07-Layer 3—IP Services Command References
HomeSupportReference GuidesCommand ReferencesH3C MSR610[810][830][1000S][2600][3600] Routers @CR@(V7)-R6749-6W10007-Layer 3—IP Services Command References
17-AFT commands
17-AFT commands 224.49 KB
AFT commands
The following compatibility matrixes show the support of hardware platforms for AFT:
Hardware
AFT compatibility
MSR610
Yes
MSR810, MSR810-W, MSR810-W-DB, MSR810-LM, MSR810-W-LM, MSR810-10-PoE, MSR810-LM-HK, MSR810-W-LM-HK, MSR810-LM-CNDE-SJK, MSR810-CNDE-SJK, MSR810-EI, MSR810-LM-EA, MSR810-LM-EI
Yes
MSR810-LMS, MSR810-LUS
No
MSR810-SI, MSR810-LM-SI
No
MSR810-LMS-EA, MSR810-LME
Yes
MSR1004S-5G, MSR1004S-5G-CN
Yes
MSR1104S-W, MSR1104S-W-CAT6, MSR1104S-5G-CN, MSR1104S-W-5G-CN
Yes
MSR2600-6-X1, MSR2600-15-X1, MSR2600-15-X1-T
Yes
MSR2600-10-X1
Yes
MSR 2630
Yes
MSR3600-28, MSR3600-51
Yes
MSR3600-28-SI, MSR3600-51-SI
Yes
Yes
MSR3600-28-G-DP, MSR3600-51-G-DP
Yes
MSR3610-I-DP, MSR3610-IE-DP, MSR3610-IE-ES, MSR3610-IE-EAD, MSR-EAD-AK770, MSR3610-I-IG, MSR3610-IE-IG
Yes
MSR3610-X1, MSR3610-X1-DP, MSR3610-X1-DC, MSR3610-X1-DP-DC, MSR3620-X1, MSR3640-X1
Yes
MSR 3610, MSR 3620, MSR 3620-DP, MSR 3640, MSR 3660
Yes
MSR3610-G, MSR3620-G
Yes
MSR3640-G
Yes
MSR3640-X1-HI
Yes
Hardware
AFT compatibility
MSR810-W-WiNet, MSR810-LM-WiNet
Yes
MSR830-4LM-WiNet
Yes
MSR830-5BEI-WiNet, MSR830-6EI-WiNet, MSR830-10BEI-WiNet
Yes
MSR830-6BHI-WiNet, MSR830-10BHI-WiNet
Yes
MSR2600-6-WiNet
Yes
MSR2600-10-X1-WiNet
Yes
MSR2630-WiNet
Yes
MSR3600-28-WiNet
Yes
MSR3610-X1-WiNet
Yes
MSR3610-WiNet, MSR3620-10-WiNet, MSR3620-DP-WiNet, MSR3620-WiNet, MSR3660-WiNet
Yes
Hardware
AFT compatibility
MSR860-6EI-XS
Yes
MSR860-6HI-XS
Yes
MSR2630-XS
Yes
MSR3600-28-XS
Yes
MSR3610-XS
Yes
MSR3620-XS
Yes
MSR3610-I-XS
Yes
MSR3610-IE-XS
Yes
MSR3620-X1-XS
Yes
MSR3640-XS
Yes
MSR3660-XS
Yes
Hardware
AFT compatibility
MSR810-LM-GL
Yes
MSR810-W-LM-GL
Yes
MSR830-6EI-GL
Yes
MSR830-10EI-GL
Yes
MSR830-6HI-GL
Yes
MSR830-10HI-GL
Yes
MSR1004S-5G-GL
Yes
MSR2600-6-X1-GL
Yes
MSR3600-28-SI-GL
Yes
address
Use address to add an address range to an AFT address group.
Use undo address to remove an address range from an AFT address group.
address start-address end-address
undo address start-address end-address
No address ranges exist.
AFT address group view
start-address end-address: Specifies the start and end IP addresses for an address range. The end address cannot be lower than the start address. If they are the same, the address range has only one IP address.
An AFT address group is a set of address ranges. Dynamic AFT translates an IPv6 address to an IPv4 address in one of the address ranges.
Each address range can contain a maximum of 256 addresses.
Make sure the address ranges do not overlap.
The device supports a maximum of 4096 address ranges in total for all AFT address groups.
# Add two address ranges to AFT address group 2.
[Sysname] aft address-group 2
[Sysname-aft-address-group-2] address 10.1.1.1 10.1.1.15
[Sysname-aft-address-group-2] address 10.1.1.20 10.1.1.30
aft address-group
aft address-group
Use aft address-group to create an AFT address group and enter its view, or enter the view of an existing AFT address group.
Use undo aft address-group to delete an AFT address group.
aft address-group group-id
undo aft address-group group-id
No AFT address groups exist.
group-id: Assigns an ID to the address group. The value range for this argument is 0 to 65535.
An AFT address group is a set of address ranges. Use the address command to add an address range.
The AFT address group is used in dynamic AFT. Dynamic AFT translates the source address of an IPv6 packet to an IPv4 address in the address group.
# Create AFT address group 1 and enter its view.
[Sysname] aft address-group 1
[Sysname-aft-address-group-1]
address
aft v6tov4 source
display aft address-group
display aft configuration
aft alg
Use aft alg to enable AFT ALG for the specified or all supported protocols.
Use undo aft alg to disable AFT ALG for the specified or all supported protocols.
aft alg { all | dns | ftp | h323 | http | icmp-error | rtsp | sip }
undo aft alg { all | dns | ftp | h323 | http | icmp-error | rtsp | sip }
AFT ALG is enabled for DNS, FTP, H.323, HTTP, ICMP error messages, RSTP, and SIP.
all: Enables AFT ALG for all supported protocols.
dns: Enables AFT ALG for DNS.
ftp: Enables AFT ALG for FTP.
h323: Enables AFT ALG for H.323.
http: Enables AFT ALG for HTTP.
icmp-error: Enables AFT ALG for ICMP error packets.
rtsp: Enables AFT ALG for RSTP.
sip: Enables AFT ALG for SIP.
AFT ALG translates address or port information in the application layer payloads.
For example, an FTP application includes a data connection and a control connection. The IP address and port number for the data connection depend on the payload information of the control connection. This requires AFT ALG to translate the address and port information.
You can execute this command multiple times to enable AFT ALG for different protocols.
# Enable AFT ALG for FTP.
[Sysname] aft alg ftp
aft enable
Use aft enable to enable AFT on an interface.
Use undo aft enable to disable AFT on an interface.
aft enable
undo aft enable
AFT is disabled on an interface.
Interface view
You must enable AFT on interfaces connected to the IPv4 network and interfaces connected to the IPv6 network.
# Enable AFT on GigabitEthernet 1/0/1.
[Sysname-GigabitEthernet1/0/1] aft enable
aft log enable
Use aft log enable to enable AFT logging.
Use undo aft log enable to disable AFT logging.
aft log enable
undo aft log enable
AFT logging is disabled.
For security auditing, you can enable AFT logging to record AFT session information. An AFT session is a session whose source and destination IP addresses are translated by AFT.
AFT can log the following events:
·     An AFT port block is created.
·     An AFT port block is deleted.
·     An AFT session is established.
To log AFT session establishment events, you must also execute the aft log flow-begin command.
·     An AFT session is removed.
