04-Layer 2—LAN Switching Command References
HomeSupportReference GuidesCommand ReferencesH3C MSR610[810][830][1000S][2600][3600] Routers @CR@(V7)-R6749-6W10004-Layer 2—LAN Switching Command References
02-Ethernet link aggregation commands
02-Ethernet link aggregation commands 269.96 KB
Layer 2 link aggregation is not supported by the following interface modules:
·     DSIC-9FSW.
·     DSIC-9FSW-PoE.
·     MSR810-LMS.
·     MSR810-LM-WiNet.
·     MSR810-LUS.
·     SIC-4FSW.
·     SIC-4FSW-PoE.
·     MSR3640-X1-HI.
·     MSR3660-XS.
·     MSR1104S-W.
·     MSR1104S-W-CAT6.
MSR3600-28-SI and MSR3600-51-SI routers do not support Layer 3 link aggregation.
bandwidth
Use bandwidth to set the expected bandwidth for an interface.
bandwidth bandwidth-value
undo bandwidth
# Set the expected bandwidth to 10000 kbps for Layer 2 aggregate interface Bridge-Aggregation 1.
[Sysname-Bridge-Aggregation1] bandwidth 10000
# Set the expected bandwidth to 10000 kbps for Layer 3 aggregate interface Route-Aggregation 1.
[Sysname-Route-Aggregation1] bandwidth 10000
default
Use default to restore the default settings for an aggregate interface.
default
CAUTION
CAUTION:
The default command might interrupt ongoing network services. Make sure you are fully aware of the impacts of this command when you execute it on a live network.
This command might fail to restore the default settings for some commands for reasons such as command dependencies and system restrictions. Use the display this command in interface view to identify these commands, and then use their undo forms or follow the command reference to restore their default settings. If your restoration attempt still fails, follow the error message instructions to resolve the problem.
# Restore the default settings for Layer 2 aggregate interface 1.
[Sysname-Bridge-Aggregation1] default
# Restore the default settings for Layer 3 aggregate interface 1.
[Sysname-Route-Aggregation1] default
description
The description of an interface is interface-name Interface. For example, the default description of Bridge-Aggregation 1 is Bridge-Aggregation1 Interface.
# Configure the description as connect to the lab for Layer 2 aggregate interface Bridge-Aggregation 1.
[Sysname-Bridge-Aggregation1] description connect to the lab
# Configure the description as connect to the lab for Layer 3 aggregate interface Route-Aggregation 1.
[Sysname-Route-Aggregation1] description connect to the lab
display interface
Use display interface to display aggregate interface information.
display interface [ { bridge-aggregation | route-aggregation } [ interface-number ] ] [ brief [ description | down ] ]
bridge-aggregation: Specifies Layer 2 aggregate interfaces.
route-aggregation: Specifies Layer 3 aggregate interfaces.
interface-number: Specifies an existing aggregate interface number.
down: Displays information about interfaces in down state and the causes for the down state. If you do not specify this keyword, the command displays information about interfaces in all states.
If you do not specify an aggregate interface type, this command displays information about all interfaces except VA interfaces. For more information about VA interfaces, see PPP configuration in Layer 2—WAN Access Configuration Guide.
If you specify an aggregate interface type but do not specify an interface number, this command displays information about all aggregate interfaces of the specified type.
# Display detailed information about Layer 2 aggregate interface Bridge-Aggregation 1.
<Sysname> display interface bridge-aggregation 1
Bridge-Aggregation1
Current state: UP
Line protocol state: UP
IP packet frame type: Ethernet II, hardware address: 000f-e207-f2e0
Description: Bridge-Aggregation1 Interface
Bandwidth: 1000 kbps
PVID: 1
Port link-type: Access
 Tagged VLANs:   None
 UnTagged VLANs: 1
  Last 300 seconds input:  6900 packets/sec 885160 bytes/sec    0%
  Last 300 seconds output:  3150 packets/sec 404430 bytes/sec    0%
  Input (total):  5364747 packets, 686688416 bytes
         2682273 unicasts, 1341137 broadcasts, 1341337 multicasts, 0 pauses
  Input (normal):  5364747 packets, 686688416 bytes
         - ignored, - parity errors
  Output (total): 1042508 packets, 133441832 bytes
         1042306 unicasts, 0 broadcasts, 202 multicasts, - pauses
  Output (normal): 1042508 packets, 133441832 bytes
         1042306 unicasts, 0 broadcasts, 202 multicasts, 0 pauses
         - lost carrier, - no carrier
# Display detailed information about Layer 3 aggregate interface Route-Aggregation 1.
<Sysname> display interface route-aggregation 1
Route-Aggregation1
Current state: UP
Description: Route-Aggregation1 Interface
IP packet frame type: Ethernet II, hardware address: 0000-0000-0000
IPv6 packet frame type: Ethernet II, hardware address: 0000-0000-0000
# Display brief information about Layer 2 aggregate interface Bridge-Aggregation 1.
<Sysname> display interface bridge-aggregation 1 brief
Speed: (a) – auto
BAGG1                UP   auto    A      A    1
# Display brief information about Layer 3 aggregate interface Route-Aggregation 1.
<Sysname> display interface route-aggregation 1 brief
Protocol: (s) - spoofing
RAGG1                UP   UP       --
Bridge-Aggregation1
Layer 2 aggregate interface name.
Route-Aggregation1
Layer 3 aggregate interface name.
Current state
Physical link state of the interface:
·     Administratively DOWN—The interface has been shut down by using the shutdown command.
·     DOWN—The interface is administratively up, but its physical state is down (possibly because no physical link exists or the link has failed).
·     UP—The interface is both administratively and physically up.
IPv4 packet framing format.
Port priority
Port priority of the interface.
Information about the urgent output queue:
·     Size—Number of packets in the queue.
·     Length—Maximum number of packets that the queue can contain.
·     Discards—Number of dropped packets.
Information about the protocol output queue:
Information about the FIFO output queue:
The interface speed and duplex mode are unknown.
Port link-type
Port link type:
·     Access.
·     Trunk.
·     Hybrid.
Tagged VLANs
VLAN whose packets are sent out of this interface with a tag.
Untagged VLANs
VLAN whose packets are sent out of this interface without a tag.
Time when the reset counters interface command was last used to clear the interface statistics. This field displays Never if the reset counters interface command has never been used on the interface since device startup.
Last 300 seconds input/output rate
Average input or output rate over the last 300 seconds.
Input/Output (total)
Statistics of all packets received or sent on the interface.
Input/Output (normal)
Statistics of all normal packets received or sent on the interface.
Line protocol state
Data link layer state of the interface:
·     UP.
·     DOWN.
MTU of the interface.
The interface is not assigned an IP address and cannot process IP packets.
Brief information about Layer 3 interfaces.
Brief information about Layer 2 interfaces.
Abbreviated interface name.
Link
·     UP—The interface is physically up.
·     DOWN—The interface is physically down.
·     ADM—The interface has been shut down by using the shutdown command. To restore the physical state of the interface, use the undo shutdown command.
·     Stby—The interface is a backup interface in standby state.
Speed
Speed of the interface, in bps.
Duplex
Duplex mode of the interface:
Link type of the interface:
·     A—Access.
·     H—Hybrid.
·     T—Trunk.
Protocol
Data link layer protocol state of the interface:
·     UP—The data link layer protocol of the interface is up.
·     DOWN—The data link layer protocol of the interface is down.
·     UP(s)—The data link layer protocol of the interface is up, but the link is an on-demand link or does not exist. The (s) attribute represents the spoofing flag. This value is typical of null interfaces and loopback interfaces.
Primary IP
Primary IP address of the interface. This field displays two hyphens (--) if the interface does not have an IP address.
