15-Network Management and Monitoring
HomeSupportSwitchesS9820 SeriesReference GuidesMIB CompanionH3C S9820-8C MIB Companion-Release 6715-6W10015-Network Management and Monitoring
04-HH3C-NTP-MIB
04-HH3C-NTP-MIB 338.80 KB
HH3C-NTP-MIB
About this MIB
Use this MIB to configure NTP of the device.
MIB file name
hh3c-ntp.mib
Root object
iso(1).org(3).dod(6).internet(1).private(4).enterprises(1).hh3c(25506).hh3cRhw(8).hh3cNTP(22)
Scalar objects
hh3cNTPSysLeap
Object (OID)
Access
Value range
Implementation
hh3cNTPSysLeap (1.3.6.1.4.1.25506.8.22.1.1.1)
read-only
INTEGER
noWarning(0), addSecond(1), subtractSecond(2), alarm(3)
Two-bit system leap second indicator.
As per the MIB.
hh3cNTPSysStratum
Object (OID)
Access
Value range
Implementation
hh3cNTPSysStratum (1.3.6.1.4.1.25506.8.22.1.1.2)
read-only
Integer32
Integer32 (1..16)
Stratum level of the local system clock.
As per the MIB.
hh3cNTPSysPrecision
Object (OID)
Access
Value range
Implementation
hh3cNTPSysPrecision (1.3.6.1.4.1.25506.8.22.1.1.3)
read-only
Integer32
Integer32 (-20..20)
Accuracy of the system clock.
As per the MIB.
hh3cNTPSysRootdelay
Object (OID)
Access
Value range
Implementation
hh3cNTPSysRootdelay (1.3.6.1.4.1.25506.8.22.1.1.4)
read-only
OCTET STRING
OCTET STRING (1..128)
Round-trip delay from the local device to the primary reference source at the root of the synchronization subnet.
As per the MIB.
hh3cNTPSysRootdispersion
Object (OID)
Access
Value range
Implementation
hh3cNTPSysRootdispersion (1.3.6.1.4.1.25506.8.22.1.1.5)
read-only
OCTET STRING
Maximum error of the system clock relative to the primary reference source at the root of the synchronization subnet.
As per the MIB.
hh3cNTPSysRefid
Object (OID)
Access
Value range
Implementation
hh3cNTPSysRefid (1.3.6.1.4.1.25506.8.22.1.1.6)
read-only
OCTET STRING
Reference clock ID of the local clock.
As per the MIB.
hh3cNTPSysReftime
Object (OID)
Access
Value range
Implementation
hh3cNTPSysReftime (1.3.6.1.4.1.25506.8.22.1.1.7)
read-only
OCTET STRING
Timestamp of the local system clock updated most recently.
As per the MIB.
hh3cNTPSysPoll
Object (OID)
Access
Value range
Implementation
hh3cNTPSysPoll (1.3.6.1.4.1.25506.8.22.1.1.8)
read-only
Integer32
Integer32 (-20..20)
System polling interval.
As per the MIB.
hh3cNTPSysPeer
Object (OID)
Access
Value range
Implementation
hh3cNTPSysPeer (1.3.6.1.4.1.25506.8.22.1.1.9)
read-only
Integer32
Integer32 (0..2147483647)
Reference synchronization source specified by the system.
This object is replaced by hh3cNTPSysSrcPeer.
hh3cNTPSysState
Object (OID)
Access
Value range
Implementation
hh3cNTPSysState (1.3.6.1.4.1.25506.8.22.1.1.10)
read-only
INTEGER
noUpdateClock(0), getfreqInfo(1), clockBySet(2), clockBySetAndNoFreq(3), clockBySyns(4), findError(5)
Status of the local clock.
An integer indicates the status of the local clock. Currently, clockBySet(2) is not supported.
hh3cNTPSysOffset
Object (OID)
Access
Value range
Implementation
hh3cNTPSysOffset (1.3.6.1.4.1.25506.8.22.1.1.11)
read-only
OCTET STRING
Offset of the local clock updated most recently.
As per the MIB.
hh3cNTPSysDrift
Object (OID)
Access
Value range
Implementation
hh3cNTPSysDrift (1.3.6.1.4.1.25506.8.22.1.1.12)
read-only
OCTET STRING
Pre-made clock frequency.
