- 03-Layer 2—LAN Switching Command Reference
- 01-MAC address table commands
- 02-PFC commands
- 03-Bulk interface commands
- 04-Ethernet interface commands
- 05-Ethernet link aggregation commands
- 06-M-LAG commands
- 07-Port isolation commands
- 08-VLAN commands
- 09-MVRP commands
- 10-Loopback, null, and inloopback interface commands
- 11-QinQ commands
- 12-VLAN mapping commands
- 13-Loop detection commands
- 14-Spanning tree commands
- 15-LLDP commands
- 16-L2PT commands
- 17-Layer 2 forwarding commands
11-QinQ commands | 70.19 KB |
QinQ commands
This document uses the following terms:
· CVLAN—Customer network VLANs, also called inner VLANs, refer to VLANs that a customer uses on the private network.
· SVLAN—Service provider network VLANs, also called outer VLANs, refer to VLANs that a service provider uses to transmit VLAN tagged traffic for customers.
display qinq
Use display qinq to display QinQ-enabled interfaces.
display qinq [ interface interface-type interface-number ]
interface interface-type interface-number: Specifies an interface by its type and number. If you do not specify an interface, this command displays all QinQ-enabled interfaces.
If QinQ is not enabled on any interfaces, this command does not provide any output.
# Enable QinQ on GigabitEthernet 1/0/1. Then, verify that QinQ is enabled on the interface.
[Sysname-GigabitEthernet1/0/1] qinq enable
[Sysname-GigabitEthernet1/0/1] display qinq interface gigabitethernet 1/0/1
# Enable QinQ on GigabitEthernet 1/0/1 and GigabitEthernet 1/0/3. Then, verify that QinQ is enabled on the interfaces.
[Sysname] interface gigabitethernet 1/0/3
[Sysname-GigabitEthernet1/0/3] qinq enable
[Sysname-GigabitEthernet1/0/3] display qinq
qinq enable
qinq enable
Use qinq enable to enable QinQ on an interface.
Use undo qinq enable to disable QinQ on an interface.
qinq enable
undo qinq enable
QinQ is disabled on interfaces.
display qinq
qinq ethernet-type (interface view)
Use qinq ethernet-type to set the TPID value in SVLAN tags on an interface.
Use undo qinq ethernet-type to restore the default TPID value in SVLAN tags on an interface.
qinq ethernet-type service-tag hex-value
undo qinq ethernet-type service-tag
The TPID value in SVLAN tags is 8100 in hexadecimal notation.
service-tag: Sets the TPID value in the SVLAN tag.
hex-value: Sets a hexadecimal TPID value in the range of 1 to ffff, excluding the reserved EtherType values listed in Table 1.
Table 1 Reserved EtherType values
Protocol type |
Value |
ARP |
0x0806 |
PUP |
0x0200 |
RARP |
0x8035 |
IP |
0x0800 |
IPv6 |
0x86dd |
PPPoE |
0x8863/0x8864 |
MPLS |
0x8847/0x8848 |
IPX/SPX |
0x8137 |
IS-IS |
0x8000 |
LACP |
0x8809 |
LLDP |
0x88cc |
802.1X |
0x888e |
802.1ag |
0x8902 |
Cluster |
0x88a7 |
Reserved |
0xfffd/0xfffe/0xffff |
You cannot use this command to edit the TPID value in VLAN tags. After you configure this command, the device identifies whether a frame carries an SVLAN tag as follows:
· When the device receives a frame that carries an SVLAN tag with the same TPID value as that specified in this command, the device identifies that this frame carries an SVLAN tag.
· When the device receives a frame that carries an SVLAN tag with a different TPID value from that specified in this command, the device identifies that this frame does not carry an SVLAN tag.
A QinQ-enabled port will add VLAN tags with the TPID value specified in this command to frames.
# Set the TPID value in SVLAN tags to 9100 (hexadecimal) on GigabitEthernet 1/0/1.
[Sysname-GigabitEthernet1/0/1] qinq ethernet-type service-tag 9100
qinq ethernet-type (system view)
Use qinq ethernet-type to set the TPID value in CVLAN tags globally.
Use undo qinq ethernet-type to restore the default TPID value in CVLAN tags globally.
qinq ethernet-type customer-tag hex-value
undo qinq ethernet-type customer-tag
The global TPID value in CVLAN tags is 8100 in hexadecimal notation.
customer-tag: Sets the TPID value in the CVLAN tag.
hex-value: Sets a hexadecimal TPID value in the range of 1 to ffff, excluding the reserved EtherType values listed in Table 2.
Table 2 Reserved EtherType values
Protocol type |
Value |
ARP |
0x0806 |
PUP |
0x0200 |
RARP |
0x8035 |
IP |
0x0800 |
IPv6 |
0x86dd |
PPPoE |
0x8863/0x8864 |
MPLS |
0x8847/0x8848 |
IPX/SPX |
0x8137 |
IS-IS |
0x8000 |
LACP |
0x8809 |
LLDP |
0x88cc |
802.1X |
0x888e |
802.1ag |
0x8902 |
Cluster |
0x88a7 |
Reserved |
You cannot use this command to edit the TPID value in VLAN tags. After you configure this command, the device identifies whether a frame carries a CVLAN tag as follows:
· When the device receives a frame that carries a CVLAN tag with the same TPID value as that specified in this command, the device identifies that this frame carries a CVLAN tag.
· When the device receives a frame that carries a CVLAN tag with a different TPID value from that specified in this command, the device identifies that this frame does not carry a CVLAN tag.
# Set the global TPID value in CVLAN tags to 8200 (hexadecimal).
[Sysname] qinq ethernet-type customer-tag 8200