To log AFT session removal events, you must also execute the aft log flow-end command.
The logs are sent to the information center of the device. For the logs to be output correctly, you must also configure the information center on the device. For more information about information center configuration, see Network Management and Monitoring Configuration Guide.
# Enable AFT logging.
[Sysname] aft log enable
aft log flow-begin
aft log flow-end
aft log flow-begin
Use aft log flow-begin to enable AFT session establishment logging.
Use undo aft log flow-begin to disable AFT session establishment logging.
aft log flow-begin
AFT session establishment logging is disabled.
This feature enables the AFT module to generate a log entry for every AFT session establishment event.
AFT session establishment logging takes effect only after you enable AFT logging.
# Enable AFT session establishment logging.
[Sysname] aft log flow-begin
aft log enable
aft log flow-end
aft log flow-end
Use aft log flow-end to enable AFT session removal logging.
Use undo aft log flow-end to disable AFT session removal logging.
aft log flow-end
AFT session removal logging is disabled.
This feature enables the AFT module to generate a log entry for every AFT session removal event.
AFT session removal logging takes effect only after you enable AFT logging.
# Enable AFT session removal logging.
[Sysname] aft log flow-end
aft log enable
aft log flow-begin
aft log port-block
Use aft log port-block to enable AFT port block logging.
Use undo aft log port-block to disable AFT port block logging.
aft log port-block { alarm | assign | withdraw }
undo aft log port-block { alarm | assign | withdraw }
AFT port block logging is disabled.
alarm: Enables logging for port exhaustion in an AFT port block.
assign: Enables logging for AFT port block assignment.
withdraw: Enables logging for AFT port block withdrawal.
After you configure this command, AFT generates logs when an AFT port block is assigned or withdrawn, and an AFT port block has assigned all its ports.
AFT port block logging takes effect only after you execute the aft log enable command to enable AFT logging.
# Enable AFT port block logging.
[Sysname] aft log port-block assign
aft log enable
aft log port-block usage threshold
Use aft log port-block usage threshold to set the AFT port block usage threshold.
Use undo aft log port-block usage threshold to restore the default.
aft log port-block usage threshold threshold-value
The AFT port block usage threshold is 90%.
threshold-value: Specifies a threshold in the range of 40 to 100 in percentage.
A log is generated when the AFT port block usage exceeds the threshold.
This command takes effect only after you use the aft log enable command to enable AFT logging.
# Set the AFT port block usage threshold to 60%.
[Sysname] aft log port-block usage threshold 60
aft log enable
aft port-block synchronization enable
Use aft port-block synchronization enable to enable dynamic AFT port block mapping synchronization.
Use undo aft port-block synchronization enable to disable dynamic AFT port block mapping synchronization.
Dynamic AFT port block mapping synchronization is enabled.
Dynamic AFT port block mapping synchronization enables the master and the backup to synchronize dynamic port block mappings, which ensures smooth switchover without service interruption.
In an IRF network, dynamic AFT port block mapping synchronization takes effect after you enable session synchronization for stateful failover by using the session synchronization enable command.
# Enable dynamic AFT port block mapping synchronization.
[Sysname] aft port-block synchronization enable
aft v6tov4 source
session synchronization enable (Security Command Reference)
aft port-block-group
Use aft port-block-group to create an AFT port block group and enter its view, or enter the view of an existing AFT port block group.
Use undo aft port-block-group to delete an AFT port block group.
aft port-block-group block-group-id
undo aft port-block-group block-group-id
No AFT port block groups exist.
block-group-id: Assigns an ID to the AFT port block group. The value range is 0 to 65535.
An AFT port block group can be used in a port block group-based IPv6-to-IPv4 source address static translation policy for IPv6-to-IPv4 source address translation.
An AFT port block group contains the following settings:
·     Address ranges:
¡     IPv4 address ranges used for IPv6-to-IPv4 source address translation, specified by using the ip-address command.
¡     IPv6 prefix ranges used to match the IPv6 addresses to be translated, specified by using the ipv6-prefix command.
·     Port range specified by using the port-range command. The port range will be divided into port blocks of the specified port block size. Each port block is paired with an IPv4 address to match an IPv6 prefix for IPv6-to-IPv4 source address translation.
·     Port block size specified by using the block-size command.
# Create AFT port block group 1 and enter its view.
[Sysname] aft port-block-group 1
[Sysname-aft-port-block-group-1]
aft v6tov4 source
block-size
ip-address
ipv6-prefix
port-range
aft port-load-balance enable
Use aft port-load-balance enable to enable AFT port halving.
Use undo aft port-load-balance enable to disable AFT port halving.
aft port-load-balance enable slot slot-number
AFT port halving is disabled.
slot slot-number: Specifies an IRF member device by its member ID. This device will use the lower half of the port block.
AFT supports IRF hot backup in active/standby and dual-active mode. The AFT configuration for IRF hot backup depends on the deployment mode.
·     In dual-active mode, if the two IRF member devices in an IRF fabric use the same AFT address group, the devices might map different IPv6 addresses and ports to the same IPv4 address and port. To avoid this situation, enable AFT port halving on the devices. After you enable AFT port halving, each port block will be equally divided between the two devices. The two devices will use different ports to translate packets from different IP addresses, avoiding port assignment conflicts.
·     You do not need to enable AFT port halving on the IRF member devices in active/standby mode or when the devices work in standalone mode.
This command is exclusive with the aft remote-backup port-alloc command.
# Enable AFT port halving.
[Sysname] aft port-load-balance enable slot 1
aft prefix-general
Use aft prefix-general to configure a general prefix.
Use undo aft prefix-general to delete a general prefix.
aft prefix-general prefix-general prefix-length
undo aft prefix-general prefix-general prefix-length
No general prefixes exist.
prefix-general: Specifies the general prefix.
prefix-length: Specifies the prefix length. The value for this argument can be 32, 40, 48, 56, 64, or 96.
A general prefix is an IPv6 address prefix of 32, 40, 48, 56, 64, or 96 bits. A general prefix can be used for source and destination address translation between IPv4 and IPv6.
When a general prefix is used alone, it provides IPv6-to-IPv4 source and destination address translation. If a source or destination IPv6 address matches the general prefix, AFT translates it to the embedded IPv4 address.
When a general prefix is used in the aft v4tov6 source or aft v4tov6 destination command, it provides IPv4-to-IPv6 source or destination address translation. If a source or destination IPv4 address matches the ACL, AFT constructs the IPv6 address by using the general prefix and the IPv4 address.
A general prefix cannot be on the same subnet as any interface on the device.
A general prefix must be different from a NAT64 prefix or an IVI prefix.
# Specify 2000:db8e:: as a general prefix and set its prefix length to 32.
[Sysname] aft prefix-general 2000:db8e:: 32
aft v4tov6 source
aft prefix-ivi
Use aft prefix-ivi to configure an IVI prefix.
Use undo aft prefix-ivi to delete an IVI prefix.
aft prefix-ivi prefix-ivi
undo aft prefix-ivi prefix-ivi
No IVI prefixes exist.
prefix-ivi: Specifies an IVI prefix.
An IVI prefix is an IPv6 address prefix whose length is fixed at 32 bits. An IVI prefix can be used for IPv6-to-IPv4 source address translation and IPv4-to-IPv6 destination address translation.