As per the MIB.
hh3cNTPSysCompliance
Object (OID)
Access
Value range
Implementation
hh3cNTPSysCompliance (1.3.6.1.4.1.25506.8.22.1.1.13)
read-only
OCTET STRING
System error.
As per the MIB.
hh3cNTPSysClock
Object (OID)
Access
Value range
Implementation
hh3cNTPSysClock (1.3.6.1.4.1.25506.8.22.1.1.14)
read-only
OCTET STRING
System local time.
As per the MIB.
hh3cNTPSysStabil
Object (OID)
Access
Value range
Implementation
hh3cNTPSysStabil (1.3.6.1.4.1.25506.8.22.1.1.15)
read-only
OCTET STRING
Clock frequency stability.
As per the MIB.
hh3cNTPSysAuthenticate
Object (OID)
Access
Value range
Implementation
hh3cNTPSysAuthenticate (1.3.6.1.4.1.25506.8.22.1.1.16)
read-write
INTEGER
noAuthenticate(0), authenticate(1)
An integer indicates that the system supports authentication.
As per the MIB.
hh3cNTPSysPollSec
Object (OID)
Access
Value range
Implementation
hh3cNTPSysPollSec
(1.3.6.1.4.1.25506.8.22.1.1.17)
read-write
Integer32
Integer32 (2..1048576)
System polling interval, in seconds.
Only read operations are supported.
hh3cNTPSysClockSec
Object (OID)
Access
Value range
Implementation
hh3cNTPSysClockSec
(1.3.6.1.4.1.25506.8.22.1.1.18)
read-only
Integer32
Standard MIB values.
System local time, in seconds.
As per the MIB.
hh3cNTPServerIP
Object (OID)
Access
Value range
Implementation
hh3cNTPServerIP
(1.3.6.1.4.1.25506.8.22.1.1.19)
read-write
IpAddress
OCTET STRING (4)
IP address of the NTP server.
As per the MIB.
hh3cNTPSysSrcPeer
Object (OID)
Access
Value range
Implementation
hh3cNTPSysSrcPeer (1.3.6.1.4.1.25506.8.22.1.1.20)
read-only
Unsigned32
As per the MIB.
hh3cNTPSysOldServerIP
Object (OID)
Access
Value range
Implementation
hh3cNTPSysOldServerIP (1.3.6.1.4.1.25506.8.22.1.1.21)
accessible-for-notify
IpAddress
OCTET STRING (4)
IP address of the last NTP server.
As per the MIB.
hh3cNTPSysSrcVpnName
Object (OID)
Access
Value range
Implementation
hh3cNTPSysSrcVpnName (1.3.6.1.4.1.25506.8.22.1.1.22)
DisplayString
OCTET STRING (0..255)
VPN instance to which the current NTP server belongs.
As per the MIB.
hh3cNTPSysOldSrcVpnName
Object (OID)
Access
Value range
Implementation
hh3cNTPSysOldSrcVpnName (1.3.6.1.4.1.25506.8.22.1.1.23)
DisplayString
VPN instance to which the last NTP server belongs.
As per the MIB.
hh3cNTPSysMaxDynamicSessions
Object (OID)
Access
Value range
Implementation
(1.3.6.1.4.1.25506.8.22.1.1.24)
Unsigned32
Unsigned32(0..4294967295)
Maximum number of dynamic NTP sessions.
As per the MIB.
hh3cNTPSysMaxSessions
Object (OID)
Access
Value range
Implementation
hh3cNTPSysMaxSessions (1.3.6.1.4.1.25506.8.22.1.1.25)
Unsigned32
Unsigned32 (0..255)
Maximum number of NTP sessions.
As per the MIB.
hh3cNTPSysOldStratum
Object (OID)
Access
Value range
Implementation
hh3cNTPSysOldStratum (1.3.6.1.4.1.25506.8.22.1.1.26)
Integer32
Integer32 (1..16)
Old stratum level of the local system clock.
As per the MIB.
hh3cNTPSysTimeOffsetThres
Object (OID)
Access
Value range
Implementation
hh3cNTPSysTimeOffsetThres (1.3.6.1.4.1.25506.8.22.1.1.27)
OCTET STRING
Clock time offset threshold.