Cause
Cause for the physical link state of an interface to be DOWN.
display lacp system-id
Use display lacp system-id to display the local system ID.
You can use the lacp system-priority command to change the LACP priority of the local system. The LACP priority value is specified in decimal format in the lacp system-priority command. However, it is displayed in hexadecimal format in the output from the display lacp system-id command.
# Display the local system ID.
<Sysname> display lacp system-id
Actor System ID: 0x8000, 0000-fc00-6504
Local system ID, which contains the system LACP priority (0x8000 in this sample output) and the system MAC address (0000-FC00-6504 in this sample output).
display link-aggregation load-sharing mode
Use display link-aggregation load-sharing mode to display global or group-specific link-aggregation load sharing modes.
display link-aggregation load-sharing mode [ interface [ { bridge-aggregation | route-aggregation } interface-number ] ]
If you do not specify the interface keyword, the command displays the global link-aggregation load sharing modes.
If you specify the interface keyword, but do not specify an interface, the command displays all group-specific load sharing modes.
The bridge-aggregation or route-aggregation keyword is available only when aggregate interfaces of the corresponding type exist on the device.
# Display the global link-aggregation load sharing mode when both hardware-based forwarding and software-based forwarding are used. This example displays the default settings.
<Sysname> display link-aggregation load-sharing mode
Link-aggregation hardware-based forwarding load-sharing mode:
Layer 2 traffic: destination-mac address  source-mac address
Layer 3 traffic: destination-ip address   source-ip address
                 ip-protocol
Layer 4 traffic: destination-port         source-port
MPLS traffic   : mpls-label1
Link-aggregation software-based forwarding load-sharing mode:
Layer 4 traffic: destination-ip address   source-ip address
# Display the global link-aggregation load sharing mode when both hardware-based forwarding and software-based forwarding are used. This example displays user-configured settings.
# Display the link-aggregation load sharing mode of Layer 2 aggregation group 1. This example displays the default settings.
<Sysname> display link-aggregation load-sharing mode interface bridge-aggregation 1
Bridge-Aggregation1 hardware-based forwarding load-sharing mode:
                 ip-protocol
Bridge-Aggregation1 software-based forwarding load-sharing mode:
# Display the link-aggregation load sharing mode of Layer 3 aggregation group 1. This example displays the default settings.
<Sysname> display link-aggregation load-sharing mode interface route-aggregation 1
Route-Aggregation1 load-sharing mode:
Layer 2 traffic: packet type-based sharing
Layer 3 traffic: packet type-based sharing
# Display the link-aggregation load sharing mode of Layer 3 aggregation group 1. This example displays user-configured settings.
destination-mac address, source-mac address
# Display the link-aggregation load sharing mode of Layer 2 aggregation group 1 when both hardware-based forwarding and software-based forwarding are used. This example displays the default settings.
                 ip-protocol
Table 3  Command output
Link-aggregation load-sharing mode
Global link-aggregation load sharing mode.
By default, this field displays the link-aggregation load sharing modes for Layer 2, Layer 3, Layer 4, and MPLS traffic.
If you have configured the global link-aggregation load sharing mode, this field displays the configured mode.
Global link-aggregation load sharing mode for hardware-based forwarding.
Global link-aggregation load sharing mode for software-based forwarding.
Bridge-Aggregation1 load-sharing mode
Link-aggregation load sharing mode of Layer 2 aggregation group 1.
By default, this field displays the global link-aggregation load sharing modes.
If you have configured a link-aggregation load sharing mode for this aggregation group, this field displays the configured mode.
Link-aggregation load sharing mode for hardware-based forwarding of Layer 2 aggregation group 1.
Link-aggregation load sharing mode for software-based forwarding of Layer 2 aggregation group 1.
Link-aggregation load sharing mode of Layer 3 aggregation group 1.
Route-Aggregation1 hardware-based forwarding load-sharing mode
Link-aggregation load sharing mode for hardware-based forwarding of Layer 3 aggregation group 1.
Route-Aggregation1 software-based forwarding load-sharing mode
Link-aggregation load sharing mode for software-based forwarding of Layer 3 aggregation group 1.
Bridge-aggregation1 load sharing enhancement enabled for MPLS traffic
Link-aggregation load sharing enhancement is enabled for MPLS traffic on the aggregate interface.
Layer 2 traffic: destination-mac address, source-mac address
Default link-aggregation load sharing mode for Layer 2 traffic. In this sample output, Layer 2 traffic is load shared based on source and destination MAC addresses.
display link-aggregation member-port
Use display link-aggregation member-port to display detailed link aggregation information about the specified member ports.
display link-aggregation member-port [ interface-list | auto ]
interface-list: Specifies a list of link aggregation member ports, in the format interface-type interface-number1 [ to interface-type interface-number2 ]. The value for the interface-number2 argument must be equal to or greater than the value for the interface-number1 argument.
auto: Specifies all link aggregation member ports that are enabled with automatic assignment.
A member port in a static aggregation group cannot obtain information about the peer group. For such member ports, the command displays the port number, port priority, and operational key of only the local end.
# Display detailed information about GigabitEthernet 1/0/1, which is a member port of a static aggregation group.
<Sysname> display link-aggregation member-port gigabitethernet 1/0/1
       G -- Defaulted, H -- Expired
GigabitEthernet1/0/1:
Port Number: 1
Port Priority: 32768
Oper-Key: 1
# Display detailed information about GigabitEthernet 1/0/2, which is a member port of a dynamic aggregation group.
<Sysname> display link-aggregation member-port gigabitethernet 1/0/2
GigabitEthernet1/0/2:
Local:
    Port Number: 2
    Oper-Key: 2
    Flag: {ACDEF}
Remote:
    Port Number: 26
    Oper-Key: 2
    Flag: {ACDEF}
Received LACP Packets: 5 packet(s)
Illegal: 0 packet(s)
Sent LACP Packets: 7 packet(s)
Flags
LACP state flags. This field is one byte long, represented by ABCDEFGH from the least significant bit to the most significant bit. A letter appears when its bit is 1 and does not appear when its bit is 0.
·     A—Indicates whether LACP is active on the port. 1 indicates active. 0 indicates passive.
·     B—Indicates the LACP timeout interval. 1 indicates the short timeout interval. 0 indicates the long timeout interval.
·     C—Indicates whether the sending system considers that the link is aggregatable. 1 indicates yes. 0 indicates no.
·     D—Indicates whether the sending system considers that the link has been aggregated. 1 indicates yes. 0 indicates no.
·     E—Indicates whether the sending system considers that the link can collect frames. 1 indicates yes. 0 indicates no.
·     F—Indicates whether the sending system considers that the link can distribute frames. 1 indicates yes. 0 indicates no.
·     G—Indicates whether the RX state machine of the sending system is in default state. 1 indicates yes. 0 indicates no.
·     H—Indicates whether the RX state machine of the sending system is in expired state. 1 indicates yes. 0 indicates no.
Aggregate Interface
Aggregate interface to which the member port belongs.
Local
Information about the local end.
Oper-key
Operational key.
Flag
LACP protocol state flag.
Remote
Information about the peer end.
System ID
Peer system ID, containing the system LACP priority and the system MAC address.
Total number of LACP packets received.
Illegal
Total number of illegal packets.
Sent LACP Packets
Total number of LACP packets sent.
display link-aggregation summary
Use display link-aggregation summary to display brief information about all aggregation groups.
Static link aggregation groups cannot obtain information about the peer groups. As a result, the Partner ID field displays None or nothing for a static link aggregation group.
