| 04-H3C WBC Multiservice Access Controllers Software Upgrade Guide | 426.88 KB |
H3C WBC Multiservice Access Controllers |
Document version: 6W100-20191125
Copyright © 2023 New H3C Technologies Co., Ltd. All rights reserved.
Upgrading the software of the AC
Upgrading from the BootWare menu
Upgrading from the Web interface
Upgrading from the WBC monitoring platform
Upgrading the update software image package
About the update software image package
Upgrading software
Cloudnet in this document refers to the local Cloudnet on a WBC multiservice access controller (AC).
This document uses a WBC580 G2 multiservice AC as an example to describe the upgrade procedures.
Contents on the Web interface might differ by hardware and software versions.
Upgrade methods
You can upgrade system software by using one of the following methods:
Upgrade method |
Remarks |
· You must reboot the AC to complete the upgrade. · This method can interrupt ongoing network services. |
Use this method when the AC cannot correctly start up. |
This method is simple. |
Preparing for the upgrade
CAUTION: During the upgrade, the AC cannot provide any services. Make sure the upgrade has minimal impact on the network services. |
Before you upgrade system software from the CLI or BootWare menu, complete the following tasks:
· Set up the upgrade environment as shown in Figure 1.
· Configure routes to ensure that the AC and the file server can reach each other.
· Run a TFTP or FTP server on the file server.
· Log in to the CLI of the AC through Telnet or the console port. The WBC580 G2 multiservice AC does not provide physical console ports. To access the CLI through the virtual console port, you must use the HDM dedicated port on the AC to access the H3C WBC system monitoring platform, and click AC console on the page that opens.
· Copy the upgrade file to the file server and correctly set the working directory on the TFTP or FTP server.
Figure 1 Setting up the upgrade environment for upgrading from the CLI or BootWare menu
Before you upgrade system software from the Web interface, complete the following tasks:
· Set up the upgrade environment as shown in Figure 2.
· Configure routes to ensure that the AC and the PC can reach each other.
· Copy the upgrade file to the PC.
Figure 2 Setting up the upgrade environment for upgrading from the Web interface
Upgrading from the CLI
Saving the running configuration and verifying the storage space
1. Execute the save command in any view to save the running configuration.
2. Execute the dir command in user view to display files on the storage medium. Identify the system software image and configuration file names and verify that the storage medium has sufficient space for the new system software image.
Downloading the image file to the AC
You can use the TFTP or FTP commands on the AC to access the TFTP or FTP server to back up or download files.
· Use TFTP
In user view, download the image file (for example, wbc580g2_gl_ac.ipe) to the storage medium on the AC.
<Sysname> tftp 192.168.0.1 get wbc580g2_gl_ac.ipe
Press CTRL+C to abort.
% Total % Received % Xferd Average Speed Time Time Time Current
Dload Upload Total Spent Left Speed
100 295M 100 295M 0 0 651k 0 0:07:43 0:07:43 --:--:-- 531k
Writing file...Done.
<Sysname>
· Use FTP
a. In FTP client view, download the image file (for example, wbc580g2_gl_ac.ipe) to the storage medium on the AC.
<ftp> get wbc580g2_gl_ac.ipe
227 Entering passive mode (192,168,0,1,5,20)
125 Using existing data connection
226 Closing data connection; File transfer successful.
309370880 bytes received in 17.7 seconds (2.03 Mbyte/s)
b. Return to user view.
<ftp> quit
221 Service closing control connection
<Sysname>
Specifying the startup image file
1. Specify the wbc580g2_gl_ac.ipe file as the main image file for the AC at the next reboot.
<Sysname> boot-loader file flash:/wbc580g2_gl_ac.ipe main
Verifying the file flash:/wbc580g2_gl_ac.ipe on the device.....Done.
H3C WBC580g2 images in IPE:
boot.bin
system.bin
This command will set the main startup software images. Please do not reboot the
device during the upgrade. Continue? [Y/N:y
Add images to the device.
File flash:/boot.bin already exists on the device.
File flash:/system.bin already exists on the device.
