- 15-Network Management and Monitoring
- 01-DISMAN-EVENT-MIB
- 02-DISMAN-PING-MIB
- 03-DISMAN-TRACEROUTE-MIB
- 04-HH3C-NTP-MIB
- 05-HH3C-HTTP-MIB
- 06-HH3C-MIRRORGROUP-MIB
- 07-HH3C-NETCONF-MIB
- 08-HH3C-NETSTREAM4-MIB
- 09-HH3C-NETSTREAM6-MIB
- 10-HH3C-NQA-MIB
- 11-HH3C-RMON-EXT2-MIB
- 12-HH3C-SNMP-EXT-MIB
- 13-RMON-MIB
- 14-RMON2-MIB
- 15-SFLOW-MIB
- 16-SNMP-FRAMEWORK-MIB
- 17-SNMP-MPD-MIB
- 18-SNMP-NOTIFICATION-MIB
- 19-SNMP-TARGET-MIB
- 20-SNMP-USER-BASED-SM-MIB
- 21-SNMP-VIEW-BASED-ACM-MIB
- 22-SNMPv2-MIB
22-SNMPv2-MIB | 148.42 KB |
SNMPv2-MIB
About this MIB
Use this MIB to configure SNMPv2 basic settings and obtain SNMP packet statistics.
MIB file name
rfc3418-snmpv2.mib
Root object
iso(1).org(3).dod(6).internet(1).snmpV2(6).snmpModules(3).snmpMIB(1)
Scalar objects
snmpTrapOID
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
snmpTrapOID (1.3.6.1.6.3.1.1.4.1) |
accessible-for-notify |
OBJECT IDENTIFIER |
Standard MIB values. |
OID of the notification currently being sent. |
As per the MIB. |
snmpTrapEnterprise
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
snmpTrapEnterprise (1.3.6.1.6.3.1.1.4.3) |
OBJECT IDENTIFIER |
OID of the enterprise associated with the trap currently being sent. |
As per the MIB. |
snmpSetSerialNo
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
snmpSetSerialNo (1.3.6.1.6.3.1.1.6.1) |
read-write |
TestAndIncr |
An advisory lock used to allow several cooperating command generator applications to coordinate their use of the SNMP set operation. |
As per the MIB. |
snmpInPkts
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
snmpInPkts (1.3.6.1.2.1.11.1) |
read-only |
Counter32 |
Total number of SNMP messages received on the SNMP agent. |
As per the MIB. |
snmpOutPkts
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
snmpOutPkts (1.3.6.1.2.1.11.2) |
read-only |
Counter32 |
Total number of SNMP messages sent by the SNMP agent. |
As per the MIB. |
snmpInBadVersions
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
snmpInBadVersions (1.3.6.1.2.1.11.3) |
read-only |
Counter32 |
Total number of received SNMP messages not supported by the SNMP version. |
As per the MIB. |
snmpInBadCommunityNames
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
snmpInBadCommunityNames (1.3.6.1.2.1.11.4) |
read-only |
Counter32 |
Total number of received SNMP messages which used an SNMP community name unknown to the SNMP entity. |
As per the MIB. |
snmpInBadCommunityUses
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
snmpInBadCommunityUses (1.3.6.1.2.1.11.5) |
read-only |
Counter32 |
Total number of messages carrying an operation that the community has no right to perform. |
As per the MIB. |
snmpInASNParseErrs
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
snmpInASNParseErrs (1.3.6.1.2.1.11.6) |
read-only |
Counter32 |
Total number of received SNMP messages that had ASN.1 or BER errors during decoding. |
As per the MIB. |
snmpInTooBigs
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
snmpInTooBigs (1.3.6.1.2.1.11.8) |
read-only |
Counter32 |
Total number of received SNMP PDUs with a TooBig error. |
When read, this object always returns 0. |
snmpInNoSuchNames
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
snmpInNoSuchNames (1.3.6.1.2.1.11.9) |
read-only |
Counter32 |
Total number of received SNMP PDUs with a NoSuchName error. |
snmpInBadValues
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
snmpInBadValues (1.3.6.1.2.1.11.10) |
read-only |
Counter32 |
Total number of received SNMP PDUs with a BadValue error. |
snmpInReadOnlys
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
snmpInReadOnlys (1.3.6.1.2.1.11.11) |
read-only |
Counter32 |
Total number of received SNMP PDUs with a readOnly error. |
snmpInGenErrs
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
snmpInGenErrs (1.3.6.1.2.1.11.12) |
read-only |
Counter32 |
Total number of received SNMP PDUs with a genErr error. |
snmpInTotalReqVars
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
snmpInTotalReqVars (1.3.6.1.2.1.11.13) |
read-only |
Counter32 |
Total number of MIB objects that have been successfully retrieved. |
As per the MIB. |
snmpInTotalSetVars
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
snmpInTotalSetVars (1.3.6.1.2.1.11.14) |
read-only |
Counter32 |
Total number of MIB objects that have been successfully modified. |
As per the MIB. |
snmpInGetRequests
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
snmpInGetRequests (1.3.6.1.2.1.11.15) |
read-only |
Counter32 |
Total number of GetRequest requests that have been received and processed. |
As per the MIB. |
snmpInGetNexts
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
snmpInGetNexts (1.3.6.1.2.1.11.16) |
read-only |
Counter32 |
Total number of getNext requests that have been received and processed. |
As per the MIB. |
snmpInSetRequests
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
snmpInSetRequests (1.3.6.1.2.1.11.17) |
read-only |