# Display brief information about all aggregation groups.
<Sysname> display link-aggregation summary
Aggregate Interface Type:
BAGG -- Bridge-Aggregation, BLAGG –- Blade-Aggregation, RAGG -- Route-Aggregation, SCH-B – Schannel-Bundle
Aggregation Mode: S -- Static, D -- Dynamic
Actor System ID: 0x8000, 000f-e267-6c6a
AGG        AGG   Partner ID              Selected  Unselected  Individual  Share
Interface  Mode                          Ports     Ports       Ports       Type
RAGG1      S     None                    1         0           0           NonS
BAGG2      D     0x8000,00e0-fcff-ff01   2         0           0           Shar
Table 5 Command output
Aggregate interface type:
·     BAGG—Layer 2.
·     RAGG—Layer 3.
Aggregation Mode
Aggregation group type:
·     S—Static.
·     D—Dynamic.
Loadsharing Type
Load sharing type:
·     Shar—Load-sharing.
·     NonS—Non-load-sharing.
Actor System ID
Local system ID, which contains the local system LACP priority and the local system MAC address.
AGG Interface
Type and number of the aggregate interface.
AGG Mode
Aggregation group type.
Partner ID
System ID of the peer system, which contains the peer system LACP priority and the peer system MAC address.
Selected Ports
Total number of Selected ports.
Unselected Ports
Total number of Unselected ports.
Individual Ports
Total number of Individual ports.
Share Type
Load sharing type.
display link-aggregation troubleshooting
Use display link-aggregation troubleshooting to display the aggregation states of aggregation member ports and the reason why a port was placed in Unselected state.
display link-aggregation troubleshooting [ { bridge-aggregation | route-aggregation } [ interface-number ] ]
interface-number: Specifies an existing aggregate interface by its number.
If you do not specify an aggregate interface type, the command displays information about all aggregation groups.
If you specify an aggregate interface type but do not specify an interface number, the command displays information about all aggregation groups of the specified type.
You can specify the bridge-aggregation or route-aggregation keyword only when aggregate interfaces of the specified type exist on the device.
# Display the aggregation states of aggregation member ports for all aggregation groups and the reason why a port was placed in Unselected state.
<Sysname> display link-aggregation troubleshooting
Aggregate Interface: Bridge-Aggregation2
 Member ports:
  GE1/0/2
   Status: Selected
  GE1/0/3
   Status: Unselected
   Reason: The physical or line protocol state of the port is down
   Advice: Check the connection
Table 6 Command output
Reason
Reason why the port was placed in Unselected state.
Advice
Recommended action.
display link-aggregation verbose
Use display link-aggregation verbose to display detailed information about the aggregation groups that correspond to the specified aggregate interfaces.
display link-aggregation verbose [ { bridge-aggregation | route-aggregation } [ interface-number ] ]
If you do not specify an aggregate interface type, the command displays detailed information about all aggregation groups.
If you specify an aggregate interface type but do not specify an interface number, the command displays detailed information about all aggregation groups of the specified type.
# Display detailed information about Layer 2 aggregation group 1, which is a dynamic aggregation group.
<Sysname> display link-aggregation verbose bridge-aggregation 1
Port: A -- Auto port
Creation Mode: Manual
Aggregation Mode: Dynamic
Local:
  Port             Status  Priority Oper-Key  Flag
  GE1/0/1          S       32768    2         {ACDEF}
  GE1/0/2          S       32768    2         {ACDEF}
  GE1/0/3          S       32768    2         {ACDEF}
Remote:
  Actor            Partner Priority Oper-Key  SystemID               Flag
  GE1/0/1          1       32768    2         0x8000, 000f-e267-57ad {ACDEF}
  GE1/0/2          1       32768    2         0x8000, 000f-e267-57ad {ACDEF}
  GE1/0/3          1       32768    2         0x8000, 000f-e267-57ad {ACDEF}
# Display detailed information about Layer 3 aggregation group 1, which is a dynamic aggregation group.
<Sysname> display link-aggregation verbose route-aggregation 1
Local:
Remote:
# Display detailed information about Layer 2 aggregation group 1, which is a static aggregation group.
Aggregation Mode: Static
  GE1/0/1          S       32768    1
  GE1/0/2          S       32768    1
  GE1/0/3          S       32768    1
# Display detailed information about Layer 3 aggregation group 2, which is a static aggregation group.
<Sysname> display link-aggregation verbose route-aggregation 2
Aggregate Interface: Route-Aggregation2
  GE1/0/1          S       32768    1
  GE1/0/2          S       32768    1
  GE1/0/3          S       32768    1
Table 7 Command output
Loadsharing Type
Load sharing type:
Port Status
Port state:
·     Selected.
·     Unselected.
·     Individual.
Port
Port type. Auto port indicates that the port is enabled with automatic assignment.
Flags
Aggregate Interface
Name of the aggregate interface.
Creation Mode
Creation mode of the dynamic aggregate interface:
·     Auto.
·     Manual.
Aggregation Mode
·     S—Static.
·     D—Dynamic.
System ID
Local system ID, containing the local system LACP priority and the local system MAC address.
Local
Information about the local end:
·     Port—Port type and number.
·     Status—Port state, which can be Selected, Unselected, or Individual.
·     Priority—Port priority.
·     Oper-Key—Operational key.
·     Flag—LACP state flag.
For static aggregation groups, the Flag field is not displayed.
Remote
Information about the peer end:
·     Actor—Type and number of the local port. This field displays the (R) flag next to the port if its peer port is the reference port.
·     Partner—Index of the peer port.
·     Priority—Priority of the peer port.
·     Oper-Key—Operational key of the peer port.
·     System ID—System ID of the peer end.
·     Flag—LACP state flag of the peer end.
Use interface bridge-aggregation to create a Layer 2 aggregate interface and enter its view, or enter the view of an existing Layer 2 aggregate interface.
Use undo interface bridge-aggregation to delete a Layer 2 aggregate interface.
undo interface bridge-aggregation interface-number
No Layer 2 aggregate interfaces exist.
interface-number: Specifies a Layer 2 aggregate interface number. The value range for the interface-number argument is 1 to 8.
When you create a Layer 2 aggregate interface, the system automatically creates a Layer 2 aggregation group with the same number. The aggregation group operates in static aggregation mode by default.
Deleting a Layer 2 aggregate interface also deletes the Layer 2 aggregation group. At the same time, the member ports of the aggregation group, if any, leave the aggregation group.
# Create Layer 2 aggregate interface Bridge-Aggregation 1, and enter its view.
Use interface route-aggregation to create a Layer 3 aggregate interface or subinterface and enter its view, or enter the view of an existing Layer 3 aggregate interface or subinterface.
Use undo interface route-aggregation to delete a Layer 3 aggregate interface or subinterface.
undo interface route-aggregation { interface-number | interface-number.subnumber }
No Layer 3 aggregate interfaces or subinterfaces exist.
interface-number: Specifies a Layer 3 aggregate interface number. The value range for the interface-number argument is 1 to 8.
interface-number.subnumber: Specifies a subinterface of a Layer 3 aggregate interface. The interface-number argument specifies the main interface number. The subnumber argument specifies the subinterface number and is separated from the main interface number by a dot (.). The value range for the subnumber argument is 1 to 4094.
When you create a Layer 3 aggregate interface, the system automatically creates a Layer 3 aggregation group with the same number. The Layer 3 aggregation group operates in static aggregation mode by default.
Deleting a Layer 3 aggregate interface also deletes the Layer 3 aggregation group and all its aggregate subinterfaces. At the same time, the member ports of the aggregation group, if any, leave the aggregation group.
Deleting a Layer 3 aggregate subinterface does not affect the state of the main interface and the corresponding aggregation group.
# Create Layer 3 aggregate interface Route-Aggregation 1 and enter its view.
# Create Layer 3 aggregate subinterface Route-Aggregation 1.1 and enter its view.
[Sysname] interface route-aggregation 1.1
[Sysname-Route-Aggregation1.1]
jumboframe enable
Use jumboframe enable to allow the jumbo frames on an interface to pass through.
