- H3C S10500X-G Switch Series Installation Guide-6W101
- 01-Installation Precautions
- 02-Preparing for Installation
- 03-Installing the Switch
- 04-Installing FRUs
- 05-Connecting Your Switch to the Network
- 06-Troubleshooting
- 07-Replacement Procedures
- 08-Appendix A Engineering Labels
- 09-Appendix B Cabling Recommendations
- 10-Appendix C Repackaging the Switch
06-Troubleshooting | 337.66 KB |
Configuration terminal display issues at startup
No display on the configuration terminal
Garbled display on the configuration terminal
System failures during operation
6 Troubleshooting
This chapter describes how to troubleshoot your switch.
TIP: · Noncompliant operating environment might cause switch failure. You need to clean your switch periodically and make sure the installation environment meets the requirements. For more information, see "Preparing for installation." · Periodically perform power-on test on spare switches. |
Troubleshooting methods
When your switch fails, you can use the following methods to troubleshoot the switch:
· At the CLI, you can use related commands to display hardware information, and locate hardware failures.
· Every MPU provides LEDs for the fans, power supplies, and modules. You can locate the failures according to the LED status on the MPU. For more information about the LED status on the MPU, see H3C S10500X-G Switch Series Hardware Information and Specifications.
· The MPUs and service modules provide port status LEDs, with which you can detect port failures. For more information about port status LEDs, see H3C S10500X-G Switch Series Hardware Information and Specifications.
If you cannot locate failures by following the guidelines in this chapter, contact the local agents or technical support engineers. For more information, see "Technical support."
Symptom
The configuration terminal does not have display when the switch is powered on.
Solution
To resolve the issue:
1. Verify that the power system is operating correctly.
2. Verify that the MPU is operating correctly.
3. Verify that the console cable connects the console port on the MPU correctly.
4. Verify that the console cable connects to the correct serial port on the terminal.
5. Verify that the console cable is in good quality and is operating correctly.
6. Verify that the following settings are configured for the terminal:
¡ Baud rate—9600.
¡ Data bits—8.
¡ Parity—None.
¡ Stop bits—1.
¡ Flow control—None.
¡ Emulation—VT100.
7. If the issue persists, contract H3C support.
Symptom
The configuration terminal displays garbled text when the switch is powered on.
Solution
1. Verify that the following settings are configured for the terminal:
¡ Baud rate—9600.
¡ Data bits—8.
¡ Parity—None.
¡ Stop bits—1.
¡ Emulation—VT100.
2. If the issue persists, contact H3C Support.
Symptom
A system failure occurs when the switch is operating.
Solution
1. Execute related commands to locate the fault.
2. If a configuration error is found, re-configure the switch or restore the factory-default settings.
For more information, see H3C S10500X-G Switch Series Fundamentals Configuration Guide.
3. If the issue persists, contact H3C Support.
Power supply failure
Symptom
The LEDs for the power supply are in the following states:
· On the MPU, the power supply status LED is steady red.
The power supply status LED is steady green only when all the power supplies are operating correctly. When a power supply is faulty, the power supply status LED is steady red.
· On the power supply, the LED is yellow or off.
For more information about the LEDs, see H3C S10500X-G Switch Series Hardware Information and Specifications.
NOTE: After a power supply is disconnected from its power source, the LED on the power supply stay on for several seconds. |
Solution
1. Verify that the power supply model is compatible with the switch.
2. Verify that more than one power switch on the chassis is turned on.
3. Remove and reconnect the power cord to verify that the power cord is connected securely.
4. Replace the power cord.
5. Remove and reinstall the power supply to verify that it is installed securely.
For more information, see "Installing power supplies."
6. Verify that the power source is supplying power correctly and the output voltage is at the acceptable voltage range.
7. Verify that the installed power supplies can meet the system power requirements.
8. Verify that the power supply does not have issues such as output short circuit, output overcurrent, output overvoltage, input undervoltage, or overtemperature.
9. Install the power supply in another empty power supply slot. If the power supply operates correctly, the previous power supply slot is faulty. If the power supply does not operate correctly, go to the next step.
10. Install a correctly operating power supply of the same model in the same slot, and connect it to the same power source. If the new power supply can operate correctly, the old power supply has failed. Contact your sales agent or local service engineer to replace the old power supply.
11. If the issue persists, contact H3C Support.
Fan tray failure
Symptom
The LEDs for the fan tray are in the following states:
· On the MPU, the FAN LED is steady red.
· On the fan tray, the OK/FAIL LED is steady red.
Solution
1. If all the LEDs are off, verify that the power supplies are operating correctly. For more information, see "Power supply failure."
2. Execute the display fan command in any view to display the operating state of the fan tray and rectify the fault:
¡ Whether the fan tray is present.
