone or undo hardware fast-forwarding standalone command on all modules one by one to change their hardware forwarding mode for upstream packets.
2. Restart all modules.
Series |
Models |
F5000 series |
Yes |
No |
F1000 series |
F1000-AI-25 |
No |
2. Enable single-chip hardware forwarding for upstream packets.
hardware fast-forwarding standalone [ slot slot-number ]
By default, dual-chip hardware forwarding is enabled for upstream packets.
Task |
Command |
Display the aging time of fast forwarding entries. |
display ip fast-forwarding aging-time |
Display fast forwarding entries. |
display ip fast-forwarding cache [ ip-address ] [ slot slot-number ] |
Display fast forwarding entries about fragmented packets. |
display ip fast-forwarding fragcache [ ip-address ] [ slot slot-number ] |
Clear the fast forwarding table. |
reset ip fast-forwarding cache [ slot slot-number ] |