Overwrite the existing files? [Y/N]:y
Decompressing file boot.bin to flash:/boot.bin......Done.
Decompressing file system.bin to flash:/system.bin...Done.
Verifying the file flash:/boot.bin on the device.....Done.
Verifying the file flash:/system.bin on the device...Done.
The images that have passed all examinations will be used as the main startup so
ftware images at the next reboot on the device.
Decompression completed.
You are recommended to delete the .ipe file after you set startup software image
s for all slots.
Do you want to delete flash:/wbc580g2_gl_ac.ipe now? [Y/N]:y
<Sysname>
2. Verify that the file has been loaded.
<Sysname> display boot-loader
Software images on slot 1:
Current software images:
Image Version
flash:/boot.bin Release 5463P01
flash:/system.bin Release 5463P01
Main startup software images:
Image Version
Backup startup software images:
None
Rebooting the AC to complete the upgrade
1. Reboot the AC.
<Sysname> reboot
Now rebooting, please wait...
<Sysname>
System is starting...
2. After the reboot is complete, verify that the system software version is the same as that of the system software image package.
<Sysname> display version
H3C Comware Software, Version 7.1.064, Release 5463P01
Copyright (c) 2004-2023 New H3C Technologies Co., Ltd. All rights reserved.
H3C WBC580GL uptime is 0 weeks, 0 days, 19 hours, 10 minutes
Last reboot reason : Power on
Boot image: flash:/boot.bin
Boot image version: 7.1.064, Release 5463P01
Compiled Mar 15 2023 16:00:00
System image: flash:/system.bin
System image version: 7.1.064, Release 5463P01
Slot 1
Uptime is 0 week, 0 day, 19 hours, 10 minutes
with 1 2095MHz Multi-core Processor
15914M bytes SDRAM
15328M bytes Flash
PCB Version is Ver.A
Basic Bootrom Version is 1.03
Extend Bootrom Version is 1.05
[Subslot 0]WBC580GL Hardware Version is Ver.A
<Sysname>
CAUTION: · The configuration will be cleared automatically during the software upgrade process. Back up the configuration file for the current software version before upgrade and reconfigure the device by using the backup configuration file after software upgrade. · To upgrade software from the BootWare menu through an Ethernet port, you can use only GE 1/0/1 (1000 Base-T Ethernet interface 1/HDM shared network interface). |
Backing up the running configuration
1. Save the running configuration to the storage medium.
<Sysname> save
Configuration is saved to device successfully.
2. Transfer the configuration file (for example, startup.cfg) to the PC.
<Sysname> tftp 192.168.0.1 put startup.cfg
File will be transferred in binary mode
Sending file to remote TFTP server. Please wait... \
TFTP: 1914 bytes sent in 0 second(s).
File uploaded successfully.
Accessing the EXTEND-BOOTWARE menu
1. Reboot the AC.
Press Ctrl+D to access BASIC-BOOTWARE MENU
Booting Normal Extended BootWare
The Extended BootWare is self-decompressing.................................
...Done.
* H3C WBC580GL BootWare, Version 1.03 *
Compiled Date : May 16 2017
BootWare Validating...
Press Ctrl+B to access EXTENDED-BOOTWARE MENU...
2. Press Ctrl+B at the prompt to access the EXTEND-BOOTWARE menu.
Password recovery capability is enabled.
==========================<EXTENDED-BOOTWARE MENU>=========================
|<1> Boot System |
|<2> Enter Ethernet SubMenu |
|<3> File Control |
|<4> Restore to Factory Default Configuration |
|<5> Skip Current System Configuration |
|<6> Skip Authentication for Console Login |
|<7> BootWare Operation Menu |
|<0> Reboot |
Ctrl+F: Format File System
Ctrl+C: Display Copyright
Enter your choice(0-7):
Table 1 EXTEND-BOOTWARE menu options
Item |
<1> Boot System |
Boot the system software image. |
Access the Ethernet submenu. |
<3> File Control |
Access the File Control submenu. |
Delete the next-startup configuration files and load the factory default configuration. |
Start the AC with the factory default configuration. This is a one-time operation and does not take effect at the next reboot. You use this option when you forget the console login password. |
Clear all the authentication schemes on the console port. |
Access the BootWare Operation menu for backing up, restoring, or upgrading BootWare. When you upgrade the system software image, BootWare is automatically upgraded. As a best practice, do not upgrade BootWare separately. This document does not cover using the BootWare Operation menu. |
