15-Network Management and Monitoring
HomeSupportSwitchesS9820 SeriesReference GuidesMIB CompanionH3C S9820-8C MIB Companion-Release 6715-6W10015-Network Management and Monitoring
08-HH3C-NETSTREAM4-MIB
08-HH3C-NETSTREAM4-MIB 67.22 KB
HH3C-NETSTREAM4-MIB
About this MIB
Use this MIB to export alarm information of the NETSTREAM4 module.
MIB file name
hh3c-netstream4.mib
Root object
iso(1).org(3).dod(6).internet(1).private(4).enterprises(1).hh3c(25506).hh3cCommon(2).hh3cNetstream4(256)
Scalar objects
hh3cNetstream4TrapEntrySpec
Object (OID)
Access
Value range
Implementation
hh3cNetstream4TrapEntrySpec (1.3.6.1.4.1.25506.2.256.1.1.1)
accessible-for-notify
Unsigned32
Standard MIB values.
Flow table specification.
As per the MIB.
hh3cNetstream4TrapEntryChassis
Object (OID)
Access
Value range
Implementation
hh3cNetstream4TrapEntryChassis (1.3.6.1.4.1.25506.2.256.1.1.2)
Unsigned32
Alarmed chassis number.
As per the MIB.
hh3cNetstream4TrapEntrySlot
Object (OID)
Access
Value range
Implementation
hh3cNetstream4TrapEntrySlot (1.3.6.1.4.1.25506.2.256.1.1.3)
Unsigned32
Alarmed slot number.
As per the MIB.
Notifications
hh3cNetstream4TrapEntryTHAlarm
Basic information
OID
Event
Severity
Recovery notification
Default status
1.3.6.1.4.1.25506.2.256.1.0.1
The number of IPv4 NetStream entries reaches the alarm threshold of the device, module, or member device.
Informational
Warning
1.3.6.1.4.1.25506.2.256.1.0.2 (hh3cNetstream4TrapEntryTHResume)
ON
Notification triggers
This notification is generated when the number of IPv4 NetStream entries reaches 80% of the upper limit of the device, module, or member device.
System impact
Too many IPv4 NetStream entries will use a large amount of the memory. When the number of the entries reaches the upper limit, the system might not be able to collect statistics for some of the entries.
Status control
ON
CLI: Use the snmp-agent trap enable ip netstream [ entry-limit ] command.
OFF
CLI: Use the undo snmp-agent trap enable ip netstream [ entry-limit ] command.
Objects
OID (object name)
Index nodes
Value range
1.3.6.1.4.1.25506.2.256.1.1.1 (hh3cNetstream4TrapEntrySpec)
N/A
Unsigned32
(hh3cNetstream4TrapEntryChassis)
Chassis number
N/A
Unsigned32
(hh3cNetstream4TrapEntrySlot)
Slot number
N/A
Unsigned32
Recommended action
1.     If the device has enough memory, use the ip netstream max-entry command to expand the upper limit for IPv4 NetStream entries.
2.     If the device has good performance, use the ip netstream max-entry aging command to age out some entries when the upper limit is reached. This can resolve the issue that some entry statistics cannot be collected.
3.     Adjust the incoming interface or add new modules to sort flows.
Basic information
OID
Event
Severity
Default status
The number of IPv4 Netstream entries reaches the recovery threshold of the device, module, or member device.
Recovery
Warning
N/A
ON
This notification is generated when the number of IPv4 NetStream entries drops below 70% of the upper limit of the device, module, or member device.
System impact
No negative impact on the system.
Status control
ON
OFF
Objects
OID (object name)
Index nodes
Value range
N/A
Unsigned32
Chassis number.
N/A
Unsigned32
Slot number.
N/A
Unsigned32
Recommended action
No action is required.