Use undo jumboframe enable to deny jumbo frames on an interface.
Use undo jumboframe enable size to restore the default.
jumboframe enable [ size ]
An aggregate interface allows jumbo frames with a maximum length of 1536 bytes to pass through.
size: Specifies the maximum length of jumbo frames, in bytes. The value of this argument is fixed at 1536.
# Allow jumbo frames to pass through on Layer 2 aggregate interface Bridge-Aggregation 1.
<Sysname> System-view
[Sysname-Bridge-Aggregation1] jumboframe enable
# Allow jumbo frames to pass through on Layer 3 aggregate interface Route-Aggregation 1.
[Sysname-Route-Aggregation1] jumboframe enable
lacp default-selected-port disable
Use lacp default-selected-port disable to disable the default port selection action for dynamic aggregation groups.
Use undo lacp default-selected-port disable to enable the default port selection action for dynamic aggregation groups.
The default port selection action is enabled for dynamic aggregation groups.
The default port selection action applies to dynamic aggregation groups.
This action automatically chooses the port with the lowest ID from among all up member ports as a Selected port if none of them has received LACPDUs before the LACP timeout interval expires.
After this action is disabled, a dynamic aggregation group will not have any Selected ports to forward traffic if it has not received LACPDUs before the LACP timeout interval expires.
# Disable the default port selection action.
[Sysname] lacp default-selected-port disable
lacp edge-port
Use lacp edge-port to configure an aggregate interface as an edge aggregate interface.
Use undo lacp edge-port to restore the default.
lacp edge-port
undo lacp edge-port
An aggregate interface does not operate as an edge aggregate interface.
Use this command on the aggregate interface that connects the device to a server if dynamic link aggregation is configured only on the device. This feature improves link reliability by enabling all member ports of the aggregation group to forward packets.
This command takes effect only on an aggregate interface corresponding to a dynamic aggregation group.
Link-aggregation traffic redirection cannot operate correctly on an edge aggregate interface.
# Configure Layer 2 aggregate interface Bridge-Aggregation 1 as an edge aggregate interface.
[Sysname-Bridge-Aggregation1] lacp edge-port
# Configure Layer 3 aggregate interface Route-Aggregation 1 as an edge aggregate interface.
[Sysname-Route-Aggregation1] lacp edge-port
lacp mode
Use lacp mode passive to configure LACP to operate in passive mode on a port.
Use undo lacp mode to restore the default.
lacp mode passive
undo lacp mode
LACP operates in active mode on a port.
This command takes effect only on member ports of dynamic aggregation groups.
When LACP is operating in passive mode on a local member port and its peer port, both ports cannot send LACPDUs. When LACP is operating in active mode on either end of a link, both ports can send LACPDUs.
# Configure LACP to operate in passive mode on GigabitEthernet 1/0/1.
[Sysname-GigabitEthernet1/0/1] lacp mode passive
lacp period short
Use lacp period short to enable the short LACP timeout interval (3 seconds) on an interface.
Use undo lacp period to restore the default.
lacp period short
undo lacp period
The LACP timeout interval is the long timeout interval (90 seconds) on an interface.
# Enable the short LACP timeout interval (3 seconds) on GigabitEthernet 1/0/1.
[Sysname-GigabitEthernet1/0/1] lacp period short
Use lacp system-priority to set the system LACP priority.
Use undo lacp system-priority to restore the default.
lacp system-priority priority
The system LACP priority is 32768.
priority: Specifies the system LACP priority in the range of 0 to 65535. The smaller the value, the higher the system LACP priority.
# Set the system LACP priority to 64.
[Sysname] lacp system-priority 64
link-aggregation port-priority
lacp transparent enable
Use lacp transparent enable to enable transparent LACPDU transmission on an interface.
Use undo lacp transparent enable to disable transparent LACPDU transmission on an interface.
Transparent LACPDU transmission is disabled on an interface.
To establish a dynamic aggregation between two remote CEs, use transparent LACPDU transmission on the PEs to which the CEs are attached.
On the PEs, enable transparent LACPDU transmission on the interfaces that transmit traffic between CEs and PEs and between PEs.
Do not use an interface for dynamic link aggregation if you enable transparent LACPDU transmission on that interface. With transparent LACPDU transmission enabled, an interface cannot be selected for aggregation.
# Enable transparent LACPDU transmission on GigabitEthernet 1/0/1.
<Sysname> system
[Sysname-GigabitEthernet1/0/1] lacp transparent enable
link-aggregation auto-aggregation enable
Use link-aggregation auto-aggregation enable to enable automatic link aggregation.
Use undo link-aggregation auto-aggregation enable to disable automatic link aggregation.
Automatic link aggregation is disabled.
After you enable automatic link aggregation and LLDP on two connected devices, they automatically establish a dynamic link aggregation based on the information in incoming LLDP frames. The devices each automatically create a dynamic aggregate interface and assign the redundant ports connected to the peer to the aggregation group of that interface. If you disable LLDP or automatic link aggregation on one device, that device removes the aggregation member ports from the aggregation group, but it will retain the aggregate interface. This event will not trigger member port removal actions on the peer device.
If automatic link aggregation is enabled, subinterface creation might fail on LLDP-enabled Layer 3 Ethernet interfaces. As a best practice, do not create subinterfaces on LLDP-enabled Layer 3 Ethernet interfaces.
To ensure correct operation of an automatically created aggregate interface, do not modify the configuration on the member ports of its aggregation group. Doing so might cause the member ports to be removed from the aggregation group.
On an interface, the port link-aggregation group setting takes precedence over automatic link aggregation. The interface will not be added to the aggregation group of an automatically created aggregate interface if it has been the member port of a manually created aggregate interface.
# Enable automatic link aggregation.
<Sysname> system
[Sysname] link-aggregation auto-aggregation enable
lldp enable
lldp global enable
link-aggregation bfd ipv4
Use link-aggregation bfd ipv4 to enable BFD for an aggregation group.
Use undo link-aggregation bfd to disable BFD for an aggregation group.
