- 03-Layer 2—LAN Switching Command Reference
- 01-MAC address table commands
- 02-PFC commands
- 03-Bulk interface commands
- 04-Ethernet interface commands
- 05-Ethernet link aggregation commands
- 06-M-LAG commands
- 07-Port isolation commands
- 08-VLAN commands
- 09-MVRP commands
- 10-Loopback, null, and inloopback interface commands
- 11-QinQ commands
- 12-VLAN mapping commands
- 13-Loop detection commands
- 14-Spanning tree commands
- 15-LLDP commands
- 16-L2PT commands
- 17-Layer 2 forwarding commands
04-Ethernet interface commands | 642.73 KB |
Common Ethernet interface commands
display link-state-change statistics interface
interface default-description output
reset link-state-change statistics interface
shutdown all-physical-interface
snmp-agent trap enable ifmonitor
Layer 2 Ethernet interface commands
Layer 3 Ethernet interface or subinterface commands
bandwidth
Use bandwidth to set the expected bandwidth of an interface.
bandwidth bandwidth-value
undo bandwidth
Ethernet interface view
Ethernet subinterface view
# Set the expected bandwidth of GigabitEthernet 1/0/1 to 1000 kbps.
[Sysname-GigabitEthernet1/0/1] bandwidth 1000
# Set the expected bandwidth of GigabitEthernet 1/0/1.1 to 1000 kbps.
[Sysname] interface gigabitethernet 1/0/1.1
[Sysname-GigabitEthernet1/0/1.1] bandwidth 1000
speed
broadcast-suppression
Use broadcast-suppression to enable broadcast suppression and set the broadcast suppression threshold.
Use undo broadcast-suppression to disable broadcast suppression.
Ethernet interfaces do not suppress broadcast traffic.
ratio: Sets the broadcast suppression threshold as a percentage of the interface bandwidth. The value range for this argument is 0 to 100. A smaller value means that less broadcast traffic is allowed to pass through.
pps max-pps: Specifies the maximum number of broadcast packets that the interface can forward per second. The value range for the max-pps argument (in pps) is 0 to 1.4881 × the interface bandwidth.
kbps max-kbps: Specifies the maximum number of kilobits of broadcast traffic that the Ethernet interface can forward per second. The value range for this argument (in kbps) is 0 to the interface bandwidth.
The broadcast storm suppression features limits the size of broadcast traffic to a threshold on an interface. When the broadcast traffic on the interface exceeds this threshold, the system drops packets until the traffic drops below this threshold.
Both the storm-constrain command and the broadcast-suppression command can suppress broadcast storms on a port. The broadcast-suppression command uses the chip to physically suppress broadcast traffic. It has less influence on the device performance than the storm-constrain command, which uses software to suppress broadcast traffic.
The configured suppression threshold value in pps or kbps will be converted into a multiple of a step supported by the chip. As a result, the effective suppression threshold might be different from the configured one. To determine the suppression threshold that takes effect, see the prompts on the device.
# Set the broadcast suppression threshold to 10000 kbps on GigabitEthernet 1/0/1.
[Sysname-GigabitEthernet1/0/1] broadcast-suppression kbps 10000
The actual value is 9984 on port GigabitEthernet1/0/1 currently.
multicast-suppression
unicast-suppression
combo enable
Use combo enable to activate the copper or fiber combo port of a combo interface.
combo enable { auto | copper | fiber }
The copper or fiber combo port is automatically activated depending on the medium inserted in the combo interface.
auto: Automatically identifies the media inserted and activates the corresponding combo port.
copper: Activates the copper combo port. In this case, use twisted pairs to connect the port.
fiber: Activates the fiber combo port. In this case, use optical fibers to connect the port.
A combo interface is a logical interface that physically contains one fiber combo port and one copper combo port on the device panel. The two ports share one forwarding interface. As a result, they cannot work simultaneously. When you activate either port, the other port is automatically disabled. You can select to activate the copper combo port or fiber combo port.
If you execute the combo enable auto command on a combo interface and the combo interface is connected to cables or optical fibers, you can use the display interface command to display the interface information.
· If the display interface command output contains "Media type is twisted pair," the copper combo port is activated.
· Otherwise, the fiber combo port is activated.
Before using this command, perform the following tasks according to the marks on the device panel:
· Determine the combo interfaces on your device.
· Identify the two physical interfaces that belong to each combo interface.
# Activate the copper combo port of combo interface GigabitEthernet 1/0/1.
[Sysname-GigabitEthernet1/0/1] combo enable copper
# Activate the fiber combo port of combo interface GigabitEthernet 1/0/1.
[Sysname-GigabitEthernet1/0/1] combo enable fiber
dampening
Use dampening to enable the device to dampen an interface when the interface is flapping.
Use undo dampening to restore the default.
undo dampening
Interface dampening is disabled on Ethernet interfaces.
half-life: Specifies the amount of time after which a penalty is decreased, in the range of 1 to 120 seconds. The default value is 54 seconds.
reuse: Specifies the reuse threshold in the range of 200 to 20000. The default value is 750. The reuse threshold must be less than the suppression threshold.
suppress: Specifies the suppression threshold in the range of 200 to 20000. The default value is 2000.
max-suppress-time: Specifies the maximum amount of time the interface can be dampened, in the range of 1 to 255 seconds. The default value is 162 seconds (three times the half-life timer).
When configuring the dampening command, follow these rules to set the values mentioned above:
· The ceiling is equal to 2 (Max-suppress-time/Decay) × reuse-limits. It is not user configurable.
· The configured suppress limit is lower than or equal to the ceiling.
· The ceiling is lower than or equal to the maximum suppress limit supported.
This command, the link-delay command, and the port link-flap protect enable command are mutually exclusive on an interface.
This command does not take effect on the administratively down events. When you execute the shutdown command, the penalty restores to 0, and the interface reports the down event to the higher layer protocols.
Do not enable the dampening function on an interface with RRPP, MSTP, or Smart Link enabled.
After an interface in down state is dampened, the interface state displayed through the display interface command is always down.
# Enable interface dampening on GigabitEthernet 1/0/1.
[Sysname-GigabitEthernet1/0/1] dampening
# Enable interface dampening on GigabitEthernet 1/0/1, and set the following parameters:
· Half life time to 2 seconds.
· Reuse value to 800.
· Suppression threshold to 3000.
· Maximum suppression interval to 5 seconds.
[Sysname-GigabitEthernet1/0/1] dampening 2 800 3000 5
display interface
link-delay
default
Use default to restore the default settings for an interface.
default
CAUTION: The default command might interrupt ongoing network services. Make sure you are fully aware of the impacts of this command when you use it in a live network. |
This command might fail to restore the default settings for some commands because of command dependencies or system restrictions. You can use the display this command in interface view to identify these commands, and use their undo forms or follow the command reference to restore their default settings. If your restoration attempt still fails, follow the error message instructions to solve the problem.
# Restore the default settings for GigabitEthernet 1/0/1.
[Sysname-GigabitEthernet1/0/1] default
# Restore the default settings for GigabitEthernet 1/0/1.1.
[Sysname-GigabitEthernet1/0/1.1] default
description
The description of an interface is the interface name plus Interface (for example, GigabitEthernet1/0/1 Interface).
text: Specifies the interface description, a case-sensitive string of 1 to 255 characters.
# Set the description of GigabitEthernet 1/0/1 to lan-interface.
[Sysname-GigabitEthernet1/0/1] description lan-interface
# Set the description of GigabitEthernet 1/0/1.1 to subinterface1/0/1.1.
[Sysname-GigabitEthernet1/0/1.1] description subinterface1/0/1.1
display counters
Use display counters to display interface traffic statistics.
display counters { inbound | outbound } interface [ interface-type [ interface-number ] ]
inbound: Displays inbound traffic statistics.
outbound: Displays outbound traffic statistics.
To clear the Ethernet interface traffic statistics, use the reset counters interface command.
If you do not specify an interface type, this command displays traffic statistics for all interfaces that have traffic counters.
If you specify an interface type but do not specify an interface number, this command displays traffic statistics for all interfaces of the specified type.
If you specify an interface type and number, this command displays traffic statistics for the specified interface.
# Display inbound traffic statistics for all interfaces.
<Sysname> display counters inbound interface
Interface Total (pkts) Broadcast (pkts) Multicast (pkts) Err (pkts)
GE1/0/1 100 100 0 0
GE1/0/2 Overflow Overflow Overflow Overflow
Overflow: More than 14 digits (7 digits for column "Err").
--: Not supported.
Abbreviated interface name. |
Total (pkts) |
Total number of packets received or sent through the interface. |
Broadcast (pkts) |
Total number of broadcast packets received or sent through the interface. |
Multicast (pkts) |
Total number of multicast packets received or sent through the interface. |
Err (pkts) |
Total number of error packets received or sent through the interface. |
Overflow: More than 14 digits (7 digits for column "Err") |
The command displays Overflow when any of the following conditions exist: · The data length of an Err field value is greater than 7 decimal digits. · The data length of a non-Err field value is greater than 14 decimal digits. |
--: Not supported |
The statistical item is not supported. |
display counters rate
Use display counters rate to display traffic rate statistics for interfaces in up state for the most recent statistics polling interval.
display counters rate { inbound | outbound } interface [ interface-type [ interface-number ] ]
inbound: Displays inbound traffic rate statistics.
outbound: Displays outbound traffic rate statistics.
If you do not specify an interface type, this command displays traffic rate statistics for all up interfaces that have traffic counters.
If you specify an interface type but do not specify an interface number, this command displays traffic rate statistics for all up interfaces of the specified type.
If you specify an interface type and an interface, this command displays traffic rate statistics for the specified interface.
If an interface that you specify is always down for the most recent statistics polling interval, the system prompts that the interface does not support the command.
To set the statistics polling interval, use the flow-interval command.
# Display the inbound traffic rate statistics for all interfaces.
<Sysname> display counters rate inbound interface
Usage: Bandwidth utilization in percentage
Interface Usage (%) Total (pps) Broadcast (pps) Multicast (pps)
GE1/0/1 0 0 -- --
Overflow: More than 14 digits.
--: Not supported.
Usage (%) |
Bandwidth usage (in percentage) of the interface for the last statistics polling interval. |
Total (pps) |
Average receiving or sending rate (in pps) for unicast packets for the last statistics polling interval. |
Broadcast (pps) |
Average receiving or sending rate (in pps) for broadcast packets for the last statistics polling interval. |
Multicast (pps) |
Average receiving or sending rate (in pps) for multicast packets for the last statistics polling interval. . |
Overflow: more than 14 decimal digits |
The command displays Overflow if the data length of a statistical item is greater than 14 decimal digits. |
--: not supported |
flow-interval
display ethernet statistics
Use display ethernet statistics to display the Ethernet module statistics.
display ethernet statistics slot slot-number
slot slot-number: Specifies an IRF member device by its member ID.
# Display the Ethernet module statistics for the specified slot.
<Sysname> display ethernet statistics slot 1
ETH receive packet statistics:
Totalnum : 10447 ETHIINum : 4459
SNAPNum : 0 RAWNum : 0
LLCNum : 0 UnknownNum : 0
ForwardNum : 4459 ARP : 0
MPLS : 0 ISIS : 0
ISIS2 : 0 IP : 0
IPV6 : 0
ETH receive error statistics:
NullPoint : 0 ErrIfindex : 0
ErrIfcb : 0 IfShut : 0
ErrAnalyse : 5988 ErrSrcMAC : 5988
ErrHdrLen : 0
ETH send packet statistics:
L3OutNum : 211 VLANOutNum : 0
FastOutNum : 155 L2OutNum : 0
ETH send error statistics:
MbufRelayNum : 0 NullMbuf : 0
ErrAdjFwd : 0 ErrPrepend : 0
ErrHdrLen : 0 ErrPad : 0
ErrQoSTrs : 0 ErrVLANTrs : 0
ErrEncap : 0 ErrTagVLAN : 0
IfShut : 0 IfErr : 0
Table 3 Output description
ETH receive packet statistics |
Statistics about the Ethernet packets received by the Ethernet module: · Totalnum—Total number of received packets. · ETHIINum—Number of packets encapsulated by using Ethernet II. · SNAPNum—Number of packets encapsulated by using SNAP. · RAWNum—Number of packets encapsulated by using RAW. · LLCNum—Number of packets encapsulated by using LLC. · UnknownNum—Number of packets encapsulated by using unknown methods. · ForwardNum—Number of packets forwarded at Layer 2 or sent to the CPU. · ARP—Number of ARP packets. · MPLS—Number of MPLS packets. This field is not supported in the current software version. · ISIS—Number of IS-IS packets. · ISIS2—Number of large 802.3/802.2 frames encapsulated by using IS-IS. · IP—Number of IP packets. · IPv6—Number of IPv6 packets. |
ETH receive error statistics |
Statistics about the error Ethernet packets in the inbound direction on the Ethernet module. Errors might be included in packets or occur during the receiving process. The items include: · NullPoint—Number of packets that include null pointers. · ErrIfindex—Number of packets that include incorrect interface indexes. · ErrIfcb—Number of packets that include incorrect interface control blocks. · IfShut—Number of packets that are being received when the interface is shut down. · ErrAnalyse—Number of packets that include packet parsing errors. · ErrSrcMAC—Number of packets that include incorrect source MAC addresses. · ErrHdrLen—Number of packets that include header length errors. |
ETH send packet statistics |
Statistics about the Ethernet packets sent by the Ethernet module: · L3OutNum—Number of packets sent out of Layer 3 Ethernet interfaces. · VLANOutNum—Number of packets sent out of VLAN interfaces. · FastOutNum—Number of packets fast forwarded. · L2OutNum—Number of packets sent out of Layer 2 Ethernet interfaces. |
ETH send error statistics |
Statistics about the error Ethernet packets in the outbound direction on the Ethernet module: · MbufRelayNum—Number of packets transparently sent. · NullMbuf—Number of packets with null pointers. · ErrAdjFwd—Number of packets with adjacency table errors. · ErrPrepend—Number of packets with extension errors. · ErrHdrLen—Number of packets with header length errors. · ErrPad—Number of packets with padding errors. · ErrQoSTrs—Number of packets that failed to be sent by QoS. · ErrVLANTrs—Number of packets that failed to be sent in VLANs. · ErrEncap—Number of packets that failed to be sent due to link header encapsulation failures. · ErrTagVLAN—Number of packets that failed to be sent due to VLAN tag encapsulation failures. · IfShut—Number of packets that are being sent when the interface is shut down. · IfErr—Number of packets with incorrect outgoing interfaces. |
reset ethernet statistics
display interface
Use display interface to display interface information.
display interface [ interface-type [ interface-number | interface-number.subnumber ] ] [ brief [ description | down ] ]
interface-number.subnumber: Specifies a subinterface number. The interface-number argument is an interface number. The subnumber argument is the number of a subinterface created under the interface. The value range for the subnumber argument is 1 to 4094.
description: Displays complete interface descriptions. If you do not specify this keyword, the command displays only the first 25 characters of each interface description.
down: Displays information about interfaces in down state and the causes. If you do not specify this keyword, the command displays information about interfaces in all states.