As per the MIB.
Tabular objects
hh3cNTPPeerTable
About this table
This table provides information about the peers associated with the local NTP server.
Support for operations
Create
Edit/Modify
Delete
Read
Supported. The hh3cNTPPeerRowStatus column supports only value createAndGo.
Not supported
Supported
Supported
Columns
The table indexes are hh3cNTPPeerRemAdr and hh3cNTPPeerHMode.
Object (OID)
Access
Value range
Implementation
hh3cNTPPeerConfig (1.3.6.1.4.1.25506.8.22.2.1.1.1.1)
read-only
TruthValue
true(1),
false(2)
A bit indicates the establishment of the association. If a peer is unreachable, the bit is not recoverable.
As per the MIB.
hh3cNTPPeerAuthenable (1.3.6.1.4.1.25506.8.22.2.1.1.1.2)
read-only
TruthValue
true(1),
false(2)
A bit indicates that the peer system supports authentication.
As per the MIB.
hh3cNTPPeerAuthentic (1.3.6.1.4.1.25506.8.22.2.1.1.1.3)
read-only
TruthValue
true(1),
false(2)
A bit indicates that the authentic message passes authentication.
As per the MIB.
hh3cNTPPeerRemAdr (1.3.6.1.4.1.25506.8.22.2.1.1.1.4)
not-accessible
IpAddress
OCTET STRING (4)
IP address of the peer. Set the object when creating a new association.
As per the MIB.
hh3cNTPPeerRemPort (1.3.6.1.4.1.25506.8.22.2.1.1.1.5)
read-only
Integer32
Integer32 (1..65535)
The UDP port number on which the peer receives NTP messages.
As per the MIB.
hh3cNTPPeerLocAdr (1.3.6.1.4.1.25506.8.22.2.1.1.1.6)
read-only
IpAddress
OCTET STRING (4)
IP address of the local host.
As per the MIB.
hh3cNTPPeerLocPort (1.3.6.1.4.1.25506.8.22.2.1.1.1.7)
read-only
Integer32
The UDP port number on which the local host receives NTP messages.
As per the MIB.
hh3cNTPPeerLeap (1.3.6.1.4.1.25506.8.22.2.1.1.1.8)
read-only
INTEGER
Leap second indicator of the peer.
As per the MIB.
hh3cNTPPeerHMode (1.3.6.1.4.1.25506.8.22.2.1.1.1.9)
not-accessible
INTEGER
unspecified (0), symmetricActive (1), symmetricPassive (2), client (3), server(4), broadcast (5), reservedControl (6), reservedPrivate (7), broadcastclient (8), multicastclient (9)
Host association mode.
As per the MIB.
hh3cNTPPeerStratum (1.3.6.1.4.1.25506.8.22.2.1.1.1.10)
read-only
Integer32
Integer32 (0..255)
Stratum level of the peer, indicating the clock accuracy.
As per the MIB.
hh3cNTPPeerPPoll (1.3.6.1.4.1.25506.8.22.2.1.1.1.11)
read-only
Integer32
Integer32 (-20..20)
The interval at which the peer polls the local host.
As per the MIB.
hh3cNTPPeerHPoll (1.3.6.1.4.1.25506.8.22.2.1.1.1.12)
read-only
Integer32
Integer32 (-20..20)
The interval at which the local host polls the peer.
As per the MIB.
hh3cNTPPeerPrecision (1.3.6.1.4.1.25506.8.22.2.1.1.1.13)
read-only
Integer32
Integer32 (-20..20)
Precision of the peer clock.
As per the MIB.
hh3cNTPPeerRootDelay (1.3.6.1.4.1.25506.8.22.2.1.1.1.14)
read-only
OCTET STRING
Round-trip delay from the peer clock to the local clock.
As per the MIB.
hh3cNTPPeerRootDispersion (1.3.6.1.4.1.25506.8.22.2.1.1.1.15)
read-only
OCTET STRING
Clock time difference between the peer clock and the time source.
As per the MIB.
hh3cNTPPeerRefId (1.3.6.1.4.1.25506.8.22.2.1.1.1.16)
read-only
OCTET STRING
Reference source ID of the peer clock.