Counter32 |
Total number of set requests that have been received and processed. |
As per the MIB. |
snmpOutTooBigs
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
snmpOutTooBigs (1.3.6.1.2.1.11.20) |
read-only |
Counter32 |
Total number of sent SNMP PDUs with a TooBig error. |
As per the MIB. |
snmpOutNoSuchNames
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
snmpOutNoSuchNames (1.3.6.1.2.1.11.21) |
read-only |
Counter32 |
Total number of sent SNMP PDUs with a NoSuchName error. |
As per the MIB. |
snmpOutBadValues
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
snmpOutBadValues (1.3.6.1.2.1.11.22) |
read-only |
Counter32 |
Total number of sent SNMP PDUs with a BadValues error. |
As per the MIB. |
snmpOutGenErrs
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
snmpOutGenErrs (1.3.6.1.2.1.11.24) |
read-only |
Counter32 |
Total number of sent SNMP PDUs with a genErr error. |
As per the MIB. |
snmpOutGetRequests
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
snmpOutGetRequests (1.3.6.1.2.1.11.25) |
read-only |
Counter32 |
Total number of sent SNMP Get-Request PDUs. |
As per the MIB. |
snmpOutGetNexts
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
snmpOutGetNexts (1.3.6.1.2.1.11.26) |
read-only |
Counter32 |
Total number of sent SNMP Get-Next PDUs. |
As per the MIB. |
snmpOutSetRequests
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
snmpOutSetRequests (1.3.6.1.2.1.11.27) |
read-only |
Counter32 |
Total number of sent SNMP Set-Request PDUs. |
As per the MIB. |
snmpOutGetResponses
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
snmpOutGetResponses (1.3.6.1.2.1.11.28) |
read-only |
Counter32 |
Total number of sent SNMP Get-Response PDUs. |
As per the MIB. |
snmpOutTraps
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
snmpOutTraps (1.3.6.1.2.1.11.29) |
read-only |
Counter32 |
Total number of notifications sent by the SNMP entity. |
As per the MIB. |
snmpEnableAuthenTraps
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
snmpEnableAuthenTraps (1.3.6.1.2.1.11.30) |
read-write |
INTEGER |
enabled(1), |
Whether authenticationFailure traps are enabled. |
The default value is enabled(1). |
snmpSilentDrops
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
snmpSilentDrops (1.3.6.1.2.1.11.31) |
read-only |
Counter32 |
Number of packets delivered to but dropped by the SNMP entity because the response packet size exceeded the limit. |
As per the MIB. |
snmpProxyDrops
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
snmpProxyDrops (1.3.6.1.2.1.11.32) |
read-only |
Counter32 |
Total number of packets delivered to but dropped by the SNMP entity because transmission of the message to a proxy target failed. |
Notifications
This section contains SNMPv2-MIB notifications.
coldStart
Basic information
OID |
Event |
Type |
Severity |
Recovery notification |
Default status |
1.3.6.1.6.3.1.1.5.1 |
SNMP agent cold start |
Informational |
Warning |
N/A |
ON |
Notification triggers
This notification is generated when the SNMP agent is initialized for the first time after the device is started.
System impact
No negative impact on the system.
Status control
ON
CLI: snmp-agent trap enable standard coldstart
OFF
CLI: undo snmp-agent trap enable standard coldstart
Objects
N/A
No action is required.
warmStart
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.6.3.1.1.5.2 |
SNMP agent warm start |
Informational |
Warning |
N/A |
ON |
This notification is generated when the SNMP agent is initialized for the non-first time after the device is started.
System impact
Status control
ON
CLI: snmp-agent trap enable standard warmstart
OFF
CLI: undo snmp-agent trap enable standard warmstart
Objects
N/A
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.6.3.1.1.5.5 |
SNMP authentication failure |
Informational |
Warning |
N/A |
ON |
This notification is generated when an NMS uses a wrong community name or SNMPv3 username to connect to the device and fails to be authenticated.
System impact
If SNMP silence is enabled, illegitimate NMSs might fail to access the device.
Status control
ON
CLI: snmp-agent trap enable standard authentication
OFF
CLI: undo snmp-agent trap enable standard authentication
Objects
N/A
Recommended action
1. Verify that the agent and NMS are configured with the same SNMP settings.
¡ To view the SNMP settings, execute the display current-configuration | include snmp-agent command in user view.
¡ If the community name is configured incorrectly, execute the snmp-agent community command in system view to change the community name.
¡ If the SNMPv3 user settings are configured incorrectly, execute the snmp-agent user command in system view to change the SNMPv3 user settings.
2. Identify whether a network attack has occurred. You can configure ACLs to allow access only from illegitimate NMSs.
3. If the issue persists, collect alarm information and configuration data and then contact H3C Support for help.