If you do not specify an interface type, this command displays information about all interfaces.
If you specify an interface type but do not specify an interface number, this command displays information about all interfaces of the specified type.
# Display information about Layer 3 interface GigabitEthernet 1/0/1.
<Sysname> display interface gigabitethernet 1/0/1
Line protocol state: DOWN
Description: GigabitEthernet1/0/1 Interface
Bandwidth: 1000000 kbps
Allow jumbo frames to pass
Broadcast max-ratio: 100%
Unknown-multicast max-ratio: 100%
Unicast max-ratio: 100%
Known unicast max-ratio: 100%
IP packet frame type: Ethernet II, hardware address: 3822-d666-bd0c
IPv6 packet frame type: Ethernet II, hardware address: 3822-d666-bd0c
Media type is optical fiber, port hardware type is 25G_BASE_SR_SFP28
Port priority: 0
Flow-control is not enabled
The Maximum Frame Length is 13312
Last link flapping: 6 hours 39 minutes 28 seconds
Current system time:2021-08-10 14:56:12
Last time when physical state changed to up:-
Last time when physical state changed to down:2021-08-10 14:55:25
Peak input rate: 0 bytes/sec, at 2021-07-07 16:07:11
Peak output rate: 0 bytes/sec, at 2021-07-07 16:07:11
Last 300 seconds input: 0 packets/sec 0 bytes/sec 0%
Last 300 seconds output: 0 packets/sec 0 bytes/sec 0%
Input (total): 0 packets, 0 bytes
0 unicasts, 0 broadcasts, 0 multicasts, - pauses
Input (normal): 0 packets, 0 bytes
Input: 0 input errors, 0 runts, 0 giants, 0 throttles
- ignored, - parity errors
Output (normal): 0 packets, 0 bytes
- lost carrier, - no carrier
# Display detailed information about Layer 2 interface GigabitEthernet 1/0/1.
Current state: DOWN
IP packet frame type: Ethernet II, hardware address: 000c-2963-b767
Bandwidth: 100000 kbps
Loopback is not set
Maximum frame length: 13312
Allow jumbo frame to pass
PVID: 1
MDI type: Automdix
Port link-type: Access
Tagged VLANs: None
UnTagged VLANs: 1
Port priority: 0
Last link flapping: 6 hours 39 minutes 25 seconds
Last clearing of counters: 14:34:09 Tue 11/07/2021
Current system time:2020-08-10 14:58:27
Last time when physical state changed to down:2021-08-10 14:57:58
Peak input rate: 0 bytes/sec, at 2021-07-17 22:06:19
Peak output rate: 0 bytes/sec, at 2021-07-17 22:06:19
Last 300 seconds input: 0 packets/sec 0 bytes/sec -%
Last 300 seconds output: 0 packets/sec 0 bytes/sec -%
0 CRC, 0 frame, 0 overruns, 0 aborts
0 ignored, 0 parity errors
Output: 0 output errors, 0 underruns, 0 buffer failures
0 lost carrier, 0 no carrier
Current state |
Physical link state of the interface: · Administratively DOWN—The interface has been shut down by using the shutdown command. · Administratively DOWN(Global)—The interface has been shut down by using the shutdown all-physical-interfaces command in system view. · DOWN—The interface is administratively up, but its physical state is down (possibly because no physical link exists or the link has failed). · DOWN ( Link-Aggregation interface down )—The aggregate interface to which the interface belongs has been shut down by using the shutdown command. · DOWN (Monitor-Link uplink down )—The interface has been shut down by Monitor Link. · Link-Flap DOWN—The interface has been shut down by the link flapping protection feature. · mac-address moving down—The interface has been shut down by the MAC address move suppression feature. · MAD ShutDown—The interface has been shut down by IRF MAD. This state occurs if the interface is on an IRF fabric placed in Recovery state after an IRF split. · Storm-Constrain—The interface has been shut down because the storm control feature detected that multicast traffic or broadcast traffic exceeded the upper threshold. · STP DOWN—The interface has been shut down by the BPDU guard feature. · M-LAG MAD Shutdown—The interface was set to the M-LAG MAD DOWN state when the M-LAG system split. · UP—The interface is both administratively and physically up. |
Line protocol state |
Data link layer state of the interface. The state is determined through automatic parameter negotiation at the data link layer. · UP—The data link layer protocol is up. · UP (spoofing)—The data link layer protocol is up, but the link is an on-demand link or does not exist. This attribute is typical of null interfaces and loopback interfaces. · DOWN—The data link layer protocol is down. · DOWN (protocols)—The data link layer has been shut down by protocols included in the parentheses. Available protocols include: ¡ DLDP—Shuts down the data link layer when it detects that the link is unidirectional. ¡ OAM—Shuts down the data link layer when it detects a remote link failure. ¡ LAGG—Shuts down the data link layer when it detects that the aggregate interface does not have Selected ports. ¡ BFD—Shuts down the data link layer when it detects a link failure. ¡ MACSEC—Shuts down the data link layer when it fails to negotiate the encryption parameters. |
Bandwidth |
Expected bandwidth of the interface. |
Maximum transmission unit |
MTU of the interface. |
Internet protocol processing: Disabled |
The interface is not assigned an IP address and cannot process IP packets. |
Internet address |
IP address of the interface. The primary attribute indicates that the address is the primary IP address. |
Internet address: ip-address/mask-length (Type) |
IP address of the interface and type of the address in parentheses. Possible IP address types include: · Primary—Manually configured primary IP address. · Sub—Manually configured secondary IP address. If the interface has both primary and secondary IP addresses, the primary IP address is displayed. If the interface has only secondary IP addresses, the lowest secondary IP address is displayed. · DHCP-allocated—DHCP allocated IP address. For more information, see DHCP client configuration in Layer 3—IP Services Configuration Guide. · Unnumbered—IP address borrowed from another interface. |
IP packet frame type |
IPv4 packet framing format. |
hardware address |
MAC address of the interface. |
IPv6 packet frame type |
IPv6 packet framing format. |
Port priority |
Port priority of the interface. |
Loopback is set internal |
An internal loopback test is running on the interface. This field depends on your configuration. |
Loopback is not set |
No loopback test is running on the interface. This field depends on your configuration. |
10Mbps-speed mode |
The interface is operating at 10 Mbps. This field depends on your configuration and the link parameter negotiation result. |
100Mbps-speed mode |
The interface is operating at 100 Mbps. This field depends on your configuration and the link parameter negotiation result. |
1000Mbps-speed mode |
The interface is operating at 1000 Mbps. This field depends on your configuration and the link parameter negotiation result. |
10Gbps-speed mode |
The interface is operating at 10 Gbps. This field depends on your configuration and the link parameter negotiation result. |
25Gbps-speed mode |
The interface is operating at 25 Gbps. This field depends on your configuration and the link parameter negotiation result. |
40Gbps-speed mode |
The interface is operating at 40 Gbps. This field depends on your configuration and the link parameter negotiation result. |
100Gbps-speed mode |
The interface is operating at 100 Gbps. This field depends on your configuration and the link parameter negotiation result. |
Unknown-speed mode |
The speed of the interface is unknown because the speed negotiation fails or the interface is physically disconnected. |
half-duplex mode |
The interface is operating in half duplex mode. This field depends on your configuration and the link parameter negotiation result. |
full-duplex mode |
The interface is operating in full duplex mode. This field depends on your configuration and the link parameter negotiation result. |
unknown-duplex mode |
The duplex mode of the interface is unknown because the duplex mode negotiation fails or the interface is physically disconnected. |
Link speed type is autonegotiation |
The interface is configured with the speed auto command. |
Link speed type is force link |
The interface is manually configured with a speed (for example, 1000 Mbps) by using the speed command. |
link duplex type is autonegotiation |
The interface is configured with the duplex auto command. |
link duplex type is force link |
The interface is manually configured with a duplex mode (for example, half or full) by using the duplex command. |
Flow-control is not enabled |
Generic flow control is disabled on the interface. This field depends on your configuration and the link parameter negotiation result. |
Maximum frame length |
Maximum length of Ethernet frames allowed to pass through the interface. |
Allow jumbo frame to pass |
The interface allows jumbo frames to pass through. |
Broadcast max- |
Broadcast storm suppression threshold. |
Unknown-multicast max- |
Multicast storm suppression threshold. |
Unicast max- |
This field is not supported in the current software version. Unknown unicast storm suppression threshold. |
Known-unicast max- |
This field is not supported in the current software version.Known unicast storm suppression threshold. |
PVID |
Port VLAN ID (PVID) of the interface. |
MDI type |
MDIX mode of the interface: · automdix. · mdi. · mdix. |
Dampening enabled |
Damping is enabled on the interface. |
Penalty |
Penalty value. |
Ceiling |
The penalty stops increasing when it reaches the ceiling. |
Reuse |
Reuse threshold. |
Suppress |
Suppression threshold. |
Half-life |
Amount of time after which a penalty is decreased, in seconds. |
Max-suppress-time |
Maximum amount of time the interface can be dampened, in seconds. |
Flap count |
Number of flaps (up/down events) on the interface. |
Port link-type |
Link type of the interface: · access. · trunk. · hybrid. |
Tagged VLANs |
VLANs for which the interface sends packets without removing VLAN tags. |
Untagged VLANs |
VLANs for which the interface sends packets after removing VLAN tags. |
VLAN Passing |
VLANs whose packets can be forwarded by the port. The VLANs must have been created. |
VLAN permitted |
VLANs whose packets are permitted by the port. |
Trunk port encapsulation |
Encapsulation protocol type for the trunk port. |
Last link flapping |
The amount of time that has elapsed since the most recent physical state change of the interface. This field displays Never if the interface has been physically down since device startup. |
Last clearing of counters |
Time when the reset counters interface command was last used to clear the interface statistics. This field displays Never if the reset counters interface command has never been used on the interface since device startup. |
Current system time |
Current system time in the YYYY/MM/DD HH:MM:SS format. If the time zone is configured, this field is in the YYYY/MM/DD HH:MM:SS zone-name±HH:MM:SS format, where the zone-name argument is the local time zone. |
Last time when physical state changed to up |
Last time when the physical state of the interface changed to up. If the time zone is configured, this field is in the YYYY/MM/DD HH:MM:SS zone-name±HH:MM:SS format, where the zone-name argument is the local time zone. A hyphen (-) indicates that the physical state of the interface has never changed. |
Last time when physical state changed to down |
Last time when the physical state of the interface changed to down. If the time zone is configured, this field is in the YYYY/MM/DD HH:MM:SS zone-name±HH:MM:SS format, where the zone-name argument is the local time zone. A hyphen (-) indicates that the physical state of the interface has never changed. |
Last interval seconds input: 0 packets/sec 0 bytes/sec 0% Last interval seconds output: 0 packets/sec 0 bytes/sec 0% |
Average inbound or outbound traffic rate (in pps and Bps) in the last statistics polling interval, and the ratio of the actual rate to the interface bandwidth. To set the statistics polling interval (interval), use the flow-interval command. A hyphen (-) indicates that the statistical item is not supported. |
Input(total): 0 packets, 0 bytes 0 unicasts, 0 broadcasts, 0 multicasts, 0 pauses |
The two fields on the first line represent the inbound traffic statistics (in packets and bytes) for the interface. All inbound normal packets, abnormal packets, and normal pause frames were counted. The four fields on the second line represent: · Number of inbound unicast packets. · Number of inbound broadcasts. · Number of inbound multicasts. · Number of inbound pause frames. Layer 3 Ethernet interfaces do not support collecting statistics of Layer 3 multicast packets in the current software version. |
Input(normal): 0 packets, 0 bytes 0 unicasts, 0 broadcasts, 0 multicasts, 0 pauses |
The two fields on the first line represent the inbound normal traffic and pause frame statistics (in packets and bytes) for the interface. The four fields on the second line represent: · Number of inbound normal unicast packets. · Number of inbound normal broadcasts. · Number of inbound normal multicasts. · Number of inbound normal pause frames. Layer 3 Ethernet interfaces do not support collecting statistics of Layer 3 multicast packets in the current software version. |
input errors |
Statistics of incoming error packets. |
runts |
Number of inbound frames meeting the following conditions: · Shorter than 64 bytes. · In correct format. · Containing valid CRCs. |
giants |
Number of inbound giants. Giants refer to frames larger than the maximum frame length supported on the interface. For an Ethernet interface that does not permit jumbo frames, the maximum frame length is as follows: · 1532 bytes (without VLAN tags). · 1536 bytes (with VLAN tags). For an Ethernet interface that permits jumbo frames, the maximum Ethernet frame length is set when you configure jumbo frame support on the interface. |
throttles |
Number of inbound frames that had a non-integer number of bytes. |
CRC |
Total number of inbound frames that had a normal length, but contained CRC errors. |
frame |
Total number of inbound frames that contained CRC errors and a non-integer number of bytes. |
overruns |
Number of packets dropped because the input rate of the port exceeded the queuing capability. |
aborts |
Total number of illegal inbound packets: · Fragment frames—CRC error frames shorter than 64 bytes. The length (in bytes) can be an integral or non-integral value. · Jabber frames—CRC error frames greater than the maximum frame length supported on the Ethernet interface (with an integral or non-integral length). ¡ For an Ethernet interface that does not permit jumbo frames, the maximum frame length is 1532 bytes (without VLAN tags) or 1536 bytes (with VLAN tags). ¡ For an Ethernet interface that permits jumbo frames, the maximum Ethernet frame length is set when you configure jumbo frame support on the interface. · Symbol error frames—Frames that contained a minimum of one undefined symbol. · Unknown operation code frames—Non-pause MAC control frames. · Length error frames—Frames whose 802.3 length fields did not match the actual frame length (46 to 1500 bytes). |
ignored |
Number of inbound frames dropped because the receiving buffer of the port ran low. |
parity errors |
Total number of frames with parity errors. |
Output(total): 0 packets, 0 bytes 0 unicasts, 0 broadcasts, 0 multicasts, 0 pauses |
The two fields on the first line represent the outbound traffic statistics (in packets and bytes) for the interface. All outbound normal packets, abnormal packets, and normal pause frames were counted. The four fields on the second line represent: · Number of outbound unicast packets. · Number of outbound broadcasts. · Number of outbound multicasts. · Number of outbound pause frames. Layer 3 Ethernet interfaces do not support collecting statistics of Layer 3 multicast packets in the current software version. |
Output(normal): 0 packets, 0 bytes 0 unicasts, 0 broadcasts, 0 multicasts, 0 pauses |
The two fields on the first line represent the outbound normal traffic and pause frame statistics (in packets and bytes) for the interface. The four fields on the second line represent: · Number of outbound normal unicast packets. · Number of outbound normal broadcasts. · Number of outbound normal multicasts. · Number of outbound normal pause frames. Layer 3 Ethernet interfaces do not support collecting statistics of Layer 3 multicast packets in the current software version. |
output errors |
Number of outbound packets with errors. |
underruns |
Number of packets dropped because the output rate of the interface exceeded the output queuing capability. This is a low-probability hardware anomaly. |
buffer failures |
Number of packets dropped because the transmitting buffer of the interface ran low. |
aborts |
Number of packets that failed to be transmitted, for example, because of Ethernet collisions. |
deferred |
Number of frames that the interface deferred to transmit because of detected collisions. |
collisions |
Number of frames that the interface stopped transmitting because Ethernet collisions were detected during transmission. |
late collisions |
Number of frames that the interface deferred to transmit after transmitting their first 512 bits because of detected collisions. |
lost carrier |
Number of carrier losses during transmission. This counter increases by one when a carrier is lost, and applies to serial WAN interfaces. |
no carrier |
Number of times that the port failed to detect the carrier when attempting to send frames. This counter increases by one when a port failed to detect the carrier, and applies to serial WAN interfaces. |
Peak input rate |
Peak rate of inbound traffic in Bps, and the time when the peak inbound traffic rate occurred. |
Peak output rate |
Peak rate of outbound traffic in Bps, and the time when the peak outbound traffic rate occurred. |
