03-WAPI commands | 113.32 KB |
display wapi pre-auth statistics
reset wapi pre-auth statistics
wapi msk-rekey client-offline enable
WAPI commands
The following compatibility matrix shows the support of hardware platforms for WAPI:
Model |
Command compatibility |
WX5540X |
Yes |
WX5560X |
Yes |
WX5860X |
No |
Use display wapi pre-auth statistics to display WAPI preauthentication statistics.
display wapi pre-auth statistics [ ap ap-name [ radio radio-id ] ]
ap ap-name: Specifies an AP by its name, a case-sensitive string of 1 to 64 characters. It can contain letters, digits, underlines (_), left square brackets ([), right square brackets (]), forward slashes (/), and hyphens. If you do not specify this option, this command displays WAPI preauthentication statistics for all APs.
radio radio-id: Specifies a radio by its ID. The value for the radio-id argument depends on the AP model. If you do not specify this option, this command displays WAPI preauthentication statistics for all radios on an AP.
# Display WAPI preauthentication statistics for all APs.
<Sysname> display wapi pre-auth statistics
AP name: AP1 Radio ID: 2 SSID: wapi
BSSID: 487a-da52-d4f0
Signature errors: 0
HMAC errors: 0
Authentication failures: 0
Discarded packets: 0
Overtime errors: 27
Format errors: 0
Certificate verification failures: 3
Received WAI packets: 18
Authentication access requests: 8
Certificate authentication responses: 2
Sent WAI packets: 28
Authentication activation packets: 8
Certificate authentication requests: 8
Authentication access responses: 2
Parameter |
AP name |
Name of the AP to which the client is associated. |
Radio ID |
ID of the radio to which the client is associated. |
SSID |
SSID to which the client is associated. |
BSSID |
Basic service set identifier. |
Signature errors |
Number of signature verification failures. |
HMAC errors |
Number of incorrect message authentication codes. |
Authentication failures |
Number of WAI authentication failures. |
Discarded packets |
Number of discarded WAI packets. |
Overtime errors |
Number of WAI packet retransmissions. |
Format errors |
Number of WAI packets with format errors. |
Certificate verification failures |
Number of WAI certificate authentication failures. |
Received WAI packets |
Number of WAI packets received by the radio. |
Authentication access requests |
Number of access authentication requests received by the radio. |
Certificate authentication responses |
Number of certificate authentication responses received by the radio. |
Sent WAI packets |
Number of WAI packets sent by the radio. |
Authentication activation packets |
Number of authentication activation packets sent by the radio. |
Certificate authentication requests |
Number of certificate authentication requests sent by the radio. |
Authentication access responses |
Number of access authentication responses sent by the radio. |
display wapi statistics
Use display wapi statistics to display WLAN Authentication and Privacy Infrastructure (WAPI) statistics.
display wapi statistics [ ap ap-name [ radio radio-id ] ]
ap ap-name: Specifies an AP by its name, a case-sensitive string of 1 to 64 characters. The AP name can contain letters, digits, underscores (_), left brackets ([), right brackets (]), forward slashes (/), and hyphens (-). If you do not specify an AP, this command displays WAPI statistics for all APs.
radio radio-id: Specifies a radio by its ID. The value range for the radio-id argument varies by device model. If you do not specify a radio, this command displays WAPI statistics for all radios of the specified AP.
# Display WAPI statistics for all APs.
<Sysname> display wapi statistics
Signature errors: 0
HMAC errors: 0
Overtime errors: 27
Format errors: 0
Unicast negotiation failures: 0
Multicast negotiation failures: 0
Received WAI packets: 24
Pre-auth start requests: 1
Unicast key negotiation responses: 2
Multicast key responses: 6
Pre-auth packets: 5
Correct packets: 24
Wrong packets: 0
Sent WAI packets: 33
Unicast key negotiation requests: 2
Unicast key negotiation confirmation packets: 2
Multicast key announcements: 6
Pre-auth packets: 5
AP name |
Radio ID |
SSID |
BSSID |
Signature errors |
HMAC errors |
Discarded packets |
Overtime errors |
Format errors |
Number of certificate authentication failures. |
Unicast negotiation failures |
Number of USK negotiation failures. |
Multicast negotiation failures |
Number of MSK negotiation failures. |
Pre-auth start requests |
Number of preauthentication start requests received by the radio. |
Unicast key negotiation responses |
Number of USK negotiation responses received by the radio. |
Multicast key responses |
Number of MSK responses received by the radio. |
Pre-auth packets |
Number of preauthentication packets received by the radio. |
Correct packets |
Number of correct WAI packets received by the radio. |
Wrong packets |
Number of WAI packets with errors received by the radio. |
Sent WAI packets |
Authentication active packets |
Number of authentication activation messages sent by the radio. |
Unicast key negotiation requests |
Number of USK negotiation requests sent by the radio. |
Unicast key negotiation confirmation packets |
Number of USK negotiation acknowledges sent by the radio. |
Multicast key announcements |
Number of MSK advertisements sent by the radio. |
Pre-auth packets |
Number of preauthentication packets sent by the radio. |
reset wapi statistics
display wapi user
Use display wapi user to display information about WAPI users.