¡ Airflow direction of the fan.
¡ Number of fans in the fan tray.
¡ Operating status of each fan.
¡ Fan speed.
3. Verify that the air inlet and exhaust vents of the chassis are not blocked. If they are blocked, clean them to keep good ventilation.
4. Remove and reinstall the fan tray to make sure it is installed securely in the slot.
5. Verify that the empty module slots and power supply slots are installed with filler panels. Install filler panels in empty slots.
6. Replace the fan tray.
7. If the issue persists, contact H3C Support.
MPU failure
Symptom
The LED for the MPU is red or off.
Solution
1. Verify that the power system is operating correctly. For more information, see "Power supply failure."
2. Remove and reinstall the MPU to make sure it is installed securely. For more information, see "Installing MPUs."
3. Press the RESET button on the MPU to reset the MPU. After the MPU is reset, verify that the LED for the MPU is flashing green.
4. If the switch has empty MPU slots, install the MPU in the empty MPU slot, and verify that the MPU can operate correctly.
5. If the issue persists, contact H3C Support.
NOTE: The MPU slot number and service module slot number are marked at the left side of the MPU and service module slots, respectively. You can see the switch fabric module slot numbers through the openings in the fan trays. |
Service module failure
Symptom
The LEDs for the service modules are in the following states:
· On the service module, the status LED is red or off.
Solution
1. Verify that the MPU is operating correctly. For more information, see "MPU failure."
2. Verify that the system software is compatible with the service module. Upgrade the system software if it is not compatible with the service module.
3. Calculate the total power consumption, and make sure your power supplies can provide enough power. For more information, see H3C S10500X-G Switch Series Hardware Information and Specifications.
4. Remove and reinstall the service module to make sure it is installed securely. For more information about installing a service module, see "Installing service modules."
5. If the switch has empty service module slots, install the module in an empty service module slot. If the service module operates correctly, the previous slot is faulty.
6. If the issue persists, contact H3C Support.
Switch fabric module failure
Symptom
The LEDs for a switch fabric module are in the following states:
· On the MPU, the switch fabric module status LED is steady red or off.
· On the fan tray, the RUN/ALM LED for the switch fabric module is red or off.
The RUN/ALM LEDs on the fan tray correspond to the switch fabric module slots from left to right.
Figure6-1 Corresponding relations between the LEDs on the fan trays and switch fabric module slots (S10506X-G)
(1) LEDs for the switch fabric module slots 8 and 9 |
(2) LEDs for the switch fabric module slots 10 and 11 |
· On the switch fabric module, the RUN/ALM LED is red or off.
Solution
1. Verify that the MPU and the fan tray are operating correctly. For more information, see "MPU failure" and "Fan tray failure."
2. Verify that the switch fabric module is compatible with the system software. Upgrade the system software if it does not support the switch fabric module.
4. Remove and reinstall the switch fabric module to make sure the module is installed securely. You also need to verify that the ejector levers are locked securely in place. For more information, see "Installing switch fabric modules."
5. If the switch has empty switch fabric module slots, install the module in an empty switch fabric module slot. If the module operates correctly, the previous slot is faulty.
6. If the issue persists, contract H3C Support.
Interface failure
Symptom
The LED for the interface is off.
NOTE: A management Ethernet port has two LEDs, LINK and ACT. When the LINK LED is off, the management Ethernet port fails. |
Solution
1. Make sure the MPU or service module where the interface resides operates correctly. For more information, see "MPU failure" or "Service module failure."
2. Verify that the cable is connected correctly. For how to correctly connect a cable, see "Connecting the switch to the network."
3. Verify that the cable is in good condition. Use the cable to connect two interfaces of the same type that operate correctly. If the LEDs of the two interfaces are on, the cable is in good condition. Otherwise, the cable is faulty. Use a compliant cable to connect the interface. For more information, see H3C S10500X-G Switch Series Hardware Information and Specifications.
4. If the interface uses a transceiver module, perform the following tasks:
a. Make sure the interface type is compatible with the transceiver and that the transceiver is compatible with the cable. For more information, see H3C S10500X-G Switch Series Hardware Information and Specifications.
b. Replace the transceiver module.
5. Verify that the speed and duplex settings of the interfaces on the two ends are the same.
NOTE: · If an interface is brought down by the shutdown command, use the undo shutdown command to bring up the interface. · After an interface fails, if the switch has an idle interface of the same type, you can connect the cable to the idle interface. |
Technical support
Before contacting H3C Support, prepare the following information:
· Arrival time of the switch.
· Serial number of the chassis (on the label at the right of the rear panel).
· Software version, which you can view by using the display version command.
· Maintenance agreement or warranty card.
· Brief issue description.
· Brief explanation of the troubleshooting measures that have been taken.