IPv4 traffic statistics |
IPv4 packet statistics. IPv4 packet statistics do not count dropped packets. |
IPv6 traffic statistics |
IPv6 packet statistics. IPv6 packet statistics do not count dropped packets. |
# Display brief information about all interfaces.
Protocol: (s) – spoofing
GE1/0/1 DOWN DOWN --
Loop0 UP UP(s) 2.2.2.9
NULL0 UP UP(s) --
Vlan1 UP UP --
Vlan999 UP UP 192.168.1.42
Speed: (a) - auto
Interface Link Speed Duplex Type PVID Description
GE1/0/2 DOWN auto A A 1
GE1/0/3 UP 1G(a) F(a) A 1 aaaaaaaaaaaaaaaaaaaaaaaaa
# Display brief information about GigabitEthernet 1/0/3, including the complete description of the interface.
<Sysname> display interface gigabitethernet 1/0/3 brief description
Speed: (a) - auto
GE1/0/3 UP 1G(a) F(a) A 1 aaaaaaaaaaaaaaaaaaaaaaaaaaa
aaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaa
# Display information about interfaces in DOWN state and the causes.
Interface Link Cause
GE1/0/1 DOWN Not connected
Vlan2 DOWN Not connected
GE1/0/2 DOWN Not connected
Brief information on interfaces in route mode: |
Brief information about Layer 3 interfaces. |
Interface name. |
Link |
Physical link state of the interface: · UP—The interface is physically up. · DOWN—The interface is physically down. · ADM—The interface has been shut down by using the shutdown command. To restore the physical state of the interface, use the undo shutdown command. |
Protocol |
Data link layer protocol state of the interface: · UP—The data link layer protocol of the interface is up. · DOWN—The data link layer protocol of the interface is down. · UP(s)—The data link layer protocol of the interface is up, but the link is an on-demand link or does not exist. The (s) attribute represents the spoofing flag. This value is typical of null interfaces and loopback interfaces. |
Primary IP |
Primary IP address of the interface. This field displays two hyphens (--) if the interface does not have an IP address. |
Description of the interface. |
Brief information of interfaces in bridge mode: |
Brief information about Layer 2 interfaces. |
Type: A - access; T - trunk; H – hybrid |
Link type options for interfaces. |
Speed |
Speed of the interface, in bps. This field displays the (a) flag next to the speed if the speed is automatically negotiated. This field displays auto if the interface is configured to autonegotiate its speed but the autonegotiation has not started. |
Duplex |
Duplex mode of the interface: · A—Autonegotiation. The interface is configured to autonegotiate its duplex mode but the autonegotiation has not started. · F—Full duplex. · F(a)—Autonegotiated full duplex. · H—Half duplex. · H(a)—Autonegotiated half duplex. |
Type |
Link type of the interface: · A—Access. · H—Hybrid. · T—Trunk. |
PVID |
Port VLAN ID. |
Cause |
Cause for the physical link state of an interface to be DOWN: · Administratively—The interface has been manually shut down by using the shutdown command. To restore the physical state of the interface, use the undo shutdown command. · DOWN ( Link-Aggregation interface down )—The interface is a member port of an aggregate interface, and the aggregate interface is down. · DOWN (Loopback detection down)—The loopback detection module has detected loops. · DOWN ( Monitor-Link uplink down )—The monitor link module has detected that the uplink is down. · MAD ShutDown—The interface is on an IRF fabric placed by IRF MAD in Recovery state after an IRF split. · Not connected—No physical connection exists (possibly because the network cable is disconnected or faulty). · Storm-Constrain—The storm control feature has detected that multicast traffic or broadcast traffic exceeded the upper threshold. · STP DOWN—The interface has been shut down by the BPDU guard feature. · Port Security Disabled—The interface has been shut down by the intrusion detection mechanism because the interface received illegal packets. |
flow-interval
display interface link-info
Use display interface link-info to display the status and packet statistics of interfaces.
display interface link-info [ main ]
main: Specifies all interfaces except subinterfaces. If you do not specify this keyword, this command displays status and packet statistics of all interfaces.
# Display status and statistics of all interfaces.
<Sysname> display interface link-info
Protocol: (s) - spoofing
Interface Link Protocol InUsage OutUsage InErrs OutErrs
GE1/0/1 UP UP 10% 0% 0 0
NULL0 UP UP(s) 0% 0% 0 0
Overflow: More than 7 digits.
--: Not supported.
Table 6 Command output
Link: ADM - administratively down; Stby - standby |
Physical link state of the interface: · ADM—The interface has been shut down by using the shutdown command. To restore the physical state of the interface, use the undo shutdown command. · Stby—The interface is a backup interface in standby state. |
Protocol: (s) – spoofing |
The data link layer protocol of the interface is up, but the link is an on-demand link or does not exist. The (s) attribute represents the spoofing flag. This value is typical of null interfaces, loopback interfaces, and InLoopback interfaces. |
Link |
Physical link state of the interface: · UP—The interface is physically up. · DOWN—The interface is physically down. · ADM—The interface has been shut down by using the shutdown command. To restore the physical state of the interface, use the undo shutdown command. · Stby—The interface is a backup interface in standby state. |
Protocol |
Data link layer protocol state of the interface: · UP—The data link layer protocol of the interface is up. · DOWN—The data link layer protocol of the interface is down. · UP(s)—The data link layer protocol of the interface is up, but the link is an on-demand link or does not exist. The (s) attribute represents the spoofing flag. This value is typical of null interfaces, loopback interfaces, and InLoopback interfaces. |
InUsage |
Inbound bandwidth usage within the most recent statistics polling interval. It is calculated by this formula: Average inbound speed of the interface within the most recent statistics polling interval/interface bandwidth. To set the statistics polling interval, use the flow-interval command. |
OutUsage |
Outbound bandwidth usage within the most recent statistics polling interval. It is calculated by this formula: Average outbound speed of the interface within the most recent statistics polling interval/interface bandwidth. To set the statistics polling interval, use the flow-interval command. |
InErrs |
Number of error packets received. |
OutErrs |
Number of error packets sent. |
Overflow: More than 7 digits. |
The data length of a statistical item value is greater than 7 decimal digits. |
--: Not supported. |
A hyphen (-) indicates that the corresponding statistical item is not supported. |
flow-interval
display interface main
Use display interface main to display operating status and information of all interfaces except subinterfaces.
display interface [ interface-type ] [ brief [ description | down ] ] main
interface-type: Specifies an interface type. If you do not specify this argument, the command displays information about interfaces of all types.
# Display operating status and information of all interfaces except subinterfaces.
<Sysname> display interface main
Current state: UP
Line protocol state: UP
Known-unicast max-ratio: 100%
IP packet frame type: Ethernet II, hardware address: 0004-0004-000e
IPv6 packet frame type: Ethernet II, hardware address: 0004-0004-000e
Port priority: 0
Last link flapping: 0 hours 0 minutes 52 seconds
Current system time:2021-04-11 10:20:24
Last time when physical state changed to down:2021-04-11 09:11:09
Peak input rate: 0 bytes/sec, at 00-00-00 00:00:00
Peak output rate: 0 bytes/sec, at 00-00-00 00:00:00
# Display brief information of all interfaces except subinterfaces.
<Sysname> display interface brief main
NULL0 UP UP(s) --
Vlan1 UP DOWN --
Speed: (a) - auto
# Display brief information about all interfaces except subinterfaces, including the complete interface descriptions.
<Sysname> display interface brief description main
Speed: (a) - auto
GE1/0/3 UP auto F(a) A 1 aaaaaaaaaaaaaaaaaaaaaaaaaaaaa
# Display information about interfaces except subinterfaces in DOWN state and the causes.
<Sysname> display interface brief down main
For description on the display interface main command output, see Table 4 and Table 5.
display link-flap protection
Use display link-flap protection to display information about link flapping protection on an interface.
display link-flap protection [ interface interface-type [ interface-number ] ]
interface-type: Specifies an interface type. If you do not specify an interface type, the command displays information about link flapping protection on all interfaces.
interface-number: Specifies an interface number. If you do not specify an interface number, the command displays information about link flapping protection on all interfaces of the specified type.
# Display information about link flapping protection on all interfaces.
<Sysname> display link-flap protection
Link-flap protection: Enabled
Interface Link-flap Status Interval(L1/L2) Threshold(L1/L2)
GE1/0/1 Enabled Down 10/5 5/60
GE1/0/2 Disabled N/A --/-- --/--
Link-flap protection |
Status of global link flapping protection: · Enabled—Link flapping protection is enabled globally. · Disabled—Link flapping protection is disabled globally. |
Link-flap |
Status of link flapping protection on an interface: · Enabled—Link flapping protection is enabled on an interface. · Disabled—Link flapping protection is disabled on an interface. |
Status |
Status of an interface: · Down—The interface has been shut down by the link flapping protection feature. · N/A—The interface status is not affected by the link flapping protection feature. |
Interval(L1/L2) |
Level-1/Level-2 link flapping detection interval for an interface. |
Threshold(L1/L2) |
Level-1/Level-2 link flapping detection threshold for an interface. |
Use display link-state-change statistics interface to display the physical link state change statistics of interfaces.
display link-state-change statistics interface [ interface-type [ interface-number ] ]
If you do not specify an interface type, this command displays the link state change statistics for all interfaces.
If you specify an interface type but do not specify an interface number, this command displays the link state change statistics for all interfaces of the specified type.
# Display the link state change statistics of all interfaces.
<Sysname> display link-state-change statistics interface
Interface Change-times Last-change-time Reset link-state time
Link-flap-begin Link-flap-end
GE1/0/1 0 Never Never
Never Never
Table 8 Command output
Change-times |
Number of physical state changes. |
Last-change-time |
Last time when the physical state changed. |
Reset link-state time |
Time when the physical link state change statistics were cleared. |
Link-flap-begin |
Last time when a physical link state flapping began. If no link state flapping has occurred, this field displays Never. |
Link-flap-end |
Last time when a physical link state flapping ended. If no link state flapping has occurred, this field displays Never. |
display packet-drop
Use display packet-drop to display information about packets dropped on an interface.
display packet-drop { interface [ interface-type [ interface-number ] ] | summary }
summary: Displays the summary of dropped packets on only interfaces that support this command.
If you do not specify an interface type, this command displays information about dropped packets on only interfaces that support this command on the device.
If you specify an interface type but do not specify an interface number, this command displays information about dropped packets on only interfaces of the specified type that support this command.
# Display information about dropped packets on GigabitEthernet 1/0/1.
<Sysname> display packet-drop interface gigabitethernet 1/0/1
GigabitEthernet1/0/1:
Packets dropped due to full GBP or insufficient bandwidth: 301
Packets dropped due to Egress Filter Processor (EFP): 0
Packets dropped due to Fast Filter Processor (FFP): 261
Packets dropped due to STP non-forwarding state: 0
Packets of ECN marked: 0
Packets of WRED droped: 0
# Display the summary of dropped packets on only interfaces that support this command.
<Sysname> display packet-drop summary
All interfaces:
Table 9 Command output
Packets dropped due to full GBP or insufficient bandwidth |
Packets that are dropped because the buffer is used up or the bandwidth is insufficient. |
Packets dropped due to Fast Filter Processor (FFP) |
Packets that are filtered out. |
Packets dropped due to Egress Filter Processor (EFP) |
Packets that are dropped due to EFP in the outbound direction. |
Packets dropped due to STP non-forwarding state |
Packets that are dropped because STP is in the non-forwarding state. |
Packets of ECN marked |
Packets with the ECN field set to 11 because WRED queue thresholds are reached. For more information about WRED and ECN, see ACL and QoS Configuration Guide. |
Packets of WRED dropped |
Packets that are dropped because the WRED queue thresholds are reached. |
display port-speed-mode
Use display port-speed-mode to display the port speed mode for expansion slots.
NOTE: This command is supported only on the S5590-HI switch series. |
# Display the port speed mode for expansion slots.
<Sysname> display port-speed-mode
Port speed mode :
Current : 0
After reboot: 0
Table 10 Command output
Port speed mode |
Port speed mode for expansion slots on the specified IRF member device. |
Current |
Current port speed mode for expansion slots: · 0 · 1 · 2 |
After reboot |
Port speed mode for expansion slots after the device is restarted: · 0 · 1 · 2 |
duplex
Use duplex to set the duplex mode for an Ethernet interface.
Use undo duplex to restore the default.
duplex { auto | full | half }
undo duplex
Ethernet interfaces operate in autonegotiation mode.
auto: Configures the interface to autonegotiate the duplex mode with the peer.
full: Configures the interface to operate in full duplex mode. In this mode, the interface can receive and transmit packets simultaneously.
half: Configures the interface to operate in half duplex mode. In this mode, the interface can only receive or transmit packets at a given time. Fiber ports, 1000-Mbps Ethernet interfaces, and 10000-Mbps Ethernet interfaces do not support this keyword.