<0> Reboot |
Restart the AC. |
Using TFTP or FTP to upgrade software through an Ethernet port
1. In the EXTEND-BOOTWARE menu, enter 2 to access the Ethernet submenu.
==========================<Enter Ethernet SubMenu>==========================
|Note:the operating device is flash |
|<1> Download Image Program To SDRAM And Run |
|<2> Update Main Image File |
|<3> Update Backup Image File |
|<4> Download Files(*.*) |
|<5> Modify Ethernet Parameter |
|<0> Exit To Main Menu |
|<Ensure The Parameter Be Modified Before Downloading!> |
Enter your choice(0-5):
Table 2 Ethernet submenu options
Item |
Download a system software image to the SDRAM and run the image. |
Upgrade the main system software image. |
Upgrade the backup system software image. |
Download a system software image to the storage medium. |
Modify network settings. |
Return to the EXTEND-BOOTWARE menu. |
2. Enter 5 to configure the network settings.
=========================<ETHERNET PARAMETER SET>=========================
|Note: '.' = Clear field. |
| '-' = Go to previous field. |
| Ctrl+D = Quit. |
Protocol (FTP or TFTP) :tftp
Load File Name :wbc580g2_gl_ac.ipe
Target File Name :wbc580g2_gl_ac.ipe
Server IP Address :192.168.0.1
Local IP Address :192.168.0.100
Subnet Mask :255.255.255.0
Gateway IP Address :0.0.0.0
Table 3 Network parameter fields and shortcut keys
'.' = Clear field |
Press a dot (.) and then Enter to clear the setting for a field. |
'-' = Go to previous field |
Press a hyphen (-) and then Enter to return to the previous field. |
Ctrl+D = Quit |
Press Ctrl + D to exit the Ethernet Parameter Set menu. |
Protocol (FTP or TFTP) |
Set the file transfer protocol to FTP or TFTP. |
Load File Name |
Set the name of the file to be downloaded. |
Target File Name |
Set a file name for saving the file on the AC. By default, the target file name is the same as the source file name. |
Server IP Address |
Set the IP address of the FTP or TFTP server. If a mask must be set, use a colon (:) to separate the mask length from the IP address, for example, 192.168.80.10:24. |
Local IP Address |
Set the IP address of the AC. |
Subnet Mask |
Subnet mask of the local IP address. |
Gateway IP Address |
Set a gateway IP address if the AC is on a different network than the server. |
FTP User Name |
Set the username for accessing the FTP server. This username must be the same as that configured on the FTP server. This field is not available for TFTP. |
FTP User Password |
Set the password for accessing the FTP server. This password must be the same as that configured on the FTP server. This field is not available for TFTP. |
3. Enter 2 or 3 in the Ethernet submenu to upgrade a system software image. For example, enter 2 to upgrade the main system software image.
Loading.....................................................................
.........................................Done.
309370880 bytes downloaded!
The file is exist,will you overwrite it? [Y/N]Y
Image file boot.bin is self-decompressing...
Saving file flash:/boot.bin ...........................Done.
Image file system.bin is self-decompressing...
Saving file flash:/system.bin .........................Done.
4. Enter 0 to return to the EXTEND-BOOTWARE menu.
Enter your choice(0-5): 0
===========================<EXTENDED-BOOTWARE MENU>==========================
|<1> Boot System |
|<3> File Control |
|<4> Modify BootWare Password |
|<0> Reboot |
Enter your choice(0-9):
5. Enter 1 to boot the system.
Enter your choice(0-9): 1
Loading the main image files...
Loading file flash:/system.bin...........................Done.
