01-H3C Access Controllers Introduction | 133.12 KB |
New H3C Technologies Co., Ltd. http://www.h3c.com
Document version: 6W100-20220630 |
WX5800H Series Access Controllers
WX5800X Series Access Controllers
WX3800H Series Access Controllers
WX3800X Series Access Controllers
WX2800X Series Access Controllers
WX1800H Series Access Controllers
WSG Series Wireless Integrated Services Gateways
VAC1000 Series Access Controllers
Item |
WX5860H |
Operating system |
Comware 7 |
Interfaces |
· One Console port, 9600 bps (default) to 115200 bps · 8 × 1000BASE-T autosensing Ethernet ports · 12 × 10GBASE-R SFP+ ports · 4 × 40GBase-R QSFP+ ports |
Supported APs by default |
0 |
Maximum number of supported APs |
3072 |
Supported AP license BOM codes |
· 3132A09W (1 AP) · 3130A1L9 (1 AP) · 3130A2HB (4 APs) · 3130A1LA (8 APs) · 3130A1LB (16 APs) · 3130A1LC (32 APs) · 3130A2HC (64 APs) · 3130A1LD (128 APs) · 3130A1QM (512 APs) · 3130A1LE (1024 APs) |
Maximum number of wireless users |
32768 |
Maximum number of local users that can be configured |
32768 |
IRF |
Supported |
Item |
WX5860X |
Operating system |
Comware 7 |
Interfaces |
· 1 × console port · 3 × USB ports · 1× OOBM port Support a maximum of two interface cards. An interface card provides: · 2 × 40G QSFP+ ports · 8 × 10G SFP+ ports · 8 × GE combo interfaces (The 2 × 40G QSFP+ ports and 8 × 10G SFP+ ports are mutually exclusive.) |
0 |
· One interface card: 6656 · Two interface cards: 8192 |
· 3130A1L9(1 AP) · 3132A09W (1 AP) · 3130A2HB (4 APs) · 3130A1LA (8 APs) · 3130A1LB (16 APs) · 3130A1LC (32 APs) · 3130A2HC (64 APs) · 3130A1LD (128 APs) · 3130A1QM (512 APs) · 3130A1LE (1024 APs) |
81920 |
81920 |
IRF |
Supported |
Item |
WX3820H |
WX3840H |
Operating system |
Comware 7 |
Comware 7 |
Interfaces |
· One Console port, 9600 bps (default) to 115200 bps · 8 × 100/1000 BASE-T autosensing Ethernet copper ports · 8 × 100BASE-FX/1000BASE-X SFP ports · 2 × 10GBASE-R SFP+ ports |
· One Console port, 9600 bps (default) to 115200 bps · 8 × 100/1000BASE-T autosensing Ethernet copper ports · 1 × 100/1000BASE-T management Ethernet port · 8 × 100BASE-FX/1000BASE-X SFP ports · 2 × 10GBASE-R SFP+ ports |
0 |
0 |
· 512 (Recommended for local forwarding) · 256 (Recommended for centralized forwarding) |
1024 |
· 3132A09W (1 AP) · 3130A1L9 (1 AP) · 3130A2HB (4 APs) · 3130A1LA (8 APs) · 3130A1LB (16 APs) · 3130A1LC (32 APs) · 3130A2HC (64 APs) · 3130A1LD (128 APs) · 3130A1QM (512 APs) |
8192 |
20480 |
8192 |
20480 |
IRF |
Supported |
Supported |
Item |
WX3820X |
WX3840X |
Operating system |
Comware 7 |
Comware 7 |
Interfaces |
Fixed: · 8 × GE ports · 8 × SFP ports · 1 × OOBM port · 2 × USB ports Expandable: · 8 × GE ports · 2 × SFP+ ports |
Fixed: · 8 × GE ports · 8 × SFP ports · 1 × OOBM port · 2 × USB ports Expandable: · 8 × GE ports · 4 × SFP+ ports |
0 |
0 |
768 |
1536, expandable to 2048 |
· 3130A1L9 (1 AP) · 3132A09W (1 AP) · 3130A2HB (4 APs) · 3130A1LA (8 APs) · 3130A1LB (16 APs) · 3130A1LC (32 APs) · 3130A2HC (64 APs) · 3130A1LD (128 APs) · 3130A1QM (512 APs) |
· 3130A1L9 (1 AP) · 3132A09W (1 AP) · 3130A2HB (4 APs) · 3130A1LA (8 APs) · 3130A1LB (16 APs) · 3130A1LC (32 APs) · 3130A2HC (64 APs) · 3130A1LD (128 APs) · 3130A1QM (512 APs) · 3130A1LE (1024 APs) |