For Ethernet interfaces connected to the same physical link to operate correctly, you must configure the same duplex mode for them.
# Configure GigabitEthernet 1/0/1 to operate in full duplex mode.
[Sysname-GigabitEthernet1/0/1] duplex full
eee enable
IMPORTANT: Fiber ports do not support this command. |
Use eee enable to enable Energy Efficient Ethernet (EEE) on an interface.
Use undo eee enable to disable EEE on an interface.
eee enable
undo eee enable
EEE is disabled.
With EEE enabled, a link-up interface enters low power state if it has not received any packet for a period of time. The time period depends on the chip specifications and is not configurable. When a packet arrives later, the interface restores to the normal state.
# Enable EEE on GigabitEthernet 1/0/1.
[Sysname-GigabitEthernet1/0/1] eee enable
flow-control
Use flow-control to enable TxRx-mode generic flow control on an Ethernet interface.
Use undo flow-control to disable TxRx-mode generic flow control on the Ethernet interface.
flow-control
undo flow-control
TxRx-mode generic flow control is disabled on an Ethernet interface.
With TxRx-mode generic flow control configured, an interface can both send and receive flow control frames:
· When congested, the interface sends a flow control frame to its peer.
· Upon receiving a flow control frame from the peer, the interface suspends sending packets.
To implement flow control on a link, enable generic flow control at both ends of the link.
# Enable TxRx-mode generic flow control on GigabitEthernet 1/0/1.
[Sysname-GigabitEthernet1/0/1] flow-control
flow-control receive enable
Use flow-control receive enable to enable Rx-mode generic flow control on an Ethernet port.
Use undo flow-control to disable Rx-mode generic flow control on an Ethernet port.
undo flow-control
Rx-mode generic flow control is disabled on Ethernet interfaces.
With Rx-mode flow control enabled, an interface can receive but cannot send flow control frames.
· When the interface receives a flow control frame from its peer, it suspends sending packets to the peer.
· When traffic congestion occurs on the interface, it cannot send flow control frames to the peer.
To handle unidirectional traffic congestion on a link, configure the flow-control receive enable command at one end, and the flow-control command at the other. To enable both ends of the link to handle traffic congestion, configure the flow-control command at both ends.
# Enable Rx-mode generic flow control on GigabitEthernet 1/0/1.
[Sysname-gigabitethernet 1/0/1] flow-control receive enable
flow-control
flow-interval
Use flow-interval to set the statistics polling interval.
Use undo flow-interval to restore the default.
flow-interval interval
undo flow-interval
The statistics polling interval is 300 seconds.
interval: Sets the statistics polling interval in seconds. The interval is in the range of 1 to 300 and must be a multiple of 1.
# Set the statistics polling interval to 100 seconds on GigabitEthernet 1/0/1.
[Sysname-GigabitEthernet1/0/1] flow-interval 100
ifmonitor crc-error
Use ifmonitor crc-error to configure global CRC error packet alarm parameters.
Use undo ifmonitor crc-error to restore the default.
ifmonitor crc-error slot slot-number high-threshold high-value low-threshold low-value interval interval [ down-auto-recovery | shutdown ]
undo ifmonitor crc-error slot slot-number
The upper threshold is 1000, the lower threshold is 100, and the statistics collection and comparison interval is 10 seconds for CRC error packet alarms.
high-threshold high-value: Specifies the upper threshold for CRC error packet alarms, in the range of 1 to 4294967295 packets.
low-threshold low-value: Specifies the lower threshold for CRC error packet alarms, in the range of 1 to 4294967295 packets.
interval interval: Specifies the statistics collection and comparison interval for CRC error packets, in the range of 1 to 65535 seconds.
down-auto-recovery: Shuts down an interface when the number of incoming CRC error packets on the interface exceeds the upper threshold. Then, the interface stops forwarding all packets. After the port recovery time set by the shutdown-interval crc-error command, the port automatically restores to its actual physical state. If you do not specify this keyword, an upper threshold exceeding alarm is generated and the interface enters alarm state when the number of incoming CRC error packets exceeds the upper threshold on the interface.
shutdown: Shuts down an interface when the number of incoming CRC error packets on the interface exceeds the upper threshold. Then, the interface stops forwarding all packets. To recover the interface, execute the undo shutdown command on the interface. If you do not specify this keyword, an upper threshold exceeding alarm is generated and the interface enters the alarm state when the number of incoming CRC error packets exceeds the upper threshold on the interface, but the interface will not be shut down. If you specify this keyword when the upper threshold has been exceeded on an interface, the interface will be shut down.
With the CRC error packet alarm function enabled, when the number of incoming CRC error packets on an interface in normal state within the specified interval exceeds the upper threshold, the interface generates an upper threshold exceeding alarm and enters the alarm state. When the number of incoming CRC error packets on an interface in the alarm state within the specified interval drops below the lower threshold, the interface generates a recovery alarm and restores to the normal state.
You can configure the CRC error packet alarm parameters in system view and interface view.
· The configuration in system view takes effect on all interfaces of the specified slot. The configuration in interface view takes effect only on the current interface.
· For an interface, the configuration in interface view takes priority, and the configuration in system view is used only when no configuration is made in interface view.
When you execute this command multiple times, the most recent configuration takes effect.
# Set the upper threshold to 5000, lower threshold to 400, and statistics collection and comparison interval to 6 seconds for CRC error packet alarms.
[Sysname] ifmonitor crc-error slot 1 high-threshold 5000 low-threshold 400 interval 6
ifmonitor input-error
Use ifmonitor input-error to configure global input error packet alarm parameters.
Use undo ifmonitor input-error to restore the default.
ifmonitor input-error slot slot-number high-threshold high-value low-threshold low-value interval interval [ shutdown ]
undo ifmonitor input-error slot slot-number
The upper threshold is 1000, the lower threshold is 100, and the statistics collection and comparison interval is 10 seconds for input error packet alarms.
high-threshold high-value: Specifies the upper threshold for input error packet alarms, in the range of 1 to 4294967295 packets.
low-threshold low-value: Specifies the lower threshold for input error packet alarms, in the range of 1 to 4294967295 packets.
interval interval: Specifies the statistics collection and comparison interval for input error packets, in the range of 1 to 65535 seconds.
shutdown: Shuts down an interface when the number of input error packets on the interface exceeds the upper threshold. Then, the interface stops forwarding all packets. To recover the interface, execute the undo shutdown command on the interface. If you do not specify this keyword, an upper threshold exceeding alarm is generated and the interface enters the alarm state when the number of input error packets exceeds the upper threshold on the interface, but the interface will not be shut down. If you specify this keyword when the upper threshold has been exceeded on an interface, the interface will be shut down.
With the input error packet alarm function enabled, when the number of input error packets on an interface in normal state within the specified interval exceeds the upper threshold, the interface generates an upper threshold exceeding alarm and enters the alarm state. When the number of input error packets on an interface in the alarm state within the specified interval drops below the lower threshold, the interface generates a recovery alarm and restores to the normal state.
You can configure the input error packet alarm parameters in system view and interface view.
# Set the upper threshold to 5000, lower threshold to 400, and statistics collection and comparison interval to 6 seconds for input error packet alarms.
[Sysname] ifmonitor input-error slot 1 high-threshold 5000 low-threshold 400 interval 6
snmp-agent trap enable ifmonitor
ifmonitor input-usage
Use ifmonitor input-usage to configure global input bandwidth usage alarm parameters.
Use undo ifmonitor input-usage to restore the default.
ifmonitor input-usage slot slot-number high-threshold high-value low-threshold low-value
undo ifmonitor input-usage slot slot-number
The upper threshold is 90, and the lower threshold is 80.
high-threshold high-value: Specifies the upper threshold for input bandwidth usage alarms, in the range of 1 to 100.
low-threshold low-value: Specifies the lower threshold for input bandwidth usage alarms, in the range of 1 to 100.
With the input bandwidth usage alarm function enabled, when the input bandwidth usage on an interface in normal state within the most recent statistics polling interval exceeds the upper threshold, the interface generates an upper threshold exceeding alarm and enters the alarm state. When the input bandwidth usage on an interface in the alarm state within the most recent statistics polling interval drops below the lower threshold, the interface generates a recovery alarm and restores to the normal state.
You can use the flow-interval command to set the statistics polling interval.
You can configure the input bandwidth usage alarm parameters in system view and interface view.
For this command to take effect, you must use the snmp-agent trap enable ifmonitor command to enable the input bandwidth usage alarm function.
# Set the upper threshold to 95 and lower threshold to 80 for input bandwidth usage alarms.
[Sysname] ifmonitor input-usage slot 1 high-threshold 95 low-threshold 80
flow-interval
ifmonitor output-error
Use ifmonitor output-error to configure global output error packet alarm parameters.
Use undo ifmonitor output-error to restore the default.
ifmonitor output-error slot slot-number high-threshold high-value low-threshold low-value interval interval [ shutdown ]
undo ifmonitor output-error slot slot-number
The upper threshold is 1000, the lower threshold is 100, and the statistics collection and comparison interval is 10 seconds for output error packet alarms.
high-threshold high-value: Specifies the upper threshold for output error packet alarms, in the range of 1 to 4294967295 packets.
low-threshold low-value: Specifies the lower threshold for output error packet alarms, in the range of 1 to 4294967295 packets.
interval interval: Specifies the statistics collection and comparison interval for output error packets, in the range of 1 to 65535 seconds.
shutdown: Shuts down an interface when the number of output error packets on the interface exceeds the upper threshold. Then, the interface stops forwarding all packets. To recover the interface, execute the undo shutdown command on the interface. If you do not specify this keyword, an upper threshold exceeding alarm is generated and the interface enters the alarm state when the number of output error packets exceeds the upper threshold on the interface, but the interface will not be shut down. If you specify this keyword when the upper threshold has been exceeded on an interface, the interface will be shut down.
With the output error packet alarm function enabled, when the number of output error packets on an interface in normal state within the specified interval exceeds the upper threshold, the interface generates an upper threshold exceeding alarm and enters the alarm state. When the number of output error packets on an interface in the alarm state within the specified interval drops below the lower threshold, the interface generates a recovery alarm and restores to the normal state.
You can configure the output error packet alarm parameters in system view and interface view.
# Set the upper threshold to 5000, lower threshold to 400, and statistics collection and comparison interval to 6 seconds for output error packet alarms.
[Sysname] ifmonitor output-error slot 1 high-threshold 5000 low-threshold 400 interval 6
ifmonitor output-usage
Use ifmonitor output-usage to configure global output bandwidth usage alarm parameters.
Use undo ifmonitor output-usage to restore the default.
ifmonitor output-usage slot slot-number high-threshold high-value low-threshold low-value
undo ifmonitor output-usage slot slot-number
high-threshold high-value: Specifies the upper threshold for output bandwidth usage alarms, in the range of 1 to 100.
low-threshold low-value: Specifies the lower threshold for output bandwidth usage alarms, in the range of 1 to 100.
With the output bandwidth usage alarm function enabled, when the output bandwidth usage on an interface in normal state within the most recent statistics polling interval exceeds the upper threshold, the interface generates an upper threshold exceeding alarm and enters the alarm state. When the output bandwidth usage on an interface in the alarm state within the most recent statistics polling interval drops below the lower threshold, the interface generates a recovery alarm and restores to the normal state.
You can configure the output bandwidth usage alarm parameters in system view and interface view.
For this command to take effect, you must use the snmp-agent trap enable ifmonitor command to enable the output bandwidth usage alarm function.
# Set the upper threshold to 80 and lower threshold to 60 for output bandwidth usage alarms.
[Sysname] ifmonitor output-usage slot 1 high-threshold 80 low-threshold 60
flow-interval
ifmonitor rx-pause
Use ifmonitor rx-pause to configure global received pause frame alarm parameters.
Use undo ifmonitor rx-pause to restore the default.
ifmonitor rx-pause slot slot-number high-threshold high-value low-threshold low-value interval interval
undo ifmonitor rx-pause slot slot-number
The upper threshold is 500, the lower threshold is 100, and the statistics collection and comparison interval is 10 seconds for received pause frame alarms.
high-threshold high-value: Specifies the upper threshold for received pause frame alarms, in the range of 1 to 4294967295 packets.
low-threshold low-value: Specifies the lower threshold for received pause frame alarms, in the range of 1 to 4294967295 packets.
interval interval: Specifies the statistics collection and comparison interval for received pause frames, in the range of 1 to 65535 seconds.
With the received pause frame alarm function enabled, when the number of received pause frames on an interface in normal state within the specified interval exceeds the upper threshold, the interface generates an upper threshold exceeding alarm and enters the alarm state. When the number of received pause frames on an interface in the alarm state within the specified interval drops below the lower threshold, the interface generates a recovery alarm and restores to the normal state.
You can configure the received pause frame alarm parameters in system view and interface view.
For this command to take effect, you must use the snmp-agent trap enable ifmonitor command to enable the received pause frame alarm function.
# Set the upper threshold to 30, lower threshold to 20, and statistics collection and comparison interval to 4 seconds for received pause frame alarms.
[Sysname] ifmonitor rx-pause slot 1 high-threshold 30 low-threshold 20 interval 4
ifmonitor sdh-b1-error
Use ifmonitor sdh-b1-error to configure global SDH-B1 error packet alarm parameters.
Use undo ifmonitor sdh-b1-error to restore the default.
ifmonitor sdh-b1-error slot slot-number high-threshold high-value low-threshold low-value interval interval [ shutdown ]
undo ifmonitor sdh-b1-error slot slot-number
The upper threshold is 1000, the lower threshold is 100, and the statistics collection and comparison interval is 10 seconds for SDH-B1 error packet alarms.
high-threshold high-value: Specifies the upper threshold for SDH-B1 error packet alarms, in the range of 1 to 4294967295 packets.
low-threshold low-value: Specifies the lower threshold for SDH-B1 error packet alarms, in the range of 1 to 4294967295 packets.
interval interval: Specifies the statistics collection and comparison interval for SDH-B1 error packets, in the range of 1 to 65535 seconds.
shutdown: Shuts down an interface when the number of incoming SDH-B1 error packets on the interface exceeds the upper threshold. Then, the interface stops forwarding all packets. To recover the interface, execute the undo shutdown command on the interface. If you do not specify this keyword, an upper threshold exceeding alarm is generated and the interface enters the alarm state when the number of incoming SDH-B1 error packets exceeds the upper threshold on the interface, but the interface will not be shut down. If you specify this keyword when the upper threshold has been exceeded on an interface, the interface will be shut down.
