- H3C WSG1812X-PWR Wireless Integrated Services Gateway Installation Guide-5W104
- 01-Preparing for installation
- 02-Installing the device
- 03-Log in to the device
- 04-Hardware management and maintenance
- 05-Troubleshooting
- 06-Appendix A Chassis views and technical specifications
- 07-Appendix B LEDs
- 08-Appendix C Optional transceiver modules
| 07-Appendix B LEDs | 80.20 KB |
1 Appendix B LEDs
LEDs
(1) System status LED (SYS) |
(2) 100/1000MBASE-T autosensing port LEDs |
(3) 100/1000BASE-T-PoE+ autosensing port LEDs |
(4) 10GBASE-R-SFP+ port LED |
(5) 10GBASE-R-SFP+ port LED |
LED description
LED |
Mark |
Status |
System status LED |
SYS |
Flashing green (4 Hz) |
The system is starting up. |
Flashing green (0.5 Hz) |
The system is operating correctly. |
Steady red |
A critical alarm has occurred, such as a fan tray alarm, high temperature alarm, or software missing alarm. |
Off |
The device has not started up. |
100/1000M autosensing port LEDs |
100/1000BASE-T or 100/1000BASE-T-PoE+ |
Steady green |
A 100/1000 Mbps link is present on the port. |
Flashing green |
The port is receiving or transmitting data at 100/1000 Mbps. |
Off |
No link is present on the port. |
SFP+ port LEDs |
10GBASE-R-SFP+ |
Steady green |
A 1000 Mbps or 10 Gbps link is present on the port. |
Flashing green |
The port is receiving or sending data at 1000 Mbps or 10 Gbps. |
Off |