15360 |
30720 |
15360 |
30720 |
IRF |
Not supported |
Not supported |
Item |
WX2812X-PWR |
WX2860X |
WX2880X |
Operating system |
Comware 7 |
Comware 7 |
Comware 7 |
Interfaces |
LAN: · 2 × SFP+ ports · 12 × PoE+ ports WAN: · 2 × GE ports · 1 × USB port |
WAN: · 2 × 2.5GE ports LAN: · 8 × GE ports · 2 × SFP+ ports · 1 × USB port · 1 × console port |
18 |
0 |
0 |
18 |
144 |
288 |
Not supported |
· 3130A1L9 (1 AP) · 3132A09W (1 AP) · 3130A2HB (4 APs) · 3130A1LA (8 APs) · 3130A1LB (16 APs) · 3130A1LC (32 APs) · 3130A2HC (64 APs) · 3130A1LD (128 APs) |
1024 |
4096 |
8192 |
1024 |
4096 |
8192 |
IRF |
Not supported |
Not supported |
Not supported |
Item |
WX1804H-PWR |
WX1810H-PWR |
WX1820H |
WX1840H |
Operating system |
Comware 7 |
Comware 7 |
Comware 7 |
Comware 7 |
Interfaces |
· One Console port, 9600 bps (default) to 115200 bps · 5 × 100/1000BASE-T autosensing Ethernet copper port, including four LAN ports and one WAN port · LAN ports support PoE |
· One Console port, 9600 bps (default) to 115200 bps · 12 × 100/1000BASE-T autosensing Ethernet copper port, including four LAN ports and one WAN port · LAN ports support PoE |
· One Console port, 9600 bps (default) to 115200 bps · 5 × 100/1000BASE-T autosensing Ethernet copper port, including four LAN ports and one WAN port |
· One Console port, 9600 bps (default) to 115200 bps · 8 × 100/1000BASE-T autosensing Ethernet copper port, including six LAN ports and two WAN ports · 1000BASE-X SFP ports 5 and 6 form combo interfaces with 100/1000BASE-T autosensing Ethernet copper ports LAN 5 and LAN 6, respectively. |
4 |
10 |
20 |
20 |
4 |
10 |
20 |
· 128 (Recommended for local forwarding) · 64 (Recommended for centralized forwarding) |
Not supported |
Not supported |
Not supported |
· 3132A09W (1 AP) · 3130A1L9 (1 AP) · 3130A2HB (4 APs) · 3130A1LA (8 APs) · 3130A1LB (16 APs) · 3130A1LC (32 APs) · 3130A2HC (64 APs) |
128 |
320 |
640 |
1280 |
128 |
320 |
640 |
1280 |
IRF |
Not supported |
Not supported |
Not supported |
Not supported |
WBC Series Access Controllers
Item |
WBC580 G2 |
Operating system |
Comware 7 |
Interfaces |
· 2 × embedded 1000 Mbps Ethernet ports · 2 × 10 Gbps Ethernet fiber ports · 1 × HDM dedicated network port |
0 |
2048 |
· 3130A1L9 (1 APs) · 3130A2HB (4 APs) · 3130A1LA (8 APs) · 3130A1LB (16 APs) · 3130A1LC (32 APs) · 3130A2HC (64 APs) · 3130A1LD (128 APs) · 3130A1QM (512 APs) · 3130A1LE (1024 APs) |
32768 |
32768 |
IRF |
Not supported |
Item |
WSG1812X-PWR |
WSG1840X |
Operating system |
Comware 7 |
Comware 7 |
Interfaces |
WAN: · 2 × GE ports LAN: · 2 × SFP+ ports · 12 × GE PoE+ ports |
WAN: · 2 × GE ports LAN: · 1 × SFP+ port · 1 × 2.5GE port · 4 × GE ports |
32 |
64 |
64 |
128 |
Not supported |
Not supported |
1024 |
2048 |
1024 |
2048 |
IRF |
Not supported |
Not supported |
Item |
VAC1000 |
Operating system |
Comware 7 |
32 (180-day trial license) |
2048 |
· 3130A1Q9 (8 APs, 1-year) · 3130A1QA (8 APs, 3-year) · 3130A1QB (8 APs, permanent) · 3130A1QC (8 APs, 1-year) · 3130A1QD (8 APs, 3-year) · 3130A1QE (8 APs, permanent) · 3130A1QG (8 APs, 1-year) · 3130A1QH (8 APs, 3-year) · 3130A1QF (8 APs, permanent) |
32768 |
32768 |
IRF |
Not supported |