When an IVI prefix is used alone, it provides IPv6-to-IPv4 source address translation. If a source IPv6 address matches the IVI prefix, AFT translates it to the embedded IPv4 address.
When an IVI prefix is used in the aft v4tov6 destination command, it provides IPv4-to-IPv6 destination address translation. If a destination IPv4 address matches the ACL, AFT constructs the IPv6 address by using the IVI prefix and the IPv4 address.
An IVI prefix must be different from a NAT64 prefix or a general prefix.
# Specify 3000:db8e:: as an IVI prefix.
[Sysname] aft prefix-ivi 3000:db8e::
aft prefix-nat64
Use aft prefix-nat64 to configure a NAT64 prefix.
Use undo aft prefix-nat64 to delete a NAT64 prefix.
aft prefix-nat64 prefix-nat64 prefix-length
undo aft prefix-nat64 prefix-nat64 prefix-length
No NAT64 prefixes exist.
prefix-nat64: Specifies a NAT64 prefix.
prefix-length: Specifies the NAT64 prefix length. The value for this argument can be 32, 40, 48, 56, 64, or 96.
A NAT64 prefix is an IPv6 address prefix of 32, 40, 48, 56, 64, or 96 bits. A NAT64 prefix can be used for IPv4-to-IPv6 source address translation and IPv6-to-IPv4 destination address translation.
When a NAT64 prefix is used alone, it provides IPv6-to-IPv4 destination address translation. If a destination IPv6 address matches the NAT64 prefix, AFT translates it to the embedded IPv4 address.
When a NAT64 prefix is used alone or in the aft v4tov6 source command, it also provides IPv4-to-IPv6 source address translation. AFT constructs the IPv6 address by using the NAT64 prefix and the source IPv4 address. If the NAT64 prefix is used in the aft v4tov6 source command, AFT only translates packets permitted by the ACL.
When you configure a 96-bit NAT64 prefix, make sure bits 64 through 71 are all 0.
A NAT64 prefix cannot be on the same subnet as any of the interfaces on the device.
A NAT64 prefix must be different from an IVI prefix or a general prefix.
# Specify 2000:db8e:: as a NAT64 prefix and set its prefix length to 32.
[Sysname] aft prefix-nat64 2000:db8e:: 32
aft v4tov6 source
Use aft remote-backup port-alloc to specify AFT port ranges for the two devices in the HA group.
Use undo remote-backup port-alloc to restore the default.
aft remote-backup port-alloc { primary | secondary }
undo aft remote-backup port-alloc
The two devices in the HA group share AFT port resources.
primary: Specifies the lower half of the port block.
secondary: Specifies the higher half of the port block.
In the HA group in dual-active mode, different IP+port combinations on the two devices might be translated to the same AFT IP+port resources due to the following reasons:
·     The two devices in the HA group share AFT addresses.
·     The same AFT port range is assigned to each device.
To avoid this situation, execute this command on the primary device to equally divide the port resources for the two devices. Executing the command on the primary device also makes the remaining half of the port block be automatically assigned to the secondary device. For example, if you execute the aft remote-backup port-alloc secondary command on the primary device, the aft remote-backup port-alloc primary command is automatically executed on the secondary device.
You do not need to execute this command for the HA group in active/standby mode. No port conflict exists in active/standby mode because only one device processes AFT services.
This command is exclusive with the aft port-load-balance enable command.
# Specify the primary device in the HA group to use the lower half of the port block.
[Sysname] aft remote-backup port-alloc primary
aft turn-off tos
Use aft turn-off tos to set the ToS field to 0 for IPv4 packets translated from IPv6 packets.
Use undo aft turn-off tos to restore the default.
aft turn-off tos
The ToS field value of translated IPv4 packets is the same as the Traffic Class field value of original IPv6 packets.
# Set the ToS field to 0 for IPv4 packets translated from IPv6 packets.
[Sysname] aft turn-off tos
aft turn-off traffic-class
Use aft turn-off traffic-class to set the Traffic Class field to 0 for IPv6 packets translated from IPv4 packets.
Use undo aft turn-off traffic-class to restore the default.
The Traffic Class field value of translated IPv6 packets is the same as the ToS field value of original IPv4 packets.
# Set the Traffic Class field to 0 for IPv6 packets translated from IPv4 packets.
[Sysname] aft turn-off traffic-class
aft v4server
Use aft v4server to configure an AFT mapping for an IPv4 internal server.
Use undo aft v4server to delete an AFT mapping for an IPv4 internal server.
aft v4server protocol protocol-type ipv6-destination-address ipv6-port-number [ vpn-instance ipv6-vpn-instance-name ] ipv4-destination-address ipv4-port-number [ vpn-instance ipv4-vpn-instance-name ] [ vrrp virtual-router-id ]
undo aft v4server protocol { tcp | udp } ipv6-destination-address ipv6-port-number [ vpn-instance ipv6-vpn-instance-name ]
No AFT mapping for an IPv4 internal server is configured.
protocol protocol-type: Specifies a transport layer protocol by its type. The protocol-type argument can be tcp or udp.
ipv6-destination-address: Specifies an IPv6 address.
ipv6-port-number: Specifies an IPv6 port number in the range of 0 to 65535.
vpn-instance ipv6-vpn-instance-name: Specifies an IPv6 MPLS L3VPN instance to which the IPv6 address belongs. The ipv6-vpn-instance-name argument is a case-sensitive string of 1 to 31 characters. If the IPv6 address belongs to the public network, do not specify this option.
ipv4-destination-address: Specifies an IPv4 address.
ipv4-port-number: Specifies an IPv4 port number in the range of 0 to 65535.
vpn-instance ipv4-vpn-instance-name: Specifies an IPv4 MPLS L3VPN instance to which the IPv4 address belongs. The ipv4-vpn-instance-name argument is a case-sensitive string of 1 to 31 characters. If the IPv4 address belongs to the public network, do not specify this option.
vrrp virtual-router-id: Binds the IPv4 server to a VRRP group on the IPv6 network. The virtual-router-id parameter represents the virtual router ID of the VRRP group, in the range of 1 to 255.
This command maps the IPv4 address and port number of an IPv4 server to an IPv6 address and port number. IPv6 hosts can use the IPv6 address and port number to access the services provided by the IPv4 server.
An IPv4 server can be bound to only one VRRP group. You can execute this command multiple times to change the bound VRRP group for the IPv4 server.
The AFT mappings for different IPv4 internal servers cannot be the same.
# Map IPv4 address 2.2.2.123 and port number 1720 of an IPv4 internal server to IPv6 address 3001::5  and port number 1720 for TCP packets.
[Sysname] aft v4server protocol tcp 3001::5 1720 2.2.2.123 1720
Use aft v4tov6 destination to configure an IPv4-to-IPv6 destination address translation policy.