Loading file flash:/boot.bin..............Done.
Image file flash:/boot.bin is self-decompressing..............Done.
System image is starting...
Cryptographic algorithms tests passed.
Line con0 is available.
Press ENTER to get started.
When you upgrade the system software from the Web interface, follow these restrictions and guidelines:
· As a best practice, use one of the following browsers to access the Web interface:
¡ Internet Explorer 10 or higher
¡ Firefox 30.0.0.5269 or higher.
¡ Chrome 35.0.1916.114 or higher.
¡ Safari 6.0 or higher.
· To ensure successful Web access, make sure the browser in use can accept first-party cookies (cookies from the site of the Web interface) and is enabled with Active Scripting (or JavaScript). The names and methods for the features might differ in different browsers.
· If an Internet Explorer is used, make sure the following features are enabled:
¡ Script ActiveX controls marked safe for scripting.
¡ Run ActiveX controls and plugins.
· After software upgrade, first clear cache in the browser and then log in to the Web interface as a best practice.
1. Set the IP address of the PC to an address in the 192.168.0.0/24 segment (except for 192.168.0.100). This section uses 192.168.0.1 as an example.
2. Open a browser, enter the IP address of the AC in the address bar, and then press Enter.
3. On the login page, enter the username and password, and then click Login. By default, both the username and password are admin. You can change the password as prompted.
Figure 3 Logging in to the Web interface
4. Click the system view tab at the bottom of the page.
5. From the left navigation pane, select File Systems > File System Management to verify that the storage medium has sufficient space for the new system software image.
6. From the left navigation pane, select System > Management, and then click the Configuration tab. On the page that opens, click Export Running Configuration.
Figure 4 Exporting the running configuration
7. Click the Upgrade tab. On the page that opens, click Upgrade. In the dialog box that opens, upload the new software image. You can select Reboot now to enable the system to restart the AC immediately after the upgrade completes. Then, click Apply.
8. After AC restarts, re-log in to the Web interface and click the system view tab at the bottom of the page. From the left navigation pane, select System > Management. On the page that opens, click the About tab. Then, view the version information to verify that the system software has been upgraded successfully.
1. Open a browser, enter the login IP address of the WBC monitoring platform in the address bar, and then press Enter. In this example, the Internet Explorer browser is used to access https://192.168.0.101:9999. By default, the URL of the WBC monitoring platform is https://192.168.0.101:9999, the username is admin, and the password is admin.Default.0506.
Figure 5 Logging in to the WBC monitoring platform
2. In the ACs area, click Manage. On the page that opens, click the Update tab.
Figure 6 Update tab
3. (Optional.) On the Update page, click Upload. In the dialog box that opens, click Select File, select the upgrade image files to be uploaded, and then click Upload. After the files are uploaded completely, manually close the dialog box.
Figure 7 Uploading files
4. On the Update page, click Update in the Actions column for the target image file. In the dialog box that opens, click OK.
Figure 8 Upgrading software for the AC
Upgrading Cloudnet
Figure 9 Logging in to the WBC monitoring platform
2. In the Cloudnet area, click Manage.
Figure 10 Cloudnet O&M interface
3. On the Update page, click Upload. In the dialog box that opens, click Select File, select the upgrade image files to be uploaded, and then click Upload. After the files are uploaded completely, manually close the dialog box.
5. After the update is complete, click OK to complete the upgrade.
The update software image package acts as the system upgrade package for the WBC580 G2 multiservice AC. As a best practice to ensure that the AC can operate correctly with the latest features, upgrade the update software image package in a timely manner.
Figure 13 Logging in to the WBC monitoring platform
2. Click the Devices area. On the page that opens, click the Update tab.
Figure 14 Devices O&M interface
5. Select an upgrade method as needed. You can uninstall the current version of software and then install the new version of software or upgrade software directly based on the current version of software.
NOTE: During the uninstall-then-install upgrade process, the device logs out of the current session and returns to the login page. After logging in again, you can see the upgrade progress. Once the upgrade is complete, a prompt message appears to indicate that the upgrade is successful. |
