04-Layer 2—LAN Switching Command References
HomeSupportReference GuidesCommand ReferencesH3C MSR610[810][830][1000S][2600][3600] Routers @CR@(V7)-R6749-6W10004-Layer 2—LAN Switching Command References
03-Port isolation commands
03-Port isolation commands 40.05 KB
Layer 2 interface modules MSR1104S-W, MSR1104S-W-CAT6, MSR1104S-5G-CN, MSR1104S-W-5G-CN, SIC-4FSW, and SIC-4FSW-PoE do not support this feature.
display port-isolate group
Use display port-isolate group to display port isolation group information.
# Display port isolation group information.
<Sysname> display port-isolate group
 Port isolation group information:
 Group ID: 1
 Group members:
    GigabitEthernet1/0/2
 Community VLAN ID: 3
Group ID
ID of the isolation group.
Group members
Isolated ports in the isolation group. No ports indicates that the isolation group does not contain isolated ports.
port-isolate enable
port-isolate enable
Use port-isolate enable to assign a port to the isolation group.
Use undo port-isolate enable to remove a port from the isolation group.
port-isolate enable
The port is not assigned to the isolation group.
This command assigns a port to the default isolation group (isolation group 1).
The configuration in Layer 2 Ethernet interface view applies only to the interface.
The configuration in Layer 2 aggregate interface view applies to the Layer 2 aggregate interface and its aggregation member ports. If the device fails to apply the configuration to the aggregate interface, it does not assign any aggregation member port to the isolation group. If the failure occurs on an aggregation member port, the device skips the port and continues to assign other aggregation member ports to the isolation group.
# Assign GigabitEthernet 1/0/1 and GigabitEthernet 1/0/2 to the default isolation group.
[Sysname-GigabitEthernet1/0/1] port-isolate enable
[Sysname-GigabitEthernet1/0/2] port-isolate enable
# Assign Layer 2 aggregate interface Bridge-Aggregation 1 to the default isolation group.
[Sysname-Bridge-Aggregation1] quit
[Sysname-GigabitEthernet1/0/1] port link-aggregation group 1
[Sysname-GigabitEthernet1/0/2] port link-aggregation group 1
[Sysname-GigabitEthernet1/0/2] quit
[Sysname-Bridge-Aggregation1] port-isolate enable
  • Become a Partner
  • Partner Resources