Use undo aft v4tov6 destination to delete an IPv4-to-IPv6 destination address translation policy.
aft v4tov6 destination acl { name ipv4-acl-name prefix-ivi prefix-ivi [ vpn-instance ipv6-vpn-instance-name ] | number ipv4-acl-number { prefix-general prefix-general prefix-length | prefix-ivi prefix-ivi [ vpn-instance ipv6-vpn-instance-name ] } }
undo aft v4tov6 destination acl { name ipv4-acl-name | number ipv4-acl-number }
No IPv4-to-IPv6 destination address translation policies exist.
acl: Identifies IPv4 packets for address translation. AFT translates destination addresses for IPv4 packets permitted by the ACL.
name ipv4-acl-name: Specifies an IPv4 ACL by its name. The ipv4-acl-name argument is a case-insensitive string of 1 to 63 characters. It must start with an English letter and to avoid confusion, it cannot be all.
number ipv4-acl-number: Specifies an IPv4 ACL by its number in the range of 2000 to 3999.
prefix-general prefix-general prefix-length: Specifies a general prefix and its prefix length. The value for the prefix-length argument can be 32, 40, 48, 56, 64, or 96. AFT uses the general prefix to translate destination addresses for packets permitted by the ACL.
prefix-ivi prefix-ivi: Specifies an IVI prefix. AFT uses the IVI prefix to translate destination addresses for packets permitted by the ACL.
vpn-instance ipv6-vpn-instance-name: Specifies an IPv6 MPLS L3VPN instance to which translated IPv6 addresses belong. The ipv6-vpn-instance-name argument is a case-sensitive string of 1 to 31 characters. If the IPv6 addresses belong to the public network, do not specify this option.
You must specify different ACLs for different IPv4-to-IPv6 destination address translation policies.
You can specify a nonexistent IVI prefix or general prefix in a policy, but the policy takes effect only after you configure the prefix.
# Configure the device to use IVI prefix 3000:db8e:: to translate IPv4 destination addresses to IPv6 addresses for IPv4 packets permitted by ACL 2000.
[Sysname] aft v4tov6 destination acl number 2000 prefix-ivi 3000:db8e::
# Configure the device to use general prefix 2000:db8e::/32 to translate IPv4 destination addresses to IPv6 addresses for IPv4 packets permitted by ACL 2000.
[Sysname] aft v4tov6 destination acl number 2000 prefix-general 2000:db8e:: 32
aft prefix-general
aft prefix-ivi
aft v4tov6 source
Use aft v4tov6 source to configure an IPv4-to-IPv6 source address translation policy.
Use undo aft v4tov6 source to delete an IPv4-to-IPv6 source address translation policy.
IPv4-to-IPv6 source address static mapping:
aft v4tov6 source ipv4-address [ vpn-instance ipv4-vpn-instance-name ] ipv6-address [ vpn-instance ipv6-vpn-instance-name ] [ vrrp virtual-router-id ]
undo aft v4tov6 source ipv4-address [ vpn-instance ipv4-vpn-instance-name ]
IPv4-to-IPv6 source address translation policy using a NAT64 prefix or general prefix:
aft v4tov6 source acl { name ipv4-acl-name prefix-nat64 prefix-nat64 prefix-length [ vpn-instance ipv6-vpn-instance-name ] | number ipv4-acl-number { prefix-general prefix-general prefix-length | prefix-nat64 prefix-nat64 prefix-length [ vpn-instance ipv6-vpn-instance-name ] } }
undo aft v4tov6 source acl { name ipv4-acl-name | number ipv4-acl-number }
No IPv4-to-IPv6 source address translation policies exist.
ipv4-address: Specifies an IPv4 address.
ipv6-address: Specifies an IPv6 address. The IPv6 address in a static mapping cannot be on the same subnet as any interface on the device.
acl: Identifies IPv4 packets for address translation. AFT translates source addresses for packets permitted by the ACL.
prefix-general prefix-general prefix-length: Specifies a general prefix and its prefix length. The value for the prefix-length argument can be 32, 40, 48, 56, 64, or 96. AFT uses the general prefix to translate source IPv4 address for packets permitted by the ACL.
prefix-nat64 prefix-nat64 prefix-length: Specifies a NAT64 prefix and its prefix length. The value for the prefix-length argument can be 32, 40, 48, 56, 64, or 96. AFT uses the NAT64 prefix to translate source IPv4 address for packets permitted by the ACL.
vrrp virtual-router-id: Binds the IPv4-to-IPv6 source address translation policy to a VRRP group on the IPv6 network. The virtual-router-id parameter represents the virtual router ID of the VRRP group, in the range of 1 to 255.
An IPv4-to-IPv6 source address translation policy can be bound to only one VRRP group. You can execute this command multiple times to change the bound VRRP group for the policy.
The IPv4 or IPv6 addresses in different static mappings cannot be the same.
You must specify different ACLs for IPv4-to-IPv6 source address translation policies that use NAT64 prefixes or general prefixes.
You can specify a nonexistent NAT64 prefix or general prefix in a policy, but the policy takes effect only after you configure the prefix.
# Map IPv4 source address 2.2.2.123 to IPv6 source address 3001::5.
[Sysname] aft v4tov6 source 2.2.2.123 3001::5
# Configure the device to use NAT64 prefix 2000::/32 to translate IPv4 source addresses to IPv6 addresses for IPv4 packets permitted by ACL 2000.
[Sysname] aft prefix-nat64 2000:: 32
[Sysname] aft v4tov6 source acl number 2000 prefix-nat64 2000:: 32
# Configure the device to use general prefix 3000::/32 to translate IPv4 source addresses to IPv6 addresses for IPv4 packets permitted by ACL 2000.
[Sysname] aft v4tov6 source acl number 2000 prefix-general 3000:: 32
aft prefix-general
aft prefix-nat64
aft v6server
Use aft v6server to configure an AFT mapping for an IPv6 internal server.
Use undo aft v6server to delete an AFT mapping for an IPv6 internal server.
aft v6server protocol protocol-type ipv4-destination-address ipv4-port-number [ vpn-instance ipv4-vpn-instance-name ] ipv6-destination-address ipv6-port-number [ vpn-instance ipv6-vpn-instance-name ] [ vrrp virtual-router-id ]
undo aft v6server protocol protocol-type ipv4-destination-address ipv4-port-number [ vpn-instance ipv4-vpn-instance-name ]
An IPv6 internal server does not have an AFT mapping.
vrrp virtual-router-id: Binds the IPv6 server to a VRRP group on the IPv4 network. The virtual-router-id parameter represents the virtual router ID of the VRRP group, in the range of 1 to 255.
This command maps the IPv6 address and port number of an IPv6 server to an IPv4 address and port number.
An IPv6 server can be bound to only one VRRP group. You can execute this command multiple times to change the bound VRRP group for the IPv6 server.
The AFT mappings for different IPv6 internal servers cannot be the same.
# Map IPv6 address 3001::5 and port number 1720 of an IPv6 internal server to IPv4 address 2.2.2.123 and port number 1720 for TCP packets.
[Sysname] aft v6server protocol tcp 2.2.2.123 1720 3001::5 1720
aft v6tov4 source
Use aft v6tov4 source to configure an IPv6-to-IPv4 source address translation policy.
Use undo aft v6tov4 source to delete an IPv6-to-IPv4 source address translation policy.