link-aggregation bfd ipv4 source ip-address destination ip-address
The following matrixes show the hardware and command compatibility:
Hardware
Command compatibility
MSR610
No
MSR810-10-PoE
Yes
MSR810, MSR810-W, MSR810-W-DB, MSR810-LM, MSR810-W-LM, , MSR810-LM-HK, MSR810-W-LM-HK, MSR810-LM-CNDE-SJK, MSR810-CNDE-SJK, MSR810-EI, MSR810-LM-EA, MSR810-LM-EI
No
MSR810-LMS, MSR810-LUS
Yes
MSR810-SI, MSR810-LM-SI
Yes
MSR810-LMS-EA, MSR810-LME
No
MSR1004S-5G, MSR1004S-5G-CN
No
MSR1104S-W, MSR1104S-W-CAT6, MSR1104S-5G-CN, MSR1104S-W-5G-CN
No
MSR2600-6-X1, MSR2600-15-X1, MSR2600-15-X1-T
No
MSR2600-10-X1
No
MSR 2630
Yes
MSR3600-28, MSR3600-51
Yes
MSR3600-28-SI, MSR3600-51-SI
Yes
Yes
MSR3600-28-G-DP, MSR3600-51-G-DP
Yes
MSR3610-I-DP, MSR3610-IE-DP, MSR3610-IE-ES, MSR3610-IE-EAD, MSR-EAD-AK770, MSR3610-I-IG, MSR3610-IE-IG
Yes
MSR3610-X1, MSR3610-X1-DP, MSR3610-X1-DC, MSR3610-X1-DP-DC, MSR3620-X1, MSR3640-X1
Yes
MSR 3610, MSR 3620, MSR 3620-DP, MSR 3640, MSR 3660
Yes
MSR3610-G, MSR3620-G
Yes
MSR3640-G
Yes
MSR3640-X1-HI
Yes
Hardware
MSR810-W-WiNet, MSR810-LM-WiNet
No
MSR830-4LM-WiNet
No
MSR830-5BEI-WiNet, MSR830-6EI-WiNet, MSR830-10BEI-WiNet
No
MSR830-6BHI-WiNet, MSR830-10BHI-WiNet
No
MSR2600-6-WiNet
No
MSR2600-10-X1-WiNet
No
MSR2630-WiNet
Yes
MSR3600-28-WiNet
Yes
MSR3610-X1-WiNet
Yes
MSR3610-WiNet, MSR3620-10-WiNet, MSR3620-DP-WiNet, MSR3620-WiNet, MSR3660-WiNet
Yes
Hardware
MSR860-6EI-XS
No
MSR860-6HI-XS
No
MSR2630-XS
No
MSR3600-28-XS
Yes
MSR3610-XS
Yes
MSR3620-XS
Yes
MSR3610-I-XS
Yes
MSR3610-IE-XS
Yes
MSR3620-X1-XS
Yes
MSR3640-XS
Yes
MSR3660-XS
Yes
Hardware
MSR810-LM-GL
No
MSR810-W-LM-GL
No
MSR830-6EI-GL
No
MSR830-10EI-GL
No
MSR830-6HI-GL
No
MSR830-10HI-GL
No
MSR1004S-5G-GL
No
MSR2600-6-X1-GL
No
MSR3600-28-SI-GL
Yes
BFD is disabled for an aggregation group.
source ip-address: Specifies the unicast source IP address of BFD sessions. The source IP address cannot be 0.0.0.0.
destination ip-address: Specifies the unicast destination IP address of BFD sessions. The destination IP address cannot be 0.0.0.0.
Make sure the source and destination IP addresses are reversed between the two ends of an aggregate link. For example, if you execute link-aggregation bfd ipv4 source 1.1.1.1 destination 2.2.2.2 at the local end, execute link-aggregation bfd ipv4 source 2.2.2.2 destination 1.1.1.1 at the peer end. The source and destination IP addresses cannot be the same.
The BFD parameters configured on an aggregate interface take effect on all BFD sessions established by the member ports in its aggregation group. BFD on a link aggregation supports only control packet mode for session establishment and maintenance. The two ends of an established BFD session can only operate in Asynchronous mode. For more information about BFD, see High Availability Configuration Guide.
As a best practice, do not configure BFD for any protocols on a BFD-enabled aggregate interface.
Make sure the number of member ports in the BFD-enabled aggregation group is less than or identical to the number of BFD sessions supported by the device. If the aggregation group contains more member ports than the supported sessions, some Selected ports might change to the Unselected state.
If the number of BFD sessions differs between the two ends of an aggregate link, check their settings for inconsistency in the maximum number of Selected ports. You must make sure the two ends have the same setting for the maximum number of Selected ports.
# Enable BFD for Layer 2 aggregation group 1 and specify the source and destination IP addresses as 1.1.1.1 and 2.2.2.2 for BFD sessions.
[Sysname-Bridge-Aggregation1] link-aggregation bfd ipv4 source 1.1.1.1 destination 2.2.2.2
# Enable BFD for Layer 3 aggregation group 1 and specify the source and destination IP addresses as 1.1.1.1 and 2.2.2.2 for BFD sessions.
[Sysname-Route-Aggregation1] link-aggregation bfd ipv4 source 1.1.1.1 destination 2.2.2.2
link-aggregation global load-sharing mode
Use link-aggregation global load-sharing mode to set the global link-aggregation load sharing mode.
Use undo link-aggregation global load-sharing mode to restore the default.
link-aggregation global load-sharing mode { destination-ip | destination-mac | destination-port | mpls-label1 | source-ip | source-mac | source-port } *
Link aggregation groups distribute traffic based on source and destination IP addresses.
destination-ip: Distributes traffic based on destination IP addresses.
destination-mac: Distributes traffic based on destination MAC addresses.
The following matrixes show the hardware and keyword compatibility:
Hardware
Keyword compatibility
MSR610
No
MSR810-10-PoE
Yes
MSR810, MSR810-W, MSR810-W-DB, MSR810-LM, MSR810-W-LM, MSR810-LM-HK, MSR810-W-LM-HK, MSR810-LM-CNDE-SJK, MSR810-CNDE-SJK, MSR810-EI, MSR810-LM-EA, MSR810-LM-EI
No
No
No
No
No
No
Yes
MSR2600-10-X1
No
MSR 2630
No
No
No
No
Yes
Yes
Yes
Yes
Yes
MSR3640-G
Yes
MSR3640-X1-HI
Yes
Hardware
No
MSR830-4LM-WiNet
No
No
No
MSR2600-6-WiNet
Yes
MSR2600-10-X1-WiNet
No
MSR2630-WiNet
No
MSR3600-28-WiNet
No
MSR3610-X1-WiNet
Yes
Yes
Hardware
MSR860-6EI-XS
No
MSR860-6HI-XS
No
MSR2630-XS
Yes
MSR3600-28-XS
No
MSR3610-XS
Yes
MSR3620-XS
Yes
MSR3610-I-XS
Yes
MSR3610-IE-XS
Yes
MSR3620-X1-XS
Yes
MSR3640-XS
Yes
MSR3660-XS
Yes
Hardware
MSR810-LM-GL
No
MSR810-W-LM-GL
No
MSR830-6EI-GL
No
MSR830-10EI-GL
No
MSR830-6HI-GL
No
MSR830-10HI-GL
No
MSR1004S-5G-GL
No
MSR2600-6-X1-GL
Yes
MSR3600-28-SI-GL
No
destination-port: Distributes traffic based on destination ports.
mpls-label1: Distributes MPLS traffic based on Layer 1 labels.
Hardware
MSR610
No
MSR810-10-PoE
Yes
No
No
No
No
No
No
No
MSR2600-10-X1
No
MSR 2630
No
No
No
No
Yes
Yes
Yes
Yes
Yes
MSR3640-G
Yes
MSR3640-X1-HI
Yes
Hardware
No
MSR830-4LM-WiNet
No
No
No
MSR2600-6-WiNet
Yes
MSR2600-10-X1-WiNet
No
MSR2630-WiNet
No
MSR3600-28-WiNet
No
MSR3610-X1-WiNet
Yes
Yes
Hardware
MSR860-6EI-XS
No
MSR860-6HI-XS
No
MSR2630-XS
No
MSR3600-28-XS
No
MSR3610-XS
Yes
MSR3620-XS
Yes
MSR3610-I-XS
Yes
MSR3610-IE-XS
Yes
MSR3620-X1-XS
Yes
MSR3640-XS
Yes
MSR3660-XS
Yes
Hardware
MSR810-LM-GL
No
MSR810-W-LM-GL
No
MSR830-6EI-GL
No
MSR830-10EI-GL
No
MSR830-6HI-GL
No
MSR830-10HI-GL
No
MSR1004S-5G-GL
No
MSR2600-6-X1-GL
No
MSR3600-28-SI-GL
No
source-ip: Distributes traffic based on source IP addresses.
source-mac: Distributes traffic based on source MAC addresses.