With the SDH-B1 error packet alarm function enabled, when the number of incoming SDH-B1 error packets on an interface in normal state within the specified interval exceeds the upper threshold, the interface generates an upper threshold exceeding alarm and enters the alarm state. When the number of incoming SDH-B1 error packets on an interface in the alarm state within the specified interval drops below the lower threshold, the interface generates a recovery alarm and restores to the normal state.
You can configure the SDH-B1 error packet alarm parameters in system view and interface view.
For this command to take effect, you must use the snmp-agent trap enable ifmonitor command to enable the SDH-B1 error packet alarm function.
# Set the upper threshold to 65, lower threshold to 25, and statistics collection and comparison interval to 20 seconds for SDH-B1 error packet alarms.
[Sysname] ifmonitor sdh-b1-error slot 1 high-threshold 65 low-threshold 25 interval 20
ifmonitor sdh-b2-error
Use ifmonitor sdh-b2-error to configure global SDH-B2 error packet alarm parameters.
Use undo ifmonitor sdh-b2-error to restore the default.
ifmonitor sdh-b2-error slot slot-number high-threshold high-value low-threshold low-value interval interval [ shutdown ]
undo ifmonitor sdh-b2-error slot slot-number
The upper threshold is 1000, the lower threshold is 100, and the statistics collection and comparison interval is 10 seconds for SDH-B2 error packet alarms.
high-threshold high-value: Specifies the upper threshold for SDH-B2 error packet alarms, in the range of 1 to 4294967295 packets.
low-threshold low-value: Specifies the lower threshold for SDH-B2 error packet alarms, in the range of 1 to 4294967295 packets.
interval interval: Specifies the statistics collection and comparison interval for SDH-B2 error packets, in the range of 1 to 65535 seconds.
shutdown: Shuts down an interface when the number of incoming SDH-B2 error packets on the interface exceeds the upper threshold. Then, the interface stops forwarding all packets. To recover the interface, execute the undo shutdown command on the interface. If you do not specify this keyword, an upper threshold exceeding alarm is generated and the interface enters the alarm state when the number of incoming SDH-B2 error packets exceeds the upper threshold on the interface, but the interface will not be shut down. If you specify this keyword when the upper threshold has been exceeded on an interface, the interface will be shut down.
With the SDH-B2 error packet alarm function enabled, when the number of incoming SDH-B2 error packets on an interface in normal state within the specified interval exceeds the upper threshold, the interface generates an upper threshold exceeding alarm and enters the alarm state. When the number of incoming SDH-B2 error packets on an interface in the alarm state within the specified interval drops below the lower threshold, the interface generates a recovery alarm and restores to the normal state.
You can configure the SDH-B2 error packet alarm parameters in system view and interface view.
For this command to take effect, you must use the snmp-agent trap enable ifmonitor command to enable the SDH-B2 error packet alarm function.
# Set the upper threshold to 6, lower threshold to 5, and statistics collection and comparison interval to 2 seconds for SDH-B2 error packet alarms.
[Sysname] ifmonitor sdh-b2-error slot 1 high-threshold 6 low-threshold 5 interval 2
ifmonitor sdh-error
Use ifmonitor sdh-error to configure global SDH error packet alarm parameters.
Use undo ifmonitor sdh-error to restore the default.
ifmonitor sdh-error slot slot-number high-threshold high-value low-threshold low-value interval interval [ shutdown ]
undo ifmonitor sdh-error slot slot-number
The upper threshold is 1000, the lower threshold is 100, and the statistics collection and comparison interval is 10 seconds for SDH error packet alarms.
high-threshold high-value: Specifies the upper threshold for SDH error packet alarms, in the range of 1 to 4294967295 packets.
low-threshold low-value: Specifies the lower threshold for SDH error packet alarms, in the range of 1 to 4294967295 packets.
interval interval: Specifies the statistics collection and comparison interval for SDH error packets, in the range of 1 to 65535 seconds.
shutdown: Shuts down an interface when the number of incoming SDH error packets on the interface exceeds the upper threshold. Then, the interface stops forwarding all packets. To recover the interface, execute the undo shutdown command on the interface. If you do not specify this keyword, an upper threshold exceeding alarm is generated and the interface enters the alarm state when the number of incoming SDH error packets exceeds the upper threshold on the interface, but the interface will not be shut down. If you specify this keyword when the upper threshold has been exceeded on an interface, the interface will be shut down.
slot slot-number: Specifies an IRF member device by its member ID.
With the SDH error packet alarm function enabled, when the number of incoming SDH error packets on an interface in normal state within the specified interval exceeds the upper threshold, the interface generates an upper threshold exceeding alarm and enters the alarm state. When the number of incoming SDH error packets on an interface in the alarm state within the specified interval drops below the lower threshold, the interface generates a recovery alarm and restores to the normal state.
You can configure the SDH error packet alarm parameters in system view and interface view.
For this command to take effect, you must use the snmp-agent trap enable ifmonitor command to enable the SDH error packet alarm function.
# Set the upper threshold to 35, lower threshold to 20, and statistics collection and comparison interval to 8 seconds for SDH error packet alarms.
[Sysname] ifmonitor sdh-error slot 1 high-threshold 35 low-threshold 20 interval 8
ifmonitor tx-pause
Use ifmonitor tx-pause to configure global sent pause frame alarm parameters.
Use undo ifmonitor tx-pause to restore the default.
ifmonitor tx-pause slot slot-number high-threshold high-value low-threshold low-value interval interval [ shutdown ]
undo ifmonitor tx-pause slot slot-number
The upper threshold is 500, the lower threshold is 100, and the statistics collection and comparison interval is 10 seconds for sent pause frame alarms.
high-threshold high-value: Specifies the upper threshold for sent pause frame alarms, in the range of 1 to 4294967295 packets.
low-threshold low-value: Specifies the lower threshold for sent pause frame alarms, in the range of 1 to 4294967295 packets.
interval interval: Specifies the statistics collection and comparison interval for sent pause frames, in the range of 1 to 65535 seconds.
shutdown: Shuts down an interface when the number of sent pause frames on the interface exceeds the upper threshold. Then, the interface stops forwarding all packets. To recover the interface, execute the undo shutdown command on the interface. If you do not specify this keyword, an upper threshold exceeding alarm is generated and the interface enters the alarm state when the number of sent pause frames exceeds the upper threshold on the interface, but the interface will not be shut down. If you specify this keyword when the upper threshold has been exceeded on an interface, the interface will be shut down.
With the sent pause frame alarm function enabled, when the number of sent pause frames on an interface in normal state within the specified interval exceeds the upper threshold, the interface generates an upper threshold exceeding alarm and enters the alarm state. When the number of sent pause frames on an interface in the alarm state within the specified interval drops below the lower threshold, the interface generates a recovery alarm and restores to the normal state.
You can configure the sent pause frame alarm parameters in system view and interface view.
For this command to take effect, you must use the snmp-agent trap enable ifmonitor command to enable the sent pause frame alarm function.
# Set the upper threshold to 20, lower threshold to 10, and statistics collection and comparison interval to 5 seconds for sent pause frame alarms.
[Sysname] ifmonitor tx-pause slot 1 high-threshold 20 low-threshold 10 interval 5
interface
Use interface to enter interface view, create a subinterface and enter its view, or enter the view of an existing subinterface.
interface-number.subnumber: Specifies a subinterface number. The interface-number argument is an interface number. The subnumber argument is the number of a subinterface created under the interface. The value range for the subnumber argument is 1 to 4094.
# Enter the view of GigabitEthernet 1/0/1.
# Create Ethernet subinterface GigabitEthernet 1/0/1.1 and enter its view.
[Sysname] interface gigabitethernet 1/0/1.1
[Sysname-GigabitEthernet1/0/1.1]
interface default-description output
Use interface default-description output to display the default description for interfaces when the interface information is displayed.
Use undo interface default-description output to not display the default description for interfaces when the interface information is displayed.
The device displays the default description for interfaces when it displays the interface information.
This command takes effect only on physical interfaces.
# Configure the device to not display the the default description for interfaces when it displays the interface information.
[Sysname] undo interface default-description output
description
jumboframe enable
Use jumboframe enable to allow jumbo frames within the specified length to pass through.
Use undo jumboframe enable to prevent jumbo frames from passing through.
Use undo jumboframe enable size to restore the default.
jumboframe enable [ size ]
The device allows jumbo frames within 13312 bytes to pass through.
size: Sets the maximum length (in bytes) of Ethernet frames that are allowed to pass through. The value range for this argument is 1536 to 13312.
If you execute this command multiple times on the same interface, the most recent configuration takes effect.
If you execute this command on multiple interfaces in the same slot, the most recent configuration takes effect on all interfaces of the slot.
To assign a physical interface to an aggregate interface, make sure the physical interface is configured with the same maximum jumbo frame size (13312) as the aggregate interface. After assigning a physical interface to an aggregate interface, you cannot modify the maximum jumbo frame size of the physical interface. Additionally, you cannot modify the maximum jumbo frame size for interfaces in the same slot as the physical interface.
If a physical interface in a slot is configured as an IRF physical interface, the maximum jumbo frame size is restored to the default for all physical interfaces in the slot and cannot be modified.
You cannot modify the maximum jumbo frame size of an aggregate interface.
To assign interfaces to an aggregate interface, make sure these interfaces are configured with the same maximum jumbo frame size as that of the aggregate interface, 13312.
After assigning an interface to an aggregate interface, you cannot modify the maximum jumbo frame size of the interface. Additionally, you cannot modify the maximum jumbo frame size for interfaces in the same slot as the interface.
# Allow jumbo frames to pass through GigabitEthernet 1/0/1.
[Sysname-GigabitEthernet1/0/1] jumboframe enable
link-delay
Use link-delay to set the physical state change suppression interval on an Ethernet interface.
Use undo link-delay to restore the default.
undo link-delay { down | up }
Each time the physical link of a port goes up or comes down, the interface immediately reports the change to the CPU.
down: Suppresses link-down events.
up: Suppresses link-up events.
msec: Enables the physical state change suppression interval to be accurate to milliseconds. If you do not specify this keyword, the suppression interval is accurate to seconds.
delay-time: Sets the physical state change suppression interval on the Ethernet interface. A value of 0 means that physical state changes are immediately reported to the CPU and are not suppressed.
· If you do not specify the msec keyword, the value range is 0 to 120 seconds.
· If you specify the msec keyword, the value range is 0 to 10000 milliseconds, and the value must be a multiple of 100.
You can configure this feature to suppress only link-down events, only link-up events, or both. If an event of the specified type still exists when the suppression interval expires, the system reports the event.
When you configure this feature, follow these guidelines:
· To suppress link-down events, execute the link-delay down command.
· To suppress link-up events, execute the link-delay up command.
On an interface, you can configure different suppression intervals for link-up and link-down events. If you execute the link-delay command multiple times on an interface, the following rules apply:
· You can configure the suppression intervals for link-up and link-down events separately.
· If you configure the suppression interval multiple times for link-up or link-down events, the most recent configuration takes effect.
Do not execute this command on an interface that has RRPP, spanning tree protocols, or Smart Link enabled.
This command, the dampening command, and the port link-flap protect enable command are mutually exclusive on an Ethernet interface.
# Set the link-down event suppression interval to 8 seconds on GigabitEthernet 1/0/1.
[Sysname-GigabitEthernet1/0/1] link-delay down 8
# Set the link-up event suppression interval to 800 milliseconds on GigabitEthernet 1/0/1.
[Sysname-GigabitEthernet1/0/1] link-delay up msec 800
dampening
Use link-flap protect enable to enable link flapping protection globally.
Use undo link-flap protect enable to disable link flapping protection globally.
link-flap protect enable [ down-auto-recovery ]
down-auto-recovery: Shuts down the interface when the device detects link flapping. After reaching the interface status detection timer timeout configured by the shutdown-interval link-flap command, the interface return to its true physical state. If you do not specify this parameter, the interface cannot automatically return to the UP after DOWN.
Link flapping on any interface changes network topology and increases the system overhead. For example, in an active/standby link scenario, when the interface status on the active link changes between UP and DOWN, traffic switches between active and standby links. To solve this problem, execute this command.
With link flapping protection enabled on an interface, when the interface goes down, the system enables link flapping detection on the interface. During the link flapping detection interval, if the number of detected flaps reaches or exceeds the link flapping detection threshold, the system shuts down the interface.
Link flapping protection takes effect only when it is enabled in both system view and interface view.
# Enable link flapping protection globally.
[Sysname] link-flap protect enable
loopback
CAUTION: After you enable loopback testing on an Ethernet interface, the interface does not forward data traffic. |
Use loopback to enable loopback testing on an Ethernet interface.
Use undo loopback to disable loopback testing on an Ethernet interface.
loopback internal
undo loopback
Loopback testing is disabled on an Ethernet interface.
internal: Enables internal loopback testing on the Ethernet interface.
After you enable loopback testing on an Ethernet interface, the Ethernet interface switches to full duplex mode. After you disable loopback testing, the Ethernet interface restores to its duplex setting.
The shutdown, port up-mode, and loopback commands are mutually exclusive.
# Enable internal loopback testing on GigabitEthernet 1/0/1.
[Sysname-GigabitEthernet1/0/1] loopback internal
multicast-suppression
Use multicast-suppression to enable multicast storm suppression and set the multicast storm suppression threshold.
Use undo multicast-suppression to disable multicast storm suppression.
Ethernet interfaces do not suppress multicast traffic.
ratio: Sets the multicast suppression threshold as a percentage of the interface bandwidth. The value range for this argument (in percentage) is 0 to 100. A smaller value means that less multicast traffic is allowed to pass through.
pps max-pps: Specifies the maximum number of multicast packets that the interface can forward per second. The value range for the max-pps argument (in pps) is 0 to 1.4881 × the interface bandwidth.
kbps max-kbps: Specifies the maximum number of kilobits of multicast traffic that the Ethernet interface can forward per second. The value range for this argument (in kbps) is 0 to the interface bandwidth.
The multicast storm suppression feature limits the size of multicast traffic to a threshold on an interface. When the multicast traffic on the interface exceeds this threshold, the system drops packets until the traffic drops below this threshold.
Both the storm-constrain command and the multicast-suppression command can suppress multicast storms on a port. The multicast-suppression command uses the chip to physically suppress multicast traffic. It has less influence on the device performance than the storm-constrain command, which uses software to suppress multicast traffic.
For the traffic suppression result to be determined, do not execute both the storm-constrain multicast command and the multicast-suppression command on an interface.
The configured suppression threshold value in pps or kbps will be converted into a multiple of a step supported by the chip. As a result, the effective suppression threshold might be different from the configured one. To determine the suppression threshold that takes effect, see the prompts on the device.