IPv6-to-IPv4 source address static mapping:
aft v6tov4 source ipv6-address [ vpn-instance ipv6-vpn-instance-name ] ipv4-address [ vpn-instance ipv4-vpn-instance-name ] [ vrrp virtual-router-id ]
undo aft v6tov4 source ipv6-address [ vpn-instance ipv6-vpn-instance-name ]
IPv6-to-IPv4 source address translation policy:
aft v6tov4 source { acl ipv6 { name ipv6-acl-name | number ipv6-acl-number } | prefix-nat64 prefix-nat64 prefix-length [ vpn-instance ipv6-vpn-instance-name ] } { address-group group-id [ no-pat | port-block-size blocksize  [ extended-block-number extended-block-number ] [ port-range start-port-number end-port-number ]] | interface interface-type interface-number } [ vpn-instance ipv4-vpn-instance-name ]
undo aft v6tov4 source { acl ipv6 { name ipv6-acl-name | number ipv6-acl-number } | prefix-nat64 prefix-nat64 prefix-length [ vpn-instance ipv6-vpn-instance-name ] }
No IPv6-to-IPv4 source address translation policies exist.
vrrp virtual-router-id: Binds the IPv6-to-IPv4 source address translation policy to a VRRP group on the IPv4 network. The virtual-router-id parameter represents the virtual router ID of the VRRP group, in the range of 1 to 255.
acl ipv6: Identifies IPv6 packets for address translation. AFT translates source addresses for IPv6 packets permitted by the ACL.
name ipv6-acl-name: Specifies an IPv6 ACL by its name. The ipv6-acl-name argument is a case-insensitive string of 1 to 63 characters. It must start with an English letter and to avoid confusion, it cannot be all.
number ipv6-acl-number: Specifies an IPv6 ACL by its number in the range of 2000 to 3999.
prefix-nat64 prefix-nat64 prefix-length: Specifies a NAT64 prefix and its prefix length. The prefix-length argument represents a prefix length, which can be 32, 40, 48, 56, 64, or 96. AFT translates source IPv6 addresses for packets whose destination IPv6 addresses match the NAT64 prefix.
address-group group-id: Specifies an AFT address group by its ID in the range of 0 to 65535.
no-pat: Specifies the NO-PAT mode. If you do not specify the keyword, AFT uses the PAT mode.
port-block-size blocksize: Specifies the port block size in the range of 100 to 64512. If you do not specify the option, the port range will not be divided.
extended-block-number extended-block-number: Specifies the number of extended port blocks, in the range of 1 to 5. When the IPv6 address accesses the IPv4 address, but the ports in the selected port block are all occupied, AFT extends port blocks one by one for the IPv6 address. An IPv6 address can be assigned a maximum of extended-block-number extended port blocks.
port-range start-port-number end-port-number: Specifies the start port number and end port number of a port range for the IPv4 address. The value range for the start-port-number argument are is 1024 to 65535, and the default value is 1024. The value range for the end-port-number argument are is 1024 to 65535, and the default value is 65535. The end port number cannot be smaller than the start port number.
interface interface-type interface-number: Specifies an interface by its type and number. AFT translates source IPv6 addresses to the primary IPv4 address of the specified interface.
If you set a port block size, the port range (1024 to 65535) will be divided into port blocks by the port block size. For example, if you set the port block size to 1000, the port range is divided into port blocks 1024 to 2023, 2024 to 3023, and so on. The port blocks are used for PAT.
You must specify different ACLs, NAT64 prefixes, and AFT address groups for different IPv6-to-IPv4 source address translation policies.
You can specify a nonexistent NAT64 prefix in a policy, but the policy takes effect only after you configure the prefix.
An IPv6-to-IPv4 source address translation policy can be bound to only one VRRP group. You can execute this command multiple times to change the bound VRRP group for the policy.
# Map source IPv6 address 3001::5 to source IPv4 address 2.2.2.123.
[Sysname] aft v6tov4 source 3001::5 2.2.2.123
# Configure the device to use AFT address group 0 to translate source addresses for IPv6 packets permitted by ACL 2000.
[Sysname] aft v6tov4 source acl ipv6 number 2000 address-group 0 port-block-size 100
display aft port-block
aft v6tov4 source port-block-group
Use aft v6tov4 source to configure a port block group-based IPv6-to-IPv4 source address static translation policy.
Use undo aft v6tov4 source to delete a port block group-based IPv6-to-IPv4 source address static translation policy.
aft v6tov4 source port-block-group group-id
undo aft v6tov4 source port-block-group group-id
No port block group-based IPv6-to-IPv4 source address static translation policies exist.
group-id: Specifies a port block group by its ID for the policy. The value range is 0 to 65535.
After a policy is created, the device algorithmically maps each IPv6 prefix to a unique IPv4 address and port block pair according to the policy's port block group configuration. If not enough unique IPv4 address and port block pairs are available, excessive IPv6 prefixes will be ignored and IPv6 addresses matching those IPv6 prefixes cannot be translated.
The total number of IPv6 prefixes that can be mapped equals to the total number of unique IPv4 address and port block pairs in the policy, which is calculated as follows:
Total number of IPv6 prefixes that can be mapped = N × M, where:
·     N is the total number of port blocks in the port block group, which is result of dividing the port range by the port block size.
·     M is the total number of IPv4 addresses in the policy available for IPv6-to-IPv4 source address translation.
For example, assuming that a policy contains two IPv4 addresses (X1 and Y1) and n port blocks. The device takes n IPv6 prefixes in the port block group, maps them to the same IPv4 address paired in turn with the first to nth port blocks. The created static port block mappings are as follows:
·     IPv6 prefix x1<-->IPv4 address X1 + Port block 1
·     IPv6 prefix x2<-->IPv4 address X1 + Port block 2
·     IPv6 prefix xn<-->IPv4 address X1 + Port block n
·     IPv6 prefix y1<-->IPv4 address Y1 + Port block 1
·     IPv6 prefix y2<-->IPv4 address Y1 + Port block 2
·     IPv6 prefix yn<-->IPv4 address Y1 + Port block n.
For an IPv6-initiated session packet, AFT first identifies the matching static port block mapping entry based on the IPv6 prefix that the packet's source IPv6 address matches. Then, AFT translates the source IPv6 address of the packet into the IPv4 address and a TCP or UDP port number in the port block of the matching entry.
# Create AFT port block group 1. In the port block group, specify the IPv4 address range, IPv6 prefix range and prefix length, port block size, and port block range.
[Sysname-aft-port-block-group-1] address 10.1.1.1 10.1.1.15
[Sysname-aft-port-block-group-1] ipv6-prefix 100::100 100::a00 120
[Sysname-aft-port-block-group-1] block-size 1024
[Sysname-aft-port-block-group-1] port-range 1024 65535
[Sysname-aft-port-block-group-1] quit
# Create an IPv6-to-IPv4 source address static translation policy based on port block group 1.
[Sysname] aft v6tov4 source port-block-group 1
aft v6tov4 source
block-size
Use block-size to set the port block size for a port block group.
Use undo block-size to restore the default.
block-size block-size-value
undo block-size
The default port block size is 256.
AFT port block group view
block-size-value: Specifies the number of ports per port block, in the range of 1 to 65535.
The port range in a port block group will be divided into port blocks of the specified port block size. AFT pairs each port block in the port range in turn with each IPv4 address and creates one-to-one mappings between the IPv4 address-port block pairs and IPv6 prefixes. Set an appropriate port block size for the port block group to meet the AFT translation requirements.
The number of ports in a port range cannot be smaller than the port block size.
# Set the port block size to 1024 for port block group 1.
[Sysname-port-block-group-1] block-size 1024
aft v6tov4 source
port-range
Use display aft address-group to display AFT address group information.
display aft address-group [ group-id ]
group-id: Specifies an AFT address group ID in the range of 0 to 65535. If you do not specify this argument, the command displays information about all AFT address groups.
