- H3C WSG1812X-PWR Wireless Integrated Services Gateway Installation Guide-5W104
- 01-Preparing for installation
- 02-Installing the device
- 03-Log in to the device
- 04-Hardware management and maintenance
- 05-Troubleshooting
- 06-Appendix A Chassis views and technical specifications
- 07-Appendix B LEDs
- 08-Appendix C Optional transceiver modules
| 04-Hardware management and maintenance | 89.74 KB |
WSGContents
1 Hardware management and maintenance
Displaying hardware information about the device
Displaying software and hardware version information about the device
Displaying the operational statistics about the device
Displaying information about the device
Displaying electrical label information for the device
Displaying the CPU usage of the device
Displaying the memory usage of the device
The command lines and outputs depend on the software version that runs on the device.
Use the display version command to display software and hardware version information about the device. The output includes the following information:
· Current software version.
· Current hardware version.
· Device operating time.
The output depends on the software and hardware version of the device.
<H3C> display version
H3C Comware Software, Version 7.1.064, Alpha 5611
Copyright (c) 2004-2022 New H3C Technologies Co., Ltd. All rights reserved.
H3C WSG1812X-PWR uptime is 0 weeks, 0 days, 0 hours, 3 minutes
Last reboot reason : Power on
Boot image: flash:/boot.bin
Boot image version: 7.1.064, Alpha 5611
Compiled Jun 13 2022 15:00:00
System image: flash:/system.bin
System image version: 7.1.064, Alpha 5611
with 1 ARM 2000MHz Processor
2048M bytes DDR4
3776M bytes EMMC Memory
Hardware Version is Ver.A
CPLD Version is 001
Basic Bootrom Version is 0.53
Extend Bootrom Version is 0.53
[Subslot 0]H3C WSG1812-PWR Hardware Version is Ver.A
When you perform routine maintenance or the system fails, you might need to display the operational information of each feature module to locate failures. Typically, you need to run the display commands individually. However, you can use the display diagnostic-information command in any view to display or save the operational statistics of multiple feature modules of the device. This command displays the output of the display clock, display version, display device, and display current-configuration commands.
· Save the operational statistics for each feature module of the device:
<H3C> display diagnostic-information
Save or display diagnostic information (Y=save, N=display)? [Y/N]:y
Please input the file name(*.tar.gz)[flash:/diag_H3C_20220713-024922.tar.gz]:
Diagnostic information is outputting to flash:/diag_H3C_20220713-024922.tar.gz.
Please wait...
Save successfully.
To view the contents of the default.diag file, execute the more default.diag command in user view, and then press the Page Up and Page Down keys.
· Display the operational statistics for each feature module of the device. (Details not shown.)
01:40:29 UTC Sat 03/11/2023
H3C WSG1812X-PWR uptime is 0 weeks, 0 days, 0 hours, 12 minutes
2048M bytes DDR4
Use the display device command to display information about the device.
<H3C> display device
Slot No. Subslot No. Board Type Status Max Ports
1 0 H3C WSG1812-PWR Normal 16
Table1-1 Command output
Board Type |
Device type. |
Status |
Device status: · Fault—The device is faulty and cannot start up correctly. · Normal—The device is operating correctly. |
Max Ports |
Maximum number of ports supported. |
An electrical label is a profile of a device. It contains the permanent configuration, including the serial number, manufacturing date, MAC address, and vendor name.
Use the display device manuinfo command to display the electrical label information for the device.
<H3C> display device manuinfo
DEVICE_NAME:WSG1812X-PWR
DEVICE_SERIAL_NUMBER:DPPMWWB123456
MAC_ADDRESS:000f-e212-6103
MANUFACTURING_DATE:2006-08-08
VENDOR_NAME:H3C
Table1-2 Command output
DEVICE_NAME |
Device model. |
DEVICE_SERIAL_NUMBER |
Serial number of the device. |
MAC_ADDRESS |
MAC address of the device. |
MANUFACTURING_DATE |
Manufacturing data of the device. |
VENDOR_NAME |
Vendor name. |
Use the display cpu-usage command to display the CPU usage statistics for the device.
<H3C> display cpu-usage
Unit CPU usage:
3% in last 5 seconds
3% in last 1 minute
4% in last 5 minutes
Table1-3 Command output
3% in last 5 seconds |
Average CPU usage in the last 5 seconds (after the device boots, the device calculates and records the average CPU usage at the interval of 5 seconds). |
3% in last 1 minute |
Average CPU usage in the last minute (after the device boots, the device calculates and records the average CPU usage at the interval of 1 minute). |
4% in last 5 minutes |
Average CPU usage in the last 5 minutes (after the device boots, the device calculates and records the average CPU usage at the interval of 5 minutes). |
Use the display memory command to display the memory usage statistics for the device.
<H3C> display memory
Memory statistics are measured in KB:
Slot 1:
Total Used Free Shared Buffers Cached FreeRatio
Mem: 1995224 995016 1000208 0 6120 290652 50.7%
-/+ Buffers/Cache: 698244 1296980
Swap: 0 0 0
Mem |
Memory usage information. |
Total |
Total size of the physical memory space that can be allocated. |
Used |
Used physical memory. |
Free |
Free physical memory. |
Shared |
Physical memory shared by processes. |
Buffers |
Physical memory used for buffers. |
Cached |
Used physical memory for cache. |
FreeRatio |
Free memory ratio. |
–/+ Buffers/Cache |
· -/+ Buffers/Cache:used = Mem:Used – Mem:Buffers – Mem:Cached, which indicates the physical memory used by applications. · -/+ Buffers/Cache:free = Mem:Free + Mem:Buffers + Mem:Cached, which indicates the physical memory available for applications. |
Swap |
Swap memory. |
Rebooting the device
To reboot the device, use one of the following methods:
· Reboot the device at the CLI. You can remotely reboot the device in either of the following ways:
¡ Reboot the device immediately by using the reboot command.
¡ Schedule a reboot to occur at a specific time or date or after a delay by using the schedule reboot command.
· Power off and power on the device. This method cuts off the power of the device forcibly, which might cause data loss. It is the least-preferred method.
· Before you reboot the device, perform the following tasks:
¡ Use the save command to save the running configuration. For more information about the save command, see configuration file management commands in H3C WSG1812X-PWR Wireless Integrated Services Gateway Fundamentals Command Reference.
¡ Use the display startup and display boot-loader commands to verify that you have specified the correct next-startup configuration files and startup software images. If the main startup software image is corrupt or does not exist, a reboot failure will occur. To avoid a reboot failure, use the boot-loader file command to specify a new startup software image. For more information about the display startup and display boot-loader commands, see software upgrade commands in H3C WSG1812X-PWR Wireless Integrated Services Gateway Fundamentals Command Reference.
· The device will not reboot if a file is being accessed.
Configuration procedure
Rebooting the device immediately
Task |
Command |
Remarks |
Reboot the device immediately. |
reboot [ force ] |
Available in user view. |
Scheduling a reboot for the device
Task |
Command |
Remarks |
Schedule a reboot. |
· Schedule a reboot to occur at a specific time or date: · Schedule a reboot to occur after a delay: |
Use either command. By default, no reboot date or time or reboot delay time is specified. Available in user view. The most recent configuration takes effect if you execute the scheduler reboot at or scheduler reboot delay command multiple times. |