# Set the multicast storm suppression threshold to 10000 kbps on GigabitEthernet 1/0/1.
[Sysname-GigabitEthernet1/0/1] multicast-suppression kbps 10000
The actual value is 9984 on port GigabitEthernet1/0/1 currently.
broadcast-suppression
unicast-suppression
port fec mode
Use port fec mode to set the forward error correction (FEC) mode of an interface.
Use undo port fec mode to restore the default.
port fec mode { auto | base-r | none | rs-fec }
undo port fec mode
The FEC mode of an interface is autonegotiation.
25-GE interface view
100-GE interface view
auto: Specifies the FEC autonegotiation mode.
base-r: Specifies the BASE-R FEC mode. 100-GE interfaces do not support this keyword.
none: Performs no FEC.
rs-fec: Specifies the RS-FEC mode. 25-GE interfaces do not support this keyword.
The FEC feature corrects packet errors to improve transmission quality. It attaches correction information to a packet at the sending end, and corrects error codes generated during transmission at the receiving end based on the correction information. You can set the FEC mode as needed.
Make sure you set the same FEC mode for both interfaces of a link.
# Set the FEC mode of Twenty-FiveGigE 1/0/1 to autonegotiation.
[Sysname] interface twenty-fivegige 1/0/1
[Sysname-Twenty-FiveGigE1/0/1] port fec mode auto
# Set the FEC mode of HundredGigE1/0/1 to autonegotiation.
[Sysname-HundredGigE1/0/1] port fec mode auto
port ifmonitor crc-error
Use port ifmonitor crc-error to configure CRC error packet alarm parameters for an interface.
Use undo port ifmonitor crc-error to restore the default.
An interface uses the global CRC error packet alarm parameters.
ratio: Specifies the alarm thresholds in percentage. If you do not specify this keyword, you configure the alarm thresholds in absolute value.
high-threshold high-value: Specifies the upper threshold for CRC error packet alarms. If you specify the ratio keyword, the value range is 1 to 100. If you do not specify the ratio keyword, the value range is 1 to 4294967295 packets.
low-threshold low-value: Specifies the lower threshold for CRC error packet alarms. If you specify the ratio keyword, the value range is 1 to 100. If you do not specify the ratio keyword, the value range is 1 to 4294967295 packets.
# Set the upper threshold to 5000, lower threshold to 400, and statistics collection and comparison interval to 6 seconds for CRC error packet alarms on GigabitEthernet 1/0/1.
[Sysname-GigabitEthernet1/0/1] port ifmonitor crc-error high-threshold 5000 low-threshold 400 interval 6
port ifmonitor input-error
Use port ifmonitor input-error to configure input error packet alarm parameters for an interface.
Use undo port ifmonitor input-error to restore the default.
An interface uses the global input error packet alarm parameters.
# Set the upper threshold to 5000, lower threshold to 400, and statistics collection and comparison interval to 6 seconds for input error packet alarms on GigabitEthernet 1/0/1.
[Sysname-GigabitEthernet1/0/1] port ifmonitor input-error high-threshold 5000 low-threshold 400 interval 6
port ifmonitor input-usage
Use port ifmonitor input-usage to configure input bandwidth usage alarm parameters.
Use undo port ifmonitor input-usage to restore the default.
An interface uses the global input bandwidth usage alarm parameters.
Interface view
The statistics polling interval varies by device model:
· On a device that does not support the flow-interval command, the statistics polling interval is 5 minutes.
· On a device that supports the flow-interval command, you can use the flow-interval command to set the statistics polling interval.
· The configuration in system view takes effect on all interfaces. The configuration in interface view takes effect only on the current interface. (Devices that do not support the slot keyword.)
· The configuration in system view takes effect on all interfaces of the specified slot. The configuration in interface view takes effect only on the current interface. (Devices that support the slot keyword.)
# Set the upper threshold to 80 and lower threshold to 60 for input bandwidth usage alarms on GigabitEthernet 1/0/1.
[Sysname-GigabitEthernet1/0/1] port ifmonitor input-usage high-threshold 80 low-threshold 60
flow-interval
port ifmonitor output-error
Use port ifmonitor output-error to configure output error packet alarm parameters for an interface.
Use undo port ifmonitor output-error to restore the default.
An interface uses the global output error packet alarm parameters.
# Set the upper threshold to 5000, lower threshold to 400, and statistics collection and comparison interval to 6 seconds for output error packet alarms on GigabitEthernet 1/0/1.
[Sysname-GigabitEthernet1/0/1] port ifmonitor output-error high-threshold 5000 low-threshold 400 interval 6
port ifmonitor output-usage
Use port ifmonitor output-usage to configure output bandwidth usage alarm parameters.
Use undo port ifmonitor output-usage to restore the default.
An interface uses the global output bandwidth usage alarm parameters.
Interface view
# Set the upper threshold to 9 and lower threshold to 7 for output bandwidth usage alarms on GigabitEthernet 1/0/1.
[Sysname-GigabitEthernet1/0/1] port ifmonitor output-usage high-threshold 9 low-threshold 7
flow-interval
port ifmonitor rx-pause
Use port ifmonitor rx-pause to configure received pause frame alarm parameters for an interface.
Use undo port ifmonitor rx-pause to restore the default.
port ifmonitor rx-pause high-threshold high-value low-threshold low-value interval interval
An interface uses the global received pause frame alarm parameters.
high-threshold high-value: Specifies the upper threshold for received pause frame alarms, in the range of 1 to 4294967295.
low-threshold low-value: Specifies the lower threshold for received pause frame alarms, in the range of 1 to 4294967295.
interval interval: Specifies the statistics collection and comparison interval for received pause frame packets, in the range of 1 to 65535 seconds.
With the received pause frame alarm function enabled, when the number of received pause frame packets on an interface in normal state within the specified interval exceeds the upper threshold, the interface generates an upper threshold exceeding alarm and enters the alarm state. When the number of received pause frame packets on an interface in the alarm state within the specified interval drops below the lower threshold, the interface generates a recovery alarm and restores to the normal state.
# Set the upper threshold to 90, lower threshold to 50, and statistics collection and comparison interval to 5 seconds for received pause frame alarms on GigabitEthernet 1/0/1.
[Sysname-GigabitEthernet1/0/1] port ifmonitor rx-pause high-threshold 90 low-threshold 50 interval 5
port ifmonitor sdh-b1-error
Use port ifmonitor sdh-b1-error to configure SDH-B1 error packet alarm parameters for an interface.
Use undo port ifmonitor sdh-b1-error to restore the default.
port ifmonitor sdh-b1-error high-threshold high-value low-threshold low-value interval interval [ shutdown ]
An interface uses the global SDH-B1 error packet alarm parameters.
# Set the upper threshold to 20, lower threshold to 10, and statistics collection and comparison interval to 10 seconds for SDH-B1 error packet alarms on GigabitEthernet 1/0/1.
[Sysname-GigabitEthernet1/0/1] port ifmonitor sdh-b1-error high-threshold 20 low-threshold 10 interval 10
port ifmonitor sdh-b2-error
Use port ifmonitor sdh-b2-error to configure SDH-B2 error packet alarm parameters for an interface.
Use undo port ifmonitor sdh-b2-error to restore the default.
port ifmonitor sdh-b2-error high-threshold high-value low-threshold low-value interval interval [ shutdown ]
An interface uses the global SDH-B2 error packet alarm parameters.
# Set the upper threshold to 10, lower threshold to 8, and statistics collection and comparison interval to 3 seconds for SDH-B2 error packet alarms on GigabitEthernet 1/0/1.
[Sysname-GigabitEthernet1/0/1] port ifmonitor sdh-b2-error high-threshold 10 low-threshold 8 interval 3
port ifmonitor sdh-error
Use port ifmonitor sdh-error to configure SDH error packet alarm parameters for an interface.
Use undo port ifmonitor sdh-error to restore the default.
port ifmonitor sdh-error high-threshold high-value low-threshold low-value interval interval [ shutdown ]
An interface uses the global SDH error packet alarm parameters.
# Set the upper threshold to 50, lower threshold to 30, and statistics collection and comparison interval to 10 seconds for SDH error packet alarms on GigabitEthernet 1/0/1.
[Sysname-GigabitEthernet1/0/1] port ifmonitor sdh-error high-threshold 50 low-threshold 30 interval 10
port ifmonitor tx-pause
Use port ifmonitor tx-pause to configure sent pause frame alarm parameters for an interface.
Use undo port ifmonitor tx-pause to restore the default.
port ifmonitor tx-pause high-threshold high-value low-threshold low-value interval interval [ shutdown ]
An interface uses the global sent pause frame alarm parameters.
high-threshold high-value: Specifies the upper threshold for sent pause frame alarms, in the range of 1 to 4294967295.
low-threshold low-value: Specifies the lower threshold for sent pause frame alarms, in the range of 1 to 4294967295.
interval interval: Specifies the statistics collection and comparison interval for sent pause frame packets, in the range of 1 to 65535 seconds.
With the sent pause frame alarm function enabled, when the number of sent pause frame packets on an interface in normal state within the specified interval exceeds the upper threshold, the interface generates an upper threshold exceeding alarm and enters the alarm state. When the number of sent pause frame packets on an interface in the alarm state within the specified interval drops below the lower threshold, the interface generates a recovery alarm and restores to the normal state.
# Set the upper threshold to 50, lower threshold to 40, and statistics collection and comparison interval to 8 seconds for sent pause frame alarms on GigabitEthernet 1/0/1.
[Sysname-GigabitEthernet1/0/1] port ifmonitor tx-pause high-threshold 50 low-threshold 40 interval 8
Use port link-flap protect enable to enable link flapping protection on an interface.
Use undo port link-flap protect enable to disable link flapping protection on an interface.
port link-flap protect enable [ down-auto-recovery ] [ interval interval | threshold threshold ] * [ second-interval second-interval second-threshold second-threshold ]
undo port link-flap protect enable [ interval | threshold ]
down-auto-recovery: Shuts down an interface when the device detects link flapping. When the port status detection timer set by the shutdown-interval link-flap command expires, the port automatically restores to its actual physical state. If you do not specify this keyword, the system does not automatically restore the interface status, and you must execute the down-auto-recovery command to manually restore the interface status.
interval interval: Specifies the level-1 link flapping detection interval in seconds. The value range for this argument is 5 to 86400. The default value for this argument is 10.
threshold threshold: Specifies the level-1 link flapping detection threshold in the range of 2 to 1200. The default value for this argument is 5.
second-interval interval: Specifies the level-2 link flapping detection interval in seconds. The value range for this argument is 5 to 86400.
second-threshold threshold: Specifies the level-2 link flapping detection threshold in the range of 2 to 1200.
Operating mechanism
When you configure this feature on an interface, how link flapping protection is triggered depends on the parameters specified:
· If you specify level-1 link flapping protection parameters but do not specify level-2 parameters, link flapping protection will be triggered and the interface will be shut down when the level-1 link flapping protection conditions are met.
· If you specify both level-1 and level-2 link flapping protection parameters, link flapping protection will be triggered and the interface will be shut down when either of level-1 and level-2 link flapping protection conditions are met.
If you do not specify the interval interval or threshold threshold option, the command uses the default level-1 link flapping protection settings. If you do not specify the second-interval interval or second-threshold threshold option, the command uses only the level-1 link flapping protection settings.
If you specify the interval or threshold keyword when you execute the undo port link-flap protect enable command, the command restores the default setting for the keyword.
With link flapping protection enabled on an interface, when the interface goes down, the system enables link flapping detection on the interface. During a link flapping detection interval, if the number of detected flaps reaches or exceeds the corresponding link flapping detection threshold, the system shuts down the interface. If you specify both level-1 and level-2 link flapping protection settings, link flapping protection will be triggered and the interface will be shut down when either of level-1 and level-2 link flapping protection conditions are met.
This command, the dampening command, and the link-delay command are mutually exclusive on an Ethernet interface.
# Enable link flapping protection on an interface. Set the link flapping detection interval to 10 seconds, and set the link flapping detection threshold to 5.
[Sysname-GigabitEthernet 1/0/1] port link-flap protect enable interval 10 threshold 5
dampening
link-delay
port link-mode
Use port link-mode to change the link mode of an Ethernet interface.
Use undo port link-mode to restore the default.
undo port link-mode
Interfaces operate in bridge mode.
bridge: Specifies the Layer 2 mode.
route: Specifies the Layer 3 mode.
CAUTION: Changing the link mode of an Ethernet interface also restores all commands (except description, duplex, jumboframe enable, speed, shutdown, and combo enable) on the Ethernet interface to their defaults in the new link mode. |
Interfaces on the device can operate either as Layer 2 or Layer 3 Ethernet interfaces.
You can use commands to set the link mode to bridge or route.
# Configure GigabitEthernet 1/0/1 to operate in Layer 2 mode.
[Sysname-GigabitEthernet1/0/1] port link-mode bridge
The configuration of the interface will be restored to the default. Continue? [Y/N]:y
port up-mode
Use port up-mode to forcibly bring up a fiber Ethernet port.
Use undo port up-mode to restore the default.
port up-mode
undo port up-mode
A fiber Ethernet port is not forcibly brought up. The physical state of a fiber port depends on the physical state of the fibers.
This command forcibly brings up a fiber Ethernet port and enables the port to forward packets unidirectionally over a single link. In this way, transmission links are well utilized.
Copper ports do not support this command.
A fiber Ethernet port does not support this command if the port is shut down by a protocol or by using the shutdown command.
A GE fiber port forcibly brought up cannot correctly forward traffic if it is installed with a fiber-to-copper converter, 100/1000-Mbps transceiver module, or 100-Mbps transceiver module. To solve the problem, use the undo port up-mode command on the fiber port.
# Forcibly bring up fiber port GigabitEthernet 1/0/1.
[Sysname-GigabitEthernet1/0/1] port up-mode
port-speed-mode
Use port-speed-mode to configure the port speed mode for expansion slots.
Use undo port-speed-mode to restore the default.
NOTE: This command is not supported on the S5590-HI switch series. |
port-speed-mode mode { 0 | 1 | 2 }
The port speed mode is 0 for expansion slots.
mode { 0 | 1 | 2 }: Specifies a port speed mode for expansion slots.
For this feature to take effect, reboot the device after you configure the feature.
To set up an IRF fabric successfully, make sure the same port speed mode for expansion slots is configured on the member devices.
When the port speed mode is 2, only the first 44 GE interfaces are available for the S5590-48T4XC-HI and S5590-48S4XC-HI switches.
In different port speed modes, different expansion slots support different expansion cards. For more information, see Table 11 and Table 12.