# Display information about all AFT address groups.
<Sysname> display aft address-group
There are 3 AFT address groups.
Group ID   VRID   Start address         End address
1                 202.110.10.10         202.110.10.15
2                 202.110.10.20         202.110.10.25
                  202.110.10.30         202.110.10.35
6                 ---                   ---
# Display information about AFT address group 1.
<Sysname> display aft address-group 1
There are n AFT address groups
Total number of existing AFT address groups.
Group ID
Address group ID.
VRID
Virtual router ID of a VRRP group. If no VRRP group is specified, this field displays three hyphens (---).
Start address
Start IP address of an address range. If you do not specify the start address, this field displays three hyphens (---).
End address
End IP address of an address range. If you do not specify the end address, this field displays three hyphens (---).
display aft address-mapping
Use aft address-mapping to display AFT mappings.
In standalone mode:
In IRF mode:
display aft address-mapping [ slot slot-number ]
View
slot slot-number: Specifies an IRF member device by its member ID. If you do not specify a member device, this command displays AFT mappings for all member devices. (In IRF mode.)
# (In standalone mode.) Display AFT mappings.
<Sysname> display aft address-mapping
IPv6: Source IP/port: 2000:0:FF01:101:100::8/1024
      Destination IP/port: 5000::1717:1714/1025
      Protocol: TCP(6)
IPv4: Source IP/port: 1.1.1.1/1031
      Destination IP/port: 23.23.23.20/1025
      Protocol: TCP(6)
Total address mappings found: 1
# (In IRF mode.) Display AFT mappings.
Slot 1:
      Protocol: TCP(6)
      Protocol: TCP(6)
IPv4
IPv4 address information.
IPv6
IPv6 address information.
Source IP/port
Source IP address and port number.
Destination IP/port
Destination IP address and port number.
The fields identify the following information:
·     VPN instance—MPLS L3VPN instance to which the session belongs.
·     VLAN ID—VLAN to which the session belongs for Layer 2 forwarding.
·     Inline ID—Inline to which the session belongs for Layer 2 forwarding.
If no VPN instance, VLAN ID, or Inline ID is specified, a hyphen (-) is displayed for the related field.
Protocol
Transport layer protocol type: DCCP, ICMP, ICMPv6, Raw IP, SCTP, TCP, UDP, or UDP-Lite.
Use display aft configuration to display AFT configuration.
To view AFT configurations by using the display aft configuration command, you must execute commands to configure the configurations first except the AFT ALG configuration.
# Display AFT configuration.
<Sysname> display aft configuration
aft address-group 1
VRID: 1
 address 202.110.10.10 202.110.10.15
 address 101.1.1.100 101.1.1.200
  ip-address 20.1.1.20 20.1.1.30
  ipv6-prefix 100::100 100::110 128
  block-size 100
  port-range 1024 2000
aft prefix-ivi 3000:DB8E::
aft prefix-general 2000:DB8E:: 32
extended-block-number 5 port-range 1024 65535
aft v4tov6 destination acl number 2000 prefix-ivi 3000:DB8E::
aft v4server protocol tcp 3001::5 1800 2.2.2.123 1800
aft turn-off tos
aft log enable
aft log flow-begin
aft log flow-end
aft log port-block withdraw
aft log port-block alarm
 aft enable
aft flow-redirect dynamic disable
AFT ALG:
  DNS        : Enabled
  FTP        : Enabled
  HTTP       : Enabled
  ICMP-ERROR : Enabled
  RTSP       : Enabled
  SIP        : Enabled
  H323       : Enabled
aft address-group XX
AFT address group ID.
VRID
Virtual router ID (VRRP group number).
address
Address ranges in the AFT address group.
aft port-load-balance enable slot XX
AFT port halving is enabled.
The XX is in slot number format, which represents the member ID of an IRF member device.
aft remote-backup port-alloc XX
The XX indicates the AFT port ranges used by the primary and secondary devices in the HA group.
·     primary—The primary device uses the lower half of the port block, and the secondary device uses the higher half of the port block.
·     secondary—The primary device uses the higher half of the port block, and the secondary device uses the lower half of the port block.
aft port-block-group XX
AFT port block identified by ID XX. An AFT port block group contains the following settings:
·     ip-address—IPv4 address ranges used for IPv6-to-IPv4 source address translation.
·     ipv6-prefix—IPv6 prefix ranges for IPv6-to-IPv4 source address translation.
·     block-size—Port block size of the port block group.
·     port-range—Port range of the port block group.
aft prefix-nat64 X:X::X:X
NAT64 prefix address.
aft prefix-ivi X:X::X:X
IVI prefix.
aft prefix-general X:X::X:X
General prefix.
aft v6tov4 source XX
IPv6-to-IPv4 source address translation policy. For more information, see the aft v6tov4 source command.
aft v4tov6 source XX
IPv4-to-IPv6 source address translation policy. For more information, see the aft v4tov6 source command.
aft v4tov6 destination XX
IPv4-to-IPv6 destination address translation policy. For more information, see the aft v4tov6 destination command.
aft v6server
aft v4server
aft turn-off tos
Value of the ToS field in IPv4 packets translated from IPv6 packets.
Value of the Traffic Class field in IPv6 packets translated from IPv4 packets.
aft log enable
AFT logging is enabled.
aft log flow-begin
AFT session establishment logging is enabled.
aft log flow-end
AFT session removal logging is enabled.
aft log port-block-assign
AFT port block assignment logging is enabled.
aft log port-block-withdraw
AFT port block withdrawal logging is enabled.
AFT port block exhaustion logging is enabled.
interface XXX
AFT-enabled interface.
aft enable
AFT is enabled.
AFT ALG
AFT ALG status:
·     Enabled.
·     Disabled.
Dynamic AFT port block mapping synchronization is disabled.
display aft no-pat
Use display aft no-pat to display AFT NO-PAT entries.
In standalone mode:
display aft no-pat
In IRF mode:
display aft no-pat [ slot slot-number ]
slot slot-number: Specifies an IRF member device by its member ID. If you do not specify a member device, this command displays AFT NO-PAT entries for all member devices. (In IRF mode.)
An AFT NO-PAT entry records a mapping between an IPv4 address and an IPv6 address without ports.
# (In standalone mode.) Display AFT NO-PAT entries.
<Sysname> display aft no-pat
IPv6 address: 3006::0002
IPv4 address: 200.100.1.100
IPv4 VPN instance: vpn2
IPv6 VPN instance: vpn1
IPv6 address: 4016::1102
IPv4 address: 202.120.12.110
IPv4 VPN    : vpn2
IPv6 VPN    : vpn1
Total entries found: 2
# (In IRF mode.) Display AFT NO-PAT entries.
Slot 1:
IPv4 VPN    : vpn2
IPv6 VPN    : vpn1
IPv4 VPN    : vpn2
IPv6 VPN    : vpn1
IPv6 address
Original IPv6 address.
IPv4 address
Translated IPv4 address.
IPv4 VPN
VPN instance to which the translated IPv4 address belongs. If the IPv4 address does not belong to a VPN instance, this field is not displayed.
IPv6 VPN
VPN instance to which the original IPv6 address belongs. If the IPv6 address does not belong to a VPN instance, this field is not displayed.
Total entries found
Total number of AFT NO-PAT entries.
Use display aft port-block to display AFT port block mappings.