As per the MIB.
hh3cNTPPeerRefTime (1.3.6.1.4.1.25506.8.22.2.1.1.1.17)
read-only
OCTET STRING
Timestamp of the peer clock.
As per the MIB.
hh3cNTPPeerOrg (1.3.6.1.4.1.25506.8.22.2.1.1.1.18)
read-only
OCTET STRING
Local clock timestamp in the NTP message sent most recently.
As per the MIB.
hh3cNTPPeerRec (1.3.6.1.4.1.25506.8.22.2.1.1.1.19)
read-only
OCTET STRING
Local timestamp in the NTP message received most recently from the peer.
As per the MIB.
hh3cNTPPeerXmt (1.3.6.1.4.1.25506.8.22.2.1.1.1.20)
read-only
OCTET STRING
Local time after the sending of a NTP message.
As per the MIB.
hh3cNTPPeerReach (1.3.6.1.4.1.25506.8.22.2.1.1.1.21)
read-only
Integer32
Reachability count. A peer is unreachable if the object value is 0.
As per the MIB.
hh3cNTPPeerValid (1.3.6.1.4.1.25506.8.22.2.1.1.1.22)
read-only
Integer32
Integer32 (0..255)
Valid sampling data.
As per the MIB.
hh3cNTPPeerTimer (1.3.6.1.4.1.25506.8.22.2.1.1.1.23)
read-only
Integer32
The interval of transmitted NTP messages from the host to the peer.
As per the MIB.
hh3cNTPPeerDelay (1.3.6.1.4.1.25506.8.22.2.1.1.1.24)
read-only
OCTET STRING
Delay of messages from the host to the peer.
As per the MIB.
hh3cNTPPeerOffset (1.3.6.1.4.1.25506.8.22.2.1.1.1.25)
read-only
OCTET STRING
Offset of the peer relative to the local clock.
As per the MIB.
hh3cNTPPeerJitter (1.3.6.1.4.1.25506.8.22.2.1.1.1.26)
read-only
OCTET STRING
Sampling data flag.
As per the MIB.
hh3cNTPPeerDispersion (1.3.6.1.4.1.25506.8.22.2.1.1.1.27)
read-only
OCTET STRING
Maximum error of the peer relative to the local clock.
As per the MIB.
hh3cNTPPeerKeyId (1.3.6.1.4.1.25506.8.22.2.1.1.1.28)
read-only
Unsigned32
Authentication key ID in NTP messages.
As per the MIB.
hh3cNTPPeerFiltDelay (1.3.6.1.4.1.25506.8.22.2.1.1.1.29)
read-only
OCTET STRING
Round-trip delay of the peer relative to the local clock.
As per the MIB.
hh3cNTPPeerFiltOffset (1.3.6.1.4.1.25506.8.22.2.1.1.1.30)
read-only
OCTET STRING
As per the MIB.
hh3cNTPPeerFiltError (1.3.6.1.4.1.25506.8.22.2.1.1.1.31)
read-only
OCTET STRING
As per the MIB.
hh3cNTPPeerPMode (1.3.6.1.4.1.25506.8.22.2.1.1.1.32)
read-only
INTEGER
Association mode of the peer.
As per the MIB.
hh3cNTPPeerReceived (1.3.6.1.4.1.25506.8.22.2.1.1.1.33)
read-only
INTEGER(0..4294967295)
Number of received NTP messages.
As per the MIB.
hh3cNTPPeerSent (1.3.6.1.4.1.25506.8.22.2.1.1.1.34)
read-only
Number of sent NTP messages.
As per the MIB.
hh3cNTPPeerFlash (1.3.6.1.4.1.25506.8.22.2.1.1.1.35)
read-only
Hh3cAlarmStatus
BITS{
recvRepeatMsg(0),
recvremanMsg(1),
unSynMsg(2),
dispBeyond(3),
unauthenticate(4), unSynClock(5), straBeyond(6), rootDispBeyond(7), noAuthen(8),
refuOperate(9) }
Message test flag.
As per the MIB.
hh3cNTPPeerRowStatus (1.3.6.1.4.1.25506.8.22.2.1.1.1.36)
read-create
RowStatus
Supports only values active, createAndGo, and destroy.
