07-Layer 3—IP Services Command References
HomeSupportReference GuidesCommand ReferencesH3C MSR610[810][830][1000S][2600][3600] Routers @CR@(V7)-R6749-6W10007-Layer 3—IP Services Command References
22-Lighttpd service commands
22-Lighttpd service commands 52.45 KB
Lighttpd Web service commands
The following compatibility matrixes show the support of hardware platforms for lighttpd Web services:
Hardware
Lighttpd Web service compatibility
MSR610
Yes
MSR810, MSR810-W, MSR810-W-DB, MSR810-LM, MSR810-W-LM, MSR810-10-PoE, MSR810-LM-HK, MSR810-W-LM-HK, MSR810-LM-CNDE-SJK, MSR810-CNDE-SJK, MSR810-EI, MSR810-LM-EA, MSR810-LM-EI
Yes
MSR810-LMS, MSR810-LUS
No
MSR810-SI, MSR810-LM-SI
No
MSR810-LMS-EA, MSR810-LME
Yes
MSR1004S-5G, MSR1004S-5G-CN
Yes
MSR1104S-W, MSR1104S-W-CAT6, MSR1104S-5G-CN, MSR1104S-W-5G-CN
Yes
MSR2600-6-X1, MSR2600-15-X1, MSR2600-15-X1-T
No
MSR2600-10-X1
No
MSR 2630
No
MSR3600-28, MSR3600-51
No
MSR3600-28-SI, MSR3600-51-SI
No
No
MSR3600-28-G-DP, MSR3600-51-G-DP
No
MSR3610-I-DP, MSR3610-IE-DP, MSR3610-IE-ES, MSR3610-IE-EAD, MSR-EAD-AK770, MSR3610-I-IG, MSR3610-IE-IG
No
MSR3610-X1, MSR3610-X1-DP, MSR3610-X1-DC, MSR3610-X1-DP-DC, MSR3620-X1, MSR3640-X1
No
MSR3610, MSR3620, MSR3620-DP, MSR3640, MSR3660
No
MSR3610-G, MSR3620-G
No
MSR3640-G
No
MSR3640-X1-HI
No
Hardware
MSR810-W-WiNet, MSR810-LM-WiNet
Yes
MSR830-4LM-WiNet
Yes
MSR830-5BEI-WiNet, MSR830-6EI-WiNet, MSR830-10BEI-WiNet
Yes
MSR830-6BHI-WiNet, MSR830-10BHI-WiNet
Yes
MSR2600-6-WiNet
No
MSR2600-10-X1-WiNet
No
MSR2630-WiNet
No
MSR3600-28-WiNet
No
MSR3610-X1-WiNet
No
MSR3610-WiNet, MSR3620-10-WiNet, MSR3620-DP-WiNet, MSR3620-WiNet, MSR3660-WiNet
No
Hardware
MSR860-6EI-XS
Yes
MSR860-6HI-XS
Yes
MSR2630-XS
No
MSR3600-28-XS
No
MSR3610-XS
No
MSR3620-XS
No
MSR3610-I-XS
No
MSR3610-IE-XS
No
MSR3620-X1-XS
No
MSR3640-XS
No
MSR3660-XS
No
Hardware
MSR810-LM-GL
Yes
MSR810-W-LM-GL
Yes
MSR830-6EI-GL
Yes
MSR830-10EI-GL
Yes
MSR830-6HI-GL
Yes
MSR830-10HI-GL
Yes
MSR1004S-5G-GL
Yes
MSR2600-6-X1-GL
No
MSR3600-28-SI-GL
No
light-http server directory
Use light-http server directory to specify the lighttpd Web service working directory.
light-http server directory directory
undo light-http server directory
No lighttpd Web service working directory is specified.
directory: Specifies the lighttpd Web service working directory.
If the lighttpd Web server is already enabled, the specified lighttpd Web service working directory takes effect after you disable the lighttpd Web server and then enable the server again.
To use the lighttpd Web server to provide HTTPS access service, you must save the required certificate to the lighttpd Web service working directory.
# Set the lighttpd Web service working directory to flash:/lighttpd.
[Sysname] light-http server directory flash:/lighttpd
light-http server enable
Use light-http server enable to enable the lighttpd Web server.
Use undo light-http server enable to disable the lighttpd Web server.
The lighttpd Web server is disabled.
Specify the lighttpd Web working directory before enabling the lighttpd Web server.
For the lighttpd Web server to provide lightweight HTTP or HTTPS access service correctly, make sure it uses different service ports than other services. By default, the lightweight HTTP service port number is 80 and the lightweight HTTPS service port number is 443.
# Enable the lighttpd Web server.
[Sysname] light-http server enable
light-http server http-port
Use light-http server http-port to specify the lightweight HTTP service port number.
Use undo light-http server http-port to restore the default.
light-http server http-port port-number
The lightweight HTTP service port number is 80.
port-number: Specifies the lightweight HTTP service port number, in the range of 1 to 65535.
When the lighttpd Web server is enabled, changing the lightweight HTTP service port number re-enables the lighttpd Web server and closes all lightweight HTTP and HTTPS connections. To log in again, users must enter the new URL in the Web browser's address bar.
# Set the lightweight HTTP service port number to 8080.
[Sysname] light-http server http-port 8080
Current configuration will restart the lighttpd service. Continue? [Y/N]:
light-http server https-port
Use light-http server https-port to specify the lightweight HTTPS service port number.
Use undo light-http server https-port to restore the default.
light-http server https-port port-number
The lightweight HTTPS service port number is 443.
port-number: Specifies the lightweight HTTPS service port number, in the range of 1 to 65535.
When the lighttpd Web server is enabled, changing the lightweight HTTPS service port number re-enables the lighttpd Web server and closes all lightweight HTTP and HTTPS connections. To log in again, users must enter the new URL in the Web browser's address bar.
# Set the lightweight HTTPS service port number to 8081.
[Sysname] light-http server https-port 8081
  • Become a Partner
  • Partner Resources