display wapi user [ ap ap-name [ radio radio-id ] | user-mac mac-address ]
user-mac mac-address: Specifies a WAPI user by its MAC address in the format of H-H-H.
If you do not specify any options, the command displays information about all WAPI users.
# Display information about all WAPI users.
<Sysname> display wapi user
Total number of users: 1
AP name : ap1
Radio ID : 2
SSID : wapi
BSSID : 487a-da52-d4f0
MAC address : 54dc-1d2d-fb20
VLAN : 1
Authentication method : PSK
Current state : Online
Authentication state : Idle
Unicast key negotiation state : Established
Multicast key negotiation state : Established
Authorization state : Success
Accounting state : Success
Uptime : 01:18:26
AP name |
Radio ID |
SSID |
BSSID |
MAC address |
MAC address of the client. |
VLAN |
ID of the VLAN to which the client belongs. |
Authentication method |
Authentication mode: · PSK—PSK authentication. · Certificate—Certificate authentication. |
Current state |
Current state of the client: · Init—Initializing. · Auth—Authenticated. · USK—The client is in a USK negotiation process. · MSK—The client is in an MSK advertisement process. · Author—Authorized. · Online—Online. · Deactive—Offline. |
Authentication state |
Certificate authentication state: · Idle—Initializing. · Request—Access authentication request in progress. · Response—Certificate authentication response in progress. · Authenticated—Certificate authentication completed. |
Unicast key negotiation state |
USK negotiation state: · Idle—Initializing. · Negotiating—USK negotiation request in progress. · Established—USK negotiation completed. |
Multicast key negotiation state |
MSK negotiation state: · Idle—Initializing. · Negotiating—MSK advertisement in progress. · Established—MSK negotiation completed. |
Authorization state |
Authorization state: · Idle—Initializing. · Waiting—Waiting. · Success—Succeeded. · Fail—Failed. · Timeout—Timed out. |
Accounting state |
Accounting state: · Idle—Initializing. · Waiting—Waiting. · Success—Succeeded. · Fail—Failed. · Timeout—Timed out. |
Online time |
Online duration of the client, in the hh:mm:ss format. |
Use reset wapi pre-auth statistics to clear WAPI preauthentication statistics.
reset wapi pre-auth statistics [ ap ap-name [ radio radio-id ] ]
ap ap-name: Specifies an AP by its name, a case-sensitive string of 1 to 64 characters. It can contain letters, digits, underlines (_), left square brackets ([), right square brackets (]), forward slashes (/), and hyphens. If you do not specify this option, this command clears WAPI preauthentication statistics for all APs.
radio radio-id: Specifies a radio by its ID. The value for the radio-id argument depends on the AP model. If you do not specify this option, this command clears WAPI preauthentication statistics for all radios on an AP.
# Clear WAPI preauthentication statistics for all APs.
<Sysname> reset wapi pre-auth statistics
Use reset wapi statistics to clear WAPI statistics.
reset wapi statistics [ ap ap-name [ radio radio-id ] ]
ap ap-name: Specifies an AP by its name, a case-sensitive string of 1 to 64 characters. The AP name can contain letters, digits, underscores (_), left brackets ([), right brackets (]), forward slashes (/), and hyphens (-). If you do not specify an AP, this command clears WAPI statistics for all APs.
radio radio-id: Specifies a radio by its ID. The value range for the radio-id argument varies by device model. If you do not specify a radio, this command clears WAPI statistics for all radios of the specified AP.
# Clear WAPI statistics for all APs.
<Sysname> reset wapi statistics
wapi authentication method
Use wapi authentication-method to specify an authentication mode for WAPI.
Use undo wapi authentication-method to restore the default.
wapi authentication-method { certificate | certificate-or-psk | psk }
WAPI uses the certificate authentication mode.
Service template view
certificate: Specifies the certificate authentication mode.
certificate-or-psk: Specifies the certificate or PSK authentication mode.
psk: Specifies the PSK authentication mode.