Row status.
Supports only values active, createAndGo, and destroy. If the value broadcast, broadcastclient, or multicastclient is used for hh3cNTPPeerHMode, this object supports only the read operation.
Notifications
This section contains HH3C-NTP-MIB notifications.
hh3cNTPSysStateChangeTrap
Basic information
OID
Event
Severity
Recovery notification
Default status
1.3.6.1.4.1.25506.8.22.1.2.0.1
NTP local time synchronization status changed.
Informational
Warning
N/A
ON
Notification triggers
This notification is generated when the NTP local time synchronization status changes.
Possible reasons for change of the NTP time status from synchronized to unsynchronized include:
·     Reason 1: The specified time server is deleted.
·     Reason 2: The specified time server fails authentication.
·     Reason 3: The clock of the specified time server is not synchronized.
·     Reason 4: The specified time server is not reachable.
·     Reason 5: The stratum level of the clock source is larger than that of the local clock.
·     Reason 6: The clock source is lost.
System impact
The local time is inaccurate.
Status control
The notification cannot be disabled.
Objects
This table does not have indexes.
OID (object name)
Index nodes
Value range
(hh3cNTPSysState)
Local clock status.
N/A
INTEGER
(hh3cNTPServerIP)
N/A
IpAddress
OCTET STRING (4)
(hh3cNTPSysSrcVpnName)
VPN instance to which the NTP server belongs.
N/A
DisplayString
OCTET STRING(0..255)
Recommended action
To resolve the issue:
1.     Specify another time server.
2.     If the issue persists, collect alarm information and configuration data, and then contact H3C Support for help.
3.     Execute the display this | include ntp-service authentication command in system view to identify whether the local device and time server are both configured with NTP authentication settings.
¡     If they are both configured with NTP authentication settings, make sure they use the same authentication key and the key is configured as a trust key.
¡     If NTP authentication settings are not configured, configure NTP authentication.
4.     If the issue persists, collect alarm information and configuration data, and then contact H3C Support for help.
5.     Specify another NTP server.
6.     If the issue persists, collect alarm information and configuration data, and then contact H3C Support for help.
7.     Execute the ping command to test whether the time server is reachable.
¡     If the time server is reachable, proceed to the next step.
¡     If the time server is not reachable, resolve the network connectivity issue or replace another time server.
8.     If the issue persists, collect alarm information and configuration data, and then contact H3C Support for help.
9.     Execute the display ntp-service status command to view the stratum level of the local clock.
¡     If the stratum level of the clock source is larger than that of the local NTP clock, specify another clock source with a lower stratum level lower than the local clock.
¡     If the stratum level of the clock source is lower than that of the local NTP clock, proceed to the next step.
10.     If the issue persists, collect alarm information and configuration data, and then contact H3C Support for help.
11.     Execute the display ntp-service sessions command to identify whether the clock source is lost. If the clock source is lost, specify another clock source.
12.     If the issue persists, collect alarm information and configuration data, and then contact H3C Support for help.
hh3cNTPSysPeerChangeTrap
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.8.22.1.2.0.2
Change of the NTP time server.
Informational
Warning
N/A
ON
This notification is generated when the NTP time server changes.
System impact
No negative impact on the system.
Status control
Objects
OID (object name)
Index nodes
Value range
1.3.6.1.4.1.25506.8.22.1.1.21 (hh3cNTPSysOldServerIP)
IP address of last NTP server.
N/A
IpAddress
1.3.6.1.4.1.25506.8.22.1.1.23 (hh3cNTPSysOldSrcVpnName)
N/A
DisplayString
1.3.6.1.4.1.25506.8.22.1.1.19 (hh3cNTPServerIP)
IP address of the current NTP server.
N/A
IpAddress
1.3.6.1.4.1.25506.8.22.1.1.22 (hh3cNTPSysSrcVpnName)
N/A
DisplayString
Recommended action
If the clock source is changed because another clock source is specified, no action is required.
If the clock source is changed because of a change in clock source properties, execute the display ntp-service sessions verbos command to view the clock source properties and conduct further investigation. You can see the recommended actions for the hh3cNTPSysStateChangeTrap.
hh3cNTPDynSessionLimit
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.8.22.1.2.0.3
The number of dynamic NTP sessions reached the threshold.