In standalone mode:
display aft port-block { dynamic | static }
In IRF mode:
display aft port-block { dynamic | static } [ slot slot-number ]
dynamic: Specifies dynamic port block mappings.
static: Specifies static port block mappings.
slot slot-number: Specifies an IRF member device by its member ID. If you do not specify a member device, this command displays AFT port block mappings for all member devices. (In IRF mode.)
# (In standalone mode.) Display dynamic AFT port block mappings.
<Sysname> display aft port-block dynamic
Port block  : [1024 – 1123]
IPv4 VPN    : vpn2
IPv6 VPN    : vpn1
Port-block mapping state: Normal
Port block  : [1024 – 1200]
IPv4 VPN    : vpn2
IPv6 VPN    : vpn1
# (In IRF mode.) Display dynamic AFT port block mappings on the specified slot.
<Sysname> display aft port-block dynamic slot 1
Slot 1:
IPv4 VPN    : vpn2
IPv6 VPN    : vpn1
IPv4 VPN    : vpn2
IPv6 VPN    : vpn1
# (In standalone mode.) Display static AFT port block mappings.
<Sysname> display aft port-block static
IPv6 Prefix:  3006::/16
IPv4 Address: 200.100.1.100
IPv4 VPN    : vpn2
IPv6 VPN    : vpn1
IPv6 Prefix: 4016::/16
IPv4 Address: 202.120.12.110
IPv4 VPN    : vpn2
IPv6 VPN    : vpn1
# (In IRF mode.) Display static AFT port block mappings on slot 1.
<Sysname> display aft port-block static slot 1
Slot 1:
IPv4 VPN    : vpn2
IPv6 VPN    : vpn1
IPv4 VPN    : vpn2
IPv6 VPN    : vpn1
Table 5 Command output
IPv6 address
IPv6 address to be translated. This field is available only in dynamic port block mappings.
IPv6 Prefix
IPv6 prefix to match the IPv6 addresses to be translated. This field is available only in static port block mappings.
IPv4 Address
Port block
Port range for the translated IPv4 address.
IPv4 VPN
IPv6 VPN
State of a dynamic port block. Options are:
·     Normal—Dual-device hot backup has not backed up the dynamic port block or the device works in standalone mode.
·     Backed up—Dual-device hot backup has backed up the dynamic port block.
·     Restored—Dual-device hot backup has restored the dynamic port block from the backup.
Total entries found
Total number of AFT port block mapping entries.
display aft session
Use display aft session to display AFT sessions.
In standalone mode:
display aft session ipv4 [ { source-ip source-ip-address | destination-ip destination-ip-address } * [ vpn-instance ipv4-vpn-instance-name ] ] [ verbose ]
display aft session ipv6 [ { source-ip source-ipv6-address | destination-ip destination-ipv6-address } * [ vpn-instance ipv6-vpn-instance-name ] ] [ verbose ]
In IRF mode:
display aft session ipv4 [ { source-ip source-ip-address | destination-ip destination-ip-address } * [ vpn-instance ipv4-vpn-instance-name ] ] [ slot slot-number ] [ verbose ]
display aft session ipv6 [ { source-ip source-ipv6-address | destination-ip destination-ipv6-address } * [ vpn-instance ipv6-vpn-instance-name ] ] [ slot slot-number ] [ verbose ]
ipv4: Displays IPv4 AFT sessions.
source-ip source-ip-address: Specifies the source IPv4 address of the packets that initiate AFT sessions.
destination-ip destination-ip-address: Specifies the destination IPv4 address of the packets that initiate AFT sessions.
vpn-instance ipv4-vpn-instance-name: Specifies an IPv4 MPLS L3VPN instance by its name, a case-sensitive string of 1 to 31 characters. If you do not specify a VPN instance, this command displays AFT sessions for the public network.
ipv6: Displays IPv6 AFT sessions.
source-ip source-ipv6-address: Specifies the source IPv6 address of the packets that initiate AFT sessions.
destination-ip destination-ipv6-address: Specifies the destination IPv6 address of the packets that initiate AFT sessions.
vpn-instance ipv6-vpn-instance-name: Specifies an IPv6 MPLS L3VPN instance by its name, a case-sensitive string of 1 to 31 characters. If you do not specify a VPN instance, this command displays AFT sessions for the public network.
slot slot-number: Specifies an IRF member device by its member ID. If you do not specify a member device, this command displays AFT sessions for all member devices. (In IRF mode.)
verbose: Display detailed information about AFT sessions. If you do not specify this keyword, this command displays brief information about AFT sessions.
If you do not specify any parameters, this command displays all AFT sessions.
# (In standalone mode.) Display detailed information about AFT sessions.
<Sysname> display aft session ipv4 verbose
Initiator:
  Source      IP/port: 10.1.1.1/280
  Destination IP/port: 20.1.1.1/2048
  DS-Lite tunnel peer: -
  Protocol: ICMP(1)
  Inbound interface: GigabitEthernet1/0/1
  Source security zone: Trust
Responder:
  Source      IP/port: 20.1.1.1/280
  Destination IP/port: 10.1.1.1/0
  Protocol: ICMP(1)
  Inbound interface: GigabitEthernet1/0/2
  Source security zone: Local
State: ICMP_REPLY
Application: ICMP
Rule ID: -/-/-
Rule name:
Start time: 2022-07-15 17:23:16  TTL: 16s
Initiator->Responder:            0 packets          0 bytes
Responder->Initiator:            0 packets          0 bytes
Total sessions found: 1
# (In IRF mode.) Display detailed information about AFT sessions for the specified slot.
<Sysname> display aft session ipv4 slot 1 verbose
Slot 1:
Initiator:
  Source      IP/port: 10.1.1.1/217
  Protocol: ICMP(1)
Responder:
  Source      IP/port: 20.1.1.1/217
  Protocol: ICMP(1)
State: ICMP_REPLY
Application: ICMP
Rule ID: -/-/-
Rule name:
Start time: 2022-07-18 09:42:38  TTL: 28s
Table 6 Command output
Initiator
Session information about the initiator.
Source IP/port
Destination IP/port
DS-Lite tunnel peer
Address of the B4 end on the DS-Lite tunnel. If the session does not belong to any DS-Lite tunnel, this field displays a hyphen (-).
Protocol
Inbound interface
Input interface.
Responder
Session information about the responder.
Security zone to which the input interface belongs.
AFT session state.
Application
Application layer protocol type, such as FTP and DNS.
This field displays unknown for the protocol types that are identified by non-well-known ports and are not user-defined.
Rule ID
ID of the security policy rule.
Rule name
Name of the security policy rule.
Start time
Time when the session starts.
TTL
Remaining lifetime of the session, in seconds.
Number of packets and bytes from the initiator to the responder.
Number of packets and bytes from the responder to the initiator.
Total number of AFT sessions.
reset aft session
display aft statistics
Use display aft statistics to display AFT statistics.
In standalone mode:
In IRF mode:
display aft statistics [ slot slot-number ]
slot slot-number: Specifies an IRF member device by its member ID. If you do not specify a member device, this command displays AFT statistics for all member devices. (In IRF mode.)
If you do not specify any parameters, this command displays all AFT statistics.