# Configure WAPI to use the certificate authentication mode.
[Sysname] wlan service-template service1
[Sysname-wlan-st-service1] wapi authentication-method certificate
# Configure WAPI to use the certificate or PSK authentication mode.
# Configure WAPI to use the PSK authentication mode.
wapi psk
wapi authentication-server ip
Use wapi authentication-server ip to specify an AS by its IP address.
Use undo wapi authentication-server ip to restore the default.
wapi authentication-server ip ip-address
No AS is specified.
ip-address: Specifies the IP address of the AS.
You can specify only one AS for a service template. If you execute this command multiple times for a service template, the most recent configuration takes effect.
# Specify AS 10.10.1.1 for service template service1.
[Sysname-wlan-st-service1] wapi authentication-server ip 10.10.1.1
wapi bk lifetime
Use wapi bk lifetime to set the BK lifetime.
Use undo wapi bk lifetime to restore the default.
wapi bk lifetime time
The BK lifetime is 43200 seconds.
time: Specifies the BK lifetime in the range of 180 to 604800 seconds.
WAPI updates the BK after the BK expires. WAPI can update the BK only when you enable BK update.
When both BK update and USK update are enabled, WAPI updates the USK every time the BK is updated, regardless of whether the USK has expired or not. The BK lifetime timer is reset after the USK is updated.
# Set the BK lifetime to 1000 seconds.
[Sysname-wlan-st-service1] wapi bk lifetime 1000
wapi bk rekey enable
wapi usk lifetime
wapi usk rekey enable
wapi bk-rekey enable
Use wapi bk-rekey enable to enable BK update.
Use undo wapi bk-rekey enable to disable BK update.
BK update is enabled.
# Enable BK update.
[Sysname-wlan-st-service1] wapi bk-rekey enable
wapi bk lifetime
wapi certificate domain
Use wapi certificate domain to specify a PKI domain and a certificate.
Use undo wapi certificate domain to restore the default.
wapi certificate domain domain-name serial serial-number
No PKI domain or certificate is specified.
domain-name: Specifies a PKI domain by its name, a case-insensitive string of 1 to 31 characters. The argument cannot contain the special characters listed in Table 2.
Character name |
Symbol |
Character name |
Symbol |
Tilde |
Dot |
Asterisk |
Left angle bracket |
Backslash |
Right angle bracket |
Vertical bar |
Quotation marks |
Colon |
Apostrophe |
serial serial-number: Specifies a certificate by its serial number, a case-sensitive string of 1 to 127 characters.
You can specify only one PKI domain and one certificate for a service template. If you execute this command multiple times for a service template, the most recent configuration takes effect.
# Specify PKI domain abc and certificate def for service template service1.
[Sysname-wlan-st-service1] wapi certificate domain abc serial def
wapi domain
Use wapi domain to specify an ISP domain to charge WAPI users.
Use undo wapi domain to restore the default.
wapi domain domain-name
undo wapi domain
No ISP domain is specified, and the system does not charge WAPI users.
domain-name: Specifies an ISP domain by its name, a case-insensitive string of 1 to 255 characters. The name must meet the following requirements:
· The name does not contain a forward slash (/), backslash (\), vertical bar (|), quotation marks ("), colon (:), asterisk (*), question mark (?), left angle bracket (<), right angle bracket (>), or at sign (@).
· The name is not d, de, def, defa, defau, defaul, default, i, if, if-, if-u, if-un, if-unk, if-unkn, if-unkno, if-unknow, or if-unknown.
Make sure the ISP domain specified in this command has been created using the domain command. For more information about the domain command, see AAA commands in User Access and Authentication Command Reference.
In the current software version, the authentication and authorization methods for an ISP domain do not take effect on WAPI users.
# Specify ISP domain abc for WAPI users.
[Sysname-wlan-st-service1] wapi domain abc
wapi enable
Use wapi enable to enable WAPI.
Use undo wapi enable to disable WAPI.
wapi enable
undo wapi enable
WAPI is disabled.
Before enabling WAPI for a service template, disable the service template.
# Enable WAPI for service template service1.
[Sysname-wlan-st-service1] wapi enable
Use wapi msk-rekey client-offline enable to configure WAPI to update the MSK every time a client goes offline.
Use undo wapi msk-rekey client-offline enable to disable this feature.
WAPI does not update the MSK when a client goes offline.
This command takes effect only when you enable MSK update.