Expansion card |
mode 0 |
mode 1 |
mode 2 |
LSPM6FWD |
Yes |
No |
Yes |
LSWM2EC |
No |
Yes |
Yes |
LSWM2QP2P |
Yes |
No |
Yes |
LSWM2SP8P |
No |
No |
Yes |
LSWM2ZQP2P |
No |
No |
No |
LSWM2ZSP8P |
No |
No |
No |
Expansion card |
mode 0 |
mode 1 |
mode 2 |
LSPM6FWD |
Yes |
LSWM2EC |
Yes |
LSWM2QP2P |
Yes |
LSWM2SP8P |
Yes |
LSWM2ZQP2P |
Yes |
LSWM2ZSP8P |
Yes |
# Configure the port speed mode for expansion slots as 1.
[Sysname] port-speed-mode mode 1
Reboot device to make the configuration take effect.
reset counters interface
Use reset counters interface to clear the interface statistics.
reset counters interface [ interface-type [ interface-number | interface-number.subnumber ] ]
Use this command to clear history statistics if you want to collect traffic statistics for a specific time period.
If you do not specify an interface type, this command clears statistics for all interfaces.
If you specify an interface type but do not specify an interface number, this command clears statistics for all interfaces of the specified type.
# Clear the statistics for GigabitEthernet 1/0/1.
<Sysname> reset counters interface gigabitethernet 1/0/1
display counters interface
display counters rate interface
display interface
reset ethernet statistics
Use reset ethernet statistics to clear the Ethernet module statistics.
reset ethernet statistics [ slot slot-number ]
slot slot-number: Specifies an IRF member device by its member ID. If you do not specify a member device, this command clears statistics for all IRF member devices.
# Clear the Ethernet module statistics for the specified slot.
<Sysname> reset ethernet statistics slot 1
display ethernet statistics
reset link-state-change statistics interface
Use reset link-state-change statistics interface to clear link state change statistics of interfaces.
reset link-state-change statistics interface [ interface-type [ interface-number ] ]
Link state change statistics of an interface are not cleared.
If you do not specify an interface type, this command clears the link state change statistics for all interfaces.
If you specify an interface type but do not specify an interface number, this command clears the link state change statistics for all interfaces of the specified type.
# Clear the link state change statistics of GigabitEthernet 1/0/1.
<Sysname> reset link-state-change statistics interface gigabitethernet 1/0/1
display link-state-change statistics interface
reset packet-drop interface
Use reset packet-drop interface to clear the dropped packet statistics for an interface.
reset packet-drop interface [ interface-type [ interface-number ] ]
interface-type: Specify an interface type.
interface-number: Specify an interface number.
If you do not specify an interface type, this command clears dropped packet statistics for all interfaces on the device.
If you specify an interface type but do not specify an interface number, the command clears dropped packet statistics for all interfaces of the specified type.
# Clear dropped packet statistics for GigabitEthernet 1/0/1.
<Sysname> reset packet-drop interface gigabitethernet 1/0/1
# Clear dropped packet statistics for all interfaces.
display packet-drop
shutdown
Use shutdown to shut down an Ethernet interface or subinterface.
Use undo shutdown to bring up an Ethernet interface or subinterface.
shutdown
Ethernet interfaces and subinterfaces are in up state.
Ethernet subinterface view
CAUTION: Executing the shutdown command on an interface will disconnect the link of the interface and interrupt communication. Use this command with caution. |
Some interface configurations might require an interface restart before taking effect.
# Shut down and then bring up GigabitEthernet 1/0/1.
[Sysname-GigabitEthernet1/0/1] shutdown
[Sysname-GigabitEthernet1/0/1] undo shutdown
# Shut down and then bring up GigabitEthernet 1/0/1.1.
[Sysname-GigabitEthernet1/0/1.1] shutdown
[Sysname-GigabitEthernet1/0/1.1] undo shutdown
shutdown all-physical-interface
Use shutdown all-physical-interfaces to shut down all physical interfaces except management Ethernet interfaces.
Use undo shutdown all-physical-interfaces to bring up all physical interfaces except management Ethernet interfaces.
shutdown all-physical-interfaces [ include irf-physical-interface ]
Physical interfaces are up.
include irf-physical-interface: Shuts down all physical interfaces including the IRF physical interfaces. If you do not specify this keyword, this command does not shut down IRF physical interfaces.
With the shutdown all-physical-interfaces command, you can shut down all physical interfaces except the management Ethernet interfaces on the device. Physical interfaces shut down by using this command are in ADM state.
To shut down all physical interfaces or the specified interface, execute the shutdown all-physical-interfaces command in system view or execute the shutdown command in interface view.
To bring up interfaces shut down by using the shutdown all-physical-interfaces command, execute its undo form in system view. To bring up an interface shut down by using the shutdown command, execute its undo form in interface view.
If you execute this command with the include irf-physical-interface keyword multiple times, this command shuts down all physical interfaces except the management Ethernet interfaces on the device.
# Shut down all physical interfaces except management Ethernet interfaces and IRF physical interfaces.
[Sysname] shutdown all-physical-interfaces
shutdown
Use shutdown-interval crc-error to set the port status detection timer for the ports that are shut down by the CRC error packet alarm feature.
Use undo shutdown-interval crc-error to restore the default.
shutdown-interval [ crc-error ] interval
undo shutdown-interval [ crc-error ]
The port status detection timer is 30 seconds.
crc-error: Specifies the CRC error packet alarm feature. If you do not specify this keyword, the port status detection timer configured by this command takes effect for all features that support the shutdown-interval command, for example, the CRC error packet alarm feature.
interval: Specifies the port status detection timer, in the range of 0 to 300 seconds. When the value is 0, the system does not automatically restore the interface status, and you must execute the undo shutdown command to manually restore the interface status.
Operating mechanism
When a port is shut down automatically by a feature, the device starts a port status detection timer. When the timer expires, the device restores the port status to its actual physical status automatically.
If you change the timer setting during port detection, the device compares the new setting (T1) with the time that elapsed since the port was shut down (T).
· If T < T1, the port will be brought up after T1 – T seconds.
· If T ≥ T1, the port is brought up immediately.
For example, the timer setting is 30 seconds. If you change it to 10 seconds 2 seconds after the port is shut down, the port will come up 8 seconds later. If you change the timer setting to 2 seconds 10 seconds after the port is shut down, the port comes up immediately.
The ifmonitor crc-error command takes effect only if you specify the down-auto-recovery keyword.
# Set the port status detection timer to 100 seconds for the ports that are shut down by the CRC error packet alarm feature.
[Sysname] shutdown-interval crc-error 100
ifmonitor crc-error
Use shutdown-interval link-flap to set the port status detection timer for the ports that are shut down by the link flapping protection feature.
Use undo shutdown-interval link-flap to restore the default.
shutdown-interval [ link-flap ] interval
undo shutdown-interval [ link-flap ]
link-flap: Specifies the link flapping protection feature. If you do not specify this keyword, the port status detection timer configured by this command takes effect for all features that support the shutdown-interval command, for example, the CRC error packet alarm feature.
Operating mechanism
# Set the port status detection timer to 100 seconds for the ports that are shut down by the link flapping protection feature.
[Sysname] shutdown-interval link-flap 100
Use snmp-agent trap enable ifmonitor to enable interface alarm functions.
Use undo snmp-agent trap enable ifmonitor to disable interface alarm functions.
snmp-agent trap enable ifmonitor [ crc-error | input-error | input-usage | output-error | output-usage | rx-pause | sdh-b1-error | sdh-b2-error | sdh-error | tx-pause ] *
undo snmp-agent trap enable ifmonitor [ crc-error | input-error | input-usage | output-error | output-usage | rx-pause | sdh-b1-error | sdh-b2-error | sdh-error | tx-pause ] *
All interface alarm functions are enabled.
crc-error: Enables the input CRC error packet alarm function for interfaces. With the CRC error packet alarm function enabled, when the number of incoming CRC error packets on an interface in normal state within the specified interval exceeds the upper threshold, the interface generates an upper threshold exceeding alarm and enters alarm state. When the number of incoming CRC error packets on an interface in the alarm state within the specified interval drops below the lower threshold, the interface generates a recovery alarm and restores to normal state.
input-error: Enables the input error packet alarm function for interfaces. With the input error packet alarm function enabled, when the number of input error packets on an interface in normal state within the specified interval exceeds the upper threshold, the interface generates an upper threshold exceeding alarm and enters alarm state. When the number of input error packets on an interface in the alarm state within the specified interval drops below the lower threshold, the interface generates a recovery alarm and restores to normal state.
input-usage: Enables the input bandwidth usage alarm function for interfaces. With the input bandwidth usage alarm function enabled, when the input bandwidth usage on an interface in normal state within the most recent statistics polling interval exceeds the upper threshold, the interface generates an upper threshold exceeding alarm and enters alarm state. When the input bandwidth usage on an interface in the alarm state within the most recent statistics polling interval drops below the lower threshold, the interface generates a recovery alarm and restores to normal state.
output-error: Enables the output error packet alarm function for interfaces. With the output error packet alarm function enabled, when the number of output error packets on an interface in normal state within the specified interval exceeds the upper threshold, the interface generates an upper threshold exceeding alarm and enters alarm state. When the number of output error packets on an interface in the alarm state within the specified interval drops below the lower threshold, the interface generates a recovery alarm and restores to normal state.
output-usage: Enables the output bandwidth usage alarm function for interfaces. With the output bandwidth usage alarm function enabled, when the output bandwidth usage on an interface in normal state within the most recent statistics polling interval exceeds the upper threshold, the interface generates an upper threshold exceeding alarm and enters alarm state. When the output bandwidth usage on an interface in the alarm state within the most recent statistics polling interval drops below the lower threshold, the interface generates a recovery alarm and restores to normal state.
rx-pause: Enables the received pause frame alarm function for interfaces. guidelines With the received pause frame alarm function enabled, when the number of received pause frames on an interface in normal state within the specified interval exceeds the upper threshold, the interface generates an upper threshold exceeding alarm and enters alarm state. When the number of received pause frames on an interface in the alarm state within the specified interval drops below the lower threshold, the interface generates a recovery alarm and restores to normal state.
sdh-b1-error: Enables the SDH-B1 error packet alarm function for interfaces. With the SDH-B1 error packet alarm function enabled, when the number of incoming SDH-B1 error packets on an interface in normal state within the specified interval exceeds the upper threshold, the 19 interface generates an upper threshold exceeding alarm and enters alarm state. When the number of incoming SDH-B1 error packets on an interface in the alarm state within the specified interval drops below the lower threshold, the interface generates a recovery alarm and restores to normal state.
sdh-b2-error: Enables the SDH-B2 error packet alarm function for interfaces. With the SDH-B2 error packet alarm function enabled, when the number of incoming SDH-B2 error packets on an interface in normal state within the specified interval exceeds the upper threshold, the interface generates an upper threshold exceeding alarm and enters alarm state. When the number of incoming SDH-B2 error packets on an interface in the alarm state within the specified interval drops below the lower threshold, the interface generates a recovery alarm and restores to normal state.
sdh-error: Enables the SDH error packet alarm function for interfaces. With the SDH error packet alarm function enabled, when the number of incoming SDH error packets on an interface in normal state within the specified interval exceeds the upper threshold, the interface generates an upper threshold exceeding alarm and enters alarm state. When the number of incoming SDH error packets on an interface in the alarm state within the specified interval drops below the lower threshold, the interface generates a recovery alarm and restores to normal state.
tx-pause: Enables the sent pause frame alarm function for interfaces. With the sent pause frame alarm function enabled, when the number of sent pause frames on an interface in normal state within the specified interval exceeds the upper threshold, the interface generates an upper threshold exceeding alarm and enters alarm state. When the number of sent pause frames on an interface in the alarm state within the specified interval drops below the lower threshold, the interface generates a recovery alarm and restores to normal state.
Operating mechanism
With interface alarm functions enabled, when the number of incoming or outgoing error packets or the bandwidth usage on an interface exceeds the upper threshold or drops below the lower threshold, the interface generates an alarm. Error packets include CRC error packets, error packets, pause frames, SDH-B1 error packets, SDH-B2 error packets, and SDH error packets.
To report critical interface events to an NMS, enable SNMP notifications for Ethernet interfaces. For interface alarms to be sent correctly, you must also configure SNMP as described in Network Management and Monitoring Configuration Guide.
For more information about the alarm thresholds, see the commands listed in related commands.
If you do not specify any parameters, this feature enables or disables all alarm functions on interfaces. If you specify a parameter, this feature enables only the alarm function specified by that parameter.
# Enable the CRC error packet alarm function for interfaces.
[Sysname] snmp-agent trap enable ifmonitor crc-error
ifmonitor crc-error
ifmonitor rx-pause
ifmonitor sdh-error
ifmonitor tx-pause
speed
Use speed to set the speed of an Ethernet interface.
Use undo speed to restore the default.
speed { 10 | 100 | 1000 | 10000 | 25000 | 40000 | 100000 | auto }
undo speed
An Ethernet interface negotiates a speed with its peer.
10: Sets the interface speed to 10 Mbps.
100: Sets the interface speed to 100 Mbps.
1000: Sets the interface speed to 1000 Mbps.
10000: Sets the interface speed to 10000 Mbps.
25000: Sets the interface speed to 25000 Mbps.
40000: Sets the interface speed to 40000 Mbps.
100000: Sets the interface speed to 100000 Mbps.
auto: Enables the interface to negotiate a speed with its peer.
For an Ethernet copper port, use the speed command to set its speed to match the speed of the peer interface. Support of copper ports for keywords of this command varies by copper port type. For more information, use the speed ? command in interface view. If the system does not prompt that operation failed when you configure a speed for a copper port, the copper port supports this speed. Otherwise, the copper port does not support this speed.
For a fiber port, use the speed command to set its speed to match the rate of a transceiver module. Support of fiber ports for keywords of this command varies by fiber port type. For more information, use the speed ? command in interface view. If the system does not prompt that operation failed when you configure a speed for a fiber port, the fiber port supports this speed. Otherwise, the fiber port does not support this speed.
Additionally, you must select a speed for a fiber port according to the transceiver module installed to ensure that the transceiver module can be used properly. If the transceiver module installed in a fiber port does not support the speed for the fiber port, the transceiver module cannot be used. For example, if the transceiver module installed in an SFP+ fiber port is an SFP GE transceiver module and the speed 10000 command is executed on the fiber port or the transceiver module installed in an SFP+ fiber port is a 10-GE transceiver module and the speed 1000 command is executed on the fiber port, the transceiver module cannot be used.
# Configure GigabitEthernet 1/0/1 to autonegotiate the speed.
[Sysname-GigabitEthernet1/0/1] speed auto
speed auto downgrade
Use speed auto downgrade to enable automatic negotiation for speed downgrading.
Use undo speed auto downgrade to disable automatic negotiation for speed downgrading.