Hardware
MSR610
No
MSR810-10-PoE
Yes
No
No
No
No
No
No
Yes
MSR2600-10-X1
No
MSR 2630
No
No
No
No
Yes
Yes
Yes
Yes
Yes
MSR3640-G
Yes
MSR3640-X1-HI
Yes
Hardware
No
MSR830-4LM-WiNet
No
No
No
MSR2600-6-WiNet
Yes
MSR2600-10-X1-WiNet
No
MSR2630-WiNet
No
MSR3600-28-WiNet
No
MSR3610-X1-WiNet
Yes
Yes
Hardware
MSR860-6EI-XS
No
MSR860-6HI-XS
No
MSR2630-XS
Yes
MSR3600-28-XS
No
MSR3610-XS
Yes
MSR3620-XS
Yes
MSR3610-I-XS
Yes
MSR3610-IE-XS
Yes
MSR3620-X1-XS
Yes
MSR3640-XS
Yes
MSR3660-XS
Yes
Hardware
MSR810-LM-GL
No
MSR810-W-LM-GL
No
MSR830-6EI-GL
No
MSR830-10EI-GL
No
MSR830-6HI-GL
No
MSR830-10HI-GL
No
MSR1004S-5G-GL
No
MSR2600-6-X1-GL
Yes
MSR3600-28-SI-GL
No
source-port: Distributes traffic based on source ports.
If an unsupported load sharing mode is set, the device displays an error message.
# Set the global load sharing mode to load share packets based on destination MAC addresses.
[Sysname] link-aggregation global load-sharing mode destination-mac
bandwidth
link-aggregation ignore vlan
Use link-aggregation ignore vlan to configure a Layer 2 aggregate interface to ignore the specified VLANs.
Use undo link-aggregation ignore vlan to remove the specified ignored VLANs for a Layer 2 aggregate interface.
link-aggregation ignore vlan vlan-id-list
undo link-aggregation ignore vlan vlan-id-list
A Layer 2 aggregate interface does not ignore any VLANs.
vlan-id-list: Specifies a space-separated list of up to 10 VLAN items. Each item specifies a VLAN ID or a range of VLAN IDs in the form of vlan-id1 to vlan-id2. The value range for VLAN IDs is 1 to 4094. The value for the vlan-id2 argument must be equal to or greater than the value for the vlan-id1 argument.
This command takes effect only when the link type of the Layer 2 aggregate interface is hybrid or trunk.
With this command configured, a Layer 2 aggregate interface ignores the permitted VLAN and VLAN tagging mode configuration of the specified VLANs when choosing Selected ports.
# Configure Layer 2 aggregate interface bridge-aggregation 1 to ignore VLAN 50.
[Sysname-Bridge-Aggregation1] link-aggregation ignore vlan 50
link-aggregation lacp isolate
Use link-aggregation lacp isolate to isolate aggregate interfaces on the device.
Use undo link-aggregation lacp isolate to remove aggregate interface isolation.
Aggregate interfaces are not isolated.
Aggregate interface isolation gracefully changes member ports of all dynamic aggregate interfaces to Unselected state. The member ports of the counterpart aggregation groups will also be placed in Unselected state.
This feature takes effect only on dynamic aggregate interfaces. It cannot isolate static aggregate interfaces.
# Isolate aggregate interfaces.
[Sysname] link-aggregation lacp isolate
link-aggregation lacp traffic-redirect-notification enable
Use link-aggregation lacp traffic-redirect-notification enable to enable link-aggregation traffic redirection.
Use undo link-aggregation lacp traffic-redirect-notification enable to disable link-aggregation traffic redirection.
Link-aggregation traffic redirection is disabled.
This feature redirects traffic on a Selected port to the remaining available Selected ports of an aggregation group if the port is shut down by using the shutdown command.
The device does not redirect traffic to member ports that become Selected during the traffic redirection process.
This feature ensures zero packet loss for known unicast traffic, but does not protect unknown unicast traffic.
This feature applies only to dynamic link aggregation groups.
# Enable link-aggregation traffic redirection.
[Sysname] link-aggregation lacp traffic-redirect-notification enable
Use link-aggregation load-sharing mode to set the link-aggregation load sharing mode for an aggregation group.
Use undo link-aggregation load-sharing mode to restore the default.
link-aggregation load-sharing mode { { destination-ip | destination-port | flow-label | source-ip | source-port } * | bandwidth-usage | per-packet }
An aggregation group uses the global link-aggregation load sharing mode.
flow-label: Distributes traffic based on flow labels.
bandwidth-usage: Distributes a data flow to the Selected port that has the lowest bandwidth usage when the first packet of that data flow arrives. In this mode, each flow is identified by an IP five-tuple (source and destination IP addresses, source and destination ports, and protocol).
per-packet: Distributes traffic on a per-packet basis. Traffic is distributed across the Selected member ports in proportion to their expected bandwidth, which is configurable with the bandwidth command.
# Configure Layer 3 aggregation group 1 to load share packets based on destination IP addresses.
[Sysname-Route-Aggregation1] link-aggregation load-sharing mode destination-ip
bandwidth
link-aggregation load-sharing mode local-first
Use link-aggregation load-sharing mode local-first to enable local-first load sharing for link aggregation globally.
Use undo link-aggregation load-sharing mode local-first to disable local-first load sharing for link aggregation globally.
Hardware
MSR610
No
MSR810, MSR810-W, MSR810-W-DB, MSR810-LM, MSR810-W-LM, MSR810-10-PoE, MSR810-LM-HK, MSR810-W-LM-HK, MSR810-LM-CNDE-SJK, MSR810-CNDE-SJK, MSR810-EI, MSR810-LM-EA, MSR810-LM-EI
No
No
No
No
No
No
Yes
MSR2600-10-X1
No
MSR 2630
Yes
Yes
No
Yes
Yes
No
Yes
Yes
Yes
MSR3640-G
Yes
MSR3640-X1-HI
Yes
Hardware
No
MSR830-4LM-WiNet
No
No
No
MSR2600-6-WiNet
Yes
MSR2600-10-X1-WiNet
No
MSR2630-WiNet
Yes
MSR3600-28-WiNet
Yes
MSR3610-X1-WiNet
Yes
Yes
Hardware
MSR860-6EI-XS
No
MSR860-6HI-XS
No
MSR2630-XS
Yes
MSR3600-28-XS
Yes
MSR3610-XS
Yes
MSR3620-XS
Yes
MSR3610-I-XS
No
MSR3610-IE-XS
No
MSR3620-X1-XS
Yes
MSR3640-XS
Yes
MSR3660-XS
No
Hardware
MSR810-LM-GL
No
MSR810-W-LM-GL
No
MSR830-6EI-GL
No
MSR830-10EI-GL
No
MSR830-6HI-GL
No
MSR830-10HI-GL
No
MSR1004S-5G-GL
No
MSR2600-6-X1-GL
Yes
MSR3600-28-SI-GL
No
Local-first load sharing is enabled for link aggregation globally.
Use local-first load sharing in a multichassis link aggregation scenario to distribute traffic preferentially across member ports on the ingress device.
If you disable local-first load sharing, packets of an aggregate interface are load shared among all Selected ports on IRF member devices.
You can configure local-first load sharing globally or on a per-interface basis. An aggregate interface preferentially uses the interface-specific setting. If no interface-specific setting is available, the aggregate interface uses the global setting.
# Disable local-first load sharing for link aggregation globally.
[Sysname] undo link-aggregation load-sharing mode local-first
link-aggregation load-sharing mpls enhanced
Use link-aggregation load-sharing mpls enhanced to enable link-aggregation load sharing enhancement for MPLS packets.
Use undo link-aggregation load-sharing mpls enhanced to disable link-aggregation load sharing enhancement for MPLS packets.
Link-aggregation load sharing enhancement is disabled for MPLS packets.
This command enables an aggregate interface to use the IP five-tuple for MPLS packet distribution. The IP five-tuple contains the source IP address, source port number, destination IP address, destination port number, and protocol number.
Use this command only on the provider (P) device. For information about the P device, see MPLS L3VPN configuration in MPLS Configuration Guide.
