- 15-Network Management and Monitoring
- 01-DISMAN-EVENT-MIB
- 02-DISMAN-PING-MIB
- 03-DISMAN-TRACEROUTE-MIB
- 04-HH3C-NTP-MIB
- 05-HH3C-HTTP-MIB
- 06-HH3C-MIRRORGROUP-MIB
- 07-HH3C-NETCONF-MIB
- 08-HH3C-NETSTREAM4-MIB
- 09-HH3C-NETSTREAM6-MIB
- 10-HH3C-NQA-MIB
- 11-HH3C-RMON-EXT2-MIB
- 12-HH3C-SNMP-EXT-MIB
- 13-RMON-MIB
- 14-RMON2-MIB
- 15-SFLOW-MIB
- 16-SNMP-FRAMEWORK-MIB
- 17-SNMP-MPD-MIB
- 18-SNMP-NOTIFICATION-MIB
- 19-SNMP-TARGET-MIB
- 20-SNMP-USER-BASED-SM-MIB
- 21-SNMP-VIEW-BASED-ACM-MIB
- 22-SNMPv2-MIB
09-HH3C-NETSTREAM6-MIB | 66.96 KB |
HH3C-NETSTREAM6-MIB
About this MIB
Use this MIB to export alarm information of the NETSTREAM6 module.
MIB file name
hh3c-netstream6.mib
Root object
iso(1).org(3).dod(6).internet(1).private(4).enterprises(1).hh3c(25506).hh3cCommon(2).hh3cNetstream6(257)
Scalar objects
hh3cNetstream6TrapEntrySpec
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cNetstream6TrapEntrySpec (1.3.6.1.4.1.25506.2.257.1.1.1) |
accessible-for-notify |
Unsigned32 |
Standard MIB values. |
Flow table specification. |
As per the MIB. |
hh3cNetstream6TrapEntryChassis
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cNetstream6TrapEntryChassis (1.3.6.1.4.1.25506.2.257.1.1.2) |
Unsigned32 |
Alarmed chassis number. |
As per the MIB. |
hh3cNetstream6TrapEntrySlot
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cNetstream6TrapEntrySlot (1.3.6.1.4.1.25506.2.257.1.1.3) |
Unsigned32 |
Alarmed slot number. |
As per the MIB. |
Notifications
hh3cNetstream6TrapEntryTHAlarm
Basic information
OID |
Event |
Type |
Severity |
Recovery notification |
Default status |
1.3.6.1.4.1.25506.2.257.1.0.1 |
The number of IPv6 Netstream entries reaches the alarm threshold of the device, module, or member device. |
Informational |
Warning |
1.3.6.1.4.1.25506.2.257.1.0.2 (hh3cNetstream6TrapEntryTHResume) |
ON |
Notification triggers
This notification is generated when the number of IPv6 NetStream entries reaches 80% of the upper limit of the module.
System impact
Too many IPv6 NetStream entries will increase the memory usage. When the number of the entries reaches the upper limit, the system might not be able to collect statistics for some of the entries.
Status control
ON
CLI: Use the snmp-agent trap enable ipv6 netstream [ entry-limit ] command.
OFF
CLI: Use the undo snmp-agent trap enable ipv6 netstream [ entry-limit ] command.
Objects
OID (object name) |
Index nodes |
Type |
Value range |
1.3.6.1.4.1.25506.2.257.1.1.1 (hh3cNetstream6TrapEntrySpec) |
Flow table specification |
N/A |
Unsigned32 |
1.3.6.1.4.1.25506.2.257.1.1.2 (hh3cNetstream6TrapEntryChassis) |
Chassis number |
N/A |
Unsigned32 |
1.3.6.1.4.1.25506.2.257.1.1.3 (hh3cNetstream6TrapEntrySlot) |
Slot number |
N/A |
Unsigned32 |
Recommended action
1. If the device has enough memory, use the ipv6 netstream max-entry command to expand the upper limit for IPv6 NetStream entries.
2. If the device has good performance, use the ipv6 netstream max-entry aging command to age out some entries when the upper limit is reached. This can resolve the issue that some entry statistics cannot be collected.
3. Adjust the incoming interface or add new modules to sort flows.
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.2.257.1.0.2 |
The number of IPv6 Netstream entries reaches the recovery threshold of the card. |
Recovery |
Warning |
N/A |
ON |
This notification is generated when the number of IPv6 NetStream entries drops below 70% of the upper limit of the device, module, or member device.
System impact
No negative impact on the system.
Status control
ON
OFF
Objects
OID (object name) |
Index nodes |
Type |
Value range |
N/A |
Unsigned32 |
Chassis number. |
N/A |
Unsigned32 |
Slot number. |
N/A |
Unsigned32 |
Recommended action
No action is required.