Automatic negotiation for speed downgrading is enabled.
GE interface view
10GE interface view
This command takes effect after you configure it on the interface at either end of a link and the two interfaces are configured to automatically negotiate the speed.
# Enable automatic negotiation for speed downgrading on GigabitEthernet 1/0/1.
[Sysname-GigabitEthernet1/0/1] speed auto downgrade
speed auto
unicast-suppression
Use unicast-suppression to enable unknown unicast storm suppression and set the unknown unicast storm suppression threshold.
Use undo unicast-suppression to disable unknown unicast storm suppression.
Ethernet interfaces do not suppress unknown unicast traffic.
ratio: Sets the unknown unicast suppression threshold as a percentage of the interface bandwidth. The value range for this argument (in percentage) is 0 to 100. A smaller value means that less unknown unicast traffic is allowed to pass through.
pps max-pps: Specifies the maximum number of unknown unicast packets that the interface can forward per second. The value range for the max-pps argument (in pps) is 0 to 1.4881 × the interface bandwidth.
kbps max-kbps: Specifies the maximum number of kilobits of unknown unicast traffic that the Ethernet interface can forward per second. The value range for this argument (in kbps) is 0 to the interface bandwidth.
The unknown unicast storm suppression feature limits the size of unknown unicast traffic to a threshold on an interface. When the unknown unicast traffic on the interface exceeds this threshold, the system discards packets until the unknown unicast traffic drops below this threshold.
# Set the unknown unicast storm suppression threshold to 10000 kbps on GigabitEthernet 1/0/1.
[Sysname-GigabitEthernet1/0/1] unicast-suppression kbps 10000
Layer 2 Ethernet interface commands
display storm-constrain
Use display storm-constrain to display storm control settings and statistics.
display storm-constrain [ broadcast | multicast ] [ interface interface-type interface-number ]
broadcast: Displays broadcast storm control settings and statistics.
multicast: Displays multicast storm control settings and statistics.
interface interface-type interface-number: Specifies an interface by its type and number. If you do not specify this option, the command displays storm control settings and statistics for all storm control-enabled interfaces.
If you do not specify any keywords, this command displays all storm control settings on all storm control-enabled interfaces.
# Display the storm control settings on all storm control-enabled ports.
<Sysname> display storm-constrain
Abbreviation: BC - broadcast; MC - multicast; UC - unknown unicast;
KNUC - known unicast; FW - forwarding
Flow Statistic Interval: 5 (in seconds)
Port Type Lower Upper Unit Mode Status Trap Log StateChg
GE1/0/1 MC 100 200 kbps shutdown shutdown off on 10
Table 13 Command output
Flow Statistic Interval |
Traffic polling interval (in seconds) of the storm control module. |
Port |
Abbreviated interface name. |
Type |
Type of traffic subjected to storm control: · BC—Broadcast packets. · MC—Multicast packets. · UC—Unknown unicast packets. This field is not supported in the current software version. |
Lower |
Lower storm control threshold, in pps, kbps, or percentage. |
Upper |
Upper storm control threshold, in pps, kbps, or percentage. |
Unit |
Storm control threshold unit: · pps. · kbps. · percentage. |
Mode |
Action (block or shutdown) taken on the interface when the upper threshold is reached. N/A indicates that no action is configured. |
Status |
Packet forwarding status: · FW—The port is forwarding traffic correctly. · shutdown—The port has been shut down. · block—The port drops the type of traffic. |
Trap |
Status of the storm control threshold event trap switch: · on—The port sends threshold event traps. · off—The port does not send threshold event traps. |
Log |
Status of the storm control threshold event log switch: · on—The port sends threshold event log messages. · off—The port does not send threshold event log messages. |
StateChg |
Number of forwarding state changes of the interface. When the StateChg field reaches 65535, it resets automatically. |
mdix-mode
IMPORTANT: Fiber ports do not support this command. |
Use mdix-mode to configure the Medium Dependent Interface Cross-Over (MDIX) mode of an Ethernet interface.
Use undo mdix-mode to restore the default.
mdix-mode { automdix | mdi| mdix }
undo mdix-mode
Ethernet interfaces operate in automdix mode.
automdix: Specifies that the interface negotiates pin roles with its peer.
mdi: Specifies that pins 1 and 2 are transmit pins and pins 3 and 6 are receive pins.
mdix: Specifies that pins 1 and 2 are receive pins and pins 3 and 6 are transmit pins.
# Configure GigabitEthernet 1/0/1 to operate in automdix mode.
[Sysname-GigabitEthernet1/0/1] mdix-mode automdix
port bridge enable
Use port bridge enable to enable bridging on an Ethernet interface.
Use undo port bridge enable to disable bridging on an Ethernet interface.
port bridge enable
Bridging is disabled on an Ethernet interface.
By default, the device drops packets whose outgoing interface and incoming interface are the same.
To enable the device to forward such packets rather than drop them, configure this command in Ethernet interface view. After the device receives a broadcast or unknown unicast packet, the device forwards the packet through all interfaces in the VLAN to which the incoming interface of the packet belongs.
Do not add interfaces configured with this command to an aggregation group.
# Enable bridging on GigabitEthernet 1/0/1.
[Sysname-GigabitEthernet1/0/1] port bridge enable
speed auto
Use speed auto to set options for speed autonegotiation.
speed auto { 10 | 100 | 1000 } *
undo speed
No option is set for speed autonegotiation.
100-Mbps or 1000-Mbps Layer 2 Ethernet interface view
10: Configures 10 Mbps as an option for speed autonegotiation.
100: Configures 100 Mbps as an option for speed autonegotiation.
1000: Configures 1000 Mbps as an option for speed autonegotiation.
The speed command and the speed auto command supersede each other. The most recent command that you configure takes effect. For example:
· If you configure speed auto 100 1000 and then speed 100 on the interface, the interface speed is forcibly set to 100 Mbps.
· If you configure speed 100 and then speed auto 100 1000 on the interface, the interface negotiates with its peer for a speed. The negotiated speed is either 100 Mbps or 1000 Mbps.
Speed autonegotiation enables an Ethernet interface to negotiate with its peer for the highest speed that both ends support. You can narrow down the speed option list for negotiation. To avoid negotiation failures, make sure a minimum of one speed option is supported at both ends.
# Configure GigabitEthernet 1/0/1 to use 10 Mbps and 1000 Mbps for speed negotiation.
[Sysname-GigabitEthernet1/0/1] speed auto 10 1000
speed
storm-constrain
Use storm-constrain to enable storm control and set thresholds for broadcast, multicast, or unknown unicast packets on an Ethernet interface.
Use undo storm-constrain to disable storm control for broadcast, multicast, unknown unicast, or all types of traffic.
storm-constrain { broadcast | multicast } { pps | kbps | ratio } upperlimit lowerlimit
undo storm-constrain { all | broadcast | multicast }
Traffic storm control is disabled.
all: Disables storm control for all types of traffic: broadcast, multicast.
broadcast: Enables or disables broadcast storm control.
multicast: Enables or disables multicast storm control.
pps: Sets storm control thresholds in pps.
kbps: Sets storm control thresholds in kbps.
ratio: Sets storm control thresholds as a percentage of the transmission capacity of the interface.
upperlimit: Sets the upper threshold, in pps, kbps, or percentage.
· If you specify the pps keyword, the value range for the upperlimit argument is 1 to 1.4881 × the interface bandwidth.
· If you specify the kbps keyword, the value range for the upperlimit argument is 1 to the interface bandwidth.
· If you specify the ratio keyword, the value range for the upperlimit argument is 1 to 100.
lowerlimit: Sets the lower threshold, in pps, kbps, or percentage.
· If you specify the pps keyword, the value range for the lowerlimit argument is 1 to 1.4881 × the interface bandwidth.
· If you specify the kbps keyword, the value range for the lowerlimit argument is 1 to the interface bandwidth.
· If you specify the ratio keyword, the value range for the lowerlimit argument is 1 to 100.
After you configure storm control for a type of traffic, the device collects the statistics for the type of traffic at the interval configured by using the storm-constrain interval command. When the type of traffic exceeds its upper threshold, the interface takes an action configured by using the storm-constrain control command.
The storm-constrain, broadcast-suppression, multicast-suppression, and unicast-suppression commands can suppress storms on an interface. The broadcast-suppression, multicast-suppression, and unicast-suppression commands use the chip to physically suppress traffic. They have less influence on the device performance than the storm-constrain command, which uses software to suppress traffic.
For the traffic suppression result to be determined, do not configure both storm control and storm suppression for the same type of traffic.
When configuring this command, make sure upperlimit is greater than lowerlimit.
# Enable broadcast storm control on GigabitEthernet 1/0/2, and set the upper and lower thresholds to 2000 kbps and 1500 kbps, respectively.
[Sysname-GigabitEthernet1/0/2] storm-constrain broadcast kbps 2000 1500
# Enable multicast storm control on GigabitEthernet 1/0/3, and set the upper and lower thresholds to 80% and 15%, respectively.
[Sysname] interface gigabitethernet 1/0/3
[Sysname-GigabitEthernet1/0/3] storm-constrain multicast ratio 80 15
Use storm-constrain control to set the action to take on an Ethernet interface when a type of traffic (multicast, or broadcast) exceeds the upper storm control threshold.
Use undo storm-constrain control to restore the default.
No action is taken on an Ethernet interface when a type of traffic exceeds the upper storm control threshold.
block: Blocks this type of traffic and forwards other types of traffic. Even though the interface does not forward the blocked traffic, it still counts the traffic. When the blocked traffic drops below the lower threshold, the port begins to forward the traffic.
shutdown: Goes down automatically. The interface goes down automatically and stops forwarding any traffic. When the blocked traffic drops below the lower threshold, the interface does not forward the traffic. To bring up the interface, use the undo shutdown command or disable storm control on the interface.
# Configure GigabitEthernet 1/0/1 to block a specific type of traffic when the type of traffic exceeds the upper storm control threshold.
[Sysname-GigabitEthernet1/0/1] storm-constrain control block
storm-constrain
storm-constrain enable log
Use storm-constrain enable log to enable an Ethernet interface to output log messages when it detects storm control threshold events.
Use undo storm-constrain enable log to disable an Ethernet interface from outputting log messages for storm control threshold events.
An Ethernet interface outputs log messages when monitored traffic exceeds the upper threshold or drops below the lower threshold from a value above the upper threshold.
# Enable GigabitEthernet 1/0/1 to output log messages when it detects storm control threshold events.
[Sysname-GigabitEthernet1/0/1] storm-constrain enable log
storm-constrain enable trap
Use storm-constrain enable trap to enable an Ethernet interface to send storm control threshold event traps.
Use undo storm-constrain enable trap to disable an Ethernet interface from sending storm control threshold event traps.
An interface sends out storm control threshold event traps when monitored traffic exceeds the upper threshold or drops below the lower threshold from a value above the upper threshold.
# Enable GigabitEthernet 1/0/1 to send traps when it detects storm control threshold events.
[Sysname-GigabitEthernet1/0/1] storm-constrain enable trap
Use storm-constrain interval to set the traffic polling interval of the storm control module.
Use undo storm-constrain interval to restore the default.
storm-constrain interval interval
The storm control module polls traffic statistics every 10 seconds.
interval: Sets the traffic polling interval of the storm control module. The value range is 1 to 300 seconds. To ensure network stability, as a best practice, do not use a traffic polling interval shorter than 10 seconds.
The traffic polling interval set by using the storm-constrain interval command is specific to storm control. To set the statistics polling interval of an interface, use the flow-interval command.
# Set the traffic statistics polling interval of the storm control module to 60 seconds.
[Sysname] storm-constrain interval 60
storm-constrain
virtual-cable-test
Use virtual-cable-test to test the cable connection of an Ethernet interface and display the test result.
virtual-cable-test
This command is not available on fiber ports.
If the link of an Ethernet interface is up, testing its cable connection will cause the link to go down and then up.
The test result is for reference only. The cable length detection error is up to 5 m (about 16 ft).
If a test item is not available, a hyphen (-) is displayed.
# Test the cable connection of GigabitEthernet 1/0/1.
[Sysname-GigabitEthernet1/0/1] virtual-cable-test
Cable status:
Pair A length: 12 meters
Pair B length: 13 meters
Pair C length: 14 meters
Pair D length: 15 meters
Pair A state: OK
Pair B state: OK
Pair C state: OK
Pair D state: OK
Pair Impedance mismatch: yes
Pair skew: 38 ns
Pair swap: swap
Pair polarity: swap
Insertion loss: 12 db
Return loss: 11 db
Near-end crosstalk: 13 db
Table 14 Command output
Cable status |
Cable status. |
Pair x length |
When the cable pair state is OK, this field displays the total length of the cable pair. When the cable pair is in any other state, this field displays the length from the local interface to the faulty point. |
Pair x state |
Cable pair state: · OK—The cable pair is in good condition. · Abnormal—The cable pair is abnormal. · Abnormal (open)—An open circuit is detected. · Abnormal (short)—A short circuit is detected. · Invalid—The test failed. |
Pair Impedance mismatch |
Pair Impedance state: · Yes—The pair impedance is match. · No—The pair impedance is mismatch. |
Layer 3 Ethernet interface or subinterface commands
mac-address
Use mac-address to set the MAC address of an Ethernet interface.
Use undo mac-address to restore the default.
mac-address mac-address
undo mac-address
No MAC address is set for a Layer 3 Ethernet interface.
mac-address: Specifies a MAC address in the format of H-H-H.
Do not set a VRRP-reserved MAC address for a Layer 3 Ethernet subinterface.
# Set the MAC address of GigabitEthernet 1/0/1 to 0001-0001-0001.
[Sysname-GigabitEthernet1/0/1] mac-address 1-1-1
mtu
Use mtu to set the MTU for an Ethernet interface or subinterface.
mtu size
undo mtu
The MTU of an Ethernet interface or subinterface is 1500 bytes.
size: Sets the MTU in bytes. The value range for this argument is 46 to 10240.
The MTU configured on an interface takes effect only on packets sent to the CPU for software forwarding. Configure the MTU as appropriate for interfaces in the network to avoid fragmentation.
If an interface supports both the mtu and ip mtu commands, the device fragments an IPv4 packet based on the MTU set by using the ip mtu command. For more information about the ip mtu command, see Layer 3—IP Services Command Reference.
# Set the MTU to 1430 bytes for GigabitEthernet 1/0/1.
[Sysname-GigabitEthernet1/0/1] mtu 1430
# Set the MTU to 1430 bytes for GigabitEthernet 1/0/1.1.
[Sysname] interface gigabitethernet 1/0/1.1
[Sysname-GigabitEthernet1/0/1.1] mtu 1430