# Enable link-aggregation load sharing enhancement for MPLS packets on Route-Aggregation 1.
[Sysname-Route-Aggregation1] link-aggregation load-sharing mpls enhanced
link-aggregation mode
Use link-aggregation mode dynamic to configure an aggregation group to operate in dynamic aggregation mode and enable LACP.
Use undo link-aggregation mode to restore the default.
An aggregation group operates in static aggregation mode.
Aggregation mode change might cause Selected member ports to become Unselected.
When you change the aggregation mode, make sure you understand the impact of the change on services.
# Configure Layer 2 aggregation group 1 to operate in dynamic aggregation mode.
# Configure Layer 3 aggregation group 1 to operate in dynamic aggregation mode.
[Sysname-Route-Aggregation1] link-aggregation mode dynamic
link-aggregation multivlan-termination
Use link-aggregation multivlan-termination to allow a Layer 3 aggregation group to contain Ethernet subinterfaces that terminate different VLANs.
Use undo link-aggregation multivlan-termination to restore the default.
You can only assign subinterfaces that terminate the same VLAN to the same Layer 3 aggregation group.
By default, you can assign only subinterfaces that terminate the same VLAN to the same aggregation group.
This command allows you to assign subinterfaces that terminate different VLANs to the same aggregation group. This command also enables you to assign Ethernet interfaces that do not have subinterfaces and Ethernet subinterfaces to the same aggregation group.
# Allow the aggregation group of Route-Aggregation 1 to contain Ethernet subinterfaces that terminate different VLANs.
[Sysname-Route-Aggregation1] link-aggregation multivlan-termination
Use link-aggregation port-priority to set the port priority of an interface.
Use undo link-aggregation port-priority to restore the default.
The port priority of an interface is 32768.
priority: Specifies the port priority in the range of 0 to 65535. The smaller the value, the higher the port priority.
# Set the port priority to 64 for Layer 2 Ethernet interface GigabitEthernet 1/0/1.
[Sysname-GigabitEthernet1/0/1] link-aggregation port-priority 64
# Set the port priority to 64 for Layer 3 Ethernet interface GigabitEthernet 1/0/2.
[Sysname-GigabitEthernet1/0/2] link-aggregation port-priority 64
link-aggregation selected-port maximum
Use link-aggregation selected-port maximum to set the maximum number of Selected ports allowed in an aggregation group.
Use undo link-aggregation selected-port maximum to restore the default.
link-aggregation selected-port maximum max-number
The maximum number of Selected ports allowed in an aggregation group depends on hardware limitation.
max-number: Specifies the maximum number of Selected ports allowed in an aggregation group. The value range for the max-number argument is 1 to 8.
Executing this command might cause some of the Selected ports in an aggregation group to become Unselected ports.
The maximum number of Selected ports allowed in the aggregation groups must be the same for the local and peer ends.
For an aggregation group, the maximum number of Selected ports must be equal to or higher than the minimum number of Selected ports.
The maximum number of Selected ports allowed in an aggregation group is limited by one of the following values, whichever value is smaller:
·     Maximum number set by using the link-aggregation selected-port maximum command.
·     Maximum number of Selected ports allowed by the link aggregation capability.
You can implement backup between two ports by performing the following tasks:
·     Assigning two ports to an aggregation group.
·     Setting the maximum number of Selected ports to 1 for the aggregation group.
Then, only one Selected port is allowed in the aggregation group at any point in time, while the Unselected port acts as a backup port.
# Set the maximum number of Selected ports to 5 for Layer 2 aggregation group 1.
[Sysname-Bridge-Aggregation1] link-aggregation selected-port maximum 5
# Set the maximum number of Selected ports to 5 for Layer 3 aggregation group 1.
[Sysname-Route-Aggregation1] link-aggregation selected-port maximum 5
link-aggregation selected-port minimum
Use link-aggregation selected-port minimum to set the minimum number of Selected ports in an aggregation group.
Use undo link-aggregation selected-port minimum to restore the default.
The minimum number of Selected ports in an aggregation group is not specified.
min-number: Specifies the minimum number of Selected ports in an aggregation group required to bring up the aggregate interface. The value range for the min-number argument is 1 to 8.
Executing this command might cause all member ports in the aggregation group to become Unselected ports.
The minimum number of Selected ports allowed in the aggregation groups must be the same for the local and peer ends.
For an aggregation group, the minimum number of Selected ports must be equal to or lower than the maximum number of Selected ports.
# Set the minimum number of Selected ports to 3 for Layer 2 aggregation group 1.
[Sysname-Bridge-Aggregation1] link-aggregation selected-port minimum 3
# Set the minimum number of Selected ports to 3 for Layer 3 aggregation group 1.
[Sysname-Route-Aggregation1] link-aggregation selected-port minimum 3
link-aggregation traffic-forwarding-path
Use link-aggregation traffic-forwarding-path to configure a forwarding path for a traffic flow.
Use undo link-aggregation traffic-forwarding-path to restore the default.
link-aggregation traffic-forwarding-path { force | preference } path-id
No forwarding path is configured for traffic flows.
force: Specifies the aggregation member port as the fixed outgoing port to establish a fixed forwarding path.
preference: Specifies the aggregation member as the preferred outgoing port to establish a preferred forwarding path.
path-id: Specifies a path ID in the range of 1 to 4095. The path ID must be identical to the local QoS ID configured in the QoS policy for identifying the traffic flow.
This command takes effect only on aggregation member ports. Execute this command on a member port of an aggregate interface if a deterministic path is required for a traffic flow that uses the aggregate interface as an outgoing interface.
When you use this command, you must use a QoS policy on the incoming interface to identify traffic flows of interest. In the QoS policy, set the local QoS ID marking action in the traffic behavior for each matching traffic flow by using the remark qos-local-id command. Make sure the local QoS ID is identical to the path ID. For more information about configuring a QoS policy, see QoS configuration in ACL and QoS Configuration Guide.
When the traffic flow arrives at the aggregate interface, the aggregate interface forwards it out of the specified fixed or preferred outgoing port if its bandwidth is sufficient.
If the outgoing port does not have sufficient bandwidth, the forwarding behavior depends on the forwarding path type.
·     If a fixed forwarding path is specified, the aggregate interface drops the excess packets.
·     If a preferred path is specified, the aggregate interface hashes the excess packets to other aggregation member ports.
For a traffic flow, you can configure multiple outgoing interfaces, which must be all fixed or preferred.
# Configure aggregation member port GigabitEthernet 1/0/1 as the preferred outgoing port for the traffic flow with local QoS ID 10.
[Sysname-GigabitEthernet1/0/1] link-aggregation traffic-forwarding-path preference 10
remark qos-local-id (ACL and QoS Command Reference)
link-delay
Use link-delay to set the physical state change suppression interval on an aggregate interface.
Use undo link-delay to restore the default.
link-delay [ msec ] delay-time [ mode { up | updown } ]
undo link-delay [ msec ] delay-time [ mode { up | updown } ]
Each time the physical link of an aggregate interface goes up or comes down, the system immediately reports the change to the CPU.
msec: Sets the physical state change suppression interval in milliseconds. If you do not specify this keyword, the suppression interval is in seconds.
delay-time: Sets the physical state change suppression interval. To report a physical state change immediately to the CPU, set the interval to 0.
·     If you do not specify the msec keyword, the value range is 0 to 30 seconds.
·     If you specify the msec keyword, the value range is 0 to 10000 milliseconds, and the value must be a multiple of 100.
mode up: Suppresses link-up events.
mode updown: Suppresses both link-up and link-down events.
You can configure this feature to suppress only link-down events, only link-up events, or both. If an event of the specified type persists when the suppression interval expires, the system reports the event.