Error
Major
1.3.6.1.4.1.25506.8.22.1.2.0.4 (hh3cNTPDynSessionLimitResume)
ON
This notification is generated when the number of dynamic NTP sessions reaches the threshold.
System impact
New dynamic NTP sessions cannot be established.
Status control
Objects
OID (object name)
Index nodes
Value range
1.3.6.1.4.1.25506.8.22.1.1.24 (hh3cNTPSysMaxDynamicSessions)
N/A
Unsigned32
Recommended action
Execute the ntp-service max-dynamic-sessions command to set the maximum number of dynamic sessions to a value large enough.
Basic information
OID
Event
Severity
Default status
The number of dynamic NTP sessions dropped below the threshold.
Recovery
Major
N/A
ON
This notification is generated when the number of dynamic NTP sessions drops below the threshold.
System impact
Status control
Objects
OID (object name)
Index nodes
Value range
N/A
Unsigned32
Recommended action
No action is required.
hh3cNTPSessionLimit
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.8.22.1.2.0.5
Number of NTP sessions reached the threshold.
Error
Major
1.3.6.1.4.1.25506.8.22.1.2.0.6(hh3cNTPSessionLimitResume)
ON
This notification is generated when the number of NTP sessions reaches the threshold.
System impact
New NTP sessions cannot be established.
Status control
Objects
OID (object name)
Index node
Value range
N/A
Unsigned32
Unsigned32 (0..65535)
Recommended action
Delete unused static NTP sessions.
Basic information
OID
Event
Severity
Default status
Number of NTP sessions fell below the threshold.
Recovery
Major
N/A
ON
This notification is generated when the number of NTP sessions falls below the threshold.
System impact
Status control
Objects
OID (object name)
Index nodes
Value range
N/A
Unsigned32
Recommended action
hh3cNTPSynchronizationLost
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.8.22.1.2.0.7
NTP local clock lost synchronization.
Error
Major
1.3.6.1.4.1.25506.8.22.1.2.0.8(hh3cNTPSynchronizationResume)
ON
This notification is generated when the local NTP clock loses synchronization in the following situations:
·     Reason 1: The time server is unreachable.
·     Reason 2: The time server has been removed.
·     Reason 3: The time server is in an unsynchronized state.
System impact
The local NTP clock will change to unsynchronized state.
Status control
Objects
OID (object name)
Index nodes
Value range
hh3cNTPSysState
Local clock status.
N/A
INTEGER
hh3cNTPServerIP
N/A
IpAddress
OCTET STRING (4)
Recommended action
Execute the display this | include ntp-service command to identify whether a symmetric peer or NTP server has been specified.
Execute the command to identify whether the time server is in synchronized state.
Basic information
OID
Event
Severity
Default status
The local NTP clock resumed time synchronization.
Recovery
Major
N/A
ON
This notification is generated when the local NTP clock resumes time synchronization.
System impact
Status control
Objects
OID (object name)
Index nodes
Value range
(hh3cNTPSysState)
Local clock status.
N/A
INTEGER
(hh3cNTPServerIP)
N/A
IpAddress
OCTET STRING (4)
Recommended action
hh3cNTPSysStratumChange
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.8.22.1.2.0.9
The stratum level of the local clock changed.
Informational
Warning
N/A
ON
This notification is generated when the stratum level of the local clock changes.
System impact
The downstream NTP clock might become unsynchronized.
Status control
Objects
OID (object name)
Index nodes
Value range
1.3.6.1.4.1.25506.8.22.1.1.2 (hh3cNTPSysStratum)
Current stratum level of the local system clock.
N/A
Integer32
Integer32 (1..16)
1.3.6.1.4.1.25506.8.22.1.1.26 (hh3cNTPSysOldStratum)
N/A
Integer32
Integer32 (1..16)
Recommended action
hh3cNTPTimeOffsetThresExceed
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.8.22.1.2.0.10
NTP clock offset reached the threshold.
Error
Major
1.3.6.1.4.1.25506.8.22.1.2.0.11(hh3cNTPTimeOffsetThresResume)
OFF
This notification is generated when the time offset between the local NTP clock and the NTP time server reaches or exceeds the threshold.