# Configure WAPI to update the MSK every time a client goes offline.
[Sysname-wlan-st-service1] wapi msk-rekey enable
[Sysname-wlan-st-service1] wapi msk-rekey client-offline enable
wapi msk-rekey method
Use wapi msk-rekey enable to enable MSK update.
Use undo wapi msk-rekey enable to disable MSK update.
MSK update is enabled.
WAPI updates the MSK after the MSK expires. WAPI can update the MSK only when you enable MSK update.
# Enable MSK update.
Use wapi msk-rekey method to configure the MSK update mode.
Use undo wapi msk-rekey method to restore the default.
wapi msk-rekey method { packet-based [ packet ] | time-based [ interval ] }
WAPI uses the time-based MSK update mode.
packet-based: Specifies the packet-based MSK update mode.
packet: Specifies the number of packets that triggers an MSK update. The value range for this argument is 5000 to 4294967295, and the default value is 10000. The system increases the counter of this argument by one for every 1000 packets.
time-based: Specifies the time-based MSK update mode.
interval: Specifies the MSK update interval in the range of 180 to 604800 seconds. The default value for this argument is 86400.
Make sure MSK update has been enabled before executing this command.
Packet-based MSK update and time-based MSK update are mutually exclusive. If you execute this command multiple times, the most recent configuration takes effect.
# Configure WAPI to update the MSK for every 20000000 packets.
[Sysname-wlan-st-service1] wapi msk-rekey method pack-based 20000
wapi pre-auth enable
Use wapi pre-auth enable to enable WAPI preauthentication.
Use undo wapi pre-auth enable to disable WAPI preauthentication.
WAPI preauthentication is disabled.
With WAPI preauthentication enabled, clients that use WAPI certificate authentication can roam between APs associated with the same AC.
This feature takes effect only on clients that use WAPI certificate authentication.
Assume a client roams from AP 1 to AP 2, WAPI preauthentication operates as follows:
1. The client sends information about the destination AP to which it will roam to the AC when the client comes tries to come online to AP 1 through WAPI certificate authentication. The AC will create a roaming entry for the client. The entry contains the SSID, BKID, authentication method, security authentication mode, and roaming VLAN information for the client.
2. The client roams to AP 2. The AC searches for the roaming entry for the client. If the authentication method is WAPI certificate authentication, and the BKID carried by the client is the same as the BKID cached on the AC, the AC uses the BK for key negotiation and onboards the client.
Enable WAPI preauthentication in service template service1.
[Sysname-wlan-st-service1] wapi pre-auth enable
wapi enable
wapi psk
Use wapi psk to specify a PSK.
Use undo wapi psk to restore the default.
wapi psk { cipher | simple } { hex | string } key
undo wapi psk
No PSK is specified.
simple: Specifies a key in plaintext form. For security purposes, the key specified in plaintext form will be stored in encrypted form.
hex: Specifies a hexadecimal key string.
string: Specifies a character key string.
key: Specifies the key. If you specify a character key string, the plaintext form is a case-sensitive string of 1 to 16 characters and the encrypted form is a case-sensitive string of 1 to 53 characters. If you specify a hexadecimal key string, the plaintext form is a case-insensitive string of 2 to 32 characters and the encrypted form is a case-sensitive string of 2 to 88 characters.
As a best practice, specify a key in the form of a character string that contains 8 or more digits in plain text.
# Specify character string 123456 in plaintext form as the PSK.
[Sysname-wlan-st-service1] wapi psk simple string 123456
# Specify character string 123456 in encrypted form as the PSK.
[Sysname-wlan-st-service1] wapi psk cipher string 123456
# Specify hexadecimal string 123456 in plaintext form as the PSK.
[Sysname-wlan-st-service1] wapi psk simple hex 123456
# Specify hexadecimal string 123456 in encrypted form as the PSK.
[Sysname-wlan-st-service1] wapi psk cipher hex 123456
wapi usk lifetime
Use wapi usk lifetime to set the USK lifetime.
Use undo wapi usk lifetime to restore the default.
wapi usk lifetime time
The USK lifetime is 86400 seconds.
time: Specifies the USK lifetime in the range of 180 to 604800 seconds.
WAPI updates the USK after the USK expires. WAPI can update the USK only when you enable USK update.
# Set the USK lifetime to 1000 seconds.
[Sysname-wlan-st-service1] wapi usk lifetime 1000
wapi usk-rekey enable
Use wapi usk-rekey enable to enable USK update.
Use undo wapi usk-rekey enable to disable USK update.
USK update is enabled.
# Enable USK update.
[Sysname-wlan-st-service1] wapi usk-rekey enable
wapi usk lifetime