When you configure this feature, follow these guidelines:
·     To suppress only link-down events, use the link-delay [ msec ] delay-time command.
·     To suppress only link-up events, use the link-delay [ msec ] delay-time mode up command.
·     To suppress both link-down and link-up events, use the link-delay [ msec ] delay-time mode updown command.
On an interface, you can configure different suppression intervals for link-up and link-down events. If you execute the link-delay command multiple times for link-up or link-down events, the most recent configuration takes effect.
# Set the link-down event suppression interval to 8 seconds on Bridge-Aggregation 1.
[Sysname-Bridge-Aggregation1] link-delay down 8
# Set the link-down event suppression interval to 8 seconds on Route-Aggregation 1.
[Sysname-Route-Aggregation1] link-delay down 8
mtu
Use mtu to set the MTU of a Layer 3 aggregate interface or subinterface.
mtu size
undo mtu
The MTU of Layer 3 aggregate interfaces and subinterfaces is 1500 bytes.
size: Specifies an MTU in bytes. The value range for the size argument is 46 to 9600.
# Set the MTU of interface Route-Aggregation 1 to 1430 bytes.
[Sysname-Route-Aggregation1] mtu 1430
display interface
Use port link-aggregation group to assign an interface to an aggregation group.
Use undo port link-aggregation group to remove an interface from the aggregation group to which it belongs.
An interface does not belong to any aggregation group.
group-id: Specifies an aggregation group by its aggregate interface number. The value range for the group-id argument is 1 to 8.
You can assign a Layer 2 or Layer 3 Ethernet interface only to a Layer 2 or Layer 3 aggregation group, respectively. You cannot assign two Layer 2 Ethernet interfaces located on different cards to the same Layer 2 aggregation group.
An interface can belong to only one aggregation group.
The following restrictions apply if you have not enabled multi-VLAN termination on an aggregate interface by using the link-aggregation multivlan-termination command:
·     You cannot assign both Ethernet interfaces and Ethernet subinterfaces to the aggregation group.
·     You cannot create subinterfaces on an Ethernet interface that is in the aggregation group.
·     You cannot assign an Ethernet interface that has subinterfaces to the aggregation group.
You cannot create aggregate subinterfaces on an aggregate interface if its aggregation group contains Ethernet subinterfaces. You cannot assign Ethernet subinterfaces to an aggregation group if its aggregate interface has aggregate subinterfaces.
Before you assign an Ethernet subinterface to an aggregation group, perform the following tasks:
·     If multi-VLAN termination is not enabled on the aggregate interface, configure VLAN termination on the Ethernet subinterface. You will be unable to modify the VLAN termination configuration after you assign the subinterface to the aggregation group. To configure VLAN termination, use the following commands:
¡     vlan-type dot1q default.
¡     vlan-type dot1q untagged.
¡     vlan-type dot1q vid.
¡     vlan-type dot1q vid second-dot1q.
·     To assign Ethernet subinterfaces that terminate different VLANs to the same aggregation group, enable multi-VLAN termination on the aggregate interface. If multi-VLAN termination is not enabled on the aggregate interface, you must make sure the Ethernet subinterfaces to be assigned to its aggregation group terminate the same VLAN.
·     If you are assigning the Ethernet subinterface to a dynamic aggregation group, specify only one VLAN ID when you execute the vlan-type dot1q vid vlan-id-list [ loose ] command.
# Assign Layer 2 Ethernet interface GigabitEthernet 1/0/1 to Layer 2 aggregation group 1.
[Sysname-GigabitEthernet1/0/1] port link-aggregation group 1
# Assign Layer 3 Ethernet interface GigabitEthernet 1/0/2 to Layer 3 aggregation group 2.
[Sysname-GigabitEthernet1/0/2] port link-aggregation group 2
vlan-type dot1q vid
Use reset counters interface to clear statistics about the specified aggregate interfaces.
reset counters interface [ { bridge-aggregation | route-aggregation } [ interface-number ] ]
bridge-aggregation: Specifies Layer 2 aggregate interfaces.
route-aggregation: Specifies Layer 3 aggregate interfaces.
interface-number: Specifies an existing aggregate interface number.
Use this command to clear history statistics before you collect traffic statistics for a time period.
If you do not specify an aggregate interface type, the command clears statistics about all interfaces in the system except VA interfaces.
If you specify only an aggregate interface type, the command clears statistics about all aggregate interfaces of the specified type.
# Clear the statistics about interface Bridge-Aggregation 1.
<Sysname> reset counters interface bridge-aggregation 1
reset lacp statistics
Use reset lacp statistics to clear LACP statistics about the specified link aggregation member ports.
interface interface-list: Specifies a list of link aggregation member ports, in the format interface-type interface-number1 [ to interface-type interface-number2 ]. The value for the interface-number1 argument must be equal to or greater than the value for the interface-number2 argument. If you do not specify any member ports, the command clears LACP statistics about all member ports.
# Clear LACP statistics about all link aggregation member ports.
<Sysname> reset lacp statistics
shutdown
Use shutdown to shut down an aggregate interface or subinterface
Use undo shutdown to bring up an aggregate interface or subinterface.
shutdown
An interface is not manually shut down.
CAUTION
CAUTION:
The shutdown command will disconnect all links established on an interface. Make sure you are fully aware of the impacts of this command when you use it on a live network.
Shutting down or bringing up a Layer 3 aggregate interface shuts down or brings up its subinterfaces. Shutting down or bringing up a Layer 3 aggregate subinterface does not affect its main interface.
# Bring up Layer 2 aggregate interface Bridge-Aggregation 1.
[Sysname-Bridge-Aggregation1] undo shutdown
# Bring up Layer 3 aggregate interface Route-Aggregation 1.
[Sysname-Route-Aggregation1] undo shutdown
sub-interface rate-statistic
Use sub-interface rate-statistic to enable rate statistics collection for the subinterfaces of a Layer 3 aggregate interface.
Use undo sub-interface rate-statistic to disable rate statistics collection for the subinterfaces of a Layer 3 aggregate interface.
Rate statistics collection is disabled for Layer 3 aggregate subinterfaces.
Rate statistics collection for Layer 3 aggregate subinterfaces is resource intensive. When you use this feature on a live network, make sure you fully understand its impact.
This command enables the device to periodically refresh rate statistics for the subinterfaces of a Layer 3 aggregate interface. The rate statistics are available in two statistics polling intervals after you execute this command. To set the statistics polling interval, use the flow-interval command.
# Enable rate statistics collection for the subinterfaces of Route-Aggregation 1.
[Sysname-Route-Aggregation1] sub-interface rate-statistic
This configuration may make a negative effect on the performance. Are you sure to continue? [Y/N]:y
The configuration will take effect after 2 flow intervals.
flow-interval (Ethernet interface commands)
traffic-statistic enable
Use traffic-statistic enable to enable packet statistics for a Layer 3 aggregate subinterface.
Use undo traffic-statistic enable to disable packet statistics for a Layer 3 aggregate subinterface.
The packet statistics feature is disabled for a Layer 3 aggregate subinterface.
The packet statistics feature is CPU intensive. When you use this command for Layer 3 aggregate subinterfaces, make sure you fully understand its impact on system performance.
You can use the flow-interval command to adjust the interval at which the statistics are polled. To conserve hardware resources, increase the polling interval. For more information about this command, see Ethernet interface commands in Interface Command Reference.
To view packet statistics of Layer 3 aggregate subinterfaces, use the display interface command.
# Enable packet statistics for Layer 3 aggregate subinterface Route-Aggregation 1.1.
[Sysname-Route-Aggregation1.1] traffic-statistic enable
display interface
flow-interval (Interface Command Reference)
  • Become a Partner
  • Partner Resources