System impact
The clock precision might be affected.
Status control
ON
CLI: Use the ntp-service time-offset-threshold trap trap-threshold command.
OFF
CLI: Use the undo ntp-service time-offset-threshold command.
Objects
OID (object name)
Index nodes
Value range
1.3.6.1.4.1.25506.8.22.1.1.11 (hh3cNTPSysOffset)
NTP time offset.
N/A
OCTET STRING
1.3.6.1.4.1.25506.8.22.1.1.27 (hh3cNTPSysTimeOffsetThres)
NTP time offset threshold.
N/A
OCTET STRING
Recommended action
1.     Execute the display ntp-service sessions verbose command to view detailed information about the NTP session.
¡     If the session meets the requirements, execute the ntp-service time-offset-threshold command to correct the alarm threshold.
¡     If the session does not meet the requirements, specify another clock source.
Basic information
OID
Event
Severity
Default status
The NTP clock offset fell below the threshold to the normal range.
Recovery
Major
N/A
OFF
This notification is generated when the NTP clock offset falls below the threshold to the normal range.
System impact
Status control
ON
OFF
Objects
OID (object name)
Index nodes
Value range
NTP time offset.
N/A
OCTET STRING
N/A
OCTET STRING
Recommended action
hh3cNTPSysLeapChangeTrap
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.8.22.1.2.0.14
System leap second indicator changed.
Informational
Warning
N/A
ON
This notification is generated when the system leap second indicator changes.
Leap second indicator is a two-bit code warning of an impending leap second to be inserted/deleted in the last minute of the current day. The indicator changes also when the NTP synchronization status changes.
System impact
Status control
Objects
OID (object name)
Index nodes
Value range
hh3cNTPSysLeap
N/A
INTEGER
Recommended action
hh3cNTPServerAbnormal
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.8.22.1.2.0.15
NTP server abnormal.
Error
Major
1.3.6.1.4.1.25506.8.22.1.2.0.16 (hh3cNTPServerNormal)
ON
This notification is generated when the NTP server is abnormal.
·     The NTP server is unreachable.
·     The NTP server clock is not synchronized.
·     The NTP server failed authentication.
·     The NTP server does not have access to the NTP service on the device.
·     The clock offset of NTP server is greater than the threshold.
·     NTP server message verification failed.
System impact
The clock cannot be synchronized.
Status control
Objects
OID (object name)
Index nodes
Value range
N/A
IpAddress
Recommended action
·     Execute the display ip routing-table command to view the effective routing entries on the device and ensure that the device and the NTP server are reachable to each other.
·     Login to the NTP server and execute the display ntp-service status command to view the value of the Clock status field. If the value is unsynchronized, the NTP server clock is not synchronized. Resolve the NTP server clock synchronization issue first.
·     Check the NTP authentication settings on both the NTP client and server to ensure that they are consistent in the authentication parameters.
·     View the ntp-service acl and ntp-service ipv6 acl command settings to ensure that the NTP server has access to the NTP service on the local device.
·     Execute the display clock command on both the NTP server and the local device to view the system date and time and verify that the NTP server clock is accurate. If the NTP server clock is accurate, you can execute the ntp-service time-offset-threshold command on the device to reconfigure the clock offset threshold.
·     Execute the display ntp-service status command on the NTP server to check if the Root delay, Root dispersion, and Clock stratum field values meet the networking requirements. If they do not meet the requirements, adjust the parameters on the NTP server or replace the NTP server.
hh3cNTPServerNormal
Basic information
OID
Event
Severity
Default status
NTP server returned to normal.
Recovery
Major
N/A
ON
This notification is generated when the NTP server status transitions from abnormal to normal.
System impact
Status control
Objects
OID (object name)
Index nodes
Value range
N/A
IpAddress
Recommended action
hh3cNTPStepSetTimeFailed
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.8.22.1.2.0.17
System time failed to be set during the single-step adjustment process.
Informational
Warning
N/A
ON
This notification is generated when system time fails to be set during the single-step adjustment process.
System impact
The system time is incorrect.
Status control
Objects
No objects are carried in the notification.
Recommended action
Collect alarm information and configuration data, and then contact H3C Support for help.
