04-WLAN DRS commands | 41.89 KB |
WLAN DRS commands
wlan drs enable
Use wlan drs enable to enable DRS.
Use undo wlan drs enable to disable DRS.
wlan drs [ ipv6 ] enable
undo wlan drs [ ipv6 ] enable
DRS is disabled.
ipv6: Enables DRS for IPv6 packets. If you do not specify this keyword, the command enables DRS for IPv4 packets.
With this feature enabled, DPI report statistics (DRS) classifies user application and URL session information detected by DPI, and stores the statistics in file drs.db in the bash directory of the local SQL database. You can view the statistics on the local database by using SQL database statements or from the Web interface.
# Enable DRS for IPv4 packets.
[Sysname] wlan drs enable
# Enable DRS for IPv6 packets.
[Sysname] wlan drs ipv6 enable
wlan drs report-oasis
Use wlan drs report-oasis to set the DRS information reporting interval and the number of entries to be reported every time.
Use undo wlan drs report-oasis to restore the default.
wlan drs report-oasis { app | url } [ interval interval | number number ] *
undo wlan drs report-oasis { app | url }
The AC reports 10 DRS entries to the cloud platform server every 1000 milliseconds.
app: Specifies user application information.
url: Specifies URL session information.
interval interval: Specifies the reporting interval in the range of 100 to 10000 milliseconds.
number number: Specifies the number of entries to be reported every time, in the range of 1 to 60.
# Set the DRS information reporting interval to 100 seconds, and the number of entries to be reported every time to 20.
[Sysname] wlan drs report-oasis app interval 100 number 20
wlan drs report-oasis enable
Use wlan drs report-oasis enable to enable DRS information reporting to the cloud platform server.
Use undo wlan drs report-oasis enable to disable DRS information reporting to the cloud platform.
DRS information reporting to the cloud platform is enabled.
This feature enables the AC to send a specific number of DRS entries to the cloud platform at the specified interval.
# Enable DRS information reporting to the cloud platform.
[Sysname] wlan drs report-oasis enable
wlan drs wired-statistics enable
Use wlan drs wired-statistics enable to enable DRS for wired clients.
Use undo wlan drs wired-statistics enable to disable DRS for wired clients.
DRS for wired clients is disabled.
This feature enables the AC to send a specific number of DRS entries for wired clients to the cloud platform at the specified interval.
# Enable DRS for wired clients.
[Sysname] wlan drs wired-statistics enable