# Display all AFT statistics.
<Sysname> display aft statistics
Total NO-PAT entries found: 0
Total port-block entries found: 0
Total IPv4 sessions: 0
Total IPv6 sessions: 0
Dropped packets: 3006
  Configuration sequence changed: 0
  Failed to transfer payload: 0
  Failed to transfer packet header: 0
  Packet examination failed before packet sending: 0
  Failed to translate destination address: 0
  The translated destination address is invalid: 0
  Failed to translate source address: 0
  Failed to transfer FSBUF to MBUF: 0
  Session ext-info is null: 0
  Peer session is null: 0
  Failed to get translation information from session: 0
  Failed to create session: 0
  Failed to fragment the MBUF: 0
  Failed to create fast forwarding table: 0
  Failed to formalize session: 0
  Other reasons: 0
Table 7 Command output
Total number of AFT port block mappings.
Total IPv4 sessions
Total number of AFT IPv4 sessions.
Total IPv6 sessions
Total number of AFT IPv6 sessions.
Dropped packets
Number of packets dropped by AFT.
Number of packets dropped due to configuration sequence changes.
Number of packets dropped due to ALG failures.
Number of packets dropped due to packet header transformation failures.
Number of packets dropped due to packet examination failures before packet sending.
Number of packets dropped due to destination address translation failures.
Number of packets dropped due to the invalidity of the translated destination address.
Number of packets dropped due to source address translation failures.
Number of packets dropped due to FSBUF-to-MBUF transformation failures.
Number of packets dropped due to session extended information acquisition failures.
Number of packets dropped due to peer session lookup failures.
Number of packets dropped due to translation information acquisition failures from sessions.
Number of packets dropped due to session creation failures.
Number of packets dropped due to fragmentation failures.
Number of packets dropped due to fast forwarding table creation failures.
Number of packets dropped due to session formalization failures.
Other reasons
Number of packets dropped due to other reasons.
reset aft statistics
ip-address
Use ip-address to add an IPv4 address range to an AFT port block group.
Use undo ip-address to remove an IPv4 address range from an AFT port block group.
ip-address start-address end-address [ vpn-instance vpn-name ]
undo ip-address start-address end-address [ vpn-instance vpn-name ]
An AFT port block group does not contain IPv4 address ranges.
vpn-instance vpn-name: Specifies an MPLS L3VPN instance to which the IPv4 address or IPv4 address range belongs. The vpn-name argument is a case-sensitive string of 1 to 31 characters. If the IPv4 address or IPv4 address range belongs to the public network, do not specify this option..
For IPv6-initiated session packets, a port block group-based IPv6-to-IPv4 source address translation policy translates the packets' source IPv6 addresses into IPv4 addresses in the address range of the port block group.
You can execute this command multiple times to add multiple IPv4 address ranges to a port block group. When you add address ranges to an AFT port block group, follow these guidelines:
·     Each address range can contain a maximum of 256 addresses.
·     The address ranges within the same port block group cannot not overlap.
·     Different port block group can use overlapping address ranges but the overlapping address ranges must have non-overlapping port ranges.
# Add an IPv4 address range (10.1.1.1 to 10.1.1.15) to AFT port block group 1.
[Sysname-aft-port-block-group-1] ip-address 10.1.1.1 10.1.1.15
aft v6tov4 source
ipv6-prefix
Use ipv6-prefix to add an IPv6 prefix range to an AFT port block group.
Use undo ipv6-prefix to remove an IPv6 prefix range from an AFT port block group.
ipv6-prefix ipv6-start-prefix ipv6-end-prefix prefix-length [ vpn-instance vpn-name ]
undo ipv6-prefix ipv6-start-prefix ipv6-end-prefix prefix-length [ vpn-instance vpn-name ]
An AFT port block group does not contain IPv6 prefix ranges.
ipv6-start-prefix: Specifies the start IPv6 prefix of the IPv6 prefix range.
ipv6-end-prefix: Specifies the end IPv6 prefix of the IPv6 prefix range.
prefix-length: Specifies the prefix length in the range of 1 to 128.
vpn-instance vpn-name: Specifies an IPv6 MPLS L3VPN instance to which the IPv6 addresses belong. The vpn-name argument is a case-sensitive string of 1 to 31 characters. If the IPv6 addresses belong to the public network, do not specify this option.
You can execute this command multiple times to add multiple IPv6 prefix ranges to a port block group. After an IPv6-to-IPv4 source address translation policy is created based on the port block group, the device maps each IPv6 prefix to a unique IPv4 address and port block pair according to the port block group configuration. If not enough unique IPv4 address and port block pairs are available, excessive IPv6 prefixes will be ignored and IPv6 addresses matching those IPv6 prefixes cannot be translated.
The IPv6 prefix ranges within the same AFT port block group must meet the following requirements:
·     IPv6 prefix ranges within the same VPN instance cannot overlap.
·     IPv6 prefix ranges that belong to the public network cannot overlap.
The IPv6 prefix ranges in different AFT port block groups must meet the following requirements:
·     IPv6 prefix ranges in the same VPN instance cannot overlap.
·     IPv6 prefix ranges that belong to the public network can overlap.
# Add an IPv6 prefix range (240E:00D8:8200:0000::/64 to 240E:00D8:8200:0007::/64) to AFT port block group 1.
[Sysname-aft-port-block-group-1] ipv6-prefix 240E:00D8:8200:0000:: 240E:00D8:8200:0007:: 64
aft v6tov4 source
port-range
Use port-range to specify the port range for an AFT port block group.
Use undo port-range to restore the default port range for an AFT port block group.
undo port-range
An AFT port block group uses port range 1 to 65535.
start-port-number end-port-number: Specifies the start and end port numbers for the port  range. The end port number cannot be lower than the start port number. As a best practice, set the start port number to 1024 or higher to avoid application protocol identification errors.
# Specify port range 1024 to 65535 for AFT port block group 1.
·     aft port-block-group
·     aft v6tov4 source
·     block-size
·     display aft configuration
reset aft session
Use reset aft session to clear AFT sessions.
In standalone mode:
reset aft session
In IRF mode:
reset aft session [ slot slot-number ]
slot slot-number: Specifies an IRF member device by its member ID. If you do not specify a member device, this command clears AFT sessions for all member devices. (In IRF mode.)
After you clear AFT sessions, the corresponding AFT NO-PAT entries and port block mappings are also cleared.
# Clear all AFT sessions.
<Sysname> reset aft session
display aft session
Use reset aft statistics to clear AFT statistics.
In standalone mode:
In IRF mode:
reset aft statistics [ slot slot-number ]
slot slot-number: Specifies an IRF member device by its member ID. If you do not specify a member device, this command clears AFT statistics for all member devices. (In IRF mode.)
The AFT statistics include the number of dropped packets, the number of NO-PAT entries, and the number of port block entries. This command only resets the counter for dropped packets.
# Clear all AFT statistics.
<Sysname> reset aft statistics
vrrp vrid
Use vrrp vrid to bind a VRRP group to an AFT address group.
Use undo vrrp vrid to restore the default.
vrrp vrid virtual-router-id
undo vrrp vrid virtual-router-id
An AFT address group is not bound to any VRRP group.
virtual-router-id: Specifies a VRRP group by its virtual router ID in the range of 1 to 255.
If you execute the vrrp vrid command multiple times, the most recent configuration takes effect.
# Bind VRRP group 1 to AFT address group 2.
[Sysname-aft-address-group-2] vrrp vrid 1
  • Become a Partner
  • Partner Resources
